[U-Boot] [PATCH v2 00/11] samsung: Tidy up sound, DM_MMC drop dead code
This series was previously sent as a v1 without a cover letter. Since then I have added a few more patches:
- Support for spring's audio codec - Dropping unused MMC and audio code - Removing unused fdt_compat_id values
Changes in v2: - Add new patch to resync defconfigs for odroid - Remove stranded comments in the header files - Update to convert s5p_goni also - Add new patches as per the cover letter
Simon Glass (11): odroid: Resync defconfigs Convert CONFIG_BOARD_TYPES to Kconfig exynos: Drop duplicate 'model' line exynos: Convert to use CONFIG_BLK sound: Add a driver for max98088 spring: Update sound to use max98088 codec spring: Update flashmap details samsung: Drop board_enable_audio_codec() samsung: mmc: Drop old MMC init code fdt: samsung: Drop unused fdt_compat_id values fdt: tegra: Drop COMPAT_AMS_AS3722
arch/arm/dts/exynos5250-spring.dts | 77 +++-- arch/arm/mach-exynos/Kconfig | 7 + arch/arm/mach-exynos/include/mach/mmc.h | 2 - arch/arm/mach-s5pc1xx/Kconfig | 2 + arch/arm/mach-s5pc1xx/Makefile | 1 + arch/arm/mach-s5pc1xx/pinmux.c | 20 ++ board/samsung/common/board.c | 52 +-- board/samsung/common/exynos5-dt.c | 29 -- common/Kconfig | 8 + configs/axs101_defconfig | 1 + configs/axs103_defconfig | 1 + configs/odroid-xu3_defconfig | 2 +- configs/odroid_defconfig | 2 +- configs/spring_defconfig | 1 + drivers/mmc/s5p_sdhci.c | 50 --- drivers/sound/Kconfig | 8 + drivers/sound/Makefile | 1 + drivers/sound/max98088.c | 431 ++++++++++++++++++++++++ drivers/sound/max98088.h | 192 +++++++++++ drivers/sound/samsung_sound.c | 2 +- include/configs/axs10x.h | 5 - include/configs/hsdk.h | 5 - include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 1 - include/fdtdec.h | 7 - include/samsung/misc.h | 2 - lib/fdtdec.c | 7 - scripts/config_whitelist.txt | 1 - 28 files changed, 739 insertions(+), 179 deletions(-) create mode 100644 arch/arm/mach-s5pc1xx/pinmux.c create mode 100644 drivers/sound/max98088.c create mode 100644 drivers/sound/max98088.h
Sync defconfigs again since USB_STORAGE is the default on these boards.
configs/odroid-xu3_defconfig | 1 - configs/odroid_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index d5c7cc7129d..11796e5bdf4 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -47,7 +47,6 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GADGET=y CONFIG_USB_DWC3_PHY_SAMSUNG=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 594800fc50c..cdb033ba780 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -47,7 +47,6 @@ CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8
Changes in v2:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
This converts the following to Kconfig: CONFIG_BOARD_TYPES
Changes in v2: - Remove stranded comments in the header files
common/Kconfig | 8 ++++++++ configs/axs101_defconfig | 1 + configs/axs103_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + include/configs/axs10x.h | 5 ----- include/configs/hsdk.h | 5 ----- include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 1 - scripts/config_whitelist.txt | 1 - 10 files changed, 12 insertions(+), 13 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 57bd16d9623..a118bbb4b65 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -645,6 +645,14 @@ config DISPLAY_BOARDINFO_LATE the relocation phase. The board function checkboard() is called to do this.
+config BOARD_TYPES + bool "Call get_board_type() to get and display the board type" + help + If this option is enabled, checkboard() will call get_board_type() + to get a string containing the board type and this will be + displayed immediately after the model is shown on the console + early in boot. + menu "Start-up hooks"
config ARCH_EARLY_INIT_R diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index b4621c359fc..126ee1a3edf 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS3,115200n8" +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AXS# " diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index e7894d297cd..c50d51b189b 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -8,6 +8,7 @@ CONFIG_DEBUG_UART=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS3,115200n8" +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AXS# " diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 11796e5bdf4..f6f05b29483 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y +CONFIG_BOARD_TYPES=y CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index cdb033ba780..184bb62c1c1 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y +CONFIG_BOARD_TYPES=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 1b2966fd612..79411282ce2 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -31,11 +31,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_128M #define CONFIG_SYS_LOAD_ADDR 0x82000000
-/* - * This board might be of different versions so handle it - */ -#define CONFIG_BOARD_TYPES - /* * NAND Flash configuration */ diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index cdf4fddd940..d8331206cd9 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -32,11 +32,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_128M #define CONFIG_SYS_LOAD_ADDR 0x82000000
-/* - * This board might be of different versions so handle it - */ -#define CONFIG_BOARD_TYPES - /* * UART configuration */ diff --git a/include/configs/odroid.h b/include/configs/odroid.h index ad77242e380..bc044e069e0 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -186,7 +186,6 @@ * TODO: Add Odroid X support */ #define CONFIG_MISC_COMMON -#define CONFIG_BOARD_TYPES
#undef CONFIG_REVISION_TAG
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index f683ee46e39..c2363dd1eef 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -86,7 +86,6 @@ /* Set soc_rev, soc_id, board_rev, boardname, fdtfile */ #define CONFIG_ODROID_REV_AIN 9 #define CONFIG_REVISION_TAG -#define CONFIG_BOARD_TYPES
#undef CONFIG_SYS_BOARD #define CONFIG_SYS_BOARD "odroid" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b8addeaf693..335977b3038 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -132,7 +132,6 @@ CONFIG_BOARD_POSTCLK_INIT CONFIG_BOARD_REVISION_TAG CONFIG_BOARD_SIZE_LIMIT CONFIG_BOARD_TAURUS -CONFIG_BOARD_TYPES CONFIG_BOOGER CONFIG_BOOTBLOCK CONFIG_BOOTFILE
Changes in v2:
+config BOARD_TYPES
- bool "Call get_board_type() to get and display the board
type"
- help
get_board_type()
console
early in boot.
- This board might be of different versions so handle it
- NAND Flash configuration
- UART configuration
- TODO: Add Odroid X support
Lukasz Majewski
At present the model is shown twice, once in the generic code and once in the exynos code. Drop the latter.
