[U-Boot] [PATCH v2 0/3] add support for the at91 based smartweb board
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog:
RomBOOT
U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200)
CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot>
As this board is based on sam9260 SoC with 4k sram only, SPL must be small, so SPL is compiled without serial support. Therefore the code needs here and there some small fixes to support SPL compile without serial support.
Changes in v2: - add comment from Tom Rini: - do not delete __maybe_unused - remove preloader_console_init() in non SERIAL case - squashed patch "lib/display_options: fix compiler warnings" into this patch. - add Acked-by from Scott Wood - rebase to 7853d76b0bdab9b
Heiko Schocher (3): spl, common, serial: build SPL without serial support nand, atmel: remove udelay in spl_nand_erase_one() arm, at91: support for sam9260 based smwartweb board
arch/arm/include/asm/mach-types.h | 1 + arch/arm/lib/interrupts.c | 4 +- arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/Makefile | 1 + arch/arm/mach-at91/arm926ejs/cpu.c | 2 +- arch/arm/mach-at91/spl_at91.c | 3 + board/siemens/smartweb/Kconfig | 12 ++ board/siemens/smartweb/MAINTAINERS | 6 + board/siemens/smartweb/Makefile | 20 +++ board/siemens/smartweb/smartweb.c | 220 ++++++++++++++++++++++++++++ common/Makefile | 4 + common/cli_readline.c | 2 +- common/cli_simple.c | 2 +- common/image.c | 8 +- configs/smartweb_defconfig | 6 + drivers/mtd/nand/atmel_nand.c | 2 - include/common.h | 7 + include/configs/apf27.h | 1 + include/configs/mx31pdk.h | 1 + include/configs/mxs.h | 1 + include/configs/smartweb.h | 289 +++++++++++++++++++++++++++++++++++++ include/configs/tx25.h | 1 + lib/display_options.c | 13 +- 23 files changed, 600 insertions(+), 12 deletions(-) create mode 100644 board/siemens/smartweb/Kconfig create mode 100644 board/siemens/smartweb/MAINTAINERS create mode 100644 board/siemens/smartweb/Makefile create mode 100644 board/siemens/smartweb/smartweb.c create mode 100644 configs/smartweb_defconfig create mode 100644 include/configs/smartweb.h
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support.
Signed-off-by: Heiko Schocher hs@denx.de ---
arch/arm/lib/interrupts.c | 4 ++-- arch/arm/mach-at91/arm926ejs/cpu.c | 2 +- arch/arm/mach-at91/spl_at91.c | 3 +++ common/Makefile | 4 ++++ common/cli_readline.c | 2 +- common/cli_simple.c | 2 +- common/image.c | 8 ++++++-- include/common.h | 7 +++++++ include/configs/apf27.h | 1 + include/configs/mx31pdk.h | 1 + include/configs/mxs.h | 1 + include/configs/tx25.h | 1 + lib/display_options.c | 13 ++++++++++--- 13 files changed, 39 insertions(+), 10 deletions(-)
diff --git a/arch/arm/lib/interrupts.c b/arch/arm/lib/interrupts.c index 06f4679..ec3fb77 100644 --- a/arch/arm/lib/interrupts.c +++ b/arch/arm/lib/interrupts.c @@ -123,8 +123,8 @@ void bad_mode (void)
void show_regs (struct pt_regs *regs) { - unsigned long flags; - const char *processor_modes[] = { + unsigned long __maybe_unused flags; + const char __maybe_unused *processor_modes[] = { "USER_26", "FIQ_26", "IRQ_26", "SVC_26", "UK4_26", "UK5_26", "UK6_26", "UK7_26", "UK8_26", "UK9_26", "UK10_26", "UK11_26", diff --git a/arch/arm/mach-at91/arm926ejs/cpu.c b/arch/arm/mach-at91/arm926ejs/cpu.c index da1d359..990c689 100644 --- a/arch/arm/mach-at91/arm926ejs/cpu.c +++ b/arch/arm/mach-at91/arm926ejs/cpu.c @@ -42,7 +42,7 @@ void arch_preboot_os(void) #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo(void) { - char buf[32]; + char __maybe_unused buf[32];
