[U-Boot-Users] [Patch][CVS] Adjust CFG_CMD_ECHO as default ENV setting
Hi list,
Attached patch makes up a fix on CFG_CMD_ECHO. To avoid breaking exists boards, I adjust "echo" as a default command with aggreement of Wolfgang.
For the sake of it's effect on all boards, pls check this one more carefully. About 12 boards related was fixed as well. Fix policy is that if CONFIG_CMD_DFL is used, CFG_CMD_ECHO shouldn't be redefined. Did I fix too much or not enough? Ideas pls...
Sorry for the late. I just made my PC get CVS tree:-( CVS hasn't supported proxy. It brings me some troubles more or less.
Thanks for all your concern,
Sam
CHANGELOG: * Patch by Sam Song, 19 June 2005: - Adjust echo as a defalut command.
Sam
___________________________________________________________ 雅虎免费G邮箱-中国第一绝无垃圾邮件骚扰超大邮箱 http://cn.mail.yahoo.com/?id=77071
Index: README =================================================================== RCS file: /cvsroot/u-boot/u-boot/README,v retrieving revision 1.126 diff -p -u -r1.126 README --- README 3 May 2005 14:12:25 -0000 1.126 +++ README 19 Jun 2005 12:27:42 -0000 @@ -590,7 +590,7 @@ The following options need to be configu CFG_CMD_DIAG * Diagnostics CFG_CMD_DOC * Disk-On-Chip Support CFG_CMD_DTT * Digital Therm and Thermostat - CFG_CMD_ECHO * echo arguments + CFG_CMD_ECHO echo arguments CFG_CMD_EEPROM * EEPROM read/write support CFG_CMD_ELF * bootelf, bootvx CFG_CMD_ENV saveenv Index: common/command.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/command.c,v retrieving revision 1.18 diff -p -u -r1.18 command.c --- common/command.c 6 Apr 2005 00:04:17 -0000 1.18 +++ common/command.c 19 Jun 2005 12:27:51 -0000 @@ -42,6 +42,8 @@ U_BOOT_CMD( NULL );
+#if (CONFIG_COMMANDS & CFG_CMD_ECHO) + int do_echo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -74,6 +76,8 @@ U_BOOT_CMD( " - echo args to console; \c suppresses newline\n" );
+#endif /* CFG_CMD_ECHO */ + #ifdef CFG_HUSH_PARSER
int Index: include/cmd_confdefs.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/cmd_confdefs.h,v retrieving revision 1.22 diff -p -u -r1.22 cmd_confdefs.h --- include/cmd_confdefs.h 1 Apr 2005 00:25:45 -0000 1.22 +++ include/cmd_confdefs.h 19 Jun 2005 12:27:53 -0000 @@ -110,7 +110,6 @@ CFG_CMD_DIAG | \ CFG_CMD_DOC | \ CFG_CMD_DTT | \ - CFG_CMD_ECHO | \ CFG_CMD_EEPROM | \ CFG_CMD_ELF | \ CFG_CMD_EXT2 | \ Index: include/configs/ISPAN.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/ISPAN.h,v retrieving revision 1.2 diff -p -u -r1.2 ISPAN.h --- include/configs/ISPAN.h 31 Dec 2004 09:32:53 -0000 1.2 +++ include/configs/ISPAN.h 19 Jun 2005 12:27:55 -0000 @@ -108,7 +108,6 @@ #define CONFIG_COMMANDS ( CONFIG_CMD_DFL \ | CFG_CMD_ASKENV \ | CFG_CMD_DHCP \ - | CFG_CMD_ECHO \ | CFG_CMD_IMMAP \ | CFG_CMD_MII \ | CFG_CMD_PING \ Index: include/configs/MIP405.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/MIP405.h,v retrieving revision 1.10 diff -p -u -r1.10 MIP405.h --- include/configs/MIP405.h 23 Feb 2004 22:22:33 -0000 1.10 +++ include/configs/MIP405.h 19 Jun 2005 12:27:56 -0000 @@ -58,7 +58,6 @@ CFG_CMD_CACHE | \ CFG_CMD_DATE | \ CFG_CMD_DHCP | \ - CFG_CMD_ECHO | \ CFG_CMD_EEPROM | \ CFG_CMD_ELF | \ CFG_CMD_FAT | \ Index: include/configs/PIP405.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/PIP405.h,v retrieving revision 1.8 diff -p -u -r1.8 PIP405.h --- include/configs/PIP405.h 20 Jan 2004 23:12:34 -0000 1.8 +++ include/configs/PIP405.h 19 Jun 2005 12:27:57 -0000 @@ -50,7 +50,6 @@ CFG_CMD_PCI | \ CFG_CMD_CACHE | \ CFG_CMD_IRQ | \ - CFG_CMD_ECHO | \ CFG_CMD_EEPROM | \ CFG_CMD_I2C | \ CFG_CMD_REGINFO | \ Index: include/configs/RPXsuper.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/RPXsuper.h,v retrieving revision 1.3 diff -p -u -r1.3 RPXsuper.h --- include/configs/RPXsuper.h 20 Jan 2004 23:12:34 -0000 1.3 +++ include/configs/RPXsuper.h 19 Jun 2005 12:27:58 -0000 @@ -154,7 +154,6 @@ #define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ CFG_CMD_IMMAP | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_I2C | \ CFG_CMD_REGINFO & \ ~CFG_CMD_KGDB ) Index: include/configs/Rattler.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/Rattler.h,v retrieving revision 1.2 diff -p -u -r1.2 Rattler.h --- include/configs/Rattler.h 5 May 2005 09:13:21 -0000 1.2 +++ include/configs/Rattler.h 19 Jun 2005 12:27:59 -0000 @@ -125,7 +125,6 @@
