[U-Boot] [PATCH v2 1/2] ARM: mvebu: rename armada-385-amc.dts to armada-385-db-88f6820-amc.dts
This board was added to u-boot first but the Linux maintainers requested a more descriptive name. Rename the file to match the Linux usage and update the board defconfig.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v2: - rebase against u-boot-marvell/master
arch/arm/dts/Makefile | 2 +- .../dts/{armada-385-amc.dts => armada-385-db-88f6820-amc.dts} | 0 configs/db-88f6820-amc_defconfig | 2 +- 3 files changed, 2 insertions(+), 2 deletions(-) rename arch/arm/dts/{armada-385-amc.dts => armada-385-db-88f6820-amc.dts} (100%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7704dfb81334..4f661552b0a6 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -140,7 +140,7 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-388-clearfog.dtb \ armada-388-gp.dtb \ armada-388-helios4.dtb \ - armada-385-amc.dtb \ + armada-385-db-88f6820-amc.dtb \ armada-385-turris-omnia.dtb \ armada-7040-db.dtb \ armada-7040-db-nand.dtb \ diff --git a/arch/arm/dts/armada-385-amc.dts b/arch/arm/dts/armada-385-db-88f6820-amc.dts similarity index 100% rename from arch/arm/dts/armada-385-amc.dts rename to arch/arm/dts/armada-385-db-88f6820-amc.dts diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index dcf2a25395e2..e8ba5184c4d7 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_DEFAULT_DEVICE_TREE="armada-385-amc" +CONFIG_DEFAULT_DEVICE_TREE="armada-385-db-88f6820-amc" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000
Sync armada-385-db-88f6820-amc.dts with Linux. Retain the u-boot,dm-pre-reloc and nand differences.
arch/arm/dts/armada-385-db-88f6820-amc.dts | 184 +++++++++------------ 1 file changed, 82 insertions(+), 102 deletions(-)
diff --git a/arch/arm/dts/armada-385-db-88f6820-amc.dts b/arch/arm/dts/armada-385-db-88f6820-amc.dts index c9ccbb57fff5..59a425f6b155 100644 --- a/arch/arm/dts/armada-385-db-88f6820-amc.dts +++ b/arch/arm/dts/armada-385-db-88f6820-amc.dts @@ -1,51 +1,19 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) /* - * Device Tree file for Marvell Armada 385 development board + * Device Tree file for Marvell Armada 385 AMC board * (DB-88F6820-AMC) * - * Copyright (C) 2014 Marvell - * - * Gregory CLEMENT gregory.clement@free-electrons.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is licensed under the terms of the GNU General Public - * License version 2. This program is licensed "as is" without - * any warranty of any kind, whether express or implied. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. + * Copyright (C) 2017 Allied Telesis Labs */
/dts-v1/; #include "armada-385.dtsi" + #include <dt-bindings/gpio/gpio.h>
/ { model = "Marvell Armada 385 AMC"; - compatible = "marvell,a385-amc", "marvell,armada385", "marvell,armada380"; + compatible = "marvell,a385-db-amc", "marvell,armada385", "marvell,armada380";
chosen { stdout-path = "serial0:115200n8"; @@ -60,90 +28,88 @@
memory { device_type = "memory"; - reg = <0x00000000 0x80000000>; /* 2 GB */ + reg = <0x00000000 0x80000000>; /* 2GB */ };
soc { ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000>; + }; +};
- internal-regs { - i2c@11000 { - clock-frequency = <100000>; - u-boot,i2c-slave-addr = <0x0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins>; - status = "okay"; - }; - - serial@12000 { - /* - * Exported on the micro USB connector CON16 - * through an FTDI - */ +&i2c0 { + u-boot,i2c-slave-addr = <0x0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "okay"; +};
- pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins>; - status = "okay"; - u-boot,dm-pre-reloc; - }; +&uart0 { + /* + * Exported on the micro USB connector CON3 + * through an FTDI + */
- ethernet@34000 { - status = "okay"; - phy = <&phy1>; - phy-mode = "sgmii"; - }; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + status = "okay"; + u-boot,dm-pre-reloc; +};
- usb@58000 { - status = "okay"; - };
- ethernet@70000 { - pinctrl-names = "default"; - /* - * The Reference Clock 0 is used to provide a - * clock to the PHY - */ - pinctrl-0 = <&ge0_rgmii_pins>, <&ref_clk0_pins>; - status = "okay"; - phy = <&phy0>; - phy-mode = "rgmii-id"; - }; +ð0 { + pinctrl-names = "default"; + /* + * The Reference Clock 0 is used to provide a + * clock to the PHY + */ + pinctrl-0 = <&ge0_rgmii_pins>, <&ref_clk0_pins>; + status = "okay"; + phy = <&phy0>; + phy-mode = "rgmii-id"; +};
+ð2 { + status = "okay"; + phy = <&phy1>; + phy-mode = "sgmii"; +};
- mdio@72004 { - pinctrl-names = "default"; - pinctrl-0 = <&mdio_pins>; +&usb0 { + status = "okay"; +};
- phy0: ethernet-phy@1 { - reg = <1>; - };
- phy1: ethernet-phy@0 { - reg = <0>; - }; - };
- flash@d0000 { - status = "okay"; - num-cs = <1>; - marvell,nand-keep-config; - marvell,nand-enable-arbiter; - nand-on-flash-bbt; - }; - }; +&mdio { + pinctrl-names = "default"; + pinctrl-0 = <&mdio_pins>;
- pcie { - status = "okay"; - pcie@1,0 { - /* Port 0, Lane 0 */ - status = "okay"; - }; + phy0: ethernet-phy@1 { + reg = <1>; + };
- }; + phy1: ethernet-phy@0 { + reg = <0>; }; };
+&nand_controller { + status = "okay"; + marvell,nand-keep-config; + marvell,nand-enable-arbiter; + nand-on-flash-bbt; +}; + +&pciec { + status = "okay"; +}; + +&pcie1 { + /* Port 0, Lane 0 */ + status = "okay"; +}; + &spi1 { pinctrl-names = "default"; pinctrl-0 = <&spi1_pins>; @@ -154,10 +120,24 @@ u-boot,dm-pre-reloc; #address-cells = <1>; #size-cells = <1>; - compatible = "st,m25p128", "jedec,spi-nor", "spi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; /* Chip select 0 */ spi-max-frequency = <50000000>; m25p,fast-read; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + partition@0 { + reg = <0x00000000 0x00100000>; + label = "u-boot"; + }; + partition@100000 { + reg = <0x00100000 0x00040000>; + label = "u-boot-env"; + }; + }; }; };
Changes in v2:
Applied to u-boot-marvell/master.
Thanks, Stefan
Thanks, Stefan
Chris Packham
Stefan Roese
