[U-Boot] [PATCH 00/11] Add support for Stratix 10 SoC
Add support for Stratix 10 SoC which is ARM64 based. This series of patches are tested with Stratix 10 SOC Virtual Platform that is available today.
Chin Liang See (11): arm: socfpga: stratix10: Add SOCFPGA Stratix10 base address arm: socfpga: rstmgr: Add Reset Manager for Stratix 10 arm: socfpga: rstmgr: Segregate the Reset Manager for Stratix 10 arm: socfpga: clkmgr: Segregate the Clock Manager for Stratix 10 arm: socfpga: fpgamgr: Segregate the FPGA Manager for Stratix 10 arm: socfpga: misc: Segregate the misc.c for Stratix 10 arm: socfpga: sysmgr: Fix casting warning when enabling ARM64 arm: socfpga: mmu: Add memory map layout for Stratix 10 SoC arm: socfpga: stratix10: Add board folder for Stratix 10 socdk arm: dts: socfpga: Add dts for Stratix 10 socdk arm: socfpga: Add support for Stratix 10 SoC dev kit
arch/arm/Kconfig | 7 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/socfpga_stratix10_socdk.dts | 64 ++++++++++ arch/arm/mach-socfpga/Kconfig | 10 ++ arch/arm/mach-socfpga/Makefile | 2 + arch/arm/mach-socfpga/clock_manager.c | 8 ++ arch/arm/mach-socfpga/fpga_manager.c | 4 + arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 48 ++++++++ arch/arm/mach-socfpga/include/mach/reset_manager.h | 32 +++++ arch/arm/mach-socfpga/misc.c | 12 ++ arch/arm/mach-socfpga/mmu-arm64.c | 71 +++++++++++ arch/arm/mach-socfpga/reset_manager.c | 12 ++ arch/arm/mach-socfpga/system_manager.c | 2 +- board/altera/stratix10-socdk/MAINTAINERS | 8 ++ board/altera/stratix10-socdk/Makefile | 7 ++ board/altera/stratix10-socdk/socfpga.c | 7 ++ configs/socfpga_stratix10_defconfig | 14 +++ include/configs/socfpga_stratix10_socdk.h | 135 +++++++++++++++++++++ 18 files changed, 441 insertions(+), 5 deletions(-) create mode 100755 arch/arm/dts/socfpga_stratix10_socdk.dts create mode 100755 arch/arm/mach-socfpga/include/mach/base_addr_s10.h create mode 100755 arch/arm/mach-socfpga/mmu-arm64.c create mode 100755 board/altera/stratix10-socdk/MAINTAINERS create mode 100755 board/altera/stratix10-socdk/Makefile create mode 100755 board/altera/stratix10-socdk/socfpga.c create mode 100755 configs/socfpga_stratix10_defconfig create mode 100644 include/configs/socfpga_stratix10_socdk.h
-- 2.2.2
Add base address header file for Stratix10 SoC
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/include/mach/base_addr_s10.h | 48 ++++++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100755 arch/arm/mach-socfpga/include/mach/base_addr_s10.h
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_s10.h b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h new file mode 100755 index 0000000..cd29a59 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/base_addr_s10.h @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SOCFPGA_S10_BASE_HARDWARE_H_ +#define _SOCFPGA_S10_BASE_HARDWARE_H_ + +#define SOCFPGA_SMMU_ADDRESS 0xfa000000 +#define SOCFPGA_EMAC0_ADDRESS 0xff800000 +#define SOCFPGA_EMAC1_ADDRESS 0xff802000 +#define SOCFPGA_EMAC2_ADDRESS 0xff804000 +#define SOCFPGA_SDMMC_ADDRESS 0xff808000 +#define SOCFPGA_USB0_ADDRESS 0xffb00000 +#define SOCFPGA_USB1_ADDRESS 0xffb40000 +#define SOCFPGA_NANDREGS_ADDRESS 0xffb80000 +#define SOCFPGA_NANDDATA_ADDRESS 0xffb90000 +#define SOCFPGA_UART0_ADDRESS 0xffc02000 +#define SOCFPGA_UART1_ADDRESS 0xffc02100 +#define SOCFPGA_I2C0_ADDRESS 0xffc02800 +#define SOCFPGA_I2C1_ADDRESS 0xffc02900 +#define SOCFPGA_I2C2_ADDRESS 0xffc02a00 +#define SOCFPGA_I2C3_ADDRESS 0xffc02b00 +#define SOCFPGA_I2C4_ADDRESS 0xffc02c00 +#define SOCFPGA_SPTIMER0_ADDRESS 0xffc03000 +#define