Re: [U-Boot] [PATCH 2/3] ventana: define CONFIG_MACH_VENTANA
On 03/01/2012 03:55 PM, Troy Kisky wrote:
On 3/1/2012 2:30 PM, Stephen Warren wrote:
On 03/01/2012 02:13 PM, Troy Kisky wrote:
ventana uses board/nvidia/seaboard/seaboard.c which uses machine_is_ventana. diff --git a/include/configs/ventana.h b/include/configs/ventana.h +#define CONFIG_MACH_VENTANA
It'd be nice not to have to do this; that header already does:
#define CONFIG_MACH_TYPE MACH_TYPE_VENTANA
Can't the code key off that? Otherwise, any use of machine_is_xxx() will be very error-prone, since CONFIG_MACH_XXX has to be manually defined, and people will forget.
Before patch 3/3 mach-types.h has
#ifdef CONFIG_MACH_VENTANA # ifdef machine_arch_type # undef machine_arch_type # define machine_arch_type __machine_arch_type # else # define machine_arch_type MACH_TYPE_VENTANA # endif # define machine_is_ventana() (machine_arch_type == MACH_TYPE_VENTANA) #else # define machine_is_ventana() (0) #endif
So, it wants CONFIG_MACH_VENTANA defined.
Yes, there's certainly a pre-existing bug that needs to be fixed.
My point is that every board already needs to set CONFIG_MACH_TYPE to the relevant type. It's quite unexpected that boards will /also/ need to set e.g. CONFIG_MACH_VENTANA on top of that if they need to call machine_is_xxx(). That is exactly why this bug exists for Ventana and needs to be fixed.
So, rather than forcing this unusual requirement on boards, isn't it possible to fix mach-types.h to use CONFIG_MACH_TYPE rather than CONFIG_MACH_${machine_name}? It's probably not too hard to run some kind of script over mach-types.h when importing it from the kernel, or instead of importing the generated mach-types.h, import the source data file and write a U-Boot-specific script that generates mach-types.h in a format more suitable for U-Boot.
Stephen Warren
