[U-Boot] [PATCH] dm: pcie: designware: add correct ATU handling
Currently, ATU (address translation unit) implementation doesn't support translate addresses > 32 bits.
This patch allows to configure ATU correctly for different memory accesses (memory, configuration and IO). The same approach is used in Linux Kernel.
Signed-off-by: Igal Liberman igall@marvell.com --- drivers/pci/pcie_dw_mvebu.c | 91 +++++++++++++++++++++++++++++---------------- 1 file changed, 58 insertions(+), 33 deletions(-)
diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index a198855..a0032b7 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -111,6 +111,10 @@ struct pcie_dw_mvebu { void *cfg_base; fdt_size_t cfg_size; int first_busno; + + /* IO and MEM PCI regions */ + struct pci_region io; + struct pci_region mem; };
static int pcie_dw_get_link_speed(const void *regs_base) @@ -126,6 +130,34 @@ static int pcie_dw_get_link_width(const void *regs_base) }
/** + * pcie_dw_prog_outbound_atu() - Configure ATU for outbound accesses + * + * @pcie: Pointer to the PCI controller state + * @index: ATU region index + * @type: ATU accsess type + * @cpu_addr: the physical address for the translation entry + * @pci_addr: the pcie bus address for the translation entry + * @size: the size of the translation entry + */ +static void pcie_dw_prog_outbound_atu(struct pcie_dw_mvebu *pcie, int index, + int type, u64 cpu_addr, u64 pci_addr, + u32 size) +{ + writel(PCIE_ATU_REGION_OUTBOUND | index, + pcie->ctrl_base + PCIE_ATU_VIEWPORT); + writel(lower_32_bits(cpu_addr), pcie->ctrl_base + PCIE_ATU_LOWER_BASE); + writel(upper_32_bits(cpu_addr), pcie->ctrl_base + PCIE_ATU_UPPER_BASE); + writel(lower_32_bits(cpu_addr + size - 1), + pcie->ctrl_base + PCIE_ATU_LIMIT); + writel(lower_32_bits(pci_addr), + pcie->ctrl_base + PCIE_ATU_LOWER_TARGET); + writel(upper_32_bits(pci_addr), + pcie->ctrl_base + PCIE_ATU_UPPER_TARGET); + writel(type, pcie->ctrl_base + PCIE_ATU_CR1); + writel(PCIE_ATU_ENABLE, pcie->ctrl_base + PCIE_ATU_CR2); +} + +/** * set_cfg_address() - Configure the PCIe controller config space access * * @pcie: Pointer to the PCI controller state @@ -143,27 +175,29 @@ static uintptr_t set_cfg_address(struct pcie_dw_mvebu *pcie, pci_dev_t d, uint where) { uintptr_t va_address; + u32 atu_type;
/* * Region #0 is used for Outbound CFG space access. * Direction = Outbound * Region Index = 0 */ - writel(0, pcie->ctrl_base + PCIE_ATU_VIEWPORT);
if (PCI_BUS(d) == (pcie->first_busno + 1)) /* For local bus, change TLP Type field to 4. */ - writel(PCIE_ATU_TYPE_CFG0, pcie->ctrl_base + PCIE_ATU_CR1); + atu_type = PCIE_ATU_TYPE_CFG0; else /* Otherwise, change TLP Type field to 5. */ - writel(PCIE_ATU_TYPE_CFG1, pcie->ctrl_base + PCIE_ATU_CR1); + atu_type = PCIE_ATU_TYPE_CFG1;
if (PCI_BUS(d) == pcie->first_busno) { /* Accessing root port configuration space. */ va_address = (uintptr_t)pcie->ctrl_base; } else { d = PCI_MASK_BUS(d) | (PCI_BUS(d) - pcie->first_busno); - writel(d << 8, pcie->ctrl_base + PCIE_ATU_LOWER_TARGET); + pcie_dw_prog_outbound_atu(pcie, PCIE_ATU_REGION_INDEX0, + atu_type, (u64)pcie->cfg_base, + d << 8, pcie->cfg_size); va_address = (uintptr_t)pcie->cfg_base; }
@@ -231,6 +265,10 @@ static int pcie_dw_mvebu_read_config(struct udevice *bus, pci_dev_t bdf, debug("(addr,val)=(0x%04x, 0x%08lx)\n", offset, value); *valuep = pci_conv_32_to_size(value, offset, size);
+ pcie_dw_prog_outbound_atu(pcie, PCIE_ATU_REGION_INDEX0, + PCIE_ATU_TYPE_IO, pcie->io.phys_start, + pcie->io.bus_start, pcie->io.size); + return 0; }
