[PATCH] Revert "tree: imx: remove old fit generator script"
This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73.
For right now, it's too close to the release to merge the series that allows for binman to be used to generate the final images, and also not break CI, and then also merge all of the series that convert currently broken platforms to use binman instead. So, bring back this script now and remove it again for real after the release.
Suggested-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Tom Rini trini@konsulko.com --- Makefile | 3 + arch/arm/mach-imx/mkimage_fit_atf.sh | 143 +++++++++++++++++++++++++++ 2 files changed, 146 insertions(+) create mode 100755 arch/arm/mach-imx/mkimage_fit_atf.sh
diff --git a/Makefile b/Makefile index ae9bfab91acf..0c478645c3a7 100644 --- a/Makefile +++ b/Makefile @@ -1343,6 +1343,9 @@ $(U_BOOT_ITS): $(subst ",,$(CONFIG_SPL_FIT_SOURCE)) else ifneq ($(CONFIG_USE_SPL_FIT_GENERATOR),) U_BOOT_ITS := u-boot.its +ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-imx/mkimage_fit_atf.sh") +U_BOOT_ITS_DEPS += u-boot-nodtb.bin +endif ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-rockchip/make_fit_atf.py") U_BOOT_ITS_DEPS += u-boot endif diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach-imx/mkimage_fit_atf.sh new file mode 100755 index 000000000000..2a17968794c1 --- /dev/null +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -0,0 +1,143 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to generate FIT image source for i.MX8MQ boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +[ -z "$BL31" ] && BL31="bl31.bin" +[ -z "$TEE_LOAD_ADDR" ] && TEE_LOAD_ADDR="0xfe000000" +[ -z "$ATF_LOAD_ADDR" ] && ATF_LOAD_ADDR="0x00910000" +[ -z "$BL33_LOAD_ADDR" ] && BL33_LOAD_ADDR="0x40200000" + +if [ ! -f $BL31 ]; then + echo "ERROR: BL31 file $BL31 NOT found" >&2 + exit 0 +else + echo "$BL31 size: " >&2 + stat -c %s $BL31 >&2 +fi + +BL32="tee.bin" + +if [ ! -f $BL32 ]; then + BL32=/dev/null +else + echo "Building with TEE support, make sure your $BL31 is compiled with spd. If you do not want tee, please delete $BL31" >&2 + echo "$BL32 size: " >&2 + stat -c %s $BL32 >&2 +fi + +BL33="u-boot-nodtb.bin" + +if [ ! -f $BL33 ]; then + echo "ERROR: $BL33 file NOT found" >&2 + exit 0 +else + echo "u-boot-nodtb.bin size: " >&2 + stat -c %s u-boot-nodtb.bin >&2 +fi + +for dtname in $* +do + echo "$dtname size: " >&2 + stat -c %s $dtname >&2 +done + + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + + images { + uboot@1 { + description = "U-Boot (64-bit)"; + os = "u-boot"; + data = /incbin/("$BL33"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <$BL33_LOAD_ADDR>; + }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt@$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + compression = "none"; + }; +__FDT_IMAGE_EOF +cnt=$((cnt+1)) +done + +cat << __HEADER_EOF + atf@1 { + description = "ARM Trusted Firmware"; + os = "arm-trusted-firmware"; + data = /incbin/("$BL31"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <$ATF_LOAD_ADDR>; + entry = <$ATF_LOAD_ADDR>; + }; +__HEADER_EOF + +if [ -f $BL32 ]; then +cat << __HEADER_EOF + tee@1 { + description = "TEE firmware"; + data = /incbin/("$BL32"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <$TEE_LOAD_ADDR>; + entry = <$TEE_LOAD_ADDR>; + }; +__HEADER_EOF +fi + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config@1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do +if [ -f $BL32 ]; then +cat << __CONF_SECTION_EOF + config@$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot@1"; + loadables = "atf@1", "tee@1"; + fdt = "fdt@$cnt"; + }; +__CONF_SECTION_EOF +else +cat << __CONF_SECTION1_EOF + config@$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot@1"; + loadables = "atf@1"; + fdt = "fdt@$cnt"; + }; +__CONF_SECTION1_EOF +fi +cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF
Hello Tom,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini Sent: Thursday, January 6, 2022 7:52 PM To: u-boot@lists.denx.de Cc: Tim Harvey tharvey@gateworks.com Subject: [PATCH] Revert "tree: imx: remove old fit generator script"
Please note that this might not work, as the FIT generator script would generate ITS with '@' symbols which are not compatible with mkimage due to CVE-2021-27138. This revert should be complemented with the fix to remove those '@' symbols as well.
diff --git a/Makefile b/Makefile index ae9bfab91acf..0c478645c3a7 100644 --- a/Makefile +++ b/Makefile @@ -1343,6 +1343,9 @@ $(U_BOOT_ITS): $(subst ",,$(CONFIG_SPL_FIT_SOURCE)) else ifneq ($(CONFIG_USE_SPL_FIT_GENERATOR),) U_BOOT_ITS := u-boot.its +ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-imx/mkimage_fit_atf.sh") +U_BOOT_ITS_DEPS += u-boot-nodtb.bin +endif ifeq ($(CONFIG_SPL_FIT_GENERATOR),"arch/arm/mach-rockchip/make_fit_atf.py") U_BOOT_ITS_DEPS += u-boot endif diff --git a/arch/arm/mach-imx/mkimage_fit_atf.sh b/arch/arm/mach- imx/mkimage_fit_atf.sh new file mode 100755 index 000000000000..2a17968794c1 --- /dev/null +++ b/arch/arm/mach-imx/mkimage_fit_atf.sh @@ -0,0 +1,143 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to generate FIT image source for i.MX8MQ boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...]
- echo "ERROR: BL31 file $BL31 NOT found" >&2
- exit 0
+else
- echo "$BL31 size: " >&2
- stat -c %s $BL31 >&2
+fi
+BL32="tee.bin"
- BL32=/dev/null
+else
- echo "Building with TEE support, make sure your $BL31 is compiled with
- echo "$BL32 size: " >&2
- stat -c %s $BL32 >&2
+fi
- echo "ERROR: $BL33 file NOT found" >&2
- exit 0
+else
- echo "u-boot-nodtb.bin size: " >&2
- stat -c %s u-boot-nodtb.bin >&2
+fi
- echo "$dtname size: " >&2
- stat -c %s $dtname >&2
+done
- description = "Configuration to load ATF before U-Boot";
- images {
uboot@1 {
This (and all other similar places) would be rejected by mkimage... :(
os = "u-boot";
arch = "arm64";
+__HEADER_EOF
- cat << __FDT_IMAGE_EOF
fdt@$cnt {
type = "flat_dt";
atf@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF
tee@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF +fi
- configurations {
+__CONF_HEADER_EOF
config@$cnt {
fdt = "fdt@$cnt";
config@$cnt {
fdt = "fdt@$cnt";
+cat << __ITS_EOF
+__ITS_EOF
2.25.1
-- andrey
On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote:
Hello Tom,
Correct, the revert is not enough anymore: MKIMAGE u-boot.itb u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: node has a unit name, but no reg property u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: node has a unit name, but no reg property u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: node has a unit name, but no reg property u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: node has a unit name, but no reg property u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: node has a unit name, but no reg property u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: node has a unit name, but no reg property u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: node has a unit name, but no reg property u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): /configurations/config@1: node has a unit name, but no reg property u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): /configurations/config@2: node has a unit name, but no reg property u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): /configurations/config@3: node has a unit name, but no reg property u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): /configurations/config@4: node has a unit name, but no reg property u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): /configurations/config@5: node has a unit name, but no reg property ./tools/mkimage: verify_header failed for FIT Image support with exit code 1 Makefile:1433: recipe for target 'u-boot.itb' failed make: *** [u-boot.itb] Error 1 make: *** Deleting file 'u-boot.itb' make: *** Waiting for unfinished jobs....
I don't know what had changed to cause this or when (again, I stopped worrying about it because I thought we were moving to binman for this release). There was a patch that resolved this from Oliver at https://lists.denx.de/pipermail/u-boot/2021-August/457997.html but I don't think that fully solves anything 'at this point' either.
Even with that applied to current master I then end up with: MKIMAGE flash.bin ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or directory arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed make[1]: *** [flash.bin] Error 1 make[1]: *** Deleting file 'flash.bin' Makefile:1526: recipe for target 'flash.bin' failed
At some point over the past couple of months that patch resolved the building issue when using the FIT generator but I also don't know what else has changed that now causes that to not work.
As Tom pointed out in another thread these build failures did not get caught by CI apparently because CI does a 'make all' which did not include the FIT images (that was accomplished with the 'flash.bin' target prior to binman conversion).
Is it too late to apply the CI fix and the pending binman conversions?
