[U-Boot] [PATCH] travis: Use kernel.org pre-built toolchain for riscv
This updates travis configuration to use kernel.org pre-built toolchain for riscv.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
.travis.yml | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 4db629d..95cfa5b 100644 --- a/.travis.yml +++ b/.travis.yml @@ -87,9 +87,8 @@ before_script: fi - if [[ "${TOOLCHAIN}" == "powerpc" ]]; then ./tools/buildman/buildman --fetch-arch powerpc; fi - if [[ "${TOOLCHAIN}" == "riscv" ]]; then - wget https://github.com/andestech/prebuilt/releases/download/20180530/riscv64-unk... && - tar -C /tmp -xf riscv64-unknown-linux-gnu.tar.gz && - echo -e "\n[toolchain-prefix]\nriscv = /tmp/riscv64-unknown-linux-gnu/bin/riscv64-unknown-linux-gnu-" >> ~/.buildman; + ./tools/buildman/buildman --fetch-arch riscv64; + echo -e "\n[toolchain-alias]\nriscv = riscv64" >> ~/.buildman; fi - if [[ "${QEMU_TARGET}" != "" ]]; then git clone git://git.qemu.org/qemu.git /tmp/qemu;
Hi Tom,
Since this is travis-ci changes, can we take this for v2018.09? I've verified that it works well for current riscv build on travis-ci.org.
Regards, Bin
On Mon, Sep 03, 2018 at 05:50:39PM +0800, Bin Meng wrote:
Hi Tom,
Seeing as things are still working before this change I would like to see an ack from the custodian, thanks!
Hi Rick,
Hi Tom,
Are you OK with this?
Regards, Bin
Bin Meng