printf("CPU: %s\n", ATMEL_CPU_NAME); printf("Crystal frequency: %8s MHz\n", diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index a79a9dc..b19f95b 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -123,9 +123,12 @@ void board_init_f(ulong dummy) at91_periph_clk_enable(ATMEL_ID_PIOB); at91_periph_clk_enable(ATMEL_ID_PIOC); #endif + +#if defined(CONFIG_SPL_SERIAL_SUPPORT) /* init console */ at91_seriald_hw_init(); preloader_console_init(); +#endif
mem_init();
diff --git a/common/Makefile b/common/Makefile index d6c1d48..516c299 100644 --- a/common/Makefile +++ b/common/Makefile @@ -250,7 +250,11 @@ obj-$(CONFIG_DDR_SPD) += ddr_spd.o obj-$(CONFIG_SPD_EEPROM) += ddr_spd.o obj-$(CONFIG_HWCONFIG) += hwconfig.o obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_SERIAL_SUPPORT) += console.o +else obj-y += console.o +endif obj-$(CONFIG_CROS_EC) += cros_ec.o obj-y += dlmalloc.o ifdef CONFIG_SYS_MALLOC_F_LEN diff --git a/common/cli_readline.c b/common/cli_readline.c index 9a9fb35..c1476e4 100644 --- a/common/cli_readline.c +++ b/common/cli_readline.c @@ -597,7 +597,7 @@ int cli_readline_into_buffer(const char *const prompt, char *buffer, puts(tab_seq + (col & 07)); col += 8 - (col & 07); } else { - char buf[2]; + char __maybe_unused buf[2];
/* * Echo input using puts() to force an diff --git a/common/cli_simple.c b/common/cli_simple.c index 6c65cc6..00a8d2f 100644 --- a/common/cli_simple.c +++ b/common/cli_simple.c @@ -68,7 +68,7 @@ void cli_simple_process_macros(const char *input, char *output) /* 1 = waiting for '(' or '{' */ /* 2 = waiting for ')' or '}' */ /* 3 = waiting for ''' */ - char *output_start = output; + char __maybe_unused *output_start = output;
debug_parser("[PROCESS_MACROS] INPUT len %zd: "%s"\n", strlen(input), input); diff --git a/common/image.c b/common/image.c index f0f0135..eaa98d3 100644 --- a/common/image.c +++ b/common/image.c @@ -54,6 +54,10 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, #include <u-boot/md5.h> #include <time.h> #include <image.h> + +#ifndef __maybe_unused +# define __maybe_unused /* unimplemented */ +#endif #endif /* !USE_HOSTCC*/
#include <u-boot/crc.h> @@ -274,7 +278,7 @@ void image_multi_getimg(const image_header_t *hdr, ulong idx,
static void image_print_type(const image_header_t *hdr) { - const char *os, *arch, *type, *comp; + const char __maybe_unused *os, *arch, *type, *comp;
os = genimg_get_os_name(image_get_os(hdr)); arch = genimg_get_arch_name(image_get_arch(hdr)); @@ -299,7 +303,7 @@ static void image_print_type(const image_header_t *hdr) void image_print_contents(const void *ptr) { const image_header_t *hdr = (const image_header_t *)ptr; - const char *p; + const char __maybe_unused *p;
p = IMAGE_INDENT_STRING; printf("%sImage Name: %.*s\n", p, IH_NMLEN, image_get_name(hdr)); diff --git a/include/common.h b/include/common.h index 8f4b2ec..bafe120 100644 --- a/include/common.h +++ b/include/common.h @@ -830,11 +830,18 @@ int getc(void); int tstc(void);
/* stdout */ +#if defined(CONFIG_SPL_BUILD) && !defined(CONFIG_SPL_SERIAL_SUPPORT) +#define putc(...) do { } while (0) +#define puts(...) do { } while (0) +#define printf(...) do { } while (0) +#define vprintf(...) do { } while (0) +#else void putc(const char c); void puts(const char *s); int printf(const char *fmt, ...) __attribute__ ((format (__printf__, 1, 2))); int vprintf(const char *fmt, va_list args); +#endif
/* stderr */ #define eputc(c) fputc(stderr, c) diff --git a/include/configs/apf27.h b/include/configs/apf27.h index a0a26bb..cf13563 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -40,6 +40,7 @@ #define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds" #define CONFIG_SPL_MAX_SIZE 2048 #define CONFIG_SPL_TEXT_BASE 0xA0000000 +#define CONFIG_SPL_SERIAL_SUPPORT
