Pull request for efi-2021-07-rc5-2
Dear Tom,
I have removed the one patch for better EFI/DM integration that caused sandbox test problems on my last pull request. This topic needs more coordination with Simon.
Gitlab CI showed no problems: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/7968
The following changes since commit 4d8c21da4170e7c1d38c0106898e0d8347b4f0ff:
Merge tag 'u-boot-imx-20210625' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx (2021-06-25 13:33:47 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2021-07-rc5-2
for you to fetch changes up to 70e80666f26a516096f3787e884d42818d8b4087:
smbios: Fix SMBIOS tables (2021-06-28 19:57:13 +0200)
---------------------------------------------------------------- Pull request for efi-2021-07-rc5-2
Documentation:
* man-page for askenv
bug fixes
* correct display of BootOrder in efidebug command * do not allow TPL_HIGH_LEVEL for CreateEvent(Ex) * correct handling of unknown properties in SMBIOS tables
---------------------------------------------------------------- Adarsh Babu Kalepalli (1): doc/usage: cmd-usage help file for askenv
Heinrich Schuchardt (3): efi_loader: TPL_HIGH_LEVEL not allowed for CreateEvent efidebug: correct display of BootOrder smbios: convert function descriptions to Sphinx style
Ilias Apalodimas (2): smbios: Fix BIOS Characteristics Extension Byte 2 smbios: Fix SMBIOS tables
cmd/efidebug.c | 2 +- doc/usage/askenv.rst | 87 +++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + include/smbios.h | 2 +- lib/efi_loader/efi_boottime.c | 1 - lib/efi_selftest/efi_selftest_tpl.c | 2 +- lib/smbios.c | 24 +++++++--- 7 files changed, 108 insertions(+), 11 deletions(-) create mode 100644 doc/usage/askenv.rst
On Mon, Jun 28, 2021 at 09:47:53PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
Dear Tom,
-- Tom
Hi Heinrich and Ilias,
We use SMBIOS/DMI entries to identify our boards. For some reason the device tree entries are not being passed to /sys/class/virtual/dmi/id. I'm using master as of this morning.
EFI stub: Booting Linux Kernel... EFI stub: Using DTB from configuration table ... [ 0.000000] Linux version 5.10.45 (dxue@build-server) (aarch64-buildroot-linux-musl-gcc.br_real (Buildroot 2019.08-10705-g7cb51d4843-dirty) 10.3.0, GNU ld (GNU Binutils) 2.36.1) #21 [ 0.000000] Machine model: Libre Computer AML-S805X-AC ... [ 0.000000] efi: ESRT=0x3aeea040 RTPROP=0x3aee8040 SMBIOS=0x3aee4000 RNG=0x394ee040 MEMRESERVE=0x394ed040
/sys/firmware/devicetree/base/smbios/smbios # grep -r . * baseboard/manufacturer:libre-computer baseboard/product:aml-s805x-ac baseboard/name:baseboard chassis/manufacturer:libre-computer chassis/product:aml-s805x-ac chassis/name:chassis name:smbios system/manufacturer:libre-computer system/product:aml-s805x-ac system/name:system /sys/firmware/devicetree/base/smbios/smbios # cd /sys/devices/virtual/dmi/id /sys/devices/virtual/dmi/id # grep -r . * bios_date:07/03/2021 bios_release:21.7 bios_vendor:U-Boot bios_version:2021.07-rc5+ board_name:Unknown Product board_vendor:Unknown chassis_type:3 chassis_vendor:Unknown modalias:dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr: power/runtime_active_time:0 power/runtime_status:unsupported power/runtime_suspended_time:0 power/control:auto product_name:Unknown Product sys_vendor:Unknown uevent:MODALIAS=dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr:
diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi index 39270ea71c..02177c64a6 100644 --- a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi +++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi @@ -5,3 +5,26 @@ */
#include "meson-gxl-u-boot.dtsi" + +/ { + smbios { + compatible = "u-boot,sysinfo-smbios"; + + smbios { + system { + manufacturer = "libre-computer"; + product = "aml-s805x-ac"; + }; + + baseboard { + manufacturer = "libre-computer"; + product = "aml-s805x-ac"; + }; + + chassis { + manufacturer = "libre-computer"; + }; + }; + }; +};
Any ideas?
Best, Da
Am 3. Juli 2021 14:46:39 MESZ schrieb Da Xue da@libre.computer:
Dear Tom,
caused
more
13:33:47
-0400)
-- Tom
This matces the device tree segment below.
All that is marked unknown is not in your device-tree below.
What are you expecting here? Was it here before the pull request?
Best regards
Heinrich
smbios {
smbios {
system {
baseboard {
chassis {
Any ideas?
Best, Da
Dear Tom,
caused
more
13:33:47
-0400)
-- Tom
Best regards
Heinrich
smbios {
smbios {
system {
baseboard {
chassis {
Any ideas?
