[U-Boot] [Patch V6 00/18] add LS1043A platform support
Hi All,
Here are the changes for version 6 patchset. Please kindly help to review the patchset.
- Added secondary core support - Added ls2085a simulator/emulator into the arch-fsl-layerscape framework - Moved some SoC related macors from board header file into config.h
- serdes_prtl enum is not merged between ls2085a platform and ls1043a platform due to the fact that they are using different DPAA implementation.
[Patch V6 01/18] armv7/ls1021a: move ns_access to common file [Patch V6 02/18] common/board_f.c: modify the macro to use [Patch V6 03/18] net/fm: Fix the endian issue to support both [Patch V6 04/18] net/fm/eth: Use mb() to be compatible for both ARM [Patch V6 05/18] net/fm: Add support for 64-bit platforms [Patch V6 06/18] net/fm: Make the return value logic consistent with [Patch V6 07/18] net: fm: bug fix when CONFIG_PHYLIB not defined [Patch V6 08/18] net: Move some header files to include/ [Patch V6 09/18] net/fm: Add QSGMII PCS init [Patch V6 10/18] net/fm: fix MDIO controller base on FMAN2 [Patch V6 11/18] armv8/fsl_lsch3: Change arch to fsl-layerscape [Patch V6 12/18] armv8/fsl_lsch2: Add fsl_lsch2 SoC [Patch V6 13/18] armv8/ls1043ardb: Add LS1043ARDB board support [Patch V6 14/18] armv8/ls1043ardb: Add nand boot support [Patch V6 15/18] armv8/ls1043a: Add Fman support [Patch V6 16/18] armv8/ls1043ardb: esdhc: Add esdhc support for [Patch V6 17/18] armv8/ls1043ardb: Add sd boot support [Patch V6 18/18] armv8/ls1043a: Enable secondary cores
Thanks, Qianyu
Config Security Level Register is different between different SoCs, so put the CSL register definition into the arch specific directory.
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - No change. V2: - Create include/fsl_csu.h instead of board/freescale/common/ns_access.h
arch/arm/include/asm/arch-ls102xa/ns_access.h | 103 ++++++++++++++++++++------ board/freescale/common/Makefile | 2 +- board/freescale/common/ns_access.c | 8 +- board/freescale/ls1021aqds/ls1021aqds.c | 101 ++----------------------- board/freescale/ls1021atwr/ls1021atwr.c | 92 +---------------------- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atwr.h | 2 +- include/fsl_csu.h | 34 +++++++++ 8 files changed, 136 insertions(+), 208 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/ns_access.h b/arch/arm/include/asm/arch-ls102xa/ns_access.h index b53f699..a921fb6 100644 --- a/arch/arm/include/asm/arch-ls102xa/ns_access.h +++ b/arch/arm/include/asm/arch-ls102xa/ns_access.h @@ -7,22 +7,6 @@ #ifndef __FSL_NS_ACCESS_H_ #define __FSL_NS_ACCESS_H_
-enum csu_cslx_access { - CSU_NS_SUP_R = 0x08, - CSU_NS_SUP_W = 0x80, - CSU_NS_SUP_RW = 0x88, - CSU_NS_USER_R = 0x04, - CSU_NS_USER_W = 0x40, - CSU_NS_USER_RW = 0x44, - CSU_S_SUP_R = 0x02, - CSU_S_SUP_W = 0x20, - CSU_S_SUP_RW = 0x22, - CSU_S_USER_R = 0x01, - CSU_S_USER_W = 0x10, - CSU_S_USER_RW = 0x11, - CSU_ALL_RW = 0xff, -}; - enum csu_cslx_ind { CSU_CSLX_PCIE2_IO = 0, CSU_CSLX_PCIE1_IO, @@ -108,11 +92,88 @@ enum csu_cslx_ind { CSU_CSLX_MAX, };
-struct csu_ns_dev { - unsigned long ind; - uint32_t val; +static struct csu_ns_dev ns_dev[] = { + { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, + { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, + { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, + { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, + { CSU_CSLX_OCRAM, CSU_ALL_RW }, + { CSU_CSLX_GIC, CSU_ALL_RW }, + { CSU_CSLX_PCIE1, CSU_ALL_RW }, + { CSU_CSLX_OCRAM2, CSU_ALL_RW }, + { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, + { CSU_CSLX_PCIE2, CSU_ALL_RW }, + { CSU_CSLX_SATA, CSU_ALL_RW }, + { CSU_CSLX_USB3, CSU_ALL_RW }, + { CSU_CSLX_SERDES, CSU_ALL_RW }, + { CSU_CSLX_QDMA, CSU_ALL_RW }, + { CSU_CSLX_LPUART2, CSU_ALL_RW }, + { CSU_CSLX_LPUART1, CSU_ALL_RW }, + { CSU_CSLX_LPUART4, CSU_ALL_RW }, + { CSU_CSLX_LPUART3, CSU_ALL_RW }, + { CSU_CSLX_LPUART6, CSU_ALL_RW }, + { CSU_CSLX_LPUART5, CSU_ALL_RW }, + { CSU_CSLX_DSPI2, CSU_ALL_RW }, + { CSU_CSLX_DSPI1, CSU_ALL_RW }, + { CSU_CSLX_QSPI, CSU_ALL_RW }, + { CSU_CSLX_ESDHC, CSU_ALL_RW }, + { CSU_CSLX_2D_ACE, CSU_ALL_RW }, + { CSU_CSLX_IFC, CSU_ALL_RW }, + { CSU_CSLX_I2C1, CSU_ALL_RW }, + { CSU_CSLX_USB2, CSU_ALL_RW }, + { CSU_CSLX_I2C3, CSU_ALL_RW }, + { CSU_CSLX_I2C2, CSU_ALL_RW }, + { CSU_CSLX_DUART2, CSU_ALL_RW }, + { CSU_CSLX_DUART1, CSU_ALL_RW }, + { CSU_CSLX_WDT2, CSU_ALL_RW }, + { CSU_CSLX_WDT1, CSU_ALL_RW }, + { CSU_CSLX_EDMA, CSU_ALL_RW }, + { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, + { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, + { CSU_CSLX_DDR, CSU_ALL_RW }, + { CSU_CSLX_QUICC, CSU_ALL_RW }, + { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, + { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, + { CSU_CSLX_SFP, CSU_ALL_RW }, + { CSU_CSLX_TMU, CSU_ALL_RW }, + { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, + { CSU_CSLX_RESERVED0, CSU_ALL_RW }, + { CSU_CSLX_ETSEC1, CSU_ALL_RW }, + { CSU_CSLX_SEC5_5, CSU_ALL_RW }, + { CSU_CSLX_ETSEC3, CSU_ALL_RW }, + { CSU_CSLX_ETSEC2, CSU_ALL_RW }, + { CSU_CSLX_GPIO2, CSU_ALL_RW }, + { CSU_CSLX_GPIO1, CSU_ALL_RW }, + { CSU_CSLX_GPIO4, CSU_ALL_RW }, + { CSU_CSLX_GPIO3, CSU_ALL_RW }, + { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, + { CSU_CSLX_CSU, CSU_ALL_RW }, + { CSU_CSLX_ASRC, CSU_ALL_RW }, + { CSU_CSLX_SPDIF, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, + { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, + { CSU_CSLX_SAI2, CSU_ALL_RW }, + { CSU_CSLX_SAI1, CSU_ALL_RW }, + { CSU_CSLX_SAI4, CSU_ALL_RW }, + { CSU_CSLX_SAI3, CSU_ALL_RW }, + { CSU_CSLX_FTM2, CSU_ALL_RW }, + { CSU_CSLX_FTM1, CSU_ALL_RW }, + { CSU_CSLX_FTM4, CSU_ALL_RW }, + { CSU_CSLX_FTM3, CSU_ALL_RW }, + { CSU_CSLX_FTM6, CSU_ALL_RW }, + { CSU_CSLX_FTM5, CSU_ALL_RW }, + { CSU_CSLX_FTM8, CSU_ALL_RW }, + { CSU_CSLX_FTM7, CSU_ALL_RW }, + { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, + { CSU_CSLX_EPU, CSU_ALL_RW }, + { CSU_CSLX_GDI, CSU_ALL_RW }, + { CSU_CSLX_DDI, CSU_ALL_RW }, + { CSU_CSLX_RESERVED1, CSU_ALL_RW }, + { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, + { CSU_CSLX_RESERVED2, CSU_ALL_RW }, };
-void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num); - #endif diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 87d0578..51d2814 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -71,7 +71,7 @@ obj-$(CONFIG_P4080DS) += p_corenet/ obj-$(CONFIG_P5020DS) += p_corenet/ obj-$(CONFIG_P5040DS) += p_corenet/
-obj-$(CONFIG_LS102XA_NS_ACCESS) += ns_access.o +obj-$(CONFIG_LAYERSCAPE_NS_ACCESS) += ns_access.o
ifdef CONFIG_SECURE_BOOT obj-$(CONFIG_CMD_ESBC_VALIDATE) += fsl_validate.o cmd_esbc_validate.o diff --git a/board/freescale/common/ns_access.c b/board/freescale/common/ns_access.c index d7de982..d8d16c5 100644 --- a/board/freescale/common/ns_access.c +++ b/board/freescale/common/ns_access.c @@ -6,9 +6,10 @@
#include <common.h> #include <asm/io.h> +#include <fsl_csu.h> #include <asm/arch/ns_access.h>
-void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) +static void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) { u32 *base = (u32 *)CONFIG_SYS_FSL_CSU_ADDR; u32 *reg; @@ -28,3 +29,8 @@ void enable_devices_ns_access(struct csu_ns_dev *ns_dev, uint32_t num) out_be32(reg, val); } } + +void enable_layerscape_ns_access(void) +{ + enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +} diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 655fc64..612f17e 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -8,13 +8,13 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> -#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> #include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> +#include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <fsl_sec.h> @@ -56,92 +56,6 @@ enum { GE1_CLK125, };
-#ifdef CONFIG_LS102XA_NS_ACCESS -static struct csu_ns_dev ns_dev[] = { - { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, - { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, - { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, - { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, - { CSU_CSLX_OCRAM, CSU_ALL_RW }, - { CSU_CSLX_GIC, CSU_ALL_RW }, - { CSU_CSLX_PCIE1, CSU_ALL_RW }, - { CSU_CSLX_OCRAM2, CSU_ALL_RW }, - { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, - { CSU_CSLX_PCIE2, CSU_ALL_RW }, - { CSU_CSLX_SATA, CSU_ALL_RW }, - { CSU_CSLX_USB3, CSU_ALL_RW }, - { CSU_CSLX_SERDES, CSU_ALL_RW }, - { CSU_CSLX_QDMA, CSU_ALL_RW }, - { CSU_CSLX_LPUART2, CSU_ALL_RW }, - { CSU_CSLX_LPUART1, CSU_ALL_RW }, - { CSU_CSLX_LPUART4, CSU_ALL_RW }, - { CSU_CSLX_LPUART3, CSU_ALL_RW }, - { CSU_CSLX_LPUART6, CSU_ALL_RW }, - { CSU_CSLX_LPUART5, CSU_ALL_RW }, - { CSU_CSLX_DSPI2, CSU_ALL_RW }, - { CSU_CSLX_DSPI1, CSU_ALL_RW }, - { CSU_CSLX_QSPI, CSU_ALL_RW }, - { CSU_CSLX_ESDHC, CSU_ALL_RW }, - { CSU_CSLX_2D_ACE, CSU_ALL_RW }, - { CSU_CSLX_IFC, CSU_ALL_RW }, - { CSU_CSLX_I2C1, CSU_ALL_RW }, - { CSU_CSLX_USB2, CSU_ALL_RW }, - { CSU_CSLX_I2C3, CSU_ALL_RW }, - { CSU_CSLX_I2C2, CSU_ALL_RW }, - { CSU_CSLX_DUART2, CSU_ALL_RW }, - { CSU_CSLX_DUART1, CSU_ALL_RW }, - { CSU_CSLX_WDT2, CSU_ALL_RW }, - { CSU_CSLX_WDT1, CSU_ALL_RW }, - { CSU_CSLX_EDMA, CSU_ALL_RW }, - { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, - { CSU_CSLX_DDR, CSU_ALL_RW }, - { CSU_CSLX_QUICC, CSU_ALL_RW }, - { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, - { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, - { CSU_CSLX_SFP, CSU_ALL_RW }, - { CSU_CSLX_TMU, CSU_ALL_RW }, - { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, - { CSU_CSLX_RESERVED0, CSU_ALL_RW }, - { CSU_CSLX_ETSEC1, CSU_ALL_RW }, - { CSU_CSLX_SEC5_5, CSU_ALL_RW }, - { CSU_CSLX_ETSEC3, CSU_ALL_RW }, - { CSU_CSLX_ETSEC2, CSU_ALL_RW }, - { CSU_CSLX_GPIO2, CSU_ALL_RW }, - { CSU_CSLX_GPIO1, CSU_ALL_RW }, - { CSU_CSLX_GPIO4, CSU_ALL_RW }, - { CSU_CSLX_GPIO3, CSU_ALL_RW }, - { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, - { CSU_CSLX_CSU, CSU_ALL_RW }, - { CSU_CSLX_ASRC, CSU_ALL_RW }, - { CSU_CSLX_SPDIF, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, - { CSU_CSLX_SAI2, CSU_ALL_RW }, - { CSU_CSLX_SAI1, CSU_ALL_RW }, - { CSU_CSLX_SAI4, CSU_ALL_RW }, - { CSU_CSLX_SAI3, CSU_ALL_RW }, - { CSU_CSLX_FTM2, CSU_ALL_RW }, - { CSU_CSLX_FTM1, CSU_ALL_RW }, - { CSU_CSLX_FTM4, CSU_ALL_RW }, - { CSU_CSLX_FTM3, CSU_ALL_RW }, - { CSU_CSLX_FTM6, CSU_ALL_RW }, - { CSU_CSLX_FTM5, CSU_ALL_RW }, - { CSU_CSLX_FTM8, CSU_ALL_RW }, - { CSU_CSLX_FTM7, CSU_ALL_RW }, - { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, - { CSU_CSLX_EPU, CSU_ALL_RW }, - { CSU_CSLX_GDI, CSU_ALL_RW }, - { CSU_CSLX_DDI, CSU_ALL_RW }, - { CSU_CSLX_RESERVED1, CSU_ALL_RW }, - { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, - { CSU_CSLX_RESERVED2, CSU_ALL_RW }, -}; -#endif - int checkboard(void) { #ifndef CONFIG_QSPI_BOOT @@ -382,9 +296,8 @@ void board_init_f(ulong dummy) dram_init();
/* Allow OCRAM access permission as R/W */ -#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(&ns_dev[4], 1); - enable_devices_ns_access(&ns_dev[7], 1); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif
board_init_r(NULL, 0); @@ -602,8 +515,8 @@ int board_init(void) ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
-#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif
#ifdef CONFIG_U_QE @@ -627,8 +540,8 @@ void board_sleep_prepare(void) }
-#ifdef CONFIG_LS102XA_NS_ACCESS - enable_devices_ns_access(ns_dev, ARRAY_SIZE(ns_dev)); +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); #endif } #endif diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 228dbf8..fd736e1 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -8,13 +8,13 @@ #include <i2c.h> #include <asm/io.h> #include <asm/arch/immap_ls102xa.h> -#include <asm/arch/ns_access.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> #include <asm/arch/ls102xa_stream_id.h> #include <asm/arch/ls102xa_devdis.h> #include <hwconfig.h> #include <mmc.h> +#include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <fsl_immap.h> @@ -69,92 +69,6 @@ DECLARE_GLOBAL_DATA_PTR; #define PIN_QE_LCD_MUX_LCD 0x0 #define PIN_QE_LCD_MUX_QE 0x1
-#ifdef CONFIG_LS102XA_NS_ACCESS -static struct csu_ns_dev ns_dev[] = { - { CSU_CSLX_PCIE2_IO, CSU_ALL_RW }, - { CSU_CSLX_PCIE1_IO, CSU_ALL_RW }, - { CSU_CSLX_MG2TPR_IP, CSU_ALL_RW }, - { CSU_CSLX_IFC_MEM, CSU_ALL_RW }, - { CSU_CSLX_OCRAM, CSU_ALL_RW }, - { CSU_CSLX_GIC, CSU_ALL_RW }, - { CSU_CSLX_PCIE1, CSU_ALL_RW }, - { CSU_CSLX_OCRAM2, CSU_ALL_RW }, - { CSU_CSLX_QSPI_MEM, CSU_ALL_RW }, - { CSU_CSLX_PCIE2, CSU_ALL_RW }, - { CSU_CSLX_SATA, CSU_ALL_RW }, - { CSU_CSLX_USB3, CSU_ALL_RW }, - { CSU_CSLX_SERDES, CSU_ALL_RW }, - { CSU_CSLX_QDMA, CSU_ALL_RW }, - { CSU_CSLX_LPUART2, CSU_ALL_RW }, - { CSU_CSLX_LPUART1, CSU_ALL_RW }, - { CSU_CSLX_LPUART4, CSU_ALL_RW }, - { CSU_CSLX_LPUART3, CSU_ALL_RW }, - { CSU_CSLX_LPUART6, CSU_ALL_RW }, - { CSU_CSLX_LPUART5, CSU_ALL_RW }, - { CSU_CSLX_DSPI2, CSU_ALL_RW }, - { CSU_CSLX_DSPI1, CSU_ALL_RW }, - { CSU_CSLX_QSPI, CSU_ALL_RW }, - { CSU_CSLX_ESDHC, CSU_ALL_RW }, - { CSU_CSLX_2D_ACE, CSU_ALL_RW }, - { CSU_CSLX_IFC, CSU_ALL_RW }, - { CSU_CSLX_I2C1, CSU_ALL_RW }, - { CSU_CSLX_USB2, CSU_ALL_RW }, - { CSU_CSLX_I2C3, CSU_ALL_RW }, - { CSU_CSLX_I2C2, CSU_ALL_RW }, - { CSU_CSLX_DUART2, CSU_ALL_RW }, - { CSU_CSLX_DUART1, CSU_ALL_RW }, - { CSU_CSLX_WDT2, CSU_ALL_RW }, - { CSU_CSLX_WDT1, CSU_ALL_RW }, - { CSU_CSLX_EDMA, CSU_ALL_RW }, - { CSU_CSLX_SYS_CNT, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX2, CSU_ALL_RW }, - { CSU_CSLX_DMA_MUX1, CSU_ALL_RW }, - { CSU_CSLX_DDR, CSU_ALL_RW }, - { CSU_CSLX_QUICC, CSU_ALL_RW }, - { CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW }, - { CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW }, - { CSU_CSLX_SFP, CSU_ALL_RW }, - { CSU_CSLX_TMU, CSU_ALL_RW }, - { CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW }, - { CSU_CSLX_RESERVED0, CSU_ALL_RW }, - { CSU_CSLX_ETSEC1, CSU_ALL_RW }, - { CSU_CSLX_SEC5_5, CSU_ALL_RW }, - { CSU_CSLX_ETSEC3, CSU_ALL_RW }, - { CSU_CSLX_ETSEC2, CSU_ALL_RW }, - { CSU_CSLX_GPIO2, CSU_ALL_RW }, - { CSU_CSLX_GPIO1, CSU_ALL_RW }, - { CSU_CSLX_GPIO4, CSU_ALL_RW }, - { CSU_CSLX_GPIO3, CSU_ALL_RW }, - { CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW }, - { CSU_CSLX_CSU, CSU_ALL_RW }, - { CSU_CSLX_ASRC, CSU_ALL_RW }, - { CSU_CSLX_SPDIF, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN2, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN1, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN4, CSU_ALL_RW }, - { CSU_CSLX_FLEXCAN3, CSU_ALL_RW }, - { CSU_CSLX_SAI2, CSU_ALL_RW }, - { CSU_CSLX_SAI1, CSU_ALL_RW }, - { CSU_CSLX_SAI4, CSU_ALL_RW }, - { CSU_CSLX_SAI3, CSU_ALL_RW }, - { CSU_CSLX_FTM2, CSU_ALL_RW }, - { CSU_CSLX_FTM1, CSU_ALL_RW }, - { CSU_CSLX_FTM4, CSU_ALL_RW }, - { CSU_CSLX_FTM3, CSU_ALL_RW }, - { CSU_CSLX_FTM6, CSU_ALL_RW }, - { CSU_CSLX_FTM5, CSU_ALL_RW }, - { CSU_CSLX_FTM8, CSU_ALL_RW }, - { CSU_CSLX_FTM7, CSU_ALL_RW }, - { CSU_CSLX_COP_DCSR, CSU_ALL_RW }, - { CSU_CSLX_EPU, CSU_ALL_RW }, - { CSU_CSLX_GDI, CSU_ALL_RW }, - { CSU_CSLX_DDI, CSU_ALL_RW }, - { CSU_CSLX_RESERVED1, CSU_ALL_RW }, - { CSU_CSLX_USB3_PHY, CSU_ALL_RW }, - { CSU_CSLX_RESERVED2, CSU_ALL_RW }, -}; -#endif - struct cpld_data { u8 cpld_ver; /* cpld revision */ u8 cpld_ver_sub; /* cpld sub revision */ @@ -637,8 +551,8 @@ int board_init(void) ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id));
#ifdef CONFIG_U_QE diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index f73900f..9b8b001 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -563,7 +563,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN -#define CONFIG_LS102XA_NS_ACCESS +#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 02cc09c..676c096 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -415,7 +415,7 @@ #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN -#define CONFIG_LS102XA_NS_ACCESS +#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 #define CONFIG_TIMER_CLK_FREQ 12500000
diff --git a/include/fsl_csu.h b/include/fsl_csu.h new file mode 100644 index 0000000..f4d97fb --- /dev/null +++ b/include/fsl_csu.h @@ -0,0 +1,34 @@ +/* + * Copyright 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __FSL_CSU_H__ +#define __FSL_CSU_H__ + +enum csu_cslx_access { + CSU_NS_SUP_R = 0x08, + CSU_NS_SUP_W = 0x80, + CSU_NS_SUP_RW = 0x88, + CSU_NS_USER_R = 0x04, + CSU_NS_USER_W = 0x40, + CSU_NS_USER_RW = 0x44, + CSU_S_SUP_R = 0x02, + CSU_S_SUP_W = 0x20, + CSU_S_SUP_RW = 0x22, + CSU_S_USER_R = 0x01, + CSU_S_USER_W = 0x10, + CSU_S_USER_RW = 0x11, + CSU_ALL_RW = 0xff, +}; + +struct csu_ns_dev { + unsigned long ind; + uint32_t val; +}; + +void enable_layerscape_ns_access(void); + +#endif
get_clocks() should not be limited by ESDHC.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - Removed defines in PPC configs that have no need to use. V2: - No change.
common/board_f.c | 2 +- include/configs/colibri_vf.h | 1 + include/configs/ls1021aqds.h | 1 + include/configs/ls1021atwr.h | 1 + include/configs/ls2085aqds.h | 1 + include/configs/ls2085ardb.h | 1 + include/configs/m53evk.h | 1 + include/configs/mx25pdk.h | 1 + include/configs/mx35pdk.h | 1 + include/configs/mx51evk.h | 1 + include/configs/mx53ard.h | 1 + include/configs/mx53evk.h | 1 + include/configs/mx53loco.h | 1 + include/configs/mx53smd.h | 1 + include/configs/mx6_common.h | 1 + include/configs/mx7_common.h | 1 + include/configs/usbarmory.h | 1 + include/configs/vf610twr.h | 1 + include/configs/woodburn_common.h | 1 + 19 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 613332e..1bb84b3 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -806,7 +806,7 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_BOARD_POSTCLK_INIT) board_postclk_init, #endif -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_CLK get_clocks, #endif #ifdef CONFIG_M68K diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 2583155..5bd742d 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -18,6 +18,7 @@ #define CONFIG_SYS_THUMB_BUILD #define CONFIG_USE_ARCH_MEMCPY #define CONFIG_USE_ARCH_MEMSET +#define CONFIG_FSL_CLK
#define CONFIG_SYS_GENERIC_BOARD #define CONFIG_ARCH_MISC_INIT diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 9b8b001..42b66b3 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -12,6 +12,7 @@ #define CONFIG_ARMV7_PSCI
#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_FSL_CLK
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 676c096..8a86473 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -12,6 +12,7 @@ #define CONFIG_ARMV7_PSCI
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/ls2085aqds.h b/include/configs/ls2085aqds.h index f7f3870..4cfcf98 100644 --- a/include/configs/ls2085aqds.h +++ b/include/configs/ls2085aqds.h @@ -16,6 +16,7 @@ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); #endif
+#define CONFIG_FSL_CLK #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() #define COUNTER_FREQUENCY_REAL (CONFIG_SYS_CLK_FREQ/4) diff --git a/include/configs/ls2085ardb.h b/include/configs/ls2085ardb.h index a190bc7..583fed5 100644 --- a/include/configs/ls2085ardb.h +++ b/include/configs/ls2085ardb.h @@ -18,6 +18,7 @@ unsigned long get_board_sys_clk(void); #endif
+#define CONFIG_FSL_CLK #define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ 133333333 #define COUNTER_FREQUENCY_REAL (CONFIG_SYS_CLK_FREQ/4) diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 8853d8f..456e5b4 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -18,6 +18,7 @@ #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_REVISION_TAG #define CONFIG_SYS_NO_FLASH +#define CONFIG_FSL_CLK
#define CONFIG_FIT
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 0414086..afe2a02 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -15,6 +15,7 @@ #define CONFIG_SYS_TEXT_BASE 0x81200000 #define CONFIG_MXC_GPIO #define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_FSL_CLK
#define CONFIG_SYS_TIMER_RATE 32768 #define CONFIG_SYS_TIMER_COUNTER \ diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 6bfdaa6..dca2f86 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -20,6 +20,7 @@
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_FSL_CLK
/* Set TEXT at the beginning of the NOR flash */ #define CONFIG_SYS_TEXT_BASE 0xA0000000 diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 2203c15..e3763c1 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -18,6 +18,7 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+#define CONFIG_FSL_CLK #define CONFIG_SYS_TEXT_BASE 0x97800000
#include <asm/arch/imx-regs.h> diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index b889c25..9ef973d 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -24,6 +24,7 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 4f304ed..56ef9e6 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -24,6 +24,7 @@ #define CONFIG_REVISION_TAG
#define CONFIG_OF_LIBFDT
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 3a65861..7b2917f 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -23,6 +23,7 @@ #define CONFIG_INITRD_TAG
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index e46f2ee..5b21dd5 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -24,6 +24,7 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index ef4cb68..c157e81 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -46,6 +46,7 @@ #define CONFIG_DISPLAY_BOARDINFO #define CONFIG_DISPLAY_CPUINFO #define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_FSL_CLK
/* ATAGs */ #define CONFIG_CMDLINE_TAG diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index ea2be49..85c8df8 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -21,6 +21,7 @@ #define CONFIG_MXC_GPT_HCLK #define CONFIG_SYSCOUNTER_TIMER #define CONFIG_SC_TIMER_CLK 8000000 /* 8Mhz */ +#define CONFIG_FSL_CLK
/* Enable iomux-lpsr support */ #define CONFIG_IOMUX_LPSR diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 714e3e2..e8cbd8f 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -14,6 +14,7 @@ #define CONFIG_MX53 #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_FSL_CLK #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_OF_LIBFDT #define CONFIG_SYS_GENERIC_BOARD diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 7f4260a..7b17ac9 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -16,6 +16,7 @@ #define CONFIG_SYS_GENERIC_BOARD #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_FSL_CLK
#define CONFIG_MACH_TYPE 4146
diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index fc46565..76d22e7 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -16,6 +16,7 @@ /* High Level Configuration Options */ #define CONFIG_MX35 #define CONFIG_MX35_HCLK_FREQ 24000000 +#define CONFIG_FSL_CLK
#define CONFIG_SYS_DCACHE_OFF #define CONFIG_SYS_CACHELINE_SIZE 32
The Frame Manager(FMan) is a big-endian peripheral, so the registers, internal MURAM and BDs, which are allocated in main memory and used to communication between core and FMan, should be accessed in big-endian. The big-endian platforms can access them directly as the code implemented so far, while for the little-endian platforms it need to swap the byte-order.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - Modify the subject to make the aim clear. V2: - No change.
drivers/net/fm/eth.c | 70 +++++++++++++++++++++++++++------------------------- drivers/net/fm/fm.c | 11 +++++---- 2 files changed, 43 insertions(+), 38 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 6702f5a..368d554 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -109,7 +109,7 @@ static int tgec_is_fibre(struct eth_device *dev) static u16 muram_readw(u16 *addr) { u32 base = (u32)addr & ~0x3; - u32 val32 = *(u32 *)base; + u32 val32 = in_be32((u32 *)base); int byte_pos; u16 ret;
@@ -125,7 +125,7 @@ static u16 muram_readw(u16 *addr) static void muram_writew(u16 *addr, u16 val) { u32 base = (u32)addr & ~0x3; - u32 org32 = *(u32 *)base; + u32 org32 = in_be32((u32 *)base); u32 val32; int byte_pos;
@@ -135,7 +135,7 @@ static void muram_writew(u16 *addr, u16 val) else val32 = (org32 & 0x0000ffff) | ((u32)val << 16);
- *(u32 *)base = val32; + out_be32((u32 *)base, val32); }
static void bmi_rx_port_disable(struct fm_bmi_rx_port *rx_port) @@ -213,10 +213,10 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) pram_page_offset = (u32)pram - fm_muram_base(fm_eth->fm_index);
/* enable global mode- snooping data buffers and BDs */ - pram->mode = PRAM_MODE_GLOBAL; + out_be32(&pram->mode, PRAM_MODE_GLOBAL);
/* init the Rx queue descriptor pionter */ - pram->rxqd_ptr = pram_page_offset + 0x20; + out_be32(&pram->rxqd_ptr, pram_page_offset + 0x20);
/* set the max receive buffer length, power of 2 */ muram_writew(&pram->mrblr, MAX_RXBUF_LOG2); @@ -243,10 +243,11 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) /* init Rx BDs ring */ rxbd = (struct fm_port_bd *)rx_bd_ring_base; for (i = 0; i < RX_BD_RING_SIZE; i++) { - rxbd->status = RxBD_EMPTY; - rxbd->len = 0; - rxbd->buf_ptr_hi = 0; - rxbd->buf_ptr_lo = (u32)rx_buf_pool + i * MAX_RXBUF_LEN; + muram_writew(&rxbd->status, RxBD_EMPTY); + muram_writew(&rxbd->len, 0); + muram_writew(&rxbd->buf_ptr_hi, 0); + out_be32(&rxbd->buf_ptr_lo, (u32)rx_buf_pool + + i * MAX_RXBUF_LEN); rxbd++; }
@@ -254,7 +255,7 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) rxqd = &pram->rxqd; muram_writew(&rxqd->gen, 0); muram_writew(&rxqd->bd_ring_base_hi, 0); - rxqd->bd_ring_base_lo = (u32)rx_bd_ring_base; + out_be32(&rxqd->bd_ring_base_lo, (u32)rx_bd_ring_base); muram_writew(&rxqd->bd_ring_size, sizeof(struct fm_port_bd) * RX_BD_RING_SIZE); muram_writew(&rxqd->offset_in, 0); @@ -285,10 +286,10 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) pram_page_offset = (u32)pram - fm_muram_base(fm_eth->fm_index);
/* init the Tx queue descriptor pionter */ - pram->txqd_ptr = pram_page_offset + 0x40; + out_be32(&pram->txqd_ptr, pram_page_offset + 0x40);
/* alloc Tx buffer descriptors from main memory */ tx_bd_ring_base = malloc(sizeof(struct fm_port_bd) @@ -304,16 +305,17 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) /* init Tx BDs ring */ txbd = (struct fm_port_bd *)tx_bd_ring_base; for (i = 0; i < TX_BD_RING_SIZE; i++) { - txbd->status = TxBD_LAST; - txbd->len = 0; - txbd->buf_ptr_hi = 0; - txbd->buf_ptr_lo = 0; + muram_writew(&txbd->status, TxBD_LAST); + muram_writew(&txbd->len, 0); + muram_writew(&txbd->buf_ptr_hi, 0); + out_be32(&txbd->buf_ptr_lo, 0); + txbd++; }
/* set the Tx queue decriptor */ txqd = &pram->txqd; muram_writew(&txqd->bd_ring_base_hi, 0); - txqd->bd_ring_base_lo = (u32)tx_bd_ring_base; + out_be32(&txqd->bd_ring_base_lo, (u32)tx_bd_ring_base); muram_writew(&txqd->bd_ring_size, sizeof(struct fm_port_bd) * TX_BD_RING_SIZE); muram_writew(&txqd->offset_in, 0); @@ -368,7 +370,7 @@ static void fmc_tx_port_graceful_stop_enable(struct fm_eth *fm_eth)
pram = fm_eth->tx_pram; /* graceful stop transmission of frames */ - pram->mode |= PRAM_MODE_GRACEFUL_STOP; + setbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); sync(); }
@@ -378,7 +380,7 @@ static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth)
pram = fm_eth->tx_pram; /* re-enable transmission of frames */ - pram->mode &= ~PRAM_MODE_GRACEFUL_STOP; + clrbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); sync(); }
@@ -469,19 +471,20 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) txbd = fm_eth->cur_txbd;
/* find one empty TxBD */ - for (i = 0; txbd->status & TxBD_READY; i++) { + for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { udelay(100); if (i > 0x1000) { - printf("%s: Tx buffer not ready\n", dev->name); + printf("%s: Tx buffer not ready, txbd->status = 0x%x\n", + dev->name, muram_readw(&txbd->status)); return 0; } } /* setup TxBD */ - txbd->buf_ptr_hi = 0; - txbd->buf_ptr_lo = (u32)buf; - txbd->len = len; + muram_writew(&txbd->buf_ptr_hi, 0); + out_be32(&txbd->buf_ptr_lo, (u32)buf); + muram_writew(&txbd->len, len); sync(); - txbd->status = TxBD_READY | TxBD_LAST; + muram_writew(&txbd->status, TxBD_READY | TxBD_LAST); sync();
/* update TxQD, let RISC to send the packet */ @@ -493,10 +496,11 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) sync();
/* wait for buffer to be transmitted */ - for (i = 0; txbd->status & TxBD_READY; i++) { + for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { udelay(100); if (i > 0x10000) { - printf("%s: Tx error\n", dev->name); + printf("%s: Tx error, txbd->status = 0x%x\n", + dev->name, muram_readw(&txbd->status)); return 0; } } @@ -525,12 +529,12 @@ static int fm_eth_recv(struct eth_device *dev) fm_eth = (struct fm_eth *)dev->priv; pram = fm_eth->rx_pram; rxbd = fm_eth->cur_rxbd; - status = rxbd->status; + status = muram_readw(&rxbd->status);
while (!(status & RxBD_EMPTY)) { if (!(status & RxBD_ERROR)) { - data = (u8 *)rxbd->buf_ptr_lo; - len = rxbd->len; + data = (u8 *)in_be32(&rxbd->buf_ptr_lo); + len = muram_readw(&rxbd->len); net_process_received_packet(data, len); } else { printf("%s: Rx error\n", dev->name); @@ -538,8 +542,8 @@ static int fm_eth_recv(struct eth_device *dev) }
/* clear the RxBDs */ - rxbd->status = RxBD_EMPTY; - rxbd->len = 0; + muram_writew(&rxbd->status, RxBD_EMPTY); + muram_writew(&rxbd->len, 0); sync();
/* advance RxBD */ @@ -548,7 +552,7 @@ static int fm_eth_recv(struct eth_device *dev) if (rxbd >= (rxbd_base + RX_BD_RING_SIZE)) rxbd = rxbd_base; /* read next status */ - status = rxbd->status; + status = muram_readw(&rxbd->status);
/* update RxQD */ offset_out = muram_readw(&pram->rxqd.offset_out); diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 400e9dd..eb0eb3d 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -80,11 +80,11 @@ static void fm_upload_ucode(int fm_idx, struct fm_imem *imem, out_be32(&imem->iadd, IRAM_IADD_AIE); /* write microcode to IRAM */ for (i = 0; i < size / 4; i++) - out_be32(&imem->idata, ucode[i]); + out_be32(&imem->idata, (be32_to_cpu(ucode[i])));
/* verify if the writing is over */ out_be32(&imem->iadd, 0); - while ((in_be32(&imem->idata) != ucode[0]) && --timeout) + while ((in_be32(&imem->idata) != be32_to_cpu(ucode[0])) && --timeout) ; if (!timeout) printf("Fman%u: microcode upload timeout\n", fm_idx + 1); @@ -177,14 +177,15 @@ static int fman_upload_firmware(int fm_idx, const struct qe_microcode *ucode = &firmware->microcode[i];
/* Upload a microcode if it's present */ - if (ucode->code_offset) { + if (be32_to_cpu(ucode->code_offset)) { u32 ucode_size; u32 *code; printf("Fman%u: Uploading microcode version %u.%u.%u\n", fm_idx + 1, ucode->major, ucode->minor, ucode->revision); - code = (void *)firmware + ucode->code_offset; - ucode_size = sizeof(u32) * ucode->count; + code = (void *)firmware + + be32_to_cpu(ucode->code_offset); + ucode_size = sizeof(u32) * be32_to_cpu(ucode->count); fm_upload_ucode(fm_idx, fm_imem, code, ucode_size); } }
Use mb() instead of sync() to be compatible for both ARM and PowerPC.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - New patch. Separated from patch 'net: Move some header files to include/'
drivers/net/fm/eth.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 368d554..ad02c66 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -371,7 +371,7 @@ static void fmc_tx_port_graceful_stop_enable(struct fm_eth *fm_eth) pram = fm_eth->tx_pram; /* graceful stop transmission of frames */ setbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); - sync(); + mb(); }
static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth) @@ -381,7 +381,7 @@ static void fmc_tx_port_graceful_stop_disable(struct fm_eth *fm_eth) pram = fm_eth->tx_pram; /* re-enable transmission of frames */ clrbits_be32(&pram->mode, PRAM_MODE_GRACEFUL_STOP); - sync(); + mb(); }
static int fm_eth_open(struct eth_device *dev, bd_t *bd) @@ -483,9 +483,9 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) muram_writew(&txbd->buf_ptr_hi, 0); out_be32(&txbd->buf_ptr_lo, (u32)buf); muram_writew(&txbd->len, len); - sync(); + mb(); muram_writew(&txbd->status, TxBD_READY | TxBD_LAST); - sync(); + mb();
/* update TxQD, let RISC to send the packet */ offset_in = muram_readw(&pram->txqd.offset_in); @@ -493,7 +493,7 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) if (offset_in >= muram_readw(&pram->txqd.bd_ring_size)) offset_in = 0; muram_writew(&pram->txqd.offset_in, offset_in); - sync(); + mb();
/* wait for buffer to be transmitted */ for (i = 0; muram_readw(&txbd->status) & TxBD_READY; i++) { @@ -544,7 +544,7 @@ static int fm_eth_recv(struct eth_device *dev) /* clear the RxBDs */ muram_writew(&rxbd->status, RxBD_EMPTY); muram_writew(&rxbd->len, 0); - sync(); + mb();
/* advance RxBD */ rxbd++; @@ -560,7 +560,7 @@ static int fm_eth_recv(struct eth_device *dev) if (offset_out >= muram_readw(&pram->rxqd.bd_ring_size)) offset_out = 0; muram_writew(&pram->rxqd.offset_out, offset_out); - sync(); + mb(); } fm_eth->cur_rxbd = (void *)rxbd;
The FMan IM driver is developed for 32-bit platfroms and isn't friendly to 64-bit platforms, so do the minimal refactor:
1. Refine the MURAM management and access. 2. Correct the initialization and operations for QDs and BDs.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - New patch.