/* NAND boot config */ #define CONFIG_SPL_NAND_SUPPORT diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 7e709cd..72d28c9 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -35,6 +35,7 @@ #define CONFIG_SPL_MAX_SIZE 2048 #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT
#define CONFIG_SPL_TEXT_BASE 0x87dc0000 #define CONFIG_SYS_TEXT_BASE 0x87e00000 diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 38b1e93..9d823de 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -55,6 +55,7 @@ #define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT
/* Memory sizes */ diff --git a/include/configs/tx25.h b/include/configs/tx25.h index e7b006c..834b616 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -26,6 +26,7 @@ #define CONFIG_SPL_MAX_SIZE 2048 #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT
#define CONFIG_SPL_TEXT_BASE 0x810c0000 #define CONFIG_SYS_TEXT_BASE 0x81200000 diff --git a/lib/display_options.c b/lib/display_options.c index 57fb974..df134cd 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -25,7 +25,10 @@ int display_options (void)
void print_freq(uint64_t freq, const char *s) { - unsigned long m = 0, n; + unsigned long m = 0; +#if defined(CONFIG_SPL_SERIAL_SUPPORT) + unsigned long n; +#endif uint32_t f; static const char names[] = {'G', 'M', 'K'}; unsigned long d = 1e9; @@ -45,7 +48,9 @@ void print_freq(uint64_t freq, const char *s) }
f = do_div(freq, d); +#if defined(CONFIG_SPL_SERIAL_SUPPORT) n = freq; +#endif
/* If there's a remainder, show the first few digits */ if (f) { @@ -58,7 +63,9 @@ void print_freq(uint64_t freq, const char *s) m = (m / 10) + (m % 100 >= 50); }
+#if defined(CONFIG_SPL_SERIAL_SUPPORT) printf("%lu", n); +#endif if (m) printf(".%ld", m); printf(" %cHz%s", c, s); @@ -121,9 +128,9 @@ int print_buffer(ulong addr, const void *data, uint width, uint count, } lb; int i; #ifdef CONFIG_SYS_SUPPORT_64BIT_DATA - uint64_t x; + uint64_t __maybe_unused x; #else - uint32_t x; + uint32_t __maybe_unused x; #endif
if (linelen*width > MAX_LINE_LENGTH_BYTES)
remove unneeded udelay() in this function, as we use the dev_ready pin.
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Scott Wood scottwood@freescale.com ---
Changes in v2: - add Acked-by from Scott Wood
drivers/mtd/nand/atmel_nand.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index a2016e7..0d4f327 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -1378,9 +1378,7 @@ int spl_nand_erase_one(int block, int page) hwctrl(&mtd, (page_addr >> 16) & 0x0f, NAND_CTRL_ALE | NAND_CTRL_CHANGE); #endif - hwctrl(&mtd, NAND_CMD_ERASE2, NAND_CTRL_CLE | NAND_CTRL_CHANGE); - udelay(2000);
while (!this->dev_ready(&mtd)) ;
RomBOOT
Changes in v2: - rebase to 7853d76b0bdab9b
arch/arm/include/asm/mach-types.h | 1 + arch/arm/mach-at91/Kconfig | 6 + arch/arm/mach-at91/Makefile | 1 + board/siemens/smartweb/Kconfig | 12 ++ board/siemens/smartweb/MAINTAINERS | 6 + board/siemens/smartweb/Makefile | 20 +++ board/siemens/smartweb/smartweb.c | 220 ++++++++++++++++++++++++++++ configs/smartweb_defconfig | 6 + include/configs/smartweb.h | 289 +++++++++++++++++++++++++++++++++++++ 9 files changed, 561 insertions(+) create mode 100644 board/siemens/smartweb/Kconfig create mode 100644 board/siemens/smartweb/MAINTAINERS create mode 100644 board/siemens/smartweb/Makefile create mode 100644 board/siemens/smartweb/smartweb.c create mode 100644 configs/smartweb_defconfig create mode 100644 include/configs/smartweb.h
