[PATCH] buildman: Remove output binaries before building
Buildman reuses build directories from previous builds to avoid the cost of 'make mrproper' for every build. If the previous build produced an SPL image but the current one does not, the SPL image will remain and buildman will think it is a result of building the current board.
Remove these files before building, to avoid this problem.
tools/buildman/builderthread.py | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index c5bf31e9e11..d6648685823 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -13,6 +13,7 @@ from patman import command from patman import gitutil
RETURN_CODE_RETRY = -1 +BASE_ELF_FILENAMES = ['u-boot', 'spl/u-boot-spl', 'tpl/u-boot-tpl']
def Mkdir(dirname, parents = False): """Make a directory if it doesn't already exist. @@ -240,6 +241,17 @@ class BuilderThread(threading.Thread): args.extend(self.builder.toolchains.GetMakeArguments(brd)) args.extend(self.toolchain.MakeArgs())
+ # Remove any output targets. Since we use a build directory that + # was previously used by another board, it may have produced an + # SPL image. If we don't remove it (i.e. see do_config and + # self.mrproper below) then it will appear to be the output of + # this build, even if it does not produce SPL images. + build_dir = self.builder.GetBuildDir(commit_upto, brd.target) + for elf in BASE_ELF_FILENAMES: + fname = os.path.join(out_dir, elf) + if os.path.exists(fname): + os.remove(fname) + # If we need to reconfigure, do that now if do_config: config_out = '' @@ -335,7 +347,7 @@ class BuilderThread(threading.Thread): for var in sorted(env.keys()): print('%s="%s"' % (var, env[var]), file=fd) lines = [] - for fname in ['u-boot', 'spl/u-boot-spl', 'tpl/u-boot-tpl']: + for fname in BASE_ELF_FILENAMES: cmd = ['%snm' % self.toolchain.cross, '--size-sort', fname] nm_result = command.RunPipe([cmd], capture=True, capture_stderr=True, cwd=result.out_dir,
Applied to u-boot-dm/next, thanks!