Best, Da
There's two issues:
1) I just saw this patch: "x86: Provide default SMBIOS manufacturer/product". Should we add the same thing for ARM or maybe generically across the board?
2) The DMI entries previously took CONFIG_SYS_VENDOR and CONFIG_SYS_BOARD entries as manufacturer and product respectively. Now those entries become Unknown and Unknown Product.
Best,
Da
On 7/3/21 5:25 PM, Da Xue wrote:
On Sat, Jul 3, 2021 at 9:36 AM Heinrich Schuchardt <xypron.glpk@gmx.de mailto:xypron.glpk@gmx.de> wrote:
Am 3. Juli 2021 14:46:39 MESZ schrieb Da Xue <da@libre.computer>: >On Wed, Jun 30, 2021 at 8:06 AM Tom Rini <trini@konsulko.com <mailto:trini@konsulko.com>> wrote: > >> On Mon, Jun 28, 2021 at 09:47:53PM +0200, Heinrich Schuchardt wrote: >> >> > Dear Tom, >> > >> > I have removed the one patch for better EFI/DM integration that >caused >> > sandbox test problems on my last pull request. This topic needs >more >> > coordination with Simon. >> > >> > Gitlab CI showed no problems: >> > >https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/7968 <https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/7968> >> > >> > The following changes since commit >> 4d8c21da4170e7c1d38c0106898e0d8347b4f0ff: >> > >> > Merge tag 'u-boot-imx-20210625' of >> > https://gitlab.denx.de/u-boot/custodians/u-boot-imx <https://gitlab.denx.de/u-boot/custodians/u-boot-imx> (2021-06-25 >13:33:47 >> > -0400) >> > >> > are available in the Git repository at: >> > >> > https://source.denx.de/u-boot/custodians/u-boot-efi.git <https://source.denx.de/u-boot/custodians/u-boot-efi.git> >> > tags/efi-2021-07-rc5-2 >> > >> > for you to fetch changes up to >70e80666f26a516096f3787e884d42818d8b4087: >> > >> > smbios: Fix SMBIOS tables (2021-06-28 19:57:13 +0200) >> > >> >> Applied to u-boot/master, thanks! >> >> -- >> Tom >> > >Hi Heinrich and Ilias, > >We use SMBIOS/DMI entries to identify our boards. For some reason the >device tree entries are not being passed to /sys/class/virtual/dmi/id. >I'm >using master as of this morning. > >EFI stub: Booting Linux Kernel... >EFI stub: Using DTB from configuration table >... >[ 0.000000] Linux version 5.10.45 (dxue@build-server) >(aarch64-buildroot-linux-musl-gcc.br_real (Buildroot >2019.08-10705-g7cb51d4843-dirty) 10.3.0, GNU ld (GNU Binutils) 2.36.1) >#21 >[ 0.000000] Machine model: Libre Computer AML-S805X-AC >... >[ 0.000000] efi: ESRT=0x3aeea040 RTPROP=0x3aee8040 SMBIOS=0x3aee4000 >RNG=0x394ee040 MEMRESERVE=0x394ed040 > >/sys/firmware/devicetree/base/smbios/smbios # grep -r . * >baseboard/manufacturer:libre-computer >baseboard/product:aml-s805x-ac >baseboard/name:baseboard >chassis/manufacturer:libre-computer >chassis/product:aml-s805x-ac >chassis/name:chassis This matces the device tree segment below. >name:smbios >system/manufacturer:libre-computer >system/product:aml-s805x-ac >system/name:system >/sys/firmware/devicetree/base/smbios/smbios # cd >/sys/devices/virtual/dmi/id >/sys/devices/virtual/dmi/id # grep -r . * >bios_date:07/03/2021 >bios_release:21.7 >bios_vendor:U-Boot >bios_version:2021.07-rc5+ >board_name:Unknown Product >board_vendor:Unknown >chassis_type:3 >chassis_vendor:Unknown All that is marked unknown is not in your device-tree below. What are you expecting here? Was it here before the pull request? Best regards Heinrich >modalias:dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr: >power/runtime_active_time:0 >power/runtime_status:unsupported >power/runtime_suspended_time:0 >power/control:auto >product_name:Unknown Product >sys_vendor:Unknown >uevent:MODALIAS=dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr: > >diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >index 39270ea71c..02177c64a6 100644 >--- a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >+++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >@@ -5,3 +5,26 @@ > */ > > #include "meson-gxl-u-boot.dtsi" >+ >+/ { >+ smbios { >+ compatible = "u-boot,sysinfo-smbios"; >+ >+ smbios { >+ system { >+ manufacturer = "libre-computer"; >+ product = "aml-s805x-ac"; >+ }; >+ >+ baseboard { >+ manufacturer = "libre-computer"; >+ product = "aml-s805x-ac"; >+ }; >+ >+ chassis { >+ manufacturer = "libre-computer"; >+ }; >+ }; >+ }; >+}; > >Any ideas? > >Best, >Da
There's two issues:
- I just saw this patch: "x86: Provide default SMBIOS
- The DMI entries previously took CONFIG_SYS_VENDOR and
Having file smbios.dtsi in an x86 specific path (arch/x86/dts/) does not make much sense. There is nothing architecture specific in it.