Changes in v2: None
board/samsung/common/board.c | 14 ++++++-------- include/samsung/misc.h | 2 -- 2 files changed, 6 insertions(+), 10 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 6fd26a3a919..3391228522c 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -290,15 +290,13 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { - const char *board_info; + if (IS_ENABLED(CONFIG_BOARD_TYPES)) { + const char *board_info = get_board_type(); + + if (board_info) + printf("Type: %s\n", board_info); + }
- board_info = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - printf("Board: %s\n", board_info ? board_info : "unknown"); -#ifdef CONFIG_BOARD_TYPES - board_info = get_board_type(); - if (board_info) - printf("Type: %s\n", board_info); -#endif return 0; } #endif diff --git a/include/samsung/misc.h b/include/samsung/misc.h index 0f957dc3675..017560c2566 100644 --- a/include/samsung/misc.h +++ b/include/samsung/misc.h @@ -32,9 +32,7 @@ void draw_logo(void); char *get_dfu_alt_system(char *interface, char *devstr); char *get_dfu_alt_boot(char *interface, char *devstr); #endif -#ifdef CONFIG_BOARD_TYPES void set_board_type(void); const char *get_board_type(void); -#endif
#endif /* __SAMSUNG_MISC_COMMON_H__ */
Changes in v2: None
- if (IS_ENABLED(CONFIG_BOARD_TYPES)) {
if (board_info)
- if (board_info)
Lukasz Majewski
Move all exynos boards over to use CONFIG_BLK.
This converts s5p_goni also, but adding dummy functions for pinmux and peripheral ID. This will not function correctly, but gives the maintainer more time to convert the board if desired.
Changes in v2: - Update to convert s5p_goni also
arch/arm/mach-exynos/Kconfig | 7 +++++++ arch/arm/mach-s5pc1xx/Kconfig | 2 ++ arch/arm/mach-s5pc1xx/Makefile | 1 + arch/arm/mach-s5pc1xx/pinmux.c | 20 ++++++++++++++++++++ 4 files changed, 30 insertions(+) create mode 100644 arch/arm/mach-s5pc1xx/pinmux.c
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index ed04369cfae..38077703621 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -8,6 +8,8 @@ config ARCH_EXYNOS4 bool "Exynos4 SoC family" select BOARD_EARLY_INIT_F select CPU_V7A + select BLK + select DM_MMC help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There are multiple SoCs in this family including Exynos4210, Exynos4412, @@ -24,6 +26,9 @@ config ARCH_EXYNOS5 imply USB_ETHER_ASIX imply USB_ETHER_RTL8152 imply USB_ETHER_SMSC95XX + select BLK + select DM_MMC + help Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU (and Cortex-A7 CPU in big.LITTLE configuration). There are multiple SoCs @@ -33,6 +38,8 @@ config ARCH_EXYNOS7 bool "Exynos7 SoC family" select ARM64 select BOARD_EARLY_INIT_F + select BLK + select DM_MMC help Samsung Exynos7 SoC family are based on ARM Cortex-A57 CPU or Cortex-A53 CPU (and some in a big.LITTLE configuration). There are diff --git a/arch/arm/mach-s5pc1xx/Kconfig b/arch/arm/mach-s5pc1xx/Kconfig index 04acdaad79c..8cffced5512 100644 --- a/arch/arm/mach-s5pc1xx/Kconfig +++ b/arch/arm/mach-s5pc1xx/Kconfig @@ -7,6 +7,8 @@ choice config TARGET_S5P_GONI bool "S5P Goni board" select OF_CONTROL + select BLK + select DM_MMC
config TARGET_SMDKC100 bool "Support smdkc100 board" diff --git a/arch/arm/mach-s5pc1xx/Makefile b/arch/arm/mach-s5pc1xx/Makefile index a4be3fcbdae..ab804604d54 100644 --- a/arch/arm/mach-s5pc1xx/Makefile +++ b/arch/arm/mach-s5pc1xx/Makefile @@ -10,3 +10,4 @@ obj-y = cache.o obj-y += reset.o
obj-y += clock.o +obj-y += pinmux.o diff --git a/arch/arm/mach-s5pc1xx/pinmux.c b/arch/arm/mach-s5pc1xx/pinmux.c new file mode 100644 index 00000000000..511e57a28df --- /dev/null +++ b/arch/arm/mach-s5pc1xx/pinmux.c @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Dummy functions to keep s3p_goni building (although it won't work) + * + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <asm/arch/pinmux.h> + +int exynos_pinmux_config(int peripheral, int flags) +{ + return 0; +} + +int pinmux_decode_periph_id(const void *blob, int node) +{ + return 0; +}
Changes in v2:
- select BLK
- select DM_MMC help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU.
- select BLK
- select DM_MMC
- help Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU
- select BLK
- select DM_MMC help Samsung Exynos7 SoC family are based on ARM Cortex-A57 CPU
- select BLK
- select DM_MMC
- Dummy functions to keep s3p_goni building (although it won't work)
^^^^ s5p_goni
- Copyright 2018 Google LLC
- Written by Simon Glass sjg@chromium.org
Despite the above comment, rest seems Ok.
Lukasz Majewski
This chip is used by spring. Add a driver for it and update the samsung_sound driver to pick it up.
Changes in v2: None
drivers/sound/Kconfig | 8 + drivers/sound/Makefile | 1 + drivers/sound/max98088.c | 431 ++++++++++++++++++++++++++++++++++ drivers/sound/max98088.h | 192 +++++++++++++++ drivers/sound/samsung_sound.c | 2 +- 5 files changed, 633 insertions(+), 1 deletion(-) create mode 100644 drivers/sound/max98088.c create mode 100644 drivers/sound/max98088.h
diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index c0d97cca338..6a04a59dada 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -31,6 +31,14 @@ config I2S_SAMSUNG option provides an implementation for sound_init() and sound_play().