@@ -272,6 +310,10 @@ static int pcie_dw_mvebu_write_config(struct udevice *bus, pci_dev_t bdf, value = pci_conv_size_to_32(old, value, offset, size); writel(value, va_address);
@@ -388,34 +430,6 @@ static int pcie_dw_mvebu_pcie_link_up(const void *regs_base, u32 cap_speed) }
/** - * pcie_dw_regions_setup() - iATU region setup - * - * @pcie: Pointer to the PCI controller state - * - * Configure the iATU regions in the PCIe controller for outbound access. - */ -static void pcie_dw_regions_setup(struct pcie_dw_mvebu *pcie) -{ - /* - * Region #0 is used for Outbound CFG space access. - * Direction = Outbound - * Region Index = 0 - */ - writel(0, pcie->ctrl_base + PCIE_ATU_VIEWPORT); - - writel((u32)(uintptr_t)pcie->cfg_base, pcie->ctrl_base - + PCIE_ATU_LOWER_BASE); - writel(0, pcie->ctrl_base + PCIE_ATU_UPPER_BASE); - writel((u32)(uintptr_t)pcie->cfg_base + pcie->cfg_size, - pcie->ctrl_base + PCIE_ATU_LIMIT); - - writel(0, pcie->ctrl_base + PCIE_ATU_LOWER_TARGET); - writel(0, pcie->ctrl_base + PCIE_ATU_UPPER_TARGET); - writel(PCIE_ATU_TYPE_CFG0, pcie->ctrl_base + PCIE_ATU_CR1); - writel(PCIE_ATU_ENABLE, pcie->ctrl_base + PCIE_ATU_CR2); -} - -/** * pcie_dw_set_host_bars() - Configure the host BARs * * @regs_base: A pointer to the PCIe controller registers @@ -495,7 +509,18 @@ static int pcie_dw_mvebu_probe(struct udevice *dev) hose->first_busno); }
- pcie_dw_regions_setup(pcie); + /* Store the IO and MEM windows settings for future use by the ATU */ + pcie->io.phys_start = hose->regions[0].phys_start; /* IO base */ + pcie->io.bus_start = hose->regions[0].bus_start; /* IO_bus_addr */ + pcie->io.size = hose->regions[0].size; /* IO size */ + + pcie->mem.phys_start = hose->regions[1].phys_start; /* MEM base */ + pcie->mem.bus_start = hose->regions[1].bus_start; /* MEM_bus_addr */ + pcie->mem.size = hose->regions[1].size; /* MEM size */ + + pcie_dw_prog_outbound_atu(pcie, PCIE_ATU_REGION_INDEX1, + PCIE_ATU_TYPE_MEM, pcie->mem.phys_start, + pcie->mem.bus_start, pcie->mem.size);
/* Set the CLASS_REV of RC CFG header to PCI_CLASS_BRIDGE_PCI */ clrsetbits_le32(pcie->ctrl_base + PCI_CLASS_REVISION,
- pcie_dw_prog_outbound_atu() - Configure ATU for outbound accesses
- @pcie: Pointer to the PCI controller state
- @index: ATU region index
- @type: ATU accsess type
- @cpu_addr: the physical address for the translation entry
- @pci_addr: the pcie bus address for the translation entry
- @size: the size of the translation entry
u32 size)
- writel(PCIE_ATU_REGION_OUTBOUND | index,
- writel(lower_32_bits(cpu_addr), pcie->ctrl_base + PCIE_ATU_LOWER_BASE);
- writel(upper_32_bits(cpu_addr), pcie->ctrl_base + PCIE_ATU_UPPER_BASE);
- writel(lower_32_bits(cpu_addr + size - 1),
- writel(lower_32_bits(pci_addr),
- writel(upper_32_bits(pci_addr),
- writel(type, pcie->ctrl_base + PCIE_ATU_CR1);
- set_cfg_address() - Configure the PCIe controller config space access
u32 atu_type;
- Region #0 is used for Outbound CFG space access.
- Direction = Outbound
- Region Index = 0
else /* Otherwise, change TLP Type field to 5. */atu_type = PCIE_ATU_TYPE_CFG0;
va_address = (uintptr_t)pcie->cfg_base; }d << 8, pcie->cfg_size);
- pcie_dw_prog_outbound_atu(pcie, PCIE_ATU_REGION_INDEX0,
- return 0; }
- return 0; }
- pcie_dw_regions_setup() - iATU region setup
- Configure the iATU regions in the PCIe controller for outbound access.
* Region Index = 0
- pcie_dw_set_host_bars() - Configure the host BARs
- @regs_base: A pointer to the PCIe controller registers
Applied to u-boot-marvell/master.
Thanks, Stefan
igall@marvell.com
Stefan Roese