drivers/net/fm/eth.c | 61 ++++++++++++++++++++++++++++++++++++---------------- drivers/net/fm/fm.c | 20 ++++++++++------- drivers/net/fm/fm.h | 12 +++++------ 3 files changed, 60 insertions(+), 33 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index ad02c66..6451dce 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -108,12 +108,12 @@ static int tgec_is_fibre(struct eth_device *dev)
static u16 muram_readw(u16 *addr) { - u32 base = (u32)addr & ~0x3; - u32 val32 = in_be32((u32 *)base); + ulong base = (ulong)addr & ~0x3UL; + u32 val32 = in_be32((void *)base); int byte_pos; u16 ret;
- byte_pos = (u32)addr & 0x3; + byte_pos = (ulong)addr & 0x3UL; if (byte_pos) ret = (u16)(val32 & 0x0000ffff); else @@ -124,18 +124,18 @@ static u16 muram_readw(u16 *addr)
static void muram_writew(u16 *addr, u16 val) { - u32 base = (u32)addr & ~0x3; - u32 org32 = in_be32((u32 *)base); + ulong base = (ulong)addr & ~0x3UL; + u32 org32 = in_be32((void *)base); u32 val32; int byte_pos;
- byte_pos = (u32)addr & 0x3; + byte_pos = (ulong)addr & 0x3UL; if (byte_pos) val32 = (org32 & 0xffff0000) | val; else val32 = (org32 & 0x0000ffff) | ((u32)val << 16);
- out_be32((u32 *)base, val32); + out_be32((void *)base, val32); }
static void bmi_rx_port_disable(struct fm_bmi_rx_port *rx_port) @@ -199,6 +199,8 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) u32 pram_page_offset; void *rx_bd_ring_base; void *rx_buf_pool; + u32 bd_ring_base_lo, bd_ring_base_hi; + u32 buf_lo, buf_hi; struct fm_port_bd *rxbd; struct fm_port_qd *rxqd; struct fm_bmi_rx_port *bmi_rx_port = fm_eth->rx_port; @@ -207,10 +209,15 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) /* alloc global parameter ram at MURAM */ pram = (struct fm_port_global_pram *)fm_muram_alloc(fm_eth->fm_index, FM_PRAM_SIZE, FM_PRAM_ALIGN); + if (!pram) { + printf("%s: No muram for Rx global parameter\n", __func__); + return 0; + } + fm_eth->rx_pram = pram;
/* parameter page offset to MURAM */ - pram_page_offset = (u32)pram - fm_muram_base(fm_eth->fm_index); + pram_page_offset = (void *)pram - fm_muram_base(fm_eth->fm_index);
/* enable global mode- snooping data buffers and BDs */ out_be32(&pram->mode, PRAM_MODE_GLOBAL); @@ -234,6 +241,7 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) if (!rx_buf_pool) return 0; memset(rx_buf_pool, 0, MAX_RXBUF_LEN * RX_BD_RING_SIZE); + debug("%s: rx_buf_pool = %p\n", __func__, rx_buf_pool);
/* save them to fm_eth */ fm_eth->rx_bd_ring = rx_bd_ring_base; @@ -245,17 +253,22 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) for (i = 0; i < RX_BD_RING_SIZE; i++) { muram_writew(&rxbd->status, RxBD_EMPTY); muram_writew(&rxbd->len, 0); - muram_writew(&rxbd->buf_ptr_hi, 0); - out_be32(&rxbd->buf_ptr_lo, (u32)rx_buf_pool + - i * MAX_RXBUF_LEN); + buf_hi = upper_32_bits(virt_to_phys(rx_buf_pool + + i * MAX_RXBUF_LEN)); + buf_lo = lower_32_bits(virt_to_phys(rx_buf_pool + + i * MAX_RXBUF_LEN)); + muram_writew(&rxbd->buf_ptr_hi, (u16)buf_hi); + out_be32(&rxbd->buf_ptr_lo, buf_lo); rxbd++; }
/* set the Rx queue descriptor */ rxqd = &pram->rxqd; muram_writew(&rxqd->gen, 0); - muram_writew(&rxqd->bd_ring_base_hi, 0); - out_be32(&rxqd->bd_ring_base_lo, (u32)rx_bd_ring_base); + bd_ring_base_hi = upper_32_bits(virt_to_phys(rx_bd_ring_base)); + bd_ring_base_lo = lower_32_bits(virt_to_phys(rx_bd_ring_base)); + muram_writew(&rxqd->bd_ring_base_hi, (u16)bd_ring_base_hi); + out_be32(&rxqd->bd_ring_base_lo, bd_ring_base_lo); muram_writew(&rxqd->bd_ring_size, sizeof(struct fm_port_bd) * RX_BD_RING_SIZE); muram_writew(&rxqd->offset_in, 0); @@ -272,6 +285,7 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) struct fm_port_global_pram *pram; u32 pram_page_offset; void *tx_bd_ring_base; + u32 bd_ring_base_lo, bd_ring_base_hi; struct fm_port_bd *txbd; struct fm_port_qd *txqd; struct fm_bmi_tx_port *bmi_tx_port = fm_eth->tx_port; @@ -280,10 +294,14 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) /* alloc global parameter ram at MURAM */ pram = (struct fm_port_global_pram *)fm_muram_alloc(fm_eth->fm_index, FM_PRAM_SIZE, FM_PRAM_ALIGN); + if (!pram) { + printf("%s: No muram for Tx global parameter\n", __func__); + return 0; + } fm_eth->tx_pram = pram;
/* enable global mode- snooping data buffers and BDs */ out_be32(&pram->mode, PRAM_MODE_GLOBAL); @@ -314,8 +332,10 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth)
/* set the Tx queue decriptor */ txqd = &pram->txqd; - muram_writew(&txqd->bd_ring_base_hi, 0); - out_be32(&txqd->bd_ring_base_lo, (u32)tx_bd_ring_base); + bd_ring_base_hi = upper_32_bits(virt_to_phys(tx_bd_ring_base)); + bd_ring_base_lo = lower_32_bits(virt_to_phys(tx_bd_ring_base)); + muram_writew(&txqd->bd_ring_base_hi, (u16)bd_ring_base_hi); + out_be32(&txqd->bd_ring_base_lo, bd_ring_base_lo); muram_writew(&txqd->bd_ring_size, sizeof(struct fm_port_bd) * TX_BD_RING_SIZE); muram_writew(&txqd->offset_in, 0); @@ -480,8 +500,8 @@ static int fm_eth_send(struct eth_device *dev, void *buf, int len) } } /* setup TxBD */ - muram_writew(&txbd->buf_ptr_hi, 0); - out_be32(&txbd->buf_ptr_lo, (u32)buf); + muram_writew(&txbd->buf_ptr_hi, (u16)upper_32_bits(virt_to_phys(buf))); + out_be32(&txbd->buf_ptr_lo, lower_32_bits(virt_to_phys(buf))); muram_writew(&txbd->len, len); mb(); muram_writew(&txbd->status, TxBD_READY | TxBD_LAST); @@ -522,6 +542,7 @@ static int fm_eth_recv(struct eth_device *dev) struct fm_port_global_pram *pram; struct fm_port_bd *rxbd, *rxbd_base; u16 status, len; + u32 buf_lo, buf_hi; u8 *data; u16 offset_out; int ret = 1; @@ -533,7 +554,9 @@ static int fm_eth_recv(struct eth_device *dev)
while (!(status & RxBD_EMPTY)) { if (!(status & RxBD_ERROR)) { - data = (u8 *)in_be32(&rxbd->buf_ptr_lo); + buf_hi = muram_readw(&rxbd->buf_ptr_hi); + buf_lo = in_be32(&rxbd->buf_ptr_lo); + data = (u8 *)((ulong)(buf_hi << 16) << 16 | buf_lo); len = muram_readw(&rxbd->len); net_process_received_packet(data, len); } else { diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index eb0eb3d..df5db72 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -22,21 +22,22 @@
struct fm_muram muram[CONFIG_SYS_NUM_FMAN];
-u32 fm_muram_base(int fm_idx) +void *fm_muram_base(int fm_idx) { return muram[fm_idx].base; }
-u32 fm_muram_alloc(int fm_idx, u32 size, u32 align) +void *fm_muram_alloc(int fm_idx, size_t size, ulong align) { - u32 ret; - u32 align_mask, off; - u32 save; + void *ret; + ulong align_mask; + size_t off; + void *save;
align_mask = align - 1; save = muram[fm_idx].alloc;
- off = save & align_mask; + off = (ulong)save & align_mask; if (off != 0) muram[fm_idx].alloc += (align - off); off = size & align_mask; @@ -45,6 +46,7 @@ u32 fm_muram_alloc(int fm_idx, u32 size, u32 align) if ((muram[fm_idx].alloc + size) >= muram[fm_idx].top) { muram[fm_idx].alloc = save; printf("%s: run out of ram.\n", __func__); + return NULL; }
ret = muram[fm_idx].alloc; @@ -56,7 +58,7 @@ u32 fm_muram_alloc(int fm_idx, u32 size, u32 align)
static void fm_init_muram(int fm_idx, void *reg) { - u32 base = (u32)reg; + void *base = reg;
muram[fm_idx].base = base; muram[fm_idx].size = CONFIG_SYS_FM_MURAM_SIZE; @@ -256,7 +258,9 @@ static void fm_init_fpm(struct fm_fpm *fpm) static int fm_init_bmi(int fm_idx, struct fm_bmi_common *bmi) { int blk, i, port_id; - u32 val, offset, base; + u32 val; + size_t offset; + void *base;
/* alloc free buffer pool in MURAM */ base = fm_muram_alloc(fm_idx, FM_FREE_POOL_SIZE, FM_FREE_POOL_ALIGN); diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index a9691c6..73c525e 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -26,10 +26,10 @@ #define MIIM_TIMEOUT 0xFFFF
struct fm_muram { - u32 base; - u32 top; - u32 size; - u32 alloc; + void *base; + void *top; + size_t size; + void *alloc; }; #define FM_MURAM_RES_SIZE 0x01000
@@ -95,8 +95,8 @@ struct fm_port_global_pram { #endif #define FM_FREE_POOL_ALIGN 256
-u32 fm_muram_alloc(int fm_idx, u32 size, u32 align); -u32 fm_muram_base(int fm_idx); +void *fm_muram_alloc(int fm_idx, size_t size, ulong align); +void *fm_muram_base(int fm_idx); int fm_init_common(int index, struct ccsr_fman *reg); int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info); phy_interface_t fman_port_enet_if(enum fm_port port);
In convention, the '0' is a normal return value indicating there isn't an error. While some functions of FMan IM driver treat '0' as an error return value.
drivers/net/fm/eth.c | 60 +++++++++++++++++++++++++++++++--------------------- 1 file changed, 36 insertions(+), 24 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 6451dce..d7d064b 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -211,7 +211,7 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) FM_PRAM_SIZE, FM_PRAM_ALIGN); if (!pram) { printf("%s: No muram for Rx global parameter\n", __func__); - return 0; + return -ENOMEM; }
fm_eth->rx_pram = pram; @@ -232,14 +232,16 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) rx_bd_ring_base = malloc(sizeof(struct fm_port_bd) * RX_BD_RING_SIZE); if (!rx_bd_ring_base) - return 0; + return -ENOMEM; + memset(rx_bd_ring_base, 0, sizeof(struct fm_port_bd) * RX_BD_RING_SIZE);
/* alloc Rx buffer from main memory */ rx_buf_pool = malloc(MAX_RXBUF_LEN * RX_BD_RING_SIZE); if (!rx_buf_pool) - return 0; + return -ENOMEM; + memset(rx_buf_pool, 0, MAX_RXBUF_LEN * RX_BD_RING_SIZE); debug("%s: rx_buf_pool = %p\n", __func__, rx_buf_pool);
@@ -277,7 +279,7 @@ static int fm_eth_rx_port_parameter_init(struct fm_eth *fm_eth) /* set IM parameter ram pointer to Rx Frame Queue ID */ out_be32(&bmi_rx_port->fmbm_rfqid, pram_page_offset);
- return 1; + return 0; }
static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) @@ -296,7 +298,7 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) FM_PRAM_SIZE, FM_PRAM_ALIGN); if (!pram) { printf("%s: No muram for Tx global parameter\n", __func__); - return 0; + return -ENOMEM; } fm_eth->tx_pram = pram;
@@ -313,7 +315,8 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) tx_bd_ring_base = malloc(sizeof(struct fm_port_bd) * TX_BD_RING_SIZE); if (!tx_bd_ring_base) - return 0; + return -ENOMEM; + memset(tx_bd_ring_base, 0, sizeof(struct fm_port_bd) * TX_BD_RING_SIZE); /* save it to fm_eth */ @@ -344,29 +347,35 @@ static int fm_eth_tx_port_parameter_init(struct fm_eth *fm_eth) /* set IM parameter ram pointer to Tx Confirmation Frame Queue ID */ out_be32(&bmi_tx_port->fmbm_tcfqid, pram_page_offset);
static int fm_eth_init(struct fm_eth *fm_eth) { + int ret;
- if (!fm_eth_rx_port_parameter_init(fm_eth)) - return 0; + ret = fm_eth_rx_port_parameter_init(fm_eth); + if (ret) + return ret;
- if (!fm_eth_tx_port_parameter_init(fm_eth)) - return 0; + ret = fm_eth_tx_port_parameter_init(fm_eth); + if (ret) + return ret;
static int fm_eth_startup(struct fm_eth *fm_eth) { struct fsl_enet_mac *mac; + int ret; + mac = fm_eth->mac;
/* Rx/TxBDs, Rx/TxQDs, Rx buff and parameter ram init */ - if (!fm_eth_init(fm_eth)) - return 0; + ret = fm_eth_init(fm_eth); + if (ret) + return ret; /* setup the MAC controller */ mac->init_mac(mac);
@@ -381,7 +390,7 @@ static int fm_eth_startup(struct fm_eth *fm_eth) /* init bmi tx port, IM mode and disable */ bmi_tx_port_init(fm_eth->tx_port);
static void fmc_tx_port_graceful_stop_enable(struct fm_eth *fm_eth) @@ -628,7 +637,7 @@ static int fm_eth_init_mac(struct fm_eth *fm_eth, struct ccsr_fman *reg) /* alloc mac controller */ mac = malloc(sizeof(struct fsl_enet_mac)); if (!mac) - return 0; + return -ENOMEM; memset(mac, 0, sizeof(struct fsl_enet_mac));
/* save the mac to fm_eth struct */ @@ -643,7 +652,7 @@ static int fm_eth_init_mac(struct fm_eth *fm_eth, struct ccsr_fman *reg) init_tgec(mac, base, phyregs, MAX_RXBUF_LEN); #endif
static int init_phy(struct eth_device *dev) @@ -696,17 +705,18 @@ int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info) struct eth_device *dev; struct fm_eth *fm_eth; int i, num = info->num; + int ret;
/* alloc eth device */ dev = (struct eth_device *)malloc(sizeof(struct eth_device)); if (!dev) - return 0; + return -ENOMEM; memset(dev, 0, sizeof(struct eth_device));
/* alloc the FMan ethernet private struct */ fm_eth = (struct fm_eth *)malloc(sizeof(struct fm_eth)); if (!fm_eth) - return 0; + return -ENOMEM; memset(fm_eth, 0, sizeof(struct fm_eth));
/* save off some things we need from the info struct */ @@ -721,8 +731,9 @@ int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info) fm_eth->max_rx_len = MAX_RXBUF_LEN;
/* init global mac structure */ - if (!fm_eth_init_mac(fm_eth, reg)) - return 0; + ret = fm_eth_init_mac(fm_eth, reg); + if (ret) + return ret;
/* keep same as the manual, we call FMAN1, FMAN2, DTSEC1, DTSEC2, etc */ if (fm_eth->type == FM_ETH_1G_E) @@ -743,8 +754,9 @@ int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info) fm_eth->enet_if = info->enet_if;
/* startup the FM im */ - if (!fm_eth_startup(fm_eth)) - return 0; + ret = fm_eth_startup(fm_eth); + if (ret) + return ret;
init_phy(dev);
@@ -753,5 +765,5 @@ int fm_eth_initialize(struct ccsr_fman *reg, struct fm_eth_info *info) dev->enetaddr[i] = 0; eth_register(dev);
codes related to phylib operations should be wrapped by CONFIG_PHYLIB.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - Fix all codes related to phylib to be wrapped by CONFIG_PHYLIB. V5: - No change. V4: - No change. V3: - New patch.
drivers/net/fm/eth.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index d7d064b..e262859 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -95,6 +95,7 @@ static void dtsec_init_phy(struct eth_device *dev) dtsec_configure_serdes(fm_eth); }
+#ifdef CONFIG_PHYLIB static int tgec_is_fibre(struct eth_device *dev) { struct fm_eth *fm = dev->priv; @@ -105,6 +106,7 @@ static int tgec_is_fibre(struct eth_device *dev) return hwconfig_arg_cmp(phyopt, "xfi"); } #endif +#endif
static u16 muram_readw(u16 *addr) { @@ -483,8 +485,10 @@ static void fm_eth_halt(struct eth_device *dev) /* disable bmi Rx port */ bmi_rx_port_disable(fm_eth->rx_port);
+#ifdef CONFIG_PHYLIB if (fm_eth->phydev) phy_shutdown(fm_eth->phydev); +#endif }
static int fm_eth_send(struct eth_device *dev, void *buf, int len) @@ -658,13 +662,15 @@ static int fm_eth_init_mac(struct fm_eth *fm_eth, struct ccsr_fman *reg) static int init_phy(struct eth_device *dev) { struct fm_eth *fm_eth = dev->priv; +#ifdef CONFIG_PHYLIB struct phy_device *phydev = NULL; u32 supported; +#endif
-#ifdef CONFIG_PHYLIB if (fm_eth->type == FM_ETH_1G_E) dtsec_init_phy(dev);
+#ifdef CONFIG_PHYLIB if (fm_eth->bus) { phydev = phy_connect(fm_eth->bus, fm_eth->phyaddr, dev, fm_eth->enet_if);
The fsl_dtsec.h & fsl_tgec.h & fsl_fman.h can be shared on both ARM and PPC, move it out of ppc to include/, and change the path in drivers accordingly.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - No change. V2: - No change.
arch/powerpc/include/asm/immap_85xx.h | 2 +- board/freescale/b4860qds/eth_b4860qds.c | 2 +- board/freescale/corenet_ds/eth_hydra.c | 2 +- board/freescale/corenet_ds/eth_p4080.c | 2 +- board/freescale/corenet_ds/eth_superhydra.c | 2 +- board/freescale/p1023rdb/p1023rdb.c | 2 +- board/freescale/p2041rdb/eth.c | 2 +- board/freescale/t102xqds/eth_t102xqds.c | 2 +- board/freescale/t102xrdb/eth_t102xrdb.c | 2 +- board/freescale/t1040qds/eth.c | 2 +- board/freescale/t104xrdb/eth.c | 2 +- board/freescale/t208xqds/eth_t208xqds.c | 2 +- board/freescale/t208xrdb/eth_t208xrdb.c | 2 +- board/freescale/t4qds/eth.c | 2 +- board/freescale/t4rdb/eth.c | 2 +- drivers/net/fm/dtsec.c | 2 +- drivers/net/fm/eth.c | 4 ++-- drivers/net/fm/fm.h | 2 +- drivers/net/fm/tgec.c | 2 +- drivers/net/fm/tgec_phy.c | 2 +- {arch/powerpc/include/asm => include}/fsl_dtsec.h | 0 {arch/powerpc/include/asm => include}/fsl_fman.h | 0 {arch/powerpc/include/asm => include}/fsl_tgec.h | 0 23 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 0c9d85e..101b8db 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -19,7 +19,7 @@ #include <fsl_sec.h> #include <fsl_sfp.h> #include <asm/fsl_lbc.h> -#include <asm/fsl_fman.h> +#include <fsl_fman.h> #include <fsl_immap.h>
typedef struct ccsr_local { diff --git a/board/freescale/b4860qds/eth_b4860qds.c b/board/freescale/b4860qds/eth_b4860qds.c index 501d4b3..df90476 100644 --- a/board/freescale/b4860qds/eth_b4860qds.c +++ b/board/freescale/b4860qds/eth_b4860qds.c @@ -26,7 +26,7 @@ #include <fsl_mdio.h> #include <malloc.h> #include <fdt_support.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
#include "../common/ngpixis.h" #include "../common/fman.h" diff --git a/board/freescale/corenet_ds/eth_hydra.c b/board/freescale/corenet_ds/eth_hydra.c index 396103f..172a55b 100644 --- a/board/freescale/corenet_ds/eth_hydra.c +++ b/board/freescale/corenet_ds/eth_hydra.c @@ -55,7 +55,7 @@ #include <fsl_mdio.h> #include <malloc.h> #include <fdt_support.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
#include "../common/ngpixis.h" #include "../common/fman.h" diff --git a/board/freescale/corenet_ds/eth_p4080.c b/board/freescale/corenet_ds/eth_p4080.c index 5cbec7f..c68dc2c 100644 --- a/board/freescale/corenet_ds/eth_p4080.c +++ b/board/freescale/corenet_ds/eth_p4080.c @@ -24,7 +24,7 @@
#include "../common/ngpixis.h" #include "../common/fman.h" -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
#define EMI_NONE 0xffffffff #define EMI_MASK 0xf0000000 diff --git a/board/freescale/corenet_ds/eth_superhydra.c b/board/freescale/corenet_ds/eth_superhydra.c index ad1bffd..62b1635 100644 --- a/board/freescale/corenet_ds/eth_superhydra.c +++ b/board/freescale/corenet_ds/eth_superhydra.c @@ -55,7 +55,7 @@ #include <fsl_mdio.h> #include <malloc.h> #include <fdt_support.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
#include "../common/ngpixis.h" #include "../common/fman.h" diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c index 56f561a..074b713 100644 --- a/board/freescale/p1023rdb/p1023rdb.c +++ b/board/freescale/p1023rdb/p1023rdb.c @@ -26,7 +26,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
diff --git a/board/freescale/p2041rdb/eth.c b/board/freescale/p2041rdb/eth.c index 532eeac..95fe85b 100644 --- a/board/freescale/p2041rdb/eth.c +++ b/board/freescale/p2041rdb/eth.c @@ -19,7 +19,7 @@ #include <fm_eth.h> #include <fsl_mdio.h> #include <malloc.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h>
#include "cpld.h" #include "../common/fman.h" diff --git a/board/freescale/t102xqds/eth_t102xqds.c b/board/freescale/t102xqds/eth_t102xqds.c index 441d6a3..99c23f7 100644 --- a/board/freescale/t102xqds/eth_t102xqds.c +++ b/board/freescale/t102xqds/eth_t102xqds.c @@ -21,7 +21,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h> #include "../common/qixis.h" #include "../common/fman.h" diff --git a/board/freescale/t102xrdb/eth_t102xrdb.c b/board/freescale/t102xrdb/eth_t102xrdb.c index 856ec6e..02b283d 100644 --- a/board/freescale/t102xrdb/eth_t102xrdb.c +++ b/board/freescale/t102xrdb/eth_t102xrdb.c @@ -21,7 +21,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h> #include "../common/fman.h"
diff --git a/board/freescale/t1040qds/eth.c b/board/freescale/t1040qds/eth.c index 8c82934..8bf34fa 100644 --- a/board/freescale/t1040qds/eth.c +++ b/board/freescale/t1040qds/eth.c @@ -17,7 +17,7 @@ #include <fm_eth.h> #include <fsl_mdio.h> #include <malloc.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <vsc9953.h>
#include "../common/fman.h" diff --git a/board/freescale/t104xrdb/eth.c b/board/freescale/t104xrdb/eth.c index 71d0457..52cd112 100644 --- a/board/freescale/t104xrdb/eth.c +++ b/board/freescale/t104xrdb/eth.c @@ -11,7 +11,7 @@ #include <fm_eth.h> #include <fsl_mdio.h> #include <malloc.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <vsc9953.h>
#include "../common/fman.h" diff --git a/board/freescale/t208xqds/eth_t208xqds.c b/board/freescale/t208xqds/eth_t208xqds.c index b82e9e7..1c0ce24 100644 --- a/board/freescale/t208xqds/eth_t208xqds.c +++ b/board/freescale/t208xqds/eth_t208xqds.c @@ -21,7 +21,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h> #include <hwconfig.h> #include "../common/qixis.h" diff --git a/board/freescale/t208xrdb/eth_t208xrdb.c b/board/freescale/t208xrdb/eth_t208xrdb.c index cbbc625..ea51195 100644 --- a/board/freescale/t208xrdb/eth_t208xrdb.c +++ b/board/freescale/t208xrdb/eth_t208xrdb.c @@ -21,7 +21,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h>
int board_eth_init(bd_t *bis) diff --git a/board/freescale/t4qds/eth.c b/board/freescale/t4qds/eth.c index 9b416b1..2dfdcbb 100644 --- a/board/freescale/t4qds/eth.c +++ b/board/freescale/t4qds/eth.c @@ -21,7 +21,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h> #include <hwconfig.h> #include "../common/qixis.h" diff --git a/board/freescale/t4rdb/eth.c b/board/freescale/t4rdb/eth.c index 879bd1a..e563a61 100644 --- a/board/freescale/t4rdb/eth.c +++ b/board/freescale/t4rdb/eth.c @@ -23,7 +23,7 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <asm/fsl_serdes.h> #include <hwconfig.h>
diff --git a/drivers/net/fm/dtsec.c b/drivers/net/fm/dtsec.c index 8d3dc0e..b339a84 100644 --- a/drivers/net/fm/dtsec.c +++ b/drivers/net/fm/dtsec.c @@ -7,7 +7,7 @@ #include <common.h> #include <asm/types.h> #include <asm/io.h> -#include <asm/fsl_dtsec.h> +#include <fsl_dtsec.h> #include <fsl_mdio.h> #include <phy.h>
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index e262859..bf16101 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -13,8 +13,8 @@ #include <fsl_mdio.h> #include <miiphy.h> #include <phy.h> -#include <asm/fsl_dtsec.h> -#include <asm/fsl_tgec.h> +#include <fsl_dtsec.h> +#include <fsl_tgec.h> #include <fsl_memac.h>
#include "fm.h" diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index 73c525e..fa9bc9f 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -10,7 +10,7 @@ #include <common.h> #include <phy.h> #include <fm_eth.h> -#include <asm/fsl_fman.h> +#include <fsl_fman.h>
/* Port ID */ #define OH_PORT_ID_BASE 0x01 diff --git a/drivers/net/fm/tgec.c b/drivers/net/fm/tgec.c index 5017123..8d4622f 100644 --- a/drivers/net/fm/tgec.c +++ b/drivers/net/fm/tgec.c @@ -12,7 +12,7 @@ #include <phy.h> #include <asm/types.h> #include <asm/io.h> -#include <asm/fsl_tgec.h> +#include <fsl_tgec.h>
#include "fm.h"
diff --git a/drivers/net/fm/tgec_phy.c b/drivers/net/fm/tgec_phy.c index 095f00c..24cb17b 100644 --- a/drivers/net/fm/tgec_phy.c +++ b/drivers/net/fm/tgec_phy.c @@ -9,7 +9,7 @@ #include <miiphy.h> #include <phy.h> #include <asm/io.h> -#include <asm/fsl_tgec.h> +#include <fsl_tgec.h> #include <fm_eth.h>
/* diff --git a/arch/powerpc/include/asm/fsl_dtsec.h b/include/fsl_dtsec.h similarity index 100% rename from arch/powerpc/include/asm/fsl_dtsec.h rename to include/fsl_dtsec.h diff --git a/arch/powerpc/include/asm/fsl_fman.h b/include/fsl_fman.h similarity index 100% rename from arch/powerpc/include/asm/fsl_fman.h rename to include/fsl_fman.h diff --git a/arch/powerpc/include/asm/fsl_tgec.h b/include/fsl_tgec.h similarity index 100% rename from arch/powerpc/include/asm/fsl_tgec.h rename to include/fsl_tgec.h
QSGMII PCS needed to be programmed same as SGMII PCS, and there are four ports in QSGMII PCS, port 0, 1, 2, 3, all the four ports shared port 0's MDIO controller, so when programming port 0, we continue to program other three ports.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - Remove the "if(priv->phyaddr%4 != 0)" condition in qsgmii_loop. V3: - No change. V2: - No change.
drivers/net/fm/eth.c | 18 +++++++++++++----- 1 file changed, 13 insertions(+), 5 deletions(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index bf16101..1cb1f7a 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -41,28 +41,35 @@ static void dtsec_configure_serdes(struct fm_eth *priv) bus.priv = priv->mac->phyregs; bool sgmii_2500 = (priv->enet_if == PHY_INTERFACE_MODE_SGMII_2500) ? true : false; + int i = 0;
+qsgmii_loop: /* SGMII IF mode + AN enable only for 1G SGMII, not for 2.5G */ value = PHY_SGMII_IF_MODE_SGMII; if (!sgmii_2500) value |= PHY_SGMII_IF_MODE_AN;
- memac_mdio_write(&bus, 0, MDIO_DEVAD_NONE, 0x14, value); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x14, value);
/* Dev ability according to SGMII specification */ value = PHY_SGMII_DEV_ABILITY_SGMII; - memac_mdio_write(&bus, 0, MDIO_DEVAD_NONE, 0x4, value); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x4, value);
/* Adjust link timer for SGMII - 1.6 ms in units of 8 ns = 2 * 10^5 = 0x30d40 */ - memac_mdio_write(&bus, 0, MDIO_DEVAD_NONE, 0x13, 0x3); - memac_mdio_write(&bus, 0, MDIO_DEVAD_NONE, 0x12, 0xd40); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x13, 0x3); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0x12, 0xd40);
/* Restart AN */ value = PHY_SGMII_CR_DEF_VAL; if (!sgmii_2500) value |= PHY_SGMII_CR_RESET_AN; - memac_mdio_write(&bus, 0, MDIO_DEVAD_NONE, 0, value); + memac_mdio_write(&bus, i, MDIO_DEVAD_NONE, 0, value); + + if ((priv->enet_if == PHY_INTERFACE_MODE_QSGMII) && (i < 3)) { + i++; + goto qsgmii_loop; + } #else struct dtsec *regs = priv->mac->base; struct tsec_mii_mng *phyregs = priv->mac->phyregs; @@ -91,6 +98,7 @@ static void dtsec_init_phy(struct eth_device *dev) #endif
if (fm_eth->enet_if == PHY_INTERFACE_MODE_SGMII || + fm_eth->enet_if == PHY_INTERFACE_MODE_QSGMII || fm_eth->enet_if == PHY_INTERFACE_MODE_SGMII_2500) dtsec_configure_serdes(fm_eth); }
MDIO controller base on FMAN2 was defined as CONFIG_SYS_FSL_FM2_ADDR plus offset, but CONFIG_SYS_FSL_FM2_ADDR only defined when there are two FMANs, so we should only define MDIO controller base on FMAN2 when there is FMAN2.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - No change. V2: - No change.
include/fm_eth.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/include/fm_eth.h b/include/fm_eth.h index 3e1b9f4..d43f801 100644 --- a/include/fm_eth.h +++ b/include/fm_eth.h @@ -45,8 +45,10 @@ enum fm_eth_type { #ifdef CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM1_DTSEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xfc000) #define CONFIG_SYS_FM1_TGEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xfd000) +#if (CONFIG_SYS_NUM_FMAN == 2) #define CONFIG_SYS_FM2_DTSEC_MDIO_ADDR (CONFIG_SYS_FSL_FM2_ADDR + 0xfc000) #define CONFIG_SYS_FM2_TGEC_MDIO_ADDR (CONFIG_SYS_FSL_FM2_ADDR + 0xfd000) +#endif #else #define CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xe1120) #define CONFIG_SYS_FM1_TGEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xf1000) @@ -89,6 +91,7 @@ enum fm_eth_type { offsetof(struct ccsr_fman, memac[n-1]),\ } #else +#if (CONFIG_SYS_NUM_FMAN == 2) #define FM_TGEC_INFO_INITIALIZER(idx, n) \ { \ FM_ETH_INFO_INITIALIZER(idx, CONFIG_SYS_FM2_TGEC_MDIO_ADDR) \ @@ -101,6 +104,20 @@ enum fm_eth_type { .compat_offset = CONFIG_SYS_FSL_FM##idx##_OFFSET + \ offsetof(struct ccsr_fman, memac[n-1+8]),\ } +#else +#define FM_TGEC_INFO_INITIALIZER(idx, n) \ +{ \ + FM_ETH_INFO_INITIALIZER(idx, CONFIG_SYS_FM1_TGEC_MDIO_ADDR) \ + .index = idx, \ + .num = n - 1, \ + .type = FM_ETH_10G_E, \ + .port = FM##idx##_10GEC##n, \ + .rx_port_id = RX_PORT_10G_BASE + n - 1, \ + .tx_port_id = TX_PORT_10G_BASE + n - 1, \ + .compat_offset = CONFIG_SYS_FSL_FM##idx##_OFFSET + \ + offsetof(struct ccsr_fman, memac[n-1+8]),\ +} +#endif #endif
#if (CONFIG_SYS_NUM_FM1_10GEC >= 3)
There are two LS series processors are built on ARMv8 Layersacpe architecture currently, LS2085A and LS1043A. They are based on ARMv8 core although use different chassis, so create fsl-layerscape to refactor the common code for the LS series processors which also paves the way for adding LS1043A platform.
