[U-Boot] [PATCH] part: fix "part list ... -bootable varname" to use hex
Unfortunately U-Boot assumes that almost all numbers are in hex, including partition numbers passed to e.g. "load". So, the command "part list mmc 0 -bootable devplist" should use hex when writing partition numbers into $devplist, so they'll be correctly interpreted.
Change-Id: I9a70b19749643876baadb45efbc3decaef8bfee2 Fixes: 0798d6fd4191 ("part: Add support for list filtering on bootable partitions") Cc: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Stephen Warren swarren@nvidia.com --- common/cmd_part.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_part.c b/common/cmd_part.c index b860624d939c..55995097eb00 100644 --- a/common/cmd_part.c +++ b/common/cmd_part.c @@ -100,7 +100,7 @@ static int do_part_list(int argc, char * const argv[]) if (bootable && !info.bootable) continue;
- sprintf(t, "%s%d", str[0] ? " " : "", p); + sprintf(t, "%s%x", str[0] ? " " : "", p); strcat(str, t); } setenv(var, str);
Ugh, that's unexpected. But indeed it assumes partition numbers are base 16.
Reviewed-by: Sjoerd Simons sjoerd.simons@collabora.co.uk
Change-Id: I9a70b19749643876baadb45efbc3decaef8bfee2 Fixes: 0798d6fd4191 ("part: Add support for list filtering on bootable partitions") Cc: Sjoerd Simons sjoerd.simons@collabora.co.uk Signed-off-by: Stephen Warren swarren@nvidia.com Reviewed-by: Sjoerd Simons sjoerd.simons@collabora.co.uk
Sjoerd Simons
Stephen Warren
