[U-Boot] [PATCH v3 0/7] Add support for MT8516 SoC
This patch series adds basic boot support on eMMC for the MediaTek MT8516 SoC based boards. This series adds the clock, pinctrl drivers and the SoC initialization code.
Fabien Parent (7): mmc: mtk-sd: add source_cg clock support mmc: mtk-sd: add support for MT8516 mmc: mtk-sd: fix configuration option check clk: mediatek: add support for SETCLR_INV and NO_SETCLR flags clk: mediatek: add driver for MT8516 pinctrl: add driver for MT8516 ARM: MediaTek: Add support for MT8516 SoC
arch/arm/dts/mt8516-u-boot.dtsi | 25 + arch/arm/dts/mt8516.dtsi | 136 +++++ arch/arm/mach-mediatek/Kconfig | 10 + arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8516/Makefile | 3 + arch/arm/mach-mediatek/mt8516/init.c | 120 ++++ drivers/clk/mediatek/Makefile | 1 + drivers/clk/mediatek/clk-mt8516.c | 701 ++++++++++++++++++++++ drivers/clk/mediatek/clk-mtk.c | 12 + drivers/mmc/mtk-sd.c | 23 +- drivers/pinctrl/mediatek/Kconfig | 4 + drivers/pinctrl/mediatek/Makefile | 1 + drivers/pinctrl/mediatek/pinctrl-mt8516.c | 391 ++++++++++++ include/dt-bindings/clock/mt8516-clk.h | 230 +++++++ 14 files changed, 1654 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/mt8516-u-boot.dtsi create mode 100644 arch/arm/dts/mt8516.dtsi create mode 100644 arch/arm/mach-mediatek/mt8516/Makefile create mode 100644 arch/arm/mach-mediatek/mt8516/init.c create mode 100644 drivers/clk/mediatek/clk-mt8516.c create mode 100644 drivers/pinctrl/mediatek/pinctrl-mt8516.c create mode 100644 include/dt-bindings/clock/mt8516-clk.h
Some MediaTek SoC need an additional clock "source_cg". Enable this new clock. We reuse the same clock name as in the kernel.
Signed-off-by: Fabien Parent fparent@baylibre.com Acked-by: Ryder Lee ryder.lee@mediatek.com ---
v3: * No change
v2: * Get rid of variable has_src_clk_cg
--- drivers/mmc/mtk-sd.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index d3f0778368..eed98b769c 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -247,6 +247,7 @@ struct msdc_host { struct msdc_compatible *dev_comp;
struct clk src_clk; /* for SD/MMC bus clock */ + struct clk src_clk_cg; /* optional, MSDC source clock control gate */ struct clk h_clk; /* MSDC core clock */
u32 src_clk_freq; /* source clock */ @@ -1269,6 +1270,8 @@ static void msdc_ungate_clock(struct msdc_host *host) { clk_enable(&host->src_clk); clk_enable(&host->h_clk); + if (host->src_clk_cg.dev) + clk_enable(&host->src_clk_cg); }
static int msdc_drv_probe(struct udevice *dev) @@ -1332,6 +1335,8 @@ static int msdc_ofdata_to_platdata(struct udevice *dev) if (ret < 0) return ret;
+ clk_get_by_name(dev, "source_cg", &host->src_clk_cg); /* optional */ + #if IS_ENABLED(DM_GPIO) gpio_request_by_name(dev, "wp-gpios", 0, &host->gpio_wp, GPIOD_IS_IN); gpio_request_by_name(dev, "cd-gpios", 0, &host->gpio_cd, GPIOD_IS_IN);
Add config for handling MT8516 SoC.
v3: * No change
v2: * No change
--- drivers/mmc/mtk-sd.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index eed98b769c..b44686fbc9 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -1381,8 +1381,18 @@ static const struct msdc_compatible mt7623_compat = { .enhance_rx = false };
+static const struct msdc_compatible mt8516_compat = { + .clk_div_bits = 12, + .pad_tune0 = true, + .async_fifo = true, + .data_tune = true, + .busy_check = true, + .stop_clk_fix = true, +}; + static const struct udevice_id msdc_ids[] = { { .compatible = "mediatek,mt7623-mmc", .data = (ulong)&mt7623_compat }, + { .compatible = "mediatek,mt8516-mmc", .data = (ulong)&mt8516_compat }, {} };
We either need to use IS_ENABLED(CONFIG_FOO) or CONFIG_IS_ENABLED(FOO). IS_ENABLE(FOO) will always return false.
This commit fixes the comparison by using the CONFIG_IS_ENABLED(FOO) syntax.
Signed-off-by: Fabien Parent fparent@baylibre.com ---
v3: * New patch
--- drivers/mmc/mtk-sd.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index b44686fbc9..e0ac3e9d69 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -270,7 +270,7 @@ struct msdc_host { bool builtin_cd;
/* card detection / write protection GPIOs */ -#if IS_ENABLED(DM_GPIO) +#if CONFIG_IS_ENABLED(DM_GPIO) struct gpio_desc gpio_wp; struct gpio_desc gpio_cd; #endif @@ -850,7 +850,7 @@ static int msdc_ops_get_cd(struct udevice *dev) return !(val & MSDC_PS_CDSTS); }
-#if IS_ENABLED(DM_GPIO) +#if CONFIG_IS_ENABLED(DM_GPIO) if (!host->gpio_cd.dev) return 1;
@@ -862,7 +862,7 @@ static int msdc_ops_get_cd(struct udevice *dev)
static int msdc_ops_get_wp(struct udevice *dev) { -#if IS_ENABLED(DM_GPIO) +#if CONFIG_IS_ENABLED(DM_GPIO) struct msdc_host *host = dev_get_priv(dev);
if (!host->gpio_wp.dev) @@ -1337,7 +1337,7 @@ static int msdc_ofdata_to_platdata(struct udevice *dev)
-#if IS_ENABLED(DM_GPIO) +#if CONFIG_IS_ENABLED(DM_GPIO) gpio_request_by_name(dev, "wp-gpios", 0, &host->gpio_wp, GPIOD_IS_IN); gpio_request_by_name(dev, "cd-gpios", 0, &host->gpio_cd, GPIOD_IS_IN); #endif
Add the implementation for the CLK_GATE_SETCLR_INV and CLK_GATE_NO_SETCLR flags.
v3: * No changes
--- drivers/clk/mediatek/clk-mtk.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/clk/mediatek/clk-mtk.c b/drivers/clk/mediatek/clk-mtk.c index 870b14ed8b..6c6b500d9b 100644 --- a/drivers/clk/mediatek/clk-mtk.c +++ b/drivers/clk/mediatek/clk-mtk.c @@ -390,6 +390,12 @@ static int mtk_clk_gate_enable(struct clk *clk) case CLK_GATE_SETCLR: writel(bit, priv->base + gate->regs->clr_ofs); break; + case CLK_GATE_SETCLR_INV: + writel(bit, priv->base + gate->regs->set_ofs); + break; + case CLK_GATE_NO_SETCLR: + clrsetbits_le32(priv->base + gate->regs->sta_ofs, bit, 0); + break; case CLK_GATE_NO_SETCLR_INV: clrsetbits_le32(priv->base + gate->regs->sta_ofs, bit, bit); break; @@ -411,6 +417,12 @@ static int mtk_clk_gate_disable(struct clk *clk) case CLK_GATE_SETCLR: writel(bit, priv->base + gate->regs->set_ofs); break; + case CLK_GATE_SETCLR_INV: + writel(bit, priv->base + gate->regs->clr_ofs); + break; + case CLK_GATE_NO_SETCLR: + clrsetbits_le32(priv->base + gate->regs->sta_ofs, bit, bit); + break; case CLK_GATE_NO_SETCLR_INV: clrsetbits_le32(priv->base + gate->regs->sta_ofs, bit, 0); break;
Add clock driver for MediaTek MT8516 SoC.
v3: * Remove invalid clocks
v2: * Fix invalid GATE_TOP5 flag
--- drivers/clk/mediatek/Makefile | 1 + drivers/clk/mediatek/clk-mt8516.c | 802 +++++++++++++++++++++++++ include/dt-bindings/clock/mt8516-clk.h | 251 ++++++++ 3 files changed, 1054 insertions(+) create mode 100644 drivers/clk/mediatek/clk-mt8516.c create mode 100644 include/dt-bindings/clock/mt8516-clk.h
diff --git a/drivers/clk/mediatek/Makefile b/drivers/clk/mediatek/Makefile index 0632dc87b6..a47a5bdbc2 100644 --- a/drivers/clk/mediatek/Makefile +++ b/drivers/clk/mediatek/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_ARCH_MEDIATEK) += clk-mtk.o # SoC Drivers obj-$(CONFIG_TARGET_MT7623) += clk-mt7623.o obj-$(CONFIG_TARGET_MT7629) += clk-mt7629.o +obj-$(CONFIG_TARGET_MT8516) += clk-mt8516.o diff --git a/drivers/clk/mediatek/clk-mt8516.c b/drivers/clk/mediatek/clk-mt8516.c new file mode 100644 index 0000000000..e07cc59f7f --- /dev/null +++ b/drivers/clk/mediatek/clk-mt8516.c @@ -0,0 +1,802 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * MediaTek clock driver for MT8516 SoC + * + * Copyright (C) 2018 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <dt-bindings/clock/mt8516-clk.h> + +#include "clk-mtk.h" + +#define MT8516_PLL_FMAX (1502UL * MHZ) +#define MT8516_CON0_RST_BAR BIT(27) + +/* apmixedsys */ +#define PLL(_id, _reg, _pwr_reg, _en_mask, _flags, _pcwbits, _pd_reg, \ + _pd_shift, _pcw_reg, _pcw_shift) { \ + .id = _id, \ + .reg = _reg, \ + .pwr_reg = _pwr_reg, \ + .en_mask = _en_mask, \ + .rst_bar_mask = MT8516_CON0_RST_BAR, \ + .fmax = MT8516_PLL_FMAX, \ + .flags = _flags, \ + .pcwbits = _pcwbits, \ + .pd_reg = _pd_reg, \ + .pd_shift = _pd_shift, \ + .pcw_reg = _pcw_reg, \ + .pcw_shift = _pcw_shift, \ + } + +static const struct mtk_pll_data apmixed_plls[] = { + PLL(CLK_APMIXED_ARMPLL, 0x0100, 0x0110, 0x00000001, 0, + 21, 0x0104, 24, 0x0104, 0), + PLL(CLK_APMIXED_MAINPLL, 0x0120, 0x0130, 0x00000001, + HAVE_RST_BAR, 21, 0x0124, 24, 0x0124, 0), + PLL(CLK_APMIXED_UNIVPLL, 0x0140, 0x0150, 0x30000001, + HAVE_RST_BAR, 7, 0x0144, 24, 0x0144, 0), + PLL(CLK_APMIXED_MMPLL, 0x0160, 0x0170, 0x00000001, 0, + 21, 0x0164, 24, 0x0164, 0), + PLL(CLK_APMIXED_APLL1, 0x0180, 0x0190, 0x00000001, 0, + 31, 0x0180, 1, 0x0184, 0), + PLL(CLK_APMIXED_APLL2, 0x01A0, 0x01B0, 0x00000001, 0, + 31, 0x01A0, 1, 0x01A4, 0), +}; + +/* topckgen */ +#define FACTOR0(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, CLK_PARENT_APMIXED) + +#define FACTOR1(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, CLK_PARENT_TOPCKGEN) + +#define FACTOR2(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, 0) + +static const struct mtk_fixed_clk top_fixed_clks[] = { + FIXED_CLK(CLK_TOP_CLK_NULL, CLK_XTAL, 26000000), + FIXED_CLK(CLK_TOP_I2S_INFRA_BCK, CLK_TOP_CLK_NULL, 26000000), + FIXED_CLK(CLK_TOP_MEMPLL, CLK_TOP_CLK26M, 800000000), +}; + +static const struct mtk_fixed_factor top_fixed_divs[] = { + FACTOR1(CLK_TOP_DMPLL, CLK_TOP_MEMPLL, 1, 1), + FACTOR0(CLK_TOP_MAINPLL_D2, CLK_APMIXED_MAINPLL, 1, 2), + FACTOR0(CLK_TOP_MAINPLL_D4, CLK_APMIXED_MAINPLL, 1, 4), + FACTOR0(CLK_TOP_MAINPLL_D8, CLK_APMIXED_MAINPLL, 1, 8), + FACTOR0(CLK_TOP_MAINPLL_D16, CLK_APMIXED_MAINPLL, 1, 16), + FACTOR0(CLK_TOP_MAINPLL_D11, CLK_APMIXED_MAINPLL, 1, 11), + FACTOR0(CLK_TOP_MAINPLL_D22, CLK_APMIXED_MAINPLL, 1, 22), + FACTOR0(CLK_TOP_MAINPLL_D3, CLK_APMIXED_MAINPLL, 1, 3), + FACTOR0(CLK_TOP_MAINPLL_D6, CLK_APMIXED_MAINPLL, 1, 6), + FACTOR0(CLK_TOP_MAINPLL_D12, CLK_APMIXED_MAINPLL, 1, 12), + FACTOR0(CLK_TOP_MAINPLL_D5, CLK_APMIXED_MAINPLL, 1, 5), + FACTOR0(CLK_TOP_MAINPLL_D10, CLK_APMIXED_MAINPLL, 1, 10), + FACTOR0(CLK_TOP_MAINPLL_D20, CLK_APMIXED_MAINPLL, 1, 20), + FACTOR0(CLK_TOP_MAINPLL_D40, CLK_APMIXED_MAINPLL, 1, 40), + FACTOR0(CLK_TOP_MAINPLL_D7, CLK_APMIXED_MAINPLL, 1, 7), + FACTOR0(CLK_TOP_MAINPLL_D14, CLK_APMIXED_MAINPLL, 1, 14), + FACTOR0(CLK_TOP_UNIVPLL_D2, CLK_APMIXED_UNIVPLL, 1, 2), + FACTOR0(CLK_TOP_UNIVPLL_D4, CLK_APMIXED_UNIVPLL, 1, 4), + FACTOR0(CLK_TOP_UNIVPLL_D8, CLK_APMIXED_UNIVPLL, 1, 8), + FACTOR0(CLK_TOP_UNIVPLL_D16, CLK_APMIXED_UNIVPLL, 1, 16), + FACTOR0(CLK_TOP_UNIVPLL_D3, CLK_APMIXED_UNIVPLL, 1, 3), + FACTOR0(CLK_TOP_UNIVPLL_D6, CLK_APMIXED_UNIVPLL, 1, 