[U-Boot] ARM: interrupt_init before relocation, write fails
v2013.10-rc1 (and after) has a patch ( http://lists.denx.de/pipermail/u-boot/2013-June/156298.html) which sets up the abort stack before relocation. However, what I am seeing: IRQ_STACK_START_IN is in flash at that time, so this write fails.
interrupt_init: FF0A0FA8 e59f3010 LDR R3,ff0a0fc0 (ff0a0050=IRQ_STACK_START_IN)
Before this patch, abort stack setup was done after relocation, so target location is in RAM and writeable.
interrupt_init: 9FFB4020 e59f3010 LDR R3,9ffb4038 (9ffb3054=IRQ_STACK_START_IN)
If I revert that patch, I don't see that problem.
Joe Kulikauskas
FWIW, I am working on a PXA270 target, and have had to revert this patch as well. I hadn't gotten around to tracking down where and why I was crashing though so hadn't emailed in a bug report yet. Now seeing as there's someone else now seeing it too I thought I would chime in with a "me too".
Rob: CC'd you since you were the author and might have some insight. Full email in entirety below.
- Andy
Joe Kulikauskas
Other than doing stack setup in a completely different way by setting the mode in the CPSR and setting up SP_irq and SP_abt directly, I don't see an easy fix. So we should revert this change. It works for me because I run from RAM before relocation.
Albert or Tom, can you please revert commit 0f5141e9c57e96de11642a.
Rob
- Andy
Joe Kulikauskas
Hi Rob,
(putting back more context)
Hmm... Which one exactly is "this write"? The instructions below are reads, not writes.
That problem only happens when there actually is an abort before relocation, right?
I'm ok with reverting in the ARM repo (I'll PR to mainline after I get Atmel and IMX in), as soon as I get a clear understanding of the exact issue.
Rob
Amicalement,
On 11/05/2013 01:17 PM, Albert ARIBAUD wrote:
Hi Rob,
Not as I understand it. The address here is the address of the variable holding the stack address. So we are trying to write the stack address to flash which I guess does more that just get ignored.
Rob
Rob
Amicalement,
Rob, yes that's correct.
To Albert's question: the disassembled instruction I had showed LDR R3,ff0a0fc0 is load of r3 with address of the variable holding the stack address; "this write" is the str which I've now copied in below. IRQ_STACK_START_IN = gd->irq_sp + 8; ff0a0fb0: e5992044 ldr r2, [r9, #68] ; 0x44 ff0a0fb4: e2822008 add r2, r2, #8 ff0a0fb8: e5832000 str r2, [r3]
For my target, IIRC the write to flash caused problem in the flash controller hardware, breaking further instruction fetches. On other platforms the write to flash may fail silently. But the issue is that interrupt_init() moving into board_init_f (i.e. before relocation) generally just doesn't work right.
Joe
Hi Rob,
Rob
patch
Rob
Amicalement,
Hi Joe,
On Wed, 6 Nov 2013 09:18:53 -0700, Joe Kulikauskas jkulikauskas@cardinalpeak.com wrote:
Joe
Thanks Rob and Joe for the clarification.
Indeed interrupt_init() cannot execute before relocation as it sets globals.
Further, interrupt_init() uses globals to communicate with start.S. This should be changed. I understand that is because the interrupt handlers actually set the interrupt stack when they are invoked -- and that is unnecessary; stacks should be set up as soon as their addresses are known.
I'll revert the patch as soon as I finish getting the current PRs in.
I have a start.S rewrite effort underway whcuh I should post soon. I'll add to it a change to the way stacks are initialized.
Amicalement,
Albert ARIBAUD
Andrew Ruder
Joe Kulikauskas
Rob Herring
