[U-Boot] [PATCH] net: Fix TftpStart() ip:filename bug
The TftpStart() function modifies the 'BootFile' string when 'BootFile' contains both an IP address and filename (eg 1.2.3.4:/path/file). This causes subsequent calls to TftpStart to incorrectly parse the TFTP filename and server IP address to use. For example:
=> tftp 0x100000 10.52.0.62:/home/ptyser/non_existant Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.62; our IP address is 10.52.253.79 ^^^^^^^^^^ CORRECT Filename '/home/ptyser/non_existant'. ^^^^^^^^^^^^^^^^^^^^^^^^^ CORRECT Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again
eTSEC2: No link. Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.33; our IP address is 10.52.253.79 ^^^^^^^^^^ WRONG Filename '10.52.0.62'. ^^^^^^^^^^ WRONG Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again
TftpStart() was modified to not modify the 'BootFile' string. --- net/tftp.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index ce6ea3d..3dac3d8 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -499,9 +499,8 @@ TftpStart (void) strncpy(tftp_filename, BootFile, MAX_LEN); tftp_filename[MAX_LEN-1] = 0; } else { - *p++ = '\0'; TftpServerIP = string_to_ip (BootFile); - strncpy(tftp_filename, p, MAX_LEN); + strncpy(tftp_filename, p + 1, MAX_LEN); tftp_filename[MAX_LEN-1] = 0; } }
Peter Tyser
