[U-Boot] [PATCH] pico-imx7d: Remove specific code for fitImage
This implementation is a specific utilisation with CONFIG_FIT. This feature use script for boot. With distrobootcmd is possible to load script.
Signed-off-by: Joris Offouga offougajoris@gmail.com --- include/configs/pico-imx7d.h | 30 ------------------------------ 1 file changed, 30 deletions(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 5abf80a292..26eef59393 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -45,21 +45,6 @@ "/boot/imx7d-pico-pi.dtb ext4 0 1;" \ "rootfs part 0 1\0" \
-/* When booting with FIT specify the node entry containing boot.scr */ -#if defined(CONFIG_FIT) -#define PICO_BOOT_ENV \ - "bootscr_fitimage_name=bootscr\0" \ - "bootscriptaddr=0x83200000\0" \ - "fdtovaddr=0x83100000\0" \ - "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ - "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "rootwait rw;\0" \ - "loadbootscript=" \ - "load mmc ${mmcdev}:${mmcpart} ${bootscriptaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source ${bootscriptaddr}:${bootscr_fitimage_name}\0" -#else #define PICO_BOOT_ENV \ "bootmenu_0=Boot using PICO-Hobbit baseboard=" \ "setenv fdtfile imx7d-pico-hobbit.dtb\0" \ @@ -70,8 +55,6 @@ "bootmenu_3=Boot using PICO-Pi baseboard=" \ "setenv fdtfile imx7d-pico-pi.dtb\0" \ BOOTENV -#endif -
#define CONFIG_SYS_MMC_IMG_LOAD_PART 1
@@ -105,19 +88,6 @@ "setup_emmc=mmc dev 0; gpt write mmc 0 $partitions; reset;\0" \ PICO_BOOT_ENV
-#if defined(CONFIG_FIT) -#define CONFIG_BOOTCOMMAND \ - "mmc dev ${mmcdev};" \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "iminfo ${bootscriptaddr};" \ - "if test $? -eq 1; then hab_failsafe; fi;" \ - "run bootscript; " \ - "else " \ - "echo Fail to load fitImage with boot script;" \ - "hab_failsafe;" \ - "fi; " \ - "fi" #endif
#define BOOT_TARGET_DEVICES(func) \
Reviewed-by: Otavio Salvador otavio@ossystems.com.br
Joris Offouga
Otavio Salvador