SOCFPGA_SPTIMER1_ADDRESS 0xffc03100 +#define SOCFPGA_GPIO0_ADDRESS 0xffc03200 +#define SOCFPGA_GPIO1_ADDRESS 0xffc03300 +#define SOCFPGA_SYSTIMER0_ADDRESS 0xffd00000 +#define SOCFPGA_SYSTIMER1_ADDRESS 0xffd00100 +#define SOCFPGA_L4WD0_ADDRESS 0xffd00200 +#define SOCFPGA_L4WD1_ADDRESS 0xffd00300 +#define SOCFPGA_L4WD2_ADDRESS 0xffd00400 +#define SOCFPGA_L4WD3_ADDRESS 0xffd00500 +#define SOCFPGA_CLKMGR_ADDRESS 0xffd10000 +#define SOCFPGA_RSTMGR_ADDRESS 0xffd11000 +#define SOCFPGA_SYSMGR_ADDRESS 0xffd12000 +#define SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS 0xffd13000 +#define SOCFPGA_DMANONSECURE_ADDRESS 0xffda0000 +#define SOCFPGA_DMASECURE_ADDRESS 0xffda1000 +#define SOCFPGA_SPIS0_ADDRESS 0xffda2000 +#define SOCFPGA_SPIS1_ADDRESS 0xffda3000 +#define SOCFPGA_SPIM0_ADDRESS 0xffda4000 +#define SOCFPGA_SPIM1_ADDRESS 0xffda5000 +#define SOCFPGA_OCRAM_ADDRESS 0xffe00000 + +#endif /* _SOCFPGA_S10_BASE_HARDWARE_H_ */
Acked-by: Marek Vasut marex@denx.de
- Copyright (C) 2016, Intel Corporation
- SPDX-License-Identifier: GPL-2.0
Add Reset Manager registers structure for Stratix 10 SoC
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/include/mach/reset_manager.h | 32 ++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 2f070f2..1f868da 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -15,6 +15,7 @@ void socfpga_bridges_reset(int enable); void socfpga_per_reset(u32 reset, int set); void socfpga_per_reset_all(void);
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) struct socfpga_reset_manager { u32 status; u32 ctrl; @@ -28,11 +29,42 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) +struct socfpga_reset_manager { + u32 status; + u32 mpu_rst_stat; + u32 misc_stat; + u32 padding1; + u32 hdsk_en; + u32 hdsk_req; + u32 hdsk_ack; + u32 hdsk_stall; + u32 mpu_mod_reset; + u32 per_mod_reset; /* stated as per0_mod_reset in S10 datasheet */ + u32 per2_mod_reset; /* stated as per1_mod_reset in S10 datasheet */ + u32 brg_mod_reset; + u32 padding2; + u32 cold_mod_reset; + u32 padding3; + u32 dbg_mod_reset; + u32 tap_mod_reset; + u32 padding4; + u32 padding5; + u32 brg_warm_mask; + u32 padding6[3]; + u32 tst_stat; + u32 padding7; + u32 hdsk_timeout; + u32 mpul2flushtimeout; + u32 dbghdsktimeout; +}; +#endif
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 #else #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 1 +#define RSTMGR_MPUMODRST_CORE0 1 #endif
- u32 status;
- u32 mpu_rst_stat;
- u32 misc_stat;
- u32 padding1;
- u32 hdsk_en;
- u32 hdsk_req;
- u32 hdsk_ack;
- u32 hdsk_stall;
- u32 mpu_mod_reset;
- u32 per_mod_reset; /* stated as per0_mod_reset in S10 datasheet */
- u32 per2_mod_reset; /* stated as per1_mod_reset in S10 datasheet */
- u32 brg_mod_reset;
- u32 padding2;
- u32 cold_mod_reset;
- u32 padding3;
- u32 dbg_mod_reset;
- u32 tap_mod_reset;
- u32 padding4;
- u32 padding5;
- u32 brg_warm_mask;
- u32 padding6[3];
- u32 tst_stat;
- u32 padding7;
- u32 hdsk_timeout;
- u32 mpul2flushtimeout;
- u32 dbghdsktimeout;
+}; +#endif
Segregate the Reset Manager to support both GEN5 SoC and Stratix 10 SoC.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/reset_manager.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c index b6beaa2..0fa5f1a 100644 --- a/arch/arm/mach-socfpga/reset_manager.c +++ b/arch/arm/mach-socfpga/reset_manager.c @@ -15,8 +15,10 @@ DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_reset_manager *reset_manager_base = (void *)SOCFPGA_RSTMGR_ADDRESS; +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; +#endif /* CONFIG_TARGET_SOCFPGA_GEN5) */
