Re: [PATCH 04/11] net: dwc_eth_qos: Scrub ifdeffery
On 3/9/24 03:11, Marek Vasut wrote:
Replace ifdef CONFIG_CLK with if (CONFIG_IS_ENABLED(CLK)) to improve code build coverage. Some of the functions printed debug("%s: OK\n", __func__); on exit with and without CLK enabled, some did not, make it consistent and print nothing if CLK is disabled.
Signed-off-by: Marek Vasut marex@denx.de
Cc: Christophe Roullier christophe.roullier@st.com Cc: Joe Hershberger joe.hershberger@ni.com Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Ramon Fried rfried.dev@gmail.com Cc: u-boot@dh-electronics.com Cc: uboot-stm32@st-md-mailman.stormreply.com
drivers/net/dwc_eth_qos_stm32.c | 25 ++++++++++++------------- 1 file changed, 12 insertions(+), 13 deletions(-)
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 7520a136ed0..d7ec0c9be36 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -46,21 +46,22 @@
static ulong eqos_get_tick_clk_rate_stm32(struct udevice *dev) { -#ifdef CONFIG_CLK
struct eqos_priv *eqos = dev_get_priv(dev);
struct eqos_priv __maybe_unused *eqos = dev_get_priv(dev);
if (!CONFIG_IS_ENABLED(CLK))
return 0; return clk_get_rate(&eqos->clk_master_bus);
-#else
-#endif }
static int eqos_start_clks_stm32(struct udevice *dev) { -#ifdef CONFIG_CLK
struct eqos_priv __maybe_unused *eqos = dev_get_priv(dev); int ret;
debug("%s(dev=%p):\n", __func__, dev); ret = clk_enable(&eqos->clk_master_bus);
@@ -89,12 +90,10 @@ static int eqos_start_clks_stm32(struct udevice *dev) } eqos->clk_ck_enabled = true; } -#endif
debug("%s: OK\n", __func__); return 0;
-#ifdef CONFIG_CLK err_disable_clk_tx: clk_disable(&eqos->clk_tx); err_disable_clk_rx: @@ -104,20 +103,20 @@ err_disable_clk_master_bus: err: debug("%s: FAILED: %d\n", __func__, ret); return ret; -#endif }
static int eqos_stop_clks_stm32(struct udevice *dev) { -#ifdef CONFIG_CLK
return 0; debug("%s(dev=%p):\n", __func__, dev); clk_disable(&eqos->clk_tx); clk_disable(&eqos->clk_rx); clk_disable(&eqos->clk_master_bus);
-#endif
Reviewed-by: Christophe ROULLIER christophe.roullier@foss.st.com
Christophe ROULLIER
