[U-Boot] Please pull u-boot-dm (take 2)
Hi Tom,
This is without the two offending patches that broke BUILD_TAG. I'll figure out a sandbox test for this and resubmit those patches later.
The following changes since commit 156d64fa55e9914b144c5e83f2a9e13d1223a4d3:
Merge git://git.denx.de/u-boot-rockchip (2017-06-08 12:14:11 -0400)
git://git.denx.de/u-boot-dm.git
for you to fetch changes up to 9620d87259572ef21f0df60988d9a932ca673779:
cmd/fdt: support single value replacement within an array (2017-06-09 13:45:34 -0600)
---------------------------------------------------------------- Daniel Schwierzeck (2): buildman: disable localized and unicode output of all build tools buildman: properly translate strings for log and err files to ASCII
Hannes Schmelzer (1): cmd/fdt: support single value replacement within an array
Philipp Tomsich (1): patman: encode CC list to UTF-8
Simon Glass (35): patman: Adjust handling of unicode email address patman: Don't convert input data to unicode patman: Rename 'str' variable in EmailPatches() patman: Don't report unicode character patman: Don't return the series in FixPatches() patman: Add unicode to test patches patman: Add a maintainer test feature to MakeCcFile() patman: Rename 'list' variable in MakeCcFile() patman: Add a functional test arm: arm720t: Support CONFIG_SKIP_LOWLEVEL_INIT_ONLY arm: Rename HCTR to HTCR arm: Don't try to support CONFIG_ARMV7_LPAE on ARMv4T arm: Disable LPAE if not enabled power: regulator: Add more debugging and fix a missing newline tegra: Init clocks even when SPL did not run tegra: dts: Add cros-ec SPI settings tegra: spi: Wait a little after setting the clocks tegra: nyan-big: Enable the dhrystone benchmark tegra: video: Don't power up the SOR twice tegra: Enable CP15 init tegra: clock: Avoid a divide-by-zero error tegra: nyan-big: Add a .its file for chromium README: Add instructions for chain-loading U-Boot rockchip: Setup default PWM flags rockchip: Fix regualtor typo in veyron rockchip: rk3288: Add error debugging to veyron_init() rockchip: video: Add remove() methods rockchip: video: Take the vop device out of standby rockchip: jerry: Add a .its file for chromium rockchip: rk3288: Convert clock driver to use shifted masks rockchip: Init clocks again when chain-loading rockchip: rk3288: Allow setting up clocks in U-Boot proper rockchip: Enable the video display banner rockchip: jerry: Disable CONFIG_CONSOLE_SCROLL_LINES README: Add instructions for chain-loading U-Boot on jerry
Tom Rini (2): sandbox: Fix comparison of unsigned enum expression warning buildman: Fix bloat option when 'new' only drops functions
arch/arm/cpu/arm720t/start.S | 6 +- arch/arm/dts/rk3288-veyron-jerry.dts | 2 +- arch/arm/dts/tegra124-nyan-big-u-boot.dtsi | 9 ++ arch/arm/include/asm/arch-rockchip/cru_rk3288.h | 74 +++++++-------- arch/arm/include/asm/arch-tegra/clock.h | 3 + arch/arm/lib/cache-cp15.c | 13 ++- arch/arm/mach-rockchip/rk3288-board.c | 39 +++++++- arch/arm/mach-tegra/board2.c | 3 + arch/arm/mach-tegra/clock.c | 10 ++- arch/arm/mach-tegra/tegra124/clock.c | 18 ++++ arch/sandbox/cpu/os.c | 2 +- cmd/fdt.c | 29 ++++-- configs/chromebook_jerry_defconfig | 2 +- configs/nyan-big_defconfig | 2 + doc/README.chromium | 252 ++++++++++++++++++++++++++++++++++++++++++++++++++++ doc/chromium/chromebook_jerry.its | 42 +++++++++ doc/chromium/devkeys/kernel.keyblock | Bin 0 -> 1208 bytes doc/chromium/devkeys/kernel_data_key.vbprivk | Bin 0 -> 1199 bytes doc/chromium/nyan-big.its | 42 +++++++++ drivers/clk/rockchip/clk_rk3288.c | 146 +++++++++++++++--------------- drivers/power/regulator/regulator-uclass.c | 8 +- drivers/pwm/rk_pwm.c | 1 + drivers/spi/tegra114_spi.c | 1 + drivers/video/rockchip/rk3288_vop.c | 14 +++ drivers/video/rockchip/rk_edp.c | 16 +++- drivers/video/rockchip/rk_vop.c | 3 + drivers/video/tegra124/sor.c | 9 ++ include/configs/rockchip-common.h | 2 + include/configs/tegra-common-post.h | 2 +- tools/buildman/builder.py | 2 +- tools/buildman/builderthread.py | 6 +- tools/buildman/toolchain.py | 6 +- tools/patman/cros_subprocess.py | 4 - tools/patman/func_test.py | 242 +++++++++++++++++++++++++++++++++++++++++++++++++ tools/patman/gitutil.py | 8 +- tools/patman/patchstream.py | 23 ++--- tools/patman/patman.py | 10 ++- tools/patman/series.py | 28 +++--- tools/patman/test.py | 9 ++ tools/patman/test/0000-cover-letter.patch | 23 +++++ tools/patman/test/0001-pci-Correct-cast-for-sandbox.patch | 48 ++++++++++ tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch | 73 +++++++++++++++ tools/patman/test/test01.txt | 56 ++++++++++++ 43 files changed, 1120 insertions(+), 168 deletions(-) create mode 100644 doc/README.chromium create mode 100644 doc/chromium/chromebook_jerry.its create mode 100644 doc/chromium/devkeys/kernel.keyblock create mode 100644 doc/chromium/devkeys/kernel_data_key.vbprivk create mode 100644 doc/chromium/nyan-big.its create mode 100644 tools/patman/func_test.py create mode 100644 tools/patman/test/0000-cover-letter.patch create mode 100644 tools/patman/test/0001-pci-Correct-cast-for-sandbox.patch create mode 100644 tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch create mode 100644 tools/patman/test/test01.txt
On 06/09/2017 04:37 PM, Simon Glass wrote:
Hi Tom,
This version passes my Jenkins tests OK.
I did try to reproduce the issue in the original pull request, but wasn't able to immediately. It didn't seem to be solely/simply related to BUILD_TAG. Unfortunately, I have a few fire-fights going on so can't spend any more time on this today; perhaps next week.
Hi Stephen,
Hi Tom,
Habeus corpus. I can repeat the problem on beaver - I don't get a crash but I clearly see a stack overflow which I'm sure could cause a crash.
The problem is that snprintf() returns the required buffer size rather than the numberof bytes written to the buffer. I forgot about that. I'll send an updated patch.
Of course the bigger problem is that my size is not large enough so I will have to increase it (and thus hide the fault).
On Fri, Jun 09, 2017 at 04:37:07PM -0600, Simon Glass wrote:
Hi Tom,
Stephen Warren