6), + FACTOR0(CLK_TOP_UNIVPLL_D12, CLK_APMIXED_UNIVPLL, 1, 12), + FACTOR0(CLK_TOP_UNIVPLL_D24, CLK_APMIXED_UNIVPLL, 1, 24), + FACTOR0(CLK_TOP_UNIVPLL_D5, CLK_APMIXED_UNIVPLL, 1, 5), + FACTOR0(CLK_TOP_UNIVPLL_D20, CLK_APMIXED_UNIVPLL, 1, 20), + FACTOR0(CLK_TOP_MMPLL380M, CLK_APMIXED_MMPLL, 1, 1), + FACTOR0(CLK_TOP_MMPLL_D2, CLK_APMIXED_MMPLL, 1, 2), + FACTOR0(CLK_TOP_MMPLL_200M, CLK_APMIXED_MMPLL, 1, 3), + FACTOR0(CLK_TOP_USB_PHY48M, CLK_APMIXED_UNIVPLL, 1, 26), + FACTOR0(CLK_TOP_APLL1, CLK_APMIXED_APLL1, 1, 1), + FACTOR1(CLK_TOP_APLL1_D2, CLK_TOP_APLL1, 1, 2), + FACTOR1(CLK_TOP_APLL1_D4, CLK_TOP_RG_APLL1_D2_EN, 1, 2), + FACTOR1(CLK_TOP_APLL1_D8, CLK_TOP_RG_APLL1_D4_EN, 1, 2), + FACTOR0(CLK_TOP_APLL2, CLK_APMIXED_APLL2, 1, 1), + FACTOR1(CLK_TOP_APLL2_D2, CLK_TOP_APLL2, 1, 2), + FACTOR1(CLK_TOP_APLL2_D4, CLK_TOP_RG_APLL2_D2_EN, 1, 2), + FACTOR1(CLK_TOP_APLL2_D8, CLK_TOP_RG_APLL2_D4_EN, 1, 2), + FACTOR2(CLK_TOP_CLK26M, CLK_XTAL, 1, 1), + FACTOR2(CLK_TOP_CLK26M_D2, CLK_XTAL, 1, 2), + FACTOR1(CLK_TOP_AHB_INFRA_D2, CLK_TOP_AHB_INFRA_SEL, 1, 2), + FACTOR1(CLK_TOP_NFI1X, CLK_TOP_NFI2X_PAD_SEL, 1, 2), + FACTOR1(CLK_TOP_ETH_D2, CLK_TOP_ETH_SEL, 1, 2), +}; + +static const int uart0_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24, +}; + +static const int gfmux_emi1x_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_DMPLL, +}; + +static const int emi_ddrphy_parents[] = { + CLK_TOP_GFMUX_EMI1X_SEL, + CLK_TOP_GFMUX_EMI1X_SEL, +}; + +static const int ahb_infra_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D11, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D12, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D10, +}; + +static const int csw_mux_mfg_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_UNIVPLL_D3, + CLK_TOP_UNIVPLL_D2, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D4, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_MMPLL380M, +}; + +static const int msdc0_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2, +}; + +static const int pwm_mm_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12, +}; + +static const int uart1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24, +}; + +static const int msdc1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2, +}; + +static const int spm_52m_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24, +}; + +static const int pmicspi_parents[] = { + CLK_TOP_UNIVPLL_D20, + CLK_TOP_USB_PHY48M, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_CLK26M, +}; + +static const int qaxi_aud26m_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_AHB_INFRA_SEL, +}; + +static const int aud_intbus_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D22, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D11, +}; + +static const int nfi2x_pad_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MAINPLL_D8, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D6, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D4, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D10, + CLK_TOP_MAINPLL_D7, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D5 +}; + +static const int nfi1x_pad_parents[] = { + CLK_TOP_AHB_INFRA_SEL, + CLK_TOP_NFI1X, +}; + +static const int mfg_mm_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CSW_MUX_MFG_SEL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D3, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D5, + CLK_TOP_MAINPLL_D7, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D14 +}; + +static const int ddrphycfg_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D16 +}; + +static const int usb_78m_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D20, +}; + +static const int spinor_parents[] = { + CLK_TOP_CLK26M_D2, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D40, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_MAINPLL_D20, + CLK_TOP_MAINPLL_D16, + CLK_TOP_UNIVPLL_D12 +}; + +static const int msdc2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2 +}; + +static const int eth_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D40, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_MAINPLL_D20 +}; + +static const int axi_mfg_in_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D11, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_MMPLL380M, +}; + +static const int slow_mfg_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12, + CLK_TOP_UNIVPLL_D24 +}; + +static const int aud1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_APLL1 +}; + +static const int aud2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_APLL2 +}; + +static const int aud_engen1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_RG_APLL1_D2_EN, + CLK_TOP_RG_APLL1_D4_EN, + CLK_TOP_RG_APLL1_D8_EN +}; + +static const int aud_engen2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_RG_APLL2_D2_EN, + CLK_TOP_RG_APLL2_D4_EN, + CLK_TOP_RG_APLL2_D8_EN +}; + +static const int i2c_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_UNIVPLL_D12 +}; + +static const int aud_i2s0_m_parents[] = { + CLK_TOP_RG_AUD1, + CLK_TOP_RG_AUD2 +}; + +static const int pwm_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12 +}; + +static const int spi_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_UNIVPLL_D6 +}; + +static const int aud_spdifin_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D2 +}; + +static const int uart2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24 +}; + +static const int bsi_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D10, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MAINPLL_D20 +}; + +static const int dbg_atclk_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D5, + CLK_TOP_CLK_NULL, + CLK_TOP_UNIVPLL_D5 +}; + +static const int csw_nfiecc_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D7, + CLK_TOP_MAINPLL_D6, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D5 +}; + +static const int nfiecc_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_NFI2X_PAD_SEL, + CLK_TOP_MAINPLL_D4, + CLK_TOP_CLK_NULL, + CLK_TOP_CSW_NFIECC_SEL, +}; + +static const struct mtk_composite top_muxes[] = { + /* CLK_MUX_SEL0 */ + MUX(CLK_TOP_UART0_SEL, uart0_parents, 0x000, 0, 1), + MUX(CLK_TOP_GFMUX_EMI1X_SEL, gfmux_emi1x_parents, 0x000, 1, 1), + MUX(CLK_TOP_EMI_DDRPHY_SEL, emi_ddrphy_parents, 0x000, 2, 1), + MUX(CLK_TOP_AHB_INFRA_SEL, ahb_infra_parents, 0x000, 4, 4), + MUX(CLK_TOP_CSW_MUX_MFG_SEL, csw_mux_mfg_parents, 0x000, 8, 3), + MUX(CLK_TOP_MSDC0_SEL, msdc0_parents, 0x000, 11, 3), + MUX(CLK_TOP_PWM_MM_SEL, pwm_mm_parents, 0x000, 18, 1), + MUX(CLK_TOP_UART1_SEL, uart1_parents, 0x000, 19, 1), + MUX(CLK_TOP_MSDC1_SEL, msdc1_parents, 0x000, 20, 3), + MUX(CLK_TOP_SPM_52M_SEL, spm_52m_parents, 0x000, 23, 1), + MUX(CLK_TOP_PMICSPI_SEL, pmicspi_parents, 0x000, 24, 2), + MUX(CLK_TOP_QAXI_AUD26M_SEL, qaxi_aud26m_parents, 0x000, 26, 1), + MUX(CLK_TOP_AUD_INTBUS_SEL, aud_intbus_parents, 0x000, 27, 3), + /* CLK_MUX_SEL1 */ + MUX(CLK_TOP_NFI2X_PAD_SEL, nfi2x_pad_parents, 0x004, 0, 7), + MUX(CLK_TOP_NFI1X_PAD_SEL, nfi1x_pad_parents, 0x004, 7, 1), + MUX(CLK_TOP_MFG_MM_SEL, mfg_mm_parents, 0x004, 8, 6), + MUX(CLK_TOP_DDRPHYCFG_SEL, ddrphycfg_parents, 0x004, 15, 1), + MUX(CLK_TOP_USB_78M_SEL, usb_78m_parents, 0x004, 20, 3), + /* CLK_MUX_SEL8 */ + MUX(CLK_TOP_SPINOR_SEL, spinor_parents, 0x040, 0, 3), + MUX(CLK_TOP_MSDC2_SEL, msdc2_parents, 0x040, 3, 3), + MUX(CLK_TOP_ETH_SEL, eth_parents, 0x040, 6, 3), + MUX(CLK_TOP_AXI_MFG_IN_SEL, axi_mfg_in_parents, 0x040, 18, 2), + MUX(CLK_TOP_SLOW_MFG_SEL, slow_mfg_parents, 0x040, 20, 2), + MUX(CLK_TOP_AUD1_SEL, aud1_parents, 0x040, 22, 1), + MUX(CLK_TOP_AUD2_SEL, aud2_parents, 0x040, 23, 1), + MUX(CLK_TOP_AUD_ENGEN1_SEL, aud_engen1_parents, 0x040, 24, 2), + MUX(CLK_TOP_AUD_ENGEN2_SEL, aud_engen2_parents, 0x040, 26, 2), + MUX(CLK_TOP_I2C_SEL, i2c_parents, 0x040, 28, 2), + /* CLK_MUX_SEL9 */ + MUX(CLK_TOP_AUD_I2S0_M_SEL, aud_i2s0_m_parents, 0x044, 12, 1), + MUX(CLK_TOP_AUD_I2S1_M_SEL, aud_i2s0_m_parents, 0x044, 13, 1), + MUX(CLK_TOP_AUD_I2S2_M_SEL, aud_i2s0_m_parents, 0x044, 14, 1), + MUX(CLK_TOP_AUD_I2S3_M_SEL, aud_i2s0_m_parents, 0x044, 15, 1), + MUX(CLK_TOP_AUD_I2S4_M_SEL, aud_i2s0_m_parents, 0x044, 16, 1), + MUX(CLK_TOP_AUD_I2S5_M_SEL, aud_i2s0_m_parents, 0x044, 17, 1), + MUX(CLK_TOP_AUD_SPDIF_B_SEL, aud_i2s0_m_parents, 0x044, 18, 1), + /* CLK_MUX_SEL13 */ + MUX(CLK_TOP_PWM_SEL, pwm_parents, 0x07c, 0, 1), + MUX(CLK_TOP_SPI_SEL, spi_parents, 0x07c, 1, 2), + MUX(CLK_TOP_AUD_SPDIFIN_SEL, aud_spdifin_parents, 0x07c, 3, 1), + MUX(CLK_TOP_UART2_SEL, uart2_parents, 0x07c, 4, 1), + MUX(CLK_TOP_BSI_SEL, bsi_parents, 0x07c, 5, 2), + MUX(CLK_TOP_DBG_ATCLK_SEL, dbg_atclk_parents, 0x07c, 7, 3), + MUX(CLK_TOP_CSW_NFIECC_SEL, csw_nfiecc_parents, 0x07c, 10, 3), + MUX(CLK_TOP_NFIECC_SEL, nfiecc_parents, 0x07c, 13, 3), +}; + +static const struct mtk_gate_regs top0_cg_regs = { + .set_ofs = 0x50, + .clr_ofs = 0x80, + .sta_ofs = 0x20, +}; + +static const struct mtk_gate_regs top1_cg_regs = { + .set_ofs = 0x54, + .clr_ofs = 0x84, + .sta_ofs = 0x24, +}; + +static const struct mtk_gate_regs top2_cg_regs = { + .set_ofs = 0x6c, + .clr_ofs = 0x9c, + .sta_ofs = 0x3c, +}; + +static const struct mtk_gate_regs top3_cg_regs = { + .set_ofs = 0xa0, + .clr_ofs = 0xb0, + .sta_ofs = 0x70, +}; + +static const struct mtk_gate_regs top4_cg_regs = { + .set_ofs = 0xa4, + .clr_ofs = 0xb4, + .sta_ofs = 0x74, +}; + +static const struct mtk_gate_regs top5_cg_regs = { + .set_ofs = 0x44, + .clr_ofs = 0x44, + .sta_ofs = 0x44, +}; + +#define GATE_TOP0(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top0_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP1(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top1_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP2(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top2_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP2_I(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top2_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR_INV | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP3(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top3_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP4_I(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top4_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR_INV | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP5(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top5_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_NO_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +static