[U-Boot] [PATCH v2 0/2] rename colibri_t20
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 [1] get rid of the carrier board post fix in the board/configuration/device-tree naming.
[1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/192041
Changes in v2: - squashed it all together into two patches as suggested by Stephen in order to avoid any intermediate breakage and "git bisect" issues - added my previously missing signed-off-by
Marcel Ziswiler (2): ARM: tegra: get rid of colibri_t20-common ARM: tegra: rename colibri_t20 board/configuration/device-tree
arch/arm/dts/Makefile | 2 +- ...20-colibri_t20_iris.dts => tegra20-colibri.dts} | 0 arch/arm/mach-tegra/tegra20/Kconfig | 4 +-- .../colibri_t20-common/colibri_t20-common.c | 35 ------------- .../colibri_t20-common/colibri_t20-common.h | 7 ----- .../{colibri_t20_iris => colibri_t20}/Kconfig | 6 ++-- .../{colibri_t20_iris => colibri_t20}/MAINTAINERS | 9 +++--- .../{colibri_t20_iris => colibri_t20}/Makefile | 6 ++-- .../colibri_t20.c} | 33 +++++++++++++++----- ...ri_t20_iris_defconfig => colibri_t20_defconfig} | 4 +-- .../configs/{colibri_t20_iris.h => colibri_t20.h} | 6 ++-- tools/buildman/README | 2 +- 12 files changed, 45 insertions(+), 105 deletions(-) rename arch/arm/dts/{tegra20-colibri_t20_iris.dts => tegra20-colibri.dts} (100%) delete mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.c delete mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.h rename board/toradex/{colibri_t20_iris => colibri_t20}/Kconfig (51%) rename board/toradex/{colibri_t20_iris => colibri_t20}/MAINTAINERS (24%) rename board/toradex/{colibri_t20_iris => colibri_t20}/Makefile (39%) rename board/toradex/{colibri_t20_iris/colibri_t20_iris.c => colibri_t20/colibri_t20.c} (65%) rename configs/{colibri_t20_iris_defconfig => colibri_t20_defconfig} (34%) rename include/configs/{colibri_t20_iris.h => colibri_t20.h} (89%)
As a preparatory step to renaming the board folder as well first get rid of the colibri_t20-common after having integrated it into colibri_t20_iris for now.
While at it also migrate to using NVIDIA's common.mk magic.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- .../colibri_t20-common/colibri_t20-common.c | 35 ------------------ .../colibri_t20-common/colibri_t20-common.h | 7 ---- board/toradex/colibri_t20_iris/Makefile | 4 +-- board/toradex/colibri_t20_iris/colibri_t20_iris.c | 42 +++++++++++++++------- 4 files changed, 31 insertions(+), 57 deletions(-) delete mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.c delete mode 100644 board/toradex/colibri_t20-common/colibri_t20-common.h
diff --git a/board/toradex/colibri_t20-common/colibri_t20-common.c b/board/toradex/colibri_t20-common/colibri_t20-common.c deleted file mode 100644 index 58a9916..0000000 --- a/board/toradex/colibri_t20-common/colibri_t20-common.c +++ /dev/null @@ -1,35 +0,0 @@ -/* - * Copyright (C) 2012 Lucas Stach - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/arch/clock.h> -#include <asm/arch/funcmux.h> -#include <asm/arch/pinmux.h> -#include <asm/arch-tegra/board.h> - -#include "colibri_t20-common.h" - -#ifdef CONFIG_USB_EHCI_TEGRA -void colibri_t20_common_pin_mux_usb(void) -{ - /* module internal USB bus to connect ethernet chipset */ - funcmux_select(PERIPH_ID_USB2, FUNCMUX_USB2_ULPI); - /* ULPI reference clock output */ - pinmux_set_func(PMUX_PINGRP_CDEV2, PMUX_FUNC_PLLP_OUT4); - pinmux_tristate_disable(PMUX_PINGRP_CDEV2); - /* PHY reset GPIO */ - pinmux_tristate_disable(PMUX_PINGRP_UAC); - /* VBus GPIO */ - pinmux_tristate_disable(PMUX_PINGRP_DTE); -} -#endif - -#ifdef CONFIG_TEGRA_NAND -void pin_mux_nand(void) -{ - funcmux_select(PERIPH_ID_NDFLASH, FUNCMUX_NDFLASH_KBC_8_BIT); -} -#endif diff --git a/board/toradex/colibri_t20-common/colibri_t20-common.h b/board/toradex/colibri_t20-common/colibri_t20-common.h deleted file mode 100644 index 1fe53f6..0000000 --- a/board/toradex/colibri_t20-common/colibri_t20-common.h +++ /dev/null @@ -1,7 +0,0 @@ -/* - * Copyright (C) 2012 Lucas Stach - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -void colibri_t20_common_pin_mux_usb(void); diff --git a/board/toradex/colibri_t20_iris/Makefile b/board/toradex/colibri_t20_iris/Makefile index ebeac70..f286aec 100644 --- a/board/toradex/colibri_t20_iris/Makefile +++ b/board/toradex/colibri_t20_iris/Makefile @@ -4,6 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := ../../nvidia/common/board.o -obj-y += ../colibri_t20-common/colibri_t20-common.o +include $(srctree)/board/nvidia/common/common.mk + obj-y += colibri_t20_iris.o diff --git a/board/toradex/colibri_t20_iris/colibri_t20_iris.c b/board/toradex/colibri_t20_iris/colibri_t20_iris.c index 49c74f3..4656094 100644 --- a/board/toradex/colibri_t20_iris/colibri_t20_iris.c +++ b/board/toradex/colibri_t20_iris/colibri_t20_iris.c @@ -5,23 +5,11 @@ */
#include <common.h> -#include <asm/gpio.h> #include <asm/arch/clock.h> #include <asm/arch/funcmux.h> #include <asm/arch/pinmux.h> #include <asm/arch-tegra/board.h> - -#include "../colibri_t20-common/colibri_t20-common.h" - -#ifdef CONFIG_USB_EHCI_TEGRA -void pin_mux_usb(void) -{ - colibri_t20_common_pin_mux_usb(); - - /* USB 1 aka Tegra USB port 3 VBus*/ - pinmux_tristate_disable(PMUX_PINGRP_SPIG); -} -#endif +#include <asm/gpio.h>
#ifdef CONFIG_TEGRA_MMC /* @@ -34,3 +22,31 @@ void pin_mux_mmc(void) pinmux_tristate_disable(PMUX_PINGRP_GMB); } #endif + +#ifdef CONFIG_TEGRA_NAND +void pin_mux_nand(void) +{ + funcmux_select(PERIPH_ID_NDFLASH, FUNCMUX_NDFLASH_KBC_8_BIT); +} +#endif + +#ifdef CONFIG_USB_EHCI_TEGRA +void pin_mux_usb(void) +{ + /* module internal USB bus to connect ethernet chipset */ + funcmux_select(PERIPH_ID_USB2, FUNCMUX_USB2_ULPI); + + /* ULPI reference clock output */ + pinmux_set_func(PMUX_PINGRP_CDEV2, PMUX_FUNC_PLLP_OUT4); + pinmux_tristate_disable(PMUX_PINGRP_CDEV2); + + /* PHY reset GPIO */ + pinmux_tristate_disable(PMUX_PINGRP_UAC); + + /* VBus GPIO */ + pinmux_tristate_disable(PMUX_PINGRP_DTE); + + /* USB 1 aka Tegra USB port 3 VBus */ + pinmux_tristate_disable(PMUX_PINGRP_SPIG); +} +#endif
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 get rid of the carrier board in the board/ configuration/device-tree naming.
While at it also bring the prompt more in line with our other products.