I know that my series has been reviewed by Marcel [1] and as far as I know didn't get merged simply because of the CI issue. It still applies and produces a valid flash.bin image. I was also able to merge Peng's series [2] which converts imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build flash.bin images for them
I tried to merge Adam's series that moves imx8mm_beacon to binman [3] and imx8mn_beacon to binman [4] but they no longer apply due to defconfig/Kconfig changes
That still leaves the following unbuildable with CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh"
Tim [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822
exit 0
+else
+fi
+BL32="tee.bin"
BL32=/dev/null
+else
+fi
exit 0
+else
+fi
+done
images {
uboot@1 {
os = "u-boot";
arch = "arm64";
+__HEADER_EOF
fdt@$cnt {
type = "flat_dt";
atf@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF
tee@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF +fi
configurations {
+__CONF_HEADER_EOF
config@$cnt {
fdt = "fdt@$cnt";
config@$cnt {
fdt = "fdt@$cnt";
+cat << __ITS_EOF
+__ITS_EOF
2.25.1
-- andrey
Hello Tom,
Tom,
I'm not familiar with the U-boot CI tool. Is it a show-stopper that it does not build for boards using binman for release? From what you mentioned in another thread it was never building the flash.bin target for the boards using the FIT generator anyway.
Tim
exit 0
+else
+fi
+BL32="tee.bin"
BL32=/dev/null
+else
+fi
exit 0
+else
+fi
+done
images {
uboot@1 {
os = "u-boot";
arch = "arm64";
+__HEADER_EOF
fdt@$cnt {
type = "flat_dt";
atf@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF
tee@1 {
type = "firmware";
arch = "arm64";
+__HEADER_EOF +fi
configurations {
+__CONF_HEADER_EOF
config@$cnt {
fdt = "fdt@$cnt";
config@$cnt {
fdt = "fdt@$cnt";
+cat << __ITS_EOF
+__ITS_EOF
2.25.1
-- andrey
Hello Tom,
Tom,
It's at https://u-boot.readthedocs.io/en/latest/develop/ci_testing.html (and in-tree under doc/develop/ci_testing.rst).
Yes, breaking CI is a ship-stopper. That all of these boards were not previously building the final image as part of "all" is a problem.
So, here's what I'm at right now. I've grabbed Heiko's patch. Everything is currently visible at https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... and with this, we get some boards building and complaining as expected: aarch64: w+ imx8mn_evk +(imx8mn_evk) Image 'main-section' is missing external blobs and is non-functional: blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 +(imx8mn_evk) Image 'main-section' is missing external blobs and is non-functional: blob-ext +(imx8mn_evk) +(imx8mn_evk) Some images are invalid
But others are: aarch64: + imx8mn_beacon_2g +(imx8mn_beacon_2g) ===================== WARNING ====================== +(imx8mn_beacon_2g) This board uses CONFIG_SPL_FIT_GENERATOR. Please migrate +(imx8mn_beacon_2g) to binman instead, to avoid the proliferation of +(imx8mn_beacon_2g) arch-specific scripts with no tests. +(imx8mn_beacon_2g) ==================================================== +(imx8mn_beacon_2g) Image 'main-section' is missing external blobs and is non-functional: blob- ext@1 blob-ext@2 blob-ext@3 blob-ext@4 +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': spl/u-boot-spl-ddr.bin: Can't ope n: No such file or directory +(imx8mn_beacon_2g) +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2
and that's the problem to fix still, that ddr bin being faked out, in CI. I think I see how to do that however, and I'm going to test that out locally and then shoot this at CI and see what happens.
Hello Tom,
script"
that
also not
currently
script now
would
due
code 1
directory
Tom,
The beacon boards are mine. I can work on this one today. Do I just grab the binman updates and apply it to master and fix it from that starting point?
adam
-- Tom
Hello Tom,
script"
that
also not
currently
script now
would
due
code 1
directory
Tom,
So, yes, grabbing the series from the above link and applying it on top of master, and making builds work with fake binaries would be very helpful. As best I can tell there's still something missing with making fake blobs link and not fail. For example, imx8mm_venice is part of the series above but still fails with 'make BINMAN_FAKE_EXT_BLOBS=1 ...': Image 'main-section:u-boot-spl-ddr' has faked external blobs and is non-functional: lpddr4_pmu_train_1d_imem.bin lpddr4_pmu_train_1d_dmem.bin lpddr4_pmu_train_2d_imem.bin lpddr4_pmu_train_2d_dmem.bin Image 'main-section' is missing external blobs and is non-functional: atf_blob blob-ext Wrote map file './imx-boot.map' to show errors binman: Node '/binman/imx-boot/blob-ext@1': Offset 0x0 (0) overlaps with previous entry '/binman/imx-boot/uboot' ending at 0x1aee08 (1764872)
And that last error is the real problem.
Hello Tom,
> -----Original Message----- > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom
Rini
> Sent: Thursday, January 6, 2022 7:52 PM > To: u-boot@lists.denx.de > Cc: Tim Harvey tharvey@gateworks.com > Subject: [PATCH] Revert "tree: imx: remove old fit generator
script"
> > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > For right now, it's too close to the release to merge the
series
that
also not
currently
script now
would
mkimage
due
fix to
/images/uboot@1:
property
property
property
property
property
exit
code 1
stopped
this
but I
directory
failed
the
what
get
conversions?
as I
build
[3]
Tom,
It's at
target
is
grab
From what I can tell looking at the imx8mm_venice board is that
the imx8mm-u-boot.dtsi has the binman nodes to build the image, but arch/arm/dts/imx8mm-venice-u-boot.dtsi duplicates that work, so there are two copies trying to occupy the same space. Deleting the &binman node from the venice-u-boot.dtsi file appears to make the problem go away, and binman is still making the image.
$ cat imx-boot.map ImagePos Offset Size Name 00000000 00000000 0011d778 main-section 00000000 00000000 00039000 spl 00057c00 00057c00 000c5b78 uboot
$ cat spl.map ImagePos Offset Size Name 00000000 00000000 00039000 main-section 00000000 00000000 00039000 mkimage
$ cat u-boot-spl-ddr.map ImagePos Offset Size Name 00000000 00000000 00036f5c main-section 00000000 00000000 0001ef5c u-boot-spl 00000000 00000000 0001dc40 u-boot-spl-nodtb 0001dc40 0001dc40 0000131c u-boot-spl-dtb 0001ef5c 0001ef5c 00008000 1d-imem 00026f5c 00026f5c 00004000 1d_dmem 0002af5c 0002af5c 00008000 2d_imem 00032f5c 00032f5c 00004000 2d_dmem
Tim,
Can you try deleting the &binman node from your mx8mm-venice-u-boot.dtsi file and see if the stock binman node in 8mm-u-boot-dtsi works for you? The new default one does for me on my Beacon 8mm board.
Tom,
I will submit another patch for the imx8mn_beacon boards to fix the build error on the 2g version. I forgot to update the second defconfig file when I pushed the patch for the first one. I have it working, but I need to clean it up.
adam
-- Tom
wrote:
On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote: > > Hello Tom, > > > -----Original Message----- > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom
Rini
> > Sent: Thursday, January 6, 2022 7:52 PM > > To: u-boot@lists.denx.de > > Cc: Tim Harvey tharvey@gateworks.com > > Subject: [PATCH] Revert "tree: imx: remove old fit generator
script"
> > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > For right now, it's too close to the release to merge the
series
that
also not
currently
script now
> > and remove it again for real after the release. > > Please note that this might not work, as the FIT generator script
would
mkimage
due
fix to
/images/uboot@1:
property
property
property
property
property
exit
code 1
stopped
this
but I
directory
failed
the
what
get
conversions?
as I
build
[3]
Tom,
It's at
target
is
grab
From what I can tell looking at the imx8mm_venice board is that the imx8mm-u-boot.dtsi has the binman nodes to build the image, but arch/arm/dts/imx8mm-venice-u-boot.dtsi duplicates that work, so there are two copies trying to occupy the same space. Deleting the &binman node from the venice-u-boot.dtsi file appears to make the problem go away, and binman is still making the image.
Tim,
Tom,
OK, thanks! I just confirmed that with the above series it's down to: imx8mn_beacon_2g imx8mm_venice kontron-sl-mx8mm phycore-imx8mm as the fails to build in CI boards: https://source.denx.de/u-boot/u-boot/-/jobs/372239 as part of https://source.denx.de/u-boot/u-boot/-/pipelines/10497
I feel at this point that worst-case I can come up with something to make venice and kontron link still given what you figured out above and shouldn't be any worse off than they are today. And that can go in v2022.01.