const struct mtk_gate top_clks[] = { + /* TOP0 */ + GATE_TOP0(CLK_TOP_PWM_MM, CLK_TOP_PWM_MM_SEL, 0), + GATE_TOP0(CLK_TOP_MFG_MM, CLK_TOP_MFG_MM_SEL, 2), + GATE_TOP0(CLK_TOP_SPM_52M, CLK_TOP_SPM_52M_SEL, 3), + /* TOP1 */ + GATE_TOP1(CLK_TOP_THEM, CLK_TOP_AHB_INFRA_SEL, 1), + GATE_TOP1(CLK_TOP_APDMA, CLK_TOP_AHB_INFRA_SEL, 2), + GATE_TOP1(CLK_TOP_I2C0, CLK_IFR_I2C0_SEL, 3), + GATE_TOP1(CLK_TOP_I2C1, CLK_IFR_I2C1_SEL, 4), + GATE_TOP1(CLK_TOP_AUXADC1, CLK_TOP_AHB_INFRA_SEL, 5), + GATE_TOP1(CLK_TOP_NFI, CLK_TOP_NFI1X_PAD_SEL, 6), + GATE_TOP1(CLK_TOP_NFIECC, CLK_TOP_RG_NFIECC, 7), + GATE_TOP1(CLK_TOP_DEBUGSYS, CLK_TOP_RG_DBG_ATCLK, 8), + GATE_TOP1(CLK_TOP_PWM, CLK_TOP_AHB_INFRA_SEL, 9), + GATE_TOP1(CLK_TOP_UART0, CLK_TOP_UART0_SEL, 10), + GATE_TOP1(CLK_TOP_UART1, CLK_TOP_UART1_SEL, 11), + GATE_TOP1(CLK_TOP_BTIF, CLK_TOP_AHB_INFRA_SEL, 12), + GATE_TOP1(CLK_TOP_USB, CLK_TOP_USB_78M, 13), + GATE_TOP1(CLK_TOP_FLASHIF_26M, CLK_TOP_CLK26M, 14), + GATE_TOP1(CLK_TOP_AUXADC2, CLK_TOP_AHB_INFRA_SEL, 15), + GATE_TOP1(CLK_TOP_I2C2, CLK_IFR_I2C2_SEL, 16), + GATE_TOP1(CLK_TOP_MSDC0, CLK_TOP_MSDC0_SEL, 17), + GATE_TOP1(CLK_TOP_MSDC1, CLK_TOP_MSDC1_SEL, 18), + GATE_TOP1(CLK_TOP_NFI2X, CLK_TOP_NFI2X_PAD_SEL, 19), + GATE_TOP1(CLK_TOP_PMICWRAP_AP, CLK_TOP_CLK26M, 20), + GATE_TOP1(CLK_TOP_SEJ, CLK_TOP_AHB_INFRA_SEL, 21), + GATE_TOP1(CLK_TOP_MEMSLP_DLYER, CLK_TOP_CLK26M, 22), + GATE_TOP1(CLK_TOP_SPI, CLK_TOP_SPI_SEL, 23), + GATE_TOP1(CLK_TOP_APXGPT, CLK_TOP_CLK26M, 24), + GATE_TOP1(CLK_TOP_AUDIO, CLK_TOP_CLK26M, 25), + GATE_TOP1(CLK_TOP_PMICWRAP_MD, CLK_TOP_CLK26M, 27), + GATE_TOP1(CLK_TOP_PMICWRAP_CONN, CLK_TOP_CLK26M, 28), + GATE_TOP1(CLK_TOP_PMICWRAP_26M, CLK_TOP_CLK26M, 29), + GATE_TOP1(CLK_TOP_AUX_ADC, CLK_TOP_CLK26M, 30), + GATE_TOP1(CLK_TOP_AUX_TP, CLK_TOP_CLK26M, 31), + /* TOP2 */ + GATE_TOP2(CLK_TOP_MSDC2, CLK_TOP_AHB_INFRA_SEL, 0), + GATE_TOP2(CLK_TOP_RBIST, CLK_TOP_UNIVPLL_D12, 1), + GATE_TOP2(CLK_TOP_NFI_BUS, CLK_TOP_AHB_INFRA_SEL, 2), + GATE_TOP2(CLK_TOP_GCE, CLK_TOP_AHB_INFRA_SEL, 4), + GATE_TOP2(CLK_TOP_TRNG, CLK_TOP_AHB_INFRA_SEL, 5), + GATE_TOP2(CLK_TOP_SEJ_13M, CLK_TOP_CLK26M, 6), + GATE_TOP2(CLK_TOP_AES, CLK_TOP_AHB_INFRA_SEL, 7), + GATE_TOP2(CLK_TOP_PWM_B, CLK_TOP_RG_PWM_INFRA, 8), + GATE_TOP2(CLK_TOP_PWM1_FB, CLK_TOP_RG_PWM_INFRA, 9), + GATE_TOP2(CLK_TOP_PWM2_FB, CLK_TOP_RG_PWM_INFRA, 10), + GATE_TOP2(CLK_TOP_PWM3_FB, CLK_TOP_RG_PWM_INFRA, 11), + GATE_TOP2(CLK_TOP_PWM4_FB, CLK_TOP_RG_PWM_INFRA, 12), + GATE_TOP2(CLK_TOP_PWM5_FB, CLK_TOP_RG_PWM_INFRA, 13), + GATE_TOP2(CLK_TOP_USB_1P, CLK_TOP_USB_78M, 14), + GATE_TOP2(CLK_TOP_FLASHIF_FREERUN, CLK_TOP_AHB_INFRA_SEL, 15), + GATE_TOP2(CLK_TOP_66M_ETH, CLK_TOP_AHB_INFRA_D2, 19), + GATE_TOP2(CLK_TOP_133M_ETH, CLK_TOP_AHB_INFRA_SEL, 20), + GATE_TOP2(CLK_TOP_FETH_25M, CLK_IFR_ETH_25M_SEL, 21), + GATE_TOP2(CLK_TOP_FETH_50M, CLK_TOP_RG_ETH, 22), + GATE_TOP2(CLK_TOP_FLASHIF_AXI, CLK_TOP_AHB_INFRA_SEL, 23), + GATE_TOP2(CLK_TOP_USBIF, CLK_TOP_AHB_INFRA_SEL, 24), + GATE_TOP2(CLK_TOP_UART2, CLK_TOP_RG_UART2, 25), + GATE_TOP2(CLK_TOP_BSI, CLK_TOP_AHB_INFRA_SEL, 26), + GATE_TOP2_I(CLK_TOP_MSDC0_INFRA, CLK_TOP_MSDC0, 28), + GATE_TOP2_I(CLK_TOP_MSDC1_INFRA, CLK_TOP_MSDC1, 29), + GATE_TOP2_I(CLK_TOP_MSDC2_INFRA, CLK_TOP_RG_MSDC2, 30), + GATE_TOP2(CLK_TOP_USB_78M, CLK_TOP_USB_78M_SEL, 31), + /* TOP3 */ + GATE_TOP3(CLK_TOP_RG_SPINOR, CLK_TOP_SPINOR_SEL, 0), + GATE_TOP3(CLK_TOP_RG_MSDC2, CLK_TOP_MSDC2_SEL, 1), + GATE_TOP3(CLK_TOP_RG_ETH, CLK_TOP_ETH_SEL, 2), + GATE_TOP3(CLK_TOP_RG_AXI_MFG, CLK_TOP_AXI_MFG_IN_SEL, 6), + GATE_TOP3(CLK_TOP_RG_SLOW_MFG, CLK_TOP_SLOW_MFG_SEL, 7), + GATE_TOP3(CLK_TOP_RG_AUD1, CLK_TOP_AUD1_SEL, 8), + GATE_TOP3(CLK_TOP_RG_AUD2, CLK_TOP_AUD2_SEL, 9), + GATE_TOP3(CLK_TOP_RG_AUD_ENGEN1, CLK_TOP_AUD_ENGEN1_SEL, 10), + GATE_TOP3(CLK_TOP_RG_AUD_ENGEN2, CLK_TOP_AUD_ENGEN2_SEL, 11), + GATE_TOP3(CLK_TOP_RG_I2C, CLK_TOP_I2C_SEL, 12), + GATE_TOP3(CLK_TOP_RG_PWM_INFRA, CLK_TOP_PWM_SEL, 13), + GATE_TOP3(CLK_TOP_RG_AUD_SPDIF_IN, CLK_TOP_AUD_SPDIFIN_SEL, 14), + GATE_TOP3(CLK_TOP_RG_UART2, CLK_TOP_UART2_SEL, 15), + GATE_TOP3(CLK_TOP_RG_BSI, CLK_TOP_BSI_SEL, 16), + GATE_TOP3(CLK_TOP_RG_DBG_ATCLK, CLK_TOP_DBG_ATCLK_SEL, 17), + GATE_TOP3(CLK_TOP_RG_NFIECC, CLK_TOP_NFIECC_SEL, 18), + /* TOP4 */ + GATE_TOP4_I(CLK_TOP_RG_APLL1_D2_EN, CLK_TOP_APLL1_D2, 8), + GATE_TOP4_I(CLK_TOP_RG_APLL1_D4_EN, CLK_TOP_APLL1_D4, 9), + GATE_TOP4_I(CLK_TOP_RG_APLL1_D8_EN, CLK_TOP_APLL1_D8, 10), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D2_EN, CLK_TOP_APLL2_D2, 11), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D4_EN, CLK_TOP_APLL2_D4, 12), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D8_EN, CLK_TOP_APLL2_D8, 13), + /* TOP5 */ + GATE_TOP5(CLK_TOP_APLL12_DIV0, CLK_TOP_APLL12_CK_DIV0, 0), + GATE_TOP5(CLK_TOP_APLL12_DIV1, CLK_TOP_APLL12_CK_DIV1, 1), + GATE_TOP5(CLK_TOP_APLL12_DIV2, CLK_TOP_APLL12_CK_DIV2, 2), + GATE_TOP5(CLK_TOP_APLL12_DIV3, CLK_TOP_APLL12_CK_DIV3, 3), + GATE_TOP5(CLK_TOP_APLL12_DIV4, CLK_TOP_APLL12_CK_DIV4, 4), + GATE_TOP5(CLK_TOP_APLL12_DIV4B, CLK_TOP_APLL12_CK_DIV4B, 5), + GATE_TOP5(CLK_TOP_APLL12_DIV5, CLK_TOP_APLL12_CK_DIV5, 6), + GATE_TOP5(CLK_TOP_APLL12_DIV5B, CLK_TOP_APLL12_CK_DIV5B, 7), + GATE_TOP5(CLK_TOP_APLL12_DIV6, CLK_TOP_APLL12_CK_DIV6, 8), +}; + +static const struct mtk_clk_tree mt8516_clk_tree = { + .xtal_rate = 26 * MHZ, + .xtal2_rate = 26 * MHZ, + .fdivs_offs = CLK_TOP_DMPLL, + .muxes_offs = CLK_TOP_UART0_SEL, + .plls = apmixed_plls, + .fclks = top_fixed_clks, + .fdivs = top_fixed_divs, + .muxes = top_muxes, +}; + +static int mt8516_apmixedsys_probe(struct udevice *dev) +{ + return mtk_common_clk_init(dev, &mt8516_clk_tree); +} + +static int mt8516_topckgen_probe(struct udevice *dev) +{ + return mtk_common_clk_init(dev, &mt8516_clk_tree); +} + +static int mt8516_topckgen_cg_probe(struct udevice *dev) +{ + return mtk_common_clk_gate_init(dev, &mt8516_clk_tree, top_clks); +} + +static const struct udevice_id mt8516_apmixed_compat[] = { + { .compatible = "mediatek,mt8516-apmixedsys", }, + { } +}; + +static const struct udevice_id mt8516_topckgen_compat[] = { + { .compatible = "mediatek,mt8516-topckgen", }, + { } +}; + +static const struct udevice_id mt8516_topckgen_cg_compat[] = { + { .compatible = "mediatek,mt8516-topckgen-cg", }, + { } +}; + +U_BOOT_DRIVER(mtk_clk_apmixedsys) = { + .name = "mt8516-apmixedsys", + .id = UCLASS_CLK, + .of_match = mt8516_apmixed_compat, + .probe = mt8516_apmixedsys_probe, + .priv_auto_alloc_size = sizeof(struct mtk_clk_priv), + .ops = &mtk_clk_apmixedsys_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER(mtk_clk_topckgen) = { + .name = "mt8516-topckgen", + .id = UCLASS_CLK, + .of_match = mt8516_topckgen_compat, + .probe = mt8516_topckgen_probe, + .priv_auto_alloc_size = sizeof(struct mtk_clk_priv), + .ops = &mtk_clk_topckgen_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER(mtk_clk_topckgen_cg) = { + .name = "mt8516-topckgen-cg", + .id = UCLASS_CLK, + .of_match = mt8516_topckgen_cg_compat, + .probe = mt8516_topckgen_cg_probe, + .priv_auto_alloc_size = sizeof(struct mtk_cg_priv), + .ops = &mtk_clk_gate_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/mt8516-clk.h b/include/dt-bindings/clock/mt8516-clk.h new file mode 100644 index 0000000000..b62a971c59 --- /dev/null +++ b/include/dt-bindings/clock/mt8516-clk.h @@ -0,0 +1,251 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018 BayLibre, SAS + * Copyright (c) 2018 MediaTek Inc. + * Author: Fabien Parent fparent@baylibre.com + */ + +#ifndef _DT_BINDINGS_CLK_MT8516_H +#define _DT_BINDINGS_CLK_MT8516_H + + +/* APMIXEDSYS */ + +#define CLK_APMIXED_ARMPLL 0 +#define CLK_APMIXED_MAINPLL 1 +#define CLK_APMIXED_UNIVPLL 2 +#define CLK_APMIXED_MMPLL 3 +#define CLK_APMIXED_APLL1 4 +#define CLK_APMIXED_APLL2 5 +#define CLK_APMIXED_NR_CLK 6 + +/* TOPCKGEN */ + +#define CLK_TOP_CLK_NULL 0 +#define CLK_TOP_I2S_INFRA_BCK 1 +#define CLK_TOP_MEMPLL 2 +#define CLK_TOP_DMPLL 3 +#define CLK_TOP_MAINPLL_D2 4 +#define CLK_TOP_MAINPLL_D4 5 +#define CLK_TOP_MAINPLL_D8 6 +#define CLK_TOP_MAINPLL_D16 7 +#define CLK_TOP_MAINPLL_D11 8 +#define CLK_TOP_MAINPLL_D22 9 +#define CLK_TOP_MAINPLL_D3 10 +#define CLK_TOP_MAINPLL_D6 11 +#define CLK_TOP_MAINPLL_D12 12 +#define CLK_TOP_MAINPLL_D5 13 +#define CLK_TOP_MAINPLL_D10 14 +#define CLK_TOP_MAINPLL_D20 15 +#define CLK_TOP_MAINPLL_D40 16 +#define CLK_TOP_MAINPLL_D7 17 +#define CLK_TOP_MAINPLL_D14 18 +#define CLK_TOP_UNIVPLL_D2 19 +#define CLK_TOP_UNIVPLL_D4 20 +#define CLK_TOP_UNIVPLL_D8 21 +#define CLK_TOP_UNIVPLL_D16 22 +#define CLK_TOP_UNIVPLL_D3 23 +#define CLK_TOP_UNIVPLL_D6 24 +#define CLK_TOP_UNIVPLL_D12 25 +#define CLK_TOP_UNIVPLL_D24 26 +#define CLK_TOP_UNIVPLL_D5 27 +#define CLK_TOP_UNIVPLL_D20 28 +#define CLK_TOP_MMPLL380M 29 +#define CLK_TOP_MMPLL_D2 30 +#define CLK_TOP_MMPLL_200M 31 +#define CLK_TOP_USB_PHY48M 32 +#define CLK_TOP_APLL1 33 +#define CLK_TOP_APLL1_D2 34 +#define CLK_TOP_APLL1_D4 35 +#define CLK_TOP_APLL1_D8 36 +#define CLK_TOP_APLL2 37 +#define CLK_TOP_APLL2_D2 38 +#define CLK_TOP_APLL2_D4 39 +#define CLK_TOP_APLL2_D8 40 +#define CLK_TOP_CLK26M 41 +#define CLK_TOP_CLK26M_D2 42 +#define CLK_TOP_AHB_INFRA_D2 43 +#define CLK_TOP_NFI1X 44 +#define CLK_TOP_ETH_D2 45 +#define CLK_TOP_UART0_SEL 46 +#define CLK_TOP_GFMUX_EMI1X_SEL 47 +#define CLK_TOP_EMI_DDRPHY_SEL 48 +#define CLK_TOP_AHB_INFRA_SEL 49 +#define CLK_TOP_CSW_MUX_MFG_SEL 50 +#define CLK_TOP_MSDC0_SEL 51 +#define CLK_TOP_PWM_MM_SEL 52 +#define CLK_TOP_UART1_SEL 53 +#define CLK_TOP_MSDC1_SEL 54 +#define CLK_TOP_SPM_52M_SEL 55 +#define CLK_TOP_PMICSPI_SEL 56 +#define CLK_TOP_QAXI_AUD26M_SEL 57 +#define CLK_TOP_AUD_INTBUS_SEL 58 +#define CLK_TOP_NFI2X_PAD_SEL 59 +#define CLK_TOP_NFI1X_PAD_SEL 60 +#define CLK_TOP_MFG_MM_SEL 61 +#define CLK_TOP_DDRPHYCFG_SEL 62 +#define CLK_TOP_USB_78M_SEL 63 +#define CLK_TOP_SPINOR_SEL 64 +#define CLK_TOP_MSDC2_SEL 65 +#define CLK_TOP_ETH_SEL 66 +#define CLK_TOP_AXI_MFG_IN_SEL 67 +#define CLK_TOP_SLOW_MFG_SEL 68 +#define CLK_TOP_AUD1_SEL 69 +#define CLK_TOP_AUD2_SEL 70 +#define CLK_TOP_AUD_ENGEN1_SEL 71 +#define CLK_TOP_AUD_ENGEN2_SEL 72 +#define CLK_TOP_I2C_SEL 73 +#define CLK_TOP_AUD_I2S0_M_SEL 74 +#define CLK_TOP_AUD_I2S1_M_SEL 75 +#define CLK_TOP_AUD_I2S2_M_SEL 76 +#define CLK_TOP_AUD_I2S3_M_SEL 77 +#define CLK_TOP_AUD_I2S4_M_SEL 78 +#define CLK_TOP_AUD_I2S5_M_SEL 79 +#define CLK_TOP_AUD_SPDIF_B_SEL 80 +#define CLK_TOP_PWM_SEL 81 +#define CLK_TOP_SPI_SEL 82 +#define CLK_TOP_AUD_SPDIFIN_SEL 83 +#define CLK_TOP_UART2_SEL 84 +#define CLK_TOP_BSI_SEL 85 +#define CLK_TOP_DBG_ATCLK_SEL 86 +#define CLK_TOP_CSW_NFIECC_SEL 87 +#define CLK_TOP_NFIECC_SEL 88 +#define CLK_TOP_APLL12_CK_DIV0 89 +#define CLK_TOP_APLL12_CK_DIV1 90 +#define CLK_TOP_APLL12_CK_DIV2 91 +#define CLK_TOP_APLL12_CK_DIV3 92 +#define CLK_TOP_APLL12_CK_DIV4 93 +#define CLK_TOP_APLL12_CK_DIV4B 94 +#define CLK_TOP_APLL12_CK_DIV5 95 +#define CLK_TOP_APLL12_CK_DIV5B 96 +#define CLK_TOP_APLL12_CK_DIV6 97 +#define CLK_TOP_NR_CLK 98 + +/* TOPCKGEN Gates */ +#define CLK_TOP_PWM_MM 0 +#define CLK_TOP_MFG_MM 1 +#define CLK_TOP_SPM_52M 2 +#define CLK_TOP_THEM 3 +#define CLK_TOP_APDMA 4 +#define CLK_TOP_I2C0 5 +#define CLK_TOP_I2C1 6 +#define CLK_TOP_AUXADC1 7 +#define CLK_TOP_NFI 8 +#define CLK_TOP_NFIECC 9 +#define CLK_TOP_DEBUGSYS 10 +#define CLK_TOP_PWM 11 +#define CLK_TOP_UART0 12 +#define CLK_TOP_UART1 13 +#define CLK_TOP_BTIF 14 +#define CLK_TOP_USB 15 +#define CLK_TOP_FLASHIF_26M 16 +#define CLK_TOP_AUXADC2 17 +#define CLK_TOP_I2C2 18 +#define CLK_TOP_MSDC0 19 +#define CLK_TOP_MSDC1 20 +#define CLK_TOP_NFI2X 21 +#define CLK_TOP_PMICWRAP_AP 22 +#define CLK_TOP_SEJ 23 +#define CLK_TOP_MEMSLP_DLYER 24 +#define CLK_TOP_SPI 25 +#define CLK_TOP_APXGPT 26 +#define CLK_TOP_AUDIO 27 +#define CLK_TOP_PMICWRAP_MD 28 +#define CLK_TOP_PMICWRAP_CONN 29 +#define CLK_TOP_PMICWRAP_26M 30 +#define CLK_TOP_AUX_ADC 31 +#define CLK_TOP_AUX_TP 32 +#define CLK_TOP_MSDC2 33 +#define CLK_TOP_RBIST 34 +#define CLK_TOP_NFI_BUS 35 +#define CLK_TOP_GCE 36 +#define CLK_TOP_TRNG 37 +#define CLK_TOP_SEJ_13M 38 +#define CLK_TOP_AES 39 +#define CLK_TOP_PWM_B 40 +#define CLK_TOP_PWM1_FB 41 +#define CLK_TOP_PWM2_FB 42 +#define CLK_TOP_PWM3_FB 43 +#define CLK_TOP_PWM4_FB 44 +#define CLK_TOP_PWM5_FB 45 +#define CLK_TOP_USB_1P 46 +#define CLK_TOP_FLASHIF_FREERUN 47 +#define CLK_TOP_66M_ETH 48 +#define CLK_TOP_133M_ETH 49 +#define CLK_TOP_FETH_25M 50 +#define CLK_TOP_FETH_50M 51 +#define CLK_TOP_FLASHIF_AXI 52 +#define CLK_TOP_USBIF 53 +#define CLK_TOP_UART2 54 +#define CLK_TOP_BSI 55 +#define CLK_TOP_MSDC0_INFRA 56 +#define CLK_TOP_MSDC1_INFRA 57 +#define CLK_TOP_MSDC2_INFRA 58 +#define CLK_TOP_USB_78M 59 +#define CLK_TOP_RG_SPINOR 60 +#define CLK_TOP_RG_MSDC2 61 +#define CLK_TOP_RG_ETH 62 +#define CLK_TOP_RG_AXI_MFG 63 +#define CLK_TOP_RG_SLOW_MFG 64 +#define CLK_TOP_RG_AUD1 65 +#define CLK_TOP_RG_AUD2 66 +#define CLK_TOP_RG_AUD_ENGEN1 67 +#define CLK_TOP_RG_AUD_ENGEN2 68 +#define CLK_TOP_RG_I2C 69 +#define CLK_TOP_RG_PWM_INFRA 70 +#define CLK_TOP_RG_AUD_SPDIF_IN 71 +#define CLK_TOP_RG_UART2 72 +#define CLK_TOP_RG_BSI 73 +#define CLK_TOP_RG_DBG_ATCLK 74 +#define CLK_TOP_RG_NFIECC 75 +#define CLK_TOP_RG_APLL1_D2_EN 76 +#define CLK_TOP_RG_APLL1_D4_EN 77 +#define CLK_TOP_RG_APLL1_D8_EN 78 +#define CLK_TOP_RG_APLL2_D2_EN 79 +#define CLK_TOP_RG_APLL2_D4_EN 80 +#define CLK_TOP_RG_APLL2_D8_EN 81 +#define CLK_TOP_APLL12_DIV0 82 +#define CLK_TOP_APLL12_DIV1 83 +#define CLK_TOP_APLL12_DIV2 84 +#define CLK_TOP_APLL12_DIV3 85 +#define CLK_TOP_APLL12_DIV4 86 +#define CLK_TOP_APLL12_DIV4B 87 +#define CLK_TOP_APLL12_DIV5 88 +#define CLK_TOP_APLL12_DIV5B 89 +#define CLK_TOP_APLL12_DIV6 90 + +/* INFRACFG */ + +#define CLK_IFR_MUX1_SEL 0 +#define CLK_IFR_ETH_25M_SEL 1 +#define CLK_IFR_I2C0_SEL 2 +#define CLK_IFR_I2C1_SEL 3 +#define CLK_IFR_I2C2_SEL 4 +#define CLK_IFR_NR_CLK 5 + +/* AUDIOTOP */ + +#define CLK_AUD_AFE 0 +#define CLK_AUD_I2S 1 +#define CLK_AUD_22M 2 +#define CLK_AUD_24M 3 +#define CLK_AUD_INTDIR 4 +#define CLK_AUD_APLL2_TUNER 5 +#define CLK_AUD_APLL_TUNER 6 +#define CLK_AUD_HDMI 7 +#define CLK_AUD_SPDF 8 +#define CLK_AUD_ADC 9 +#define CLK_AUD_DAC 10 +#define CLK_AUD_DAC_PREDIS 11 +#define CLK_AUD_TML 12 +#define CLK_AUD_NR_CLK 13 + +/* MFGCFG */ + +#define CLK_MFG_BAXI 0 +#define CLK_MFG_BMEM 1 +#define CLK_MFG_BG3D 2 +#define CLK_MFG_B26M 3 +#define CLK_MFG_NR_CLK 4 + +#endif /* _DT_BINDINGS_CLK_MT8516_H */
--- drivers/clk/mediatek/Makefile | 1 + drivers/clk/mediatek/clk-mt8516.c | 701 +++++++++++++++++++++++++ include/dt-bindings/clock/mt8516-clk.h | 230 ++++++++ 3 files changed, 932 insertions(+) create mode 100644 drivers/clk/mediatek/clk-mt8516.c create mode 100644 include/dt-bindings/clock/mt8516-clk.h
diff --git a/drivers/clk/mediatek/Makefile b/drivers/clk/mediatek/Makefile index 0632dc87b6..a47a5bdbc2 100644 --- a/drivers/clk/mediatek/Makefile +++ b/drivers/clk/mediatek/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_ARCH_MEDIATEK) += clk-mtk.o # SoC Drivers obj-$(CONFIG_TARGET_MT7623) += clk-mt7623.o obj-$(CONFIG_TARGET_MT7629) += clk-mt7629.o +obj-$(CONFIG_TARGET_MT8516) += clk-mt8516.o diff --git a/drivers/clk/mediatek/clk-mt8516.c b/drivers/clk/mediatek/clk-mt8516.c new file mode 100644 index 0000000000..1b060258d8 --- /dev/null +++ b/drivers/clk/mediatek/clk-mt8516.c @@ -0,0 +1,701 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * MediaTek clock driver for MT8516 SoC + * + * Copyright (C) 2018 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> +#include <dt-bindings/clock/mt8516-clk.h> + +#include "clk-mtk.h" + +#define MT8516_PLL_FMAX (1502UL * MHZ) +#define MT8516_CON0_RST_BAR BIT(27) + +/* apmixedsys */ +#define PLL(_id, _reg, _pwr_reg, _en_mask, _flags, _pcwbits, _pd_reg, \ + _pd_shift, _pcw_reg, _pcw_shift) { \ + .id = _id, \ + .reg = _reg, \ + .pwr_reg = _pwr_reg, \ + .en_mask = _en_mask, \ + .rst_bar_mask = MT8516_CON0_RST_BAR, \ + .fmax = MT8516_PLL_FMAX, \ + .flags = _flags, \ + .pcwbits = _pcwbits, \ + .pd_reg = _pd_reg, \ + .pd_shift = _pd_shift, \ + .pcw_reg = _pcw_reg, \ + .pcw_shift = _pcw_shift, \ + } + +static const struct mtk_pll_data apmixed_plls[] = { + PLL(CLK_APMIXED_ARMPLL, 0x0100, 0x0110, 0x00000001, 0, + 21, 0x0104, 24, 0x0104, 0), + PLL(CLK_APMIXED_MAINPLL, 0x0120, 0x0130, 0x00000001, + HAVE_RST_BAR, 21, 0x0124, 24, 0x0124, 0), + PLL(CLK_APMIXED_UNIVPLL, 0x0140, 0x0150, 0x30000001, + HAVE_RST_BAR, 7, 0x0144, 24, 0x0144, 0), + PLL(CLK_APMIXED_MMPLL, 0x0160, 0x0170, 0x00000001, 0, + 21, 0x0164, 24, 0x0164, 0), + PLL(CLK_APMIXED_APLL1, 0x0180, 0x0190, 0x00000001, 0, + 31, 0x0180, 1, 0x0184, 0), + PLL(CLK_APMIXED_APLL2, 0x01A0, 0x01B0, 0x00000001, 0, + 31, 0x01A0, 1, 0x01A4, 0), +}; + +/* topckgen */ +#define FACTOR0(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, CLK_PARENT_APMIXED) + +#define FACTOR1(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, CLK_PARENT_TOPCKGEN) + +#define FACTOR2(_id, _parent, _mult, _div) \ + FACTOR(_id, _parent, _mult, _div, 0) + +static const struct mtk_fixed_clk top_fixed_clks[] = { + FIXED_CLK(CLK_TOP_CLK_NULL, CLK_XTAL, 26000000), + FIXED_CLK(CLK_TOP_I2S_INFRA_BCK, CLK_TOP_CLK_NULL, 26000000), + FIXED_CLK(CLK_TOP_MEMPLL, CLK_TOP_CLK26M, 800000000), +}; + +static const struct mtk_fixed_factor top_fixed_divs[] = { + FACTOR1(CLK_TOP_DMPLL, CLK_TOP_MEMPLL, 1, 1), + FACTOR0(CLK_TOP_MAINPLL_D2, CLK_APMIXED_MAINPLL, 1, 2), + FACTOR0(CLK_TOP_MAINPLL_D4, CLK_APMIXED_MAINPLL, 1, 4), + FACTOR0(CLK_TOP_MAINPLL_D8, CLK_APMIXED_MAINPLL, 1, 8), + FACTOR0(CLK_TOP_MAINPLL_D16, CLK_APMIXED_MAINPLL, 1, 16), + FACTOR0(CLK_TOP_MAINPLL_D11, CLK_APMIXED_MAINPLL, 1, 11), + FACTOR0(CLK_TOP_MAINPLL_D22, CLK_APMIXED_MAINPLL, 1, 22), + FACTOR0(CLK_TOP_MAINPLL_D3, CLK_APMIXED_MAINPLL, 1, 3), + FACTOR0(CLK_TOP_MAINPLL_D6, CLK_APMIXED_MAINPLL, 1, 6), + FACTOR0(CLK_TOP_MAINPLL_D12, CLK_APMIXED_MAINPLL, 1, 12), + FACTOR0(CLK_TOP_MAINPLL_D5, CLK_APMIXED_MAINPLL, 1, 5), + FACTOR0(CLK_TOP_MAINPLL_D10, CLK_APMIXED_MAINPLL, 1, 10), + FACTOR0(CLK_TOP_MAINPLL_D20, CLK_APMIXED_MAINPLL, 1, 20), + FACTOR0(CLK_TOP_MAINPLL_D40, CLK_APMIXED_MAINPLL, 1, 40), + FACTOR0(CLK_TOP_MAINPLL_D7, CLK_APMIXED_MAINPLL, 1, 7), + FACTOR0(CLK_TOP_MAINPLL_D14, CLK_APMIXED_MAINPLL, 1, 14), + FACTOR0(CLK_TOP_UNIVPLL_D2, CLK_APMIXED_UNIVPLL, 1, 2), + FACTOR0(CLK_TOP_UNIVPLL_D4, CLK_APMIXED_UNIVPLL, 1, 4), + FACTOR0(CLK_TOP_UNIVPLL_D8, CLK_APMIXED_UNIVPLL, 1, 8), + FACTOR0(CLK_TOP_UNIVPLL_D16, CLK_APMIXED_UNIVPLL, 1, 16), + FACTOR0(CLK_TOP_UNIVPLL_D3, CLK_APMIXED_UNIVPLL, 1, 3), + FACTOR0(CLK_TOP_UNIVPLL_D6, CLK_APMIXED_UNIVPLL, 1, 6), + FACTOR0(CLK_TOP_UNIVPLL_D12, CLK_APMIXED_UNIVPLL, 1, 12), + FACTOR0(CLK_TOP_UNIVPLL_D24, CLK_APMIXED_UNIVPLL, 1, 24), + FACTOR0(CLK_TOP_UNIVPLL_D5, CLK_APMIXED_UNIVPLL, 1, 5), + FACTOR0(CLK_TOP_UNIVPLL_D20, CLK_APMIXED_UNIVPLL, 1, 20), + FACTOR0(CLK_TOP_MMPLL380M, CLK_APMIXED_MMPLL, 1, 1), + FACTOR0(CLK_TOP_MMPLL_D2, CLK_APMIXED_MMPLL, 1, 2), + FACTOR0(CLK_TOP_MMPLL_200M, CLK_APMIXED_MMPLL, 1, 3), + FACTOR0(CLK_TOP_USB_PHY48M, CLK_APMIXED_UNIVPLL, 1, 26), + FACTOR0(CLK_TOP_APLL1, CLK_APMIXED_APLL1, 1, 1), + FACTOR1(CLK_TOP_APLL1_D2, CLK_TOP_APLL1, 1, 2), + FACTOR1(CLK_TOP_APLL1_D4, CLK_TOP_RG_APLL1_D2_EN, 1, 2), + FACTOR1(CLK_TOP_APLL1_D8, CLK_TOP_RG_APLL1_D4_EN, 1, 2), + FACTOR0(CLK_TOP_APLL2, CLK_APMIXED_APLL2, 1, 1), + FACTOR1(CLK_TOP_APLL2_D2, CLK_TOP_APLL2, 1, 2), + FACTOR1(CLK_TOP_APLL2_D4, CLK_TOP_RG_APLL2_D2_EN, 1, 2), + FACTOR1(CLK_TOP_APLL2_D8, CLK_TOP_RG_APLL2_D4_EN, 1, 2), + FACTOR2(CLK_TOP_CLK26M, CLK_XTAL, 1, 1), + FACTOR2(CLK_TOP_CLK26M_D2, CLK_XTAL, 1, 2), + FACTOR1(CLK_TOP_AHB_INFRA_D2, CLK_TOP_AHB_INFRA_SEL, 1, 2), + FACTOR1(CLK_TOP_NFI1X, CLK_TOP_NFI2X_PAD_SEL, 1, 2), + FACTOR1(CLK_TOP_ETH_D2, CLK_TOP_ETH_SEL, 1, 2), +}; + +static const int uart0_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24, +}; + +static const int gfmux_emi1x_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_DMPLL, +}; + +static const int emi_ddrphy_parents[] = { + CLK_TOP_GFMUX_EMI1X_SEL, + CLK_TOP_GFMUX_EMI1X_SEL, +}; + +static const int ahb_infra_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D11, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D12, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D10, +}; + +static const int msdc0_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2, +}; + +static const int uart1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24, +}; + +static const int msdc1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2, +}; + +static const int pmicspi_parents[] = { + CLK_TOP_UNIVPLL_D20, + CLK_TOP_USB_PHY48M, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_CLK26M, +}; + +static const int