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - Remove GIC SMMU TZPC macros from ls2085a_common.h to config.h. - Modify fsl_lsch3_wake_secondary_cores() to fsl_layerscape_wake_seconday_cores() - Fix lsch3->layerscape changes for ls2085a emu and simu. V5: - Move LS2085A ddr macros out of soc #ifdef. - Move macros and structs from cpu.c to cpu.h. - Wrap le32 and be32 functions for ccsr gur and scfg. Defined in soc.h - Modify fsl-layerscape/Makefile. V4: - New patch.
arch/arm/cpu/armv8/Makefile | 2 +- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 21 ++ .../README => fsl-layerscape/README.lsch3} | 2 +- .../cpu/armv8/{fsl-lsch3 => fsl-layerscape}/cpu.c | 248 ++++++--------------- .../cpu/armv8/{fsl-lsch3 => fsl-layerscape}/cpu.h | 2 +- .../cpu/armv8/{fsl-lsch3 => fsl-layerscape}/fdt.c | 17 +- .../fsl_lsch3_serdes.c | 8 +- .../speed.c => fsl-layerscape/fsl_lsch3_speed.c} | 12 +- .../armv8/{fsl-lsch3 => fsl-layerscape}/lowlevel.S | 14 +- .../{fsl-lsch3 => fsl-layerscape}/ls2085a_serdes.c | 3 +- .../cpu/armv8/{fsl-lsch3 => fsl-layerscape}/mp.c | 16 +- .../cpu/armv8/{fsl-lsch3 => fsl-layerscape}/soc.c | 35 +-- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 76 +++++++ arch/arm/cpu/armv8/fsl-lsch3/Makefile | 13 -- arch/arm/cpu/armv8/fsl-lsch3/speed.h | 7 - .../clock.h | 8 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 96 ++++++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 165 ++++++++++++++ .../{arch-fsl-lsch3 => arch-fsl-layerscape}/fdt.h | 4 + .../fsl_serdes.h | 11 +- .../immap_lsch3.h | 119 ++++++++-- .../arm/include/asm/arch-fsl-layerscape/imx-regs.h | 55 +++++ .../ls2085a_stream_id.h | 0 arch/arm/include/asm/arch-fsl-layerscape/mmu.h | 10 + .../asm/arch-fsl-layerscape}/mp.h | 10 +- .../{arch-fsl-lsch3 => arch-fsl-layerscape}/soc.h | 21 +- arch/arm/include/asm/arch-fsl-layerscape/speed.h | 10 + arch/arm/include/asm/arch-fsl-lsch3/config.h | 185 --------------- arch/arm/include/asm/arch-fsl-lsch3/gpio.h | 9 - arch/arm/include/asm/arch-fsl-lsch3/imx-regs.h | 13 -- arch/arm/include/asm/config.h | 7 +- board/freescale/ls2085a/Kconfig | 4 +- board/freescale/ls2085a/ls2085a.c | 2 +- board/freescale/ls2085aqds/Kconfig | 2 +- board/freescale/ls2085aqds/eth.c | 1 - board/freescale/ls2085aqds/ls2085aqds.c | 2 +- board/freescale/ls2085ardb/Kconfig | 2 +- board/freescale/ls2085ardb/eth_ls2085rdb.c | 1 - board/freescale/ls2085ardb/ls2085ardb.c | 2 +- drivers/i2c/mxc_i2c.c | 4 +- drivers/misc/fsl_debug_server.c | 1 - drivers/net/ldpaa_eth/ls2085a.c | 2 - drivers/pci/pcie_layerscape.c | 4 +- include/common.h | 3 + include/configs/ls2085a_common.h | 10 +- 45 files changed, 713 insertions(+), 526 deletions(-)
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index adb11b3..48c041b 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -15,6 +15,6 @@ obj-y += cache.o obj-y += tlb.o obj-y += transition.o
-obj-$(CONFIG_FSL_LSCH3) += fsl-lsch3/ +obj-$(CONFIG_FSL_LAYERSCAPE) += fsl-layerscape/ obj-$(CONFIG_ARCH_ZYNQMP) += zynqmp/ obj-$(CONFIG_TARGET_HIKEY) += hisilicon/ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile new file mode 100644 index 0000000..ccb3aa5 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -0,0 +1,21 @@ +# +# Copyright 2014-2015, Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cpu.o +obj-y += lowlevel.o +obj-y += soc.o +obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-$(CONFIG_SPL) += spl.o + +ifneq ($(CONFIG_FSL_LSCH3),) +obj-y += fsl_lsch3_speed.o +obj-$(CONFIG_SYS_HAS_SERDES) += fsl_lsch3_serdes.o +endif + +ifneq ($(CONFIG_LS2085A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls2085a_serdes.o +endif diff --git a/arch/arm/cpu/armv8/fsl-lsch3/README b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 similarity index 99% rename from arch/arm/cpu/armv8/fsl-lsch3/README rename to arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 index 08da7e4..03e18f6 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/README +++ b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch3 @@ -1,5 +1,5 @@ # -# Copyright 2014 Freescale Semiconductor +# Copyright 2014-2015 Freescale Semiconductor # # SPDX-License-Identifier: GPL-2.0+ # diff --git a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c similarity index 59% rename from arch/arm/cpu/armv8/fsl-lsch3/cpu.c rename to arch/arm/cpu/armv8/fsl-layerscape/cpu.c index eb1213e..be7442d 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,5 +1,5 @@ /* - * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2014-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,34 +10,28 @@ #include <asm/system.h> #include <asm/armv8/mmu.h> #include <asm/io.h> -#include <asm/arch-fsl-lsch3/soc.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> +#include <asm/arch/cpu.h> +#include <asm/arch/speed.h> +#ifdef CONFIG_MP +#include <asm/arch/mp.h> +#endif +#include <fm_eth.h> #include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> -#include <asm/arch/fsl_serdes.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> #endif -#include "cpu.h" -#include "mp.h" -#include "speed.h"
-static struct cpu_type cpu_type_list[] = { -#ifdef CONFIG_LS2085A - CPU_TYPE_ENTRY(LS2085, LS2085, 8), - CPU_TYPE_ENTRY(LS2080, LS2080, 8), - CPU_TYPE_ENTRY(LS2045, LS2045, 4), -#endif -}; - void cpu_name(char *name) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); unsigned int i, svr, ver;
- svr = in_le32(&gur->svr); + svr = gur_in32(&gur->svr); ver = SVR_SOC_VER(svr);
for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) @@ -54,146 +48,6 @@ void cpu_name(char *name) }
#ifndef CONFIG_SYS_DCACHE_OFF - -#define SECTION_SHIFT_L0 39UL -#define SECTION_SHIFT_L1 30UL -#define SECTION_SHIFT_L2 21UL -#define BLOCK_SIZE_L0 0x8000000000 -#define BLOCK_SIZE_L1 0x40000000 -#define BLOCK_SIZE_L2 0x200000 - -#define NUM_OF_ENTRY 512 - -#define TCR_EL2_PS_40BIT (2 << 16) -#define LSCH3_VA_BITS (40) -#define LSCH3_TCR (TCR_TG0_4K | \ - TCR_EL2_PS_40BIT | \ - TCR_SHARED_NON | \ - TCR_ORGN_NC | \ - TCR_IRGN_NC | \ - TCR_T0SZ(LSCH3_VA_BITS)) -#define LSCH3_TCR_FINAL (TCR_TG0_4K | \ - TCR_EL2_PS_40BIT | \ - TCR_SHARED_OUTER | \ - TCR_ORGN_WBWA | \ - TCR_IRGN_WBWA | \ - TCR_T0SZ(LSCH3_VA_BITS)) - -#define CONFIG_SYS_FSL_CCSR_BASE 0x00000000 -#define CONFIG_SYS_FSL_CCSR_SIZE 0x10000000 -#define CONFIG_SYS_FSL_QSPI_BASE1 0x20000000 -#define CONFIG_SYS_FSL_QSPI_SIZE1 0x10000000 -#define CONFIG_SYS_FSL_IFC_BASE1 0x30000000 -#define CONFIG_SYS_FSL_IFC_SIZE1 0x10000000 -#define CONFIG_SYS_FSL_IFC_SIZE1_1 0x400000 -#define CONFIG_SYS_FSL_DRAM_BASE1 0x80000000 -#define CONFIG_SYS_FSL_DRAM_SIZE1 0x80000000 -#define CONFIG_SYS_FSL_QSPI_BASE2 0x400000000 -#define CONFIG_SYS_FSL_QSPI_SIZE2 0x100000000 -#define CONFIG_SYS_FSL_IFC_BASE2 0x500000000 -#define CONFIG_SYS_FSL_IFC_SIZE2 0x100000000 -#define CONFIG_SYS_FSL_DCSR_BASE 0x700000000 -#define CONFIG_SYS_FSL_DCSR_SIZE 0x40000000 -#define CONFIG_SYS_FSL_MC_BASE 0x80c000000 -#define CONFIG_SYS_FSL_MC_SIZE 0x4000000 -#define CONFIG_SYS_FSL_NI_BASE 0x810000000 -#define CONFIG_SYS_FSL_NI_SIZE 0x8000000 -#define CONFIG_SYS_FSL_QBMAN_BASE 0x818000000 -#define CONFIG_SYS_FSL_QBMAN_SIZE 0x8000000 -#define CONFIG_SYS_FSL_QBMAN_SIZE_1 0x4000000 -#define CONFIG_SYS_PCIE1_PHYS_SIZE 0x200000000 -#define CONFIG_SYS_PCIE2_PHYS_SIZE 0x200000000 -#define CONFIG_SYS_PCIE3_PHYS_SIZE 0x200000000 -#define CONFIG_SYS_PCIE4_PHYS_SIZE 0x200000000 -#define CONFIG_SYS_FSL_WRIOP1_BASE 0x4300000000 -#define CONFIG_SYS_FSL_WRIOP1_SIZE 0x100000000 -#define CONFIG_SYS_FSL_AIOP1_BASE 0x4b00000000 -#define CONFIG_SYS_FSL_AIOP1_SIZE 0x100000000 -#define CONFIG_SYS_FSL_PEBUF_BASE 0x4c00000000 -#define CONFIG_SYS_FSL_PEBUF_SIZE 0x400000000 -#define CONFIG_SYS_FSL_DRAM_BASE2 0x8080000000 -#define CONFIG_SYS_FSL_DRAM_SIZE2 0x7F80000000 - -struct sys_mmu_table { - u64 virt_addr; - u64 phys_addr; - u64 size; - u64 memory_type; - u64 share; -}; - -static const struct sys_mmu_table lsch3_early_mmu_table[] = { - { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, - CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, - CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, - /* For IFC Region #1, only the first 4MB is cache-enabled */ - { CONFIG_SYS_FSL_IFC_BASE1, CONFIG_SYS_FSL_IFC_BASE1, - CONFIG_SYS_FSL_IFC_SIZE1_1, MT_NORMAL, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_IFC_BASE1 + CONFIG_SYS_FSL_IFC_SIZE1_1, - CONFIG_SYS_FSL_IFC_BASE1 + CONFIG_SYS_FSL_IFC_SIZE1_1, - CONFIG_SYS_FSL_IFC_SIZE1 - CONFIG_SYS_FSL_IFC_SIZE1_1, - MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FSL_IFC_BASE1, - CONFIG_SYS_FSL_IFC_SIZE1, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, - CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, - { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, - CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, - CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, -}; - -static const struct sys_mmu_table lsch3_final_mmu_table[] = { - { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, - CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, - CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, - CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, - { CONFIG_SYS_FSL_QSPI_BASE2, CONFIG_SYS_FSL_QSPI_BASE2, - CONFIG_SYS_FSL_QSPI_SIZE2, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_BASE2, - CONFIG_SYS_FSL_IFC_SIZE2, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, - CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_MC_BASE, CONFIG_SYS_FSL_MC_BASE, - CONFIG_SYS_FSL_MC_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_NI_BASE, CONFIG_SYS_FSL_NI_BASE, - CONFIG_SYS_FSL_NI_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - /* For QBMAN portal, only the first 64MB is cache-enabled */ - { CONFIG_SYS_FSL_QBMAN_BASE, CONFIG_SYS_FSL_QBMAN_BASE, - CONFIG_SYS_FSL_QBMAN_SIZE_1, MT_NORMAL, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_QBMAN_BASE + CONFIG_SYS_FSL_QBMAN_SIZE_1, - CONFIG_SYS_FSL_QBMAN_BASE + CONFIG_SYS_FSL_QBMAN_SIZE_1, - CONFIG_SYS_FSL_QBMAN_SIZE - CONFIG_SYS_FSL_QBMAN_SIZE_1, - MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_PCIE1_PHYS_ADDR, CONFIG_SYS_PCIE1_PHYS_ADDR, - CONFIG_SYS_PCIE1_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_PCIE2_PHYS_ADDR, CONFIG_SYS_PCIE2_PHYS_ADDR, - CONFIG_SYS_PCIE2_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_PCIE3_PHYS_ADDR, CONFIG_SYS_PCIE3_PHYS_ADDR, - CONFIG_SYS_PCIE3_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, -#ifdef CONFIG_LS2085A - { CONFIG_SYS_PCIE4_PHYS_ADDR, CONFIG_SYS_PCIE4_PHYS_ADDR, - CONFIG_SYS_PCIE4_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, -#endif - { CONFIG_SYS_FSL_WRIOP1_BASE, CONFIG_SYS_FSL_WRIOP1_BASE, - CONFIG_SYS_FSL_WRIOP1_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_AIOP1_BASE, CONFIG_SYS_FSL_AIOP1_BASE, - CONFIG_SYS_FSL_AIOP1_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_PEBUF_BASE, CONFIG_SYS_FSL_PEBUF_BASE, - CONFIG_SYS_FSL_PEBUF_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, - { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, - CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, -}; - -struct table_info { - u64 *ptr; - u64 table_base; - u64 entry_size; -}; - /* * Set the block entries according to the information of the table. */ @@ -311,6 +165,7 @@ static inline void early_mmu_setup(void) u64 *level1_table1 = (u64 *)(CONFIG_SYS_FSL_OCRAM_BASE + 0x2000); u64 *level2_table0 = (u64 *)(CONFIG_SYS_FSL_OCRAM_BASE + 0x3000); u64 *level2_table1 = (u64 *)(CONFIG_SYS_FSL_OCRAM_BASE + 0x4000); + struct table_info table = {level0_table, 0, BLOCK_SIZE_L0};
/* Invalidate all table entries */ @@ -320,19 +175,21 @@ static inline void early_mmu_setup(void) set_pgtable_table(level0_table, 0, level1_table0); set_pgtable_table(level0_table, 1, level1_table1); set_pgtable_table(level1_table0, 0, level2_table0); + +#ifdef CONFIG_FSL_LSCH3 set_pgtable_table(level1_table0, CONFIG_SYS_FLASH_BASE >> SECTION_SHIFT_L1, level2_table1); - +#endif /* Find the table and fill in the block entries */ - for (i = 0; i < ARRAY_SIZE(lsch3_early_mmu_table); i++) { - if (find_table(&lsch3_early_mmu_table[i], + for (i = 0; i < ARRAY_SIZE(early_mmu_table); i++) { + if (find_table(&early_mmu_table[i], &table, level0_table) == 0) { /* * If find_table() returns error, it cannot be dealt * with here. Breakpoint can be added for debugging. */ - set_block_entry(&lsch3_early_mmu_table[i], &table); + set_block_entry(&early_mmu_table[i], &table); /* * If set_block_entry() returns error, it cannot be * dealt with here too. @@ -341,7 +198,9 @@ static inline void early_mmu_setup(void) }
el = current_el(); - set_ttbr_tcr_mair(el, (u64)level0_table, LSCH3_TCR, MEMORY_ATTRIBUTES); + + set_ttbr_tcr_mair(el, (u64)level0_table, LAYERSCAPE_TCR, + MEMORY_ATTRIBUTES); set_sctlr(get_sctlr() | CR_M); }
@@ -353,6 +212,8 @@ static inline void early_mmu_setup(void) * Level 1 table 0 contains 512 entries for each 1GB from 0 to 512GB. * Level 1 table 1 contains 512 entries for each 1GB from 512GB to 1TB. * Level 2 table 0 contains 512 entries for each 2MB from 0 to 1GB. + * + * For LSCH3: * Level 2 table 1 contains 512 entries for each 2MB from 32GB to 33GB. */ static inline void final_mmu_setup(void) @@ -362,7 +223,9 @@ static inline void final_mmu_setup(void) u64 *level1_table0 = (u64 *)(gd->arch.tlb_addr + 0x1000); u64 *level1_table1 = (u64 *)(gd->arch.tlb_addr + 0x2000); u64 *level2_table0 = (u64 *)(gd->arch.tlb_addr + 0x3000); +#ifdef CONFIG_FSL_LSCH3 u64 *level2_table1 = (u64 *)(gd->arch.tlb_addr + 0x4000); +#endif struct table_info table = {level0_table, 0, BLOCK_SIZE_L0};
/* Invalidate all table entries */ @@ -372,23 +235,25 @@ static inline void final_mmu_setup(void) set_pgtable_table(level0_table, 0, level1_table0); set_pgtable_table(level0_table, 1, level1_table1); set_pgtable_table(level1_table0, 0, level2_table0); +#ifdef CONFIG_FSL_LSCH3 set_pgtable_table(level1_table0, CONFIG_SYS_FSL_QBMAN_BASE >> SECTION_SHIFT_L1, level2_table1); +#endif
/* Find the table and fill in the block entries */ - for (i = 0; i < ARRAY_SIZE(lsch3_final_mmu_table); i++) { - if (find_table(&lsch3_final_mmu_table[i], + for (i = 0; i < ARRAY_SIZE(final_mmu_table); i++) { + if (find_table(&final_mmu_table[i], &table, level0_table) == 0) { - if (set_block_entry(&lsch3_final_mmu_table[i], + if (set_block_entry(&final_mmu_table[i], &table) != 0) { printf("MMU error: could not set block entry for %p\n", - &lsch3_final_mmu_table[i]); + &final_mmu_table[i]); }
} else { printf("MMU error: could not find the table for %p\n", - &lsch3_final_mmu_table[i]); + &final_mmu_table[i]); } }
@@ -398,7 +263,8 @@ static inline void final_mmu_setup(void)
/* point TTBR to the new table */ el = current_el(); - set_ttbr_tcr_mair(el, (u64)level0_table, LSCH3_TCR_FINAL, + + set_ttbr_tcr_mair(el, (u64)level0_table, LAYERSCAPE_TCR_FINAL, MEMORY_ATTRIBUTES); /* * MMU is already enabled, just need to invalidate TLB to load the @@ -434,8 +300,9 @@ static inline u32 initiator_type(u32 cluster, int init_id) { struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); u32 idx = (cluster >> (init_id * 8)) & TP_CLUSTER_INIT_MASK; - u32 type = in_le32(&gur->tp_ityp[idx]); + u32 type = 0;
+ type = gur_in32(&gur->tp_ityp[idx]); if (type & TP_ITYP_AV) return type;
@@ -450,7 +317,8 @@ u32 cpu_mask(void)
do { int j; - cluster = in_le32(&gur->tp_cluster[i].lower); + + cluster = gur_in32(&gur->tp_cluster[i].lower); for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { type = initiator_type(cluster, j); if (type) { @@ -460,7 +328,7 @@ u32 cpu_mask(void) } } i++; - } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + } while ((cluster & TP_CLUSTER_EOC) == 0x0);
return mask; } @@ -482,7 +350,8 @@ int fsl_qoriq_core_to_cluster(unsigned int core)
do { int j; - cluster = in_le32(&gur->tp_cluster[i].lower); + + cluster = gur_in32(&gur->tp_cluster[i].lower); for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { if (initiator_type(cluster, j)) { if (count == core) @@ -491,7 +360,7 @@ int fsl_qoriq_core_to_cluster(unsigned int core) } } i++; - } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + } while ((cluster & TP_CLUSTER_EOC) == 0x0);
return -1; /* cannot identify the cluster */ } @@ -505,7 +374,8 @@ u32 fsl_qoriq_core_to_type(unsigned int core)
do { int j; - cluster = in_le32(&gur->tp_cluster[i].lower); + + cluster = gur_in32(&gur->tp_cluster[i].lower); for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { type = initiator_type(cluster, j); if (type) { @@ -515,7 +385,7 @@ u32 fsl_qoriq_core_to_type(unsigned int core) } } i++; - } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + } while ((cluster & TP_CLUSTER_EOC) == 0x0);
return -1; /* cannot identify the cluster */ } @@ -527,15 +397,13 @@ int print_cpuinfo(void) struct sys_info sysinfo; char buf[32]; unsigned int i, core; - u32 type; + u32 type, rcw;
puts("SoC: ");
cpu_name(buf); - printf(" %s (0x%x)\n", buf, in_le32(&gur->svr)); - + printf(" %s (0x%x)\n", buf, gur_in32(&gur->svr)); memset((u8 *)buf, 0x00, ARRAY_SIZE(buf)); - get_sys_info(&sysinfo); puts("Clock Configuration:"); for_each_cpu(i, core, cpu_numcores(), cpu_mask()) { @@ -551,18 +419,20 @@ int print_cpuinfo(void) printf("\n Bus: %-4s MHz ", strmhz(buf, sysinfo.freq_systembus)); printf("DDR: %-4s MT/s", strmhz(buf, sysinfo.freq_ddrbus)); +#ifdef CONFIG_FSL_LSCH3 printf(" DP-DDR: %-4s MT/s", strmhz(buf, sysinfo.freq_ddrbus2)); +#endif puts("\n");
- /* Display the RCW, so that no one gets confused as to what RCW + /* + * Display the RCW, so that no one gets confused as to what RCW * we're actually using for this boot. */ puts("Reset Configuration Word (RCW):"); for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { - u32 rcw = in_le32(&gur->rcwsr[i]); - + rcw = gur_in32(&gur->rcwsr[i]); if ((i % 4) == 0) - printf("\n %02x:", i * 4); + printf("\n %08x:", i * 4); printf(" %08x", rcw); } puts("\n"); @@ -590,11 +460,13 @@ int cpu_eth_init(bd_t *bis)
int arch_early_init_r(void) { - int rv; - rv = fsl_lsch3_wake_seconday_cores(); +#ifdef CONFIG_MP + int rv = 1;
+ rv = fsl_layerscape_wake_seconday_cores(); if (rv) printf("Did not wake secondary cores\n"); +#endif
#ifdef CONFIG_SYS_HAS_SERDES fsl_serdes_init(); @@ -605,7 +477,9 @@ int arch_early_init_r(void) int timer_init(void) { u32 __iomem *cntcr = (u32 *)CONFIG_SYS_FSL_TIMER_ADDR; +#ifdef CONFIG_FSL_LSCH3 u32 __iomem *cltbenr = (u32 *)CONFIG_SYS_FSL_PMU_CLTBENR; +#endif #ifdef COUNTER_FREQUENCY_REAL unsigned long cntfrq = COUNTER_FREQUENCY_REAL;
@@ -613,10 +487,12 @@ int timer_init(void) asm volatile("msr cntfrq_el0, %0" : : "r" (cntfrq) : "memory"); #endif
+#ifdef CONFIG_FSL_LSCH3 /* Enable timebase for all clusters. * It is safe to do so even some clusters are not enabled. */ out_le32(cltbenr, 0xf); +#endif
/* Enable clock for timer * This is a global setting. @@ -632,7 +508,7 @@ void reset_cpu(ulong addr) u32 val;
/* Raise RESET_REQ_B */ - val = in_le32(rstcr); + val = scfg_in32(rstcr); val |= 0x02; - out_le32(rstcr, val); + scfg_out32(rstcr, val); } diff --git a/arch/arm/cpu/armv8/fsl-lsch3/cpu.h b/arch/arm/cpu/armv8/fsl-layerscape/cpu.h similarity index 71% rename from arch/arm/cpu/armv8/fsl-lsch3/cpu.h rename to arch/arm/cpu/armv8/fsl-layerscape/cpu.h index 2e3312b..8072f3c 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/cpu.h +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.h @@ -1,5 +1,5 @@ /* - * Copyright 2014, Freescale Semiconductor + * Copyright 2014-2015, Freescale Semiconductor * * SPDX-License-Identifier: GPL-2.0+ */ diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c similarity index 94% rename from arch/arm/cpu/armv8/fsl-lsch3/fdt.c rename to arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 567c419..aa88d34 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -1,5 +1,5 @@ /* - * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2014-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,11 +7,16 @@ #include <common.h> #include <libfdt.h> #include <fdt_support.h> -#include <asm/arch-fsl-lsch3/fdt.h> +#include <phy.h> +#ifdef CONFIG_FSL_LSCH3 +#include <asm/arch/fdt.h> +#endif #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> #endif -#include "mp.h" +#ifdef CONFIG_MP +#include <asm/arch/mp.h> +#endif
#ifdef CONFIG_MP void ft_fixup_cpu(void *blob) @@ -150,6 +155,7 @@ void append_mmu_masters(void *blob, const char *smmu_path, * for all DPAA2 devices. * */ +#ifdef CONFIG_FSL_LSCH3 static void fdt_fixup_smmu(void *blob) { int nodeoffset; @@ -165,6 +171,7 @@ static void fdt_fixup_smmu(void *blob) fdt_fixup_smmu_pcie(blob); #endif } +#endif
void ft_cpu_setup(void *blob, bd_t *bd) { @@ -181,9 +188,11 @@ void ft_cpu_setup(void *blob, bd_t *bd) ft_pci_setup(blob, bd); #endif
-#if defined(CONFIG_FSL_ESDHC) +#ifdef CONFIG_FSL_ESDHC fdt_fixup_esdhc(blob, bd); #endif
+#ifdef CONFIG_FSL_LSCH3 fdt_fixup_smmu(blob); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c similarity index 95% rename from arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c rename to arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index ae08343..2ab8da6 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -1,5 +1,5 @@ /* - * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2014-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -8,7 +8,7 @@ #include <asm/io.h> #include <asm/errno.h> #include <asm/arch/fsl_serdes.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> +#include <asm/arch/soc.h> #include <fsl-mc/ldpaa_wriop.h>
#ifdef CONFIG_SYS_FSL_SRDS_1 @@ -35,7 +35,7 @@ int is_serdes_configured(enum srds_prtcl device) int serdes_get_first_lane(u32 sd, enum srds_prtcl device) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); - u32 cfg = in_le32(&gur->rcwsr[28]); + u32 cfg = gur_in32(&gur->rcwsr[28]); int i;
switch (sd) { @@ -76,7 +76,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift,
memset(serdes_prtcl_map, 0, sizeof(serdes_prtcl_map));
- cfg = in_le32(&gur->rcwsr[28]) & sd_prctl_mask; + cfg = gur_in32(&gur->rcwsr[28]) & sd_prctl_mask; cfg >>= sd_prctl_shift; printf("Using SERDES%d Protocol: %d (0x%x)\n", sd + 1, cfg, cfg);
diff --git a/arch/arm/cpu/armv8/fsl-lsch3/speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c similarity index 93% rename from arch/arm/cpu/armv8/fsl-lsch3/speed.c rename to arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index d9f137c..4054c3c 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -1,5 +1,5 @@ /* - * Copyright 2014, Freescale Semiconductor, Inc. + * Copyright 2014-2015, Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ * @@ -11,8 +11,8 @@ #include <fsl_ifc.h> #include <asm/processor.h> #include <asm/io.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> #include <asm/arch/clock.h> +#include <asm/arch/soc.h> #include "cpu.h"
DECLARE_GLOBAL_DATA_PTR; @@ -83,15 +83,15 @@ void get_sys_info(struct sys_info *sys_info) sys_info->freq_ddrbus2 = sysclk; #endif
- sys_info->freq_systembus *= (in_le32(&gur->rcwsr[0]) >> + sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_SYS_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_SYS_PLL_RAT_MASK; /* Platform clock is half of platform PLL */ sys_info->freq_systembus /= 2; - sys_info->freq_ddrbus *= (in_le32(&gur->rcwsr[0]) >> + sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_MEM_PLL_RAT_MASK; - sys_info->freq_ddrbus2 *= (in_le32(&gur->rcwsr[0]) >> + sys_info->freq_ddrbus2 *= (gur_in32(&gur->rcwsr[0]) >> FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_SHIFT) & FSL_CHASSIS3_RCWSR0_MEM2_PLL_RAT_MASK;
@@ -118,7 +118,7 @@ void get_sys_info(struct sys_info *sys_info) }
#if defined(CONFIG_FSL_IFC) - ccr = in_le32(&ifc_regs.gregs->ifc_ccr); + ccr = ifc_in32(&ifc_regs.gregs->ifc_ccr); ccr = ((ccr & IFC_CCR_CLK_DIV_MASK) >> IFC_CCR_CLK_DIV_SHIFT) + 1;
sys_info->freq_localbus = sys_info->freq_systembus / ccr; diff --git a/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S similarity index 97% rename from arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S rename to arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 6b19d36..41e1704 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -1,5 +1,5 @@ /* - * (C) Copyright 2014 Freescale Semiconductor + * (C) Copyright 2014-2015 Freescale Semiconductor * * SPDX-License-Identifier: GPL-2.0+ * @@ -10,11 +10,14 @@ #include <linux/linkage.h> #include <asm/gic.h> #include <asm/macro.h> -#include "mp.h" +#ifdef CONFIG_MP +#include <asm/arch/mp.h> +#endif
ENTRY(lowlevel_init) mov x29, lr /* Save LR */
+#ifdef CONFIG_FSL_LSCH3 /* Add fully-coherent masters to DVM domain */ ldr x0, =CCI_MN_BASE ldr x1, =CCI_MN_RNF_NODEID_LIST @@ -81,6 +84,7 @@ ENTRY(lowlevel_init) ldr x0, =CCI_S2_QOS_CONTROL_BASE(20) ldr x1, =0x00FF000C bl ccn504_set_qos +#endif
/* Set the SMMU page size in the sACR register */ ldr x1, =SMMU_BASE @@ -106,10 +110,12 @@ ENTRY(lowlevel_init)
branch_if_master x0, x1, 2f
+#if defined(CONFIG_MP) && defined(CONFIG_ARMV8_MULTIENTRY) ldr x0, =secondary_boot_func blr x0 -2: +#endif
+2: #ifdef CONFIG_FSL_TZPC_BP147 /* Set Non Secure access for all devices protected via TZPC */ ldr x1, =TZPCDECPROT_0_SET_BASE /* Decode Protection-0 Set Reg */ @@ -245,6 +251,7 @@ ENTRY(__asm_flush_l3_cache) ret ENDPROC(__asm_flush_l3_cache)
+#ifdef CONFIG_MP /* Keep literals not used by the secondary boot code outside it */ .ltorg
@@ -353,3 +360,4 @@ __real_cntfrq: /* Secondary Boot Code ends here */ __secondary_boot_code_size: .quad .-secondary_boot_code +#endif diff --git a/arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls2085a_serdes.c similarity index 97% rename from arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c rename to arch/arm/cpu/armv8/fsl-layerscape/ls2085a_serdes.c index 0b79a50..ea3114c 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls2085a_serdes.c @@ -1,12 +1,11 @@ /* - * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2014-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <asm/arch/fsl_serdes.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h>
struct serdes_config { u8 protocol; diff --git a/arch/arm/cpu/armv8/fsl-lsch3/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c similarity index 92% rename from arch/arm/cpu/armv8/fsl-lsch3/mp.c rename to arch/arm/cpu/armv8/fsl-layerscape/mp.c index da7853a..1b13d32 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -1,5 +1,5 @@ /* - * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2014-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -7,9 +7,8 @@ #include <common.h> #include <asm/io.h> #include <asm/system.h> -#include <asm/io.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> -#include "mp.h" +#include <asm/arch/mp.h> +#include <asm/arch/soc.h>
@@ -23,7 +22,7 @@ phys_addr_t determine_mp_bootpg(void) return (phys_addr_t)&secondary_boot_code; }
-int fsl_lsch3_wake_seconday_cores(void) +int fsl_layerscape_wake_seconday_cores(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); struct ccsr_reset __iomem *rst = (void *)(CONFIG_SYS_FSL_RST_ADDR); @@ -48,9 +47,10 @@ int fsl_lsch3_wake_seconday_cores(void) (CONFIG_MAX_CPUS*SPIN_TABLE_ELEM_SIZE));
printf("Waking secondary cores to start from %lx\n", gd->relocaddr); - out_le32(&gur->bootlocptrh, (u32)(gd->relocaddr >> 32)); - out_le32(&gur->bootlocptrl, (u32)gd->relocaddr); - out_le32(&gur->scratchrw[6], 1); + + gur_out32(&gur->bootlocptrh, (u32)(gd->relocaddr >> 32)); + gur_out32(&gur->bootlocptrl, (u32)gd->relocaddr); + gur_out32(&gur->scratchrw[6], 1); asm volatile("dsb st" : : : "memory"); rst->brrl = cores; asm volatile("dsb st" : : : "memory"); diff --git a/arch/arm/cpu/armv8/fsl-lsch3/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c similarity index 73% rename from arch/arm/cpu/armv8/fsl-lsch3/soc.c rename to arch/arm/cpu/armv8/fsl-layerscape/soc.c index 2538001..73e48a7 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -1,19 +1,18 @@ /* - * Copyright 2015 Freescale Semiconductor + * Copyright 2014-2015 Freescale Semiconductor * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> #include <fsl_ifc.h> -#include <nand.h> -#include <spl.h> -#include <asm/arch-fsl-lsch3/soc.h> +#include <asm/arch/soc.h> #include <asm/io.h> #include <asm/global_data.h>
+#ifdef CONFIG_LS2085A static void erratum_a008751(void) { #ifdef CONFIG_SYS_FSL_ERRATUM_A008751 @@ -77,31 +76,11 @@ void fsl_lsch3_early_init_f(void) init_early_memctl_regs(); /* tighten IFC timing */ erratum_a009203(); } +#endif