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 5afe791..847da59 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -276,6 +276,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_TRIZEPS4WL 1649 #define MACH_TYPE_TS78XX 1652 #define MACH_TYPE_SFFSDR 1657 +#define MACH_TYPE_SMARTWEB 1668 #define MACH_TYPE_PCM037 1673 #define MACH_TYPE_DB88F6281_BP 1680 #define MACH_TYPE_RD88F6192_NAS 1681 diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index bbf4228..d8d46dc 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -124,6 +124,11 @@ config TARGET_TAURUS select CPU_ARM926EJS select SUPPORT_SPL
+config TARGET_SMARTWEB + bool "Support smartweb" + select CPU_ARM926EJS + select SUPPORT_SPL + endchoice
config SYS_SOC @@ -155,6 +160,7 @@ source "board/ronetix/pm9263/Kconfig" source "board/ronetix/pm9g45/Kconfig" source "board/siemens/corvus/Kconfig" source "board/siemens/taurus/Kconfig" +source "board/siemens/smartweb/Kconfig" source "board/taskit/stamp9g20/Kconfig"
endif diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index 0d3ee48..313eb47 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -1,5 +1,6 @@ obj-$(CONFIG_AT91_WANTS_COMMON_PHY) += phy.o ifneq ($(CONFIG_SPL_BUILD),) +obj-$(CONFIG_AT91SAM9260) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9G20) += sdram.o spl_at91.o obj-$(CONFIG_AT91SAM9M10G45) += mpddrc.o spl_at91.o obj-$(CONFIG_AT91SAM9N12) += mpddrc.o spl_at91.o diff --git a/board/siemens/smartweb/Kconfig b/board/siemens/smartweb/Kconfig new file mode 100644 index 0000000..0871bcc --- /dev/null +++ b/board/siemens/smartweb/Kconfig @@ -0,0 +1,12 @@ +if TARGET_SMARTWEB + +config SYS_BOARD + default "smartweb" + +config SYS_VENDOR + default "siemens" + +config SYS_CONFIG_NAME + default "smartweb" + +endif diff --git a/board/siemens/smartweb/MAINTAINERS b/board/siemens/smartweb/MAINTAINERS new file mode 100644 index 0000000..51298ff --- /dev/null +++ b/board/siemens/smartweb/MAINTAINERS @@ -0,0 +1,6 @@ +SMARTWEB_HW BOARD +M: Heiko Schocher hs@denx.de +S: Maintained +F: board/siemens/smartweb +F: include/configs/smartweb.h +F: configs/smartweb_defconfig diff --git a/board/siemens/smartweb/Makefile b/board/siemens/smartweb/Makefile new file mode 100644 index 0000000..55e7798 --- /dev/null +++ b/board/siemens/smartweb/Makefile @@ -0,0 +1,20 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian@popies.net +# Lead Tech Design <www.leadtechdesign.com> +# +# (C) Copyright 2012 +# Markus Hubig mhubig@imko.de +# IMKO GmbH <www.imko.de> +# +# (C) Copyright 2014 +# Heiko Schocher hs@denx.de +# DENX Software Engineering GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += smartweb.o diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c new file mode 100644 index 0000000..cf8a7f5 --- /dev/null +++ b/board/siemens/smartweb/smartweb.c @@ -0,0 +1,220 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * Achim Ehrlich aehrlich@taskit.de + * taskit GmbH <www.taskit.de> + * + * (C) Copyright 2012- + * Markus Hubig mhubig@imko.de + * IMKO GmbH <www.imko.de> + * (C) Copyright 2014 + * Heiko Schocher hs@denx.de + * DENX Software Engineering GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9_sdramc.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_spi.h> +#include <spi.h> +#include <asm/arch/gpio.h> +#include <watchdog.h> +#ifdef CONFIG_MACB +# include <net.h> +# include <netdev.