[U-Boot] [PATCH 5/8] Add TI816X cpu definitions
--- arch/arm/include/asm/arch-am33xx/cpu.h | 4 + arch/arm/include/asm/arch-am33xx/cpu_ti816x.h | 269 +++++++++++++++++++++++++ arch/arm/include/asm/emif.h | 4 + 3 files changed, 277 insertions(+) create mode 100644 arch/arm/include/asm/arch-am33xx/cpu_ti816x.h
diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 13c0667..34b3aa9 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -25,6 +25,10 @@
#include <asm/arch/hardware.h>
+#if defined(CONFIG_TI816X) +#include <asm/arch/cpu_ti816x.h> +#endif + #define BIT(x) (1 << x) #define CL_BIT(x) (0 << x)
diff --git a/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h new file mode 100644 index 0000000..b4a13a8 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h @@ -0,0 +1,269 @@ +/* + * cpu_ti816x.h + * + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> + * Antoine Tenart, atenart@adeneo-embedded.com + * + * Based on TI-PSP-04.00.02.14 : + * + * (C) Copyright 2006 + * Texas Instruments, <www.ti.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _TI816X_CPU_H +#define _TI816X_CPU_H + +#include <asm/arch/hardware.h> + +/* Timer registers */ +#define TIMER_TCLR 0x38 /* Timer control register */ +#define TIMER_TCRR 0x3C /* Timer counter register */ +#define TIMER_TLDR 0x40 /* Timer load value register*/ + +/* Control */ +#define CONTROL_STATUS (CTRL_BASE + 0x40) + +/* device type */ +#define DEVICE_MASK (BIT(8) | BIT(9) | BIT(10)) +#define TST_DEVICE 0x0 +#define EMU_DEVICE 0x1 +#define HS_DEVICE 0x2 +#define GP_DEVICE 0x3 + +/* This gives the buswidth of the booting device */ +#define SYSBOOT_BW_POS (16) +#define SYSBOOT_BW_MASK (BIT(SYSBOOT_BW_POS)) + +/* Reset control */ +#define PRM_DEVICE_RSTCTRL (PRCM_BASE + 0x00A0) + +/* TI816X specific bits for PRM_DEVICE module */ +#define GLOBAL_RST_COLD BIT(1) + +/* PLL related registers */ +#define MAINPLL_CTRL (CTRL_BASE + 0x0400) +#define MAINPLL_PWD (CTRL_BASE + 0x0404) +#define MAINPLL_FREQ1 (CTRL_BASE + 0x0408) +#define MAINPLL_DIV1 (CTRL_BASE + 0x040C) +#define MAINPLL_FREQ2 (CTRL_BASE + 0x0410) +#define MAINPLL_DIV2 (CTRL_BASE + 0x0414) +#define MAINPLL_FREQ3 (CTRL_BASE + 0x0418) +#define MAINPLL_DIV3 (CTRL_BASE + 0x041C) +#define MAINPLL_FREQ4 (CTRL_BASE + 0x0420) +#define MAINPLL_DIV4 (CTRL_BASE + 0x0424) +#define MAINPLL_FREQ5 (CTRL_BASE + 0x0428) +#define MAINPLL_DIV5 (CTRL_BASE + 0x042C) +#define MAINPLL_DIV6 (CTRL_BASE + 0x0434) +#define MAINPLL_DIV7 (CTRL_BASE + 0x043C) + +#define DDRPLL_CTRL (CTRL_BASE + 0x0440) +#define DDRPLL_PWD (CTRL_BASE + 0x0444) +#define DDRPLL_DIV1 (CTRL_BASE + 0x044C) +#define DDRPLL_FREQ2 (CTRL_BASE + 0x0450) +#define DDRPLL_DIV2 (CTRL_BASE + 0x0454) +#define DDRPLL_FREQ3 (CTRL_BASE + 0x0458) +#define