+config SOUND_MAX98088 + bool "Support Maxim max98088 audio codec" + depends on I2S_SAMSUNG + help + Enable the max98088 audio codec. This is connected via I2S for + audio data and I2C for codec control. At present it only works + with the Samsung I2S driver. + config SOUND_MAX98090 bool "Support Maxim max98090 audio codec" depends on I2S_SAMSUNG diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 1de4346ec7a..238f33bbb40 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -11,5 +11,6 @@ obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o obj-$(CONFIG_I2S_SAMSUNG) += samsung_sound.o obj-$(CONFIG_SOUND_WM8994) += wm8994.o +obj-$(CONFIG_SOUND_MAX98088) += max98088.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o diff --git a/drivers/sound/max98088.c b/drivers/sound/max98088.c new file mode 100644 index 00000000000..5ddc11ac5c7 --- /dev/null +++ b/drivers/sound/max98088.c @@ -0,0 +1,431 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * max98088.c -- MAX98088 ALSA SoC Audio driver + * + * Copyright 2010 Maxim Integrated Products + * + * Modified for U-Boot by Chih-Chung Chang (chihchung@chromium.org), + * following the changes made in max98095.c + */ + +#include <common.h> +#include <audio_codec.h> +#include <div64.h> +#include <dm.h> +#include <i2c.h> +#include <i2s.h> +#include <sound.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/cpu.h> +#include <asm/arch/power.h> +#include "maxim_codec.h" +#include "max98088.h" + +/* codec mclk clock divider coefficients. Index 0 is reserved. */ +static const int rate_table[] = {0, 8000, 11025, 16000, 22050, 24000, 32000, + 44100, 48000, 88200, 96000}; + +/* + * codec mclk clock divider coefficients based on sampling rate + * + * @param rate sampling rate + * @param value address of indexvalue to be stored + * + * @return 0 for success or negative error code. + */ +static int rate_value(int rate, u8 *value) +{ + int i; + + for (i = 1; i < ARRAY_SIZE(rate_table); i++) { + if (rate_table[i] >= rate) { + *value = i; + return 0; + } + } + *value = 1; + + return -1; +} + +/* + * Sets hw params for max98088 + * + * @priv: max98088 information pointer + * @rate: Sampling rate + * @bits_per_sample: Bits per sample + * + * @return -EIO for error, 0 for success. + */ +int max98088_hw_params(struct maxim_priv *priv, unsigned int rate, + unsigned int bits_per_sample) +{ + int error; + u8 regval; + + switch (bits_per_sample) { + case 16: + error = maxim_bic_or(priv, M98088_REG_DAI1_FORMAT, + M98088_DAI_WS, 0); + break; + case 24: + error = maxim_bic_or(priv, M98088_REG_DAI1_FORMAT, + M98088_DAI_WS, M98088_DAI_WS); + break; + default: + debug("%s: Illegal bits per sample %d.\n", + __func__, bits_per_sample); + return -1; + } + + error |= maxim_bic_or(priv, M98088_REG_PWR_SYS, M98088_SHDNRUN, 0); + + if (rate_value(rate, ®val)) { + debug("%s: Failed to set sample rate to %d.\n", + __func__, rate); + return -1; + } + + error |= maxim_bic_or(priv, M98088_REG_DAI1_CLKMODE, + M98088_CLKMODE_MASK, regval << 4); + priv->rate = rate; + + /* Update sample rate mode */ + if (rate < 50000) + error |= maxim_bic_or(priv, M98088_REG_DAI1_FILTERS, + M98088_DAI_DHF, 0); + else + error |= maxim_bic_or(priv, M98088_REG_DAI1_FILTERS, + M98088_DAI_DHF, M98088_DAI_DHF); + + error |= maxim_bic_or(priv, M98088_REG_PWR_SYS, M98088_SHDNRUN, + M98088_SHDNRUN); + + if (error < 0) { + debug("%s: Error setting hardware params.\n", __func__); + return -EIO; + } + priv->rate = rate; + + return 0; +} + +/* + * Configures Audio interface system clock for the given frequency + * + * @priv: max98088 information + * @freq: Sampling frequency in Hz + * + * @return -EIO for error, 0 for success. + */ +int max98088_set_sysclk(struct maxim_priv *priv, unsigned int freq) +{ + int error = 0; + u8 pwr; + + /* Requested clock frequency is already setup */ + if (freq == priv->sysclk) + return 0; + + /* + * Setup clocks for slave mode, and using the PLL + * PSCLK = 0x01 (when master clk is 10MHz to 20MHz) + * 0x02 (when master clk is 20MHz to 30MHz).. + */ + if (freq >= 10000000 && freq < 20000000) { + error = maxim_i2c_write(priv, M98088_REG_SYS_CLK, 0x10); + } else if ((freq >= 20000000) && (freq < 30000000)) { + error = maxim_i2c_write(priv, M98088_REG_SYS_CLK, 0x20); + } else { + debug("%s: Invalid master clock frequency\n", __func__); + return -EIO; + } + + error |= maxim_i2c_read(priv, M98088_REG_PWR_SYS, &pwr); + if (pwr & M98088_SHDNRUN) { + error |= maxim_bic_or(priv, M98088_REG_PWR_SYS, + M98088_SHDNRUN, 0); + error |= maxim_bic_or(priv, M98088_REG_PWR_SYS, + M98088_SHDNRUN, M98088_SHDNRUN); + } + + debug("%s: Clock at %uHz\n", __func__, freq); + if (error < 0) + return -EIO; + + priv->sysclk = freq; + + return 0; +} + +/* + * Sets Max98090 I2S format + * + * @priv: max98088 information + * @fmt: i2S format - supports a subset of the options defined in i2s.h. + * + * @return -EIO for error, 0 for success. + */ +int max98088_set_fmt(struct maxim_priv *priv, int fmt) +{ + u8 reg15val; + u8 reg14val = 0; + int error = 0; + + if (fmt == priv->fmt) + return 0; + + priv->fmt = fmt; + + switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { + case SND_SOC_DAIFMT_CBS_CFS: + /* Slave mode PLL */ + error |= maxim_i2c_write(priv, M98088_REG_DAI1_CLKCFG_HI, + 0x80); + error |= maxim_i2c_write(priv, M98088_REG_DAI1_CLKCFG_LO, + 0x00); + break; + case SND_SOC_DAIFMT_CBM_CFM: + /* Set to master mode */ + reg14val |= M98088_DAI_MAS; + break; + case SND_SOC_DAIFMT_CBS_CFM: + case SND_SOC_DAIFMT_CBM_CFS: + default: + debug("%s: Clock mode unsupported\n", __func__); + return -EINVAL; + } + + switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) { + case SND_SOC_DAIFMT_I2S: + reg14val |= M98088_DAI_DLY; + break; + case SND_SOC_DAIFMT_LEFT_J: + break; + default: + debug("%s: Unrecognized format.\n", __func__); + return -EINVAL; + } + + switch (fmt & SND_SOC_DAIFMT_INV_MASK) { + case SND_SOC_DAIFMT_NB_NF: + break; + case SND_SOC_DAIFMT_NB_IF: + reg14val |= M98088_DAI_WCI; + break; + case SND_SOC_DAIFMT_IB_NF: + reg14val |= M98088_DAI_BCI; + break; + case SND_SOC_DAIFMT_IB_IF: + reg14val |= M98088_DAI_BCI | M98088_DAI_WCI; + break; + default: + debug("%s: Unrecognized inversion settings.\n", __func__); + return -EINVAL; + } + + error |= maxim_bic_or(priv, M98088_REG_DAI1_FORMAT, + M98088_DAI_MAS | M98088_DAI_DLY | M98088_DAI_BCI | + M98088_DAI_WCI, reg14val); + reg15val = M98088_DAI_BSEL64; + error |= maxim_i2c_write(priv, M98088_REG_DAI1_CLOCK, reg15val); + + if (error < 0) { + debug("%s: Error setting i2s format.\n", __func__); + return -EIO; + } + + return 0; +} + +/* + * max98088_reset() - reset the audio codec + * + * @priv: max98088 information + * @return -EIO for error, 0 for success. + */ +static int max98088_reset(struct maxim_priv *priv) +{ + int ret, i; + u8 val; + + /* + * Reset to hardware default for registers, as there is not a soft + * reset hardware control register. + */ + for (i = M98088_REG_IRQ_ENABLE; i <= M98088_REG_PWR_SYS; i++) { + switch (i) { + case M98088_REG_BIAS_CNTL: + val = 0xf0; + break; + case M98088_REG_DAC_BIAS2: + val = 0x0f; + break; + default: + val = 0; + } + ret = maxim_i2c_write(priv, i, val); + if (ret < 0) { + debug("%s: Failed to reset: %d\n", __func__, ret); + return ret; + } + } + + return 0; +} + +/** + * max98088_device_init() - Initialise max98088 codec device + * + * @priv: max98088 information + * + * @return -EIO for error, 0 for success. + */ +static int max98088_device_init(struct maxim_priv *priv) +{ + unsigned char id; + int error = 0; + + /* Enable codec clock */ + set_xclkout(); + + /* reset the codec, the DSP core, and disable all interrupts */ + error = max98088_reset(priv); + if (error != 0) { + debug("Reset\n"); + return error; + } + + /* initialize private data */ + priv->sysclk = -1U; + priv->rate = -1U; + priv->fmt = -1U; + + error = maxim_i2c_read(priv, M98088_REG_REV_ID, &id); + if (error < 0) { + debug("%s: Failure reading hardware revision: %d\n", + __func__, id); + return -EIO; + } + debug("%s: Hardware revision: %d\n", __func__, id); + + return 0; +} + +static int max98088_setup_interface(struct maxim_priv *priv) +{ + int error; + + /* Reading interrupt status to clear them */ + error = maxim_i2c_write(priv, M98088_REG_PWR_SYS, M98088_PWRSV); + error |= maxim_i2c_write(priv, M98088_REG_IRQ_ENABLE, 0x00); + + /* + * initialize registers to hardware default configuring audio + * interface2 to DAI1 + */ + error |= maxim_i2c_write(priv, M98088_REG_MIX_DAC, + M98088_DAI1L_TO_DACL | M98088_DAI1R_TO_DACR); + error |= maxim_i2c_write(priv, M98088_REG_BIAS_CNTL, 0xF0); + error |= maxim_i2c_write(priv, M98088_REG_DAC_BIAS2, 0x0F); + error |= maxim_i2c_write(priv, M98088_REG_DAI1_IOCFG, + M98088_S2NORMAL | M98088_SDATA); + + /* + * route DACL and DACR output to headphone and speakers + * Ordering: DACL, DACR, DACL, DACR + */ + error |= maxim_i2c_write(priv, M98088_REG_MIX_SPK_LEFT, 1); + error |= maxim_i2c_write(priv, M98088_REG_MIX_SPK_RIGHT, 1); + error |= maxim_i2c_write(priv, M98088_REG_MIX_HP_LEFT, 1); + error |= maxim_i2c_write(priv, M98088_REG_MIX_HP_RIGHT, 1); + + /* set volume: -12db */ + error |= maxim_i2c_write(priv, M98088_REG_LVL_SPK_L, 0x0f); + error |= maxim_i2c_write(priv, M98088_REG_LVL_SPK_R, 0x0f); + + /* set volume: -22db */ + error |= maxim_i2c_write(priv, M98088_REG_LVL_HP_L, 0x0d); + error |= maxim_i2c_write(priv, M98088_REG_LVL_HP_R, 0x0d); + + /* power enable */ + error |= maxim_i2c_write(priv, M98088_REG_PWR_EN_OUT, + M98088_HPLEN | M98088_HPREN | M98088_SPLEN | + M98088_SPREN | M98088_DALEN | M98088_DAREN); + if (error < 0) + return -EIO; + + return 0; +} + +static int max98088_do_init(struct maxim_priv *priv, int sampling_rate, + int mclk_freq, int bits_per_sample) +{ + int ret = 0; + + ret = max98088_setup_interface(priv); + if (ret < 0) { + debug("%s: max98088 setup interface failed\n", __func__); + return ret; + } + + ret = max98088_set_sysclk(priv, mclk_freq); + if (ret < 0) { + debug("%s: max98088 codec set sys clock failed\n", __func__); + return ret; + } + + ret = max98088_hw_params(priv, sampling_rate, bits_per_sample); + + if (ret == 0) { + ret = max98088_set_fmt(priv, SND_SOC_DAIFMT_I2S | + SND_SOC_DAIFMT_NB_NF | + SND_SOC_DAIFMT_CBS_CFS); + } + + return ret; +} + +static int max98088_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, + uint channels) +{ + struct maxim_priv *priv = dev_get_priv(dev); + + return max98088_do_init(priv, rate, mclk_freq, bits_per_sample); +} + +static int max98088_probe(struct udevice *dev) +{ + struct maxim_priv *priv = dev_get_priv(dev); + int ret; + + priv->dev = dev; + ret = max98088_device_init(priv); + if (ret < 0) { + debug("%s: max98088 codec chip init failed\n", __func__); + return ret; + } + + return 0; +} + +static const struct audio_codec_ops max98088_ops = { + .set_params = max98088_set_params, +}; + +static const struct udevice_id max98088_ids[] = { + { .compatible = "maxim,max98088" }, + { } +}; + +U_BOOT_DRIVER(max98088) = { + .name = "max98088", + .id = UCLASS_AUDIO_CODEC, + .of_match = max98088_ids, + .probe = max98088_probe, + .ops = &max98088_ops, + .priv_auto_alloc_size = sizeof(struct maxim_priv), +}; diff --git a/drivers/sound/max98088.h b/drivers/sound/max98088.h new file mode 100644 index 00000000000..127d2bda305 --- /dev/null +++ b/drivers/sound/max98088.h @@ -0,0 +1,192 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * max98088.h -- MAX98088 ALSA SoC Audio driver + * + * Copyright 2010 Maxim Integrated Products + */ + +#ifndef _MAX98088_H +#define _MAX98088_H + +/* MAX98088 Registers Definition */ +#define M98088_REG_IRQ_STATUS 0x00 +#define M98088_REG_MIC_STATUS 0x01 +#define M98088_REG_JACK_STAUS 0x02 +#define M98088_REG_BATTERY_VOLTAGE 0x03 +#define M98088_REG_IRQ_ENABLE 0x0f +#define M98088_REG_SYS_CLK 0X10 +#define M98088_REG_DAI1_CLKMODE 0x11 +#define M98088_REG_DAI1_CLKCFG_HI 0x12 +#define M98088_REG_DAI1_CLKCFG_LO 0x13 +#define M98088_REG_DAI1_FORMAT 0x14 +#define M98088_REG_DAI1_CLOCK 0x15 +#define M98088_REG_DAI1_IOCFG 0x16 +#define M98088_REG_DAI1_TDM 0X17 +#define M98088_REG_DAI1_FILTERS 0x18 +#define M98088_REG_DAI2_CLKMODE 0x19 +#define M98088_REG_DAI2_CLKCFG_HI 0x1a +#define M98088_REG_DAI2_CLKCFG_LO 0x1b +#define M98088_REG_DAI2_FORMAT 0x1c +#define M98088_REG_DAI2_CLOCK 0x1d +#define M98088_REG_DAI2_IOCFG 0x1e +#define M98088_REG_DAI2_TDM 0X1f +#define M98088_REG_DAI2_FILTERS 0x20 +#define M98088_REG_SRC 0X21 +#define M98088_REG_MIX_DAC 0X22 +#define M98088_REG_MIX_ADC_LEFT 0x23 +#define M98088_REG_MIX_ADC_RIGHT 0x24 +#define M98088_REG_MIX_HP_LEFT 0x25 +#define M98088_REG_MIX_HP_RIGHT 0x26 +#define M98088_REG_MIX_HP_CNTL 0x27 +#define M98088_REG_MIX_REC_LEFT 0x28 +#define M98088_REG_MIX_REC_RIGHT 0x29 +#define M98088_REG_MIC_REC_CNTL 0x2a +#define M98088_REG_MIX_SPK_LEFT 0x2b +#define M98088_REG_MIX_SPK_RIGHT 0x2c +#define M98088_REG_MIX_SPK_CNTL 0x2d +#define M98088_REG_LVL_SIDETONE 0x2e +#define M98088_REG_LVL_DAI1_PLAY 0x2f +#define M98088_REG_LVL_DAI1_PLAY_EQ 0x30 +#define M98088_REG_LVL_DAI2_PLAY 0x31 +#define M98088_REG_LVL_DAI2_PLAY_EQ 0x32 +#define M98088_REG_LVL_ADC_L 0X33 +#define M98088_REG_LVL_ADC_R 0X34 +#define M98088_REG_LVL_MIC1 0X35 +#define M98088_REG_LVL_MIC2 0X36 +#define M98088_REG_LVL_INA 0X37 +#define M98088_REG_LVL_INB 0X38 +#define M98088_REG_LVL_HP_L 0X39 +#define M98088_REG_LVL_HP_R 0X3a +#define M98088_REG_LVL_REC_L 0X3b +#define M98088_REG_LVL_REC_R 0X3c +#define M98088_REG_LVL_SPK_L 0X3d +#define M98088_REG_LVL_SPK_R 0X3e +#define M98088_REG_MICAGC_CFG 0x3f +#define M98088_REG_MICAGC_THRESH 0x40 +#define M98088_REG_SPKDHP 0X41 +#define M98088_REG_SPKDHP_THRESH 0x42 +#define M98088_REG_SPKALC_COMP 0x43 +#define M98088_REG_PWRLMT_CFG 0x44 +#define M98088_REG_PWRLMT_TIME 0x45 +#define M98088_REG_THDLMT_CFG 0x46 +#define M98088_REG_CFG_AUDIO_IN 