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- arch/arm/dts/Makefile | 2 +- .../dts/{tegra20-colibri_t20_iris.dts => tegra20-colibri.dts} | 0 arch/arm/mach-tegra/tegra20/Kconfig | 4 ++-- board/toradex/{colibri_t20_iris => colibri_t20}/Kconfig | 6 +++--- board/toradex/{colibri_t20_iris => colibri_t20}/MAINTAINERS | 9 +++++---- board/toradex/{colibri_t20_iris => colibri_t20}/Makefile | 2 +- .../colibri_t20_iris.c => colibri_t20/colibri_t20.c} | 0 configs/{colibri_t20_iris_defconfig => colibri_t20_defconfig} | 4 ++-- include/configs/{colibri_t20_iris.h => colibri_t20.h} | 6 +++--- tools/buildman/README | 2 +- 10 files changed, 18 insertions(+), 17 deletions(-) rename arch/arm/dts/{tegra20-colibri_t20_iris.dts => tegra20-colibri.dts} (100%) rename board/toradex/{colibri_t20_iris => colibri_t20}/Kconfig (51%) rename board/toradex/{colibri_t20_iris => colibri_t20}/MAINTAINERS (24%) rename board/toradex/{colibri_t20_iris => colibri_t20}/Makefile (81%) rename board/toradex/{colibri_t20_iris/colibri_t20_iris.c => colibri_t20/colibri_t20.c} (100%) rename configs/{colibri_t20_iris_defconfig => colibri_t20_defconfig} (34%) rename include/configs/{colibri_t20_iris.h => colibri_t20.h} (89%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cbe5b86..f897e6d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -24,7 +24,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-trimslice.dtb \ tegra20-ventana.dtb \ tegra20-whistler.dtb \ - tegra20-colibri_t20_iris.dtb \ + tegra20-colibri.dtb \ tegra30-apalis.dtb \ tegra30-beaver.dtb \ tegra30-cardhu.dtb \ diff --git a/arch/arm/dts/tegra20-colibri_t20_iris.dts b/arch/arm/dts/tegra20-colibri.dts similarity index 100% rename from arch/arm/dts/tegra20-colibri_t20_iris.dts rename to arch/arm/dts/tegra20-colibri.dts diff --git a/arch/arm/mach-tegra/tegra20/Kconfig b/arch/arm/mach-tegra/tegra20/Kconfig index a354e2a..7f09f81 100644 --- a/arch/arm/mach-tegra/tegra20/Kconfig +++ b/arch/arm/mach-tegra/tegra20/Kconfig @@ -30,7 +30,7 @@ config TARGET_VENTANA config TARGET_WHISTLER bool "NVIDIA Tegra20 Whistler evaluation board"
-config TARGET_COLIBRI_T20_IRIS +config TARGET_COLIBRI_T20 bool "Toradex Colibri T20 board"
endchoice @@ -47,6 +47,6 @@ source "board/avionic-design/tec/Kconfig" source "board/compulab/trimslice/Kconfig" source "board/nvidia/ventana/Kconfig" source "board/nvidia/whistler/Kconfig" -source "board/toradex/colibri_t20_iris/Kconfig" +source "board/toradex/colibri_t20/Kconfig"
endif diff --git a/board/toradex/colibri_t20_iris/Kconfig b/board/toradex/colibri_t20/Kconfig similarity index 51% rename from board/toradex/colibri_t20_iris/Kconfig rename to board/toradex/colibri_t20/Kconfig index 4bf7278..7f373b2 100644 --- a/board/toradex/colibri_t20_iris/Kconfig +++ b/board/toradex/colibri_t20/Kconfig @@ -1,12 +1,12 @@ -if TARGET_COLIBRI_T20_IRIS +if TARGET_COLIBRI_T20
config SYS_BOARD - default "colibri_t20_iris" + default "colibri_t20"
config SYS_VENDOR default "toradex"
config SYS_CONFIG_NAME - default "colibri_t20_iris" + default "colibri_t20"