On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey <
tharvey@gateworks.com>
wrote:
> > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > andrey.zhizhikin@leica-geosystems.com wrote: > > > > Hello Tom, > > > > > -----Original Message----- > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of
Tom
Rini
> > > Sent: Thursday, January 6, 2022 7:52 PM > > > To: u-boot@lists.denx.de > > > Cc: Tim Harvey tharvey@gateworks.com > > > Subject: [PATCH] Revert "tree: imx: remove old fit
generator
script"
> > > > > > This reverts commit
series
that
and
also not
convert
currently
this
script now
> > > and remove it again for real after the release. > > > > Please note that this might not work, as the FIT generator
script
would
mkimage
due
the
fix to
> > remove those '@' symbols as well. > > Correct, the revert is not enough anymore: > MKIMAGE u-boot.itb > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg):
/images/uboot@1:
> node has a unit name, but no reg property > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg):
/images/fdt@1
> node has a unit name, but no reg property > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg):
/images/fdt@2
> node has a unit name, but no reg property > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg):
/images/fdt@3
> node has a unit name, but no reg property > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg):
/images/fdt@4
> node has a unit name, but no reg property > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg):
/images/fdt@5
> node has a unit name, but no reg property > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg):
/images/atf@1
> node has a unit name, but no reg property > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > /configurations/config@1: node has a unit name, but no reg
property
> u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > /configurations/config@2: node has a unit name, but no reg
property
> u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > /configurations/config@3: node has a unit name, but no reg
property
> u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > /configurations/config@4: node has a unit name, but no reg
property
> u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > /configurations/config@5: node has a unit name, but no reg
property
with
exit
code 1
> Makefile:1433: recipe for target 'u-boot.itb' failed > make: *** [u-boot.itb] Error 1 > make: *** Deleting file 'u-boot.itb' > make: *** Waiting for unfinished jobs.... > > I don't know what had changed to cause this or when (again, I
stopped
for
this
> release). There was a patch that resolved this from Oliver at > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html
but I
> don't think that fully solves anything 'at this point' either. > > Even with that applied to current master I then end up with: > MKIMAGE flash.bin > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such
file or
directory
failed
> make[1]: *** [flash.bin] Error 1 > make[1]: *** Deleting file 'flash.bin' > Makefile:1526: recipe for target 'flash.bin' failed > > At some point over the past couple of months that patch
resolved
the
know
what
> else has changed that now causes that to not work. > > As Tom pointed out in another thread these build failures did
not
get
not
'flash.bin'
> target prior to binman conversion). > > Is it too late to apply the CI fix and the pending binman
conversions?
far
as I
> know didn't get merged simply because of the CI issue. It still > applies and produces a valid flash.bin image. > I was also able to merge Peng's series [2] which converts > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able
to
build
> flash.bin images for them > > I tried to merge Adam's series that moves imx8mm_beacon to
binman
[3]
> and imx8mn_beacon to binman [4] but they no longer apply due to > defconfig/Kconfig changes > > That still leaves the following unbuildable with > CONFIG_SPL_FIT_GENERATOR =
> > Tim > [1]
> [2]
> [3]
> [4]
Tom,
It's at
target
not
expected:
Please
of
and
is
grab
starting
point?
making
the
with
node
Tim,
Tom,
when
I just submitted two patches against this WIP branch to remove the duplicate binman node from their respective u-boot.dtsi files as well. The kontron and phycore boards had the same issue as the venice board.
They were build-only tested.
-- Tom
On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com wrote: > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > Hello Tom, > > > > > > > -----Original Message----- > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom
Rini
> > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > To: u-boot@lists.denx.de > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator script" > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > For right now, it's too close to the release to merge the
series
that > > > > allows for binman to be used to generate the final images, and also not > > > > break CI, and then also merge all of the series that convert currently > > > > broken platforms to use binman instead. So, bring back this script now > > > > and remove it again for real after the release. > > > > > > Please note that this might not work, as the FIT generator script would > > > generate ITS with '@' symbols which are not compatible with
mkimage
due > > > to CVE-2021-27138. This revert should be complemented with the
fix to
> > > remove those '@' symbols as well. > > > > Correct, the revert is not enough anymore: > > MKIMAGE u-boot.itb > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg):
/images/uboot@1:
> > node has a unit name, but no reg property > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1
> > node has a unit name, but no reg property > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2
> > node has a unit name, but no reg property > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3
> > node has a unit name, but no reg property > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4
> > node has a unit name, but no reg property > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5
> > node has a unit name, but no reg property > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1
> > node has a unit name, but no reg property > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > /configurations/config@1: node has a unit name, but no reg
property
> > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > /configurations/config@2: node has a unit name, but no reg
property
> > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > /configurations/config@3: node has a unit name, but no reg
property
> > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > /configurations/config@4: node has a unit name, but no reg
property
> > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > /configurations/config@5: node has a unit name, but no reg
property
exit
code 1 > > Makefile:1433: recipe for target 'u-boot.itb' failed > > make: *** [u-boot.itb] Error 1 > > make: *** Deleting file 'u-boot.itb' > > make: *** Waiting for unfinished jobs.... > > > > I don't know what had changed to cause this or when (again, I
stopped
this
> > release). There was a patch that resolved this from Oliver at > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html
but I
> > don't think that fully solves anything 'at this point' either. > > > > Even with that applied to current master I then end up with: > > MKIMAGE flash.bin > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or directory > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin'
failed
> > make[1]: *** [flash.bin] Error 1 > > make[1]: *** Deleting file 'flash.bin' > > Makefile:1526: recipe for target 'flash.bin' failed > > > > At some point over the past couple of months that patch resolved
the
what
> > else has changed that now causes that to not work. > > > > As Tom pointed out in another thread these build failures did not
get
> > caught by CI apparently because CI does a 'make all' which did not > > include the FIT images (that was accomplished with the 'flash.bin' > > target prior to binman conversion). > > > > Is it too late to apply the CI fix and the pending binman
conversions?
as I
> > know didn't get merged simply because of the CI issue. It still > > applies and produces a valid flash.bin image. > > I was also able to merge Peng's series [2] which converts > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to
build
> > flash.bin images for them > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman
[3]
> > and imx8mn_beacon to binman [4] but they no longer apply due to > > defconfig/Kconfig changes > > > > That still leaves the following unbuildable with > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > >
> > > > Tim > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > Tom, > > I'm not familiar with the U-boot CI tool.
It's at
> Is it a show-stopper that it > does not build for boards using binman for release? From what you > mentioned in another thread it was never building the flash.bin
target
is
grab
Tim,
Tom,
Tom,
I just resent my '[v3] imx8mm_venice: switch to use binman to pack images' as well (had to re-send as I forgot to include u-boot list earlier).
Tim
wrote:
On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com wrote: > > Hello Tom, > > > -----Original Message----- > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > Sent: Thursday, January 6, 2022 7:52 PM > > To: u-boot@lists.denx.de > > Cc: Tim Harvey tharvey@gateworks.com > > Subject: [PATCH] Revert "tree: imx: remove old fit generator
script"
> > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > For right now, it's too close to the release to merge the series
that
also not
currently
script now
would
due
> to CVE-2021-27138. This revert should be complemented with the fix to > remove those '@' symbols as well.
code 1
directory
Tom,
Adam,
I don't quite follow. I don't see any binman nodes in arch/arm/dts/imx8mm-u-boot.dtsi.
I know that Marcel submitted a patch that added them (and I'm not sure if he added them yet in a way that was compatible with multiple fdt's) but this hasn't been merged yet so I don't see any duplicate binman nodes for venice.
Tim
Tim,
Tom,
adam
-- Tom
wrote:
> > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > andrey.zhizhikin@leica-geosystems.com wrote: > > > > Hello Tom, > > > > > -----Original Message----- > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > Sent: Thursday, January 6, 2022 7:52 PM > > > To: u-boot@lists.denx.de > > > Cc: Tim Harvey tharvey@gateworks.com > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator
script"
> > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > For right now, it's too close to the release to merge the series
that
also not
currently
script now
> > > and remove it again for real after the release. > > > > Please note that this might not work, as the FIT generator script
would
due
> > to CVE-2021-27138. This revert should be complemented with the fix to > > remove those '@' symbols as well. > > Correct, the revert is not enough anymore: > MKIMAGE u-boot.itb > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > node has a unit name, but no reg property > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > node has a unit name, but no reg property > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > node has a unit name, but no reg property > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > node has a unit name, but no reg property > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > node has a unit name, but no reg property > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > node has a unit name, but no reg property > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > node has a unit name, but no reg property > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > /configurations/config@1: node has a unit name, but no reg property > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > /configurations/config@2: node has a unit name, but no reg property > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > /configurations/config@3: node has a unit name, but no reg property > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > /configurations/config@4: node has a unit name, but no reg property > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > /configurations/config@5: node has a unit name, but no reg property > ./tools/mkimage: verify_header failed for FIT Image support with exit
code 1
> Makefile:1433: recipe for target 'u-boot.itb' failed > make: *** [u-boot.itb] Error 1 > make: *** Deleting file 'u-boot.itb' > make: *** Waiting for unfinished jobs.... > > I don't know what had changed to cause this or when (again, I stopped > worrying about it because I thought we were moving to binman for this > release). There was a patch that resolved this from Oliver at > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html but I > don't think that fully solves anything 'at this point' either. > > Even with that applied to current master I then end up with: > MKIMAGE flash.bin > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or
directory
> arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > make[1]: *** [flash.bin] Error 1 > make[1]: *** Deleting file 'flash.bin' > Makefile:1526: recipe for target 'flash.bin' failed > > At some point over the past couple of months that patch resolved the > building issue when using the FIT generator but I also don't know what > else has changed that now causes that to not work. > > As Tom pointed out in another thread these build failures did not get > caught by CI apparently because CI does a 'make all' which did not > include the FIT images (that was accomplished with the 'flash.bin' > target prior to binman conversion). > > Is it too late to apply the CI fix and the pending binman conversions? > > I know that my series has been reviewed by Marcel [1] and as far as I > know didn't get merged simply because of the CI issue. It still > applies and produces a valid flash.bin image. > I was also able to merge Peng's series [2] which converts > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > flash.bin images for them > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > and imx8mn_beacon to binman [4] but they no longer apply due to > defconfig/Kconfig changes > > That still leaves the following unbuildable with > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": >
> > Tim > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 >
Tom,
Adam,
Right, so this is with https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... applied and I did have to manually apply Marcel's 4/7 and 7/7, so maybe I mismerged something there too? The tree is also at https://github.com/trini/u-boot/tree/WIP/2022-01-07-imx8-and-buildman-update...