/* Assert or de-assert SoCFPGA reset manager reset. */ void socfpga_per_reset(u32 reset, int set) @@ -31,8 +33,10 @@ void socfpga_per_reset(u32 reset, int set) reg = &reset_manager_base->per2_mod_reset; else if (RSTMGR_BANK(reset) == 3) reg = &reset_manager_base->brg_mod_reset; +#ifdef CONFIG_TARGET_SOCFPGA_GEN5 else if (RSTMGR_BANK(reset) == 4) reg = &reset_manager_base->misc_mod_reset; +#endif /* CONFIG_TARGET_SOCFPGA_GEN5) */ else /* Invalid reset register, do nothing */ return;
@@ -60,9 +64,15 @@ void socfpga_per_reset_all(void) */ void reset_cpu(ulong addr) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) /* request a warm reset */ writel((1 << RSTMGR_CTRL_SWWARMRSTREQ_LSB), &reset_manager_base->ctrl); +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) + writel((1 << RSTMGR_MPUMODRST_CORE0), + &reset_manager_base->mpu_mod_reset); +#endif + /* * infinite loop here as watchdog will trigger and reset * the processor @@ -92,6 +102,7 @@ void socfpga_bridges_reset(int enable)
void socfpga_bridges_reset(int enable) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) const uint32_t l3mask = L3REGS_REMAP_LWHPS2FPGA_MASK | L3REGS_REMAP_HPS2FPGA_MASK | L3REGS_REMAP_OCRAM_MASK; @@ -116,5 +127,6 @@ void socfpga_bridges_reset(int enable) /* Remap the bridges into memory map */ writel(l3mask, SOCFPGA_L3REGS_ADDRESS); } +#endif /* CONFIG_TARGET_SOCFPGA_GEN5) */ } #endif
- writel((1 << RSTMGR_MPUMODRST_CORE0),
- infinite loop here as watchdog will trigger and reset
- the processor
Segregate the Clock Manager to support both GEN5 SoC and Stratix 10 SoC.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/clock_manager.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c index aa71636..0d67b3c 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -10,6 +10,7 @@
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) static const struct socfpga_clock_manager *clock_manager_base = (struct socfpga_clock_manager *)SOCFPGA_CLKMGR_ADDRESS;
@@ -446,9 +447,11 @@ unsigned int cm_get_l4_sp_clk_hz(void)
return clock; } +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
unsigned int cm_get_mmc_controller_clk_hz(void) { +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) uint32_t reg, clock = 0;
/* identify the source of MMC clock */ @@ -475,8 +478,12 @@ unsigned int cm_get_mmc_controller_clk_hz(void) /* further divide by 4 as we have fixed divider at wrapper */ clock /= 4; return clock; +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) + return 25000000; +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */ }
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) unsigned int cm_get_qspi_controller_clk_hz(void) { uint32_t reg, clock = 0; @@ -556,3 +563,4 @@ U_BOOT_CMD( "display clocks", "" ); +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
- return 25000000;
Are you sure this won't cause build breakage ? I believe this is still used by the cadence qspi driver.
diff --git a/arch/arm/mach-socfpga/clock_manager.c b/arch/arm/mach -socfpga/clock_manager.c index aa71636..0d67b3c 100644 --- a/arch/arm/mach-socfpga/clock_manager.c +++ b/arch/arm/mach-socfpga/clock_manager.c @@ -10,6 +10,7 @@
- return 25000000;
That is a good question. As for SOC Virtual Platform, we are not enabling the QSPI controller.
Thanks Chin Liang
- return 25000000;
When stratix 10 ships, this will be left broken then ?
- return 25000000;
Definitely not as we will enable and validate this against emulation in coming weeks.
Thanks Chin Liang
- return 25000000;
Great, thanks. U-Boot 2016.09 is out on sept. 12 , so that should give you some space to clean this up.