-#ifdef CONFIG_SPL_BUILD -void board_init_f(ulong dummy) -{ - /* Clear global data */ - memset((void *)gd, 0, sizeof(gd_t)); - - arch_cpu_init(); - board_early_init_f(); - timer_init(); - env_init(); - gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE); - - serial_init(); - console_init_f(); - dram_init(); - - /* Clear the BSS. */ - memset(__bss_start, 0, __bss_end - __bss_start); - - board_init_r(NULL, 0); -} - -u32 spl_boot_device(void) +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) { - return BOOT_DEVICE_NAND; + return 0; } #endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c new file mode 100644 index 0000000..2f30d4b --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -0,0 +1,76 @@ +/* + * Copyright 2014-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <fsl_ifc.h> +#include <fsl_csu.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +u32 spl_boot_device(void) +{ +#ifdef CONFIG_SPL_MMC_SUPPORT + return BOOT_DEVICE_MMC1; +#endif +#ifdef CONFIG_SPL_NAND_SUPPORT + return BOOT_DEVICE_NAND; +#endif + return 0; +} + +u32 spl_boot_mode(void) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: +#ifdef CONFIG_SPL_FAT_SUPPORT + return MMCSD_MODE_FAT; +#else + return MMCSD_MODE_RAW; +#endif + case BOOT_DEVICE_NAND: + return 0; + default: + puts("spl: error: unsupported device\n"); + hang(); + } +} + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong dummy) +{ + /* Set global data pointer */ + gd = &gdata; + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); +#ifdef CONFIG_LS2085A + arch_cpu_init(); +#endif +#ifdef CONFIG_FSL_IFC + init_early_memctl_regs(); +#endif + board_early_init_f(); + timer_init(); +#ifdef CONFIG_LS2085A + env_init(); +#endif + get_clocks(); + + preloader_console_init(); + +#ifdef CONFIG_SPL_I2C_SUPPORT + i2c_init_all(); +#endif + dram_init(); + + /* Clear the BSS */ + memset(__bss_start, 0, __bss_end - __bss_start); + + board_init_r(NULL, 0); +} +#endif diff --git a/arch/arm/cpu/armv8/fsl-lsch3/Makefile b/arch/arm/cpu/armv8/fsl-lsch3/Makefile deleted file mode 100644 index 9f7815b..0000000 --- a/arch/arm/cpu/armv8/fsl-lsch3/Makefile +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright 2014, Freescale Semiconductor -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y += cpu.o -obj-y += lowlevel.o -obj-y += soc.o -obj-y += speed.o -obj-$(CONFIG_SYS_HAS_SERDES) += fsl_lsch3_serdes.o ls2085a_serdes.o -obj-$(CONFIG_MP) += mp.o -obj-$(CONFIG_OF_LIBFDT) += fdt.o diff --git a/arch/arm/cpu/armv8/fsl-lsch3/speed.h b/arch/arm/cpu/armv8/fsl-lsch3/speed.h deleted file mode 100644 index 15af5b9..0000000 --- a/arch/arm/cpu/armv8/fsl-lsch3/speed.h +++ /dev/null @@ -1,7 +0,0 @@ -/* - * Copyright 2014, Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -void get_sys_info(struct sys_info *sys_info); diff --git a/arch/arm/include/asm/arch-fsl-lsch3/clock.h b/arch/arm/include/asm/arch-fsl-layerscape/clock.h similarity index 56% rename from arch/arm/include/asm/arch-fsl-lsch3/clock.h rename to arch/arm/include/asm/arch-fsl-layerscape/clock.h index 62bc53c..6935913 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/clock.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/clock.h @@ -1,12 +1,12 @@ /* - * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ * */
-#ifndef __ASM_ARCH_FSL_LSCH3_CLOCK_H_ -#define __ASM_ARCH_FSL_LSCH3_CLOCK_H_ +#ifndef __ASM_ARCH_FSL_LAYERSCAPE_CLOCK_H_ +#define __ASM_ARCH_FSL_LAYERSCAPE_CLOCK_H_
#include <common.h>
@@ -21,4 +21,4 @@ enum mxc_clock {
unsigned int mxc_get_clock(enum mxc_clock clk);
-#endif /* __ASM_ARCH_FSL_LSCH3_CLOCK_H_ */ +#endif /* __ASM_ARCH_FSL_LAYERSCAPE_CLOCK_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h new file mode 100644 index 0000000..dd7203f --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -0,0 +1,96 @@ +/* + * Copyright 2015, Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARMV8_FSL_LAYERSCAPE_CONFIG_H_ +#define _ASM_ARMV8_FSL_LAYERSCAPE_CONFIG_H_ + +#include <fsl_ddrc_version.h> + +#ifdef CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_FSL_DDRC_GEN4 +#else +#define CONFIG_SYS_FSL_DDRC_ARM_GEN3 /* Enable Freescale ARM DDR3 driver */ +#endif +#define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ +#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 + +#if defined(CONFIG_LS2085A) +#define CONFIG_MAX_CPUS 16 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define CONFIG_NUM_DDR_CONTROLLERS 3 +#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4, 4 } +#define SRDS_MAX_LANES 8 +#define CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_FSL_SRDS_2 +#define CONFIG_SYS_PAGE_SIZE 0x10000 +#define CONFIG_SYS_CACHELINE_SIZE 64 +#ifndef L1_CACHE_BYTES +#define L1_CACHE_SHIFT 6 +#define L1_CACHE_BYTES BIT(L1_CACHE_SHIFT) +#endif + +#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x00200000 /* 2M */ + +/* DDR */ +#define CONFIG_SYS_FSL_DDR_LE +#define CONFIG_SYS_LS2_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_LS2_DDR_BLOCK1_SIZE + +#define CONFIG_SYS_FSL_CCSR_GUR_LE +#define CONFIG_SYS_FSL_CCSR_SCFG_LE +#define CONFIG_SYS_FSL_ESDHC_LE +#define CONFIG_SYS_FSL_IFC_LE + +#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x06000000 +#define GICR_BASE 0x06100000 + +/* SMMU Defintions */ +#define SMMU_BASE 0x05000000 /* GR0 Base */ + +/* Cache Coherent Interconnect */ +#define CCI_MN_BASE 0x04000000 +#define CCI_MN_RNF_NODEID_LIST 0x180 +#define CCI_MN_DVM_DOMAIN_CTL 0x200 +#define CCI_MN_DVM_DOMAIN_CTL_SET 0x210 + +#define CCI_RN_I_0_BASE (CCI_MN_BASE + 0x800000) +#define CCI_RN_I_2_BASE (CCI_MN_BASE + 0x820000) +#define CCI_RN_I_6_BASE (CCI_MN_BASE + 0x860000) +#define CCI_RN_I_12_BASE (CCI_MN_BASE + 0x8C0000) +#define CCI_RN_I_16_BASE (CCI_MN_BASE + 0x900000) +#define CCI_RN_I_20_BASE (CCI_MN_BASE + 0x940000) + +#define CCI_S0_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x10) +#define CCI_S1_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x110) +#define CCI_S2_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x210) + +/* TZ Protection Controller Definitions */ +#define TZPC_BASE 0x02200000 +#define TZPCR0SIZE_BASE (TZPC_BASE) +#define TZPCDECPROT_0_STAT_BASE (TZPC_BASE + 0x800) +#define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) +#define TZPCDECPROT_0_CLR_BASE (TZPC_BASE + 0x808) +#define TZPCDECPROT_1_STAT_BASE (TZPC_BASE + 0x80C) +#define TZPCDECPROT_1_SET_BASE (TZPC_BASE + 0x810) +#define TZPCDECPROT_1_CLR_BASE (TZPC_BASE + 0x814) +#define TZPCDECPROT_2_STAT_BASE (TZPC_BASE + 0x818) +#define TZPCDECPROT_2_SET_BASE (TZPC_BASE + 0x81C) +#define TZPCDECPROT_2_CLR_BASE (TZPC_BASE + 0x820) + +#define CONFIG_SYS_FSL_ERRATUM_A008336 +#define CONFIG_SYS_FSL_ERRATUM_A008511 +#define CONFIG_SYS_FSL_ERRATUM_A008514 +#define CONFIG_SYS_FSL_ERRATUM_A008585 +#define CONFIG_SYS_FSL_ERRATUM_A008751 +#else +#error SoC not defined +#endif + +#endif /* _ASM_ARMV8_FSL_LAYERSCAPE_CONFIG_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h new file mode 100644 index 0000000..b7b8e5d --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -0,0 +1,165 @@ +/* + * Copyright 2014-2015, Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FSL_LAYERSCAPE_CPU_H +#define _FSL_LAYERSCAPE_CPU_H + +static struct cpu_type cpu_type_list[] = { + CPU_TYPE_ENTRY(LS2085, LS2085, 8), + CPU_TYPE_ENTRY(LS2080, LS2080, 8), + CPU_TYPE_ENTRY(LS2045, LS2045, 4), +}; + +#ifndef CONFIG_SYS_DCACHE_OFF + +#define SECTION_SHIFT_L0 39UL +#define SECTION_SHIFT_L1 30UL +#define SECTION_SHIFT_L2 21UL +#define BLOCK_SIZE_L0 0x8000000000 +#define BLOCK_SIZE_L1 0x40000000 +#define BLOCK_SIZE_L2 0x200000 +#define NUM_OF_ENTRY 512 +#define TCR_EL2_PS_40BIT (2 << 16) + +#define LAYERSCAPE_VA_BITS (40) +#define LAYERSCAPE_TCR (TCR_TG0_4K | \ + TCR_EL2_PS_40BIT | \ + TCR_SHARED_NON | \ + TCR_ORGN_NC | \ + TCR_IRGN_NC | \ + TCR_T0SZ(LAYERSCAPE_VA_BITS)) +#define LAYERSCAPE_TCR_FINAL (TCR_TG0_4K | \ + TCR_EL2_PS_40BIT | \ + TCR_SHARED_OUTER | \ + TCR_ORGN_WBWA | \ + TCR_IRGN_WBWA | \ + TCR_T0SZ(LAYERSCAPE_VA_BITS)) + +#ifdef CONFIG_FSL_LSCH3 +#define CONFIG_SYS_FSL_CCSR_BASE 0x00000000 +#define CONFIG_SYS_FSL_CCSR_SIZE 0x10000000 +#define CONFIG_SYS_FSL_QSPI_BASE1 0x20000000 +#define CONFIG_SYS_FSL_QSPI_SIZE1 0x10000000 +#define CONFIG_SYS_FSL_IFC_BASE1 0x30000000 +#define CONFIG_SYS_FSL_IFC_SIZE1 0x10000000 +#define CONFIG_SYS_FSL_IFC_SIZE1_1 0x400000 +#define CONFIG_SYS_FSL_DRAM_BASE1 0x80000000 +#define CONFIG_SYS_FSL_DRAM_SIZE1 0x80000000 +#define CONFIG_SYS_FSL_QSPI_BASE2 0x400000000 +#define CONFIG_SYS_FSL_QSPI_SIZE2 0x100000000 +#define CONFIG_SYS_FSL_IFC_BASE2 0x500000000 +#define CONFIG_SYS_FSL_IFC_SIZE2 0x100000000 +#define CONFIG_SYS_FSL_DCSR_BASE 0x700000000 +#define CONFIG_SYS_FSL_DCSR_SIZE 0x40000000 +#define CONFIG_SYS_FSL_MC_BASE 0x80c000000 +#define CONFIG_SYS_FSL_MC_SIZE 0x4000000 +#define CONFIG_SYS_FSL_NI_BASE 0x810000000 +#define CONFIG_SYS_FSL_NI_SIZE 0x8000000 +#define CONFIG_SYS_FSL_QBMAN_BASE 0x818000000 +#define CONFIG_SYS_FSL_QBMAN_SIZE 0x8000000 +#define CONFIG_SYS_FSL_QBMAN_SIZE_1 0x4000000 +#define CONFIG_SYS_PCIE1_PHYS_SIZE 0x200000000 +#define CONFIG_SYS_PCIE2_PHYS_SIZE 0x200000000 +#define CONFIG_SYS_PCIE3_PHYS_SIZE 0x200000000 +#define CONFIG_SYS_PCIE4_PHYS_SIZE 0x200000000 +#define CONFIG_SYS_FSL_WRIOP1_BASE 0x4300000000 +#define CONFIG_SYS_FSL_WRIOP1_SIZE 0x100000000 +#define CONFIG_SYS_FSL_AIOP1_BASE 0x4b00000000 +#define CONFIG_SYS_FSL_AIOP1_SIZE 0x100000000 +#define CONFIG_SYS_FSL_PEBUF_BASE 0x4c00000000 +#define CONFIG_SYS_FSL_PEBUF_SIZE 0x400000000 +#define CONFIG_SYS_FSL_DRAM_BASE2 0x8080000000 +#define CONFIG_SYS_FSL_DRAM_SIZE2 0x7F80000000 +#endif + +struct sys_mmu_table { + u64 virt_addr; + u64 phys_addr; + u64 size; + u64 memory_type; + u64 share; +}; + +struct table_info { + u64 *ptr; + u64 table_base; + u64 entry_size; +}; + +static const struct sys_mmu_table early_mmu_table[] = { +#ifdef CONFIG_FSL_LSCH3 + { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, + CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, + CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, + /* For IFC Region #1, only the first 4MB is cache-enabled */ + { CONFIG_SYS_FSL_IFC_BASE1, CONFIG_SYS_FSL_IFC_BASE1, + CONFIG_SYS_FSL_IFC_SIZE1_1, MT_NORMAL, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_IFC_BASE1 + CONFIG_SYS_FSL_IFC_SIZE1_1, + CONFIG_SYS_FSL_IFC_BASE1 + CONFIG_SYS_FSL_IFC_SIZE1_1, + CONFIG_SYS_FSL_IFC_SIZE1 - CONFIG_SYS_FSL_IFC_SIZE1_1, + MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FSL_IFC_BASE1, + CONFIG_SYS_FSL_IFC_SIZE1, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, + CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, + { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, + CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, + CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, +#endif +}; + +static const struct sys_mmu_table final_mmu_table[] = { +#ifdef CONFIG_FSL_LSCH3 + { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, + CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, + CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, + CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, + { CONFIG_SYS_FSL_QSPI_BASE2, CONFIG_SYS_FSL_QSPI_BASE2, + CONFIG_SYS_FSL_QSPI_SIZE2, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_BASE2, + CONFIG_SYS_FSL_IFC_SIZE2, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, + CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_MC_BASE, CONFIG_SYS_FSL_MC_BASE, + CONFIG_SYS_FSL_MC_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_NI_BASE, CONFIG_SYS_FSL_NI_BASE, + CONFIG_SYS_FSL_NI_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + /* For QBMAN portal, only the first 64MB is cache-enabled */ + { CONFIG_SYS_FSL_QBMAN_BASE, CONFIG_SYS_FSL_QBMAN_BASE, + CONFIG_SYS_FSL_QBMAN_SIZE_1, MT_NORMAL, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_QBMAN_BASE + CONFIG_SYS_FSL_QBMAN_SIZE_1, + CONFIG_SYS_FSL_QBMAN_BASE + CONFIG_SYS_FSL_QBMAN_SIZE_1, + CONFIG_SYS_FSL_QBMAN_SIZE - CONFIG_SYS_FSL_QBMAN_SIZE_1, + MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_PCIE1_PHYS_ADDR, CONFIG_SYS_PCIE1_PHYS_ADDR, + CONFIG_SYS_PCIE1_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_PCIE2_PHYS_ADDR, CONFIG_SYS_PCIE2_PHYS_ADDR, + CONFIG_SYS_PCIE2_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_PCIE3_PHYS_ADDR, CONFIG_SYS_PCIE3_PHYS_ADDR, + CONFIG_SYS_PCIE3_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, +#ifdef CONFIG_LS2085A + { CONFIG_SYS_PCIE4_PHYS_ADDR, CONFIG_SYS_PCIE4_PHYS_ADDR, + CONFIG_SYS_PCIE4_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, +#endif + { CONFIG_SYS_FSL_WRIOP1_BASE, CONFIG_SYS_FSL_WRIOP1_BASE, + CONFIG_SYS_FSL_WRIOP1_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_AIOP1_BASE, CONFIG_SYS_FSL_AIOP1_BASE, + CONFIG_SYS_FSL_AIOP1_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_PEBUF_BASE, CONFIG_SYS_FSL_PEBUF_BASE, + CONFIG_SYS_FSL_PEBUF_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, + CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, +#endif +}; +#endif + +int fsl_qoriq_core_to_cluster(unsigned int core); +u32 cpu_mask(void); +#endif /* _FSL_LAYERSCAPE_CPU_H */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/fdt.h b/arch/arm/include/asm/arch-fsl-layerscape/fdt.h similarity index 71% rename from arch/arm/include/asm/arch-fsl-lsch3/fdt.h rename to arch/arm/include/asm/arch-fsl-layerscape/fdt.h index 21d20fb..4da73ab 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/fdt.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fdt.h @@ -4,7 +4,11 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#ifndef _ASM_ARMV8_FSL_LAYERSCAPE_FDT_H_ +#define _ASM_ARMV8_FSL_LAYERSCAPE_FDT_H_ + void alloc_stream_ids(int start_id, int count, u32 *stream_ids, int max_cnt); void append_mmu_masters(void *blob, const char *smmu_path, const char *master_name, u32 *stream_ids, int count); void fdt_fixup_smmu_pcie(void *blob); +#endif /* _ASM_ARMV8_FSL_LAYERSCAPE_FDT_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h similarity index 88% rename from arch/arm/include/asm/arch-fsl-lsch3/fsl_serdes.h rename to arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 2810f3f..730c2b2 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -4,13 +4,12 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __FSL_SERDES_H -#define __FSL_SERDES_H +#ifndef __FSL_SERDES_H__ +#define __FSL_SERDES_H__
#include <config.h>
-#define SRDS_MAX_LANES 8 - +#if defined(CONFIG_LS2085A) enum srds_prtcl { NONE = 0, PCIE1, @@ -56,12 +55,12 @@ enum srds { FSL_SRDS_1 = 0, FSL_SRDS_2 = 1, }; +#endif
int is_serdes_configured(enum srds_prtcl device); void fsl_serdes_init(void); - int serdes_get_first_lane(u32 sd, enum srds_prtcl device); enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); int is_serdes_prtcl_valid(int serdes, u32 prtcl);
-#endif /* __FSL_SERDES_H */ +#endif /* __FSL_SERDES_H__ */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h similarity index 58% rename from arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h rename to arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index d6bee60..6a70d44 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -6,9 +6,109 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __ARCH_FSL_LSCH3_IMMAP_H +#ifndef __ARCH_FSL_LSCH3_IMMAP_H_ #define __ARCH_FSL_LSCH3_IMMAP_H_
+#define CONFIG_SYS_IMMR 0x01000000 +#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) +#define CONFIG_SYS_FSL_DDR2_ADDR (CONFIG_SYS_IMMR + 0x00090000) +#define CONFIG_SYS_FSL_DDR3_ADDR 0x08210000 +#define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00E00000) +#define CONFIG_SYS_FSL_PMU_ADDR (CONFIG_SYS_IMMR + 0x00E30000) +#define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00E60000) +#define CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR (CONFIG_SYS_IMMR + 0x00300000) +#define CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR (CONFIG_SYS_IMMR + 0x00310000) +#define CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR (CONFIG_SYS_IMMR + 0x00370000) +#define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x01140000) +#define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011C0600) +#define CONFIG_SYS_FSL_TIMER_ADDR 0x023d0000 +#define CONFIG_SYS_FSL_PMU_CLTBENR (CONFIG_SYS_FSL_PMU_ADDR + \ + 0x18A0) + +#define CONFIG_SYS_FSL_WRIOP1_ADDR (CONFIG_SYS_IMMR + 0x7B80000) +#define CONFIG_SYS_FSL_WRIOP1_MDIO1 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x16000) +#define CONFIG_SYS_FSL_WRIOP1_MDIO2 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x17000) +#define CONFIG_SYS_FSL_LSCH3_SERDES_ADDR (CONFIG_SYS_IMMR + 0xEA0000) + +/* SP (Cortex-A5) related */ +#define CONFIG_SYS_FSL_SP_ADDR (CONFIG_SYS_IMMR + 0x00F00000) +#define CONFIG_SYS_FSL_SP_VSG_GIC_ADDR (CONFIG_SYS_FSL_SP_ADDR) +#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR1 (CONFIG_SYS_FSL_SP_ADDR) +#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR2 \ + (CONFIG_SYS_FSL_SP_ADDR + 0x0008) +#define CONFIG_SYS_FSL_SP_LOOPBACK_DUART \ + (CONFIG_SYS_FSL_SP_ADDR + 0x1000) + +#define CONFIG_SYS_FSL_DCSR_DDR_ADDR 0x70012c000ULL +#define CONFIG_SYS_FSL_DCSR_DDR2_ADDR 0x70012d000ULL +#define CONFIG_SYS_FSL_DCSR_DDR3_ADDR 0x700132000ULL +#define CONFIG_SYS_FSL_DCSR_DDR4_ADDR 0x700133000ULL + +#define I2C1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01000000) +#define I2C2_BASE_ADDR (CONFIG_SYS_IMMR + 0x01010000) +#define I2C3_BASE_ADDR (CONFIG_SYS_IMMR + 0x01020000) +#define I2C4_BASE_ADDR (CONFIG_SYS_IMMR + 0x01030000) + +#define CONFIG_SYS_LS2085A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_LS2085A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02110000) + +/* TZ Address Space Controller Definitions */ +#define TZASC1_BASE 0x01100000 /* as per CCSR map. */ +#define TZASC2_BASE 0x01110000 /* as per CCSR map. */ +#define TZASC3_BASE 0x01120000 /* as per CCSR map. */ +#define TZASC4_BASE 0x01130000 /* as per CCSR map. */ +#define TZASC_BUILD_CONFIG_REG(x) ((TZASC1_BASE + (x * 0x10000))) +#define TZASC_ACTION_REG(x) ((TZASC1_BASE + (x * 0x10000)) + 0x004) +#define TZASC_GATE_KEEPER(x) ((TZASC1_BASE + (x * 0x10000)) + 0x008) +#define TZASC_REGION_BASE_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x100) +#define TZASC_REGION_BASE_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x104) +#define TZASC_REGION_TOP_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x108) +#define TZASC_REGION_TOP_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x10C) +#define TZASC_REGION_ATTRIBUTES_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x110) +#define TZASC_REGION_ID_ACCESS_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x114) + +/* PCIe */ +#define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) +#define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) +#define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) +#define CONFIG_SYS_PCIE4_ADDR (CONFIG_SYS_IMMR + 0x2700000) +#define CONFIG_SYS_PCIE1_PHYS_ADDR 0x1000000000ULL +#define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL +#define CONFIG_SYS_PCIE3_PHYS_ADDR 0x1400000000ULL +#define CONFIG_SYS_PCIE4_PHYS_ADDR 0x1600000000ULL + +/* Device Configuration */ +#define DCFG_BASE 0x01e00000 +#define DCFG_PORSR1 0x000 +#define DCFG_PORSR1_RCW_SRC 0xff800000 +#define DCFG_PORSR1_RCW_SRC_NOR 0x12f00000 +#define DCFG_RCWSR13 0x130 +#define DCFG_RCWSR13_DSPI (0 << 8) + +#define DCFG_DCSR_BASE 0X700100000ULL +#define DCFG_DCSR_PORCR1 0x000 + +/* Supplemental Configuration */ +#define SCFG_BASE 0x01fc0000 +#define SCFG_USB3PRM1CR 0x000 + +#define TP_ITYP_AV 0x00000001 /* Initiator available */ +#define TP_ITYP_TYPE(x) (((x) & 0x6) >> 1) /* Initiator Type */ +#define TP_ITYP_TYPE_ARM 0x0 +#define TP_ITYP_TYPE_PPC 0x1 /* PowerPC */ +#define TP_ITYP_TYPE_OTHER 0x2 /* StarCore DSP */ +#define TP_ITYP_TYPE_HA 0x3 /* HW Accelerator */ +#define TP_ITYP_THDS(x) (((x) & 0x18) >> 3) /* # threads */ +#define TP_ITYP_VER(x) (((x) & 0xe0) >> 5) /* Initiator Version */ +#define TY_ITYP_VER_A7 0x1 +#define TY_ITYP_VER_A53 0x2 +#define TY_ITYP_VER_A57 0x3 + +#define TP_CLUSTER_EOC 0x80000000 /* end of clusters */ +#define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ +#define TP_INIT_PER_CLUSTER 4 /* This is chassis generation 3 */
struct sys_info { @@ -109,21 +209,6 @@ struct ccsr_gur { u8 res_858[0x1000-0x858]; };
-#define TP_ITYP_AV 0x00000001 /* Initiator available */ -#define TP_ITYP_TYPE(x) (((x) & 0x6) >> 1) /* Initiator Type */ -#define TP_ITYP_TYPE_ARM 0x0 -#define TP_ITYP_TYPE_PPC 0x1 /* PowerPC */ -#define TP_ITYP_TYPE_OTHER 0x2 /* StarCore DSP */ -#define TP_ITYP_TYPE_HA 0x3 /* HW Accelerator */ -#define TP_ITYP_THDS(x) (((x) & 0x18) >> 3) /* # threads */ -#define TP_ITYP_VER(x) (((x) & 0xe0) >> 5) /* Initiator Version */ -#define TY_ITYP_VER_A7 0x1 -#define TY_ITYP_VER_A53 0x2 -#define TY_ITYP_VER_A57 0x3 - -#define TP_CLUSTER_EOC 0x80000000 /* end of clusters */ -#define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ -#define TP_INIT_PER_CLUSTER 4
struct ccsr_clk_cluster_group { struct { @@ -180,4 +265,4 @@ struct ccsr_reset { u32 ip_rev1; /* 0xbf8 */ u32 ip_rev2; /* 0xbfc */ }; -#endif /* __ARCH_FSL_LSCH3_IMMAP_H */ +#endif /* __ARCH_FSL_LSCH3_IMMAP_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/imx-regs.h b/arch/arm/include/asm/arch-fsl-layerscape/imx-regs.h new file mode 100644 index 0000000..57e417b --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/imx-regs.h @@ -0,0 +1,55 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + */ + +#ifndef __ASM_ARCH_FSL_LAYERSCAPE_IMX_REGS_H__ +#define __ASM_ARCH_FSL_LAYERSCAPE_IMX_REGS_H__ + +#define I2C_QUIRK_REG /* enable 8-bit driver */ + +#ifdef CONFIG_FSL_LPUART +#ifdef CONFIG_LPUART_32B_REG +struct lpuart_fsl { + u32 baud; + u32 stat; + u32 ctrl; + u32 data; + u32 match; + u32 modir; + u32 fifo; + u32 water; +}; +#else +struct lpuart_fsl { + u8 ubdh; + u8 ubdl; + u8 uc1; + u8 uc2; + u8 us1; + u8 us2; + u8 uc3; + u8 ud; + u8 uma1; + u8 uma2; + u8 uc4; + u8 uc5; + u8 ued; + u8 umodem; + u8 uir; + u8 reserved; + u8 upfifo; + u8 ucfifo; + u8 usfifo; + u8 utwfifo; + u8 utcfifo; + u8 urwfifo; + u8 urcfifo; + u8 rsvd[28]; +}; +#endif +#endif /* CONFIG_FSL_LPUART */ + +#endif /* __ASM_ARCH_FSL_LAYERSCAPE_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/ls2085a_stream_id.h b/arch/arm/include/asm/arch-fsl-layerscape/ls2085a_stream_id.h similarity index 100% rename from arch/arm/include/asm/arch-fsl-lsch3/ls2085a_stream_id.h rename to arch/arm/include/asm/arch-fsl-layerscape/ls2085a_stream_id.h diff --git a/arch/arm/include/asm/arch-fsl-layerscape/mmu.h b/arch/arm/include/asm/arch-fsl-layerscape/mmu.h new file mode 100644 index 0000000..d54eacd --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/mmu.h @@ -0,0 +1,10 @@ +/* + * Copyright 2015, Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARMV8_FSL_LAYERSCAPE_MMU_H_ +#define _ASM_ARMV8_FSL_LAYERSCAPE_MMU_H_ +#include <asm/arch-armv8/mmu.h> +#endif /* _ASM_ARMV8_FSL_LAYERSCAPE_MMU_H_ */ diff --git a/arch/arm/cpu/armv8/fsl-lsch3/mp.h b/arch/arm/include/asm/arch-fsl-layerscape/mp.h similarity index 82% rename from arch/arm/cpu/armv8/fsl-lsch3/mp.h rename to arch/arm/include/asm/arch-fsl-layerscape/mp.h index c985d6a..e46e076 100644 --- a/arch/arm/cpu/armv8/fsl-lsch3/mp.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/mp.h @@ -1,11 +1,11 @@ /* - * Copyright 2014, Freescale Semiconductor + * Copyright 2014-2015, Freescale Semiconductor * * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _FSL_CH3_MP_H -#define _FSL_CH3_MP_H +#ifndef _FSL_LAYERSCAPE_MP_H +#define _FSL_LAYERSCAPE_MP_H
/* * Each spin table element is defined as @@ -29,10 +29,10 @@ extern u64 __spin_table[]; extern u64 __real_cntfrq; extern u64 *secondary_boot_code; extern size_t __secondary_boot_code_size; -int fsl_lsch3_wake_seconday_cores(void); +int fsl_layerscape_wake_seconday_cores(void); void *get_spin_tbl_addr(void); phys_addr_t determine_mp_bootpg(void); void secondary_boot_func(void); int is_core_online(u64 cpu_id); #endif -#endif /* _FSL_CH3_MP_H */ +#endif /* _FSL_LAYERSCAPE_MP_H */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h similarity index 50% rename from arch/arm/include/asm/arch-fsl-lsch3/soc.h rename to arch/arm/include/asm/arch-fsl-layerscape/soc.h index 9a29272..f131f57 100644 --- a/arch/arm/include/asm/arch-fsl-lsch3/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -4,6 +4,25 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#ifndef _ASM_ARMV8_FSL_LAYERSCAPE_SOC_H_ +#define _ASM_ARMV8_FSL_LAYERSCAPE_SOC_H_ + +#ifdef CONFIG_SYS_FSL_CCSR_GUR_LE +#define gur_in32(a) in_le32(a) +#define gur_out32(a, v) out_le32(a, v) +#elif defined(CONFIG_SYS_FSL_CCSR_GUR_BE) +#define gur_in32(a) in_be32(a) +#define gur_out32(a, v) out_be32(a, v) +#endif + +#ifdef CONFIG_SYS_FSL_CCSR_SCFG_LE +#define scfg_in32(a) in_le32(a) +#define scfg_out32(a, v) out_le32(a, v) +#elif defined(CONFIG_SYS_FSL_CCSR_SCFG_BE) +#define scfg_in32(a) in_be32(a) +#define scfg_out32(a, v) out_be32(a, v) +#endif + struct cpu_type { char name[15]; u32 soc_ver; @@ -25,4 +44,4 @@ struct cpu_type {