qaxi_aud26m_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_AHB_INFRA_SEL, +}; + +static const int aud_intbus_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D22, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D11, +}; + +static const int nfi2x_pad_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MAINPLL_D8, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D6, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D4, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D10, + CLK_TOP_MAINPLL_D7, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D5 +}; + +static const int nfi1x_pad_parents[] = { + CLK_TOP_AHB_INFRA_SEL, + CLK_TOP_NFI1X, +}; + +static const int ddrphycfg_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D16 +}; + +static const int usb_78m_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D20, +}; + +static const int spinor_parents[] = { + CLK_TOP_CLK26M_D2, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D40, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_MAINPLL_D20, + CLK_TOP_MAINPLL_D16, + CLK_TOP_UNIVPLL_D12 +}; + +static const int msdc2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D6, + CLK_TOP_MAINPLL_D8, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_MAINPLL_D16, + CLK_TOP_MMPLL_200M, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MMPLL_D2 +}; + +static const int eth_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D40, + CLK_TOP_UNIVPLL_D24, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_MAINPLL_D20 +}; + +static const int aud1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_APLL1 +}; + +static const int aud2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_APLL2 +}; + +static const int aud_engen1_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_RG_APLL1_D2_EN, + CLK_TOP_RG_APLL1_D4_EN, + CLK_TOP_RG_APLL1_D8_EN +}; + +static const int aud_engen2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_RG_APLL2_D2_EN, + CLK_TOP_RG_APLL2_D4_EN, + CLK_TOP_RG_APLL2_D8_EN +}; + +static const int i2c_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D20, + CLK_TOP_UNIVPLL_D16, + CLK_TOP_UNIVPLL_D12 +}; + +static const int aud_i2s0_m_parents[] = { + CLK_TOP_RG_AUD1, + CLK_TOP_RG_AUD2 +}; + +static const int pwm_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12 +}; + +static const int spi_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D12, + CLK_TOP_UNIVPLL_D8, + CLK_TOP_UNIVPLL_D6 +}; + +static const int aud_spdifin_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D2 +}; + +static const int uart2_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_UNIVPLL_D24 +}; + +static const int bsi_parents[] = { + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D10, + CLK_TOP_MAINPLL_D12, + CLK_TOP_MAINPLL_D20 +}; + +static const int dbg_atclk_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_CLK26M, + CLK_TOP_MAINPLL_D5, + CLK_TOP_CLK_NULL, + CLK_TOP_UNIVPLL_D5 +}; + +static const int csw_nfiecc_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D7, + CLK_TOP_MAINPLL_D6, + CLK_TOP_CLK_NULL, + CLK_TOP_MAINPLL_D5 +}; + +static const int nfiecc_parents[] = { + CLK_TOP_CLK_NULL, + CLK_TOP_NFI2X_PAD_SEL, + CLK_TOP_MAINPLL_D4, + CLK_TOP_CLK_NULL, + CLK_TOP_CSW_NFIECC_SEL, +}; + +static const struct mtk_composite top_muxes[] = { + /* CLK_MUX_SEL0 */ + MUX(CLK_TOP_UART0_SEL, uart0_parents, 0x000, 0, 1), + MUX(CLK_TOP_GFMUX_EMI1X_SEL, gfmux_emi1x_parents, 0x000, 1, 1), + MUX(CLK_TOP_EMI_DDRPHY_SEL, emi_ddrphy_parents, 0x000, 2, 1), + MUX(CLK_TOP_AHB_INFRA_SEL, ahb_infra_parents, 0x000, 4, 4), + MUX(CLK_TOP_MSDC0_SEL, msdc0_parents, 0x000, 11, 3), + MUX(CLK_TOP_UART1_SEL, uart1_parents, 0x000, 19, 1), + MUX(CLK_TOP_MSDC1_SEL, msdc1_parents, 0x000, 20, 3), + MUX(CLK_TOP_PMICSPI_SEL, pmicspi_parents, 0x000, 24, 2), + MUX(CLK_TOP_QAXI_AUD26M_SEL, qaxi_aud26m_parents, 0x000, 26, 1), + MUX(CLK_TOP_AUD_INTBUS_SEL, aud_intbus_parents, 0x000, 27, 3), + /* CLK_MUX_SEL1 */ + MUX(CLK_TOP_NFI2X_PAD_SEL, nfi2x_pad_parents, 0x004, 0, 7), + MUX(CLK_TOP_NFI1X_PAD_SEL, nfi1x_pad_parents, 0x004, 7, 1), + MUX(CLK_TOP_DDRPHYCFG_SEL, ddrphycfg_parents, 0x004, 15, 1), + MUX(CLK_TOP_USB_78M_SEL, usb_78m_parents, 0x004, 20, 3), + /* CLK_MUX_SEL8 */ + MUX(CLK_TOP_SPINOR_SEL, spinor_parents, 0x040, 0, 3), + MUX(CLK_TOP_MSDC2_SEL, msdc2_parents, 0x040, 3, 3), + MUX(CLK_TOP_ETH_SEL, eth_parents, 0x040, 6, 3), + MUX(CLK_TOP_AUD1_SEL, aud1_parents, 0x040, 22, 1), + MUX(CLK_TOP_AUD2_SEL, aud2_parents, 0x040, 23, 1), + MUX(CLK_TOP_AUD_ENGEN1_SEL, aud_engen1_parents, 0x040, 24, 2), + MUX(CLK_TOP_AUD_ENGEN2_SEL, aud_engen2_parents, 0x040, 26, 2), + MUX(CLK_TOP_I2C_SEL, i2c_parents, 0x040, 28, 2), + /* CLK_MUX_SEL9 */ + MUX(CLK_TOP_AUD_I2S0_M_SEL, aud_i2s0_m_parents, 0x044, 12, 1), + MUX(CLK_TOP_AUD_I2S1_M_SEL, aud_i2s0_m_parents, 0x044, 13, 1), + MUX(CLK_TOP_AUD_I2S2_M_SEL, aud_i2s0_m_parents, 0x044, 14, 1), + MUX(CLK_TOP_AUD_I2S3_M_SEL, aud_i2s0_m_parents, 0x044, 15, 1), + MUX(CLK_TOP_AUD_I2S4_M_SEL, aud_i2s0_m_parents, 0x044, 16, 1), + MUX(CLK_TOP_AUD_I2S5_M_SEL, aud_i2s0_m_parents, 0x044, 17, 1), + MUX(CLK_TOP_AUD_SPDIF_B_SEL, aud_i2s0_m_parents, 0x044, 18, 1), + /* CLK_MUX_SEL13 */ + MUX(CLK_TOP_PWM_SEL, pwm_parents, 0x07c, 0, 1), + MUX(CLK_TOP_SPI_SEL, spi_parents, 0x07c, 1, 2), + MUX(CLK_TOP_AUD_SPDIFIN_SEL, aud_spdifin_parents, 0x07c, 3, 1), + MUX(CLK_TOP_UART2_SEL, uart2_parents, 0x07c, 4, 1), + MUX(CLK_TOP_BSI_SEL, bsi_parents, 0x07c, 5, 2), + MUX(CLK_TOP_DBG_ATCLK_SEL, dbg_atclk_parents, 0x07c, 7, 3), + MUX(CLK_TOP_CSW_NFIECC_SEL, csw_nfiecc_parents, 0x07c, 10, 3), + MUX(CLK_TOP_NFIECC_SEL, nfiecc_parents, 0x07c, 13, 3), +}; + +static const struct mtk_gate_regs top1_cg_regs = { + .set_ofs = 0x54, + .clr_ofs = 0x84, + .sta_ofs = 0x24, +}; + +static const struct mtk_gate_regs top2_cg_regs = { + .set_ofs = 0x6c, + .clr_ofs = 0x9c, + .sta_ofs = 0x3c, +}; + +static const struct mtk_gate_regs top3_cg_regs = { + .set_ofs = 0xa0, + .clr_ofs = 0xb0, + .sta_ofs = 0x70, +}; + +static const struct mtk_gate_regs top4_cg_regs = { + .set_ofs = 0xa4, + .clr_ofs = 0xb4, + .sta_ofs = 0x74, +}; + +static const struct mtk_gate_regs top5_cg_regs = { + .set_ofs = 0x44, + .clr_ofs = 0x44, + .sta_ofs = 0x44, +}; + +#define GATE_TOP1(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top1_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP2(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top2_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP2_I(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top2_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR_INV | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP3(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top3_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP4_I(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top4_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_SETCLR_INV | CLK_PARENT_TOPCKGEN, \ + } + +#define GATE_TOP5(_id, _parent, _shift) { \ + .id = _id, \ + .parent = _parent, \ + .regs = &top5_cg_regs, \ + .shift = _shift, \ + .flags = CLK_GATE_NO_SETCLR | CLK_PARENT_TOPCKGEN, \ + } + +static const struct mtk_gate top_clks[] = { + /* TOP1 */ + GATE_TOP1(CLK_TOP_THEM, CLK_TOP_AHB_INFRA_SEL, 1), + GATE_TOP1(CLK_TOP_APDMA, CLK_TOP_AHB_INFRA_SEL, 2), + GATE_TOP1(CLK_TOP_I2C0, CLK_IFR_I2C0_SEL, 3), + GATE_TOP1(CLK_TOP_I2C1, CLK_IFR_I2C1_SEL, 4), + GATE_TOP1(CLK_TOP_AUXADC1, CLK_TOP_AHB_INFRA_SEL, 5), + GATE_TOP1(CLK_TOP_NFI, CLK_TOP_NFI1X_PAD_SEL, 6), + GATE_TOP1(CLK_TOP_NFIECC, CLK_TOP_RG_NFIECC, 7), + GATE_TOP1(CLK_TOP_DEBUGSYS, CLK_TOP_RG_DBG_ATCLK, 8), + GATE_TOP1(CLK_TOP_PWM, CLK_TOP_AHB_INFRA_SEL, 9), + GATE_TOP1(CLK_TOP_UART0, CLK_TOP_UART0_SEL, 10), + GATE_TOP1(CLK_TOP_UART1, CLK_TOP_UART1_SEL, 11), + GATE_TOP1(CLK_TOP_BTIF, CLK_TOP_AHB_INFRA_SEL, 12), + GATE_TOP1(CLK_TOP_USB, CLK_TOP_USB_78M, 13), + GATE_TOP1(CLK_TOP_FLASHIF_26M, CLK_TOP_CLK26M, 14), + GATE_TOP1(CLK_TOP_AUXADC2, CLK_TOP_AHB_INFRA_SEL, 15), + GATE_TOP1(CLK_TOP_I2C2, CLK_IFR_I2C2_SEL, 16), + GATE_TOP1(CLK_TOP_MSDC0, CLK_TOP_MSDC0_SEL, 17), + GATE_TOP1(CLK_TOP_MSDC1, CLK_TOP_MSDC1_SEL, 18), + GATE_TOP1(CLK_TOP_NFI2X, CLK_TOP_NFI2X_PAD_SEL, 19), + GATE_TOP1(CLK_TOP_PMICWRAP_AP, CLK_TOP_CLK26M, 20), + GATE_TOP1(CLK_TOP_SEJ, CLK_TOP_AHB_INFRA_SEL, 21), + GATE_TOP1(CLK_TOP_MEMSLP_DLYER, CLK_TOP_CLK26M, 22), + GATE_TOP1(CLK_TOP_SPI, CLK_TOP_SPI_SEL, 23), + GATE_TOP1(CLK_TOP_APXGPT, CLK_TOP_CLK26M, 24), + GATE_TOP1(CLK_TOP_AUDIO, CLK_TOP_CLK26M, 25), + GATE_TOP1(CLK_TOP_PMICWRAP_MD, CLK_TOP_CLK26M, 27), + GATE_TOP1(CLK_TOP_PMICWRAP_CONN, CLK_TOP_CLK26M, 28), + GATE_TOP1(CLK_TOP_PMICWRAP_26M, CLK_TOP_CLK26M, 29), + GATE_TOP1(CLK_TOP_AUX_ADC, CLK_TOP_CLK26M, 30), + GATE_TOP1(CLK_TOP_AUX_TP, CLK_TOP_CLK26M, 31), + /* TOP2 */ + GATE_TOP2(CLK_TOP_MSDC2, CLK_TOP_AHB_INFRA_SEL, 0), + GATE_TOP2(CLK_TOP_RBIST, CLK_TOP_UNIVPLL_D12, 1), + GATE_TOP2(CLK_TOP_NFI_BUS, CLK_TOP_AHB_INFRA_SEL, 2), + GATE_TOP2(CLK_TOP_TRNG, CLK_TOP_AHB_INFRA_SEL, 5), + GATE_TOP2(CLK_TOP_SEJ_13M, CLK_TOP_CLK26M, 6), + GATE_TOP2(CLK_TOP_AES, CLK_TOP_AHB_INFRA_SEL, 7), + GATE_TOP2(CLK_TOP_PWM_B, CLK_TOP_RG_PWM_INFRA, 8), + GATE_TOP2(CLK_TOP_PWM1_FB, CLK_TOP_RG_PWM_INFRA, 9), + GATE_TOP2(CLK_TOP_PWM2_FB, CLK_TOP_RG_PWM_INFRA, 10), + GATE_TOP2(CLK_TOP_PWM3_FB, CLK_TOP_RG_PWM_INFRA, 11), + GATE_TOP2(CLK_TOP_PWM4_FB, CLK_TOP_RG_PWM_INFRA, 12), + GATE_TOP2(CLK_TOP_PWM5_FB, CLK_TOP_RG_PWM_INFRA, 13), + GATE_TOP2(CLK_TOP_USB_1P, CLK_TOP_USB_78M, 14), + GATE_TOP2(CLK_TOP_FLASHIF_FREERUN, CLK_TOP_AHB_INFRA_SEL, 15), + GATE_TOP2(CLK_TOP_66M_ETH, CLK_TOP_AHB_INFRA_D2, 19), + GATE_TOP2(CLK_TOP_133M_ETH, CLK_TOP_AHB_INFRA_SEL, 20), + GATE_TOP2(CLK_TOP_FETH_25M, CLK_IFR_ETH_25M_SEL, 21), + GATE_TOP2(CLK_TOP_FETH_50M, CLK_TOP_RG_ETH, 22), + GATE_TOP2(CLK_TOP_FLASHIF_AXI, CLK_TOP_AHB_INFRA_SEL, 23), + GATE_TOP2(CLK_TOP_USBIF, CLK_TOP_AHB_INFRA_SEL, 24), + GATE_TOP2(CLK_TOP_UART2, CLK_TOP_RG_UART2, 25), + GATE_TOP2(CLK_TOP_BSI, CLK_TOP_AHB_INFRA_SEL, 26), + GATE_TOP2_I(CLK_TOP_MSDC0_INFRA, CLK_TOP_MSDC0, 28), + GATE_TOP2_I(CLK_TOP_MSDC1_INFRA, CLK_TOP_MSDC1, 29), + GATE_TOP2_I(CLK_TOP_MSDC2_INFRA, CLK_TOP_RG_MSDC2, 30), + GATE_TOP2(CLK_TOP_USB_78M, CLK_TOP_USB_78M_SEL, 31), + /* TOP3 */ + GATE_TOP3(CLK_TOP_RG_SPINOR, CLK_TOP_SPINOR_SEL, 0), + GATE_TOP3(CLK_TOP_RG_MSDC2, CLK_TOP_MSDC2_SEL, 1), + GATE_TOP3(CLK_TOP_RG_ETH, CLK_TOP_ETH_SEL, 2), + GATE_TOP3(CLK_TOP_RG_AUD1, CLK_TOP_AUD1_SEL, 8), + GATE_TOP3(CLK_TOP_RG_AUD2, CLK_TOP_AUD2_SEL, 