[U-Boot] [PATCH] mpc8641: Stop supporting non-PCI_PNP configs
We don't actually ever do this, remove the code so we can stop maintaining it.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 22 +--------------------- include/configs/MPC8641HPCN.h | 6 ------ 2 files changed, 1 insertions(+), 27 deletions(-)
diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index 9635cfc..c7e10d8 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -121,27 +121,7 @@ fixed_sdram(void)
#if defined(CONFIG_PCI) -/* - * Initialize PCI Devices, report devices found. - */ - -#ifndef CONFIG_PCI_PNP -static struct pci_config_table pci_fsl86xxads_config_table[] = { - {PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, PCI_ANY_ID, - PCI_IDSEL_NUMBER, PCI_ANY_ID, - pci_cfgfunc_config_device, {PCI_ENET0_IOADDR, - PCI_ENET0_MEMADDR, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER}}, - {} -}; -#endif - - -static struct pci_controller pci1_hose = { -#ifndef CONFIG_PCI_PNP - config_table:pci_mpc86xxcts_config_table -#endif -}; +static struct pci_controller pci1_hose; #endif /* CONFIG_PCI */
#ifdef CONFIG_PCI2 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index abf2a58..0bf5888 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -341,12 +341,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 #define CONFIG_SYS_OHCI_SWAP_REG_ACCESS 1
-#if !defined(CONFIG_PCI_PNP) - #define PCI_ENET0_IOADDR 0xe0000000 - #define PCI_ENET0_MEMADDR 0xe0000000 - #define PCI_IDSEL_NUMBER 0x0c /* slot0->3(IDSEL)=12->15 */ -#endif - /*PCIE video card used*/ #define VIDEO_IO_OFFSET CONFIG_SYS_PCI2_IO_PHYS
Applied to u-boot-mpc86xx.
Thanks, jdl
Becky Bruce
Jon Loeliger