void fsl_lsch3_early_init_f(void); void cpu_name(char *name); - +#endif /* _ASM_ARMV8_FSL_LAYERSCAPE_SOC_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/speed.h b/arch/arm/include/asm/arch-fsl-layerscape/speed.h new file mode 100644 index 0000000..de795f6 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/speed.h @@ -0,0 +1,10 @@ +/* + * Copyright 2014-2015, Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FSL_LAYERSCAPE_SPEED_H +#define _FSL_LAYERSCAPE_SPEED_H +void get_sys_info(struct sys_info *sys_info); +#endif /* _FSL_LAYERSCAPE_SPEED_H */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/config.h b/arch/arm/include/asm/arch-fsl-lsch3/config.h deleted file mode 100644 index 96d6c98..0000000 --- a/arch/arm/include/asm/arch-fsl-lsch3/config.h +++ /dev/null @@ -1,185 +0,0 @@ -/* - * Copyright 2014, Freescale Semiconductor - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _ASM_ARMV8_FSL_LSCH3_CONFIG_ -#define _ASM_ARMV8_FSL_LSCH3_CONFIG_ - -#include <fsl_ddrc_version.h> - -#define CONFIG_SYS_PAGE_SIZE 0x10000 -#define CONFIG_SYS_CACHELINE_SIZE 64 - -#ifndef L1_CACHE_BYTES -#define L1_CACHE_SHIFT 6 -#define L1_CACHE_BYTES (1 << L1_CACHE_SHIFT) -#endif - -#define CONFIG_MP -#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ -#define CONFIG_SYS_FSL_OCRAM_SIZE 0x00200000 /* 2M */ -/* Link Definitions */ -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) - -#define CONFIG_SYS_IMMR 0x01000000 -#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) -#define CONFIG_SYS_FSL_DDR2_ADDR (CONFIG_SYS_IMMR + 0x00090000) -#define CONFIG_SYS_FSL_DDR3_ADDR 0x08210000 -#define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00E00000) -#define CONFIG_SYS_FSL_PMU_ADDR (CONFIG_SYS_IMMR + 0x00E30000) -#define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00E60000) -#define CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR (CONFIG_SYS_IMMR + 0x00300000) -#define CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR (CONFIG_SYS_IMMR + 0x00310000) -#define CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR (CONFIG_SYS_IMMR + 0x00370000) -#define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x01140000) -#define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011C0600) -#define CONFIG_SYS_FSL_TIMER_ADDR 0x023d0000 -#define CONFIG_SYS_FSL_PMU_CLTBENR (CONFIG_SYS_FSL_PMU_ADDR + \ - 0x18A0) - -#define CONFIG_SYS_FSL_WRIOP1_ADDR (CONFIG_SYS_IMMR + 0x7B80000) -#define CONFIG_SYS_FSL_WRIOP1_MDIO1 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x16000) -#define CONFIG_SYS_FSL_WRIOP1_MDIO2 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x17000) -#define CONFIG_SYS_FSL_LSCH3_SERDES_ADDR (CONFIG_SYS_IMMR + 0xEA0000) - -/* SP (Cortex-A5) related */ -#define CONFIG_SYS_FSL_SP_ADDR (CONFIG_SYS_IMMR + 0x00F00000) -#define CONFIG_SYS_FSL_SP_VSG_GIC_ADDR (CONFIG_SYS_FSL_SP_ADDR) -#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR1 (CONFIG_SYS_FSL_SP_ADDR) -#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR2 \ - (CONFIG_SYS_FSL_SP_ADDR + 0x0008) -#define CONFIG_SYS_FSL_SP_LOOPBACK_DUART \ - (CONFIG_SYS_FSL_SP_ADDR + 0x1000) - -#define CONFIG_SYS_FSL_DCSR_DDR_ADDR 0x70012c000ULL -#define CONFIG_SYS_FSL_DCSR_DDR2_ADDR 0x70012d000ULL -#define CONFIG_SYS_FSL_DCSR_DDR3_ADDR 0x700132000ULL -#define CONFIG_SYS_FSL_DCSR_DDR4_ADDR 0x700133000ULL - -#define I2C1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01000000) -#define I2C2_BASE_ADDR (CONFIG_SYS_IMMR + 0x01010000) -#define I2C3_BASE_ADDR (CONFIG_SYS_IMMR + 0x01020000) -#define I2C4_BASE_ADDR (CONFIG_SYS_IMMR + 0x01030000) - -#define CONFIG_SYS_LS2085A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) -#define CONFIG_SYS_LS2085A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02110000) - -/* TZ Protection Controller Definitions */ -#define TZPC_BASE 0x02200000 -#define TZPCR0SIZE_BASE (TZPC_BASE) -#define TZPCDECPROT_0_STAT_BASE (TZPC_BASE + 0x800) -#define TZPCDECPROT_0_SET_BASE (TZPC_BASE + 0x804) -#define TZPCDECPROT_0_CLR_BASE (TZPC_BASE + 0x808) -#define TZPCDECPROT_1_STAT_BASE (TZPC_BASE + 0x80C) -#define TZPCDECPROT_1_SET_BASE (TZPC_BASE + 0x810) -#define TZPCDECPROT_1_CLR_BASE (TZPC_BASE + 0x814) -#define TZPCDECPROT_2_STAT_BASE (TZPC_BASE + 0x818) -#define TZPCDECPROT_2_SET_BASE (TZPC_BASE + 0x81C) -#define TZPCDECPROT_2_CLR_BASE (TZPC_BASE + 0x820) - -/* TZ Address Space Controller Definitions */ -#define TZASC1_BASE 0x01100000 /* as per CCSR map. */ -#define TZASC2_BASE 0x01110000 /* as per CCSR map. */ -#define TZASC3_BASE 0x01120000 /* as per CCSR map. */ -#define TZASC4_BASE 0x01130000 /* as per CCSR map. */ -#define TZASC_BUILD_CONFIG_REG(x) ((TZASC1_BASE + (x * 0x10000))) -#define TZASC_ACTION_REG(x) ((TZASC1_BASE + (x * 0x10000)) + 0x004) -#define TZASC_GATE_KEEPER(x) ((TZASC1_BASE + (x * 0x10000)) + 0x008) -#define TZASC_REGION_BASE_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x100) -#define TZASC_REGION_BASE_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x104) -#define TZASC_REGION_TOP_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x108) -#define TZASC_REGION_TOP_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x10C) -#define TZASC_REGION_ATTRIBUTES_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x110) -#define TZASC_REGION_ID_ACCESS_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x114) - -/* Generic Interrupt Controller Definitions */ -#define GICD_BASE 0x06000000 -#define GICR_BASE 0x06100000 - -/* SMMU Defintions */ -#define SMMU_BASE 0x05000000 /* GR0 Base */ - -/* DDR */ -#define CONFIG_SYS_FSL_DDR_LE -#define CONFIG_VERY_BIG_RAM -#ifdef CONFIG_SYS_FSL_DDR4 -#define CONFIG_SYS_FSL_DDRC_GEN4 -#else -#define CONFIG_SYS_FSL_DDRC_ARM_GEN3 /* Enable Freescale ARM DDR3 driver */ -#endif -#define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ -#define CONFIG_SYS_LS2_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) -#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_LS2_DDR_BLOCK1_SIZE -#define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 - -#define CONFIG_SYS_FSL_ESDHC_LE -/* IFC */ -#define CONFIG_SYS_FSL_IFC_LE -#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN - -/* PCIe */ -#define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) -#define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) -#define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) -#define CONFIG_SYS_PCIE4_ADDR (CONFIG_SYS_IMMR + 0x2700000) -#define CONFIG_SYS_PCIE1_PHYS_ADDR 0x1000000000ULL -#define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL -#define CONFIG_SYS_PCIE3_PHYS_ADDR 0x1400000000ULL -#define CONFIG_SYS_PCIE4_PHYS_ADDR 0x1600000000ULL - -/* Cache Coherent Interconnect */ -#define CCI_MN_BASE 0x04000000 -#define CCI_MN_RNF_NODEID_LIST 0x180 -#define CCI_MN_DVM_DOMAIN_CTL 0x200 -#define CCI_MN_DVM_DOMAIN_CTL_SET 0x210 - -#define CCI_RN_I_0_BASE (CCI_MN_BASE + 0x800000) -#define CCI_RN_I_2_BASE (CCI_MN_BASE + 0x820000) -#define CCI_RN_I_6_BASE (CCI_MN_BASE + 0x860000) -#define CCI_RN_I_12_BASE (CCI_MN_BASE + 0x8C0000) -#define CCI_RN_I_16_BASE (CCI_MN_BASE + 0x900000) -#define CCI_RN_I_20_BASE (CCI_MN_BASE + 0x940000) - -#define CCI_S0_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x10) -#define CCI_S1_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x110) -#define CCI_S2_QOS_CONTROL_BASE(x) ((CCI_RN_I_0_BASE + (x * 0x10000)) + 0x210) - -/* Device Configuration */ -#define DCFG_BASE 0x01e00000 -#define DCFG_PORSR1 0x000 -#define DCFG_PORSR1_RCW_SRC 0xff800000 -#define DCFG_PORSR1_RCW_SRC_NOR 0x12f00000 -#define DCFG_RCWSR13 0x130 -#define DCFG_RCWSR13_DSPI (0 << 8) - -#define DCFG_DCSR_BASE 0X700100000ULL -#define DCFG_DCSR_PORCR1 0x000 - -/* Supplemental Configuration */ -#define SCFG_BASE 0x01fc0000 -#define SCFG_USB3PRM1CR 0x000 - -#ifdef CONFIG_LS2085A -#define CONFIG_MAX_CPUS 16 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 -#define CONFIG_NUM_DDR_CONTROLLERS 3 -#define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4, 4 } -#define CONFIG_SYS_FSL_SRDS_1 -#define CONFIG_SYS_FSL_SRDS_2 -#else -#error SoC not defined -#endif - -#ifdef CONFIG_LS2085A -#define CONFIG_SYS_FSL_ERRATUM_A008336 -#define CONFIG_SYS_FSL_ERRATUM_A008511 -#define CONFIG_SYS_FSL_ERRATUM_A008514 -#define CONFIG_SYS_FSL_ERRATUM_A008585 -#define CONFIG_SYS_FSL_ERRATUM_A008751 -#endif - -#endif /* _ASM_ARMV8_FSL_LSCH3_CONFIG_ */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/gpio.h b/arch/arm/include/asm/arch-fsl-lsch3/gpio.h deleted file mode 100644 index f23a78c..0000000 --- a/arch/arm/include/asm/arch-fsl-lsch3/gpio.h +++ /dev/null @@ -1,9 +0,0 @@ -/* - * Copyright 2014, Freescale Semiconductor - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _ASM_ARMV8_FSL_LSCH3_GPIO_H_ -#define _ASM_ARMV8_FSL_LSCH3_GPIO_H_ -#endif /* _ASM_ARMV8_FSL_LSCH3_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-lsch3/imx-regs.h b/arch/arm/include/asm/arch-fsl-lsch3/imx-regs.h deleted file mode 100644 index 8f00535..0000000 --- a/arch/arm/include/asm/arch-fsl-lsch3/imx-regs.h +++ /dev/null @@ -1,13 +0,0 @@ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - * - */ - -#ifndef __ASM_ARCH_FSL_LSCH3_IMX_REGS_H_ -#define __ASM_ARCH_FSL_LSCH3_IMX_REGS_H_ - -#define I2C_QUIRK_REG /* enable 8-bit driver */ - -#endif /* __ASM_ARCH_FSL_LSCH3_IMX_REGS_H_ */ diff --git a/arch/arm/include/asm/config.h b/arch/arm/include/asm/config.h index 22fff02..435fc45 100644 --- a/arch/arm/include/asm/config.h +++ b/arch/arm/include/asm/config.h @@ -15,14 +15,11 @@ #define CONFIG_STATIC_RELA #endif
-#ifdef CONFIG_FSL_LSCH3 -#include <asm/arch-fsl-lsch3/config.h> -#endif - #if defined(CONFIG_LS102XA) || \ defined(CONFIG_CPU_PXA27X) || \ defined(CONFIG_CPU_MONAHANS) || \ - defined(CONFIG_CPU_PXA25X) + defined(CONFIG_CPU_PXA25X) || \ + defined(CONFIG_FSL_LAYERSCAPE) #include <asm/arch/config.h> #endif
diff --git a/board/freescale/ls2085a/Kconfig b/board/freescale/ls2085a/Kconfig index f51afc8..042f85b 100644 --- a/board/freescale/ls2085a/Kconfig +++ b/board/freescale/ls2085a/Kconfig @@ -7,7 +7,7 @@ config SYS_VENDOR default "freescale"
config SYS_SOC - default "fsl-lsch3" + default "fsl-layerscape"
config SYS_CONFIG_NAME default "ls2085a_emu" @@ -23,7 +23,7 @@ config SYS_VENDOR default "freescale"
config SYS_CONFIG_NAME default "ls2085a_simu" diff --git a/board/freescale/ls2085a/ls2085a.c b/board/freescale/ls2085a/ls2085a.c index 73c4410..27481e2 100644 --- a/board/freescale/ls2085a/ls2085a.c +++ b/board/freescale/ls2085a/ls2085a.c @@ -15,7 +15,7 @@ #include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> #include <environment.h> -#include <asm/arch-fsl-lsch3/soc.h> +#include <asm/arch/soc.h>
diff --git a/board/freescale/ls2085aqds/Kconfig b/board/freescale/ls2085aqds/Kconfig index deb640d..8d6acba 100644 --- a/board/freescale/ls2085aqds/Kconfig +++ b/board/freescale/ls2085aqds/Kconfig @@ -8,7 +8,7 @@ config SYS_VENDOR default "freescale"
config SYS_CONFIG_NAME default "ls2085aqds" diff --git a/board/freescale/ls2085aqds/eth.c b/board/freescale/ls2085aqds/eth.c index 007b433..b8a2bf4 100644 --- a/board/freescale/ls2085aqds/eth.c +++ b/board/freescale/ls2085aqds/eth.c @@ -8,7 +8,6 @@ #include <netdev.h> #include <asm/io.h> #include <asm/arch/fsl_serdes.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> #include <hwconfig.h> #include <fsl_mdio.h> #include <malloc.h> diff --git a/board/freescale/ls2085aqds/ls2085aqds.c b/board/freescale/ls2085aqds/ls2085aqds.c index 2315bdb..b02d6e8 100644 --- a/board/freescale/ls2085aqds/ls2085aqds.c +++ b/board/freescale/ls2085aqds/ls2085aqds.c @@ -17,7 +17,7 @@ #include <environment.h> #include <i2c.h> #include <rtc.h> -#include <asm/arch-fsl-lsch3/soc.h> +#include <asm/arch/soc.h> #include <hwconfig.h>
#include "../common/qixis.h" diff --git a/board/freescale/ls2085ardb/Kconfig b/board/freescale/ls2085ardb/Kconfig index 85a3dcd..cb40db9 100644 --- a/board/freescale/ls2085ardb/Kconfig +++ b/board/freescale/ls2085ardb/Kconfig @@ -8,7 +8,7 @@ config SYS_VENDOR default "freescale"
config SYS_CONFIG_NAME default "ls2085ardb" diff --git a/board/freescale/ls2085ardb/eth_ls2085rdb.c b/board/freescale/ls2085ardb/eth_ls2085rdb.c index 0a1163a..d578757 100644 --- a/board/freescale/ls2085ardb/eth_ls2085rdb.c +++ b/board/freescale/ls2085ardb/eth_ls2085rdb.c @@ -16,7 +16,6 @@ #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> #include <fsl-mc/ldpaa_wriop.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/freescale/ls2085ardb/ls2085ardb.c b/board/freescale/ls2085ardb/ls2085ardb.c index 5e7997c..18953b8 100644 --- a/board/freescale/ls2085ardb/ls2085ardb.c +++ b/board/freescale/ls2085ardb/ls2085ardb.c @@ -17,7 +17,7 @@ #include <fsl-mc/fsl_mc.h> #include <environment.h> #include <i2c.h> -#include <asm/arch-fsl-lsch3/soc.h> +#include <asm/arch/soc.h>
#include "../common/qixis.h" #include "ls2085ardb_qixis.h" diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 0f977d7..fa4c82f 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -523,8 +523,8 @@ static int bus_i2c_write(struct mxc_i2c_bus *i2c_bus, u8 chip, u32 addr, #endif
static struct mxc_i2c_bus mxc_i2c_buses[] = { -#if defined(CONFIG_LS102XA) || defined(CONFIG_FSL_LSCH3) || \ - defined(CONFIG_VF610) +#if defined(CONFIG_LS102XA) || defined(CONFIG_VF610) || \ + defined(CONFIG_FSL_LAYERSCAPE) { 0, I2C1_BASE_ADDR, I2C_QUIRK_FLAG }, { 1, I2C2_BASE_ADDR, I2C_QUIRK_FLAG }, { 2, I2C3_BASE_ADDR, I2C_QUIRK_FLAG }, diff --git a/drivers/misc/fsl_debug_server.c b/drivers/misc/fsl_debug_server.c index a592891..98d9fbe 100644 --- a/drivers/misc/fsl_debug_server.c +++ b/drivers/misc/fsl_debug_server.c @@ -8,7 +8,6 @@ #include <errno.h> #include <asm/io.h> #include <asm/system.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h>
#include <fsl-mc/fsl_mc.h> #include <fsl_debug_server.h> diff --git a/drivers/net/ldpaa_eth/ls2085a.c b/drivers/net/ldpaa_eth/ls2085a.c index 6b7960a..93ed4f1 100644 --- a/drivers/net/ldpaa_eth/ls2085a.c +++ b/drivers/net/ldpaa_eth/ls2085a.c @@ -7,9 +7,7 @@ #include <phy.h> #include <fsl-mc/ldpaa_wriop.h> #include <asm/io.h> -#include <asm/arch-fsl-lsch3/immap_lsch3.h> #include <asm/arch/fsl_serdes.h> -#include <fsl-mc/ldpaa_wriop.h>
u32 dpmac_to_devdisr[] = { [WRIOP1_DPMAC1] = FSL_CHASSIS3_DEVDISR2_DPMAC1, diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 2f24a6a..4cee038 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -11,7 +11,9 @@ #include <asm/io.h> #include <errno.h> #include <malloc.h> -#include <asm/arch-fsl-lsch3/fdt.h> +#ifdef CONFIG_FSL_LAYERSCAPE +#include <asm/arch/fdt.h> +#endif
#ifndef CONFIG_SYS_PCI_MEMORY_BUS #define CONFIG_SYS_PCI_MEMORY_BUS CONFIG_SYS_SDRAM_BASE diff --git a/include/common.h b/include/common.h index ecb1f06..142936b 100644 --- a/include/common.h +++ b/include/common.h @@ -76,6 +76,9 @@ typedef volatile unsigned char vu_char; #ifdef CONFIG_SOC_DA8XX #include <asm/arch/hardware.h> #endif +#ifdef CONFIG_FSL_LSCH3 +#include <asm/arch/immap_lsch3.h> +#endif
#include <part.h> #include <flash.h> diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 55b909c..9f02af0 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -10,8 +10,10 @@ #define CONFIG_SYS_GENERIC_BOARD
#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH3 #define CONFIG_LS2085A +#define CONFIG_MP #define CONFIG_GICV3 #define CONFIG_FSL_TZPC_BP147
@@ -19,12 +21,15 @@ #define CONFIG_ARM_ERRATA_828024 #define CONFIG_ARM_ERRATA_826974
-#include <asm/arch-fsl-lsch3/ls2085a_stream_id.h> -#include <asm/arch-fsl-lsch3/config.h> +#include <asm/arch/ls2085a_stream_id.h> +#include <asm/arch/config.h> #if (defined(CONFIG_SYS_FSL_SRDS_1) || defined(CONFIG_SYS_FSL_SRDS_2)) #define CONFIG_SYS_HAS_SERDES #endif
+/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + /* We need architecture specific misc initializations */ #define CONFIG_ARCH_MISC_INIT
@@ -62,6 +67,7 @@
#define CONFIG_SYS_FSL_DDR_INTLV_256B /* force 256 byte interleaving */
+#define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE
Freescale LayerScape with Chassis Generation 2 is a set of SoCs with ARMv8 cores and 2rd generation of Chassis.
Signed-off-by: Li Yang leoli@freescale.com Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - Remove GIC SMMU macros back to config.h. V5: - Move LS1043A ddr macros out of soc #ifdef. - Move macros and structs from cpu.c to cpu.h. - Wrap le32 and be32 functions for ccsr gur and scfg. Defined in soc.h - Modify fsl-layerscape/Makefile. V4: - Add fsl_lsch2 to fsl-layerscape framework. V3: - Update MMU table initialization to match the latest code. - Remove some dead code - Rename #include<asm/arch-fsl-lsch2/xxx> to #include<asm/arch/xxx> V2: - remove FSL_LS102xA_DEVDISR3_PCIE from immap_lsch2.h
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 5 + arch/arm/cpu/armv8/fsl-layerscape/README.lsch2 | 10 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 13 + .../cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c | 117 +++++ .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 137 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 17 + arch/arm/include/asm/arch-fsl-layerscape/config.h | 47 ++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 64 +++ .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 91 ++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 555 +++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/ns_access.h | 158 ++++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 6 + arch/arm/include/asm/armv8/mmu.h | 1 + include/common.h | 3 + 14 files changed, 1224 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index ccb3aa5..4754e59 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -14,6 +14,11 @@ obj-$(CONFIG_SPL) += spl.o ifneq ($(CONFIG_FSL_LSCH3),) obj-y += fsl_lsch3_speed.o obj-$(CONFIG_SYS_HAS_SERDES) += fsl_lsch3_serdes.o +else +ifneq ($(CONFIG_FSL_LSCH2),) +obj-y += fsl_lsch2_speed.o +obj-$(CONFIG_SYS_HAS_SERDES) += fsl_lsch2_serdes.o +endif endif
ifneq ($(CONFIG_LS2085A),) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/README.lsch2 b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch2 new file mode 100644 index 0000000..a6ef830 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/README.lsch2 @@ -0,0 +1,10 @@ +# +# Copyright 2015 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +Freescale LayerScape with Chassis Generation 2 + +This architecture supports Freescale ARMv8 SoCs with Chassis generation 2, +for example LS1043A. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index be7442d..fe9d982 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -180,6 +180,8 @@ static inline void early_mmu_setup(void) set_pgtable_table(level1_table0, CONFIG_SYS_FLASH_BASE >> SECTION_SHIFT_L1, level2_table1); +#elif defined(CONFIG_FSL_LSCH2) + set_pgtable_table(level1_table0, 1, level2_table1); #endif /* Find the table and fill in the block entries */ for (i = 0; i < ARRAY_SIZE(early_mmu_table); i++) { @@ -215,6 +217,9 @@ static inline void early_mmu_setup(void) * * For LSCH3: * Level 2 table 1 contains 512 entries for each 2MB from 32GB to 33GB. + * For LSCH2: + * Level 2 table 1 contains 512 entries for each 2MB from 1GB to 2GB. + * Level 2 table 2 contains 512 entries for each 2MB from 20GB to 21GB. */ static inline void final_mmu_setup(void) { @@ -225,6 +230,9 @@ static inline void final_mmu_setup(void) u64 *level2_table0 = (u64 *)(gd->arch.tlb_addr + 0x3000); #ifdef CONFIG_FSL_LSCH3 u64 *level2_table1 = (u64 *)(gd->arch.tlb_addr + 0x4000); +#elif defined(CONFIG_FSL_LSCH2) + u64 *level2_table1 = (u64 *)(gd->arch.tlb_addr + 0x4000); + u64 *level2_table2 = (u64 *)(gd->arch.tlb_addr + 0x5000); #endif struct table_info table = {level0_table, 0, BLOCK_SIZE_L0};
@@ -239,6 +247,11 @@ static inline void final_mmu_setup(void) set_pgtable_table(level1_table0, CONFIG_SYS_FSL_QBMAN_BASE >> SECTION_SHIFT_L1, level2_table1); +#elif defined(CONFIG_FSL_LSCH2) + set_pgtable_table(level1_table0, 1, level2_table1); + set_pgtable_table(level1_table0, + CONFIG_SYS_FSL_QBMAN_BASE >> SECTION_SHIFT_L1, + level2_table2); #endif
/* Find the table and fill in the block entries */ diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c new file mode 100644 index 0000000..f7178d1 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_serdes.c @@ -0,0 +1,117 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> + +#ifdef CONFIG_SYS_FSL_SRDS_1 +static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; +#endif + +int is_serdes_configured(enum srds_prtcl device) +{ + int ret = 0; + +#ifdef CONFIG_SYS_FSL_SRDS_1 + ret |= serdes1_prtcl_map[device]; +#endif + + return !!ret; +} + +int serdes_get_first_lane(u32 sd, enum srds_prtcl device) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 cfg = gur_in32(&gur->rcwsr[4]); + int i; + + switch (sd) { +#ifdef CONFIG_SYS_FSL_SRDS_1 + case FSL_SRDS_1: + cfg &= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + break; +#endif + default: + printf("invalid SerDes%d\n", sd); + break; + } + + /* Is serdes enabled at all? */ + if (unlikely(cfg == 0)) + return -ENODEV; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (serdes_get_prtcl(sd, cfg, i) == device) + return i; + } + + return -ENODEV; +} + +int get_serdes_protocol(void) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 cfg = gur_in32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + cfg >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + return cfg; +} + +const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + default: + return "100"; + } +} + +void serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift, + u8 serdes_prtcl_map[SERDES_PRCTL_COUNT]) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 cfg; + int lane; + + memset(serdes_prtcl_map, 0, sizeof(serdes_prtcl_map)); + + cfg = gur_in32(&gur->rcwsr[4]) & sd_prctl_mask; + cfg >>= sd_prctl_shift; + printf("Using SERDES%d Protocol: %d (0x%x)\n", sd + 1, cfg, cfg); + + if (!is_serdes_prtcl_valid(sd, cfg)) + printf("SERDES%d[PRTCL] = 0x%x is not valid\n", sd + 1, cfg); + + for (lane = 0; lane < SRDS_MAX_LANES; lane++) { + enum srds_prtcl lane_prtcl = serdes_get_prtcl(sd, cfg, lane); + + if (unlikely(lane_prtcl >= SERDES_PRCTL_COUNT)) + debug("Unknown SerDes lane protocol %d\n", lane_prtcl); + else + serdes_prtcl_map[lane_prtcl] = 1; + } +} + +void fsl_serdes_init(void) +{ +#ifdef CONFIG_SYS_FSL_SRDS_1 + serdes_init(FSL_SRDS_1, + CONFIG_SYS_FSL_SERDES_ADDR, + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK, + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT, + serdes1_prtcl_map); +#endif +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c new file mode 100644 index 0000000..ea3723f --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -0,0 +1,137 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/compiler.h> +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/arch/clock.h> +#include <asm/arch/soc.h> +#include <fsl_ifc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_SYS_FSL_NUM_CC_PLLS +#define CONFIG_SYS_FSL_NUM_CC_PLLS 2 +#endif + +void get_sys_info(struct sys_info *sys_info) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); +#ifdef CONFIG_FSL_IFC + struct fsl_ifc ifc_regs = {(void *)CONFIG_SYS_IFC_ADDR, (void *)NULL}; + u32 ccr; +#endif + struct ccsr_clk *clk = (void *)(CONFIG_SYS_FSL_CLK_ADDR); + unsigned int cpu; + const u8 core_cplx_pll[8] = { + [0] = 0, /* CC1 PPL / 1 */ + [1] = 0, /* CC1 PPL / 2 */ + [4] = 1, /* CC2 PPL / 1 */ + [5] = 1, /* CC2 PPL / 2 */ + }; + + const u8 core_cplx_pll_div[8] = { + [0] = 1, /* CC1 PPL / 1 */ + [1] = 2, /* CC1 PPL / 2 */ + [4] = 1, /* CC2 PPL / 1 */ + [5] = 2, /* CC2 PPL / 2 */ + }; + + uint i; + uint freq_c_pll[CONFIG_SYS_FSL_NUM_CC_PLLS]; + uint ratio[CONFIG_SYS_FSL_NUM_CC_PLLS]; + unsigned long sysclk = CONFIG_SYS_CLK_FREQ; + + sys_info->freq_systembus = sysclk; +#ifdef CONFIG_DDR_CLK_FREQ + sys_info->freq_ddrbus = CONFIG_DDR_CLK_FREQ; +#else + sys_info->freq_ddrbus = sysclk; +#endif + + sys_info->freq_systembus *= (gur_in32(&gur->rcwsr[0]) >> + FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT) & + FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK; + sys_info->freq_ddrbus *= (gur_in32(&gur->rcwsr[0]) >> + FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_SHIFT) & + FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK; + + for (i = 0; i < CONFIG_SYS_FSL_NUM_CC_PLLS; i++) { + ratio[i] = (in_be32(&clk->pllcgsr[i].pllcngsr) >> 1) & 0xff; + if (ratio[i] > 4) + freq_c_pll[i] = sysclk * ratio[i]; + else + freq_c_pll[i] = sys_info->freq_systembus * ratio[i]; + } + + for (cpu = 0; cpu < CONFIG_MAX_CPUS; cpu++) { + u32 c_pll_sel = (in_be32(&clk->clkcsr[cpu].clkcncsr) >> 27) + & 0xf; + u32 cplx_pll = core_cplx_pll[c_pll_sel]; + + sys_info->freq_processor[cpu] = + freq_c_pll[cplx_pll] / core_cplx_pll_div[c_pll_sel]; + } + +#define HWA_CGA_M1_CLK_SEL 0xe0000000 +#define HWA_CGA_M1_CLK_SHIFT 29 + +#define HWA_CGA_M2_CLK_SEL 0x00000007 +#define HWA_CGA_M2_CLK_SHIFT 0 + +#if defined(CONFIG_FSL_IFC) + ccr = ifc_in32(&ifc_regs.gregs->ifc_ccr); + ccr = ((ccr & IFC_CCR_CLK_DIV_MASK) >> IFC_CCR_CLK_DIV_SHIFT) + 1; + + sys_info->freq_localbus = sys_info->freq_systembus / ccr; +#endif +} + +int get_clocks(void) +{ + struct sys_info sys_info; + + get_sys_info(&sys_info); + gd->cpu_clk = sys_info.freq_processor[0]; + gd->bus_clk = sys_info.freq_systembus; + gd->mem_clk = sys_info.freq_ddrbus; + + if (gd->cpu_clk != 0) + return 0; + else + return 1; +} + +ulong get_bus_freq(ulong dummy) +{ + return gd->bus_clk; +} + +ulong get_ddr_freq(ulong dummy) +{ + return gd->mem_clk; +} + +int get_serial_clock(void) +{ + return gd->bus_clk; +} + +unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_I2C_CLK: + return get_bus_freq(0); + case MXC_DSPI_CLK: + return get_bus_freq(0); + case MXC_UART_CLK: + return get_bus_freq(0); + default: + printf("Unsupported clock\n"); + } + return 0; +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 73e48a7..637853d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -76,6 +76,23 @@ void fsl_lsch3_early_init_f(void) init_early_memctl_regs(); /* tighten IFC timing */ erratum_a009203(); } + +#elif defined(CONFIG_LS1043A) +void fsl_lsch2_early_init_f(void) +{ + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + +#ifdef CONFIG_FSL_IFC + init_early_memctl_regs(); /* tighten IFC timing */ +#endif + + /* + * Enable snoop requests and DVM message requests for + * Slave insterface S4 (A53 core cluster) + */ + out_le32(&cci->slave[4].snoop_ctrl, + CCI400_DVM_MESSAGE_REQ_EN | CCI400_SNOOP_REQ_EN); +} #endif
#ifdef CONFIG_BOARD_LATE_INIT diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index dd7203f..87bb937 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -89,6 +89,53 @@ #define CONFIG_SYS_FSL_ERRATUM_A008514 #define CONFIG_SYS_FSL_ERRATUM_A008585 #define CONFIG_SYS_FSL_ERRATUM_A008751 +#elif defined(CONFIG_LS1043A) +#define CONFIG_MAX_CPUS 4 +#define CONFIG_SYS_CACHELINE_SIZE 64 +#define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_NUM_FMAN 1 +#define CONFIG_SYS_NUM_FM1_DTSEC 7 +#define CONFIG_SYS_NUM_FM1_10GEC 1 +#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_SYS_CCSRBAR_DEFAULT 0x01000000 +#define CONFIG_SYS_FSL_SEC_COMPAT 5 +#define CONFIG_SYS_FSL_OCRAM_BASE 0x10000000 /* initial RAM */ +#define CONFIG_SYS_FSL_OCRAM_SIZE 0x200000 /* 2 MiB */ +#define CONFIG_SYS_FSL_DDR_BE +#define CONFIG_SYS_LS1_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) +#define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_LS1_DDR_BLOCK1_SIZE + +#define CONFIG_SYS_FSL_CCSR_GUR_BE +#define CONFIG_SYS_FSL_CCSR_SCFG_BE +#define CONFIG_SYS_FSL_IFC_BE +#define CONFIG_SYS_FSL_ESDHC_BE +#define CONFIG_SYS_FSL_WDOG_BE +#define CONFIG_SYS_FSL_DSPI_BE +#define CONFIG_SYS_FSL_QSPI_BE + +#define QE_MURAM_SIZE 0x6000UL +#define MAX_QE_RISC 1 +#define QE_NUM_OF_SNUM 28 + +#define SRDS_MAX_LANES 4 +#define CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" + +#define CONFIG_SYS_FSL_SFP_VER_3_2 +#define CONFIG_SYS_FSL_SNVS_LE +#define CONFIG_SYS_FSL_SEC_LE +#define CONFIG_SYS_FSL_SFP_BE +#define CONFIG_SYS_FSL_SRK_LE +#define CONFIG_KEY_REVOCATION + +/* SMMU Defintions */ +#define SMMU_BASE 0x09000000 + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0x01401000 +#define GICC_BASE 0x01402000 + #else #error SoC not defined #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index b7b8e5d..2903996 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -11,6 +11,7 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS2085, LS2085, 8), CPU_TYPE_ENTRY(LS2080, LS2080, 8), CPU_TYPE_ENTRY(LS2045, LS2045, 4), + CPU_TYPE_ENTRY(LS1043, LS1043, 4), };
#ifndef CONFIG_SYS_DCACHE_OFF @@ -73,6 +74,28 @@ static struct cpu_type cpu_type_list[] = { #define CONFIG_SYS_FSL_PEBUF_SIZE 0x400000000 #define CONFIG_SYS_FSL_DRAM_BASE2 0x8080000000 #define CONFIG_SYS_FSL_DRAM_SIZE2 0x7F80000000 +#elif defined(CONFIG_FSL_LSCH2) +#define CONFIG_SYS_FSL_BOOTROM_BASE 0x0 +#define CONFIG_SYS_FSL_BOOTROM_SIZE 0x1000000 +#define CONFIG_SYS_FSL_CCSR_BASE 0x1000000 +#define CONFIG_SYS_FSL_CCSR_SIZE 0xf000000 +#define CONFIG_SYS_FSL_DCSR_BASE 0x20000000 +#define CONFIG_SYS_FSL_DCSR_SIZE 0x4000000 +#define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 +#define CONFIG_SYS_FSL_QSPI_SIZE 0x20000000 +#define CONFIG_SYS_FSL_IFC_BASE 0x60000000 +#define CONFIG_SYS_FSL_IFC_SIZE 0x20000000 +#define CONFIG_SYS_FSL_DRAM_BASE1 0x80000000 +#define CONFIG_SYS_FSL_DRAM_SIZE1 0x80000000 +#define CONFIG_SYS_FSL_QBMAN_BASE 0x500000000 +#define CONFIG_SYS_FSL_QBMAN_SIZE 0x10000000 +#define CONFIG_SYS_FSL_DRAM_BASE2 0x880000000 +#define CONFIG_SYS_FSL_DRAM_SIZE2 0x780000000 /* 30GB */ +#define CONFIG_SYS_PCIE1_PHYS_SIZE 0x800000000 +#define CONFIG_SYS_PCIE2_PHYS_SIZE 0x800000000 +#define CONFIG_SYS_PCIE3_PHYS_SIZE 0x800000000 +#define CONFIG_SYS_FSL_DRAM_BASE3 0x8800000000 +#define CONFIG_SYS_FSL_DRAM_SIZE3 0x7800000000 /* 480GB */ #endif
struct sys_mmu_table { @@ -110,6 +133,19 @@ static const struct sys_mmu_table early_mmu_table[] = { CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, +#elif defined(CONFIG_FSL_LSCH2) + { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, + CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, + CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, + CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_BASE, + CONFIG_SYS_FSL_IFC_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, + CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, + CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, #endif };
