[PATCH 1/1] sandbox: fix documentation of struct host_ops
The documentation of struct host_ops should be Sphinx compliant.
Fixes: 9bd1aa8af2ed ("dm: sandbox: Create a new HOST uclass") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/sandbox_host.h | 19 ++++++++----------- 1 file changed, 8 insertions(+), 11 deletions(-)
diff --git a/include/sandbox_host.h b/include/sandbox_host.h index 2e37ede235..ebd7d99b47 100644 --- a/include/sandbox_host.h +++ b/include/sandbox_host.h @@ -23,26 +23,23 @@ struct host_sb_plat {
/** * struct host_ops - operations supported by UCLASS_HOST - * - * @attach_file: Attach a new file to a device - * @detach_file: Detach a file from a device */ struct host_ops { - /* - * attach_file() - Attach a new file to the device + /** + * @attach_file: - Attach a new file to the device * - * @dev: Device to update - * @filename: Name of the file, e.g. "/path/to/disk.img" - * Returns: 0 if OK, -EEXIST if a file is already attached, other -ve on + * @attach_file.dev: Device to update + * @attach_file.filename: Name of the file, e.g. "/path/to/disk.img" + * @attach_file.Returns: 0 if OK, -EEXIST if a file is already attached, other -ve on * other error */ int (*attach_file)(struct udevice *dev, const char *filename);
/** - * detach_file() - Detach a file from the device + * @detach_file: - Detach a file from the device * - * @dev: Device to detach from - * Returns: 0 if OK, -ENOENT if no file is attached, other -ve on other + * @detach_file.dev: Device to detach from + * @detach_file.Returns: 0 if OK, -ENOENT if no file is attached, other -ve on other * error */ int (*detach_file)(struct udevice *dev);
On Mon, 14 Nov 2022 at 02:28, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
