[U-Boot] Pull request: u-boot-nds32
Hi Tom,
Please pull the following patch from u-boot-nds32 into your tree. Thanks!
The following changes since commit 62c175fbb8a0f9a926c88294ea9f7e88eb898f6c:
Prepare v2013.07 (2013-07-23 07:58:13 -0400)
git://git.denx.de/u-boot-nds32.git master
for you to fetch changes up to 4fc967051396e8e82138c65fd65a353f73e51b89:
nds32: ag101/ag102: Fix setting lastdec and now values (2013-07-24 11:50:28 +0800)
---------------------------------------------------------------- Axel Lin (1): nds32: ag101/ag102: Fix setting lastdec and now values
Gabor Juhos (6): nds32: introduce macros for bit manipulation mmc: ftsdc010_mci: fix build error if CONFIG_FTSDC010_SDIO is not defined block: constify sect_buf argument of ide_write_data pci: add prototype for pci_ftpci_init() function pci: move pci_ftpci100.h to include/faraday/ftpci100.h nds32: adp-ag102: use 'faraday/ftpci100.h' for pci_ftpci_init
ken kuo (3): nds32: Enable two banks of SDRAM on Andes board nds32: Enable SDIO and EXT2 command support for Andes board nds32: Enable the function of passing parameters to Linux
arch/nds32/cpu/n1213/ag101/lowlevel_init.S | 6 +++++- arch/nds32/cpu/n1213/ag101/timer.c | 7 ++++--- arch/nds32/cpu/n1213/ag102/timer.c | 7 ++++--- arch/nds32/include/asm/io.h | 37 +++++++++++++++++++++++++++++++++ arch/nds32/include/asm/setup.h | 192 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/AndesTech/adp-ag101/adp-ag101.c | 10 ++++++++- board/AndesTech/adp-ag101p/adp-ag101p.c | 10 ++++++++- board/AndesTech/adp-ag102/adp-ag102.c | 3 +-- doc/driver-model/UDM-block.txt | 2 +- drivers/block/ftide020.c | 2 +- drivers/mmc/ftsdc010_mci.c | 6 +++++- drivers/pci/pci_ftpci100.c | 4 ++-- include/common.h | 1 + include/configs/adp-ag101.h | 19 ++++++++++++++++- include/configs/adp-ag101p.h | 18 ++++++++++++++++- drivers/pci/pci_ftpci100.h => include/faraday/ftpci100.h | 2 ++ include/ide.h | 2 +- 17 files changed, 309 insertions(+), 19 deletions(-) create mode 100644 arch/nds32/include/asm/setup.h rename drivers/pci/pci_ftpci100.h => include/faraday/ftpci100.h (98%)
Signed-off-by: Tom Rini trini@ti.com --- arch/nds32/include/asm/io.h | 4 +--- arch/nds32/include/asm/setup.h | 4 +--- 2 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/nds32/include/asm/io.h b/arch/nds32/include/asm/io.h index 254c8f9..04708e9 100644 --- a/arch/nds32/include/asm/io.h +++ b/arch/nds32/include/asm/io.h @@ -7,9 +7,7 @@ * Shawn Lin, Andes Technology Corporation nobuhiro@andestech.com * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * SPDX-License-Identifier: GPL-2.0 * * Modifications: * 16-Sep-1996 RMK Inlined the inx/outx functions & optimised for both diff --git a/arch/nds32/include/asm/setup.h b/arch/nds32/include/asm/setup.h index 0a14ea0..833d979 100644 --- a/arch/nds32/include/asm/setup.h +++ b/arch/nds32/include/asm/setup.h @@ -5,9 +5,7 @@ * Copyright (C) 2008 Andes Technology Corporation * Copyright (C) 2013 Ken Kuo (ken_kuo@andestech.com) * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * SPDX-License-Identifier: GPL-2.0 * * Structure passed to kernel to tell it about the * hardware it's running on. See Documentation/arm/Setup
Hi Tom,
2013/7/24 Tom Rini trini@ti.com:
Applied to u-boot-nds32. Thanks!
Hi Tom
2013/7/24 Macpaul Lin macpaul@gmail.com:
Hi Tom,
Because of there are new patches and compile error fix, please ignore this pull-request. I'll review those new patches and resend this pull-request later. Thanks!
Macpaul Lin