endif diff --git a/board/toradex/colibri_t20_iris/MAINTAINERS b/board/toradex/colibri_t20/MAINTAINERS similarity index 24% rename from board/toradex/colibri_t20_iris/MAINTAINERS rename to board/toradex/colibri_t20/MAINTAINERS index c68955b..b251c00 100644 --- a/board/toradex/colibri_t20_iris/MAINTAINERS +++ b/board/toradex/colibri_t20/MAINTAINERS @@ -1,6 +1,7 @@ -COLIBRI_T20_IRIS BOARD +COLIBRI_T20 M: Lucas Stach dev@lynxeye.de S: Maintained -F: board/toradex/colibri_t20_iris/ -F: include/configs/colibri_t20_iris.h -F: configs/colibri_t20_iris_defconfig +F: board/toradex/colibri_t20/ +F: include/configs/colibri_t20.h +F: configs/colibri_t20_defconfig +F: arch/arm/dts/tegra20-colibri.dtb diff --git a/board/toradex/colibri_t20_iris/Makefile b/board/toradex/colibri_t20/Makefile similarity index 81% rename from board/toradex/colibri_t20_iris/Makefile rename to board/toradex/colibri_t20/Makefile index f286aec..86f78d9 100644 --- a/board/toradex/colibri_t20_iris/Makefile +++ b/board/toradex/colibri_t20/Makefile @@ -6,4 +6,4 @@
-obj-y += colibri_t20_iris.o +obj-y += colibri_t20.o diff --git a/board/toradex/colibri_t20_iris/colibri_t20_iris.c b/board/toradex/colibri_t20/colibri_t20.c similarity index 100% rename from board/toradex/colibri_t20_iris/colibri_t20_iris.c rename to board/toradex/colibri_t20/colibri_t20.c diff --git a/configs/colibri_t20_iris_defconfig b/configs/colibri_t20_defconfig similarity index 34% rename from configs/colibri_t20_iris_defconfig rename to configs/colibri_t20_defconfig index a14d55a..8987567 100644 --- a/configs/colibri_t20_iris_defconfig +++ b/configs/colibri_t20_defconfig @@ -1,5 +1,5 @@ CONFIG_ARM=y CONFIG_TEGRA=y CONFIG_TEGRA20=y -CONFIG_TARGET_COLIBRI_T20_IRIS=y -CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri_t20_iris" +CONFIG_TARGET_COLIBRI_T20=y +CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" diff --git a/include/configs/colibri_t20_iris.h b/include/configs/colibri_t20.h similarity index 89% rename from include/configs/colibri_t20_iris.h rename to include/configs/colibri_t20.h index 4888c94..e80e9ed 100644 --- a/include/configs/colibri_t20_iris.h +++ b/include/configs/colibri_t20.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Lucas Stach + * Copyright (C) 2012 Lucas Stach * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,8 +10,8 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Colibri) # " -#define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T20 on Iris" +#define V_PROMPT "Colibri T20 # " +#define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T20"
/* Board-specific serial config */ #define CONFIG_TEGRA_ENABLE_UARTA diff --git a/tools/buildman/README b/tools/buildman/README index cf7bf5c..e870d54 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -613,7 +613,7 @@ $ ./tools/buildman/buildman -b us-mem4 -sSdB run_list_real 1996 2000 +4 do_nandboot 760 756 -4 do_mem_crc 168 68 -100 - colibri_t20_iris: all -9 rodata -29 text +20 + colibri_t20 : all -9 rodata -29 text +20 u-boot: add: 1/0, grow: 2/-3 bytes: 140/-112 (28) function old new delta hash_command 80 160 +80
The series, Acked-by: Stephen Warren swarren@nvidia.com
Marcel,
This series applied to u-boot-tegra/next. I'll push an update today or tomorrow to Denx.de.
Tom
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Thursday, March 26, 2015 7:15 AM To: Marcel Ziswiler Cc: u-boot@lists.denx.de; Marek Vasut; Akshay Saraswat; Fabio Estevam; Tom Rini; Pavel Machek; Michal Simek; Masahiro Yamada; Tom Warren; Hyungwon Hwang; Stephen Warren; Stefan Roese Subject: Re: [U-Boot] [PATCH v2 0/2] rename colibri_t20
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Marcel Ziswiler
Stephen Warren
Tom Warren
