[PATCH] Revert "configs: JH7110: enable EFI_LOADER_BOUNCE_BUFFER"
("Enable EFI_LOADER_BOUNCE_BUFFER") is not the correct fix for the problem it describes.
The change of memory addressing leading to side-effects in commit 22f2c9ed9f53 ("efi: memory: use the lmb API's for allocating and freeing memory") is remedied by commit 1a48b0be93d4 ("lmb: prohibit allocations above ram_top even from same bank").
This reverts commit 9c792ab336f7146e8d49bca6d9d093d2392ded5d. --- configs/starfive_visionfive2_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index 20f89ae6796..1c70d1d4b70 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -32,7 +32,6 @@ CONFIG_CMODEL_MEDANY=y CONFIG_RISCV_SMODE=y # CONFIG_OF_BOARD_FIXUP is not set # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y CONFIG_FIT=y CONFIG_BOOTSTD_DEFAULTS=y CONFIG_BOOTSTAGE=y
base-commit: 50334151c02077f16613b0a082d95640800ba60e
E Shattow