@@ -156,6 +192,34 @@ static const struct sys_mmu_table final_mmu_table[] = { CONFIG_SYS_FSL_PEBUF_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, +#elif defined(CONFIG_FSL_LSCH2) + { CONFIG_SYS_FSL_BOOTROM_BASE, CONFIG_SYS_FSL_BOOTROM_BASE, + CONFIG_SYS_FSL_BOOTROM_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_CCSR_BASE, CONFIG_SYS_FSL_CCSR_BASE, + CONFIG_SYS_FSL_CCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_OCRAM_BASE, CONFIG_SYS_FSL_OCRAM_BASE, + CONFIG_SYS_FSL_OCRAM_SIZE, MT_NORMAL, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, + CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_QSPI_BASE, CONFIG_SYS_FSL_QSPI_BASE, + CONFIG_SYS_FSL_QSPI_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_IFC_BASE, CONFIG_SYS_FSL_IFC_BASE, + CONFIG_SYS_FSL_IFC_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, + CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, + PMD_SECT_OUTER_SHARE | PMD_SECT_NS }, + { CONFIG_SYS_FSL_QBMAN_BASE, CONFIG_SYS_FSL_QBMAN_BASE, + CONFIG_SYS_FSL_QBMAN_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE2, CONFIG_SYS_FSL_DRAM_BASE2, + CONFIG_SYS_FSL_DRAM_SIZE2, MT_NORMAL, PMD_SECT_OUTER_SHARE }, + { CONFIG_SYS_PCIE1_PHYS_ADDR, CONFIG_SYS_PCIE1_PHYS_ADDR, + CONFIG_SYS_PCIE1_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_PCIE2_PHYS_ADDR, CONFIG_SYS_PCIE2_PHYS_ADDR, + CONFIG_SYS_PCIE2_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_PCIE3_PHYS_ADDR, CONFIG_SYS_PCIE3_PHYS_ADDR, + CONFIG_SYS_PCIE3_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, + { CONFIG_SYS_FSL_DRAM_BASE3, CONFIG_SYS_FSL_DRAM_BASE3, + CONFIG_SYS_FSL_DRAM_SIZE3, MT_NORMAL, PMD_SECT_OUTER_SHARE }, #endif }; #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 730c2b2..e1043b5 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -55,6 +55,92 @@ enum srds { FSL_SRDS_1 = 0, FSL_SRDS_2 = 1, }; +#elif defined(CONFIG_LS1043A) +enum srds_prtcl { + NONE = 0, + PCIE1, + PCIE2, + PCIE3, + PCIE4, + SATA1, + SATA2, + SRIO1, + SRIO2, + SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, + SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6, + SGMII_FM1_DTSEC9, + SGMII_FM1_DTSEC10, + SGMII_FM2_DTSEC1, + SGMII_FM2_DTSEC2, + SGMII_FM2_DTSEC3, + SGMII_FM2_DTSEC4, + SGMII_FM2_DTSEC5, + SGMII_FM2_DTSEC6, + SGMII_FM2_DTSEC9, + SGMII_FM2_DTSEC10, + SGMII_TSEC1, + SGMII_TSEC2, + SGMII_TSEC3, + SGMII_TSEC4, + XAUI_FM1, + XAUI_FM2, + AURORA, + CPRI1, + CPRI2, + CPRI3, + CPRI4, + CPRI5, + CPRI6, + CPRI7, + CPRI8, + XAUI_FM1_MAC9, + XAUI_FM1_MAC10, + XAUI_FM2_MAC9, + XAUI_FM2_MAC10, + HIGIG_FM1_MAC9, + HIGIG_FM1_MAC10, + HIGIG_FM2_MAC9, + HIGIG_FM2_MAC10, + QSGMII_FM1_A, /* A indicates MACs 1,2,5,6 */ + QSGMII_FM1_B, /* B indicates MACs 5,6,9,10 */ + QSGMII_FM2_A, + QSGMII_FM2_B, + XFI_FM1_MAC1, + XFI_FM1_MAC2, + XFI_FM1_MAC9, + XFI_FM1_MAC10, + XFI_FM2_MAC9, + XFI_FM2_MAC10, + INTERLAKEN, + QSGMII_SW1_A, /* Indicates ports on L2 Switch */ + QSGMII_SW1_B, + SGMII_2500_FM1_DTSEC1, + SGMII_2500_FM1_DTSEC2, + SGMII_2500_FM1_DTSEC3, + SGMII_2500_FM1_DTSEC4, + SGMII_2500_FM1_DTSEC5, + SGMII_2500_FM1_DTSEC6, + SGMII_2500_FM1_DTSEC9, + SGMII_2500_FM1_DTSEC10, + SGMII_2500_FM2_DTSEC1, + SGMII_2500_FM2_DTSEC2, + SGMII_2500_FM2_DTSEC3, + SGMII_2500_FM2_DTSEC4, + SGMII_2500_FM2_DTSEC5, + SGMII_2500_FM2_DTSEC6, + SGMII_2500_FM2_DTSEC9, + SGMII_2500_FM2_DTSEC10, + SERDES_PRCTL_COUNT +}; + +enum srds { + FSL_SRDS_1 = 0, +}; + #endif
int is_serdes_configured(enum srds_prtcl device); @@ -63,4 +149,9 @@ int serdes_get_first_lane(u32 sd, enum srds_prtcl device); enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane); int is_serdes_prtcl_valid(int serdes, u32 prtcl);
+#ifdef CONFIG_LS1043A +const char *serdes_clock_to_string(u32 clock); +int get_serdes_protocol(void); +#endif + #endif /* __FSL_SERDES_H__ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h new file mode 100644 index 0000000..d941437 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -0,0 +1,555 @@ +/* + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_FSL_LSCH2_IMMAP_H__ +#define __ARCH_FSL_LSCH2_IMMAP_H__ + +#include <fsl_immap.h> + +#define CONFIG_SYS_IMMR 0x01000000 +#define CONFIG_SYS_DCSRBAR 0x20000000 +#define CONFIG_SYS_DCSR_DCFG_ADDR (CONFIG_SYS_DCSRBAR + 0x00220000) + +#define CONFIG_SYS_FSL_DDR_ADDR (CONFIG_SYS_IMMR + 0x00080000) +#define CONFIG_SYS_CCI400_ADDR (CONFIG_SYS_IMMR + 0x00180000) +#define CONFIG_SYS_GIC400_ADDR (CONFIG_SYS_IMMR + 0x00400000) +#define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x00530000) +#define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x00560000) +#define CONFIG_SYS_FSL_CSU_ADDR (CONFIG_SYS_IMMR + 0x00510000) +#define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) +#define CONFIG_SYS_FSL_RST_ADDR (CONFIG_SYS_IMMR + 0x00ee00b0) +#define CONFIG_SYS_FSL_SCFG_ADDR (CONFIG_SYS_IMMR + 0x00570000) +#define CONFIG_SYS_FSL_FMAN_ADDR (CONFIG_SYS_IMMR + 0x00a00000) +#define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) +#define CONFIG_SYS_FSL_DCFG_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) +#define CONFIG_SYS_FSL_CLK_ADDR (CONFIG_SYS_IMMR + 0x00ee1000) +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011c0500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011c0600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_IMMR + 0x011d0500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_IMMR + 0x011d0600) +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) +#define CONFIG_SYS_FSL_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) +#define CONFIG_SYS_FSL_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) +#define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) +#define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) +#define CONFIG_SYS_FSL_SEC_ADDR (CONFIG_SYS_IMMR + 0x700000) +#define CONFIG_SYS_FSL_JR0_ADDR (CONFIG_SYS_IMMR + 0x710000) +#define CONFIG_SYS_SNVS_ADDR (CONFIG_SYS_IMMR + 0xe90000) +#define CONFIG_SYS_SFP_ADDR (CONFIG_SYS_IMMR + 0xe80200) + +#define CONFIG_SYS_FSL_TIMER_ADDR 0x02b00000 + +#define I2C1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01180000) +#define I2C2_BASE_ADDR (CONFIG_SYS_IMMR + 0x01190000) +#define I2C3_BASE_ADDR (CONFIG_SYS_IMMR + 0x011a0000) +#define I2C4_BASE_ADDR (CONFIG_SYS_IMMR + 0x011b0000) + +#define WDOG1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01ad0000) + +#define QSPI0_BASE_ADDR (CONFIG_SYS_IMMR + 0x00550000) +#define DSPI1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01100000) + +#define LPUART_BASE (CONFIG_SYS_IMMR + 0x01950000) + +#define AHCI_BASE_ADDR (CONFIG_SYS_IMMR + 0x02200000) + +#define CONFIG_SYS_PCIE1_PHYS_ADDR 0x4000000000ULL +#define CONFIG_SYS_PCIE2_PHYS_ADDR 0x4800000000ULL +#define CONFIG_SYS_PCIE3_PHYS_ADDR 0x5000000000ULL + +/* TZ Address Space Controller Definitions */ +#define TZASC1_BASE 0x01100000 /* as per CCSR map. */ +#define TZASC2_BASE 0x01110000 /* as per CCSR map. */ +#define TZASC3_BASE 0x01120000 /* as per CCSR map. */ +#define TZASC4_BASE 0x01130000 /* as per CCSR map. */ +#define TZASC_BUILD_CONFIG_REG(x) ((TZASC1_BASE + (x * 0x10000))) +#define TZASC_ACTION_REG(x) ((TZASC1_BASE + (x * 0x10000)) + 0x004) +#define TZASC_GATE_KEEPER(x) ((TZASC1_BASE + (x * 0x10000)) + 0x008) +#define TZASC_REGION_BASE_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x100) +#define TZASC_REGION_BASE_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x104) +#define TZASC_REGION_TOP_LOW_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x108) +#define TZASC_REGION_TOP_HIGH_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x10C) +#define TZASC_REGION_ATTRIBUTES_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x110) +#define TZASC_REGION_ID_ACCESS_0(x) ((TZASC1_BASE + (x * 0x10000)) + 0x114) + +#define TP_ITYP_AV 0x00000001 /* Initiator available */ +#define TP_ITYP_TYPE(x) (((x) & 0x6) >> 1) /* Initiator Type */ +#define TP_ITYP_TYPE_ARM 0x0 +#define TP_ITYP_TYPE_PPC 0x1 /* PowerPC */ +#define TP_ITYP_TYPE_OTHER 0x2 /* StarCore DSP */ +#define TP_ITYP_TYPE_HA 0x3 /* HW Accelerator */ +#define TP_ITYP_THDS(x) (((x) & 0x18) >> 3) /* # threads */ +#define TP_ITYP_VER(x) (((x) & 0xe0) >> 5) /* Initiator Version */ +#define TY_ITYP_VER_A7 0x1 +#define TY_ITYP_VER_A53 0x2 +#define TY_ITYP_VER_A57 0x3 + +#define TP_CLUSTER_EOC 0xc0000000 /* end of clusters */ +#define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ +#define TP_INIT_PER_CLUSTER 4 + +/* + * Define default values for some CCSR macros to make header files cleaner* + * + * To completely disable CCSR relocation in a board header file, define + * CONFIG_SYS_CCSR_DO_NOT_RELOCATE. This will force CONFIG_SYS_CCSRBAR_PHYS + * to a value that is the same as CONFIG_SYS_CCSRBAR. + */ + +#ifdef CONFIG_SYS_CCSRBAR_PHYS +#error "Do not define CONFIG_SYS_CCSRBAR_PHYS directly. Use \ +CONFIG_SYS_CCSRBAR_PHYS_LOW and/or CONFIG_SYS_CCSRBAR_PHYS_HIGH instead." +#endif + +#ifdef CONFIG_SYS_CCSR_DO_NOT_RELOCATE +#undef CONFIG_SYS_CCSRBAR_PHYS_HIGH +#undef CONFIG_SYS_CCSRBAR_PHYS_LOW +#define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0 +#endif + +#ifndef CONFIG_SYS_CCSRBAR +#define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT +#endif + +#ifndef CONFIG_SYS_CCSRBAR_PHYS_HIGH +#define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0 +#endif + +#ifndef CONFIG_SYS_CCSRBAR_PHYS_LOW +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR_DEFAULT +#endif + +#define CONFIG_SYS_CCSRBAR_PHYS ((CONFIG_SYS_CCSRBAR_PHYS_HIGH * 1ull) << 32 | \ + CONFIG_SYS_CCSRBAR_PHYS_LOW) + +struct sys_info { + unsigned long freq_processor[CONFIG_MAX_CPUS]; + unsigned long freq_systembus; + unsigned long freq_ddrbus; + unsigned long freq_localbus; + unsigned long freq_sdhc; +#ifdef CONFIG_SYS_DPAA_FMAN + unsigned long freq_fman[CONFIG_SYS_NUM_FMAN]; +#endif + unsigned long freq_qman; +}; + +#define CONFIG_SYS_FSL_FM1_OFFSET 0xa00000 +#define CONFIG_SYS_FSL_FM1_RX0_1G_OFFSET 0xa88000 +#define CONFIG_SYS_FSL_FM1_RX1_1G_OFFSET 0xa89000 +#define CONFIG_SYS_FSL_FM1_RX2_1G_OFFSET 0xa8a000 +#define CONFIG_SYS_FSL_FM1_RX3_1G_OFFSET 0xa8b000 +#define CONFIG_SYS_FSL_FM1_RX4_1G_OFFSET 0xa8c000 +#define CONFIG_SYS_FSL_FM1_RX5_1G_OFFSET 0xa8d000 + +#define CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET 0xae0000 +#define CONFIG_SYS_FSL_FM1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM1_OFFSET) +#define CONFIG_SYS_FSL_FM1_DTSEC1_ADDR \ + (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET) + +/* Device Configuration and Pin Control */ +struct ccsr_gur { + u32 porsr1; /* POR status 1 */ +#define FSL_CHASSIS2_CCSR_PORSR1_RCW_MASK 0xFF800000 + u32 porsr2; /* POR status 2 */ + u8 res_008[0x20-0x8]; + u32 gpporcr1; /* General-purpose POR configuration */ + u32 gpporcr2; +#define FSL_CHASSIS2_DCFG_FUSESR_VID_SHIFT 25 +#define FSL_CHASSIS2_DCFG_FUSESR_VID_MASK 0x1F +#define FSL_CHASSIS2_DCFG_FUSESR_ALTVID_SHIFT 20 +#define FSL_CHASSIS2_DCFG_FUSESR_ALTVID_MASK 0x1F + u32 dcfg_fusesr; /* Fuse status register */ + u8 res_02c[0x70-0x2c]; + u32 devdisr; /* Device disable control */ +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_1 0x80000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_2 0x40000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_3 0x20000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_4 0x10000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_5 0x08000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_6 0x04000000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_9 0x00800000 +#define FSL_CHASSIS2_DEVDISR2_DTSEC1_10 0x00400000 +#define FSL_CHASSIS2_DEVDISR2_10GEC1_1 0x00800000 +#define FSL_CHASSIS2_DEVDISR2_10GEC1_2 0x00400000 +#define FSL_CHASSIS2_DEVDISR2_10GEC1_3 0x80000000 +#define FSL_CHASSIS2_DEVDISR2_10GEC1_4 0x40000000 + u32 devdisr2; /* Device disable control 2 */ + u32 devdisr3; /* Device disable control 3 */ + u32 devdisr4; /* Device disable control 4 */ + u32 devdisr5; /* Device disable control 5 */ + u32 devdisr6; /* Device disable control 6 */ + u32 devdisr7; /* Device disable control 7 */ + u8 res_08c[0x94-0x8c]; + u32 coredisru; /* uppper portion for support of 64 cores */ + u32 coredisrl; /* lower portion for support of 64 cores */ + u8 res_09c[0xa0-0x9c]; + u32 pvr; /* Processor version */ + u32 svr; /* System version */ + u32 mvr; /* Manufacturing version */ + u8 res_0ac[0xb0-0xac]; + u32 rstcr; /* Reset control */ + u32 rstrqpblsr; /* Reset request preboot loader status */ + u8 res_0b8[0xc0-0xb8]; + u32 rstrqmr1; /* Reset request mask */ + u8 res_0c4[0xc8-0xc4]; + u32 rstrqsr1; /* Reset request status */ + u8 res_0cc[0xd4-0xcc]; + u32 rstrqwdtmrl; /* Reset request WDT mask */ + u8 res_0d8[0xdc-0xd8]; + u32 rstrqwdtsrl; /* Reset request WDT status */ + u8 res_0e0[0xe4-0xe0]; + u32 brrl; /* Boot release */ + u8 res_0e8[0x100-0xe8]; + u32 rcwsr[16]; /* Reset control word status */ +#define FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_SHIFT 25 +#define FSL_CHASSIS2_RCWSR0_SYS_PLL_RAT_MASK 0x1f +#define FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_SHIFT 16 +#define FSL_CHASSIS2_RCWSR0_MEM_PLL_RAT_MASK 0x3f +#define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK 0xffff0000 +#define FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT 16 + u8 res_140[0x200-0x140]; + u32 scratchrw[4]; /* Scratch Read/Write */ + u8 res_210[0x300-0x210]; + u32 scratchw1r[4]; /* Scratch Read (Write once) */ + u8 res_310[0x400-0x310]; + u32 crstsr[12]; + u8 res_430[0x500-0x430]; + + /* PCI Express n Logical I/O Device Number register */ + u32 dcfg_ccsr_pex1liodnr; + u32 dcfg_ccsr_pex2liodnr; + u32 dcfg_ccsr_pex3liodnr; + u32 dcfg_ccsr_pex4liodnr; + /* RIO n Logical I/O Device Number register */ + u32 dcfg_ccsr_rio1liodnr; + u32 dcfg_ccsr_rio2liodnr; + u32 dcfg_ccsr_rio3liodnr; + u32 dcfg_ccsr_rio4liodnr; + /* USB Logical I/O Device Number register */ + u32 dcfg_ccsr_usb1liodnr; + u32 dcfg_ccsr_usb2liodnr; + u32 dcfg_ccsr_usb3liodnr; + u32 dcfg_ccsr_usb4liodnr; + /* SD/MMC Logical I/O Device Number register */ + u32 dcfg_ccsr_sdmmc1liodnr; + u32 dcfg_ccsr_sdmmc2liodnr; + u32 dcfg_ccsr_sdmmc3liodnr; + u32 dcfg_ccsr_sdmmc4liodnr; + /* RIO Message Unit Logical I/O Device Number register */ + u32 dcfg_ccsr_riomaintliodnr; + + u8 res_544[0x550-0x544]; + u32 sataliodnr[4]; + u8 res_560[0x570-0x560]; + + u32 dcfg_ccsr_misc1liodnr; + u32 dcfg_ccsr_misc2liodnr; + u32 dcfg_ccsr_misc3liodnr; + u32 dcfg_ccsr_misc4liodnr; + u32 dcfg_ccsr_dma1liodnr; + u32 dcfg_ccsr_dma2liodnr; + u32 dcfg_ccsr_dma3liodnr; + u32 dcfg_ccsr_dma4liodnr; + u32 dcfg_ccsr_spare1liodnr; + u32 dcfg_ccsr_spare2liodnr; + u32 dcfg_ccsr_spare3liodnr; + u32 dcfg_ccsr_spare4liodnr; + u8 res_5a0[0x600-0x5a0]; + u32 dcfg_ccsr_pblsr; + + u32 pamubypenr; + u32 dmacr1; + + u8 res_60c[0x610-0x60c]; + u32 dcfg_ccsr_gensr1; + u32 dcfg_ccsr_gensr2; + u32 dcfg_ccsr_gensr3; + u32 dcfg_ccsr_gensr4; + u32 dcfg_ccsr_gencr1; + u32 dcfg_ccsr_gencr2; + u32 dcfg_ccsr_gencr3; + u32 dcfg_ccsr_gencr4; + u32 dcfg_ccsr_gencr5; + u32 dcfg_ccsr_gencr6; + u32 dcfg_ccsr_gencr7; + u8 res_63c[0x658-0x63c]; + u32 dcfg_ccsr_cgensr1; + u32 dcfg_ccsr_cgensr0; + u8 res_660[0x678-0x660]; + u32 dcfg_ccsr_cgencr1; + + u32 dcfg_ccsr_cgencr0; + u8 res_680[0x700-0x680]; + u32 dcfg_ccsr_sriopstecr; + u32 dcfg_ccsr_dcsrcr; + + u8 res_708[0x740-0x708]; /* add more registers when needed */ + u32 tp_ityp[64]; /* Topology Initiator Type Register */ + struct { + u32 upper; + u32 lower; + } tp_cluster[16]; + u8 res_8c0[0xa00-0x8c0]; /* add more registers when needed */ + u32 dcfg_ccsr_qmbm_warmrst; + u8 res_a04[0xa20-0xa04]; /* add more registers when needed */ + u32 dcfg_ccsr_reserved0; + u32 dcfg_ccsr_reserved1; +}; + +#define SCFG_QSPI_CLKSEL 0x40100000 +#define SCFG_USBDRVVBUS_SELCR_USB1 0x00000000 +#define SCFG_USBDRVVBUS_SELCR_USB2 0x00000001 +#define SCFG_USBDRVVBUS_SELCR_USB3 0x00000002 +#define SCFG_USBPWRFAULT_INACTIVE 0x00000000 +#define SCFG_USBPWRFAULT_SHARED 0x00000001 +#define SCFG_USBPWRFAULT_DEDICATED 0x00000002 +#define SCFG_USBPWRFAULT_USB3_SHIFT 4 +#define SCFG_USBPWRFAULT_USB2_SHIFT 2 +#define SCFG_USBPWRFAULT_USB1_SHIFT 0 + +#define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 +#define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 + +/* Supplemental Configuration Unit */ +struct ccsr_scfg { + u8 res_000[0x100-0x000]; + u32 usb2_icid; + u32 usb3_icid; + u8 res_108[0x114-0x108]; + u32 dma_icid; + u32 sata_icid; + u32 usb1_icid; + u32 qe_icid; + u32 sdhc_icid; + u32 edma_icid; + u32 etr_icid; + u32 core_sft_rst[4]; + u8 res_140[0x158-0x140]; + u32 altcbar; + u32 qspi_cfg; + u8 res_160[0x180-0x160]; + u32 dmamcr; + u8 res_184[0x18c-0x184]; + u32 debug_icid; + u8 res_190[0x1a4-0x190]; + u32 snpcnfgcr; + u8 res_1a8[0x1ac-0x1a8]; + u32 intpcr; + u8 res_1b0[0x204-0x1b0]; + u32 coresrencr; + u8 res_208[0x220-0x208]; + u32 rvbar0_0; + u32 rvbar0_1; + u32 rvbar1_0; + u32 rvbar1_1; + u32 rvbar2_0; + u32 rvbar2_1; + u32 rvbar3_0; + u32 rvbar3_1; + u32 lpmcsr; + u8 res_244[0x400-0x244]; + u32 qspidqscr; + u32 ecgtxcmcr; + u32 sdhciovselcr; + u32 rcwpmuxcr0; + u32 usbdrvvbus_selcr; + u32 usbpwrfault_selcr; + u32 usb_refclk_selcr1; + u32 usb_refclk_selcr2; + u32 usb_refclk_selcr3; + u8 res_424[0x600-0x424]; + u32 scratchrw[4]; + u8 res_610[0x680-0x610]; + u32 corebcr; + u8 res_684[0x1000-0x684]; + u32 pex1msiir; + u32 pex1msir; + u8 res_1008[0x2000-0x1008]; + u32 pex2; + u32 pex2msir; + u8 res_2008[0x3000-0x2008]; + u32 pex3msiir; + u32 pex3msir; +}; + +/* Clocking */ +struct ccsr_clk { + struct { + u32 clkcncsr; /* core cluster n clock control status */ + u8 res_004[0x0c]; + u32 clkcghwacsr; /* Clock generator n hardware accelerator */ + u8 res_014[0x0c]; + } clkcsr[4]; + u8 res_040[0x780]; /* 0x100 */ + struct { + u32 pllcngsr; + u8 res_804[0x1c]; + } pllcgsr[2]; + u8 res_840[0x1c0]; + u32 clkpcsr; /* 0xa00 Platform clock domain control/status */ + u8 res_a04[0x1fc]; + u32 pllpgsr; /* 0xc00 Platform PLL General Status */ + u8 res_c04[0x1c]; + u32 plldgsr; /* 0xc20 DDR PLL General Status */ + u8 res_c24[0x3dc]; +}; + +/* System Counter */ +struct sctr_regs { + u32 cntcr; + u32 cntsr; + u32 cntcv1; + u32 cntcv2; + u32 resv1[4]; + u32 cntfid0; + u32 cntfid1; + u32 resv2[1002]; + u32 counterid[12]; +}; + +#define SRDS_MAX_LANES 4 +struct ccsr_serdes { + struct { + u32 rstctl; /* Reset Control Register */ +#define SRDS_RSTCTL_RST 0x80000000 +#define SRDS_RSTCTL_RSTDONE 0x40000000 +#define SRDS_RSTCTL_RSTERR 0x20000000 +#define SRDS_RSTCTL_SWRST 0x10000000 +#define SRDS_RSTCTL_SDEN 0x00000020 +#define SRDS_RSTCTL_SDRST_B 0x00000040 +#define SRDS_RSTCTL_PLLRST_B 0x00000080 + u32 pllcr0; /* PLL Control Register 0 */ +#define SRDS_PLLCR0_POFF 0x80000000 +#define SRDS_PLLCR0_RFCK_SEL_MASK 0x70000000 +#define SRDS_PLLCR0_RFCK_SEL_100 0x00000000 +#define SRDS_PLLCR0_RFCK_SEL_125 0x10000000 +#define SRDS_PLLCR0_RFCK_SEL_156_25 0x20000000 +#define SRDS_PLLCR0_RFCK_SEL_150 0x30000000 +#define SRDS_PLLCR0_RFCK_SEL_161_13 0x40000000 +#define SRDS_PLLCR0_RFCK_SEL_122_88 0x50000000 +#define SRDS_PLLCR0_PLL_LCK 0x00800000 +#define SRDS_PLLCR0_FRATE_SEL_MASK 0x000f0000 +#define SRDS_PLLCR0_FRATE_SEL_5 0x00000000 +#define SRDS_PLLCR0_FRATE_SEL_3_75 0x00050000 +#define SRDS_PLLCR0_FRATE_SEL_5_15 0x00060000 +#define SRDS_PLLCR0_FRATE_SEL_4 0x00070000 +#define SRDS_PLLCR0_FRATE_SEL_3_12 0x00090000 +#define SRDS_PLLCR0_FRATE_SEL_3 0x000a0000 + u32 pllcr1; /* PLL Control Register 1 */ +#define SRDS_PLLCR1_PLL_BWSEL 0x08000000 + u32 res_0c; /* 0x00c */ + u32 pllcr3; + u32 pllcr4; + u8 res_18[0x20-0x18]; + } bank[2]; + u8 res_40[0x90-0x40]; + u32 srdstcalcr; /* 0x90 TX Calibration Control */ + u8 res_94[0xa0-0x94]; + u32 srdsrcalcr; /* 0xa0 RX Calibration Control */ + u8 res_a4[0xb0-0xa4]; + u32 srdsgr0; /* 0xb0 General Register 0 */ + u8 res_b4[0xe0-0xb4]; + u32 srdspccr0; /* 0xe0 Protocol Converter Config 0 */ + u32 srdspccr1; /* 0xe4 Protocol Converter Config 1 */ + u32 srdspccr2; /* 0xe8 Protocol Converter Config 2 */ + u32 srdspccr3; /* 0xec Protocol Converter Config 3 */ + u32 srdspccr4; /* 0xf0 Protocol Converter Config 4 */ + u8 res_f4[0x100-0xf4]; + struct { + u32 lnpssr; /* 0x100, 0x120, ..., 0x1e0 */ + u8 res_104[0x120-0x104]; + } srdslnpssr[4]; + u8 res_180[0x300-0x180]; + u32 srdspexeqcr; + u32 srdspexeqpcr[11]; + u8 res_330[0x400-0x330]; + u32 srdspexapcr; + u8 res_404[0x440-0x404]; + u32 srdspexbpcr; + u8 res_444[0x800-0x444]; + struct { + u32 gcr0; /* 0x800 General Control Register 0 */ + u32 gcr1; /* 0x804 General Control Register 1 */ + u32 gcr2; /* 0x808 General Control Register 2 */ + u32 sscr0; + u32 recr0; /* 0x810 Receive Equalization Control */ + u32 recr1; + u32 tecr0; /* 0x818 Transmit Equalization Control */ + u32 sscr1; + u32 ttlcr0; /* 0x820 Transition Tracking Loop Ctrl 0 */ + u8 res_824[0x83c-0x824]; + u32 tcsr3; + } lane[4]; /* Lane A, B, C, D, E, F, G, H */ + u8 res_a00[0x1000-0xa00]; /* from 0xa00 to 0xfff */ +}; + +#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 +#define CCI400_CTRLORD_EN_BARRIER 0 +#define CCI400_SHAORD_NON_SHAREABLE 0x00000002 +#define CCI400_DVM_MESSAGE_REQ_EN 0x00000002 +#define CCI400_SNOOP_REQ_EN 0x00000001 + +/* CCI-400 registers */ +struct ccsr_cci400 { + u32 ctrl_ord; /* Control Override */ + u32 spec_ctrl; /* Speculation Control */ + u32 secure_access; /* Secure Access */ + u32 status; /* Status */ + u32 impr_err; /* Imprecise Error */ + u8 res_14[0x100 - 0x14]; + u32 pmcr; /* Performance Monitor Control */ + u8 res_104[0xfd0 - 0x104]; + u32 pid[8]; /* Peripheral ID */ + u32 cid[4]; /* Component ID */ + struct { + u32 snoop_ctrl; /* Snoop Control */ + u32 sha_ord; /* Shareable Override */ + u8 res_1008[0x1100 - 0x1008]; + u32 rc_qos_ord; /* read channel QoS Value Override */ + u32 wc_qos_ord; /* read channel QoS Value Override */ + u8 res_1108[0x110c - 0x1108]; + u32 qos_ctrl; /* QoS Control */ + u32 max_ot; /* Max OT */ + u8 res_1114[0x1130 - 0x1114]; + u32 target_lat; /* Target Latency */ + u32 latency_regu; /* Latency Regulation */ + u32 qos_range; /* QoS Range */ + u8 res_113c[0x2000 - 0x113c]; + } slave[5]; /* Slave Interface */ + u8 res_6000[0x9004 - 0x6000]; + u32 cycle_counter; /* Cycle counter */ + u32 count_ctrl; /* Count Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_9010[0xa000 - 0x9010]; + struct { + u32 event_select; /* Event Select */ + u32 event_count; /* Event Count */ + u32 counter_ctrl; /* Counter Control */ + u32 overflow_status; /* Overflow Flag Status */ + u8 res_a010[0xb000 - 0xa010]; + } pcounter[4]; /* Performance Counter */ + u8 res_e004[0x10000 - 0xe004]; +}; + +/* MMU 500 */ +#define SMMU_SCR0 (SMMU_BASE + 0x0) +#define SMMU_SCR1 (SMMU_BASE + 0x4) +#define SMMU_SCR2 (SMMU_BASE + 0x8) +#define SMMU_SACR (SMMU_BASE + 0x10) +#define SMMU_IDR0 (SMMU_BASE + 0x20) +#define SMMU_IDR1 (SMMU_BASE + 0x24) + +#define SMMU_NSCR0 (SMMU_BASE + 0x400) +#define SMMU_NSCR2 (SMMU_BASE + 0x408) +#define SMMU_NSACR (SMMU_BASE + 0x410) + +#define SCR0_CLIENTPD_MASK 0x00000001 +#define SCR0_USFCFG_MASK 0x00000400 + +#endif /* __ARCH_FSL_LSCH2_IMMAP_H__*/ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h new file mode 100644 index 0000000..a3ccdb0 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h @@ -0,0 +1,158 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __FSL_NS_ACCESS_H_ +#define __FSL_NS_ACCESS_H_ + +enum csu_cslx_ind { + CSU_CSLX_PCIE2_IO = 0, + CSU_CSLX_PCIE1_IO, + CSU_CSLX_MG2TPR_IP, + CSU_CSLX_IFC_MEM, + CSU_CSLX_OCRAM, + CSU_CSLX_GIC, + CSU_CSLX_PCIE1, + CSU_CSLX_OCRAM2, + CSU_CSLX_QSPI_MEM, + CSU_CSLX_PCIE2, + CSU_CSLX_SATA, + CSU_CSLX_USB1, + CSU_CSLX_QM_BM_SWPORTAL, + CSU_CSLX_PCIE3 = 16, + CSU_CSLX_PCIE3_IO, + CSU_CSLX_USB3 = 20, + CSU_CSLX_USB2, + CSU_CSLX_SERDES = 32, + CSU_CSLX_QDMA, + CSU_CSLX_LPUART2, + CSU_CSLX_LPUART1, + CSU_CSLX_LPUART4, + CSU_CSLX_LPUART3, + CSU_CSLX_LPUART6, + CSU_CSLX_LPUART5, + CSU_CSLX_DSPI1 = 41, + CSU_CSLX_QSPI, + CSU_CSLX_ESDHC, + CSU_CSLX_IFC = 45, + CSU_CSLX_I2C1, + CSU_CSLX_I2C3 = 48, + CSU_CSLX_I2C2, + CSU_CSLX_DUART2 = 50, + CSU_CSLX_DUART1, + CSU_CSLX_WDT2, + CSU_CSLX_WDT1, + CSU_CSLX_EDMA, + CSU_CSLX_SYS_CNT, + CSU_CSLX_DMA_MUX2, + CSU_CSLX_DMA_MUX1, + CSU_CSLX_DDR, + CSU_CSLX_QUICC, + CSU_CSLX_DCFG_CCU_RCPM = 60, + CSU_CSLX_SECURE_BOOTROM, + CSU_CSLX_SFP, + CSU_CSLX_TMU, + CSU_CSLX_SECURE_MONITOR, + CSU_CSLX_SCFG, + CSU_CSLX_FM = 66, + CSU_CSLX_SEC5_5, + CSU_CSLX_BM, + CSU_CSLX_QM, + CSU_CSLX_GPIO2 = 70, + CSU_CSLX_GPIO1, + CSU_CSLX_GPIO4, + CSU_CSLX_GPIO3, + CSU_CSLX_PLATFORM_CONT, + CSU_CSLX_CSU, + CSU_CSLX_IIC4 = 77, + CSU_CSLX_WDT4, + CSU_CSLX_WDT3, + CSU_CSLX_WDT5 = 81, + CSU_CSLX_FTM2 = 86, + CSU_CSLX_FTM1, + CSU_CSLX_FTM4, + CSU_CSLX_FTM3, + CSU_CSLX_FTM6 = 90, + CSU_CSLX_FTM5, + CSU_CSLX_FTM8, + CSU_CSLX_FTM7, + CSU_CSLX_DSCR = 121, +}; + +static struct csu_ns_dev ns_dev[] = { + {CSU_CSLX_PCIE2_IO, CSU_ALL_RW}, + {CSU_CSLX_PCIE1_IO, CSU_ALL_RW}, + {CSU_CSLX_MG2TPR_IP, CSU_ALL_RW}, + {CSU_CSLX_IFC_MEM, CSU_ALL_RW}, + {CSU_CSLX_OCRAM, CSU_ALL_RW}, + {CSU_CSLX_GIC, CSU_ALL_RW}, + {CSU_CSLX_PCIE1, CSU_ALL_RW}, + {CSU_CSLX_OCRAM2, CSU_ALL_RW}, + {CSU_CSLX_QSPI_MEM, CSU_ALL_RW}, + {CSU_CSLX_PCIE2, CSU_ALL_RW}, + {CSU_CSLX_SATA, CSU_ALL_RW}, + {CSU_CSLX_USB1, CSU_ALL_RW}, + {CSU_CSLX_QM_BM_SWPORTAL, CSU_ALL_RW}, + {CSU_CSLX_PCIE3, CSU_ALL_RW}, + {CSU_CSLX_PCIE3_IO, CSU_ALL_RW}, + {CSU_CSLX_USB3, CSU_ALL_RW}, + {CSU_CSLX_USB2, CSU_ALL_RW}, + {CSU_CSLX_SERDES, CSU_ALL_RW}, + {CSU_CSLX_QDMA, CSU_ALL_RW}, + {CSU_CSLX_LPUART2, CSU_ALL_RW}, + {CSU_CSLX_LPUART1, CSU_ALL_RW}, + {CSU_CSLX_LPUART4, CSU_ALL_RW}, + {CSU_CSLX_LPUART3, CSU_ALL_RW}, + {CSU_CSLX_LPUART6, CSU_ALL_RW}, + {CSU_CSLX_LPUART5, CSU_ALL_RW}, + {CSU_CSLX_DSPI1, CSU_ALL_RW}, + {CSU_CSLX_QSPI, CSU_ALL_RW}, + {CSU_CSLX_ESDHC, CSU_ALL_RW}, + {CSU_CSLX_IFC, CSU_ALL_RW}, + {CSU_CSLX_I2C1, CSU_ALL_RW}, + {CSU_CSLX_I2C3, CSU_ALL_RW}, + {CSU_CSLX_I2C2, CSU_ALL_RW}, + {CSU_CSLX_DUART2, CSU_ALL_RW}, + {CSU_CSLX_DUART1, CSU_ALL_RW}, + {CSU_CSLX_WDT2, CSU_ALL_RW}, + {CSU_CSLX_WDT1, CSU_ALL_RW}, + {CSU_CSLX_EDMA, CSU_ALL_RW}, + {CSU_CSLX_SYS_CNT, CSU_ALL_RW}, + {CSU_CSLX_DMA_MUX2, CSU_ALL_RW}, + {CSU_CSLX_DMA_MUX1, CSU_ALL_RW}, + {CSU_CSLX_DDR, CSU_ALL_RW}, + {CSU_CSLX_QUICC, CSU_ALL_RW}, + {CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW}, + {CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW}, + {CSU_CSLX_SFP, CSU_ALL_RW}, + {CSU_CSLX_TMU, CSU_ALL_RW}, + {CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW}, + {CSU_CSLX_SCFG, CSU_ALL_RW}, + {CSU_CSLX_FM, CSU_ALL_RW}, + {CSU_CSLX_SEC5_5, CSU_ALL_RW}, + {CSU_CSLX_BM, CSU_ALL_RW}, + {CSU_CSLX_QM, CSU_ALL_RW}, + {CSU_CSLX_GPIO2, CSU_ALL_RW}, + {CSU_CSLX_GPIO1, CSU_ALL_RW}, + {CSU_CSLX_GPIO4, CSU_ALL_RW}, + {CSU_CSLX_GPIO3, CSU_ALL_RW}, + {CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW}, + {CSU_CSLX_CSU, CSU_ALL_RW}, + {CSU_CSLX_IIC4, CSU_ALL_RW}, + {CSU_CSLX_WDT4, CSU_ALL_RW}, + {CSU_CSLX_WDT3, CSU_ALL_RW}, + {CSU_CSLX_WDT5, CSU_ALL_RW}, + {CSU_CSLX_FTM2, CSU_ALL_RW}, + {CSU_CSLX_FTM1, CSU_ALL_RW}, + {CSU_CSLX_FTM4, CSU_ALL_RW}, + {CSU_CSLX_FTM3, CSU_ALL_RW}, + {CSU_CSLX_FTM6, CSU_ALL_RW}, + {CSU_CSLX_FTM5, CSU_ALL_RW}, + {CSU_CSLX_FTM8, CSU_ALL_RW}, + {CSU_CSLX_FTM7, CSU_ALL_RW}, + {CSU_CSLX_DSCR, CSU_ALL_RW}, +}; + +#endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index f131f57..5ed456e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -33,6 +33,7 @@ struct cpu_type { { .name = #n, .soc_ver = SVR_##v, .num_cores = (nc)}
#define SVR_WO_E 0xFFFFFE +#define SVR_LS1043 0x879204 #define SVR_LS2045 0x870120 #define SVR_LS2080 0x870110 #define SVR_LS2085 0x870100 @@ -42,6 +43,11 @@ struct cpu_type { #define SVR_SOC_VER(svr) (((svr) >> 8) & SVR_WO_E) #define IS_E_PROCESSOR(svr) (!((svr >> 8) & 0x1))
+#ifdef CONFIG_FSL_LSCH3 void fsl_lsch3_early_init_f(void); +#elif defined(CONFIG_FSL_LSCH2) +void fsl_lsch2_early_init_f(void); +#endif + void cpu_name(char *name); #endif /* _ASM_ARMV8_FSL_LAYERSCAPE_SOC_H_ */ diff --git a/arch/arm/include/asm/armv8/mmu.h b/arch/arm/include/asm/armv8/mmu.h index 587ee39..d8d9af4 100644 --- a/arch/arm/include/asm/armv8/mmu.h +++ b/arch/arm/include/asm/armv8/mmu.h @@ -65,6 +65,7 @@ /* * Section */ +#define PMD_SECT_NS (1 << 5) #define PMD_SECT_NON_SHARE (0 << 8) #define PMD_SECT_OUTER_SHARE (2 << 8) #define PMD_SECT_INNER_SHARE (3 << 8) diff --git a/include/common.h b/include/common.h index 142936b..09a131d 100644 --- a/include/common.h +++ b/include/common.h @@ -79,6 +79,9 @@ typedef volatile unsigned char vu_char; #ifdef CONFIG_FSL_LSCH3 #include <asm/arch/immap_lsch3.h> #endif +#ifdef CONFIG_FSL_LSCH2 +#include <asm/arch/immap_lsch2.h> +#endif
LS1043ARDB Specification: ------------------------- Memory subsystem: * 2GByte DDR4 SDRAM (32bit bus) * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card
Ethernet: * XFI 10G port * QSGMII with 4x 1G ports * Two RGMII ports
PCIe: * PCIe2 (Lanes C) to mini-PCIe slot * PCIe3 (Lanes D) to PCIe slot
USB 3.0: two super speed USB 3.0 type A ports
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Li Yang leoli@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - Move GIC SMMU macros out of ls1043a_common.h. V5: - No change. V4: - Change arch to layerscape. - Add PCIe support. - Move SMMU_BASE, GICC_BASE, GICD_BASE to ls1043a_common.h. V3: - Fix message typos. - Add ddr model number in comments. - Fix boot options in README. - Remove some dead code. V2: - Replaced ns_access.h with fsl_csu.h.