0x47 +#define M98088_REG_CFG_MIC 0X48 +#define M98088_REG_CFG_LEVEL 0X49 +#define M98088_REG_CFG_BYPASS 0x4a +#define M98088_REG_CFG_JACKDET 0x4b +#define M98088_REG_PWR_EN_IN 0X4c +#define M98088_REG_PWR_EN_OUT 0x4d +#define M98088_REG_BIAS_CNTL 0X4e +#define M98088_REG_DAC_BIAS1 0X4f +#define M98088_REG_DAC_BIAS2 0X50 +#define M98088_REG_PWR_SYS 0X51 +#define M98088_REG_DAI1_EQ_BASE 0x52 +#define M98088_REG_DAI2_EQ_BASE 0x84 +#define M98088_REG_DAI1_BIQUAD_BASE 0xb6 +#define M98088_REG_DAI2_BIQUAD_BASE 0xc0 +#define M98088_REG_REV_ID 0xff + +#define M98088_REG_CNT (0xff + 1) + +/* MAX98088 Registers Bit Fields */ + +/* M98088_REG_11_DAI1_CLKMODE, M98088_REG_19_DAI2_CLKMODE */ +#define M98088_CLKMODE_MASK 0xFF + +/* M98088_REG_14_DAI1_FORMAT, M98088_REG_1C_DAI2_FORMAT */ +#define M98088_DAI_MAS BIT(7) +#define M98088_DAI_WCI BIT(6) +#define M98088_DAI_BCI BIT(5) +#define M98088_DAI_DLY BIT(4) +#define M98088_DAI_TDM BIT(2) +#define M98088_DAI_FSW BIT(1) +#define M98088_DAI_WS BIT(0) + +/* M98088_REG_15_DAI1_CLOCK, M98088_REG_1D_DAI2_CLOCK */ +#define M98088_DAI_BSEL64 BIT(0) +#define M98088_DAI_OSR64 BIT(6) + +/* M98088_REG_16_DAI1_IOCFG, M98088_REG_1E_DAI2_IOCFG */ +#define M98088_S1NORMAL BIT(6) +#define M98088_S2NORMAL (2 << 6) +#define M98088_SDATA (3 << 0) + +/* M98088_REG_18_DAI1_FILTERS, M98088_REG_20_DAI2_FILTERS */ +#define M98088_DAI_DHF BIT(3) + +/* M98088_REG_22_MIX_DAC */ +#define M98088_DAI1L_TO_DACL BIT(7) +#define M98088_DAI1R_TO_DACL BIT(6) +#define M98088_DAI2L_TO_DACL BIT(5) +#define M98088_DAI2R_TO_DACL BIT(4) +#define M98088_DAI1L_TO_DACR BIT(3) +#define M98088_DAI1R_TO_DACR BIT(2) +#define M98088_DAI2L_TO_DACR BIT(1) +#define M98088_DAI2R_TO_DACR BIT(0) + +/* M98088_REG_2A_MIC_REC_CNTL */ +#define M98088_REC_LINEMODE BIT(7) +#define M98088_REC_LINEMODE_MASK BIT(7) + +/* M98088_REG_2D_MIX_SPK_CNTL */ +#define M98088_MIX_SPKR_GAIN_MASK (3 << 2) +#define M98088_MIX_SPKR_GAIN_SHIFT 2 +#define M98088_MIX_SPKL_GAIN_MASK (3 << 0) +#define M98088_MIX_SPKL_GAIN_SHIFT 0 + +/* M98088_REG_2F_LVL_DAI1_PLAY, M98088_REG_31_LVL_DAI2_PLAY */ +#define M98088_DAI_MUTE BIT(7) +#define M98088_DAI_MUTE_MASK BIT(7) +#define M98088_DAI_VOICE_GAIN_MASK (3 << 4) +#define M98088_DAI_ATTENUATION_MASK (0xf << 0) +#define M98088_DAI_ATTENUATION_SHIFT 0 + +/* M98088_REG_35_LVL_MIC1, M98088_REG_36_LVL_MIC2 */ +#define M98088_MICPRE_MASK (3 << 5) +#define M98088_MICPRE_SHIFT 5 + +/* M98088_REG_3A_LVL_HP_R */ +#define M98088_HP_MUTE BIT(7) + +/* M98088_REG_3C_LVL_REC_R */ +#define M98088_REC_MUTE BIT(7) + +/* M98088_REG_3E_LVL_SPK_R */ +#define M98088_SP_MUTE BIT(7) + +/* M98088_REG_48_CFG_MIC */ +#define M98088_EXTMIC_MASK (3 << 0) +#define M98088_DIGMIC_L BIT(5) +#define M98088_DIGMIC_R BIT(4) + +/* M98088_REG_49_CFG_LEVEL */ +#define M98088_VSEN BIT(6) +#define M98088_ZDEN BIT(5) +#define M98088_EQ2EN BIT(1) +#define M98088_EQ1EN BIT(0) + +/* M98088_REG_4C_PWR_EN_IN */ +#define M98088_INAEN BIT(7) +#define M98088_INBEN BIT(6) +#define M98088_MBEN BIT(3) +#define M98088_ADLEN BIT(1) +#define M98088_ADREN BIT(0) + +/* M98088_REG_4D_PWR_EN_OUT */ +#define M98088_HPLEN BIT(7) +#define M98088_HPREN BIT(6) +#define M98088_HPEN (BIT(7) | BIT(6)) +#define M98088_SPLEN BIT(5) +#define M98088_SPREN BIT(4) +#define M98088_RECEN BIT(3) +#define M98088_DALEN BIT(1) +#define M98088_DAREN BIT(0) + +/* M98088_REG_51_PWR_SYS */ +#define M98088_SHDNRUN BIT(7) +#define M98088_PERFMODE BIT(3) +#define M98088_HPPLYBACK BIT(2) +#define M98088_PWRSV8K BIT(1) +#define M98088_PWRSV BIT(0) + +#endif diff --git a/drivers/sound/samsung_sound.c b/drivers/sound/samsung_sound.c index 1d711c87322..84064ebd0fe 100644 --- a/drivers/sound/samsung_sound.c +++ b/drivers/sound/samsung_sound.c @@ -89,7 +89,7 @@ static const struct sound_ops samsung_sound_ops = {
static const struct udevice_id samsung_sound_ids[] = { { .compatible = "google,snow-audio-max98095" }, - { .compatible = "google,spring-audio-max98095" }, + { .compatible = "google,spring-audio-max98088" }, { .compatible = "samsung,smdk5420-audio-wm8994" }, { .compatible = "google,peach-audio-max98090" }, { }
Changes in v2: None
- bool "Support Maxim max98088 audio codec"
- depends on I2S_SAMSUNG
- help
for
works
- max98088.c -- MAX98088 ALSA SoC Audio driver
- Copyright 2010 Maxim Integrated Products
- Modified for U-Boot by Chih-Chung Chang (chihchung@chromium.org),
- following the changes made in max98095.c
- codec mclk clock divider coefficients based on sampling rate
- @param rate sampling rate
- @param value address of indexvalue to be stored
- @return 0 for success or negative error code.