On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com wrote: > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > Hello Tom, > > > > > > > -----Original Message----- > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > To: u-boot@lists.denx.de > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator script" > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > For right now, it's too close to the release to merge the series that > > > > allows for binman to be used to generate the final images, and also not > > > > break CI, and then also merge all of the series that convert currently > > > > broken platforms to use binman instead. So, bring back this script now > > > > and remove it again for real after the release. > > > > > > Please note that this might not work, as the FIT generator script would > > > generate ITS with '@' symbols which are not compatible with mkimage due > > > to CVE-2021-27138. This revert should be complemented with the fix to > > > remove those '@' symbols as well. > > > > Correct, the revert is not enough anymore: > > MKIMAGE u-boot.itb > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > > node has a unit name, but no reg property > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > > node has a unit name, but no reg property > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > > node has a unit name, but no reg property > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > > node has a unit name, but no reg property > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > > node has a unit name, but no reg property > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > > node has a unit name, but no reg property > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > > node has a unit name, but no reg property > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > /configurations/config@1: node has a unit name, but no reg property > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > /configurations/config@2: node has a unit name, but no reg property > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > /configurations/config@3: node has a unit name, but no reg property > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > /configurations/config@4: node has a unit name, but no reg property > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > /configurations/config@5: node has a unit name, but no reg property > > ./tools/mkimage: verify_header failed for FIT Image support with exit code 1 > > Makefile:1433: recipe for target 'u-boot.itb' failed > > make: *** [u-boot.itb] Error 1 > > make: *** Deleting file 'u-boot.itb' > > make: *** Waiting for unfinished jobs.... > > > > I don't know what had changed to cause this or when (again, I stopped > > worrying about it because I thought we were moving to binman for this > > release). There was a patch that resolved this from Oliver at > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html but I > > don't think that fully solves anything 'at this point' either. > > > > Even with that applied to current master I then end up with: > > MKIMAGE flash.bin > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or directory > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > > make[1]: *** [flash.bin] Error 1 > > make[1]: *** Deleting file 'flash.bin' > > Makefile:1526: recipe for target 'flash.bin' failed > > > > At some point over the past couple of months that patch resolved the > > building issue when using the FIT generator but I also don't know what > > else has changed that now causes that to not work. > > > > As Tom pointed out in another thread these build failures did not get > > caught by CI apparently because CI does a 'make all' which did not > > include the FIT images (that was accomplished with the 'flash.bin' > > target prior to binman conversion). > > > > Is it too late to apply the CI fix and the pending binman conversions? > > > > I know that my series has been reviewed by Marcel [1] and as far as I > > know didn't get merged simply because of the CI issue. It still > > applies and produces a valid flash.bin image. > > I was also able to merge Peng's series [2] which converts > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > > flash.bin images for them > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > > and imx8mn_beacon to binman [4] but they no longer apply due to > > defconfig/Kconfig changes > > > > That still leaves the following unbuildable with > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > > configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > Tim > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > Tom, > > I'm not familiar with the U-boot CI tool.
> Is it a show-stopper that it > does not build for boards using binman for release? From what you > mentioned in another thread it was never building the flash.bin target > for the boards using the FIT generator anyway.
Adam,
Tom,
Thank you for helping with this. During the merge window we had a lot of collisions because of things moving to defconfig that I think caused a lot of imx patches to have to be rebased. Then as most of us were submitting binman patches this CI issue popped up and as Stefano was unavailable I think it all got left hanging. In the middle of that Marcel's patch moved binman nodes to a common place so some rebasing is needed there as well. Fun times!
Yes, I couldn't get all from your patchwork bundle to apply - I didn't try as hard as you to manually merge :)
I pulled your tree and see Marcel's patches there now. With the binman node removed from arch/arm/dts/imx8mm-venice-u-boot.dtsi venice works. I will submit a v3 for you that does this.
Tim
> On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com > wrote: > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > Hello Tom, > > > > > > > > > -----Original Message----- > > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > To: u-boot@lists.denx.de > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator > script" > > > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > > > For right now, it's too close to the release to merge the series > that > > > > > allows for binman to be used to generate the final images, and > also not > > > > > break CI, and then also merge all of the series that convert > currently > > > > > broken platforms to use binman instead. So, bring back this > script now > > > > > and remove it again for real after the release. > > > > > > > > Please note that this might not work, as the FIT generator script > would > > > > generate ITS with '@' symbols which are not compatible with mkimage > due > > > > to CVE-2021-27138. This revert should be complemented with the fix to > > > > remove those '@' symbols as well. > > > > > > Correct, the revert is not enough anymore: > > > MKIMAGE u-boot.itb > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > > > node has a unit name, but no reg property > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > > > node has a unit name, but no reg property > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > > > node has a unit name, but no reg property > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > > > node has a unit name, but no reg property > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > > > node has a unit name, but no reg property > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > > > node has a unit name, but no reg property > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > > > node has a unit name, but no reg property > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > /configurations/config@1: node has a unit name, but no reg property > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > /configurations/config@2: node has a unit name, but no reg property > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > /configurations/config@3: node has a unit name, but no reg property > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > /configurations/config@4: node has a unit name, but no reg property > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > /configurations/config@5: node has a unit name, but no reg property > > > ./tools/mkimage: verify_header failed for FIT Image support with exit > code 1 > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > make: *** [u-boot.itb] Error 1 > > > make: *** Deleting file 'u-boot.itb' > > > make: *** Waiting for unfinished jobs.... > > > > > > I don't know what had changed to cause this or when (again, I stopped > > > worrying about it because I thought we were moving to binman for this > > > release). There was a patch that resolved this from Oliver at > > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html but I > > > don't think that fully solves anything 'at this point' either. > > > > > > Even with that applied to current master I then end up with: > > > MKIMAGE flash.bin > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or > directory > > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > > > make[1]: *** [flash.bin] Error 1 > > > make[1]: *** Deleting file 'flash.bin' > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > At some point over the past couple of months that patch resolved the > > > building issue when using the FIT generator but I also don't know what > > > else has changed that now causes that to not work. > > > > > > As Tom pointed out in another thread these build failures did not get > > > caught by CI apparently because CI does a 'make all' which did not > > > include the FIT images (that was accomplished with the 'flash.bin' > > > target prior to binman conversion). > > > > > > Is it too late to apply the CI fix and the pending binman conversions? > > > > > > I know that my series has been reviewed by Marcel [1] and as far as I > > > know didn't get merged simply because of the CI issue. It still > > > applies and produces a valid flash.bin image. > > > I was also able to merge Peng's series [2] which converts > > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > > > flash.bin images for them > > > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > > > and imx8mn_beacon to binman [4] but they no longer apply due to > > > defconfig/Kconfig changes > > > > > > That still leaves the following unbuildable with > > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > > > > configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > > > Tim > > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > > > > Tom, > > > > I'm not familiar with the U-boot CI tool. > > It's at https://u-boot.readthedocs.io/en/latest/develop/ci_testing.html > (and in-tree under doc/develop/ci_testing.rst). > > > Is it a show-stopper that it > > does not build for boards using binman for release? From what you > > mentioned in another thread it was never building the flash.bin target > > for the boards using the FIT generator anyway. > > Yes, breaking CI is a ship-stopper. That all of these boards were not > previously building the final image as part of "all" is a problem. > > So, here's what I'm at right now. I've grabbed Heiko's patch. > Everything is currently visible at > > https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... > and with this, we get some boards building and complaining as expected: > aarch64: w+ imx8mn_evk > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > non-functional: blob-ext@1 > blob-ext@2 blob-ext@3 blob-ext@4 > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > non-functional: blob-ext > +(imx8mn_evk) > +(imx8mn_evk) Some images are invalid > > But others are: > aarch64: + imx8mn_beacon_2g > +(imx8mn_beacon_2g) ===================== WARNING ====================== > +(imx8mn_beacon_2g) This board uses CONFIG_SPL_FIT_GENERATOR. Please > migrate > +(imx8mn_beacon_2g) to binman instead, to avoid the proliferation of > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > +(imx8mn_beacon_2g) ==================================================== > +(imx8mn_beacon_2g) Image 'main-section' is missing external blobs and is > non-functional: blob- > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > ./mkimage.spl.mkimage -n spl/u-boot-spl > .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': > spl/u-boot-spl-ddr.bin: Can't ope > n: No such file or directory > +(imx8mn_beacon_2g) > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 > +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2 >
Adam,
Tom,
Great, thanks!
