Add nxp tja1103 phy driver.
Signed-off-by: Radu Pirea (NXP OSS) radu-nicolae.pirea@oss.nxp.com --- MAINTAINERS | 5 + drivers/net/phy/Kconfig | 6 + drivers/net/phy/Makefile | 1 + drivers/net/phy/nxp-c45-tja11xx.c | 348 ++++++++++++++++++++++++++++++ drivers/net/phy/phy.c | 3 + include/phy.h | 5 + 6 files changed, 368 insertions(+) create mode 100644 drivers/net/phy/nxp-c45-tja11xx.c
diff --git a/MAINTAINERS b/MAINTAINERS index 20092cb367..737ba3b162 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -910,6 +910,11 @@ S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-nios.git F: arch/nios2/
+NXP C45 TJA11XX PHY DRIVER +M: Radu Pirea radu-nicolae.pirea@oss.nxp.com +S: Maintained +F: drivers/net/phy/nxp-c45-tja11xx.c + ONENAND #M: Lukasz Majewski l.majewski@majess.pl S: Orphaned (Since 2017-01) diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 070ffa82cb..405bf76753 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -197,6 +197,12 @@ config PHY_MSCC config PHY_NATSEMI bool "National Semiconductor Ethernet PHYs support"
+config PHY_NXP_C45_TJA11XX + tristate "NXP C45 TJA11XX PHYs" + help + Enable support for NXP C45 TJA11XX PHYs. + Currently supports only the TJA1103 PHY. + config PHY_REALTEK bool "Realtek Ethernet PHYs support"
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index e967f82201..218b8c7669 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_PHY_MICREL_KSZ8XXX) += micrel_ksz8xxx.o obj-$(CONFIG_PHY_MICREL_KSZ90X1) += micrel_ksz90x1.o obj-$(CONFIG_PHY_MESON_GXL) += meson-gxl.o obj-$(CONFIG_PHY_NATSEMI) += natsemi.o +obj-$(CONFIG_PHY_NXP_C45_TJA11XX) += nxp-c45-tja11xx.o obj-$(CONFIG_PHY_REALTEK) += realtek.o obj-$(CONFIG_PHY_SMSC) += smsc.o obj-$(CONFIG_PHY_TERANETICS) += teranetics.o diff --git a/drivers/net/phy/nxp-c45-tja11xx.c b/drivers/net/phy/nxp-c45-tja11xx.c new file mode 100644 index 0000000000..f86e31f0d9 --- /dev/null +++ b/drivers/net/phy/nxp-c45-tja11xx.c @@ -0,0 +1,348 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * NXP C45 PHY driver + * + * Copyright 2021 NXP + * Author: Radu Pirea radu-nicolae.pirea@oss.nxp.com + */ +#include <common.h> +#include <dm.h> +#include <dm/devres.h> +#include <linux/delay.h> +#include <linux/math64.h> +#include <linux/mdio.h> +#include <phy.h> + +#define PHY_ID_TJA_1103 0x001BB010 + +#define VEND1_DEVICE_CONTROL 0x0040 +#define DEVICE_CONTROL_RESET BIT(15) +#define DEVICE_CONTROL_CONFIG_GLOBAL_EN BIT(14) +#define DEVICE_CONTROL_CONFIG_ALL_EN BIT(13) + +#define VEND1_PORT_CONTROL 0x8040 +#define PORT_CONTROL_EN BIT(14) + +#define VEND1_PHY_CONTROL 0x8100 +#define PHY_CONFIG_EN BIT(14) +#define PHY_START_OP BIT(0) + +#define VEND1_PHY_CONFIG 0x8108 +#define PHY_CONFIG_AUTO BIT(0) + +#define VEND1_PORT_INFRA_CONTROL 0xAC00 +#define PORT_INFRA_CONTROL_EN BIT(14) + +#define VEND1_RXID 0xAFCC +#define VEND1_TXID 0xAFCD +#define ID_ENABLE BIT(15) + +#define VEND1_ABILITIES 0xAFC4 +#define RGMII_ID_ABILITY BIT(15) +#define RGMII_ABILITY BIT(14) +#define RMII_ABILITY BIT(10) +#define REVMII_ABILITY BIT(9) +#define MII_ABILITY BIT(8) +#define SGMII_ABILITY BIT(0) + +#define VEND1_MII_BASIC_CONFIG 0xAFC6 +#define MII_BASIC_CONFIG_REV BIT(8) +#define MII_BASIC_CONFIG_SGMII 0x9 +#define MII_BASIC_CONFIG_RGMII 0x7 +#define MII_BASIC_CONFIG_RMII 0x5 +#define MII_BASIC_CONFIG_MII 0x4 + +#define RGMII_PERIOD_PS 8000U +#define