DDRPLL_DIV3 (CTRL_BASE + 0x045C) +#define DDRPLL_FREQ4 (CTRL_BASE + 0x0460) +#define DDRPLL_DIV4 (CTRL_BASE + 0x0464) +#define DDRPLL_FREQ5 (CTRL_BASE + 0x0468) +#define DDRPLL_DIV5 (CTRL_BASE + 0x046C) + +#define DDR_RCD (CTRL_BASE + 0x070C) + +#define VIDEOPLL_CTRL (CTRL_BASE + 0x0470) +#define VIDEOPLL_PWD (CTRL_BASE + 0x0474) +#define VIDEOPLL_FREQ1 (CTRL_BASE + 0x0478) +#define VIDEOPLL_DIV1 (CTRL_BASE + 0x047C) +#define VIDEOPLL_FREQ2 (CTRL_BASE + 0x0480) +#define VIDEOPLL_DIV2 (CTRL_BASE + 0x0484) +#define VIDEOPLL_FREQ3 (CTRL_BASE + 0x0488) +#define VIDEOPLL_DIV3 (CTRL_BASE + 0x048C) + +#define AUDIOPLL_CTRL (CTRL_BASE + 0x04A0) +#define AUDIOPLL_PWD (CTRL_BASE + 0x04A4) +#define AUDIOPLL_FREQ2 (CTRL_BASE + 0x04B0) +#define AUDIOPLL_DIV2 (CTRL_BASE + 0x04B4) +#define AUDIOPLL_FREQ3 (CTRL_BASE + 0x04B8) +#define AUDIOPLL_DIV3 (CTRL_BASE + 0x04BC) +#define AUDIOPLL_FREQ4 (CTRL_BASE + 0x04C0) +#define AUDIOPLL_DIV4 (CTRL_BASE + 0x04C4) +#define AUDIOPLL_FREQ5 (CTRL_BASE + 0x04C8) +#define AUDIOPLL_DIV5 (CTRL_BASE + 0x04CC) + +/* PRCM */ +#define CM_DPLL_OFFSET (PRCM_BASE + 0x0300) + +#ifdef CONFIG_TI816X +#define CM_TIMER1_CLKSEL (CM_DPLL_OFFSET + 0x90) + +/* Timers */ +#define CM_ALWON_TIMER_0_CLKCTRL (PRCM_BASE + 0x156C) +#define CM_ALWON_TIMER_1_CLKCTRL (PRCM_BASE + 0x1570) +#define CM_ALWON_TIMER_2_CLKCTRL (PRCM_BASE + 0x1574) +#define CM_ALWON_TIMER_3_CLKCTRL (PRCM_BASE + 0x1578) +#define CM_ALWON_TIMER_4_CLKCTRL (PRCM_BASE + 0x157C) +#define CM_ALWON_TIMER_5_CLKCTRL (PRCM_BASE + 0x1580) +#define CM_ALWON_TIMER_6_CLKCTRL (PRCM_BASE + 0x1584) +#define CM_ALWON_TIMER_7_CLKCTRL (PRCM_BASE + 0x1588) +#endif + +#define CM_ALWON_WDTIMER_CLKCTRL (PRCM_BASE + 0x158C) +#define CM_ALWON_SPI_CLKCTRL (PRCM_BASE + 0x1590) +#define CM_ALWON_CONTROL_CLKCTRL (PRCM_BASE + 0x15C4) + +#define CM_ALWON_L3_SLOW_CLKSTCTRL (PRCM_BASE + 0x1400) + +#ifdef CONFIG_TI816X +#define CM_ALWON_CUST_EFUSE_CLKCTRL (PRCM_BASE + 0x1628) +#endif + +#define CM_ALWON_GPIO_0_CLKCTRL (PRCM_BASE + 0x155c) +#define CM_ALWON_GPIO_0_OPTFCLKEN_DBCLK (PRCM_BASE + 0x155c) + +#define CM_ALWON_GPIO_1_CLKCTRL (PRCM_BASE + 0x1560) +/* Ethernet */ +#define CM_ETHERNET_CLKSTCTRL (PRCM_BASE + 0x1404) +#define CM_ALWON_ETHERNET_0_CLKCTRL (PRCM_BASE + 0x15D4) +#define CM_ALWON_ETHERNET_1_CLKCTRL (PRCM_BASE + 0x15D8) + +/* UARTs */ +#define CM_ALWON_UART_0_CLKCTRL (PRCM_BASE + 0x1550) +#define CM_ALWON_UART_1_CLKCTRL (PRCM_BASE + 0x1554) +#define CM_ALWON_UART_2_CLKCTRL (PRCM_BASE + 0x1558) + +/* I2C */ +/* Note: In ti814x I2C0 and I2C2 have common clk control */ +#define CM_ALWON_I2C_0_CLKCTRL (PRCM_BASE + 0x1564) + +/* HSMMC */ +#ifdef CONFIG_TI816X +#define CM_ALWON_HSMMC_CLKCTRL (PRCM_BASE + 0x15B0) +#endif + +/* UART registers */ +#define UART_SYSCFG (DEFAULT_UART_BASE + 0x54) +#define UART_SYSSTS (DEFAULT_UART_BASE + 0x58) +#define UART_LCR (DEFAULT_UART_BASE + 0x0C) +#define UART_EFR (DEFAULT_UART_BASE + 0x08) +#define UART_MCR (DEFAULT_UART_BASE + 0x10) +#define UART_SCR (DEFAULT_UART_BASE + 0x40) +#define UART_TCR (DEFAULT_UART_BASE + 0x18) +#define UART_FCR (DEFAULT_UART_BASE + 0x08) +#define UART_DLL (DEFAULT_UART_BASE + 0x00) +#define UART_DLH (DEFAULT_UART_BASE + 0x04) +#define UART_MDR (DEFAULT_UART_BASE + 0x20) + +/*DMM & EMIF4 MMR Declaration*/ +#define DMM_LISA_MAP__0 (DMM_BASE + 0x40) +#define DMM_LISA_MAP__1 (DMM_BASE + 0x44) +#define DMM_LISA_MAP__2 (DMM_BASE + 0x48) +#define DMM_LISA_MAP__3 (DMM_BASE + 0x4C) +#define DMM_PAT_BASE_ADDR (DMM_BASE + 0x460) + +#define EMIF4_0_SDRAM_ZQCR (EMIF4_0_CFG_BASE + 0xC8) +#define EMIF4_0_SDRAM_CONFIG (EMIF4_0_CFG_BASE + 0x08) +#define EMIF4_0_SDRAM_CONFIG2 (EMIF4_0_CFG_BASE + 0x0C) +#define EMIF4_0_SDRAM_REF_CTRL (EMIF4_0_CFG_BASE + 0x10) +#define EMIF4_0_SDRAM_REF_CTRL_SHADOW (EMIF4_0_CFG_BASE + 0x14) +#define EMIF4_0_SDRAM_TIM_1 (EMIF4_0_CFG_BASE + 0x18) +#define EMIF4_0_SDRAM_TIM_1_SHADOW (EMIF4_0_CFG_BASE + 0x1C) +#define EMIF4_0_SDRAM_TIM_2 (EMIF4_0_CFG_BASE + 0x20) +#define EMIF4_0_SDRAM_TIM_2_SHADOW (EMIF4_0_CFG_BASE + 0x24) +#define EMIF4_0_SDRAM_TIM_3 (EMIF4_0_CFG_BASE + 0x28) +#define EMIF4_0_SDRAM_TIM_3_SHADOW (EMIF4_0_CFG_BASE + 0x2C) +#define EMIF4_0_DDR_PHY_CTRL_1 (EMIF4_0_CFG_BASE + 0xE4) +#define EMIF4_0_DDR_PHY_CTRL_1_SHADOW (EMIF4_0_CFG_BASE + 0xE8) +#define EMIF4_0_IODFT_TLGC (EMIF4_0_CFG_BASE + 0x60) + +#define EMIF4_1_SDRAM_ZQCR (EMIF4_1_CFG_BASE + 0xC8) +#define EMIF4_1_SDRAM_CONFIG (EMIF4_1_CFG_BASE + 0x08) +#define EMIF4_1_SDRAM_CONFIG2 (EMIF4_1_CFG_BASE + 0x0C) +#define EMIF4_1_SDRAM_REF_CTRL (EMIF4_1_CFG_BASE + 0x10) +#define EMIF4_1_SDRAM_REF_CTRL_SHADOW (EMIF4_1_CFG_BASE + 0x14) +#define EMIF4_1_SDRAM_TIM_1 (EMIF4_1_CFG_BASE + 0x18) +#define EMIF4_1_SDRAM_TIM_1_SHADOW (EMIF4_1_CFG_BASE + 0x1C) +#define EMIF4_1_SDRAM_TIM_2 (EMIF4_1_CFG_BASE + 0x20) +#define EMIF4_1_SDRAM_TIM_2_SHADOW (EMIF4_1_CFG_BASE + 0x24) +#define EMIF4_1_SDRAM_TIM_3 (EMIF4_1_CFG_BASE + 0x28) +#define EMIF4_1_SDRAM_TIM_3_SHADOW (EMIF4_1_CFG_BASE + 0x2C) +#define EMIF4_1_DDR_PHY_CTRL_1 (EMIF4_1_CFG_BASE + 0xE4) +#define EMIF4_1_DDR_PHY_CTRL_1_SHADOW (EMIF4_1_CFG_BASE + 0xE8) +#define EMIF4_1_IODFT_TLGC (EMIF4_1_CFG_BASE + 0x60) + +/*EMIF4 PRCM Defintion*/ +#define CM_DEFAULT_L3_FAST_CLKSTCTRL (PRCM_BASE + 0x0508) +#define CM_DEFAULT_EMIF_0_CLKCTRL (PRCM_BASE + 0x0520) +#define CM_DEFAULT_EMIF_1_CLKCTRL (PRCM_BASE + 0x0524) +#define CM_DEFAULT_DMM_CLKCTRL (PRCM_BASE + 0x0528) +#define CM_DEFAULT_FW_CLKCTRL (PRCM_BASE + 0x052C) + +/* Smartreflex Registers */ +#define