wrote:
On Fri, Jan 07, 2022 at 12:21:18PM -0600, Adam Ford wrote: > On Fri, Jan 7, 2022 at 11:38 AM Tom Rini trini@konsulko.com
wrote:
> > > On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey <
> > wrote: > > > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > > > Hello Tom, > > > > > > > > > > > -----Original Message----- > > > > > > From: U-Boot u-boot-bounces@lists.denx.de On
Behalf Of Tom Rini
> > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > > To: u-boot@lists.denx.de > > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit
generator
> > script" > > > > > > > > > > > > This reverts commit
the series
> > that > > > > > > allows for binman to be used to generate the final
images, and
> > also not > > > > > > break CI, and then also merge all of the series that
convert
> > currently > > > > > > broken platforms to use binman instead. So, bring
back this
> > script now > > > > > > and remove it again for real after the release. > > > > > > > > > > Please note that this might not work, as the FIT
generator script
> > would > > > > > generate ITS with '@' symbols which are not compatible
with mkimage
> > due > > > > > to CVE-2021-27138. This revert should be complemented
with the fix to
> > > > > remove those '@' symbols as well. > > > > > > > > Correct, the revert is not enough anymore: > > > > MKIMAGE u-boot.itb > > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg):
/images/uboot@1:
> > > > node has a unit name, but no reg property > > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg):
/images/fdt@1:
> > > > node has a unit name, but no reg property > > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg):
/images/fdt@2:
> > > > node has a unit name, but no reg property > > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg):
/images/fdt@3:
> > > > node has a unit name, but no reg property > > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg):
/images/fdt@4:
> > > > node has a unit name, but no reg property > > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg):
/images/fdt@5:
> > > > node has a unit name, but no reg property > > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg):
/images/atf@1:
> > > > node has a unit name, but no reg property > > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > > /configurations/config@1: node has a unit name, but no
reg property
> > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > > /configurations/config@2: node has a unit name, but no
reg property
> > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > > /configurations/config@3: node has a unit name, but no
reg property
> > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > > /configurations/config@4: node has a unit name, but no
reg property
> > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > > /configurations/config@5: node has a unit name, but no
reg property
support with exit
> > code 1 > > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > > make: *** [u-boot.itb] Error 1 > > > > make: *** Deleting file 'u-boot.itb' > > > > make: *** Waiting for unfinished jobs.... > > > > > > > > I don't know what had changed to cause this or when
(again, I stopped
binman for this
Oliver at
either.
with:
> > > > MKIMAGE flash.bin > > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No
such file or
> > directory > > > > arch/arm/mach-imx/Makefile:167: recipe for target
'flash.bin' failed
> > > > make[1]: *** [flash.bin] Error 1 > > > > make[1]: *** Deleting file 'flash.bin' > > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > > > At some point over the past couple of months that patch
resolved the
don't know what
> > > > else has changed that now causes that to not work. > > > > > > > > As Tom pointed out in another thread these build failures
did not get
which did not
'flash.bin'
> > > > target prior to binman conversion). > > > > > > > > Is it too late to apply the CI fix and the pending binman
conversions?
as far as I
still
> > > > applies and produces a valid flash.bin image. > > > > I was also able to merge Peng's series [2] which converts > > > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was
able to build
> > > > flash.bin images for them > > > > > > > > I tried to merge Adam's series that moves imx8mm_beacon
to binman [3]
due to
> > > > defconfig/Kconfig changes > > > > > > > > That still leaves the following unbuildable with > > > > CONFIG_SPL_FIT_GENERATOR =
> > > > > > > > Tim > > > > [1]
> > > > [2]
> > > > [3]
> > > > [4]
> > > > > > > > > > Tom, > > > > > > I'm not familiar with the U-boot CI tool. > > > > It's at
> > (and in-tree under doc/develop/ci_testing.rst). > > > > > Is it a show-stopper that it > > > does not build for boards using binman for release? From
what you
flash.bin target
> > > for the boards using the FIT generator anyway. > > > > Yes, breaking CI is a ship-stopper. That all of these boards
were not
problem.
> > > > So, here's what I'm at right now. I've grabbed Heiko's patch. > > Everything is currently visible at > > > >
expected:
> > aarch64: w+ imx8mn_evk > > +(imx8mn_evk) Image 'main-section' is missing external blobs
and is
> > non-functional: blob-ext@1 > > blob-ext@2 blob-ext@3 blob-ext@4 > > +(imx8mn_evk) Image 'main-section' is missing external blobs
and is
> > non-functional: blob-ext > > +(imx8mn_evk) > > +(imx8mn_evk) Some images are invalid > > > > But others are: > > aarch64: + imx8mn_beacon_2g > > +(imx8mn_beacon_2g) ===================== WARNING
Please
> > migrate > > +(imx8mn_beacon_2g) to binman instead, to avoid the
proliferation of
> > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > > +(imx8mn_beacon_2g)
blobs and is
> > non-functional: blob- > > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > > ./mkimage.spl.mkimage -n spl/u-boot-spl > > .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': > > spl/u-boot-spl-ddr.bin: Can't ope > > n: No such file or directory > > +(imx8mn_beacon_2g) > > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 > > +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2 > > > > The beacon boards are mine. I can work on this one today. Do
I just grab
starting
> point?
on top
making
of the
Adam,
sure
fdt's)
Tom,
Great, thanks!
I just sent a patch for the beacon_imx8mn_2g board against your WIP branch with the rest of the binman stuff already applied. Do you need me to rebase that patch on master and squash it with the other nano? I wasn't sure if the WIP would get merged as-is with updates.