9), + GATE_TOP3(CLK_TOP_RG_AUD_ENGEN1, CLK_TOP_AUD_ENGEN1_SEL, 10), + GATE_TOP3(CLK_TOP_RG_AUD_ENGEN2, CLK_TOP_AUD_ENGEN2_SEL, 11), + GATE_TOP3(CLK_TOP_RG_I2C, CLK_TOP_I2C_SEL, 12), + GATE_TOP3(CLK_TOP_RG_PWM_INFRA, CLK_TOP_PWM_SEL, 13), + GATE_TOP3(CLK_TOP_RG_AUD_SPDIF_IN, CLK_TOP_AUD_SPDIFIN_SEL, 14), + GATE_TOP3(CLK_TOP_RG_UART2, CLK_TOP_UART2_SEL, 15), + GATE_TOP3(CLK_TOP_RG_BSI, CLK_TOP_BSI_SEL, 16), + GATE_TOP3(CLK_TOP_RG_DBG_ATCLK, CLK_TOP_DBG_ATCLK_SEL, 17), + GATE_TOP3(CLK_TOP_RG_NFIECC, CLK_TOP_NFIECC_SEL, 18), + /* TOP4 */ + GATE_TOP4_I(CLK_TOP_RG_APLL1_D2_EN, CLK_TOP_APLL1_D2, 8), + GATE_TOP4_I(CLK_TOP_RG_APLL1_D4_EN, CLK_TOP_APLL1_D4, 9), + GATE_TOP4_I(CLK_TOP_RG_APLL1_D8_EN, CLK_TOP_APLL1_D8, 10), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D2_EN, CLK_TOP_APLL2_D2, 11), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D4_EN, CLK_TOP_APLL2_D4, 12), + GATE_TOP4_I(CLK_TOP_RG_APLL2_D8_EN, CLK_TOP_APLL2_D8, 13), + /* TOP5 */ + GATE_TOP5(CLK_TOP_APLL12_DIV0, CLK_TOP_APLL12_CK_DIV0, 0), + GATE_TOP5(CLK_TOP_APLL12_DIV1, CLK_TOP_APLL12_CK_DIV1, 1), + GATE_TOP5(CLK_TOP_APLL12_DIV2, CLK_TOP_APLL12_CK_DIV2, 2), + GATE_TOP5(CLK_TOP_APLL12_DIV3, CLK_TOP_APLL12_CK_DIV3, 3), + GATE_TOP5(CLK_TOP_APLL12_DIV4, CLK_TOP_APLL12_CK_DIV4, 4), + GATE_TOP5(CLK_TOP_APLL12_DIV4B, CLK_TOP_APLL12_CK_DIV4B, 5), + GATE_TOP5(CLK_TOP_APLL12_DIV5, CLK_TOP_APLL12_CK_DIV5, 6), + GATE_TOP5(CLK_TOP_APLL12_DIV5B, CLK_TOP_APLL12_CK_DIV5B, 7), + GATE_TOP5(CLK_TOP_APLL12_DIV6, CLK_TOP_APLL12_CK_DIV6, 8), +}; + +static const struct mtk_clk_tree mt8516_clk_tree = { + .xtal_rate = 26 * MHZ, + .xtal2_rate = 26 * MHZ, + .fdivs_offs = CLK_TOP_DMPLL, + .muxes_offs = CLK_TOP_UART0_SEL, + .plls = apmixed_plls, + .fclks = top_fixed_clks, + .fdivs = top_fixed_divs, + .muxes = top_muxes, +}; + +static int mt8516_apmixedsys_probe(struct udevice *dev) +{ + return mtk_common_clk_init(dev, &mt8516_clk_tree); +} + +static int mt8516_topckgen_probe(struct udevice *dev) +{ + return mtk_common_clk_init(dev, &mt8516_clk_tree); +} + +static int mt8516_topckgen_cg_probe(struct udevice *dev) +{ + return mtk_common_clk_gate_init(dev, &mt8516_clk_tree, top_clks); +} + +static const struct udevice_id mt8516_apmixed_compat[] = { + { .compatible = "mediatek,mt8516-apmixedsys", }, + { } +}; + +static const struct udevice_id mt8516_topckgen_compat[] = { + { .compatible = "mediatek,mt8516-topckgen", }, + { } +}; + +static const struct udevice_id mt8516_topckgen_cg_compat[] = { + { .compatible = "mediatek,mt8516-topckgen-cg", }, + { } +}; + +U_BOOT_DRIVER(mtk_clk_apmixedsys) = { + .name = "mt8516-apmixedsys", + .id = UCLASS_CLK, + .of_match = mt8516_apmixed_compat, + .probe = mt8516_apmixedsys_probe, + .priv_auto_alloc_size = sizeof(struct mtk_clk_priv), + .ops = &mtk_clk_apmixedsys_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER(mtk_clk_topckgen) = { + .name = "mt8516-topckgen", + .id = UCLASS_CLK, + .of_match = mt8516_topckgen_compat, + .probe = mt8516_topckgen_probe, + .priv_auto_alloc_size = sizeof(struct mtk_clk_priv), + .ops = &mtk_clk_topckgen_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER(mtk_clk_topckgen_cg) = { + .name = "mt8516-topckgen-cg", + .id = UCLASS_CLK, + .of_match = mt8516_topckgen_cg_compat, + .probe = mt8516_topckgen_cg_probe, + .priv_auto_alloc_size = sizeof(struct mtk_cg_priv), + .ops = &mtk_clk_gate_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/mt8516-clk.h b/include/dt-bindings/clock/mt8516-clk.h new file mode 100644 index 0000000000..0efccbab21 --- /dev/null +++ b/include/dt-bindings/clock/mt8516-clk.h @@ -0,0 +1,230 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018 BayLibre, SAS + * Copyright (c) 2018 MediaTek Inc. + * Author: Fabien Parent fparent@baylibre.com + */ + +#ifndef _DT_BINDINGS_CLK_MT8516_H +#define _DT_BINDINGS_CLK_MT8516_H + + +/* APMIXEDSYS */ + +#define CLK_APMIXED_ARMPLL 0 +#define CLK_APMIXED_MAINPLL 1 +#define CLK_APMIXED_UNIVPLL 2 +#define CLK_APMIXED_MMPLL 3 +#define CLK_APMIXED_APLL1 4 +#define CLK_APMIXED_APLL2 5 +#define CLK_APMIXED_NR_CLK 6 + +/* TOPCKGEN */ + +#define CLK_TOP_CLK_NULL 0 +#define CLK_TOP_I2S_INFRA_BCK 1 +#define CLK_TOP_MEMPLL 2 +#define CLK_TOP_DMPLL 3 +#define CLK_TOP_MAINPLL_D2 4 +#define CLK_TOP_MAINPLL_D4 5 +#define CLK_TOP_MAINPLL_D8 6 +#define CLK_TOP_MAINPLL_D16 7 +#define CLK_TOP_MAINPLL_D11 8 +#define CLK_TOP_MAINPLL_D22 9 +#define CLK_TOP_MAINPLL_D3 10 +#define CLK_TOP_MAINPLL_D6 11 +#define CLK_TOP_MAINPLL_D12 12 +#define CLK_TOP_MAINPLL_D5 13 +#define CLK_TOP_MAINPLL_D10 14 +#define CLK_TOP_MAINPLL_D20 15 +#define CLK_TOP_MAINPLL_D40 16 +#define CLK_TOP_MAINPLL_D7 17 +#define CLK_TOP_MAINPLL_D14 18 +#define CLK_TOP_UNIVPLL_D2 19 +#define CLK_TOP_UNIVPLL_D4 20 +#define CLK_TOP_UNIVPLL_D8 21 +#define CLK_TOP_UNIVPLL_D16 22 +#define CLK_TOP_UNIVPLL_D3 23 +#define CLK_TOP_UNIVPLL_D6 24 +#define CLK_TOP_UNIVPLL_D12 25 +#define CLK_TOP_UNIVPLL_D24 26 +#define CLK_TOP_UNIVPLL_D5 27 +#define CLK_TOP_UNIVPLL_D20 28 +#define CLK_TOP_MMPLL380M 29 +#define CLK_TOP_MMPLL_D2 30 +#define CLK_TOP_MMPLL_200M 31 +#define CLK_TOP_USB_PHY48M 32 +#define CLK_TOP_APLL1 33 +#define CLK_TOP_APLL1_D2 34 +#define CLK_TOP_APLL1_D4 35 +#define CLK_TOP_APLL1_D8 36 +#define CLK_TOP_APLL2 37 +#define CLK_TOP_APLL2_D2 38 +#define CLK_TOP_APLL2_D4 39 +#define CLK_TOP_APLL2_D8 40 +#define CLK_TOP_CLK26M 41 +#define CLK_TOP_CLK26M_D2 42 +#define CLK_TOP_AHB_INFRA_D2 43 +#define CLK_TOP_NFI1X 44 +#define CLK_TOP_ETH_D2 45 +#define CLK_TOP_UART0_SEL 46 +#define CLK_TOP_GFMUX_EMI1X_SEL 47 +#define CLK_TOP_EMI_DDRPHY_SEL 48 +#define CLK_TOP_AHB_INFRA_SEL 49 +#define CLK_TOP_MSDC0_SEL 50 +#define CLK_TOP_UART1_SEL 51 +#define CLK_TOP_MSDC1_SEL 52 +#define CLK_TOP_PMICSPI_SEL 53 +#define CLK_TOP_QAXI_AUD26M_SEL 54 +#define CLK_TOP_AUD_INTBUS_SEL 55 +#define CLK_TOP_NFI2X_PAD_SEL 56 +#define CLK_TOP_NFI1X_PAD_SEL 57 +#define CLK_TOP_DDRPHYCFG_SEL 58 +#define CLK_TOP_USB_78M_SEL 59 +#define CLK_TOP_SPINOR_SEL 60 +#define CLK_TOP_MSDC2_SEL 61 +#define CLK_TOP_ETH_SEL 62 +#define CLK_TOP_AUD1_SEL 63 +#define CLK_TOP_AUD2_SEL 64 +#define CLK_TOP_AUD_ENGEN1_SEL 65 +#define CLK_TOP_AUD_ENGEN2_SEL 66 +#define CLK_TOP_I2C_SEL 67 +#define CLK_TOP_AUD_I2S0_M_SEL 68 +#define CLK_TOP_AUD_I2S1_M_SEL 69 +#define CLK_TOP_AUD_I2S2_M_SEL 70 +#define CLK_TOP_AUD_I2S3_M_SEL 71 +#define CLK_TOP_AUD_I2S4_M_SEL 72 +#define CLK_TOP_AUD_I2S5_M_SEL 73 +#define CLK_TOP_AUD_SPDIF_B_SEL 74 +#define CLK_TOP_PWM_SEL 75 +#define CLK_TOP_SPI_SEL 76 +#define CLK_TOP_AUD_SPDIFIN_SEL 77 +#define CLK_TOP_UART2_SEL 78 +#define CLK_TOP_BSI_SEL 79 +#define CLK_TOP_DBG_ATCLK_SEL 80 +#define CLK_TOP_CSW_NFIECC_SEL 81 +#define CLK_TOP_NFIECC_SEL 82 +#define CLK_TOP_APLL12_CK_DIV0 83 +#define CLK_TOP_APLL12_CK_DIV1 84 +#define CLK_TOP_APLL12_CK_DIV2 85 +#define CLK_TOP_APLL12_CK_DIV3 86 +#define CLK_TOP_APLL12_CK_DIV4 87 +#define CLK_TOP_APLL12_CK_DIV4B 88 +#define CLK_TOP_APLL12_CK_DIV5 89 +#define CLK_TOP_APLL12_CK_DIV5B 90 +#define CLK_TOP_APLL12_CK_DIV6 91 +#define CLK_TOP_NR_CLK 92 + +/* TOPCKGEN Gates */ +#define CLK_TOP_THEM 0 +#define CLK_TOP_APDMA 1 +#define CLK_TOP_I2C0 2 +#define CLK_TOP_I2C1 3 +#define CLK_TOP_AUXADC1 4 +#define CLK_TOP_NFI 5 +#define CLK_TOP_NFIECC 6 +#define CLK_TOP_DEBUGSYS 7 +#define CLK_TOP_PWM 8 +#define CLK_TOP_UART0 9 +#define CLK_TOP_UART1 10 +#define CLK_TOP_BTIF 11 +#define CLK_TOP_USB 12 +#define CLK_TOP_FLASHIF_26M 13 +#define CLK_TOP_AUXADC2 14 +#define CLK_TOP_I2C2 15 +#define CLK_TOP_MSDC0 16 +#define CLK_TOP_MSDC1 17 +#define CLK_TOP_NFI2X 18 +#define CLK_TOP_PMICWRAP_AP 19 +#define CLK_TOP_SEJ 20 +#define CLK_TOP_MEMSLP_DLYER 21 +#define CLK_TOP_SPI 22 +#define CLK_TOP_APXGPT 23 +#define CLK_TOP_AUDIO 24 +#define CLK_TOP_PMICWRAP_MD 25 +#define CLK_TOP_PMICWRAP_CONN 26 +#define CLK_TOP_PMICWRAP_26M 27 +#define CLK_TOP_AUX_ADC 28 +#define CLK_TOP_AUX_TP 29 +#define CLK_TOP_MSDC2 30 +#define CLK_TOP_RBIST 31 +#define CLK_TOP_NFI_BUS 32 +#define CLK_TOP_TRNG 33 +#define CLK_TOP_SEJ_13M 34 +#define CLK_TOP_AES 35 +#define CLK_TOP_PWM_B 36 +#define CLK_TOP_PWM1_FB 37 +#define CLK_TOP_PWM2_FB 38 +#define CLK_TOP_PWM3_FB 39 +#define CLK_TOP_PWM4_FB 40 +#define CLK_TOP_PWM5_FB 41 +#define CLK_TOP_USB_1P 42 +#define CLK_TOP_FLASHIF_FREERUN 43 +#define CLK_TOP_66M_ETH 44 +#define CLK_TOP_133M_ETH 45 +#define CLK_TOP_FETH_25M 46 +#define CLK_TOP_FETH_50M 47 +#define CLK_TOP_FLASHIF_AXI 48 +#define CLK_TOP_USBIF 49 +#define CLK_TOP_UART2 50 +#define CLK_TOP_BSI 51 +#define CLK_TOP_MSDC0_INFRA 52 +#define CLK_TOP_MSDC1_INFRA 53 +#define CLK_TOP_MSDC2_INFRA 54 +#define CLK_TOP_USB_78M 55 +#define CLK_TOP_RG_SPINOR 56 +#define CLK_TOP_RG_MSDC2 57 +#define CLK_TOP_RG_ETH 58 +#define CLK_TOP_RG_AUD1 59 +#define CLK_TOP_RG_AUD2 60 +#define CLK_TOP_RG_AUD_ENGEN1 61 +#define CLK_TOP_RG_AUD_ENGEN2 62 +#define CLK_TOP_RG_I2C 63 +#define CLK_TOP_RG_PWM_INFRA 64 +#define CLK_TOP_RG_AUD_SPDIF_IN 65 +#define CLK_TOP_RG_UART2 66 +#define CLK_TOP_RG_BSI 67 +#define CLK_TOP_RG_DBG_ATCLK 68 +#define CLK_TOP_RG_NFIECC 69 +#define CLK_TOP_RG_APLL1_D2_EN 70 +#define CLK_TOP_RG_APLL1_D4_EN 71 +#define CLK_TOP_RG_APLL1_D8_EN 72 +#define CLK_TOP_RG_APLL2_D2_EN 73 +#define CLK_TOP_RG_APLL2_D4_EN 74 +#define CLK_TOP_RG_APLL2_D8_EN 75 +#define CLK_TOP_APLL12_DIV0 76 +#define CLK_TOP_APLL12_DIV1 77 +#define CLK_TOP_APLL12_DIV2 78 +#define CLK_TOP_APLL12_DIV3 79 +#define CLK_TOP_APLL12_DIV4 80 +#define CLK_TOP_APLL12_DIV4B 81 +#define CLK_TOP_APLL12_DIV5 82 +#define CLK_TOP_APLL12_DIV5B 83 +#define CLK_TOP_APLL12_DIV6 84 + +/* INFRACFG */ + +#define CLK_IFR_MUX1_SEL 0 +#define CLK_IFR_ETH_25M_SEL 1 +#define CLK_IFR_I2C0_SEL 2 +#define CLK_IFR_I2C1_SEL 3 +#define CLK_IFR_I2C2_SEL 4 +#define CLK_IFR_NR_CLK 5 + +/* AUDIOTOP */ + +#define CLK_AUD_AFE 0 +#define CLK_AUD_I2S 1 +#define CLK_AUD_22M 2 +#define CLK_AUD_24M 3 +#define CLK_AUD_INTDIR 4 +#define CLK_AUD_APLL2_TUNER 5 +#define CLK_AUD_APLL_TUNER 6 +#define CLK_AUD_SPDF 7 +#define CLK_AUD_ADC 8 +#define CLK_AUD_DAC 9 +#define CLK_AUD_DAC_PREDIS 10 +#define CLK_AUD_TML 11 +#define CLK_AUD_NR_CLK 12 + +#endif /* _DT_BINDINGS_CLK_MT8516_H */
On Sun, Mar 24, 2019 at 04:46:36PM +0100, Fabien Parent wrote:
Add clock driver for MediaTek MT8516 SoC.
Signed-off-by: Fabien Parent fparent@baylibre.com Acked-by: Ryder Lee ryder.lee@mediatek.com
Add Pinctrl driver for MediaTek MT8516 SoC.