TI816X_SMRT_SCALE_ADDR (CTRL_BASE + 0x06A0) +#define TI816X_SMRT_OPP_SVT_ADDR (CTRL_BASE + 0x06A8) +#define TI816X_SMRT_OPP_HVT_ADDR (CTRL_BASE + 0x06AC) + + +/* ALWON PRCM */ +#define CM_ALWON_OCMC_0_CLKSTCTRL (PRCM_BASE + 0x1414) +#define CM_ALWON_OCMC_0_CLKCTRL (PRCM_BASE + 0x15B4) +#define CM_ALWON_OCMC_1_CLKSTCTRL (PRCM_BASE + 0x1418) +#define CM_ALWON_OCMC_1_CLKCTRL (PRCM_BASE + 0x15B8) + +#define CM_ALWON_GPMC_CLKCTRL (PRCM_BASE + 0x15D0) + +/* OCMC */ +#define SRAM0_SIZE (0x40000) +#define SRAM_GPMC_STACK_SIZE (0x40) + +/* GPMC related */ +#define GPMC_CONFIG_CS0 (0x60) +#define GPMC_CONFIG_CS0_BAS (GPMC_BASE + GPMC_CONFIG_CS0) +#define GPMC_CONFIG1 (0x00) +#define GPMC_CONFIG2 (0x04) +#define GPMC_CONFIG3 (0x08) +#define GPMC_CONFIG4 (0x0C) +#define GPMC_CONFIG5 (0x10) +#define GPMC_CONFIG6 (0x14) +#define GPMC_CONFIG7 (0x18) + +/* WDT related */ +#define WDT_WDSC (WDT_BASE + 0x010) +#define WDT_WDST (WDT_BASE + 0x014) +#define WDT_WISR (WDT_BASE + 0x018) +#define WDT_WIER (WDT_BASE + 0x01C) +#define WDT_WWER (WDT_BASE + 0x020) +#define WDT_WCLR (WDT_BASE + 0x024) +#define WDT_WCRR (WDT_BASE + 0x028) +#define WDT_WLDR (WDT_BASE + 0x02C) +#define WDT_WTGR (WDT_BASE + 0x030) +#define WDT_WWPS (WDT_BASE + 0x034) +#define WDT_WDLY (WDT_BASE + 0x044) +#define WDT_WSPR (WDT_BASE + 0x048) +#define WDT_WIRQEOI (WDT_BASE + 0x050) +#define WDT_WIRQSTATRAW (WDT_BASE + 0x054) +#define WDT_WIRQSTAT (WDT_BASE + 0x058) +#define WDT_WIRQENSET (WDT_BASE + 0x05C) +#define WDT_WIRQENCLR (WDT_BASE + 0x060) + +#define WDT_UNFREEZE (CTRL_BASE + 0x100) + +#endif /* _TI816X_CPU_H */ diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index ed251ec..a7b938c 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -521,7 +521,11 @@ #define SDRAM_CONFIG_EXT_RD_LVL_4_SAMPLES 0x000001A7
/* DMM */ +#if defined(CONFIG_TI816X) +#define DMM_BASE 0x4E000000 +#else #define DMM_BASE 0x4E000040 +#endif
/* Memory Adapter */ #define MA_BASE 0x482AF040
"TENART" == TENART Antoine atenart@adeneo-embedded.com writes:
TENART> --- TENART> arch/arm/include/asm/arch-am33xx/cpu.h | 4 + TENART> arch/arm/include/asm/arch-am33xx/cpu_ti816x.h | 269 +++++++++++++++++++++++++ TENART> arch/arm/include/asm/emif.h | 4 + TENART> 3 files changed, 277 insertions(+) TENART> create mode 100644 arch/arm/include/asm/arch-am33xx/cpu_ti816x.h
TENART> diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h TENART> index 13c0667..34b3aa9 100644 TENART> --- a/arch/arm/include/asm/arch-am33xx/cpu.h TENART> +++ b/arch/arm/include/asm/arch-am33xx/cpu.h TENART> @@ -25,6 +25,10 @@
TENART> #include <asm/arch/hardware.h>
TENART> +#if defined(CONFIG_TI816X) TENART> +#include <asm/arch/cpu_ti816x.h> TENART> +#endif TENART> + TENART> #define BIT(x) (1 << x) TENART> #define CL_BIT(x) (0 << x)