Maybe where Ilias now has filled the missing properties with 'Unknown' he should have opted for CONFIG_SYS* instead if available. This would make smbios.dtsi superfluous.
Best regards
Heinrich
>EFI stub: Using DTB from configuration table >... >[?? ?? 0.000000] Linux version 5.10.45 (dxue@build-server) >(aarch64-buildroot-linux-musl-gcc.br_real (Buildroot >2019.08-10705-g7cb51d4843-dirty) 10.3.0, GNU ld (GNU Binutils) 2.36.1) >#21 >[?? ?? 0.000000] Machine model: Libre Computer AML-S805X-AC >... >[?? ?? 0.000000] efi: ESRT=0x3aeea040 RTPROP=0x3aee8040 SMBIOS=0x3aee4000 >RNG=0x394ee040 MEMRESERVE=0x394ed040 > >/sys/firmware/devicetree/base/smbios/smbios # grep -r . * >baseboard/manufacturer:libre-computer >baseboard/product:aml-s805x-ac >baseboard/name:baseboard >chassis/manufacturer:libre-computer >chassis/product:aml-s805x-ac >chassis/name:chassis This matces the device tree segment below. >name:smbios >system/manufacturer:libre-computer >system/product:aml-s805x-ac >system/name:system >/sys/firmware/devicetree/base/smbios/smbios # cd >/sys/devices/virtual/dmi/id >/sys/devices/virtual/dmi/id # grep -r . * >bios_date:07/03/2021 >bios_release:21.7 >bios_vendor:U-Boot >bios_version:2021.07-rc5+ >board_name:Unknown Product >board_vendor:Unknown >chassis_type:3 >chassis_vendor:Unknown All that is marked unknown is not in your device-tree below. What are you expecting here? Was it here before the pull request? Best regards Heinrich >modalias:dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr: >power/runtime_active_time:0 >power/runtime_status:unsupported >power/runtime_suspended_time:0 >power/control:auto >product_name:Unknown Product >sys_vendor:Unknown >uevent:MODALIAS=dmi:bvnU-Boot:bvr2021.07-rc5+:bd07/03/2021:br21.7:svnUnknown:pnUnknownProduct:pvr:rvnUnknown:rnUnknownProduct:rvr:cvnUnknown:ct3:cvr: > >diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >index 39270ea71c..02177c64a6 100644 >--- a/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >+++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac-u-boot.dtsi >@@ -5,3 +5,26 @@ >?? */ > > #include "meson-gxl-u-boot.dtsi" >+ >+/ { >+?? ?? ?? ??smbios { >+?? ?? ?? ?? ?? ?? ?? ??compatible = "u-boot,sysinfo-smbios"; >+ >+?? ?? ?? ?? ?? ?? ?? ??smbios { >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??system { >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??manufacturer = "libre-computer"; >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??product = "aml-s805x-ac"; >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??}; >+ >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??baseboard { >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??manufacturer = "libre-computer"; >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??product = "aml-s805x-ac"; >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??}; >+ >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??chassis { >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??manufacturer = "libre-computer"; >+?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ??}; >+?? ?? ?? ?? ?? ?? ?? ??}; >+?? ?? ?? ??}; >+}; > >Any ideas? > >Best, >Da
There's two issues:
Which version was that? My patch changed nothing in that regard. The only thing my patch did was fix e4f8e543f1a9 which removed some Kconfig options. Removing those made the strings "" which is against the spec. Heinrich fixed a similar issue with 00a871d34e2f back when we had CONFIG_SMBIOS_MANUFACTURER and CONFIG_SMBIOS_PRODUCT_NAME. Any chance that was your working version and those values were used?
We discussed this with Simon and I'll send a follow up patch. The idea is to try and use CONFIG_SYS* and if those are not available, pop a warning and use Unknown
Cheers /Ilias
Best regards
Heinrich
There's two issues:
commit 44ffb6f0ecaf ("smbios: Allow properties to come from the device tree") still used CONFIG symbols.
commit e4f8e543f1a9 ("smbios: Drop the unused Kconfig options") dropped the CONFIG symbols
Best regards
Heinrich
Cheers /Ilias
Best regards
Heinrich
Exactly, that was the point I tried to make. I think whatever Da was seing on his entires as 'correct' was prior to e4f8e543f1a9.
Cheers /Ilias
Best regards
Heinrich
Cheers /Ilias
Best regards
Heinrich
Da Xue
Ilias Apalodimas