Signed-off-by: Fabien Parent fparent@baylibre.com Acked-by: Ryder Lee ryder.lee@mediatek.com ---
v3: * Fix incorrect field size for mt8516_pin_mode_range
v2: * No change
--- drivers/pinctrl/mediatek/Kconfig | 4 + drivers/pinctrl/mediatek/Makefile | 1 + drivers/pinctrl/mediatek/pinctrl-mt8516.c | 391 ++++++++++++++++++++++ 3 files changed, 396 insertions(+) create mode 100644 drivers/pinctrl/mediatek/pinctrl-mt8516.c
diff --git a/drivers/pinctrl/mediatek/Kconfig b/drivers/pinctrl/mediatek/Kconfig index 1bd9a925a5..9930ca1faf 100644 --- a/drivers/pinctrl/mediatek/Kconfig +++ b/drivers/pinctrl/mediatek/Kconfig @@ -12,4 +12,8 @@ config PINCTRL_MT7629 bool "MT7629 SoC pinctrl driver" select PINCTRL_MTK
+config PINCTRL_MT8516 + bool "MT8516 SoC pinctrl driver" + select PINCTRL_MTK + endif diff --git a/drivers/pinctrl/mediatek/Makefile b/drivers/pinctrl/mediatek/Makefile index f6ef3627e8..c4f29088d2 100644 --- a/drivers/pinctrl/mediatek/Makefile +++ b/drivers/pinctrl/mediatek/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_PINCTRL_MTK) += pinctrl-mtk-common.o # SoC Drivers obj-$(CONFIG_PINCTRL_MT7623) += pinctrl-mt7623.o obj-$(CONFIG_PINCTRL_MT7629) += pinctrl-mt7629.o +obj-$(CONFIG_PINCTRL_MT8516) += pinctrl-mt8516.o diff --git a/drivers/pinctrl/mediatek/pinctrl-mt8516.c b/drivers/pinctrl/mediatek/pinctrl-mt8516.c new file mode 100644 index 0000000000..829b30e5a2 --- /dev/null +++ b/drivers/pinctrl/mediatek/pinctrl-mt8516.c @@ -0,0 +1,391 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <dm.h> + +#include "pinctrl-mtk-common.h" + +#define PIN_FIELD(_s_pin, _e_pin, _s_addr, _x_addrs, _s_bit, _x_bits) \ + PIN_FIELD_CALC(_s_pin, _e_pin, _s_addr, _x_addrs, _s_bit, \ + _x_bits, 16, false) + +static const struct mtk_pin_field_calc mt8516_pin_mode_range[] = { + PIN_FIELD_CALC(0, 124, 0x300, 0x10, 0, 3, 15, false), +}; + +static const struct mtk_pin_field_calc mt8516_pin_dir_range[] = { + PIN_FIELD(0, 124, 0x0, 0x10, 0, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_di_range[] = { + PIN_FIELD(0, 124, 0x200, 0x10, 0, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_do_range[] = { + PIN_FIELD(0, 124, 0x100, 0x10, 0, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_ies_range[] = { + PIN_FIELD(0, 6, 0x900, 0x10, 2, 1), + PIN_FIELD(7, 10, 0x900, 0x10, 3, 1), + PIN_FIELD(11, 13, 0x900, 0x10, 12, 1), + PIN_FIELD(14, 17, 0x900, 0x10, 13, 1), + PIN_FIELD(18, 20, 0x910, 0x10, 10, 1), + PIN_FIELD(21, 23, 0x900, 0x10, 13, 1), + PIN_FIELD(24, 25, 0x900, 0x10, 12, 1), + PIN_FIELD(26, 30, 0x900, 0x10, 0, 1), + PIN_FIELD(31, 33, 0x900, 0x10, 1, 1), + PIN_FIELD(34, 39, 0x900, 0x10, 2, 1), + PIN_FIELD(40, 40, 0x910, 0x10, 11, 1), + PIN_FIELD(41, 43, 0x900, 0x10, 10, 1), + PIN_FIELD(44, 47, 0x900, 0x10, 11, 1), + PIN_FIELD(48, 51, 0x900, 0x10, 14, 1), + PIN_FIELD(52, 53, 0x910, 0x10, 0, 1), + PIN_FIELD(54, 54, 0x910, 0x10, 2, 1), + PIN_FIELD(55, 57, 0x910, 0x10, 4, 1), + PIN_FIELD(58, 59, 0x900, 0x10, 15, 1), + PIN_FIELD(60, 61, 0x910, 0x10, 1, 1), + PIN_FIELD(62, 65, 0x910, 0x10, 5, 1), + PIN_FIELD(66, 67, 0x910, 0x10, 6, 1), + PIN_FIELD(68, 68, 0x930, 0x10, 2, 1), + PIN_FIELD(69, 69, 0x930, 0x10, 1, 1), + PIN_FIELD(70, 70, 0x930, 0x10, 6, 1), + PIN_FIELD(71, 71, 0x930, 0x10, 5, 1), + PIN_FIELD(72, 72, 0x930, 0x10, 4, 1), + PIN_FIELD(73, 73, 0x930, 0x10, 3, 1), + + PIN_FIELD(100, 103, 0x910, 0x10, 7, 1), + PIN_FIELD(104, 104, 0x920, 0x10, 12, 1), + PIN_FIELD(105, 105, 0x920, 0x10, 11, 1), + PIN_FIELD(106, 106, 0x930, 0x10, 0, 1), + PIN_FIELD(107, 107, 0x920, 0x10, 15, 1), + PIN_FIELD(108, 108, 0x920, 0x10, 14, 1), + PIN_FIELD(109, 109, 0x920, 0x10, 13, 1), + PIN_FIELD(110, 110, 0x920, 0x10, 9, 1), + PIN_FIELD(111, 111, 0x920, 0x10, 8, 1), + PIN_FIELD(112, 112, 0x920, 0x10, 7, 1), + PIN_FIELD(113, 113, 0x920, 0x10, 6, 1), + PIN_FIELD(114, 114, 0x920, 0x10, 10, 1), + PIN_FIELD(115, 115, 0x920, 0x10, 1, 1), + PIN_FIELD(116, 116, 0x920, 0x10, 0, 1), + PIN_FIELD(117, 117, 0x920, 0x10, 5, 1), + PIN_FIELD(118, 118, 0x920, 0x10, 4, 1), + PIN_FIELD(119, 119, 0x920, 0x10, 3, 1), + PIN_FIELD(120, 120, 0x920, 0x10, 2, 1), + PIN_FIELD(121, 124, 0x910, 0x10, 9, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_smt_range[] = { + PIN_FIELD(0, 6, 0xA00, 0x10, 2, 1), + PIN_FIELD(7, 10, 0xA00, 0x10, 3, 1), + PIN_FIELD(11, 13, 0xA00, 0x10, 12, 1), + PIN_FIELD(14, 17, 0xA00, 0x10, 13, 1), + PIN_FIELD(18, 20, 0xA10, 0x10, 10, 1), + PIN_FIELD(21, 23, 0xA00, 0x10, 13, 1), + PIN_FIELD(24, 25, 0xA00, 0x10, 12, 1), + PIN_FIELD(26, 30, 0xA00, 0x10, 0, 1), + PIN_FIELD(31, 33, 0xA00, 0x10, 1, 1), + PIN_FIELD(40, 40, 0xA10, 0x10, 11, 1), + PIN_FIELD(41, 43, 0xA00, 0x10, 10, 1), + PIN_FIELD(44, 47, 0xA00, 0x10, 11, 1), + PIN_FIELD(48, 51, 0xA00, 0x10, 14, 1), + PIN_FIELD(52, 53, 0xA10, 0x10, 0, 1), + PIN_FIELD(54, 54, 0xA10, 0x10, 2, 1), + PIN_FIELD(55, 57, 0xA10, 0x10, 4, 1), + PIN_FIELD(58, 59, 0xA00, 0x10, 15, 1), + PIN_FIELD(60, 61, 0xA10, 0x10, 1, 1), + PIN_FIELD(62, 65, 0xA10, 0x10, 5, 1), + PIN_FIELD(66, 67, 0xA10, 0x10, 6, 1), + PIN_FIELD(68, 68, 0xA30, 0x10, 2, 1), + PIN_FIELD(69, 69, 0xA30, 0x10, 1, 1), + PIN_FIELD(70, 70, 0xA30, 0x10, 3, 1), + PIN_FIELD(71, 71, 0xA30, 0x10, 4, 1), + PIN_FIELD(72, 72, 0xA30, 0x10, 5, 1), + PIN_FIELD(73, 73, 0xA30, 0x10, 6, 1), + + PIN_FIELD(100, 103, 0xA10, 0x10, 7, 1), + PIN_FIELD(104, 104, 0xA20, 0x10, 12, 1), + PIN_FIELD(105, 105, 0xA20, 0x10, 11, 1), + PIN_FIELD(106, 106, 0xA30, 0x10, 13, 1), + PIN_FIELD(107, 107, 0xA20, 0x10, 14, 1), + PIN_FIELD(108, 108, 0xA20, 0x10, 15, 1), + PIN_FIELD(109, 109, 0xA30, 0x10, 0, 1), + PIN_FIELD(110, 110, 0xA20, 0x10, 9, 1), + PIN_FIELD(111, 111, 0xA20, 0x10, 8, 1), + PIN_FIELD(112, 112, 0xA20, 0x10, 7, 1), + PIN_FIELD(113, 113, 0xA20, 0x10, 6, 1), + PIN_FIELD(114, 114, 0xA20, 0x10, 10, 1), + PIN_FIELD(115, 115, 0xA20, 0x10, 1, 1), + PIN_FIELD(116, 116, 0xA20, 0x10, 0, 1), + PIN_FIELD(117, 117, 0xA20, 0x10, 5, 1), + PIN_FIELD(118, 118, 0xA20, 0x10, 4, 1), + PIN_FIELD(119, 119, 0xA20, 0x10, 3, 1), + PIN_FIELD(120, 120, 0xA20, 0x10, 2, 1), + PIN_FIELD(121, 124, 0xA10, 0x10, 9, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_pullen_range[] = { + PIN_FIELD(0, 13, 0x500, 0x10, 0, 1), + PIN_FIELD(18, 20, 0x510, 0x10, 2, 1), + PIN_FIELD(24, 31, 0x510, 0x10, 8, 1), + PIN_FIELD(32, 39, 0x520, 0x10, 0, 1), + PIN_FIELD(44, 47, 0x520, 0x10, 12, 1), + PIN_FIELD(48, 63, 0x530, 0x10, 0, 1), + PIN_FIELD(64, 67, 0x540, 0x10, 0, 1), + PIN_FIELD(100, 103, 0x560, 0x10, 4, 1), + PIN_FIELD(121, 124, 0x570, 0x10, 9, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_pullsel_range[] = { + PIN_FIELD(0, 13, 0x600, 0x10, 0, 1), + PIN_FIELD(18, 20, 0x610, 0x10, 2, 1), + PIN_FIELD(24, 31, 0x610, 0x10, 8, 1), + PIN_FIELD(32, 39, 0x620, 0x10, 0, 1), + PIN_FIELD(44, 47, 0x620, 0x10, 12, 1), + PIN_FIELD(48, 63, 0x630, 0x10, 0, 1), + PIN_FIELD(64, 67, 0x640, 0x10, 0, 1), + PIN_FIELD(100, 103, 0x660, 0x10, 4, 1), + PIN_FIELD(121, 124, 0x670, 0x10, 9, 1), +}; + +static const struct mtk_pin_field_calc mt8516_pin_drv_range[] = { + PIN_FIELD(0, 4, 0xd00, 0x10, 0, 4), + PIN_FIELD(5, 10, 0xd00, 0x10, 4, 4), + PIN_FIELD(11, 13, 0xd00, 0x10, 8, 4), + PIN_FIELD(14, 17, 0xd00, 0x10, 12, 4), + PIN_FIELD(18, 20, 0xd10, 0x10, 0, 4), + PIN_FIELD(21, 23, 0xd00, 0x10, 12, 4), + PIN_FIELD(24, 25, 0xd00, 0x10, 8, 4), + PIN_FIELD(26, 30, 0xd10, 0x10, 4, 4), + PIN_FIELD(31, 33, 0xd10, 0x10, 8, 4), + PIN_FIELD(34, 35, 0xd10, 0x10, 12, 4), + PIN_FIELD(36, 39, 0xd20, 0x10, 0, 4), + PIN_FIELD(40, 40, 0xd20, 0x10, 4, 4), + PIN_FIELD(41, 43, 0xd20, 0x10, 8, 4), + PIN_FIELD(44, 47, 0xd20, 0x10, 12, 4), + PIN_FIELD(48, 51, 0xd30, 0x10, 0, 4), + PIN_FIELD(54, 54, 0xd30, 0x10, 8, 4), + PIN_FIELD(55, 57, 0xd30, 0x10, 12, 4), + PIN_FIELD(62, 67, 0xd40, 0x10, 8, 4), + PIN_FIELD(68, 68, 0xd40, 0x10, 12, 4), + PIN_FIELD(69, 69, 0xd50, 0x10, 0, 4), + PIN_FIELD(70, 73, 0xd50, 0x10, 4, 4), + PIN_FIELD(100, 103, 0xd50, 0x10, 8, 4), + PIN_FIELD(104, 104, 0xd50, 0x10, 12, 4), + PIN_FIELD(105, 105, 0xd60, 0x10, 0, 4), + PIN_FIELD(106, 109, 0xd60, 0x10, 4, 4), + PIN_FIELD(110, 113, 0xd70, 0x10, 0, 4), + PIN_FIELD(114, 114, 0xd70, 0x10, 4, 4), + PIN_FIELD(115, 115, 0xd60, 0x10, 12, 4), + PIN_FIELD(116, 116, 0xd60, 0x10, 8, 4), + PIN_FIELD(117, 120, 0xd70, 0x10, 0, 4), +}; + +static const struct mtk_pin_reg_calc mt8516_reg_cals[] = { + [PINCTRL_PIN_REG_MODE] = MTK_RANGE(mt8516_pin_mode_range), + [PINCTRL_PIN_REG_DIR] = MTK_RANGE(mt8516_pin_dir_range), + [PINCTRL_PIN_REG_DI] = MTK_RANGE(mt8516_pin_di_range), + [PINCTRL_PIN_REG_DO] = MTK_RANGE(mt8516_pin_do_range), + [PINCTRL_PIN_REG_IES] = MTK_RANGE(mt8516_pin_ies_range), + [PINCTRL_PIN_REG_SMT] = MTK_RANGE(mt8516_pin_smt_range), + [PINCTRL_PIN_REG_PULLSEL] = MTK_RANGE(mt8516_pin_pullsel_range), + [PINCTRL_PIN_REG_PULLEN] = MTK_RANGE(mt8516_pin_pullen_range), + [PINCTRL_PIN_REG_DRV] = MTK_RANGE(mt8516_pin_drv_range), +}; + +static const struct mtk_pin_desc mt8516_pins[] = { + MTK_PIN(0, "EINT0", DRV_GRP0), + MTK_PIN(1, "EINT1", DRV_GRP0), + MTK_PIN(2, "EINT2", DRV_GRP0), + MTK_PIN(3, "EINT3", DRV_GRP0), + MTK_PIN(4, "EINT4", DRV_GRP0), + MTK_PIN(5, "EINT5", DRV_GRP0), + MTK_PIN(6, "EINT6", DRV_GRP0), + MTK_PIN(7, "EINT7", DRV_GRP0), + MTK_PIN(8, "EINT8", DRV_GRP0), + MTK_PIN(9, "EINT9", DRV_GRP0), + MTK_PIN(10, "EINT10", DRV_GRP0), + MTK_PIN(11, "EINT11", DRV_GRP0), + MTK_PIN(12, "EINT12", DRV_GRP0), + MTK_PIN(13, "EINT13", DRV_GRP0), + MTK_PIN(14, "EINT14", DRV_GRP2), + MTK_PIN(15, "EINT15", DRV_GRP2), + MTK_PIN(16, "EINT16", DRV_GRP2), + MTK_PIN(17, "EINT17", DRV_GRP2), + MTK_PIN(18, "EINT18", DRV_GRP0), + MTK_PIN(19, "EINT19", DRV_GRP0), + MTK_PIN(20, "EINT20", DRV_GRP0), + MTK_PIN(21, "EINT21", DRV_GRP2), + MTK_PIN(22, "EINT22", DRV_GRP2), + MTK_PIN(23, "EINT23", DRV_GRP2), + MTK_PIN(24, "EINT24", DRV_GRP0), + MTK_PIN(25, "EINT25", DRV_GRP0), + MTK_PIN(26, "PWRAP_SPI0_MI", DRV_GRP4), + MTK_PIN(27, "PWRAP_SPI0_MO", DRV_GRP4), + MTK_PIN(28, "PWRAP_INT", DRV_GRP4), + MTK_PIN(29, "PWRAP_SPIO0_CK", DRV_GRP4), + MTK_PIN(30, "PWARP_SPI0_CSN", DRV_GRP4), + MTK_PIN(31, "RTC32K_CK", DRV_GRP4), + MTK_PIN(32, "WATCHDOG", DRV_GRP4), + MTK_PIN(33, "SRCLKENA0", DRV_GRP4), + MTK_PIN(34, "URXD2", DRV_GRP0), + MTK_PIN(35, "UTXD2", DRV_GRP0), + MTK_PIN(36, "MRG_CLK", DRV_GRP0), + MTK_PIN(37, "MRG_SYNC", DRV_GRP0), + MTK_PIN(38, "MRG_DI", DRV_GRP0), + MTK_PIN(39, "MRG_DO", DRV_GRP0), + MTK_PIN(40, "KPROW0", DRV_GRP2), + MTK_PIN(41, "KPROW1", DRV_GRP2), + MTK_PIN(42, "KPCOL0", DRV_GRP2), + MTK_PIN(43, "KPCOL1", DRV_GRP2), + MTK_PIN(44, "JMTS", DRV_GRP2), + MTK_PIN(45, "JTCK", DRV_GRP2), + MTK_PIN(46, "JTDI", DRV_GRP2), + MTK_PIN(47, "JTDO", DRV_GRP2), + MTK_PIN(48, "SPI_CS", DRV_GRP2), + MTK_PIN(49, "SPI_CK", DRV_GRP2), + MTK_PIN(50, "SPI_MI", DRV_GRP2), + MTK_PIN(51, "SPI_MO", DRV_GRP2), + MTK_PIN(52, "SDA1", DRV_GRP2), + MTK_PIN(53, "SCL1", DRV_GRP2), + MTK_PIN(54, "DISP_PWM", DRV_GRP2), + MTK_PIN(55, "I2S_DATA_IN", DRV_GRP2), + MTK_PIN(56, "I2S_LRCK", DRV_GRP2), + MTK_PIN(57, "I2S_BCK", DRV_GRP2), + MTK_PIN(58, "SDA0", DRV_GRP2), + MTK_PIN(59, "SCL0", DRV_GRP2), + MTK_PIN(60, "SDA2", DRV_GRP2), + MTK_PIN(61, "SCL2", DRV_GRP2), + MTK_PIN(62, "URXD0", DRV_GRP2), + MTK_PIN(63, "UTXD0", DRV_GRP2), + MTK_PIN(64, "URXD1", DRV_GRP2), + MTK_PIN(65, "UTXD1", DRV_GRP2), + MTK_PIN(66, "LCM_RST", DRV_GRP2), + MTK_PIN(67, "DSI_TE", DRV_GRP2), + MTK_PIN(68, "MSDC2_CMD", DRV_GRP4), + MTK_PIN(69, "MSDC2_CLK", DRV_GRP4), + MTK_PIN(70, "MSDC2_DAT0", DRV_GRP4), + MTK_PIN(71, "MSDC2_DAT1", DRV_GRP4), + MTK_PIN(72, "MSDC2_DAT2", DRV_GRP4), + MTK_PIN(73, "MSDC2_DAT3", DRV_GRP4), + MTK_PIN(74, "TDN3", DRV_GRP0), + MTK_PIN(75, "TDP3", DRV_GRP0), + MTK_PIN(76, "TDN2", DRV_GRP0), + MTK_PIN(77, "TDP2", DRV_GRP0), + MTK_PIN(78, "TCN", DRV_GRP0), + MTK_PIN(79, "TCP", DRV_GRP0), + MTK_PIN(80, "TDN1", DRV_GRP0), + MTK_PIN(81, "TDP1", DRV_GRP0), + MTK_PIN(82, "TDN0", DRV_GRP0), + MTK_PIN(83, "TDP0", DRV_GRP0), + MTK_PIN(84, "RDN0", DRV_GRP0), + MTK_PIN(85, "RDP0", DRV_GRP0), + MTK_PIN(86, "RDN1", DRV_GRP0), + MTK_PIN(87, "RDP1", DRV_GRP0), + MTK_PIN(88, "RCN", DRV_GRP0), + MTK_PIN(89, "RCP", DRV_GRP0), + MTK_PIN(90, "RDN2", DRV_GRP0), + MTK_PIN(91, "RDP2", DRV_GRP0), + MTK_PIN(92, "RDN3", DRV_GRP0), + MTK_PIN(93, "RDP3", DRV_GRP0), + MTK_PIN(94, "RCN_A", DRV_GRP0), + MTK_PIN(95, "RCP_A", DRV_GRP0), + MTK_PIN(96, "RDN1_A", DRV_GRP0), + MTK_PIN(97, "RDP1_A", DRV_GRP0), + MTK_PIN(98, "RDN0_A", DRV_GRP0), + MTK_PIN(99, "RDP0_A", DRV_GRP0), + MTK_PIN(100, "CMDDAT0", DRV_GRP2), + MTK_PIN(101, "CMDDAT1", DRV_GRP2), + MTK_PIN(102, "CMMCLK", DRV_GRP2), + MTK_PIN(103, "CMPCLK", DRV_GRP2), + MTK_PIN(104, "MSDC1_CMD", DRV_GRP4), + MTK_PIN(105, "MSDC1_CLK", DRV_GRP4), + MTK_PIN(106, "MSDC1_DAT0", DRV_GRP4), + MTK_PIN(107, "MSDC1_DAT1", DRV_GRP4), + MTK_PIN(108, "MSDC1_DAT2", DRV_GRP4), + MTK_PIN(109, "MSDC1_DAT3", DRV_GRP4), + MTK_PIN(110, "MSDC0_DAT7", DRV_GRP4), + MTK_PIN(111, "MSDC0_DAT6", DRV_GRP4), + MTK_PIN(112, "MSDC0_DAT5", DRV_GRP4), + MTK_PIN(113, "MSDC0_DAT4", DRV_GRP4), + MTK_PIN(114, "MSDC0_RSTB", DRV_GRP4), + MTK_PIN(115, "MSDC0_CMD", DRV_GRP4), + MTK_PIN(116, "MSDC0_CLK", DRV_GRP4), + MTK_PIN(117, "MSDC0_DAT3", DRV_GRP4), + MTK_PIN(118, "MSDC0_DAT2", DRV_GRP4), + MTK_PIN(119, "MSDC0_DAT1", DRV_GRP4), + MTK_PIN(120, "MSDC0_DAT0", DRV_GRP4), +}; + +/* List