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +static void smartweb_nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Assign CS3 to NAND/SmartMedia Interface */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_TDF_CYCLE(2), + &smc->cs[3].mode); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} + +#ifdef CONFIG_MACB +static void smartweb_macb_hw_init(void) +{ + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + + /* Enable the PHY Chip via PA26 on the Stamp 2 Adaptor */ + at91_set_gpio_output(AT91_PIN_PA26, 0); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + &pioa->pudr); + + at91_phy_reset(); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + &pioa->puer); + + /* Initialize EMAC=MACB hardware */ + at91_macb_hw_init(); +} +#endif /* CONFIG_MACB */ + +int board_early_init_f(void) +{ + /* enable this here, as we have SPL without serial support */ + at91_seriald_hw_init(); + return 0; +} + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + smartweb_nand_hw_init(); +#ifdef CONFIG_MACB + smartweb_macb_hw_init(); +#endif + /* power LED red */ + at91_set_gpio_output(AT91_PIN_PC6, 0); + at91_set_gpio_output(AT91_PIN_PC7, 1); + /* alarm LED off */ + at91_set_gpio_output(AT91_PIN_PC8, 0); + at91_set_gpio_output(AT91_PIN_PC9, 0); + /* prog LED red */ + at91_set_gpio_output(AT91_PIN_PC10, 0); + at91_set_gpio_output(AT91_PIN_PC11, 1); + + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size( + (void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +#ifdef CONFIG_MACB +int board_eth_init(bd_t *bis) +{ + return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x00); +} +#endif /* CONFIG_MACB */ + +#if defined(CONFIG_SPL_BUILD) +#include <spl.h> +#include <nand.h> +#include <spi_flash.h> + +void matrix_init(void) +{ + struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; + + writel((readl(&mat->scfg[3]) & (~AT91_MATRIX_SLOT_CYCLE)) + | AT91_MATRIX_SLOT_CYCLE_(0x40), + &mat->scfg[3]); +} + +void spl_board_init(void) +{ + at91_set_gpio_output(AT91_PIN_PC6, 1); + at91_set_gpio_output(AT91_PIN_PC7, 1); + /* alarm LED orange */ + at91_set_gpio_output(AT91_PIN_PC8, 1); + at91_set_gpio_output(AT91_PIN_PC9, 1); + /* prog LED red */ + at91_set_gpio_output(AT91_PIN_PC10, 0); + at91_set_gpio_output(AT91_PIN_PC11, 1); + + smartweb_nand_hw_init(); + at91_set_gpio_input(AT91_PIN_PA28, 1); + at91_set_gpio_input(AT91_PIN_PA29, 1); + + /* check if both button are pressed */ + if (at91_get_gpio_value(AT91_PIN_PA28) == 0 && + at91_get_gpio_value(AT91_PIN_PA29) == 0) { + debug("Recovery button pressed\n"); + nand_init(); + spl_nand_erase_one(0, 0); + } +} + +#define SDRAM_BASE_CONF (AT91_SDRAMC_NC_9 | AT91_SDRAMC_NR_13 \ + | AT91_SDRAMC_CAS_2 \ + | AT91_SDRAMC_NB_4 | AT91_SDRAMC_DBW_32 \ + | AT91_SDRAMC_TWR_VAL(2) | AT91_SDRAMC_TRC_VAL(7) \ + | AT91_SDRAMC_TRP_VAL(2) | AT91_SDRAMC_TRCD_VAL(2) \ + | AT91_SDRAMC_TRAS_VAL(5) | AT91_SDRAMC_TXSR_VAL(8)) + +void mem_init(void) +{ + struct at91_matrix *ma = (struct at91_matrix *)ATMEL_BASE_MATRIX; + struct at91_port *port = (struct at91_port *)ATMEL_BASE_PIOC; + struct sdramc_reg setting; + + setting.cr = SDRAM_BASE_CONF; + setting.mdr = AT91_SDRAMC_MD_SDRAM; + setting.tr = (CONFIG_SYS_MASTER_CLOCK * 7) / 1000000; + + /* + * I write here directly in this register, because this + * approach is smaller than calling at91_set_a_periph() in a + * for loop. This saved me 96 bytes. + */ + writel(0xffff0000, &port->pdr); + + writel(readl(&ma->ebicsa) | AT91_MATRIX_CS1A_SDRAMC, &ma->ebicsa); + sdramc_initialize(ATMEL_BASE_CS1, &setting); +} +#endif diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig new file mode 100644 index 0000000..08e89a0 --- /dev/null +++ b/configs/smartweb_defconfig @@ -0,0 +1,6 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_TARGET_SMARTWEB=y +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" +CONFIG_CMD_NET=y diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h new file mode 100644 index 0000000..e5aec33 --- /dev/null +++ b/include/configs/smartweb.h @@ -0,0 +1,289 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2010 + * Achim Ehrlich aehrlich@taskit.de + * taskit GmbH <www.taskit.de> + * + * (C) Copyright 2012 + * Markus Hubig mhubig@imko.de + * IMKO GmbH <www.imko.de> + * + * (C) Copyright 2014 + * Heiko Schocher hs@denx.de + * DENX Software Engineering GmbH + * + * Configuation settings for the smartweb. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * SoC must be defined first, before hardware.h is included. + * In this case SoC is defined in boards.cfg. + */ +#include <asm/hardware.h> + +/* + * Warning: changing CONFIG_SYS_TEXT_BASE requires adapting the initial boot + * program. Since the linker has to swallow that define, we must use a pure + * hex number here! + */ +#define CONFIG_SYS_TEXT_BASE 0x23000000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock xtal */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* 18.432MHz crystal */ + +/* misc settings */ +#define CONFIG_CMDLINE_TAG /* pass commandline to Kernel */ +#define CONFIG_SETUP_MEMORY_TAGS /* pass memory defs to kernel */ +#define CONFIG_INITRD_TAG /* pass initrd param to kernel */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is loaded by a bootloader */ +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ +#define CONFIG_DISPLAY_CPUINFO /* display CPU Info at startup */ + +/* setting board specific options */ +# define CONFIG_MACH_TYPE MACH_TYPE_SMARTWEB +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* The LED PINs */ +#define CONFIG_RED_LED AT91_PIN_PA9 +#define CONFIG_GREEN_LED AT91_PIN_PA6 + +/* + * SDRAM: 1 bank, 64 MB, base address 0x20000000 + * Already initialized before u-boot gets started. + */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 +#define CONFIG_SYS_SDRAM_SIZE (64 << 20) + +/* + * Perform a SDRAM Memtest from the start of SDRAM + * till the beginning of the U-Boot position in RAM. + */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_TEXT_BASE - 0x100000) + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + (128 << 10), 0x1000) + +/* NAND flash settings */ +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 + +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define MTDIDS_NAME_STR "atmel_nand" +#define MTDIDS_DEFAULT "nand0=" MTDIDS_NAME_STR +#define MTDPARTS_DEFAULT "mtdparts=" MTDIDS_NAME_STR ":" \ + "128k(Bootstrap)," \ + "896k(U-Boot)," \ + "512k(ENV0)," \ + "512k(ENV1)," \ + "4M(Linux)," \ + "-(Root-FS)" + +/* general purpose I/O */ +#define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ +#define CONFIG_AT91_GPIO /* enable the GPIO features */ +#define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */ + +/* serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 + +/* + * Ethernet configuration + * + */ +#define CONFIG_MACB +#define CONFIG_RMII /* use reduced MII inteface */ +#define CONFIG_NET_RETRY_COUNT 20 /* # of DHCP/BOOTP retries */ +#define CONFIG_AT91_WANTS_COMMON_PHY + +/* BOOTP and DHCP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_NFSBOOTCOMMAND \ + "setenv autoload yes; setenv autoboot yes; " \ + "setenv bootargs ${basicargs} ${mtdparts} " \ + "root=/dev/nfs ip=dhcp nfsroot=${serverip}:/srv/nfs/rootfs; " \ + "dhcp" + +/* Enable the watchdog */ +#define CONFIG_AT91SAM9_WATCHDOG +#if !defined(CONFIG_SPL_BUILD) +#define CONFIG_HW_WATCHDOG +#endif +#define CONFIG_AT91_HW_WDT_TIMEOUT 15 + +#if !defined(CONFIG_SPL_BUILD) +/* USB configuration */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#endif + +/* General Boot Parameter */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTCOMMAND "run flashboot" +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING + +/* + * RAM Memory address where to put the + * Linux Kernel befor starting. + */ +#define CONFIG_SYS_LOAD_ADDR 0x22000000 + +/* + * The NAND Flash partitions: + */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (0x100000) +#define CONFIG_ENV_OFFSET_REDUND (0x180000) +#define CONFIG_ENV_RANGE (0x80000) +#define CONFIG_ENV_SIZE (0x20000) + +/* + * Predefined environment variables. + * Usefull to define some easy to use boot commands. + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + \ + "basicargs=console=ttyS0,115200\0" \ + \ + "mtdparts="MTDPARTS_DEFAULT"\0" + +/* Command line & features configuration */ +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS + +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT + +#ifdef CONFIG_MACB +# define CONFIG_CMD_PING +# define CONFIG_CMD_DHCP +#else +# undef CONFIG_CMD_BOOTD +# undef CONFIG_CMD_NET +# undef CONFIG_CMD_NFS +#endif /* CONFIG_MACB */ + +#if !defined(CONFIG_SPL_BUILD) +/* Enable Device-Tree (FDT) support */ +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_FDT +#define CONFIG_FIT +#endif + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_INIT_SP_ADDR 0x301000 +#define CONFIG_SPL_STACK_R +#define CONFIG_SPL_STACK_R_ADDR CONFIG_SYS_TEXT_BASE +#else +/* + * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, + * leaving the correct space for initial global data structure above that + * address while providing maximum stack area below. + */ +#define CONFIG_SYS_INIT_SP_ADDR \ + (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) +#endif + + +/* Defines for SPL */ +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x0 +#define CONFIG_SPL_MAX_SIZE (4 * 1024) + +#define CONFIG_SPL_BSS_START_ADDR CONFIG_SYS_SDRAM_BASE +#define CONFIG_SPL_BSS_MAX_SIZE (16 * 1024) +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN +#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SYS_USE_NANDFLASH 1 +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_RAW_ONLY +#define CONFIG_SPL_NAND_SOFTECC +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_5_ADDR_CYCLE + +#define CONFIG_SYS_NAND_SIZE (256*1024*1024) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCSIZE 256 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCPOS { 40, 41, 42, 43, 44, 45, 46, 47, \ + 48, 49, 50, 51, 52, 53, 54, 55, \ + 56, 57, 58, 59, 60, 61, 62, 63, } + +#define CONFIG_SPL_ATMEL_SIZE +#define CONFIG_SYS_MASTER_CLOCK (198656000/2) +#define AT91_PLL_LOCK_TIMEOUT 1000000 +#define CONFIG_SYS_AT91_PLLA 0x2060bf09 +#define CONFIG_SYS_MCKR 0x100 +#define CONFIG_SYS_MCKR_CSS (0x02 | CONFIG_SYS_MCKR) +#define CONFIG_SYS_AT91_PLLB 0x10483f0e + +#if defined(CONFIG_SPL_BUILD) +#define CONFIG_SYS_THUMB_BUILD +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#undef CONFIG_SPL_OS_BOOT /* Not supported by existing map */ +#endif +#endif /* __CONFIG_H */
RomBOOT
Hello Tom,
Am 13.08.2015 um 15:17 schrieb Tom Rini:
RomBOOT
Thanks!
@Andreas: Do you find time for my other at91 board patches pending?
Here my current open patches list (except the at91 dfu support patches)
Patchwork [U-Boot] arm, at91: add axm extensions https://patchwork.ozlabs.org/patch/484257/
------------------------------------ corvus:
Patchwork [U-Boot] corvus, dfu: add dfu support https://patchwork.ozlabs.org/patch/484261/
Patchwork [U-Boot] at91: corvus: board updates https://patchwork.ozlabs.org/patch/484262/
------------------------------------ taurus:
Patchwork [U-Boot] taurus: board updates https://patchwork.ozlabs.org/patch/484292/
bye, Heiko
Heiko Schocher