- int i;
- for (i = 1; i < ARRAY_SIZE(rate_table); i++) {
*value = i;
- *value = 1;
- return -1;
Please change the return value to more descriptive name - e.g. -EINVAL, etc (in some parts of this patch you use -EIO, -EINVAL).
Please fix it globally.
- Sets hw params for max98088
- @priv: max98088 information pointer
- @rate: Sampling rate
- @bits_per_sample: Bits per sample
- @return -EIO for error, 0 for success.
- int error;
- u8 regval;
- switch (bits_per_sample) {
- case 16:
M98088_DAI_WS, 0);
1> + break;
- case 24:
break;
- default:
return -1;
- error |= maxim_bic_or(priv, M98088_REG_PWR_SYS,
- if (rate_value(rate, ®val)) {
__func__, rate);
return -1;
- error |= maxim_bic_or(priv, M98088_REG_DAI1_CLKMODE,
- priv->rate = rate;
- /* Update sample rate mode */
- if (rate < 50000)
M98088_DAI_DHF, 0);
- else
M98088_DAI_DHF,
M98088_DAI_DHF); +
M98088_SHDNRUN,
M98088_SHDNRUN);
- if (error < 0) {
__func__);
return -EIO;
- Configures Audio interface system clock for the given frequency
- @freq: Sampling frequency in Hz
- int error = 0;
- u8 pwr;
- /* Requested clock frequency is already setup */
- if (freq == priv->sysclk)
- if (freq >= 10000000 && freq < 20000000) {
0x10);
- } else if ((freq >= 20000000) && (freq < 30000000)) {
0x20);
- } else {
__func__);
return -EIO;
- error |= maxim_i2c_read(priv, M98088_REG_PWR_SYS, &pwr);
- if (pwr & M98088_SHDNRUN) {
M98088_SHDNRUN, 0);
M98088_SHDNRUN,
M98088_SHDNRUN);
- debug("%s: Clock at %uHz\n", __func__, freq);
- if (error < 0)
return -EIO;
- priv->sysclk = freq;
- Sets Max98090 I2S format
- @fmt: i2S format - supports a subset of the options defined in
i2s.h.
- u8 reg15val;
- u8 reg14val = 0;
- int error = 0;
- if (fmt == priv->fmt)
- priv->fmt = fmt;
- switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) {
- case SND_SOC_DAIFMT_CBS_CFS:
0x80);
0x00);
break;
- case SND_SOC_DAIFMT_CBM_CFM:
break;
- case SND_SOC_DAIFMT_CBS_CFM:
- case SND_SOC_DAIFMT_CBM_CFS:
- default:
return -EINVAL;
- switch (fmt & SND_SOC_DAIFMT_FORMAT_MASK) {
- case SND_SOC_DAIFMT_I2S:
break;
- case SND_SOC_DAIFMT_LEFT_J:
break;
- default:
return -EINVAL;
- switch (fmt & SND_SOC_DAIFMT_INV_MASK) {
- case SND_SOC_DAIFMT_NB_NF:
break;
- case SND_SOC_DAIFMT_NB_IF:
break;
- case SND_SOC_DAIFMT_IB_NF:
break;
- case SND_SOC_DAIFMT_IB_IF:
break;
- default:
__func__);
return -EINVAL;
- error |= maxim_bic_or(priv, M98088_REG_DAI1_FORMAT,
M98088_DAI_BCI |
- reg15val = M98088_DAI_BSEL64;
- error |= maxim_i2c_write(priv, M98088_REG_DAI1_CLOCK,
reg15val); +
- if (error < 0) {
return -EIO;
- max98088_reset() - reset the audio codec
- int ret, i;
- u8 val;
a soft
- for (i = M98088_REG_IRQ_ENABLE; i <= M98088_REG_PWR_SYS;
i++) {
switch (i) {
val = 0xf0;
break;
val = 0x0f;
break;
default:
val = 0;
if (ret < 0) {
ret);
return ret;
- max98088_device_init() - Initialise max98088 codec device
- unsigned char id;
- int error = 0;
- /* Enable codec clock */
- set_xclkout();
- /* reset the codec, the DSP core, and disable all interrupts
- error = max98088_reset(priv);
- if (error != 0) {
debug("Reset\n");
return error;
- /* initialize private data */
- priv->sysclk = -1U;
- priv->rate = -1U;
- priv->fmt = -1U;
- error = maxim_i2c_read(priv, M98088_REG_REV_ID, &id);
- if (error < 0) {
__func__, id);
return -EIO;
- debug("%s: Hardware revision: %d\n", __func__, id);
- int error;
- /* Reading interrupt status to clear them */
- error = maxim_i2c_write(priv, M98088_REG_PWR_SYS,
M98088_PWRSV);
- error |= maxim_i2c_write(priv, M98088_REG_IRQ_ENABLE, 0x00);
- error |= maxim_i2c_write(priv, M98088_REG_MIX_DAC,
- error |= maxim_i2c_write(priv, M98088_REG_BIAS_CNTL, 0xF0);
- error |= maxim_i2c_write(priv, M98088_REG_DAC_BIAS2, 0x0F);
- error |= maxim_i2c_write(priv, M98088_REG_DAI1_IOCFG,
- error |= maxim_i2c_write(priv, M98088_REG_MIX_SPK_LEFT, 1);
- error |= maxim_i2c_write(priv, M98088_REG_MIX_SPK_RIGHT, 1);
- error |= maxim_i2c_write(priv, M98088_REG_MIX_HP_LEFT, 1);
- error |= maxim_i2c_write(priv, M98088_REG_MIX_HP_RIGHT, 1);
- /* set volume: -12db */
- error |= maxim_i2c_write(priv, M98088_REG_LVL_SPK_L, 0x0f);
- error |= maxim_i2c_write(priv, M98088_REG_LVL_SPK_R, 0x0f);
- /* set volume: -22db */
- error |= maxim_i2c_write(priv, M98088_REG_LVL_HP_L, 0x0d);
- error |= maxim_i2c_write(priv, M98088_REG_LVL_HP_R, 0x0d);
- /* power enable */
- error |= maxim_i2c_write(priv, M98088_REG_PWR_EN_OUT,
M98088_SPLEN |
M98088_DAREN);
- if (error < 0)
return -EIO;
- int ret = 0;
- ret = max98088_setup_interface(priv);
- if (ret < 0) {
__func__);
return ret;
- ret = max98088_set_sysclk(priv, mclk_freq);
- if (ret < 0) {
__func__);
return ret;
- ret = max98088_hw_params(priv, sampling_rate,
bits_per_sample); +
- if (ret == 0) {
- return ret;
uint channels)
- struct maxim_priv *priv = dev_get_priv(dev);
- return max98088_do_init(priv, rate, mclk_freq,
- int ret;
- priv->dev = dev;
- ret = max98088_device_init(priv);
- if (ret < 0) {
__func__);
return ret;
- .set_params = max98088_set_params,
- { .compatible = "maxim,max98088" },
- .name = "max98088",
- .id = UCLASS_AUDIO_CODEC,
- .of_match = max98088_ids,
- .probe = max98088_probe,
- .ops = &max98088_ops,
- .priv_auto_alloc_size = sizeof(struct maxim_priv),
- max98088.h -- MAX98088 ALSA SoC Audio driver
- { .compatible = "google,spring-audio-max98088" }, { .compatible = "samsung,smdk5420-audio-wm8994" }, { .compatible = "google,peach-audio-max98090" }, { }
Lukasz Majewski
Update the spring settings to use this codec, which is what it actually shipped with.
