[PATCH 1/3] arm: mmc: Add "ti, am335-sdhci" compatible for TI's omap_hsmmc driver
In the Linux kernel (v5.16) for this SoC there are two separate drivers - namely sdhci-omap.c and omap_hsmmc.c which have separate set of compatibles.
The U-Boot's drivers/mmc/omap_hsmmc.c driver supports both eMMC and SD devices - hence the compatible for SDHCI can be added.
After this change the am335x DTS description can be easier ported from Linux kernel.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/mmc/omap_hsmmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 820065800f..b2f4a4e721 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -2019,6 +2019,7 @@ static const struct udevice_id omap_hsmmc_ids[] = { { .compatible = "ti,omap3-hsmmc" }, { .compatible = "ti,omap4-hsmmc" }, { .compatible = "ti,am33xx-hsmmc" }, + { .compatible = "ti,am335-sdhci" }, { .compatible = "ti,dra7-hsmmc", .data = (ulong)&dra7_mmc_of_data }, { } };
This change provides similar aliases definitions as now present in Linux kernel v5.16.9 for am33xx.dtsi file.
arch/arm/dts/am33xx.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi index b5093020ee..5f9b306ddb 100644 --- a/arch/arm/dts/am33xx.dtsi +++ b/arch/arm/dts/am33xx.dtsi @@ -40,6 +40,8 @@ ethernet1 = &cpsw_emac1; spi0 = &spi0; spi1 = &spi1; + mmc0 = &mmc1; + mmc1 = &mmc2; };
cpus {
This code has been ported from Linux v5.16.9 arch/arm/boot/dts/am33xx.dtsi file to allow correct usage of MMC2 controller in U-Boot.
This IP block is a bit specific as it is connected to L3 interconnect bus, whereas mmc[01] are connected to L4.
Proper configuration of this block (including providing clock) is handled in ti-sysc.c driver.
arch/arm/dts/am33xx.dtsi | 39 ++++++++++++++++++++++++++++++--------- 1 file changed, 30 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi index 5f9b306ddb..5871344edb 100644 --- a/arch/arm/dts/am33xx.dtsi +++ b/arch/arm/dts/am33xx.dtsi @@ -42,6 +42,7 @@ spi1 = &spi1; mmc0 = &mmc1; mmc1 = &mmc2; + mmc2 = &mmc3; };
cpus { @@ -303,6 +304,35 @@ }; };
+ target-module@47810000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x478102fc 0x4>, + <0x47810110 0x4>, + <0x47810114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + clocks = <&l3s_clkctrl AM3_L3S_MMC3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x47810000 0x1000>; + + mmc3: mmc@0 { + compatible = "ti,am335-sdhci"; + ti,needs-special-reset; + interrupts = <29>; + reg = <0x0 0x1000>; + status = "disabled"; + }; + }; + i2c0: i2c@44e0b000 { compatible = "ti,omap4-i2c"; #address-cells = <1>; @@ -359,15 +389,6 @@ status = "disabled"; };
- mmc3: mmc@47810000 { - compatible = "ti,omap4-hsmmc"; - ti,hwmods = "mmc3"; - ti,needs-special-reset; - interrupts = <29>; - reg = <0x47810000 0x1000>; - status = "disabled"; - }; - wdt2: wdt@44e35000 { compatible = "ti,omap3-wdt"; ti,hwmods = "wd_timer2";
compatibles.
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- { .compatible = "ti,am335-sdhci" }, { .compatible = "ti,dra7-hsmmc", .data = (ulong)&dra7_mmc_of_data }, { }
Hi Tom,
compatibles.
Gentle ping on this patch series.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
compatibles.
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Jaehoon Chung
Lukasz Majewski