PS_PER_DEGREE div_u64(RGMII_PERIOD_PS, 360) +#define MIN_ID_PS 1644U +#define MAX_ID_PS 2260U +#define DEFAULT_ID_PS 2000U + +#define RESET_DELAY_MS 25 +#define CONF_EN_DELAY_US 450 + +struct nxp_c45_phy { + u32 tx_delay; + u32 rx_delay; +}; + +static int nxp_c45_soft_reset(struct phy_device *phydev) +{ + int tries = 10, ret; + + ret = phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_DEVICE_CONTROL, + DEVICE_CONTROL_RESET); + if (ret) + return ret; + + do { + ret = phy_read_mmd(phydev, MDIO_MMD_VEND1, + VEND1_DEVICE_CONTROL); + if (!(ret & DEVICE_CONTROL_RESET)) + return 0; + mdelay(RESET_DELAY_MS); + } while (tries--); + + return -EIO; +} + +static int nxp_c45_start_op(struct phy_device *phydev) +{ + return phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_PHY_CONTROL, + PHY_START_OP); +} + +static int nxp_c45_config_enable(struct phy_device *phydev) +{ + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_DEVICE_CONTROL, + DEVICE_CONTROL_CONFIG_GLOBAL_EN | + DEVICE_CONTROL_CONFIG_ALL_EN); + udelay(CONF_EN_DELAY_US); + + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_PORT_CONTROL, + PORT_CONTROL_EN); + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_PHY_CONTROL, + PHY_CONFIG_EN); + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_PORT_INFRA_CONTROL, + PORT_INFRA_CONTROL_EN); + + return 0; +} + +static u64 nxp_c45_get_phase_shift(u64 phase_offset_raw) +{ + /* The delay in degree phase is 73.8 + phase_offset_raw * 0.9. + * To avoid floating point operations we'll multiply by 10 + * and get 1 decimal point precision. + */ + phase_offset_raw *= 10; + phase_offset_raw -= 738; + return div_u64(phase_offset_raw, 9); +} + +static void nxp_c45_disable_delays(struct phy_device *phydev) +{ + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_TXID, 0); + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_RXID, 0); +} + +static int nxp_c45_check_delay(struct phy_device *phydev, u32 delay) +{ + if (delay < MIN_ID_PS) { + pr_err("%s: delay value smaller than %u\n", + phydev->drv->name, MIN_ID_PS); + return -EINVAL; + } + + if (delay > MAX_ID_PS) { + pr_err("%s: delay value higher than %u\n", + phydev->drv->name, MAX_ID_PS); + return -EINVAL; + } + + return 0; +} + +static int nxp_c45_get_delays(struct phy_device *phydev) +{ + struct nxp_c45_phy *priv = phydev->priv; + int ret; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) { + ret = dev_read_u32(phydev->dev, "tx-internal-delay-ps", + &priv->tx_delay); + if (ret) + priv->tx_delay = DEFAULT_ID_PS; + + ret = nxp_c45_check_delay(phydev, priv->tx_delay); + if (ret) { + pr_err("%s: tx-internal-delay-ps invalid value\n", + phydev->drv->name); + return ret; + } + } + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) { + ret = dev_read_u32(phydev->dev, "rx-internal-delay-ps", + &priv->rx_delay); + if (ret) + priv->rx_delay = DEFAULT_ID_PS; + + ret = nxp_c45_check_delay(phydev, priv->rx_delay); + if (ret) { + pr_err("%s: rx-internal-delay-ps invalid value\n", + phydev->drv->name); + return ret; + } + } + + return 0; +} + +static void nxp_c45_set_delays(struct phy_device *phydev) +{ + struct nxp_c45_phy *priv = phydev->priv; + u64 tx_delay = priv->tx_delay; + u64 rx_delay = priv->rx_delay; + u64 degree; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) { + degree = div_u64(tx_delay, PS_PER_DEGREE); + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_TXID, + ID_ENABLE | nxp_c45_get_phase_shift(degree)); + } else { + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_TXID, 0); + } + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) { + degree = div_u64(rx_delay, PS_PER_DEGREE); + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_RXID, + ID_ENABLE | nxp_c45_get_phase_shift(degree)); + } else { + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_RXID, 0); + } +} + +static int nxp_c45_set_phy_mode(struct phy_device *phydev) +{ + int ret; + + ret = phy_read_mmd(phydev, MDIO_MMD_VEND1, VEND1_ABILITIES); + pr_debug("%s: Clause 45 managed PHY abilities 0x%x\n", + phydev->drv->name, ret); + + switch (phydev->interface) { + case PHY_INTERFACE_MODE_RGMII: + if (!(ret & RGMII_ABILITY)) { + pr_err("%s: rgmii mode not supported\n", + phydev->drv->name); + return -EINVAL; + } + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_MII_BASIC_CONFIG, + MII_BASIC_CONFIG_RGMII); + nxp_c45_disable_delays(phydev); + break; + case PHY_INTERFACE_MODE_RGMII_ID: + case PHY_INTERFACE_MODE_RGMII_TXID: + case PHY_INTERFACE_MODE_RGMII_RXID: + if (!(ret & RGMII_ID_ABILITY)) { + pr_err("%s: rgmii-id, rgmii-txid, rgmii-rxid modes are not supported\n", + phydev->drv->name); + return -EINVAL; + } + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_MII_BASIC_CONFIG, + MII_BASIC_CONFIG_RGMII); + ret = nxp_c45_get_delays(phydev); + if (ret) + return ret; + + nxp_c45_set_delays(phydev); + break; + case PHY_INTERFACE_MODE_MII: + if (!(ret & MII_ABILITY)) { + pr_err("%s: mii mode not supported\n", + phydev->drv->name); + return -EINVAL; + } + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_MII_BASIC_CONFIG, + MII_BASIC_CONFIG_MII); + break; + case PHY_INTERFACE_MODE_RMII: + if (!(ret & RMII_ABILITY)) { + pr_err("%s: rmii mode not supported\n", + phydev->drv->name); + return -EINVAL; + } + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_MII_BASIC_CONFIG, + MII_BASIC_CONFIG_RMII); + break; + case PHY_INTERFACE_MODE_SGMII: + if (!(ret & SGMII_ABILITY)) { + pr_err("%s: sgmii mode not supported\n", + phydev->drv->name); + return -EINVAL; + } + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_MII_BASIC_CONFIG, + MII_BASIC_CONFIG_SGMII); + break; + case PHY_INTERFACE_MODE_INTERNAL: + break; + default: + return -EINVAL; + } + + return 0; +} + +static int nxp_c45_config(struct phy_device *phydev) +{ + int ret; + + ret = nxp_c45_soft_reset(phydev); + if (ret) + return ret; + + ret = nxp_c45_config_enable(phydev); + if (ret) { + pr_err("%s: Failed to enable config\n", phydev->drv->name); + return ret; + } + + phy_write_mmd(phydev, MDIO_MMD_VEND1, VEND1_PHY_CONFIG, + PHY_CONFIG_AUTO); + + ret = nxp_c45_set_phy_mode(phydev); + if (ret) { + pr_err("%s: Failed to set phy mode\n", phydev->drv->name); + return ret; + } + + phydev->autoneg = AUTONEG_DISABLE; + + return nxp_c45_start_op(phydev); +} + +static int nxp_c45_startup(struct phy_device *phydev) +{ + u32 reg; + + reg = phy_read_mmd(phydev, MDIO_MMD_PMAPMD, MDIO_STAT1); + phydev->link = !!