#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_DHCP \ - | CFG_CMD_ECHO \ | CFG_CMD_IMMAP \ | CFG_CMD_JFFS2 \ | CFG_CMD_MII \ Index: include/configs/TQM5200.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/TQM5200.h,v retrieving revision 1.12 diff -p -u -r1.12 TQM5200.h --- include/configs/TQM5200.h 2 Apr 2005 22:37:55 -0000 1.12 +++ include/configs/TQM5200.h 19 Jun 2005 12:28:00 -0000 @@ -161,7 +161,6 @@ CFG_CMD_ASKENV | \ CFG_CMD_DATE | \ CFG_CMD_DHCP | \ - CFG_CMD_ECHO | \ CFG_CMD_EEPROM | \ CFG_CMD_I2C | \ CFG_CMD_MII | \ Index: include/configs/ZPC1900.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/ZPC1900.h,v retrieving revision 1.5 diff -p -u -r1.5 ZPC1900.h --- include/configs/ZPC1900.h 9 Oct 2004 23:33:43 -0000 1.5 +++ include/configs/ZPC1900.h 19 Jun 2005 12:28:01 -0000 @@ -112,7 +112,6 @@ #define CONFIG_COMMANDS (CONFIG_CMD_DFL \ | CFG_CMD_ASKENV \ | CFG_CMD_DHCP \ - | CFG_CMD_ECHO \ | CFG_CMD_IMMAP \ | CFG_CMD_MII \ | CFG_CMD_PING \ Index: include/configs/gw8260.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/gw8260.h,v retrieving revision 1.2 diff -p -u -r1.2 gw8260.h --- include/configs/gw8260.h 27 Jun 2003 21:32:46 -0000 1.2 +++ include/configs/gw8260.h 19 Jun 2005 12:28:02 -0000 @@ -305,7 +305,6 @@ CFG_CMD_BEDBUG | \ CFG_CMD_ELF | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_REGINFO | \ CFG_CMD_IMMAP | \ CFG_CMD_MII) Index: include/configs/ppmc8260.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/ppmc8260.h,v retrieving revision 1.4 diff -p -u -r1.4 ppmc8260.h --- include/configs/ppmc8260.h 25 Mar 2004 15:14:45 -0000 1.4 +++ include/configs/ppmc8260.h 19 Jun 2005 12:28:04 -0000 @@ -279,7 +279,6 @@ #define CONFIG_COMMANDS (((CONFIG_CMD_DFL & ~(CFG_CMD_KGDB))) | \ CFG_CMD_ELF | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_REGINFO | \ CFG_CMD_MEMTEST | \ CFG_CMD_MII | \ Index: include/configs/sacsng.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/sacsng.h,v retrieving revision 1.7 diff -p -u -r1.7 sacsng.h --- include/configs/sacsng.h 25 Mar 2004 15:14:45 -0000 1.7 +++ include/configs/sacsng.h 19 Jun 2005 12:28:07 -0000 @@ -507,7 +507,6 @@ # define CONFIG_COMMANDS (((CONFIG_CMD_DFL & ~(CFG_CMD_KGDB))) | \ CFG_CMD_ELF | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_I2C | \ CFG_CMD_SPI | \ CFG_CMD_SDRAM | \ @@ -520,7 +519,6 @@ # define CONFIG_COMMANDS (((CONFIG_CMD_DFL & ~(CFG_CMD_KGDB))) | \ CFG_CMD_ELF | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_I2C | \ CFG_CMD_SPI | \ CFG_CMD_SDRAM | \ Index: include/configs/sbc8260.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/sbc8260.h,v retrieving revision 1.11 diff -p -u -r1.11 sbc8260.h --- include/configs/sbc8260.h 11 Jul 2004 21:49:43 -0000 1.11 +++ include/configs/sbc8260.h 19 Jun 2005 12:28:09 -0000 @@ -448,7 +448,6 @@ #ifdef CONFIG_ETHER_ON_FCC # define CONFIG_COMMANDS (((CONFIG_CMD_DFL & ~(CFG_CMD_KGDB))) | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_ELF | \ CFG_CMD_I2C | \ CFG_CMD_IMMAP | \ @@ -459,7 +458,6 @@ #else # define CONFIG_COMMANDS (((CONFIG_CMD_DFL & ~(CFG_CMD_KGDB))) | \ CFG_CMD_ASKENV | \ - CFG_CMD_ECHO | \ CFG_CMD_ELF | \ CFG_CMD_I2C | \ CFG_CMD_IMMAP | \ Index: include/configs/utx8245.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/utx8245.h,v retrieving revision 1.3 diff -p -u -r1.3 utx8245.h --- include/configs/utx8245.h 5 Jun 2003 15:40:53 -0000 1.3 +++ include/configs/utx8245.h 19 Jun 2005 12:28:10 -0000 @@ -91,7 +91,6 @@ protect on $(u-boot_startaddr) $(u-boot_ | CFG_CMD_ENV | CFG_CMD_CONSOLE \ | CFG_CMD_LOADS | CFG_CMD_LOADB \ | CFG_CMD_IMI | CFG_CMD_CACHE \ - | CFG_CMD_RUN | CFG_CMD_ECHO \ | CFG_CMD_REGINFO | CFG_CMD_NET\ | CFG_CMD_DHCP | CFG_CMD_I2C \ | CFG_CMD_DATE)
In message 20050619143719.48123.qmail@web15902.mail.cnb.yahoo.com you wrote:
CHANGELOG:
- Patch by Sam Song, 19 June 2005:
Applied, thanks.
Sam Song