Segregate the FPGA Manager to support both GEN5 SoC and Stratix 10 SoC.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/fpga_manager.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/mach-socfpga/fpga_manager.c b/arch/arm/mach-socfpga/fpga_manager.c index 43fd2fe..a01e062 100644 --- a/arch/arm/mach-socfpga/fpga_manager.c +++ b/arch/arm/mach-socfpga/fpga_manager.c @@ -20,6 +20,8 @@ DECLARE_GLOBAL_DATA_PTR; /* Timeout count */ #define FPGA_TIMEOUT_CNT 0x1000000
+#if defined(CONFIG_TARGET_SOCFPGA_GEN5) + static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS;
@@ -76,3 +78,5 @@ int fpgamgr_poll_fpga_ready(void)
return 0; } + +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
return 0; }
Did you just disable the whole file ? If so, then just don't compile it at all, just add conditional into the Makefile.
diff --git a/arch/arm/mach-socfpga/fpga_manager.c b/arch/arm/mach -socfpga/fpga_manager.c index 43fd2fe..a01e062 100644 --- a/arch/arm/mach-socfpga/fpga_manager.c +++ b/arch/arm/mach-socfpga/fpga_manager.c @@ -20,6 +20,8 @@ DECLARE_GLOBAL_DATA_PTR; /* Timeout count */ #define FPGA_TIMEOUT_CNT 0x1000000
return 0; }
Yes, I just realize that :) I shall fix the Makefile instead of this patch.
Thanks Chin Liang
Segregate the misc.c to support both GEN5 SoC and Stratix 10 SoC.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/misc.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 5cbd8a4..295121f 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -24,6 +24,8 @@
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 + static struct pl310_regs *const pl310 = (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static struct socfpga_system_manager *sysmgr_regs = @@ -34,6 +36,7 @@ static struct nic301_registers *nic301_regs = (struct nic301_registers *)SOCFPGA_L3REGS_ADDRESS; static struct scu_registers *scu_regs = (struct scu_registers *)SOCFPGA_MPUSCU_ADDRESS; +#endif
int dram_init(void) { @@ -41,6 +44,7 @@ int dram_init(void) return 0; }
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 void enable_caches(void) { #ifndef CONFIG_SYS_ICACHE_OFF @@ -246,6 +250,7 @@ static int socfpga_fpga_id(const bool print_id) socfpga_fpga_model[i].name, version); return i; } +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
/* * Print CPU information @@ -253,14 +258,20 @@ static int socfpga_fpga_id(const bool print_id) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { +#ifdef CONFIG_TARGET_SOCFPGA_GEN5 const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; puts("CPU: Altera SoCFPGA Platform\n"); socfpga_fpga_id(1); printf("BOOT: %s\n", bsel_str[bsel].name); +#elif defined(CONFIG_TARGET_SOCFPGA_STRATIX10) + puts("CPU: Altera SoCFPGA Platform\n"); + puts("FPGA: Altera Stratix 10\n"); +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */ return 0; } #endif
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) { @@ -469,3 +480,4 @@ U_BOOT_CMD( "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges\n" "" ); +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
- Print CPU information
- puts("CPU: Altera SoCFPGA Platform\n");
- puts("FPGA: Altera Stratix 10\n");
Can't you decode the boot mode and FPGA type instead ?
return 0; } #endif
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach -socfpga/misc.c index 5cbd8a4..295121f 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -24,6 +24,8 @@
That is a good question. This is now not available in SOC Virtual Platform. But will definitely enhance this in later stage with hardware available.
Thanks Chin Liang
return 0; } #endif
+#ifdef CONFIG_TARGET_SOCFPGA_GEN5 #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) { @@ -469,3 +480,4 @@ U_BOOT_CMD( "bridge disable - Enable HPS-to-FPGA, FPGA-to-HPS, LWHPS -to-FPGA bridges\n" "" ); +#endif /* CONFIG_TARGET_SOCFPGA_GEN5 */
What do you mean not available ? Does the VT not emulate the SoC precisely ?
The VT doesn't emulate the Secure Device Manager (SDM) part as its focusing on ARM64 for this phase.
Thanks Chin Liang
And the SDM is now the place from which you fish out the information about the FPGA and bootmode ?
Fix casting warning to pointer from integer of different size when enabling ARM64 support
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/system_manager.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c index 75a65f3..89161bd 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager.c @@ -56,7 +56,7 @@ static void populate_sysmgr_fpgaintf_module(void) */ void sysmgr_pinmux_init(void) { - uint32_t regs = (uint32_t)&sysmgr_regs->emacio[0]; + uint32_t *regs = (uint32_t *)&sysmgr_regs->emacio[0]; const u8 *sys_mgr_init_table; unsigned int len; int i;
What sort of error did you observe ?