arch/arm/Kconfig | 7 + arch/arm/cpu/armv8/fsl-layerscape/Makefile | 4 + arch/arm/cpu/armv8/fsl-layerscape/ls1043a_serdes.c | 86 ++++++++++ board/freescale/ls1043ardb/Kconfig | 16 ++ board/freescale/ls1043ardb/MAINTAINERS | 7 + board/freescale/ls1043ardb/Makefile | 9 + board/freescale/ls1043ardb/README | 85 +++++++++ board/freescale/ls1043ardb/cpld.c | 115 +++++++++++++ board/freescale/ls1043ardb/cpld.h | 43 +++++ board/freescale/ls1043ardb/ddr.c | 191 +++++++++++++++++++++ board/freescale/ls1043ardb/ddr.h | 45 +++++ board/freescale/ls1043ardb/ls1043ardb.c | 131 ++++++++++++++ configs/ls1043ardb_defconfig | 4 + include/configs/ls1043a_common.h | 174 +++++++++++++++++++ include/configs/ls1043ardb.h | 191 +++++++++++++++++++++ 15 files changed, 1108 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7981355..bd99bfb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -631,6 +631,12 @@ config TARGET_LS1021ATWR select CPU_V7 select SUPPORT_SPL
+config TARGET_LS1043ARDB + bool "Support ls1043ardb" + select ARM64 + help + Support for Freescale LS1043ARDB platform. + config TARGET_H2200 bool "Support h2200" select CPU_PXA @@ -745,6 +751,7 @@ source "board/freescale/ls2085aqds/Kconfig" source "board/freescale/ls2085ardb/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" +source "board/freescale/ls1043ardb/Kconfig" source "board/freescale/mx23evk/Kconfig" source "board/freescale/mx25pdk/Kconfig" source "board/freescale/mx28evk/Kconfig" diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 4754e59..6fa08c8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -23,4 +23,8 @@ endif
ifneq ($(CONFIG_LS2085A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls2085a_serdes.o +else +ifneq ($(CONFIG_LS1043A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls1043a_serdes.o +endif endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_serdes.c new file mode 100644 index 0000000..e54d389 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1043a_serdes.c @@ -0,0 +1,86 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/immap_lsch2.h> + +struct serdes_config { + u32 protocol; + u8 lanes[SRDS_MAX_LANES]; +}; + +static struct serdes_config serdes1_cfg_tbl[] = { + /* SerDes 1 */ + {0x1555, {XFI_FM1_MAC9, PCIE1, PCIE2, PCIE3} }, + {0x2555, {SGMII_2500_FM1_DTSEC9, PCIE1, PCIE2, PCIE3} }, + {0x4555, {QSGMII_FM1_A, PCIE1, PCIE2, PCIE3} }, + {0x4558, {QSGMII_FM1_A, PCIE1, PCIE2, SATA1} }, + {0x1355, {XFI_FM1_MAC9, SGMII_FM1_DTSEC2, PCIE2, PCIE3} }, + {0x2355, {SGMII_2500_FM1_DTSEC9, SGMII_FM1_DTSEC2, PCIE2, PCIE3} }, + {0x3335, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC5, + PCIE3} }, + {0x3355, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC2, PCIE2, PCIE3} }, + {0x3358, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC2, PCIE2, SATA1} }, + {0x3555, {SGMII_FM1_DTSEC9, PCIE1, PCIE2, PCIE3} }, + {0x3558, {SGMII_FM1_DTSEC9, PCIE1, PCIE2, SATA1} }, + {0x7000, {PCIE1, PCIE1, PCIE1, PCIE1} }, + {0x9998, {PCIE1, PCIE2, PCIE3, SATA1} }, + {0x6058, {PCIE1, PCIE1, PCIE2, SATA1} }, + {0x1455, {XFI_FM1_MAC9, QSGMII_FM1_A, PCIE2, PCIE3} }, + {0x2455, {SGMII_2500_FM1_DTSEC9, QSGMII_FM1_A, PCIE2, PCIE3} }, + {0x2255, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC2, PCIE2, PCIE3} }, + {0x3333, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC5, + SGMII_FM1_DTSEC6} }, + {} +}; + +static struct serdes_config *serdes_cfg_tbl[] = { + serdes1_cfg_tbl, +}; + +enum srds_prtcl serdes_get_prtcl(int serdes, int cfg, int lane) +{ + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->protocol) { + if (ptr->protocol == cfg) + return ptr->lanes[lane]; + ptr++; + } + + return 0; +} + +int is_serdes_prtcl_valid(int serdes, u32 prtcl) +{ + int i; + struct serdes_config *ptr; + + if (serdes >= ARRAY_SIZE(serdes_cfg_tbl)) + return 0; + + ptr = serdes_cfg_tbl[serdes]; + while (ptr->protocol) { + if (ptr->protocol == prtcl) + break; + ptr++; + } + + if (!ptr->protocol) + return 0; + + for (i = 0; i < SRDS_MAX_LANES; i++) { + if (ptr->lanes[i] != NONE) + return 1; + } + + return 0; +} diff --git a/board/freescale/ls1043ardb/Kconfig b/board/freescale/ls1043ardb/Kconfig new file mode 100644 index 0000000..51818ec --- /dev/null +++ b/board/freescale/ls1043ardb/Kconfig @@ -0,0 +1,16 @@ + +if TARGET_LS1043ARDB + +config SYS_BOARD + default "ls1043ardb" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1043ardb" + +endif diff --git a/board/freescale/ls1043ardb/MAINTAINERS b/board/freescale/ls1043ardb/MAINTAINERS new file mode 100644 index 0000000..b8f6be2 --- /dev/null +++ b/board/freescale/ls1043ardb/MAINTAINERS @@ -0,0 +1,7 @@ +LS1043A BOARD +M: Mingkai Hu Mingkai.hu@freescale.com +S: Maintained +F: board/freescale/ls1043ardb/ +F: board/freescale/ls1043ardb/ls1043ardb.c +F: include/configs/ls1043ardb.h +F: configs/ls1043ardb_defconfig diff --git a/board/freescale/ls1043ardb/Makefile b/board/freescale/ls1043ardb/Makefile new file mode 100644 index 0000000..dd17e2e --- /dev/null +++ b/board/freescale/ls1043ardb/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2015 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += cpld.o +obj-y += ddr.o +obj-y += ls1043ardb.o diff --git a/board/freescale/ls1043ardb/README b/board/freescale/ls1043ardb/README new file mode 100644 index 0000000..d5925a9 --- /dev/null +++ b/board/freescale/ls1043ardb/README @@ -0,0 +1,85 @@ +Overview +-------- +The LS1043A Reference Design Board (RDB) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1043A +LayerScape Architecture processor. The LS1043ARDB provides SW development +platform for the Freescale LS1043A processor series, with a complete +debugging environment. The LS1043A RDB is lead-free and RoHS-compliant. + +LS1043A SoC Overview +-------------------- +The LS1043A integrated multicore processor combines four ARM Cortex-A53 +processor cores with datapath acceleration optimized for L2/3 packet +processing, single pass security offload and robust traffic management +and quality of service. + +The LS1043A SoC includes the following function and features: + - Four 64-bit ARM Cortex-A53 CPUs + - 1 MB unified L2 Cache + - One 32-bit DDR3L/DDR4 SDRAM memory controllers with ECC and interleaving + support + - Data Path Acceleration Architecture (DPAA) incorporating acceleration the + the following functions: + - Packet parsing, classification, and distribution (FMan) + - Queue management for scheduling, packet sequencing, and congestion + management (QMan) + - Hardware buffer management for buffer allocation and de-allocation (BMan) + - Cryptography acceleration (SEC) + - Ethernet interfaces by FMan + - Up to 1 x XFI supporting 10G interface + - Up to 1 x QSGMII + - Up to 4 x SGMII supporting 1000Mbps + - Up to 2 x SGMII supporting 2500Mbps + - Up to 2 x RGMII supporting 1000Mbps + - High-speed peripheral interfaces + - Three PCIe 2.0 controllers, one supporting x4 operation + - One serial ATA (SATA 3.0) controllers + - Additional peripheral interfaces + - Three high-speed USB 3.0 controllers with integrated PHY + - Enhanced secure digital host controller (eSDXC/eMMC) + - Quad Serial Peripheral Interface (QSPI) Controller + - Serial peripheral interface (SPI) controller + - Four I2C controllers + - Two DUARTs + - Integrated flash controller supporting NAND and NOR flash + - QorIQ platform's trust architecture 2.1 + + LS1043ARDB board Overview + ----------------------- + - SERDES Connections, 4 lanes supporting: + - PCI Express 2.0 with two PCIe connectors supporting: miniPCIe card and + standard PCIe card + - QSGMII with x4 RJ45 connector + - XFI with x1 RJ45 connector + - DDR Controller + - 2GB 32bits DDR4 SDRAM. Support rates of up to 1600MT/s + -IFC/Local Bus + - One 128MB NOR flash 16-bit data bus + - One 512 MB NAND flash with ECC support + - CPLD connection + - USB 3.0 + - Two super speed USB 3.0 Type A ports + - SDHC: connects directly to a full SD/MMC slot + - DSPI: 16 MB high-speed flash Memory for boot code and storage (up to 108MHz) + - 4 I2C controllers + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 0x00_20FF_FFFF DCSR 16MB +0x00_6000_0000 0x00_67FF_FFFF IFC - NOR Flash 128MB +0x00_7E80_0000 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 0x00_7FB0_0FFF IFC - FPGA 4KB +0x00_8000_0000 0x00_FFFF_FFFF DRAM1 2GB + +Booting Options +--------------- +a) NOR boot diff --git a/board/freescale/ls1043ardb/cpld.c b/board/freescale/ls1043ardb/cpld.c new file mode 100644 index 0000000..3f1101e --- /dev/null +++ b/board/freescale/ls1043ardb/cpld.c @@ -0,0 +1,115 @@ +/* + * Copyright 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Freescale LS1043ARDB board-specific CPLD controlling supports. + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> +#include "cpld.h" + +u8 cpld_read(unsigned int reg) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + return in_8(p + reg); +} + +void cpld_write(unsigned int reg, u8 value) +{ + void *p = (void *)CONFIG_SYS_CPLD_BASE; + + out_8(p + reg, value); +} + +/* Set the boot bank to the alternate bank */ +void cpld_set_altbank(void) +{ + u8 reg4 = CPLD_READ(soft_mux_on); + u8 reg7 = CPLD_READ(vbank); + + CPLD_WRITE(soft_mux_on, reg4 | CPLD_SW_MUX_BANK_SEL); + + reg7 = (reg7 & ~CPLD_BANK_SEL_MASK) | CPLD_BANK_SEL_ALTBANK; + CPLD_WRITE(vbank, reg7); + + CPLD_WRITE(system_rst, 1); +} + +/* Set the boot bank to the default bank */ +void cpld_set_defbank(void) +{ + CPLD_WRITE(global_rst, 1); +} + +#ifdef DEBUG +static void cpld_dump_regs(void) +{ + printf("cpld_ver = %x\n", CPLD_READ(cpld_ver)); + printf("cpld_ver_sub = %x\n", CPLD_READ(cpld_ver_sub)); + printf("pcba_ver = %x\n", CPLD_READ(pcba_ver)); + printf("soft_mux_on = %x\n", CPLD_READ(soft_mux_on)); + printf("cfg_rcw_src1 = %x\n", CPLD_READ(cfg_rcw_src1)); + printf("cfg_rcw_src2 = %x\n", CPLD_READ(cfg_rcw_src2)); + printf("vbank = %x\n", CPLD_READ(vbank)); + printf("sysclk_sel = %x\n", CPLD_READ(sysclk_sel)); + printf("uart_sel = %x\n", CPLD_READ(uart_sel)); + printf("sd1refclk_sel = %x\n", CPLD_READ(sd1refclk_sel)); + printf("tdmclk_mux_sel = %x\n", CPLD_READ(tdmclk_mux_sel)); + printf("sdhc_spics_sel = %x\n", CPLD_READ(sdhc_spics_sel)); + printf("status_led = %x\n", CPLD_READ(status_led)); + putc('\n'); +} +#endif + +void cpld_rev_bit(unsigned char *value) +{ + u8 rev_val, val; + int i; + + val = *value; + rev_val = val & 1; + for (i = 1; i <= 7; i++) { + val >>= 1; + rev_val <<= 1; + rev_val |= val & 1; + } + + *value = rev_val; +} + +int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int rc = 0; + + if (argc <= 1) + return cmd_usage(cmdtp); + + if (strcmp(argv[1], "reset") == 0) { + if (strcmp(argv[2], "altbank") == 0) + cpld_set_altbank(); + else + cpld_set_defbank(); +#ifdef DEBUG + } else if (strcmp(argv[1], "dump") == 0) { + cpld_dump_regs(); +#endif + } else { + rc = cmd_usage(cmdtp); + } + + return rc; +} + +U_BOOT_CMD( + cpld, CONFIG_SYS_MAXARGS, 1, do_cpld, + "Reset the board or alternate bank", + "reset: reset to default bank\n" + "cpld reset altbank: reset to alternate bank\n" +#ifdef DEBUG + "cpld dump - display the CPLD registers\n" +#endif +); diff --git a/board/freescale/ls1043ardb/cpld.h b/board/freescale/ls1043ardb/cpld.h new file mode 100644 index 0000000..ea4efd8 --- /dev/null +++ b/board/freescale/ls1043ardb/cpld.h @@ -0,0 +1,43 @@ +/* + * Copyright 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CPLD_H__ +#define __CPLD_H__ + +/* + * CPLD register set of LS1043ARDB board-specific. + */ +struct cpld_data { + u8 cpld_ver; /* 0x0 - CPLD Major Revision Register */ + u8 cpld_ver_sub; /* 0x1 - CPLD Minor Revision Register */ + u8 pcba_ver; /* 0x2 - PCBA Revision Register */ + u8 system_rst; /* 0x3 - system reset register */ + u8 soft_mux_on; /* 0x4 - Switch Control Enable Register */ + u8 cfg_rcw_src1; /* 0x5 - Reset config word 1 */ + u8 cfg_rcw_src2; /* 0x6 - Reset config word 1 */ + u8 vbank; /* 0x7 - Flash bank selection Control */ + u8 sysclk_sel; /* 0x8 - */ + u8 uart_sel; /* 0x9 - */ + u8 sd1refclk_sel; /* 0xA - */ + u8 tdmclk_mux_sel; /* 0xB - */ + u8 sdhc_spics_sel; /* 0xC - */ + u8 status_led; /* 0xD - */ + u8 global_rst; /* 0xE - */ +}; + +u8 cpld_read(unsigned int reg); +void cpld_write(unsigned int reg, u8 value); +void cpld_rev_bit(unsigned char *value); + +#define CPLD_READ(reg) cpld_read(offsetof(struct cpld_data, reg)) +#define CPLD_WRITE(reg, value) \ + cpld_write(offsetof(struct cpld_data, reg), value) + +/* CPLD on IFC */ +#define CPLD_SW_MUX_BANK_SEL 0x40 +#define CPLD_BANK_SEL_MASK 0x07 +#define CPLD_BANK_SEL_ALTBANK 0x04 +#endif diff --git a/board/freescale/ls1043ardb/ddr.c b/board/freescale/ls1043ardb/ddr.c new file mode 100644 index 0000000..b181579 --- /dev/null +++ b/board/freescale/ls1043ardb/ddr.c @@ -0,0 +1,191 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include "ddr.h" +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 1) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + popts->cpo_override = pbsp->cpo_override; + popts->write_data_delay = + pbsp->write_data_delay; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + /* force DDR bus width to 32 bits */ + popts->data_bus_width = 1; + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 1; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ +} + +/* DDR model number: MT40A512M8HX-093E */ +#ifdef CONFIG_SYS_DDR_RAW_TIMING +dimm_params_t ddr_raw_timing = { + .n_ranks = 1, + .rank_density = 2147483648u, + .capacity = 2147483648u, + .primary_sdram_width = 32, + .ec_sdram_width = 0, + .registered_dimm = 0, + .mirrored_dimm = 0, + .n_row_addr = 15, + .n_col_addr = 10, + .bank_addr_bits = 0, + .bank_group_bits = 2, + .edc_config = 0, + .burst_lengths_bitmask = 0x0c, + + .tckmin_x_ps = 938, + .tckmax_ps = 1500, + .caslat_x = 0x000DFA00, + .taa_ps = 13500, + .trcd_ps = 13500, + .trp_ps = 13500, + .tras_ps = 33000, + .trc_ps = 46500, + .trfc1_ps = 260000, + .trfc2_ps = 160000, + .trfc4_ps = 110000, + .tfaw_ps = 21000, + .trrds_ps = 3700, + .trrdl_ps = 5300, + .tccdl_ps = 5355, + .refresh_rate_ps = 7800000, + .dq_mapping[0] = 0x0, + .dq_mapping[1] = 0x0, + .dq_mapping[2] = 0x0, + .dq_mapping[3] = 0x0, + .dq_mapping[4] = 0x0, + .dq_mapping[5] = 0x0, + .dq_mapping[6] = 0x0, + .dq_mapping[7] = 0x0, + .dq_mapping[8] = 0x0, + .dq_mapping[9] = 0x0, + .dq_mapping[10] = 0x0, + .dq_mapping[11] = 0x0, + .dq_mapping[12] = 0x0, + .dq_mapping[13] = 0x0, + .dq_mapping[14] = 0x0, + .dq_mapping[15] = 0x0, + .dq_mapping[16] = 0x0, + .dq_mapping[17] = 0x0, + .dq_mapping_ors = 0, +}; + +int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, + unsigned int controller_number, + unsigned int dimm_number) +{ + static const char dimm_model[] = "Fixed DDR on board"; + + if (((controller_number == 0) && (dimm_number == 0)) || + ((controller_number == 1) && (dimm_number == 0))) { + memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); + } + + return 0; +} +#endif + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + +#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_SPL) + puts("Initializing DDR....\n"); + dram_size = fsl_ddr_sdram(); +#else + dram_size = fsl_ddr_sdram_size(); +#endif +#ifdef CONFIG_FSL_DEEP_SLEEP + fsl_dp_ddr_restore(); +#endif + + return dram_size; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; +} diff --git a/board/freescale/ls1043ardb/ddr.h b/board/freescale/ls1043ardb/ddr.h new file mode 100644 index 0000000..b17eb80 --- /dev/null +++ b/board/freescale/ls1043ardb/ddr.h @@ -0,0 +1,45 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo_override; + u32 write_data_delay; + u32 force_2t; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ +#ifdef CONFIG_SYS_FSL_DDR4 + {1, 1666, 0, 6, 7, 0x07090800, 0x00000000,}, + {1, 1900, 0, 6, 7, 0x07090800, 0x00000000,}, + {1, 2200, 0, 6, 7, 0x07090800, 0x00000000,}, +#endif + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +#endif diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c new file mode 100644 index 0000000..5b7f814 --- /dev/null +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -0,0 +1,131 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> +#include <hwconfig.h> +#include <ahci.h> +#include <scsi.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + static const char *freq[3] = {"100.00MHZ", "156.25MHZ"}; + u8 cfg_rcw_src1, cfg_rcw_src2; + u32 cfg_rcw_src; + u32 sd1refclk_sel; + + printf("Board: LS1043ARDB, boot from "); + + cfg_rcw_src1 = CPLD_READ(cfg_rcw_src1); + cfg_rcw_src2 = CPLD_READ(cfg_rcw_src2); + cpld_rev_bit(&cfg_rcw_src1); + cfg_rcw_src = cfg_rcw_src1; + cfg_rcw_src = (cfg_rcw_src << 1) | cfg_rcw_src2; + + if (cfg_rcw_src == 0x25) + printf("vBank %d\n", CPLD_READ(vbank)); + else if (cfg_rcw_src == 0x106) + puts("NAND\n"); + else + printf("Invalid setting of SW4\n"); + + printf("CPLD: V%x.%x\nPCBA: V%x.0\n", CPLD_READ(cpld_ver), + CPLD_READ(cpld_ver_sub), CPLD_READ(pcba_ver)); + + puts("SERDES Reference Clocks:\n"); + sd1refclk_sel = CPLD_READ(sd1refclk_sel); + printf("SD1_CLK1 = %s, SD1_CLK2 = %s\n", freq[sd1refclk_sel], freq[0]); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = initdram(0); + + return 0; +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + return 0; +} + +int board_init(void) +{ + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + + /* + * Set CCI-400 control override register to enable barrier + * transaction + */ + out_le32(&cci->ctrl_ord, CCI400_CTRLORD_EN_BARRIER); + +#ifdef CONFIG_FSL_IFC + init_final_memctl_regs(); +#endif + +#ifdef CONFIG_ENV_IS_NOWHERE + gd->env_addr = (ulong)&default_environment[0]; +#endif + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + + return 0; +} + +int config_board_mux(void) +{ + return 0; +} + +#if defined(CONFIG_MISC_INIT_R) +int misc_init_r(void) +{ + config_board_mux(); + + return 0; +} +#endif + +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} + +u8 flash_read8(void *addr) +{ + return __raw_readb(addr + 1); +} + +void flash_write16(u16 val, void *addr) +{ + u16 shftval = (((val >> 8) & 0xff) | ((val << 8) & 0xff00)); + + __raw_writew(shftval, addr); +} + +u16 flash_read16(void *addr) +{ + u16 val = __raw_readw(addr); + + return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); +} diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig new file mode 100644 index 0000000..ae84d2e --- /dev/null +++ b/configs/ls1043ardb_defconfig @@ -0,0 +1,4 @@ +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_ARM=y +CONFIG_TARGET_LS1043ARDB=y +CONFIG_FSL_LAYERSCAPE=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h new file mode 100644 index 0000000..a4577b0 --- /dev/null +++ b/include/configs/ls1043a_common.h @@ -0,0 +1,174 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1043A_COMMON_H +#define __LS1043A_COMMON_H + +#define CONFIG_SYS_GENERIC_BOARD + +#define CONFIG_REMAKE_ELF +#define CONFIG_FSL_LAYERSCAPE +#define CONFIG_FSL_LSCH2 +#define CONFIG_LS1043A +#define CONFIG_FSL_CLK +#define CONFIG_GICV2 + +#include <asm/arch/config.h> +#ifdef CONFIG_SYS_FSL_SRDS_1 +#define CONFIG_SYS_HAS_SERDES +#endif + +/* Link Definitions */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) + +#define CONFIG_SUPPORT_RAW_INITRD + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_BOARD_EARLY_INIT_F 1 + +/* Flat Device Tree Definitions */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +#ifndef CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ +#endif + +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +/* Generic Timer Definitions */ +#define COUNTER_FREQUENCY 25000000 /* 25MHz */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) + +/* Serial Port */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* IFC */ +#define CONFIG_FSL_IFC +/* + * CONFIG_SYS_FLASH_BASE has the final address (core view) + * CONFIG_SYS_FLASH_BASE_PHYS has the final address (IFC view) + * CONFIG_SYS_FLASH_BASE_PHYS_EARLY has the temporary IFC address + * CONFIG_SYS_TEXT_BASE is linked to 0x60000000 for booting + */ +#define CONFIG_SYS_FLASH_BASE 0x60000000 +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_FLASH_BASE_PHYS_EARLY 0x00000000 + +#ifndef CONFIG_SYS_NO_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#endif + +/* I2C */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_MXC_I2C2 +#define CONFIG_SYS_I2C_MXC_I2C3 +#define CONFIG_SYS_I2C_MXC_I2C4 + +/* PCIe */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controller 1 */ +#define CONFIG_PCIE2 /* PCIE controller 2 */ +#define CONFIG_PCIE3 /* PCIE controller 3 */ +#define CONFIG_PCIE_LAYERSCAPE /* Use common FSL Layerscape PCIe code */ +#define FSL_PCIE_COMPAT "fsl,ls1043a-pcie" + +#define CONFIG_SYS_PCI_64BIT + +#define CONFIG_SYS_PCIE_CFG0_PHYS_OFF 0x00000000 +#define CONFIG_SYS_PCIE_CFG0_SIZE 0x00001000 /* 4k */ +#define CONFIG_SYS_PCIE_CFG1_PHYS_OFF 0x00001000 +#define CONFIG_SYS_PCIE_CFG1_SIZE 0x00001000 /* 4k */ + +#define CONFIG_SYS_PCIE_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE_IO_PHYS_OFF 0x00010000 +#define CONFIG_SYS_PCIE_IO_SIZE 0x00010000 /* 64k */ + +#define CONFIG_SYS_PCIE_MEM_BUS 0x40000000 +#define CONFIG_SYS_PCIE_MEM_PHYS_OFF 0x40000000 +#define CONFIG_SYS_PCIE_MEM_SIZE 0x40000000 /* 1G */ + +#ifdef CONFIG_PCI +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP +#define CONFIG_E1000 +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_CMD_PCI +#endif + +/* Command line configuration */ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_PING + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) +#define CONFIG_ARCH_EARLY_INIT_R +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 128 + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "kernel_addr=0x100000\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x61200000\0" \ + "kernel_load=0x807f0000\0" \ + "kernel_size=0x1000000\0" \ + "console=ttyAMA0,38400n8\0" + +#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ + "earlycon=uart8250,0x21c0500,115200" +#define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ + "$kernel_size && bootm $kernel_load" +#define CONFIG_BOOTDELAY 10 + +/* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_MAXARGS 64 /* max command args */ + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#endif /* __LS1043A_COMMON_H */ diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h new file mode 100644 index 0000000..1f66201 --- /dev/null +++ b/include/configs/ls1043ardb.h @@ -0,0 +1,191 @@ +/* + * Copyright 2015 Freescale Semiconductor + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1043ARDB_H__ +#define __LS1043ARDB_H__ + +#include "ls1043a_common.h" + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_SYS_TEXT_BASE 0x60100000 + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define CONFIG_LAYERSCAPE_NS_ACCESS +#define CONFIG_MISC_INIT_R + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_FSL_DDR_BIST +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef + +/* + * NOR Flash Definitions + */ +#define CONFIG_SYS_NOR_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +#define CONFIG_SYS_NOR_CSPR \ + (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) + +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_TRHZ_80) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TAVDS(0x0) | \ + FTIM0_NOR_TEAHC(0xc)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1c) | \ + FTIM1_NOR_TRAD_NOR(0xb) | \ + FTIM1_NOR_TSEQRAD_NOR(0x9)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x1) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x8) | \ + FTIM2_NOR_TWP(0x10)) +#define CONFIG_SYS_NOR_FTIM3 0 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS } + +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_SYS_WRITE_SWAPPED_DATA + +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* + * CPLD + */ +#define CONFIG_SYS_CPLD_BASE 0x7fb00000 +#define CPLD_BASE_PHYS CONFIG_SYS_CPLD_BASE + +#define CONFIG_SYS_CPLD_CSPR_EXT (0x0) +#define CONFIG_SYS_CPLD_CSPR (CSPR_PHYS_ADDR(CPLD_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_CPLD_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_CPLD_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_NOR_MODE_AVD_NOR | \ + CSOR_NOR_TRHZ_80) + +/* CPLD Timing parameters for IFC GPCM */ +#define CONFIG_SYS_CPLD_FTIM0 (FTIM0_GPCM_TACSE(0xf) | \ + FTIM0_GPCM_TEADC(0xf) | \ + FTIM0_GPCM_TEAHC(0xf)) +#define CONFIG_SYS_CPLD_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CPLD_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0xff)) +#define CONFIG_SYS_CPLD_FTIM3 0x0 + +/* IFC Timing Params */ +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_CPLD_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_CPLD_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_CPLD_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_CPLD_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_CPLD_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_CPLD_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_CPLD_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_CPLD_FTIM3 + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x53 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + +/* + * Environment + */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 + +#endif /* __LS1043ARDB_H__ */
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com --- V6: - No change. V5: - No change. V4: - Add enable_layerscape_ns_access() in fsl-layerscape/spl.c V3: - No change. V2: - Removed unecessary NAND_PAGE_SIZE in ls1043a_common.h. - Fixed "select SUPPORT_SPL" in arch/arm/Kconfig. - Used CONFIG_FSL_IFC instead of SPL_NAND_SUPPORT for init_early_memctl_regs() - Replaced ns_access.h with fsl_csu.h
arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/spl.c | 3 ++ board/freescale/ls1043ardb/README | 1 + board/freescale/ls1043ardb/cpld.c | 19 +++++++++ board/freescale/ls1043ardb/cpld.h | 1 + board/freescale/ls1043ardb/ls1043ardb_pbi.cfg | 14 +++++++ board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg | 7 ++++ configs/ls1043ardb_nand_defconfig | 4 ++ include/configs/ls1043a_common.h | 27 +++++++++++++ include/configs/ls1043ardb.h | 46 ++++++++++++++++++++++ 10 files changed, 123 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index bd99bfb..6584e85 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -634,6 +634,7 @@ config TARGET_LS1021ATWR config TARGET_LS1043ARDB bool "Support ls1043ardb" select ARM64 + select SUPPORT_SPL help Support for Freescale LS1043ARDB platform.