adam
-- Tom
Hi Tim and Tom
> On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com > wrote: > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > Hello Tom, > > > > > > > > > -----Original Message----- > > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > To: u-boot@lists.denx.de > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator > script" > > > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > > > For right now, it's too close to the release to merge the series > that > > > > > allows for binman to be used to generate the final images, and > also not > > > > > break CI, and then also merge all of the series that convert > currently > > > > > broken platforms to use binman instead. So, bring back this > script now > > > > > and remove it again for real after the release. > > > > > > > > Please note that this might not work, as the FIT generator script > would > > > > generate ITS with '@' symbols which are not compatible with mkimage > due > > > > to CVE-2021-27138. This revert should be complemented with the fix to > > > > remove those '@' symbols as well. > > > > > > Correct, the revert is not enough anymore: > > > MKIMAGE u-boot.itb > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > > > node has a unit name, but no reg property > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > > > node has a unit name, but no reg property > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > > > node has a unit name, but no reg property > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > > > node has a unit name, but no reg property > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > > > node has a unit name, but no reg property > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > > > node has a unit name, but no reg property > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > > > node has a unit name, but no reg property > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > /configurations/config@1: node has a unit name, but no reg property > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > /configurations/config@2: node has a unit name, but no reg property > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > /configurations/config@3: node has a unit name, but no reg property > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > /configurations/config@4: node has a unit name, but no reg property > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > /configurations/config@5: node has a unit name, but no reg property > > > ./tools/mkimage: verify_header failed for FIT Image support with exit > code 1 > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > make: *** [u-boot.itb] Error 1 > > > make: *** Deleting file 'u-boot.itb' > > > make: *** Waiting for unfinished jobs.... > > > > > > I don't know what had changed to cause this or when (again, I stopped > > > worrying about it because I thought we were moving to binman for this > > > release). There was a patch that resolved this from Oliver at > > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html%C2%A0but I > > > don't think that fully solves anything 'at this point' either. > > > > > > Even with that applied to current master I then end up with: > > > MKIMAGE flash.bin > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or > directory > > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > > > make[1]: *** [flash.bin] Error 1 > > > make[1]: *** Deleting file 'flash.bin' > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > At some point over the past couple of months that patch resolved the > > > building issue when using the FIT generator but I also don't know what > > > else has changed that now causes that to not work. > > > > > > As Tom pointed out in another thread these build failures did not get > > > caught by CI apparently because CI does a 'make all' which did not > > > include the FIT images (that was accomplished with the 'flash.bin' > > > target prior to binman conversion). > > > > > > Is it too late to apply the CI fix and the pending binman conversions? > > > > > > I know that my series has been reviewed by Marcel [1] and as far as I > > > know didn't get merged simply because of the CI issue. It still > > > applies and produces a valid flash.bin image. > > > I was also able to merge Peng's series [2] which converts > > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > > > flash.bin images for them > > > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > > > and imx8mn_beacon to binman [4] but they no longer apply due to > > > defconfig/Kconfig changes > > > > > > That still leaves the following unbuildable with > > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > > > > configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > imx/mkimage_fit_atf.sh" > > > > configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > imx/mkimage_fit_atf.sh" > > > > configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > imx/mkimage_fit_atf.sh" > > > > configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > imx/mkimage_fit_atf.sh" > > > > > > Tim > > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > > > > Tom, > > > > I'm not familiar with the U-boot CI tool. > > It's at https://u-boot.readthedocs.io/en/latest/develop/ci_testing.html > (and in-tree under doc/develop/ci_testing.rst). > > > Is it a show-stopper that it > > does not build for boards using binman for release? From what you > > mentioned in another thread it was never building the flash.bin target > > for the boards using the FIT generator anyway. > > Yes, breaking CI is a ship-stopper. That all of these boards were not > previously building the final image as part of "all" is a problem. > > So, here's what I'm at right now. I've grabbed Heiko's patch. > Everything is currently visible at > > https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... > and with this, we get some boards building and complaining as expected: > aarch64: w+ imx8mn_evk > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > non-functional: blob-ext@1 > blob-ext@2 blob-ext@3 blob-ext@4 > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > non-functional: blob-ext > +(imx8mn_evk) > +(imx8mn_evk) Some images are invalid > > But others are: > aarch64: + imx8mn_beacon_2g > +(imx8mn_beacon_2g) ===================== WARNING ====================== > +(imx8mn_beacon_2g) This board uses CONFIG_SPL_FIT_GENERATOR. Please > migrate > +(imx8mn_beacon_2g) to binman instead, to avoid the proliferation of > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > +(imx8mn_beacon_2g) ==================================================== > +(imx8mn_beacon_2g) Image 'main-section' is missing external blobs and is > non-functional: blob- > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > ./mkimage.spl.mkimage -n spl/u-boot-spl > .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': > spl/u-boot-spl-ddr.bin: Can't ope > n: No such file or directory > +(imx8mn_beacon_2g) > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 > +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2 >
So, yes, grabbing the series from the above link and applying it on top of master, and making builds work with fake binaries would be very helpful. As best I can tell there's still something missing with making fake blobs link and not fail. For example, imx8mm_venice is part of the series above but still fails with 'make BINMAN_FAKE_EXT_BLOBS=1 ...': Image 'main-section:u-boot-spl-ddr' has faked external blobs and is non-functional: lpddr4_pmu_train_1d_imem.bin lpddr4_pmu_train_1d_dmem.bin lpddr4_pmu_train_2d_imem.bin lpddr4_pmu_train_2d_dmem.bin Image 'main-section' is missing external blobs and is non-functional: atf_blob blob-ext Wrote map file './imx-boot.map' to show errors binman: Node '/binman/imx-boot/blob-ext@1': Offset 0x0 (0) overlaps with previous entry '/binman/imx- boot/uboot' ending at 0x1aee08 (1764872)
Adam,
Tom,
I also quickly double checked everything and indeed somehow the removal of the binman stuff from arch/arm/dts/imx8mm-venice-u-boot.dtsi which I had in my 4th patch "[PATCH v3 4/7] arm64: dts: imx8mm: use common binman configuration" got lost. Otherwise it all looks good. Thanks!
Tim
Cheers
Marcel
On Fri, Jan 07, 2022 at 11:26:49PM +0100, Marcel Ziswiler wrote:
Hi Tim and Tom
On Fri, Jan 07, 2022 at 12:21:18PM -0600, Adam Ford wrote: > On Fri, Jan 7, 2022 at 11:38 AM Tom Rini trini@konsulko.com wrote: > > > On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com > > wrote: > > > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > > > Hello Tom, > > > > > > > > > > > -----Original Message----- > > > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > > To: u-boot@lists.denx.de > > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator > > script" > > > > > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > > > > > For right now, it's too close to the release to merge the series > > that > > > > > > allows for binman to be used to generate the final images, and > > also not > > > > > > break CI, and then also merge all of the series that convert > > currently > > > > > > broken platforms to use binman instead. So, bring back this > > script now > > > > > > and remove it again for real after the release. > > > > > > > > > > Please note that this might not work, as the FIT generator script > > would > > > > > generate ITS with '@' symbols which are not compatible with mkimage > > due > > > > > to CVE-2021-27138. This revert should be complemented with the fix to > > > > > remove those '@' symbols as well. > > > > > > > > Correct, the revert is not enough anymore: > > > > MKIMAGE u-boot.itb > > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > > > > node has a unit name, but no reg property > > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > > > > node has a unit name, but no reg property > > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > > > > node has a unit name, but no reg property > > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > > > > node has a unit name, but no reg property > > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > > > > node has a unit name, but no reg property > > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > > > > node has a unit name, but no reg property > > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > > > > node has a unit name, but no reg property > > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > > /configurations/config@1: node has a unit name, but no reg property > > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > > /configurations/config@2: node has a unit name, but no reg property > > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > > /configurations/config@3: node has a unit name, but no reg property > > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > > /configurations/config@4: node has a unit name, but no reg property > > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > > /configurations/config@5: node has a unit name, but no reg property > > > > ./tools/mkimage: verify_header failed for FIT Image support with exit > > code 1 > > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > > make: *** [u-boot.itb] Error 1 > > > > make: *** Deleting file 'u-boot.itb' > > > > make: *** Waiting for unfinished jobs.... > > > > > > > > I don't know what had changed to cause this or when (again, I stopped > > > > worrying about it because I thought we were moving to binman for this > > > > release). There was a patch that resolved this from Oliver at > > > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html%C2%A0but I > > > > don't think that fully solves anything 'at this point' either. > > > > > > > > Even with that applied to current master I then end up with: > > > > MKIMAGE flash.bin > > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or > > directory > > > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > > > > make[1]: *** [flash.bin] Error 1 > > > > make[1]: *** Deleting file 'flash.bin' > > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > > > At some point over the past couple of months that patch resolved the > > > > building issue when using the FIT generator but I also don't know what > > > > else has changed that now causes that to not work. > > > > > > > > As Tom pointed out in another thread these build failures did not get > > > > caught by CI apparently because CI does a 'make all' which did not > > > > include the FIT images (that was accomplished with the 'flash.bin' > > > > target prior to binman conversion). > > > > > > > > Is it too late to apply the CI fix and the pending binman conversions? > > > > > > > > I know that my series has been reviewed by Marcel [1] and as far as I > > > > know didn't get merged simply because of the CI issue. It still > > > > applies and produces a valid flash.bin image. > > > > I was also able to merge Peng's series [2] which converts > > > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > > > > flash.bin images for them > > > > > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > > > > and imx8mn_beacon to binman [4] but they no longer apply due to > > > > defconfig/Kconfig changes > > > > > > > > That still leaves the following unbuildable with > > > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > > > > > > configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > > > configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > imx/mkimage_fit_atf.sh" > > > > > > configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > imx/mkimage_fit_atf.sh" > > > > > > configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > > > configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > imx/mkimage_fit_atf.sh" > > > > > > configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > > > configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > imx/mkimage_fit_atf.sh" > > > > > > > > Tim > > > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > > > > > > > Tom, > > > > > > I'm not familiar with the U-boot CI tool. > > > > It's at https://u-boot.readthedocs.io/en/latest/develop/ci_testing.html > > (and in-tree under doc/develop/ci_testing.rst). > > > > > Is it a show-stopper that it > > > does not build for boards using binman for release? From what you > > > mentioned in another thread it was never building the flash.bin target > > > for the boards using the FIT generator anyway. > > > > Yes, breaking CI is a ship-stopper. That all of these boards were not > > previously building the final image as part of "all" is a problem. > > > > So, here's what I'm at right now. I've grabbed Heiko's patch. > > Everything is currently visible at > > > > https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... > > and with this, we get some boards building and complaining as expected: > > aarch64: w+ imx8mn_evk > > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > > non-functional: blob-ext@1 > > blob-ext@2 blob-ext@3 blob-ext@4 > > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > > non-functional: blob-ext > > +(imx8mn_evk) > > +(imx8mn_evk) Some images are invalid > > > > But others are: > > aarch64: + imx8mn_beacon_2g > > +(imx8mn_beacon_2g) ===================== WARNING ====================== > > +(imx8mn_beacon_2g) This board uses CONFIG_SPL_FIT_GENERATOR. Please > > migrate > > +(imx8mn_beacon_2g) to binman instead, to avoid the proliferation of > > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > > +(imx8mn_beacon_2g) ==================================================== > > +(imx8mn_beacon_2g) Image 'main-section' is missing external blobs and is > > non-functional: blob- > > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > > ./mkimage.spl.mkimage -n spl/u-boot-spl > > .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': > > spl/u-boot-spl-ddr.bin: Can't ope > > n: No such file or directory > > +(imx8mn_beacon_2g) > > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 > > +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2 > > > > The beacon boards are mine. I can work on this one today. Do I just grab > the binman updates and apply it to master and fix it from that starting > point?