- uint32_t *regs = (uint32_t *)&sysmgr_regs->emacio[0]; const u8 *sys_mgr_init_table; unsigned int len; int i;
The warning is triggered as ARM64 has build flag -Wpointer-to-int-cast and similar. Here is the build error log
arch/arm/mach-socfpga/system_manager.c: In function sysmgr_pinmux_init:
arch/arm/mach-socfpga/system_manager.c:59:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] uint32_t regs = (uint32_t)&sysmgr_regs ->emacio[0]; ^
In file included from arch/arm/mach-socfpga/system_manager.c:8:0:
./arch/arm/include/asm/io.h:78:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_putl(v,a) (*(volatile unsigned int *)(a) = (v)) ^ Thanks Chin Liang
diff --git a/arch/arm/mach-socfpga/system_manager.c b/arch/arm/mach -socfpga/system_manager.c index 75a65f3..89161bd 100644 --- a/arch/arm/mach-socfpga/system_manager.c +++ b/arch/arm/mach-socfpga/system_manager.c @@ -56,7 +56,7 @@ static void populate_sysmgr_fpgaintf_module(void) */ void sysmgr_pinmux_init(void) {
In file
I see ... Except the code below does regs += sizeof(regs); , which in the original case increments the address by 4 , but with your change, the increment would be 16 . So this patch breaks things.
btw it's not worth reposting patches while there is still ongoing discussion.
The warning is triggered as ARM64 has build flag -Wpointer-to-int -cast and similar. Here is the build error log
->emacio[0];
^ In file
int *)(a) = (v))
Relook back, this portion is not being used and hence not being validated. Will put #ifdef in place to skip out these code.
Thanks Chin Liang
->emacio[0];
^ In file
int *)(a) = (v))
Which portion is not used ? I don't understand why this patch is valid, in fact I think it is wrong.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/mach-socfpga/Makefile | 2 ++ arch/arm/mach-socfpga/mmu-arm64.c | 71 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 73 insertions(+) create mode 100755 arch/arm/mach-socfpga/mmu-arm64.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..af1cc01 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -12,6 +12,8 @@ obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
+obj-$(CONFIG_TARGET_SOCFPGA_STRATIX10) += mmu-arm64.o + # QTS-generated config file wrappers obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += scan_manager.o wrap_pll_config.o obj-$(CONFIG_SPL_BUILD) += wrap_iocsr_config.o wrap_pinmux_config.o \ diff --git a/arch/arm/mach-socfpga/mmu-arm64.c b/arch/arm/mach-socfpga/mmu-arm64.c new file mode 100755 index 0000000..3b73143 --- /dev/null +++ b/arch/arm/mach-socfpga/mmu-arm64.c @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct mm_region socfpga_stratix10_mem_map[] = { + { + /* MEM 2GB*/ + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* FPGA 1.5GB */ + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x60000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* DEVICE 142MB */ + .virt = 0xF7000000UL, + .phys = 0xF7000000UL, + .size = 0x08E00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* OCRAM 1MB but available 256KB */ + .virt = 0xFFE00000UL, + .phys = 0xFFE00000UL, + .size = 0x00100000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* DEVICE 32KB */ + .virt = 0xFFFC0000UL, + .phys = 0xFFFC0000UL, + .size = 0x00008000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* MEM 124GB */ + .virt = 0x0100000000UL, + .phys = 0x0100000000UL, + .size = 0x1F00000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE, + }, { + /* DEVICE 4GB */ + .virt = 0x2000000000UL, + .phys = 0x2000000000UL, + .size = 0x0100000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN, + }, { + /* List terminator */ + }, +}; + +struct mm_region *mem_map = socfpga_stratix10_mem_map;
Add board folder for Stratix 10 SoC development kit
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- board/altera/stratix10-socdk/MAINTAINERS | 8 ++++++++ board/altera/stratix10-socdk/Makefile | 7 +++++++ board/altera/stratix10-socdk/socfpga.c | 7 +++++++ 3 files changed, 22 insertions(+) create mode 100755 board/altera/stratix10-socdk/MAINTAINERS create mode 100755 board/altera/stratix10-socdk/Makefile create mode 100755 board/altera/stratix10-socdk/socfpga.c