all groups consisting of these pins dedicated to the enablement of + * certain hardware block and the corresponding mode for all of the pins. + * The hardware probably has multiple combinations of these pinouts. + */ + +/* UART */ +static int mt8516_uart0_0_rxd_txd_pins[] = { 62, 63, }; +static int mt8516_uart0_0_rxd_txd_funcs[] = { 1, 1, }; +static int mt8516_uart1_0_rxd_txd_pins[] = { 64, 65, }; +static int mt8516_uart1_0_rxd_txd_funcs[] = { 1, 1, }; +static int mt8516_uart2_0_rxd_txd_pins[] = { 34, 35, }; +static int mt8516_uart2_0_rxd_txd_funcs[] = { 1, 1, }; + +/* Joint those groups owning the same capability in user point of view which + * allows that people tend to use through the device tree. + */ +static const char *const mt8516_uart_groups[] = { "uart0_0_rxd_txd", + "uart1_0_rxd_txd", + "uart2_0_rxd_txd", }; + +/* MMC0 */ +static int mt8516_msdc0_pins[] = { 110, 111, 112, 113, 114, 115, 116, 117, 118, + 119, 120, }; +static int mt8516_msdc0_funcs[] = { 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, }; + +static const struct mtk_group_desc mt8516_groups[] = { + PINCTRL_PIN_GROUP("uart0_0_rxd_txd", mt8516_uart0_0_rxd_txd), + PINCTRL_PIN_GROUP("uart1_0_rxd_txd", mt8516_uart1_0_rxd_txd), + PINCTRL_PIN_GROUP("uart2_0_rxd_txd", mt8516_uart2_0_rxd_txd), + + PINCTRL_PIN_GROUP("msdc0", mt8516_msdc0), +}; + +static const char *const mt8516_msdc_groups[] = { "msdc0" }; + +static const struct mtk_function_desc mt8516_functions[] = { + {"uart", mt8516_uart_groups, ARRAY_SIZE(mt8516_uart_groups)}, + {"msdc", mt8516_msdc_groups, ARRAY_SIZE(mt8516_msdc_groups)}, +}; + +static struct mtk_pinctrl_soc mt8516_data = { + .name = "mt8516_pinctrl", + .reg_cal = mt8516_reg_cals, + .pins = mt8516_pins, + .npins = ARRAY_SIZE(mt8516_pins), + .grps = mt8516_groups, + .ngrps = ARRAY_SIZE(mt8516_groups), + .funcs = mt8516_functions, + .nfuncs = ARRAY_SIZE(mt8516_functions), +}; + +static int mtk_pinctrl_mt8516_probe(struct udevice *dev) +{ + return mtk_pinctrl_common_probe(dev, &mt8516_data); +} + +static const struct udevice_id mt8516_pctrl_match[] = { + { .compatible = "mediatek,mt8516-pinctrl" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(mt8516_pinctrl) = { + .name = "mt8516_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = mt8516_pctrl_match, + .ops = &mtk_pinctrl_ops, + .probe = mtk_pinctrl_mt8516_probe, + .priv_auto_alloc_size = sizeof(struct mtk_pinctrl_priv), +};
Add support for MediaTek MT8516 SoC. This include the file that will initialize the SoC after boot and its device tree.
Signed-off-by: Fabien Parent fparent@baylibre.com Reviewed-by: Tom Rini trini@konsulko.com ---
v3: * No change
v2: * Move u-boot,dm-pre-reloc into a seperate dts * Implement dram_init_banksize to get DRAM size correct
--- arch/arm/dts/mt8516-u-boot.dtsi | 25 +++++ arch/arm/dts/mt8516.dtsi | 136 +++++++++++++++++++++++++ arch/arm/mach-mediatek/Kconfig | 10 ++ arch/arm/mach-mediatek/Makefile | 1 + arch/arm/mach-mediatek/mt8516/Makefile | 3 + arch/arm/mach-mediatek/mt8516/init.c | 120 ++++++++++++++++++++++ 6 files changed, 295 insertions(+) create mode 100644 arch/arm/dts/mt8516-u-boot.dtsi create mode 100644 arch/arm/dts/mt8516.dtsi create mode 100644 arch/arm/mach-mediatek/mt8516/Makefile create mode 100644 arch/arm/mach-mediatek/mt8516/init.c
diff --git a/arch/arm/dts/mt8516-u-boot.dtsi b/arch/arm/dts/mt8516-u-boot.dtsi new file mode 100644 index 0000000000..3c0d843f35 --- /dev/null +++ b/arch/arm/dts/mt8516-u-boot.dtsi @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2019 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +&infracfg { + u-boot,dm-pre-reloc; +}; + +&topckgen_ { + u-boot,dm-pre-reloc; +}; + +&topckgen_cg { + u-boot,dm-pre-reloc; +}; + +&apmixedsys { + u-boot,dm-pre-reloc; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/mt8516.dtsi b/arch/arm/dts/mt8516.dtsi new file mode 100644 index 0000000000..1c33582086 --- /dev/null +++ b/arch/arm/dts/mt8516.dtsi @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Copyright (C) 2019 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <dt-bindings/clock/mt8516-clk.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + compatible = "mediatek,mt8516"; + interrupt-parent = <&sysirq>; + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "mediatek,mt8516-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x0>; + clock-frequency = <1300000000>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x1>; + clock-frequency = <1300000000>; + }; + + cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x2>; + clock-frequency = <1300000000>; + }; + + cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a35"; + reg = <0x3>; + clock-frequency = <1300000000>; + }; + }; + + topckgen: clock-controller@10000000 { + compatible = "mediatek,mt8516-topckgen"; + reg = <0x10000000 0x1000>; + #clock-cells = <1>; + }; + + topckgen_cg: clock-controller-cg@10000000 { + compatible = "mediatek,mt8516-topckgen-cg"; + reg = <0x10000000 0x1000>; + #clock-cells = <1>; + }; + + infracfg: clock-controller@10001000 { + compatible = "mediatek,mt8516-infracfg"; + reg = <0x10001000 0x1000>; + #clock-cells = <1>; + }; + + apmixedsys: clock-controller@10018000 { + compatible = "mediatek,mt8516-apmixedsys"; + reg = <0x10018000 0x710>; + #clock-cells = <1>; + }; + + gic: interrupt-controller@10310000 { + compatible = "arm,gic-400"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0x10310000 0x1000>, + <0x10320000 0x1000>, + <0x10340000 0x2000>, + <0x10360000 0x2000>; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + sysirq: interrupt-controller@10200620 { + compatible = "mediatek,sysirq"; + interrupt-controller; + #interrupt-cells = <3>; + interrupt-parent = <&gic>; + reg = <0x10200620 0x20>; + }; + + watchdog: watchdog@10007000 { + compatible = "mediatek,wdt"; + reg = <0x10007000 0x1000>; + interrupts = <GIC_SPI 198 IRQ_TYPE_EDGE_FALLING>; + #reset-cells = <1>; + status = "disabled"; + }; + + pinctrl: pinctrl@10005000 { + compatible = "mediatek,mt8516-pinctrl"; + reg = <0x10005000 0x1000>; + + gpio: gpio-controller { + gpio-controller; + #gpio-cells = <2>; + }; + }; + + mmc0: mmc@11120000 { + compatible = "mediatek,mt8516-mmc"; + reg = <0x11120000 0x1000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_LOW>; + clocks = <&topckgen_cg CLK_TOP_MSDC0>, + <&topckgen CLK_TOP_AHB_INFRA_SEL>, + <&topckgen_cg CLK_TOP_MSDC0_INFRA>; + clock-names = "source", "hclk", "source_cg"; + status = "disabled"; + }; + + uart0: serial@11005000 { + compatible = "mediatek,hsuart"; + reg = <0x11005000 0x1000>; + reg-shift = <2>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_LOW>; + clocks = <&topckgen CLK_TOP_UART0_SEL>, + <&topckgen_cg CLK_TOP_UART0>; + clock-names = "baud","bus"; + status = "disabled"; + }; +}; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 7a733e95df..b5e91d4a7d 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -31,6 +31,16 @@ config TARGET_MT7629 including DDR3, crypto engine, 3x3 11n/ac Wi-Fi, Gigabit Ethernet, switch, USB3.0, PCIe, UART, SPI, I2C and PWM.
+config TARGET_MT8516 + bool "MediaTek MT8516 SoC" + select ARM64 + select ARCH_MISC_INIT + help + The MediaTek MT8516 is a ARM64-based SoC with a quad-core Cortex-A35. + including UART, SPI, USB2.0 and OTG, SD and MMC cards, NAND, PWM, + Ethernet, IR TX/RX, I2C, I2S, S/PDIF, and built-in Wi-Fi / Bluetooth combo + chip and several DDR3 and DDR4 options. + endchoice
source "board/mediatek/mt7623/Kconfig" diff --git a/arch/arm/mach-mediatek/Makefile b/arch/arm/mach-mediatek/Makefile index b5d3a379bc..ea414dc407 100644 --- a/arch/arm/mach-mediatek/Makefile +++ b/arch/arm/mach-mediatek/Makefile @@ -5,3 +5,4 @@ obj-$(CONFIG_SPL_BUILD) += spl.o
obj-$(CONFIG_TARGET_MT7623) += mt7623/ obj-$(CONFIG_TARGET_MT7629) += mt7629/ +obj-$(CONFIG_TARGET_MT8516) += mt8516/ diff --git a/arch/arm/mach-mediatek/mt8516/Makefile b/arch/arm/mach-mediatek/mt8516/Makefile new file mode 100644 index 0000000000..886ab7e4eb --- /dev/null +++ b/arch/arm/mach-mediatek/mt8516/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += init.o diff --git a/arch/arm/mach-mediatek/mt8516/init.c b/arch/arm/mach-mediatek/mt8516/init.c new file mode 100644 index 0000000000..26a215a8b1 --- /dev/null +++ b/arch/arm/mach-mediatek/mt8516/init.c @@ -0,0 +1,120 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 MediaTek Inc. + * Copyright (C) 2019 BayLibre, SAS + * Author: Fabien Parent fparent@baylibre.com + */ + +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <ram.h> +#include <asm/arch/misc.h> +#include <asm/armv8/mmu.h> +#include <asm/sections.h> +#include <dm/uclass.h> +#include <linux/io.h> +#include <dt-bindings/clock/mt8516-clk.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define WDOG_SWRST 0x10007014 +#define WDOG_SWRST_KEY 0x1209 + +int dram_init(void) +{ + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = gd->ram_base; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + +int mtk_pll_early_init(void) +{ + unsigned long pll_rates[] = { + [CLK_APMIXED_ARMPLL] = 1300000000, + [CLK_APMIXED_MAINPLL] = 1501000000, + [CLK_APMIXED_UNIVPLL] = 1248000000, + [CLK_APMIXED_MMPLL] = 380000000, + }; + struct udevice *dev; + int ret, i; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(mtk_clk_apmixedsys), &dev); + if (ret) + return ret; + + /* configure default rate then enable apmixedsys */ + for (i = 0; i < ARRAY_SIZE(pll_rates); i++) { + struct clk clk = { .id = i, .dev = dev }; + + ret = clk_set_rate(&clk, pll_rates[i]); + if (ret) + return ret; + + ret = clk_enable(&clk); + if (ret) + return ret; + } + + return 0; +} + +int mtk_soc_early_init(void) +{ + int ret; + + /* initialize early clocks */ + ret = mtk_pll_early_init(); + if (ret) + return ret; + + return 0; +} + +void reset_cpu(ulong addr) +{ + while (1) { + writel(WDOG_SWRST_KEY, WDOG_SWRST); + mdelay(5); + } +} + +int print_cpuinfo(void) +{ + printf("CPU: MediaTek MT8516\n"); + return 0; +} + +static struct mm_region mt8516_mem_map[] = { + { + /* DDR */ + .virt = 0x40000000UL, + .phys = 0x40000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_OUTER_SHARE, + }, { + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 0x20000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + 0, + } +}; +struct mm_region *mem_map = mt8516_mem_map;
Fabien Parent
