[U-Boot] Microblaze gpio reset handling
Hi Simon,
I have looked at converting the rest of microblaze drivers to DM and I am curious why I can't use top level compatible string in DM based drivers. I am looking at ways how to move gpio and microblaze soft reset to sysreset framework and I see that core is not able to find out my high level xlnx,microblaze compatible string.
/ { #address-cells = <1>; #size-cells = <1>; compatible = "xlnx,microblaze"; model = "Xilinx MicroBlaze"; hard-reset-gpios = <&reset_gpio 0 1>;
As far I have seen only nodes are checked but unfortunately Microblaze is using hard-reset-gpios in root for years and will be good to keep it like that.
I have already tested to bind that driver from board file like device_bind_driver(gd->dm_root, "microblaze_sysreset", "reset", NULL); which is working fine but just asking if there is another solution for this.
Thanks, Michal
Hi Michal,
On 12 July 2018 at 08:28, Michal Simek michal.simek@xilinx.com wrote:
Hi Simon,
Not at present. But I think we should actually try to bind a driver to the root node. Probably needs changes to root.c.
Michal Simek