diff --git a/board/altera/stratix10-socdk/MAINTAINERS b/board/altera/stratix10-socdk/MAINTAINERS new file mode 100755 index 0000000..06f8989 --- /dev/null +++ b/board/altera/stratix10-socdk/MAINTAINERS @@ -0,0 +1,8 @@ +SOCFPGA BOARD +M: Chin-Liang See clsee@altera.com +M: Dinh Nguyen dinguyen@opensource.altera.com +S: Maintained +F: board/altera/stratix10-socdk/ +F: include/configs/socfpga_stratix10_socdk.h +F: configs/socfpga_stratix10_defconfig + diff --git a/board/altera/stratix10-socdk/Makefile b/board/altera/stratix10-socdk/Makefile new file mode 100755 index 0000000..a0c8024 --- /dev/null +++ b/board/altera/stratix10-socdk/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2016, Intel Corporation +# +# SPDX-License-Identifier: GPL-2.0 +# + +obj-y := socfpga.o diff --git a/board/altera/stratix10-socdk/socfpga.c b/board/altera/stratix10-socdk/socfpga.c new file mode 100755 index 0000000..6778c04 --- /dev/null +++ b/board/altera/stratix10-socdk/socfpga.c @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h>
Directory, this is not Windows :-(
Oh, btw also use "separate", not "segregate", in the previous patches.
haha... used to the windows term :) Will change this
Yup, will fix
Thanks Chin Liang
Add device tree for Stratix 10 SoC development kit
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/socfpga_stratix10_socdk.dts | 64 ++++++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+), 1 deletion(-) create mode 100755 arch/arm/dts/socfpga_stratix10_socdk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 223124e..c5e2d3c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -127,7 +127,8 @@ dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_cyclone5_sockit.dtb \ socfpga_cyclone5_socrates.dtb \ socfpga_cyclone5_sr1500.dtb \ - socfpga_cyclone5_vining_fpga.dtb + socfpga_cyclone5_vining_fpga.dtb \ + socfpga_stratix10_socdk.dtb
dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts new file mode 100755 index 0000000..7a662ee --- /dev/null +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -0,0 +1,64 @@ +/* + * Copyright (C) 2016 Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +/dts-v1/; +/* First 4KB has trampoline code for secondary cores. */ +/memreserve/ 0x00000000 0x0001000; +#include "skeleton.dtsi" + +/ { + model = "Altera SOCFPGA Stratix 10 SoC Development Kit"; + compatible = "altr,socfpga-stratix10", "altr,socfpga"; + + #address-cells = <1>; + #size-cells = <1>; + + chosen { + bootargs = "console=ttyS0,115200"; + }; + + memory { + name = "memory"; + device_type = "memory"; + reg = <0x0 0x40000000>; /* 1GB */ + }; + + regulator_3_3v: 3-3-v-regulator { + compatible = "regulator-fixed"; + regulator-name = "3.3V"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + soc { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + device_type = "soc"; + ranges; + + mmc0: dwmmc0@0xff808000 { + compatible = "altr,socfpga-dw-mshc"; + reg = <0xff808000 0x1000>; + interrupts = <0 139 4>; + num-slots = <1>; + broken-cd; + bus-width = <4>; + fifo-depth = <0x400>; + #address-cells = <1>; + #size-cells = <0>; + cap-mmc-highspeed; + cap-sd-highspeed; + drvsel = <3>; + smplsel = <0>; + status = "okay"; + u-boot,dm-pre-reloc; + vmmc-supply = <®ulator_3_3v>; + vqmmc-supply = <®ulator_3_3v>; + }; + }; +}; +
- socfpga_cyclone5_vining_fpga.dtb \
- socfpga_stratix10_socdk.dtb
- Copyright (C) 2016 Intel Corporation
- model = "Altera SOCFPGA Stratix 10 SoC Development Kit";
- compatible = "altr,socfpga-stratix10", "altr,socfpga";
- #address-cells = <1>;
- #size-cells = <1>;
- chosen {
- memory {
name = "memory";
- regulator_3_3v: 3-3-v-regulator {
- soc {
#size-cells = <1>;
ranges;
num-slots = <1>;
broken-cd;
bus-width = <4>;
#size-cells = <0>;
cap-mmc-highspeed;
cap-sd-highspeed;
drvsel = <3>;
smplsel = <0>;
status = "okay";
Add support for Stratix 10 SoC development kit