TENART> diff --git a/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h TENART> new file mode 100644 TENART> index 0000000..b4a13a8 TENART> --- /dev/null TENART> +++ b/arch/arm/include/asm/arch-am33xx/cpu_ti816x.h TENART> @@ -0,0 +1,269 @@ TENART> +/* TENART> + * cpu_ti816x.h TENART> + * TENART> + * Copyright (C) 2013, Adeneo Embedded <www.adeneo-embedded.com> TENART> + * Antoine Tenart, atenart@adeneo-embedded.com TENART> + * TENART> + * Based on TI-PSP-04.00.02.14 : TENART> + * TENART> + * (C) Copyright 2006 TENART> + * Texas Instruments, <www.ti.com> TENART> + * TENART> + * See file CREDITS for list of people who contributed to this TENART> + * project. TENART> + * TENART> + * This program is free software; you can redistribute it and/or TENART> + * modify it under the terms of the GNU General Public License as TENART> + * published by the Free Software Foundation; either version 2 of TENART> + * the License, or (at your option) any later version. TENART> + * TENART> + * This program is distributed in the hope that it will be useful, TENART> + * but WITHOUT ANY WARRANTY; without even the implied warranty of TENART> + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the TENART> + * GNU General Public License for more details. TENART> + * TENART> + * You should have received a copy of the GNU General Public License TENART> + * along with this program; if not, write to the Free Software TENART> + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, TENART> + * MA 02111-1307 USA TENART> + * TENART> + */ TENART> + TENART> +#ifndef _TI816X_CPU_H TENART> +#define _TI816X_CPU_H TENART> + TENART> +#include <asm/arch/hardware.h> TENART> + TENART> +/* Timer registers */ TENART> +#define TIMER_TCLR 0x38 /* Timer control register */ TENART> +#define TIMER_TCRR 0x3C /* Timer counter register */ TENART> +#define TIMER_TLDR 0x40 /* Timer load value register*/ TENART> +
Are these defines all needed? As far as I can see from skimming the series, they aren't referenced anywhere.
TENART> diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h TENART> index ed251ec..a7b938c 100644 TENART> --- a/arch/arm/include/asm/emif.h TENART> +++ b/arch/arm/include/asm/emif.h TENART> @@ -521,7 +521,11 @@ TENART> #define SDRAM_CONFIG_EXT_RD_LVL_4_SAMPLES 0x000001A7
TENART> /* DMM */ TENART> +#if defined(CONFIG_TI816X) TENART> +#define DMM_BASE 0x4E000000 TENART> +#else TENART> #define DMM_BASE 0x4E000040 TENART> +#endif
I don't think that's right. Matt's series uses DMM_BASE to refer to the lisa registers, which are offset 0x40 from the DMM region, so I think you can drop this.
You're right, this is because I didn't use config_dmm(). I'll fix that.
Peter Korsgaard
TENART Antoine