(reg & MDIO_STAT1_LSTATUS); + phydev->speed = SPEED_100; + phydev->duplex = DUPLEX_FULL; + return 0; +} + +static int nxp_c45_probe(struct phy_device *phydev) +{ + struct nxp_c45_phy *priv; + + priv = devm_kzalloc(phydev->priv, sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + + phydev->priv = priv; + + return 0; +} + +static struct phy_driver nxp_tja11xx = { + .name = "NXP C45 TJA1103", + .uid = PHY_ID_TJA_1103, + .mask = 0xfffff0, + .features = PHY_100BT1_FEATURES, + .probe = &nxp_c45_probe, + .config = &nxp_c45_config, + .startup = &nxp_c45_startup, + .shutdown = &genphy_shutdown, +}; + +int phy_nxp_tja11xx_init(void) +{ + phy_register(&nxp_tja11xx); + return 0; +} diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index ed197fa46d..69acb69460 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -529,6 +529,9 @@ int phy_init(void) #ifdef CONFIG_PHY_NATSEMI phy_natsemi_init(); #endif +#ifdef CONFIG_NXP_C45_TJA11XX_PHY + phy_nxp_tja11xx_init(); +#endif #ifdef CONFIG_PHY_REALTEK phy_realtek_init(); #endif diff --git a/include/phy.h b/include/phy.h index 2754421ed4..6b928636b6 100644 --- a/include/phy.h +++ b/include/phy.h @@ -51,6 +51,10 @@ struct udevice; PHY_100BT_FEATURES | \ PHY_DEFAULT_FEATURES)
+#define PHY_100BT1_FEATURES (SUPPORTED_TP | \ + SUPPORTED_MII | \ + SUPPORTED_100baseT_Full) + #define PHY_GBIT_FEATURES (PHY_BASIC_FEATURES | \ PHY_1000BT_FEATURES)
@@ -523,6 +527,7 @@ int phy_micrel_ksz8xxx_init(void); int phy_micrel_ksz90x1_init(void); int phy_meson_gxl_init(void); int phy_natsemi_init(void); +int phy_nxp_tja11xx_init(void); int phy_realtek_init(void); int phy_smsc_init(void); int phy_teranetics_init(void);
On Fri, Jun 18, 2021 at 9:58 PM Radu Pirea (NXP OSS) radu-nicolae.pirea@oss.nxp.com wrote:
help
- NXP C45 PHY driver
- Copyright 2021 NXP
- Author: Radu Pirea radu-nicolae.pirea@oss.nxp.com
u32 tx_delay;
u32 rx_delay;
if (ret)
return ret;
do {
} while (tries--);
return -EIO;
PHY_START_OP);
PORT_CONTROL_EN);
PHY_CONFIG_EN);
return -EINVAL;
return -EINVAL;
int ret;
&priv->tx_delay);
if (ret)
if (ret) {
phydev->drv->name);
return ret;
&priv->rx_delay);
if (ret)
if (ret) {
phydev->drv->name);
return ret;
u64 degree;
} else {
} else {
int ret;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
if (ret)
return ret;
break;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
break;
break;
default:
return -EINVAL;
int ret;
if (ret)
return ret;
if (ret) {
return ret;
PHY_CONFIG_AUTO);
if (ret) {
return ret;
u32 reg;
if (!priv)
return -ENOMEM;
.mask = 0xfffff0,
SUPPORTED_MII | \
@@ -523,6 +527,7 @@ int phy_micrel_ksz8xxx_init(void); int phy_micrel_ksz90x1_init(void); int phy_meson_gxl_init(void); int phy_natsemi_init(void); +int phy_nxp_tja11xx_init(void); int phy_realtek_init(void); int phy_smsc_init(void); int phy_teranetics_init(void); -- 2.31.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
help
u32 tx_delay;
u32 rx_delay;
if (ret)
return ret;
do {
} while (tries--);
return -EIO;
PHY_START_OP);
PORT_CONTROL_EN);
PHY_CONFIG_EN);
return -EINVAL;
return -EINVAL;
int ret;
&priv->tx_delay);
if (ret)
if (ret) {
phydev->drv->name);
return ret;
&priv->rx_delay);
if (ret)
if (ret) {
phydev->drv->name);
return ret;
u64 degree;
} else {
} else {
int ret;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
if (ret)
return ret;
break;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
break;
phydev->drv->name);
return -EINVAL;
break;
break;
default:
return -EINVAL;
int ret;
if (ret)
return ret;
if (ret) {
return ret;
PHY_CONFIG_AUTO);
if (ret) {
return ret;
u32 reg;
if (!priv)
return -ENOMEM;
.mask = 0xfffff0,
SUPPORTED_MII | \
Applied to network/master, Thanks.
Ramon Fried