Signed-off-by: Chin Liang See clsee@altera.com Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Ley Foon Tan lftan@altera.com --- arch/arm/Kconfig | 7 +- arch/arm/mach-socfpga/Kconfig | 10 +++ configs/socfpga_stratix10_defconfig | 14 ++++ include/configs/socfpga_stratix10_socdk.h | 135 ++++++++++++++++++++++++++++++ 4 files changed, 163 insertions(+), 3 deletions(-) create mode 100755 configs/socfpga_stratix10_defconfig create mode 100644 include/configs/socfpga_stratix10_socdk.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index aef901c..c8e8767 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -600,10 +600,11 @@ config ARCH_SNAPDRAGON
config ARCH_SOCFPGA bool "Altera SOCFPGA family" - select CPU_V7 - select SUPPORT_SPL + select CPU_V7 if !TARGET_SOCFPGA_STRATIX10 + select ARM64 if TARGET_SOCFPGA_STRATIX10 + select SUPPORT_SPL if !TARGET_SOCFPGA_STRATIX10 select OF_CONTROL - select SPL_OF_CONTROL + select SPL_OF_CONTROL if !TARGET_SOCFPGA_STRATIX10 select DM select DM_SPI_FLASH select DM_SPI diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 1a43c7b..4e3b238 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -11,6 +11,9 @@ config TARGET_SOCFPGA_CYCLONE5 config TARGET_SOCFPGA_GEN5 bool
+config TARGET_SOCFPGA_STRATIX10 + bool + choice prompt "Altera SOCFPGA board select" optional @@ -51,6 +54,10 @@ config TARGET_SOCFPGA_TERASIC_SOCKIT bool "Terasic SoCkit (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
+config TARGET_SOCFPGA_STRATIX10_SOCDK + bool "Altera SOCFPGA SoCDK (Stratix 10)" + select TARGET_SOCFPGA_STRATIX10 + endchoice
config SYS_BOARD @@ -63,6 +70,7 @@ config SYS_BOARD default "socrates" if TARGET_SOCFPGA_EBV_SOCRATES default "sr1500" if TARGET_SOCFPGA_SR1500 default "vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA + default "stratix10-socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK
config SYS_VENDOR default "altera" if TARGET_SOCFPGA_ARRIA5_SOCDK @@ -72,6 +80,7 @@ config SYS_VENDOR default "samtec" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA default "terasic" if TARGET_SOCFPGA_TERASIC_DE0_NANO default "terasic" if TARGET_SOCFPGA_TERASIC_SOCKIT + default "altera" if TARGET_SOCFPGA_STRATIX10_SOCDK
config SYS_SOC default "socfpga" @@ -86,5 +95,6 @@ config SYS_CONFIG_NAME default "socfpga_socrates" if TARGET_SOCFPGA_EBV_SOCRATES default "socfpga_sr1500" if TARGET_SOCFPGA_SR1500 default "socfpga_vining_fpga" if TARGET_SOCFPGA_SAMTEC_VINING_FPGA + default "socfpga_stratix10_socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK
endif diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig new file mode 100755 index 0000000..b17eb92 --- /dev/null +++ b/configs/socfpga_stratix10_defconfig @@ -0,0 +1,14 @@ +CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y +CONFIG_TARGET_SOCFPGA_STRATIX10=y +CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y +CONFIG_DEFAULT_DEVICE_TREE="socfpga_stratix10_socdk" +CONFIG_SYS_NS16550=y +# CONFIG_CMD_IMLS is not set +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_CMD_MMC=y +CONFIG_DM_MMC=y +CONFIG_CMD_FAT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_USE_TINY_PRINTF=y diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h new file mode 100644 index 0000000..758c995 --- /dev/null +++ b/include/configs/socfpga_stratix10_socdk.h @@ -0,0 +1,135 @@ +/* + * Copyright (C) 2016, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __CONFIG_SOCFGPA_STRATIX10_H__ +#define __CONFIG_SOCFGPA_STRATIX10_H__ + +#include <asm/arch/base_addr_s10.h> + +/* + * U-Boot general configurations + */ +#define CONFIG_SYS_TEXT_BASE 0x1000000 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_LOADADDR 0x80000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_REMAKE_ELF +# define COUNTER_FREQUENCY 0x01800000 + + +/* + * U-Boot console configurations + */ +#define CONFIG_IDENT_STRING "socfpga_stratix10" +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_LONGHELP +#define CONFIG_AUTO_COMPLETE +#define CONFIG_FAT_WRITE +#define CONFIG_DOS_PARTITION + + +/* + * U-Boot run time memory configurations + */ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x40000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) +#define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) + +/* + * U-Boot display configurations + */ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_BOARDINFO_LATE + +/* + * U-Boot environment configurations + */ +#define CONFIG_ENV_IS_NOWHERE 1 +#define CONFIG_ENV_SIZE 0x1000 + +/* + * Boot arguments passed to the boot command. The value of + * CONFIG_BOOTARGS goes into the environment value "bootargs". + * Do note the value will overide also the chosen node in FDT blob. + */ +#define CONFIG_BOOTARGS "rdinit=/sbin/init mem=2048M" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootimage=Image\0" \ + "fdt_addr=100\0" \ + "fdtimage=socfpga_stratix10_swvp.dtb\0" \ + "mmcroot=/dev/mmcblk0p2\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "booti ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:1 ${loadaddr} ${bootimage};" \ + "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ + +/* + * Generic Interrupt Controller Definitions + */ +#define CONFIG_GICV2 +#define GICD_BASE 0xFFFC1000 +#define GICC_BASE 0xFFFC2000 + +/* + * External memory configurations + */ +#define PHYS_SDRAM_1 0x0 +#define PHYS_SDRAM_1_SIZE 0x40000000 +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_MEMTEST_START 0 +#define CONFIG_SYS_MEMTEST_END 0x100000 + +/* + * Serial / UART configurations + */ +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS +#define CONFIG_SYS_NS16550_CLK 1000000 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* + * Timer & watchdog configurations + */ +#define CONFIG_SYS_TIMERBASE SOCFPGA_SYSTIMER0_ADDRESS +#define TIMER_LOAD_VAL 0xFFFFFFFF + +/* + * SDMMC configurations + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_GENERIC_MMC +#define CONFIG_DWMMC +#define CONFIG_SOCFPGA_DWMMC +#define CONFIG_SOCFPGA_DWMMC_FIFO_DEPTH 1024 +#define CONFIG_SYS_MMC_MAX_BLK_COUNT 256 +#endif +/* + * Flash configurations + */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_NO_FLASH + + +#endif /* __CONFIG_H */
- select CPU_V7
- select CPU_V7 if !TARGET_SOCFPGA_STRATIX10
- select ARM64 if TARGET_SOCFPGA_STRATIX10
- select SUPPORT_SPL if !TARGET_SOCFPGA_STRATIX10 select OF_CONTROL
- select SPL_OF_CONTROL if !TARGET_SOCFPGA_STRATIX10
Why is the SPL disabled ?
- bool
- bool "Altera SOCFPGA SoCDK (Stratix 10)"
- select TARGET_SOCFPGA_STRATIX10
endchoice
- default "stratix10-socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK
Keep all the lists sorted .
- default "altera" if TARGET_SOCFPGA_STRATIX10_SOCDK
- default "socfpga_stratix10_socdk" if TARGET_SOCFPGA_STRATIX10_SOCDK
endif
btw. what about Arria 10 ? Will it ever land ? And will I ever get a kit ? :)
- select CPU_V7
We will be having SPL for Stratix 10. It will added in later days as SPL main function is for DDR setup. This is not needed for SOC Virtual Platform now.
select DM select DM_SPI_FLASH select DM_SPI diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach -socfpga/Kconfig index 1a43c7b..4e3b238 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -11,6 +11,9 @@ config TARGET_SOCFPGA_CYCLONE5 config TARGET_SOCFPGA_GEN5 bool
- bool
endchoice
Noted, will fix this.
endif
Since S10 is good, I will help out the A10 upstreaming once S10 is intergrated. While for dev kit, let me work that out as we have A10 dev kit with production silicon :)
Thanks Chin Liang
- select CPU_V7
Please do things right from the start, add the SPL and skip the DRAM init if it's not needed.
- bool
endchoice
endif
The production silicon a10 is still not available ?
Thanks Chin Liang
select CPU_V7
select SUPPORT_SPL
That is my next to do list as I am enabling the Stratix 10 by phases. In this case, I shall repost this series once getting SPL available.
Thanks Chin Liang
bool
endchoice
endif
Thanks Chin Liang
select CPU_V7
select SUPPORT_SPL
That's fine. When do you see that happening ?
Chin Liang See