Adam,
Tom,
I must have messed it up, sorry. I'm doing one more CI run right now of Adam's versions of the patches (just to be extra safe) and then I'll merge the branch. Thanks all!
Hi Tim and Tom
wrote:
On Fri, Jan 7, 2022 at 12:25 PM Tom Rini trini@konsulko.com
wrote:
> > On Fri, Jan 07, 2022 at 12:21:18PM -0600, Adam Ford wrote: > > On Fri, Jan 7, 2022 at 11:38 AM Tom Rini trini@konsulko.com
wrote:
> > > > > On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey <
> > > wrote: > > > > > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > > > > > Hello Tom, > > > > > > > > > > > > > -----Original Message----- > > > > > > > From: U-Boot u-boot-bounces@lists.denx.de On
Behalf Of Tom Rini
> > > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > > > To: u-boot@lists.denx.de > > > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit
generator
> > > script" > > > > > > > > > > > > > > This reverts commit
merge the series
> > > that > > > > > > > allows for binman to be used to generate the final
images, and
> > > also not > > > > > > > break CI, and then also merge all of the series
that convert
> > > currently > > > > > > > broken platforms to use binman instead. So, bring
back this
> > > script now > > > > > > > and remove it again for real after the release. > > > > > > > > > > > > Please note that this might not work, as the FIT
generator script
> > > would > > > > > > generate ITS with '@' symbols which are not
> > > due > > > > > > to CVE-2021-27138. This revert should be
> > > > > > remove those '@' symbols as well. > > > > > > > > > > Correct, the revert is not enough anymore: > > > > > MKIMAGE u-boot.itb > > > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg):
/images/uboot@1:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg):
/images/fdt@1:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg):
/images/fdt@2:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg):
/images/fdt@3:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg):
/images/fdt@4:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg):
/images/fdt@5:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg):
/images/atf@1:
> > > > > node has a unit name, but no reg property > > > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@1: node has a unit name, but
no reg property
> > > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@2: node has a unit name, but
no reg property
> > > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@3: node has a unit name, but
no reg property
> > > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@4: node has a unit name, but
no reg property
> > > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@5: node has a unit name, but
no reg property
support with exit
> > > code 1 > > > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > > > make: *** [u-boot.itb] Error 1 > > > > > make: *** Deleting file 'u-boot.itb' > > > > > make: *** Waiting for unfinished jobs.... > > > > > > > > > > I don't know what had changed to cause this or when
(again, I stopped
binman for this
Oliver at
either.
with:
> > > > > MKIMAGE flash.bin > > > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No
such file or
> > > directory > > > > > arch/arm/mach-imx/Makefile:167: recipe for target
'flash.bin' failed
> > > > > make[1]: *** [flash.bin] Error 1 > > > > > make[1]: *** Deleting file 'flash.bin' > > > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > > > > > At some point over the past couple of months that
patch resolved the
don't know what
> > > > > else has changed that now causes that to not work. > > > > > > > > > > As Tom pointed out in another thread these build
which did not
'flash.bin'
> > > > > target prior to binman conversion). > > > > > > > > > > Is it too late to apply the CI fix and the pending
binman conversions?
and as far as I
It still
> > > > > applies and produces a valid flash.bin image. > > > > > I was also able to merge Peng's series [2] which
converts
was able to build
> > > > > flash.bin images for them > > > > > > > > > > I tried to merge Adam's series that moves
apply due to
> > > > > defconfig/Kconfig changes > > > > > > > > > > That still leaves the following unbuildable with > > > > > CONFIG_SPL_FIT_GENERATOR =
> > > imx/mkimage_fit_atf.sh" > > > > > > > > > > Tim > > > > > [1]
> > > > > [2]
> > > > > [3]
> > > > > [4]
> > > > > > > > > > > > > Tom, > > > > > > > > I'm not familiar with the U-boot CI tool. > > > > > > It's at
> > > (and in-tree under doc/develop/ci_testing.rst). > > > > > > > Is it a show-stopper that it > > > > does not build for boards using binman for release? From
what you
flash.bin target
> > > > for the boards using the FIT generator anyway. > > > > > > Yes, breaking CI is a ship-stopper. That all of these
boards were not
problem.
patch.
> > > Everything is currently visible at > > > > > >
as expected:
> > > aarch64: w+ imx8mn_evk > > > +(imx8mn_evk) Image 'main-section' is missing external
blobs and is
> > > non-functional: blob-ext@1 > > > blob-ext@2 blob-ext@3 blob-ext@4 > > > +(imx8mn_evk) Image 'main-section' is missing external
blobs and is
> > > non-functional: blob-ext > > > +(imx8mn_evk) > > > +(imx8mn_evk) Some images are invalid > > > > > > But others are: > > > aarch64: + imx8mn_beacon_2g > > > +(imx8mn_beacon_2g) ===================== WARNING
> > > migrate > > > +(imx8mn_beacon_2g) to binman instead, to avoid the
proliferation of
> > > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > > > +(imx8mn_beacon_2g)
> > > non-functional: blob- > > > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > > > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > > > ./mkimage.spl.mkimage -n spl/u-boot-spl > > > .cfgout -T imx8mimage -e 0x912000
> > > spl/u-boot-spl-ddr.bin: Can't ope > > > n: No such file or directory > > > +(imx8mn_beacon_2g) > > > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all]
Error 1
Error 2
Do I just grab
that starting
> > point? > > So, yes, grabbing the series from the above link and applying
it on top
very
with making
part of the
> lpddr4_pmu_train_2d_dmem.bin > Image 'main-section' is missing external blobs and is
> Wrote map file './imx-boot.map' to show errors > binman: Node '/binman/imx-boot/blob-ext@1': Offset 0x0 (0)
> boot/uboot' ending at 0x1aee08 (1764872) >
From what I can tell looking at the imx8mm_venice board is that
the imx8mm-u-boot.dtsi has the binman
nodes to build the image, but
arch/arm/dts/imx8mm-venice-u-boot.dtsi duplicates that work, so there are
two copies trying to occupy the same space. Deleting the
&binman node from the venice-u-boot.dtsi file
appears to make the problem go away, and binman is still making
the image.
Adam,
sure
fdt's)
maybe
Tom,
Thanks!
Thanks for your work and helping us get this merged while the imx maintainer is out.