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 2f30d4b..ba551aa 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -71,6 +71,9 @@ void board_init_f(ulong dummy) /* Clear the BSS */ memset(__bss_start, 0, __bss_end - __bss_start);
+#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif board_init_r(NULL, 0); } #endif diff --git a/board/freescale/ls1043ardb/README b/board/freescale/ls1043ardb/README index d5925a9..4f15557 100644 --- a/board/freescale/ls1043ardb/README +++ b/board/freescale/ls1043ardb/README @@ -83,3 +83,4 @@ Start Address End Address Description Size Booting Options --------------- a) NOR boot +b) NAND boot diff --git a/board/freescale/ls1043ardb/cpld.c b/board/freescale/ls1043ardb/cpld.c index 3f1101e..f29383d 100644 --- a/board/freescale/ls1043ardb/cpld.c +++ b/board/freescale/ls1043ardb/cpld.c @@ -45,6 +45,22 @@ void cpld_set_defbank(void) CPLD_WRITE(global_rst, 1); }
+void cpld_set_nand(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_NAND; + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(system_rst, 1); +} + #ifdef DEBUG static void cpld_dump_regs(void) { @@ -91,6 +107,8 @@ int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (strcmp(argv[1], "reset") == 0) { if (strcmp(argv[2], "altbank") == 0) cpld_set_altbank(); + else if (strcmp(argv[2], "nand") == 0) + cpld_set_nand(); else cpld_set_defbank(); #ifdef DEBUG @@ -109,6 +127,7 @@ U_BOOT_CMD( "Reset the board or alternate bank", "reset: reset to default bank\n" "cpld reset altbank: reset to alternate bank\n" + "cpld reset nand: reset to boot from NAND flash\n" #ifdef DEBUG "cpld dump - display the CPLD registers\n" #endif diff --git a/board/freescale/ls1043ardb/cpld.h b/board/freescale/ls1043ardb/cpld.h index ea4efd8..5f43a8a 100644 --- a/board/freescale/ls1043ardb/cpld.h +++ b/board/freescale/ls1043ardb/cpld.h @@ -40,4 +40,5 @@ void cpld_rev_bit(unsigned char *value); #define CPLD_SW_MUX_BANK_SEL 0x40 #define CPLD_BANK_SEL_MASK 0x07 #define CPLD_BANK_SEL_ALTBANK 0x04 +#define CPLD_CFG_RCW_SRC_NAND 0x106 #endif diff --git a/board/freescale/ls1043ardb/ls1043ardb_pbi.cfg b/board/freescale/ls1043ardb/ls1043ardb_pbi.cfg new file mode 100644 index 0000000..f072274 --- /dev/null +++ b/board/freescale/ls1043ardb/ls1043ardb_pbi.cfg @@ -0,0 +1,14 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Alt base register +09570158 00001000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg b/board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg new file mode 100644 index 0000000..935ffc0 --- /dev/null +++ b/board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# serdes protocol +0810000f 0c000000 00000000 00000000 +14550002 80004012 e0106000 61002000 +00000000 00000000 00000000 00038800 +00000000 00001100 00000096 00000001 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig new file mode 100644 index 0000000..fffaca0 --- /dev/null +++ b/configs/ls1043ardb_nand_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" +CONFIG_ARM=y +CONFIG_TARGET_LS1043ARDB=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index a4577b0..222cb43 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -62,6 +62,33 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
+/* NAND SPL */ +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_PBL_PAD +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_TEXT_BASE 0x10000000 +#define CONFIG_SPL_MAX_SIZE 0x1a000 +#define CONFIG_SPL_STACK 0x1001d000 +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_SPL_MALLOC_START 0x80200000 +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_MONITOR_LEN 0xa0000 +#endif + /* IFC */ #define CONFIG_FSL_IFC /* diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 1f66201..8ac752e 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -12,7 +12,11 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+#if defined(CONFIG_NAND_BOOT) +#define CONFIG_SYS_TEXT_BASE 0x82000000 +#else #define CONFIG_SYS_TEXT_BASE 0x60100000 +#endif
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000 @@ -33,6 +37,14 @@ #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xdeadbeef
+#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1043ardb/ls1043ardb_pbi.cfg +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg +#endif + /* * NOR Flash Definitions */ @@ -116,6 +128,12 @@
+#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) +#endif + /* * CPLD */ @@ -144,6 +162,25 @@ #define CONFIG_SYS_CPLD_FTIM3 0x0
/* IFC Timing Params */ +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR_CSPR #define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK @@ -161,6 +198,7 @@ #define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 #define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif
#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_CPLD_CSPR_EXT #define CONFIG_SYS_CSPR2 CONFIG_SYS_CPLD_CSPR @@ -183,9 +221,17 @@ /* * Environment */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_NAND_BOOT) +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 +#endif
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - Change arch to layerscape. V3: - No change. V2: - No change.
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 12 +++ arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 6 ++ .../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 23 ++++ board/freescale/common/fman.c | 6 +- board/freescale/ls1043ardb/Makefile | 1 + board/freescale/ls1043ardb/eth.c | 77 +++++++++++++ board/freescale/ls1043ardb/ls1043ardb.c | 4 + doc/README.fsl-dpaa | 4 +- drivers/net/fm/Makefile | 1 + drivers/net/fm/init.c | 10 +- drivers/net/fm/ls1043.c | 119 +++++++++++++++++++++ include/configs/ls1043a_common.h | 12 +++ include/configs/ls1043ardb.h | 25 +++++ 13 files changed, 295 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index fe9d982..0cb0afa 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -274,6 +274,9 @@ static inline void final_mmu_setup(void) flush_dcache_range(gd->arch.tlb_addr, gd->arch.tlb_addr + gd->arch.tlb_size);
+#ifdef CONFIG_SYS_DPAA_FMAN + flush_dcache_all(); +#endif /* point TTBR to the new table */ el = current_el();
@@ -432,6 +435,9 @@ int print_cpuinfo(void) printf("\n Bus: %-4s MHz ", strmhz(buf, sysinfo.freq_systembus)); printf("DDR: %-4s MT/s", strmhz(buf, sysinfo.freq_ddrbus)); +#ifdef CONFIG_SYS_DPAA_FMAN + printf(" FMAN: %-4s MHz", strmhz(buf, sysinfo.freq_fman[0])); +#endif #ifdef CONFIG_FSL_LSCH3 printf(" DP-DDR: %-4s MT/s", strmhz(buf, sysinfo.freq_ddrbus2)); #endif @@ -468,6 +474,9 @@ int cpu_eth_init(bd_t *bis) #ifdef CONFIG_FSL_MC_ENET error = fsl_mc_ldpaa_init(bis); #endif +#ifdef CONFIG_FMAN_ENET + fm_standard_init(bis); +#endif return error; }
@@ -484,6 +493,9 @@ int arch_early_init_r(void) #ifdef CONFIG_SYS_HAS_SERDES fsl_serdes_init(); #endif +#ifdef CONFIG_FMAN_ENET + fman_enet_init(); +#endif return 0; }
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index aa88d34..9c841c2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -18,6 +18,12 @@ #include <asm/arch/mp.h> #endif
+int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc) +{ + return fdt_setprop_string(blob, offset, "phy-connection-type", + phy_string_for_interface(phyc)); +} + #ifdef CONFIG_MP void ft_fixup_cpu(void *blob) { diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index ea3723f..9d5bbe7 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -25,6 +25,9 @@ void get_sys_info(struct sys_info *sys_info) struct fsl_ifc ifc_regs = {(void *)CONFIG_SYS_IFC_ADDR, (void *)NULL}; u32 ccr; #endif +#ifdef CONFIG_SYS_DPAA_FMAN + u32 rcw_tmp; +#endif struct ccsr_clk *clk = (void *)(CONFIG_SYS_FSL_CLK_ADDR); unsigned int cpu; const u8 core_cplx_pll[8] = { @@ -79,6 +82,26 @@ void get_sys_info(struct sys_info *sys_info)
#define HWA_CGA_M1_CLK_SEL 0xe0000000 #define HWA_CGA_M1_CLK_SHIFT 29 +#ifdef CONFIG_SYS_DPAA_FMAN + rcw_tmp = in_be32(&gur->rcwsr[7]); + switch ((rcw_tmp & HWA_CGA_M1_CLK_SEL) >> HWA_CGA_M1_CLK_SHIFT) { + case 2: + sys_info->freq_fman[0] = freq_c_pll[0] / 2; + break; + case 3: + sys_info->freq_fman[0] = freq_c_pll[0] / 3; + break; + case 6: + sys_info->freq_fman[0] = freq_c_pll[1] / 2; + break; + case 7: + sys_info->freq_fman[0] = freq_c_pll[1] / 3; + break; + default: + printf("Error: Unknown FMan1 clock select!\n"); + break; + } +#endif
#define HWA_CGA_M2_CLK_SEL 0x00000007 #define HWA_CGA_M2_CLK_SHIFT 0 diff --git a/board/freescale/common/fman.c b/board/freescale/common/fman.c index 9dc5402..26cf517 100644 --- a/board/freescale/common/fman.c +++ b/board/freescale/common/fman.c @@ -1,5 +1,5 @@ /* - * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -10,7 +10,11 @@ #include <fdt_support.h>
#include <fm_eth.h> +#ifdef CONFIG_FSL_LAYERSCAPE +#include <asm/arch/fsl_serdes.h> +#else #include <asm/fsl_serdes.h> +#endif
/* * Given the following ... diff --git a/board/freescale/ls1043ardb/Makefile b/board/freescale/ls1043ardb/Makefile index dd17e2e..5fe1cc9 100644 --- a/board/freescale/ls1043ardb/Makefile +++ b/board/freescale/ls1043ardb/Makefile @@ -7,3 +7,4 @@ obj-y += cpld.o obj-y += ddr.o obj-y += ls1043ardb.o +obj-$(CONFIG_SYS_DPAA_FMAN) += eth.o diff --git a/board/freescale/ls1043ardb/eth.c b/board/freescale/ls1043ardb/eth.c new file mode 100644 index 0000000..61f2b5d --- /dev/null +++ b/board/freescale/ls1043ardb/eth.c @@ -0,0 +1,77 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_dtsec.h> +#include <fsl_mdio.h> +#include <malloc.h> + +#include "../common/fman.h" + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + int i; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + struct mii_dev *dev; + u32 srds_s1; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + + /* QSGMII on lane B, MAC 1/2/5/6 */ + fm_info_set_phy_address(FM1_DTSEC1, QSGMII_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, QSGMII_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, QSGMII_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, QSGMII_PORT4_PHY_ADDR); + + switch (srds_s1) { + case 0x1455: + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1043ARDB\n", + srds_s1); + break; + } + + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) + fm_info_set_mdio(i, dev); + + /* XFI on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); + dev = miiphy_get_dev_by_name(DEFAULT_FM_TGEC_MDIO_NAME); + fm_info_set_mdio(FM1_10GEC1, dev); + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 5b7f814..6c0dd3f 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -13,6 +13,7 @@ #include <hwconfig.h> #include <ahci.h> #include <scsi.h> +#include <fm_eth.h> #include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> @@ -108,6 +109,9 @@ int ft_board_setup(void *blob, bd_t *bd) { ft_cpu_setup(blob, bd);
+#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); +#endif return 0; }
diff --git a/doc/README.fsl-dpaa b/doc/README.fsl-dpaa index 0d8d4f6..3ef5eeb 100644 --- a/doc/README.fsl-dpaa +++ b/doc/README.fsl-dpaa @@ -2,9 +2,9 @@ This file documents Freescale DPAA-specific options.
FMan (Frame Manager) - CONFIG_FSL_FM_10GEC_REGULAR_NOTATION - on SoCs earlier(e.g. T4240, T2080), the notation between 10GEC and MAC as below: + on SoCs T4240, T2080, LS1043A, etc, the notation between 10GEC and MAC as below: 10GEC1->MAC9, 10GEC2->MAC10, 10GEC3->MAC1, 10GEC4->MAC2 - on SoCs later(e.g. T1024, etc), the notation between 10GEC and MAC as below: + on SoCs T1024, etc, the notation between 10GEC and MAC as below: 10GEC1->MAC1, 10GEC2->MAC2 so we introduce CONFIG_FSL_FM_10GEC_REGULAR_NOTATION to identify the new SoCs on which 10GEC enumeration is consistent with MAC enumeration. diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index d052fcb..a3c9f99 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -37,3 +37,4 @@ obj-$(CONFIG_PPC_T4160) += t4240.o obj-$(CONFIG_PPC_T4080) += t4240.o obj-$(CONFIG_PPC_B4420) += b4860.o obj-$(CONFIG_PPC_B4860) += b4860.o +obj-$(CONFIG_LS1043A) += ls1043.o diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index b3ff4c5..3a1de59 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -1,13 +1,17 @@ /* - * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011-2015 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ #include <errno.h> #include <common.h> #include <asm/io.h> -#include <asm/fsl_serdes.h> #include <fsl_mdio.h> +#ifdef CONFIG_FSL_LAYERSCAPE +#include <asm/arch/fsl_serdes.h> +#else +#include <asm/fsl_serdes.h> +#endif
#include "fm.h"
@@ -153,7 +157,9 @@ void fm_disable_port(enum fm_port port) return;
fm_info[i].enabled = 0; +#ifndef CONFIG_SYS_FMAN_V3 fman_disable_port(port); +#endif }
void fm_enable_port(enum fm_port port) diff --git a/drivers/net/fm/ls1043.c b/drivers/net/fm/ls1043.c new file mode 100644 index 0000000..cf2cc95 --- /dev/null +++ b/drivers/net/fm/ls1043.c @@ -0,0 +1,119 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <phy.h> +#include <fm_eth.h> +#include <asm/io.h> +#include <asm/arch/fsl_serdes.h> + +#define FSL_CHASSIS2_RCWSR13_EC1 0xe0000000 /* bits 416..418 */ +#define FSL_CHASSIS2_RCWSR13_EC1_DTSEC3_RGMII 0x00000000 +#define FSL_CHASSIS2_RCWSR13_EC1_GPIO 0x20000000 +#define FSL_CHASSIS2_RCWSR13_EC1_FTM 0xa0000000 +#define FSL_CHASSIS2_RCWSR13_EC2 0x1c000000 /* bits 419..421 */ +#define FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII 0x00000000 +#define FSL_CHASSIS2_RCWSR13_EC2_GPIO 0x04000000 +#define FSL_CHASSIS2_RCWSR13_EC2_1588 0x08000000 +#define FSL_CHASSIS2_RCWSR13_EC2_FTM 0x14000000 + +u32 port_to_devdisr[] = { + [FM1_DTSEC1] = FSL_CHASSIS2_DEVDISR2_DTSEC1_1, + [FM1_DTSEC2] = FSL_CHASSIS2_DEVDISR2_DTSEC1_2, + [FM1_DTSEC3] = FSL_CHASSIS2_DEVDISR2_DTSEC1_3, + [FM1_DTSEC4] = FSL_CHASSIS2_DEVDISR2_DTSEC1_4, + [FM1_DTSEC5] = FSL_CHASSIS2_DEVDISR2_DTSEC1_5, + [FM1_DTSEC6] = FSL_CHASSIS2_DEVDISR2_DTSEC1_6, + [FM1_DTSEC9] = FSL_CHASSIS2_DEVDISR2_DTSEC1_9, + [FM1_DTSEC10] = FSL_CHASSIS2_DEVDISR2_DTSEC1_10, + [FM1_10GEC1] = FSL_CHASSIS2_DEVDISR2_10GEC1_1, + [FM1_10GEC2] = FSL_CHASSIS2_DEVDISR2_10GEC1_2, + [FM1_10GEC3] = FSL_CHASSIS2_DEVDISR2_10GEC1_3, + [FM1_10GEC4] = FSL_CHASSIS2_DEVDISR2_10GEC1_4, +}; + +static int is_device_disabled(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 devdisr2 = in_be32(&gur->devdisr2); + + return port_to_devdisr[port] & devdisr2; +} + +void fman_disable_port(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + setbits_be32(&gur->devdisr2, port_to_devdisr[port]); +} + +phy_interface_t fman_port_enet_if(enum fm_port port) +{ + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 rcwsr13 = in_be32(&gur->rcwsr[13]); + + if (is_device_disabled(port)) { + printf("%s:%d: port(%d) is disabled\n", __func__, + __LINE__, port); + return PHY_INTERFACE_MODE_NONE; + } + + if ((port == FM1_10GEC1) && (is_serdes_configured(XFI_FM1_MAC9))) + return PHY_INTERFACE_MODE_XGMII; + + if ((port == FM1_DTSEC9) && (is_serdes_configured(XFI_FM1_MAC9))) + return PHY_INTERFACE_MODE_NONE; + + if (port == FM1_DTSEC3) + if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC1) == + FSL_CHASSIS2_RCWSR13_EC1_DTSEC3_RGMII) { + printf("%s:%d: port(FM1_DTSEC3) is OK\n", + __func__, __LINE__); + return PHY_INTERFACE_MODE_RGMII; + } + if (port == FM1_DTSEC4) + if ((rcwsr13 & FSL_CHASSIS2_RCWSR13_EC2) == + FSL_CHASSIS2_RCWSR13_EC2_DTSEC4_RGMII) { + printf("%s:%d: port(FM1_DTSEC4) is OK\n", + __func__, __LINE__); + return PHY_INTERFACE_MODE_RGMII; + } + + /* handle SGMII */ + switch (port) { + case FM1_DTSEC1: + case FM1_DTSEC2: + if ((port == FM1_DTSEC2) && + is_serdes_configured(SGMII_2500_FM1_DTSEC2)) + return PHY_INTERFACE_MODE_SGMII_2500; + case FM1_DTSEC5: + case FM1_DTSEC6: + case FM1_DTSEC9: + if (is_serdes_configured(SGMII_FM1_DTSEC1 + port - FM1_DTSEC1)) + return PHY_INTERFACE_MODE_SGMII; + else if ((port == FM1_DTSEC9) && + is_serdes_configured(SGMII_2500_FM1_DTSEC9)) + return PHY_INTERFACE_MODE_SGMII_2500; + break; + default: + break; + } + + /* handle QSGMII */ + switch (port) { + case FM1_DTSEC1: + case FM1_DTSEC2: + case FM1_DTSEC5: + case FM1_DTSEC6: + /* only MAC 1,2,5,6 available for QSGMII */ + if (is_serdes_configured(QSGMII_FM1_A)) + return PHY_INTERFACE_MODE_QSGMII; + break; + default: + break; + } + + return PHY_INTERFACE_MODE_NONE; +} diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 222cb43..557b19c 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -155,6 +155,18 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_PING
+/* FMan ucode */ +#define CONFIG_SYS_DPAA_FMAN +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_FM_MURAM_SIZE 0x60000 + +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +/* FMan fireware Pre-load address */ +#define CONFIG_SYS_FMAN_FW_ADDR 0x60300000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif + /* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) #define CONFIG_ARCH_EARLY_INIT_R diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 8ac752e..c776640 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -234,4 +234,29 @@ #define CONFIG_ENV_SIZE 0x20000 #endif
+/* FMan */ +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_CMD_MII +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ + +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_AQUANTIA + +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 + +#define QSGMII_PORT1_PHY_ADDR 0x4 +#define QSGMII_PORT2_PHY_ADDR 0x5 +#define QSGMII_PORT3_PHY_ADDR 0x6 +#define QSGMII_PORT4_PHY_ADDR 0x7 + +#define FM1_10GEC1_PHY_ADDR 0x1 + +#define CONFIG_ETHPRIME "FM1@DTSEC3" +#endif + #endif /* __LS1043ARDB_H__ */
This patch adds esdhc support for ls1043ardb.
Signed-off-by: Yangbo Lu yangbo.lu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - Use CONFIG_FSL_ESDHC to enable get_sdhc_freq(). - Merge lsch2 and lsch3 into layerscape. V3: - No change. V2: - No change.
.../arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 22 +++++++++++++++++++++- board/freescale/ls1043ardb/ls1043ardb.c | 1 + drivers/mmc/fsl_esdhc.c | 12 ++++++------ include/configs/ls1043a_common.h | 11 +++++++++++ include/fsl_esdhc.h | 2 +- 5 files changed, 40 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 9d5bbe7..6f6a588 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -25,7 +25,7 @@ void get_sys_info(struct sys_info *sys_info) struct fsl_ifc ifc_regs = {(void *)CONFIG_SYS_IFC_ADDR, (void *)NULL}; u32 ccr; #endif -#ifdef CONFIG_SYS_DPAA_FMAN +#if defined(CONFIG_FSL_ESDHC) || defined(CONFIG_SYS_DPAA_FMAN) u32 rcw_tmp; #endif struct ccsr_clk *clk = (void *)(CONFIG_SYS_FSL_CLK_ADDR); @@ -105,6 +105,11 @@ void get_sys_info(struct sys_info *sys_info)
#define HWA_CGA_M2_CLK_SEL 0x00000007 #define HWA_CGA_M2_CLK_SHIFT 0 +#ifdef CONFIG_FSL_ESDHC + rcw_tmp = in_be32(&gur->rcwsr[15]); + rcw_tmp = (rcw_tmp & HWA_CGA_M2_CLK_SEL) >> HWA_CGA_M2_CLK_SHIFT; + sys_info->freq_sdhc = freq_c_pll[1] / rcw_tmp; +#endif
#if defined(CONFIG_FSL_IFC) ccr = ifc_in32(&ifc_regs.gregs->ifc_ccr); @@ -123,6 +128,10 @@ int get_clocks(void) gd->bus_clk = sys_info.freq_systembus; gd->mem_clk = sys_info.freq_ddrbus;
+#ifdef CONFIG_FSL_ESDHC + gd->arch.sdhc_clk = sys_info.freq_sdhc; +#endif + if (gd->cpu_clk != 0) return 0; else @@ -139,6 +148,13 @@ ulong get_ddr_freq(ulong dummy) return gd->mem_clk; }
+#ifdef CONFIG_FSL_ESDHC +int get_sdhc_freq(ulong dummy) +{ + return gd->arch.sdhc_clk; +} +#endif + int get_serial_clock(void) { return gd->bus_clk; @@ -149,6 +165,10 @@ unsigned int mxc_get_clock(enum mxc_clock clk) switch (clk) { case MXC_I2C_CLK: return get_bus_freq(0); +#if defined(CONFIG_FSL_ESDHC) + case MXC_ESDHC_CLK: + return get_sdhc_freq(0); +#endif case MXC_DSPI_CLK: return get_bus_freq(0); case MXC_UART_CLK: diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 6c0dd3f..461a195 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -12,6 +12,7 @@ #include <asm/arch/soc.h> #include <hwconfig.h> #include <ahci.h> +#include <mmc.h> #include <scsi.h> #include <fm_eth.h> #include <fsl_csu.h> diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 0b37002..471d6ee 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -106,7 +106,7 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) xfertyp |= XFERTYP_RSPTYP_48;
#if defined(CONFIG_MX53) || defined(CONFIG_PPC_T4240) || \ - defined(CONFIG_LS102XA) || defined(CONFIG_LS2085A) + defined(CONFIG_LS102XA) || defined(CONFIG_FSL_LAYERSCAPE) if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) xfertyp |= XFERTYP_CMDTYP_ABORT; #endif @@ -184,7 +184,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) int timeout; struct fsl_esdhc_cfg *cfg = mmc->priv; struct fsl_esdhc *regs = (struct fsl_esdhc *)cfg->esdhc_base; -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE dma_addr_t addr; #endif uint wml_value; @@ -197,7 +197,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data)
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE addr = virt_to_phys((void *)(data->dest)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -223,7 +223,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, wml_value << 16); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE addr = virt_to_phys((void *)(data->src)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -277,7 +277,7 @@ static int esdhc_setup_data(struct mmc *mmc, struct mmc_data *data) static void check_and_invalidate_dcache_range (struct mmc_cmd *cmd, struct mmc_data *data) { -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE unsigned start = 0; #else unsigned start = (unsigned)data->dest ; @@ -285,7 +285,7 @@ static void check_and_invalidate_dcache_range unsigned size = roundup(ARCH_DMA_MINALIGN, data->blocks*data->blocksize); unsigned end = start+size ; -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE dma_addr_t addr;
addr = virt_to_phys((void *)(data->dest)); diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 557b19c..f1fc685 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -155,6 +155,17 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_PING
+/* MMC */ +#define CONFIG_MMC +#ifdef CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION +#endif + /* FMan ucode */ #define CONFIG_SYS_DPAA_FMAN #ifdef CONFIG_SYS_DPAA_FMAN diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 0d00b7d..aa1b4cf 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -166,7 +166,7 @@ #define ESDHC_VENDORSPEC_VSELECT 0x00000002 /* Use 1.8V */
struct fsl_esdhc_cfg { -#ifdef CONFIG_LS2085A +#ifdef CONFIG_FSL_LAYERSCAPE u64 esdhc_base; #else u32 esdhc_base;
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - No change. V4: - No change. V3: - Squash the add cpld command patch to it. V2: - No change.
board/freescale/ls1043ardb/README | 1 + board/freescale/ls1043ardb/cpld.c | 18 ++++++++++++++ board/freescale/ls1043ardb/cpld.h | 1 + board/freescale/ls1043ardb/ls1043ardb.c | 6 +++++ board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg | 7 ++++++ configs/ls1043ardb_sdcard_defconfig | 4 ++++ include/configs/ls1043a_common.h | 30 ++++++++++++++++++++++++ include/configs/ls1043ardb.h | 11 ++++++++- 8 files changed, 77 insertions(+), 1 deletion(-)
diff --git a/board/freescale/ls1043ardb/README b/board/freescale/ls1043ardb/README index 4f15557..0556e73 100644 --- a/board/freescale/ls1043ardb/README +++ b/board/freescale/ls1043ardb/README @@ -84,3 +84,4 @@ Booting Options --------------- a) NOR boot b) NAND boot +c) SD boot diff --git a/board/freescale/ls1043ardb/cpld.c b/board/freescale/ls1043ardb/cpld.c index f29383d..78c2824 100644 --- a/board/freescale/ls1043ardb/cpld.c +++ b/board/freescale/ls1043ardb/cpld.c @@ -61,6 +61,21 @@ void cpld_set_nand(void) CPLD_WRITE(system_rst, 1); }
+void cpld_set_sd(void) +{ + u16 reg = CPLD_CFG_RCW_SRC_SD; + u8 reg5 = (u8)(reg >> 1); + u8 reg6 = (u8)(reg & 1); + + cpld_rev_bit(®5); + + CPLD_WRITE(soft_mux_on, 1); + + CPLD_WRITE(cfg_rcw_src1, reg5); + CPLD_WRITE(cfg_rcw_src2, reg6); + + CPLD_WRITE(system_rst, 1); +} #ifdef DEBUG static void cpld_dump_regs(void) { @@ -109,6 +124,8 @@ int do_cpld(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) cpld_set_altbank(); else if (strcmp(argv[2], "nand") == 0) cpld_set_nand(); + else if (strcmp(argv[2], "sd") == 0) + cpld_set_sd(); else cpld_set_defbank(); #ifdef DEBUG @@ -128,6 +145,7 @@ U_BOOT_CMD( "reset: reset to default bank\n" "cpld reset altbank: reset to alternate bank\n" "cpld reset nand: reset to boot from NAND flash\n" + "cpld reset sd: reset to boot from SD card\n" #ifdef DEBUG "cpld dump - display the CPLD registers\n" #endif diff --git a/board/freescale/ls1043ardb/cpld.h b/board/freescale/ls1043ardb/cpld.h index 5f43a8a..bd59c0e 100644 --- a/board/freescale/ls1043ardb/cpld.h +++ b/board/freescale/ls1043ardb/cpld.h @@ -41,4 +41,5 @@ void cpld_rev_bit(unsigned char *value); #define CPLD_BANK_SEL_MASK 0x07 #define CPLD_BANK_SEL_ALTBANK 0x04 #define CPLD_CFG_RCW_SRC_NAND 0x106 +#define CPLD_CFG_RCW_SRC_SD 0x040 #endif diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 461a195..9032ed3 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -25,12 +25,17 @@ DECLARE_GLOBAL_DATA_PTR; int checkboard(void) { static const char *freq[3] = {"100.00MHZ", "156.25MHZ"}; +#ifndef CONFIG_SD_BOOT u8 cfg_rcw_src1, cfg_rcw_src2; u32 cfg_rcw_src; +#endif u32 sd1refclk_sel;
+#ifdef CONFIG_SD_BOOT + puts("SD\n"); +#else cfg_rcw_src1 = CPLD_READ(cfg_rcw_src1); cfg_rcw_src2 = CPLD_READ(cfg_rcw_src2); cpld_rev_bit(&cfg_rcw_src1); @@ -43,6 +48,7 @@ int checkboard(void) puts("NAND\n"); else printf("Invalid setting of SW4\n"); +#endif
printf("CPLD: V%x.%x\nPCBA: V%x.0\n", CPLD_READ(cpld_ver), CPLD_READ(cpld_ver_sub), CPLD_READ(pcba_ver)); diff --git a/board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg b/board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg new file mode 100644 index 0000000..28cd958 --- /dev/null +++ b/board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0810000f 0c000000 00000000 00000000 +14550002 80004012 60040000 61002000 +00000000 00000000 00000000 00038800 +00000000 00001100 00000096 00000001 diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig new file mode 100644 index 0000000..5fe0470 --- /dev/null +++ b/configs/ls1043ardb_sdcard_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" +CONFIG_ARM=y +CONFIG_TARGET_LS1043ARDB=y diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index f1fc685..5b61fcc 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -62,6 +62,36 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
+/* SD boot SPL */ +#ifdef CONFIG_SD_BOOT +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0xf0 +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x500 + +#define CONFIG_SPL_TEXT_BASE 0x10000000 +#define CONFIG_SPL_MAX_SIZE 0x1d000 +#define CONFIG_SPL_STACK 0x1001e000 +#define CONFIG_SPL_PAD_TO 0x1d000 + +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 +#define CONFIG_SYS_MONITOR_LEN 0xa0000 +#endif + /* NAND SPL */ #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PBL_PAD diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index c776640..307d947 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -12,7 +12,7 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
-#if defined(CONFIG_NAND_BOOT) +#if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) #define CONFIG_SYS_TEXT_BASE 0x82000000 #else #define CONFIG_SYS_TEXT_BASE 0x60100000 @@ -45,6 +45,10 @@ #define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043ardb/ls1043ardb_rcw_nand.cfg #endif
+#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043ardb/ls1043ardb_rcw_sd.cfg +#endif + /* * NOR Flash Definitions */ @@ -227,6 +231,11 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000)
After the secondary cores enter U-Boot, use CONFIG_ARMV8_MULTIENTRY to make secondary cores to excute in spin loop.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - New patch.
arch/arm/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 14 ++++++++++++++ include/configs/ls1043a_common.h | 3 +++ 3 files changed, 18 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6584e85..6e30a5d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -634,6 +634,7 @@ config TARGET_LS1021ATWR config TARGET_LS1043ARDB bool "Support ls1043ardb" select ARM64 + select ARMV8_MULTIENTRY select SUPPORT_SPL help Support for Freescale LS1043ARDB platform. diff --git a/arch/arm/cpu/armv8/fsl-layerscape/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c index 1b13d32..0d600db 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -25,7 +25,11 @@ phys_addr_t determine_mp_bootpg(void) int fsl_layerscape_wake_seconday_cores(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); +#ifdef CONFIG_FSL_LSCH3 struct ccsr_reset __iomem *rst = (void *)(CONFIG_SYS_FSL_RST_ADDR); +#elif defined(CONFIG_FSL_LSCH2) + struct ccsr_scfg __iomem *scfg = (void *)(CONFIG_SYS_FSL_SCFG_ADDR); +#endif u32 cores, cpu_up_mask = 1; int i, timeout = 10; u64 *table = get_spin_tbl_addr(); @@ -48,13 +52,23 @@ int fsl_layerscape_wake_seconday_cores(void)
printf("Waking secondary cores to start from %lx\n", gd->relocaddr);
+#ifdef CONFIG_FSL_LSCH3 gur_out32(&gur->bootlocptrh, (u32)(gd->relocaddr >> 32)); gur_out32(&gur->bootlocptrl, (u32)gd->relocaddr); gur_out32(&gur->scratchrw[6], 1); asm volatile("dsb st" : : : "memory"); rst->brrl = cores; asm volatile("dsb st" : : : "memory"); +#elif defined(CONFIG_FSL_LSCH2) + scfg_out32(&scfg->scratchrw[0], (u32)(gd->relocaddr >> 32)); + scfg_out32(&scfg->scratchrw[1], (u32)gd->relocaddr); + asm volatile("dsb st" : : : "memory"); + gur_out32(&gur->brrl, cores); + asm volatile("dsb st" : : : "memory");
+ /* Bootup online cores */ + scfg_out32(&scfg->corebcr, cores); +#endif /* This is needed as a precautionary measure. * If some code before this has accidentally released the secondary * cores then the pre-bootloader code will trap them in a "wfe" unless diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 5b61fcc..d245fc2 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -13,6 +13,7 @@ #define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH2 #define CONFIG_LS1043A +#define CONFIG_MP #define CONFIG_FSL_CLK #define CONFIG_GICV2
@@ -46,6 +47,8 @@ #define CONFIG_SYS_FSL_DDR_SDRAM_BASE_PHY 0 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE
+#define CPU_RELEASE_ADDR secondary_boot_func + /* Generic Timer Definitions */ #define COUNTER_FREQUENCY 25000000 /* 25MHz */
-----Original Message----- From: Gong Qianyu [mailto:b52263@rhuath.am.freescale.net] Sent: 2015年10月19日 19:59 To: u-boot@lists.denx.de Cc: Hu Mingkai-B21284; Sun York-R58495; Hou Zhiqiang-B48286; Xie Shaohui- B21989; Song Wenbin-B53747; Wood Scott-B07421; Kushwaha Prabhakar-B32579; Wang Huan-B18965; Gong Qianyu-B52263 Subject: [Patch V6 11/18] armv8/fsl_lsch3: Change arch to fsl-layerscape
There are two LS series processors are built on ARMv8 Layersacpe architecture currently, LS2085A and LS1043A. They are based on ARMv8 core although use different chassis, so create fsl-layerscape to refactor the common code for the LS series processors which also paves the way for adding LS1043A platform.
Qianyu, you lost my Signed-off.
Thanks, Zhqiang
On 10/19/2015 04:58 AM, Gong Qianyu wrote:
get_clocks() should not be limited by ESDHC.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
- Removed defines in PPC configs that have no need to use.
V2:
- No change.
common/board_f.c | 2 +- include/configs/colibri_vf.h | 1 + include/configs/ls1021aqds.h | 1 + include/configs/ls1021atwr.h | 1 + include/configs/ls2085aqds.h | 1 + include/configs/ls2085ardb.h | 1 + include/configs/m53evk.h | 1 + include/configs/mx25pdk.h | 1 + include/configs/mx35pdk.h | 1 + include/configs/mx51evk.h | 1 + include/configs/mx53ard.h | 1 + include/configs/mx53evk.h | 1 + include/configs/mx53loco.h | 1 + include/configs/mx53smd.h | 1 + include/configs/mx6_common.h | 1 + include/configs/mx7_common.h | 1 + include/configs/usbarmory.h | 1 + include/configs/vf610twr.h | 1 + include/configs/woodburn_common.h | 1 + 19 files changed, 19 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 613332e..1bb84b3 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -806,7 +806,7 @@ static init_fnc_t init_sequence_f[] = { #if defined(CONFIG_BOARD_POSTCLK_INIT) board_postclk_init, #endif -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_CLK
Qianyu,
I feel it is more like a hardware requirement to have clocks calculated for the rest to operate. Maybe CONFIG_SYS_FSL_CLK is slightly better fit? Anyway please add it to README to document the usage.
York
Config Security Level Register is different between different SoCs, so put the CSL register definition into the arch specific directory.
V6:
- No change.
V5:
- No change.
V4:
- No change.
V3:
- No change.
V2:
- Create include/fsl_csu.h instead of board/freescale/common/ns_access.h
arch/arm/include/asm/arch-ls102xa/ns_access.h | 103 ++++++++++++++++++++------ board/freescale/common/Makefile | 2 +- board/freescale/common/ns_access.c | 8 +- board/freescale/ls1021aqds/ls1021aqds.c | 101 ++----------------------- board/freescale/ls1021atwr/ls1021atwr.c | 92 +---------------------- include/configs/ls1021aqds.h | 2 +- include/configs/ls1021atwr.h | 2 +- include/fsl_csu.h | 34 +++++++++ 8 files changed, 136 insertions(+), 208 deletions(-)
<snip>
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 87d0578..51d2814 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -71,7 +71,7 @@ obj-$(CONFIG_P4080DS) += p_corenet/ obj-$(CONFIG_P5020DS) += p_corenet/ obj-$(CONFIG_P5040DS) += p_corenet/
-obj-$(CONFIG_LS102XA_NS_ACCESS) += ns_access.o +obj-$(CONFIG_LAYERSCAPE_NS_ACCESS) += ns_access.o
Looks like you missed two #ifdef CONFIG_LS102XA_NS_ACCESS in board/freescale/ls1021atwr/ls1021atwr.c.
York
-----Original Message----- From: Gong Qianyu [mailto:b52263@rhuath.am.freescale.net] Sent: 2015年10月19日 19:59 To: u-boot@lists.denx.de Cc: Hu Mingkai-B21284; Sun York-R58495; Hou Zhiqiang-B48286; Xie Shaohui- B21989; Song Wenbin-B53747; Wood Scott-B07421; Kushwaha Prabhakar-B32579; Wang Huan-B18965; Gong Qianyu-B52263 Subject: [Patch V6 01/18] armv7/ls1021a: move ns_access to common file
Thanks, Zhqiang
Gong Qianyu
Hou Zhiqiang
York Sun