adam
-- Tom
Hi Tom
Hi Tim and Tom
On Fri, Jan 7, 2022 at 12:25 PM Tom Rini trini@konsulko.com wrote: > > On Fri, Jan 07, 2022 at 12:21:18PM -0600, Adam Ford wrote: > > On Fri, Jan 7, 2022 at 11:38 AM Tom Rini trini@konsulko.com wrote: > > > > > On Fri, Jan 07, 2022 at 09:27:05AM -0800, Tim Harvey wrote: > > > > On Thu, Jan 6, 2022 at 12:27 PM Tim Harvey tharvey@gateworks.com > > > wrote: > > > > > > > > > > On Thu, Jan 6, 2022 at 11:18 AM ZHIZHIKIN Andrey > > > > > andrey.zhizhikin@leica-geosystems.com wrote: > > > > > > > > > > > > Hello Tom, > > > > > > > > > > > > > -----Original Message----- > > > > > > > From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Tom Rini > > > > > > > Sent: Thursday, January 6, 2022 7:52 PM > > > > > > > To: u-boot@lists.denx.de > > > > > > > Cc: Tim Harvey tharvey@gateworks.com > > > > > > > Subject: [PATCH] Revert "tree: imx: remove old fit generator > > > script" > > > > > > > > > > > > > > This reverts commit d9a6f0eed66a39206b13513ec914f14084c3bb73. > > > > > > > > > > > > > > For right now, it's too close to the release to merge the series > > > that > > > > > > > allows for binman to be used to generate the final images, and > > > also not > > > > > > > break CI, and then also merge all of the series that convert > > > currently > > > > > > > broken platforms to use binman instead. So, bring back this > > > script now > > > > > > > and remove it again for real after the release. > > > > > > > > > > > > Please note that this might not work, as the FIT generator script > > > would > > > > > > generate ITS with '@' symbols which are not compatible with mkimage > > > due > > > > > > to CVE-2021-27138. This revert should be complemented with the fix to > > > > > > remove those '@' symbols as well. > > > > > > > > > > Correct, the revert is not enough anymore: > > > > > MKIMAGE u-boot.itb > > > > > u-boot.its:7.11-15.5: Warning (unit_address_vs_reg): /images/uboot@1: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:16.9-21.5: Warning (unit_address_vs_reg): /images/fdt@1: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:22.9-27.5: Warning (unit_address_vs_reg): /images/fdt@2: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:28.9-33.5: Warning (unit_address_vs_reg): /images/fdt@3: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:34.9-39.5: Warning (unit_address_vs_reg): /images/fdt@4: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:40.9-45.5: Warning (unit_address_vs_reg): /images/fdt@5: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:46.9-55.5: Warning (unit_address_vs_reg): /images/atf@1: > > > > > node has a unit name, but no reg property > > > > > u-boot.its:60.12-65.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@1: node has a unit name, but no reg property > > > > > u-boot.its:66.12-71.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@2: node has a unit name, but no reg property > > > > > u-boot.its:72.12-77.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@3: node has a unit name, but no reg property > > > > > u-boot.its:78.12-83.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@4: node has a unit name, but no reg property > > > > > u-boot.its:84.12-89.5: Warning (unit_address_vs_reg): > > > > > /configurations/config@5: node has a unit name, but no reg property > > > > > ./tools/mkimage: verify_header failed for FIT Image support with exit > > > code 1 > > > > > Makefile:1433: recipe for target 'u-boot.itb' failed > > > > > make: *** [u-boot.itb] Error 1 > > > > > make: *** Deleting file 'u-boot.itb' > > > > > make: *** Waiting for unfinished jobs.... > > > > > > > > > > I don't know what had changed to cause this or when (again, I stopped > > > > > worrying about it because I thought we were moving to binman for this > > > > > release). There was a patch that resolved this from Oliver at > > > > > https://lists.denx.de/pipermail/u-boot/2021-August/457997.html%C2%A0but I > > > > > don't think that fully solves anything 'at this point' either. > > > > > > > > > > Even with that applied to current master I then end up with: > > > > > MKIMAGE flash.bin > > > > > ./tools/mkimage: Can't open spl/u-boot-spl-ddr.bin: No such file or > > > directory > > > > > arch/arm/mach-imx/Makefile:167: recipe for target 'flash.bin' failed > > > > > make[1]: *** [flash.bin] Error 1 > > > > > make[1]: *** Deleting file 'flash.bin' > > > > > Makefile:1526: recipe for target 'flash.bin' failed > > > > > > > > > > At some point over the past couple of months that patch resolved the > > > > > building issue when using the FIT generator but I also don't know what > > > > > else has changed that now causes that to not work. > > > > > > > > > > As Tom pointed out in another thread these build failures did not get > > > > > caught by CI apparently because CI does a 'make all' which did not > > > > > include the FIT images (that was accomplished with the 'flash.bin' > > > > > target prior to binman conversion). > > > > > > > > > > Is it too late to apply the CI fix and the pending binman conversions? > > > > > > > > > > I know that my series has been reviewed by Marcel [1] and as far as I > > > > > know didn't get merged simply because of the CI issue. It still > > > > > applies and produces a valid flash.bin image. > > > > > I was also able to merge Peng's series [2] which converts > > > > > imx8mq_evk/imx8mq_phanbell/pico-imx8mq to binman and was able to build > > > > > flash.bin images for them > > > > > > > > > > I tried to merge Adam's series that moves imx8mm_beacon to binman [3] > > > > > and imx8mn_beacon to binman [4] but they no longer apply due to > > > > > defconfig/Kconfig changes > > > > > > > > > > That still leaves the following unbuildable with > > > > > CONFIG_SPL_FIT_GENERATOR = "arch/arm/mach-imx/mkimage_fit_atf.sh": > > > > > > > > configs/cgtqmx8_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8mm-icore-mx8mm-ctouch2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8mm-icore-mx8mm-edimm2.2_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8mm_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8mn_beacon_2g_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8mn_beacon_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > configs/imx8qm_rom7720_a1_4G_defconfig:CONFIG_SPL_FIT_GENERATOR="arch/arm/mach- > > > imx/mkimage_fit_atf.sh" > > > > > > > > > > Tim > > > > > [1] https://patchwork.ozlabs.org/project/uboot/list/?series=265765 > > > > > [2] https://patchwork.ozlabs.org/project/uboot/list/?series=268380 > > > > > [3] https://patchwork.ozlabs.org/project/uboot/list/?series=261640 > > > > > [4] https://patchwork.ozlabs.org/project/uboot/list/?series=261822 > > > > > > > > > > > > > Tom, > > > > > > > > I'm not familiar with the U-boot CI tool. > > > > > > It's at https://u-boot.readthedocs.io/en/latest/develop/ci_testing.html > > > (and in-tree under doc/develop/ci_testing.rst). > > > > > > > Is it a show-stopper that it > > > > does not build for boards using binman for release? From what you > > > > mentioned in another thread it was never building the flash.bin target > > > > for the boards using the FIT generator anyway. > > > > > > Yes, breaking CI is a ship-stopper. That all of these boards were not > > > previously building the final image as part of "all" is a problem. > > > > > > So, here's what I'm at right now. I've grabbed Heiko's patch. > > > Everything is currently visible at > > > > > > https://patchwork.ozlabs.org/bundle/trini/2022-01-07-imx8-and-binman-updates... > > > and with this, we get some boards building and complaining as expected: > > > aarch64: w+ imx8mn_evk > > > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > > > non-functional: blob-ext@1 > > > blob-ext@2 blob-ext@3 blob-ext@4 > > > +(imx8mn_evk) Image 'main-section' is missing external blobs and is > > > non-functional: blob-ext > > > +(imx8mn_evk) > > > +(imx8mn_evk) Some images are invalid > > > > > > But others are: > > > aarch64: + imx8mn_beacon_2g > > > +(imx8mn_beacon_2g) ===================== WARNING ====================== > > > +(imx8mn_beacon_2g) This board uses CONFIG_SPL_FIT_GENERATOR. Please > > > migrate > > > +(imx8mn_beacon_2g) to binman instead, to avoid the proliferation of > > > +(imx8mn_beacon_2g) arch-specific scripts with no tests. > > > +(imx8mn_beacon_2g) ==================================================== > > > +(imx8mn_beacon_2g) Image 'main-section' is missing external blobs and is > > > non-functional: blob- > > > ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > > > +(imx8mn_beacon_2g) binman: Error 1 running 'mkimage -d > > > ./mkimage.spl.mkimage -n spl/u-boot-spl > > > .cfgout -T imx8mimage -e 0x912000 ./mkimage-out.spl.mkimage': > > > spl/u-boot-spl-ddr.bin: Can't ope > > > n: No such file or directory > > > +(imx8mn_beacon_2g) > > > +(imx8mn_beacon_2g) make[1]: *** [Makefile:1088: all] Error 1 > > > +(imx8mn_beacon_2g) make: *** [Makefile:177: sub-make] Error 2 > > > > > > > The beacon boards are mine. I can work on this one today. Do I just grab > > the binman updates and apply it to master and fix it from that starting > > point? > > So, yes, grabbing the series from the above link and applying it on top > of master, and making builds work with fake binaries would be very > helpful. As best I can tell there's still something missing with making > fake blobs link and not fail. For example, imx8mm_venice is part of the > series above but still fails with 'make BINMAN_FAKE_EXT_BLOBS=1 ...': > Image 'main-section:u-boot-spl-ddr' has faked external blobs and is non-functional: > lpddr4_pmu_train_1d_imem.bin lpddr4_pmu_train_1d_dmem.bin lpddr4_pmu_train_2d_imem.bin > lpddr4_pmu_train_2d_dmem.bin > Image 'main-section' is missing external blobs and is non-functional: atf_blob blob-ext > Wrote map file './imx-boot.map' to show errors > binman: Node '/binman/imx-boot/blob-ext@1': Offset 0x0 (0) overlaps with previous entry > '/binman/imx- > boot/uboot' ending at 0x1aee08 (1764872) >
From what I can tell looking at the imx8mm_venice board is that the imx8mm-u-boot.dtsi has the binman nodes to build the image, but arch/arm/dts/imx8mm-venice-u-boot.dtsi duplicates that work, so there are two copies trying to occupy the same space. Deleting the &binman node from the venice-u-boot.dtsi file appears to make the problem go away, and binman is still making the image.
Adam,
I don't quite follow. I don't see any binman nodes in arch/arm/dts/imx8mm-u-boot.dtsi.
I know that Marcel submitted a patch that added them (and I'm not sure if he added them yet in a way that was compatible with multiple fdt's) but this hasn't been merged yet so I don't see any duplicate binman nodes for venice.
Tom,
No, I guess you just applied Tim's and my patches in a different order and therefore this binman stuff removal for venice wasn't really required resp. not even there yet. And Tim's later patch already omitted it. So all looks indeed fine.
Thank you!
Cheers
Marcel
participants (5)
Adam Ford
Marcel Ziswiler
Tim Harvey
ZHIZHIKIN Andrey