Changes in v2: None
arch/arm/dts/exynos5250-spring.dts | 36 +++++++++++++++--------------- configs/spring_defconfig | 1 + 2 files changed, 19 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/exynos5250-spring.dts b/arch/arm/dts/exynos5250-spring.dts index 191e12af6a1..942f5027753 100644 --- a/arch/arm/dts/exynos5250-spring.dts +++ b/arch/arm/dts/exynos5250-spring.dts @@ -93,6 +93,22 @@ samsung,vbus-gpio = <&gpx2 7 GPIO_ACTIVE_HIGH>; };
+ sound { + compatible = "google,spring-audio-max98088"; + + samsung,model = "Spring-I2S-MAX98088"; + samsung,audio-codec = <&max98088>; + codec-enable-gpio = <&gpx1 7 0>; + + cpu { + sound-dai = <&i2s1 0>; + }; + + codec { + sound-dai = <&max98088 0>; + }; + }; + spi@12d30000 { spi-max-frequency = <50000000>; firmware_storage_spi: flash@0 { @@ -638,27 +654,11 @@ }; };
- max98095: soundcodec@10 { + max98088: soundcodec@10 { reg = <0x10>; - compatible = "maxim,max98095"; + compatible = "maxim,max98088"; #sound-dai-cells = <1>; }; - - sound { - compatible = "google,spring-audio-max98095"; - - samsung,model = "Spring-I2S-MAX98095"; - samsung,audio-codec = <&max98095>; - - cpu { - sound-dai = <&i2s0 0>; - }; - - codec { - sound-dai = <&max98095 0>; - }; - }; - };
#include "cros-ec-keyboard.dtsi" diff --git a/configs/spring_defconfig b/configs/spring_defconfig index c089517692e..07ff029a413 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -62,6 +62,7 @@ CONFIG_DEBUG_UART_S5P=y CONFIG_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y +CONFIG_SOUND_MAX98088=y CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y
Changes in v2: None
- sound {
cpu {
codec {
- spi@12d30000 { spi-max-frequency = <50000000>; firmware_storage_spi: flash@0 {
- max98088: soundcodec@10 { reg = <0x10>;
#sound-dai-cells = <1>; };compatible = "maxim,max98088";
- sound {
cpu {
codec {
Lukasz Majewski
Update the flashmap so that this board can be started over USB A-A. It is slightly different from snow.
Changes in v2: None
arch/arm/dts/exynos5250-spring.dts | 41 ++++++++++++++++++++++++++++-- 1 file changed, 39 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/exynos5250-spring.dts b/arch/arm/dts/exynos5250-spring.dts index 942f5027753..c7553208ade 100644 --- a/arch/arm/dts/exynos5250-spring.dts +++ b/arch/arm/dts/exynos5250-spring.dts @@ -40,9 +40,46 @@ reg = <0x40000000 0x80000000>; };
+ iram { + reg = <0x02020000 0x60000>; + }; + + config { + samsung,bl1-offset = <0x1400>; + samsung,bl2-offset = <0x3400>; + u-boot-memory = "/memory"; + u-boot-offset = <0x3e00000 0x100000>; + }; + flash@0 { - spl { /* spl size override */ - size = <0x8000>; + reg = <0 0x100000>; + #address-cells = <1>; + #size-cells = <1>; + pre-boot { + label = "bl1 pre-boot"; + reg = <0 0x2000>; + read-only; + filename = "e5250.nbl1.bin"; + type = "blob exynos-bl1"; + required; + }; + + spl { + label = "bl2 spl"; + reg = <0x2000 0x8000>; + read-only; + filename = "bl2.bin"; + type = "blob exynos-bl2 boot,dtb"; + payload = "/flash/ro-boot"; + required; + }; + + ro-boot { + label = "u-boot"; + reg = <0xa000 0xb0000>; + read-only; + type = "blob boot,dtb"; + required; }; };
Changes in v2: None
- iram {
- config {
- flash@0 {
size = <0x8000>;
reg = <0 0x100000>;
#size-cells = <1>;
pre-boot {
reg = <0 0x2000>;
read-only;
required;
spl {
label = "bl2 spl";
read-only;
required;
ro-boot {
label = "u-boot";
read-only;
}; };required;
Lukasz Majewski
This function is not needed now since the audio codecs have been converted to proper drivers. The codec-enable GPIO is handled there.
Changes in v2: None
board/samsung/common/exynos5-dt.c | 29 ----------------------------- 1 file changed, 29 deletions(-)
diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index c183965b92a..87eb381345d 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -34,37 +34,8 @@
DECLARE_GLOBAL_DATA_PTR;
-static void board_enable_audio_codec(void) -{ - int node, ret; - struct gpio_desc en_gpio; - - node = fdtdec_next_compatible(gd->fdt_blob, 0, - COMPAT_SAMSUNG_EXYNOS5_SOUND); - if (node <= 0) - return; - - ret = gpio_request_by_name_nodev(offset_to_ofnode(node), - "codec-enable-gpio", 0, &en_gpio, - GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); - if (ret == -FDT_ERR_NOTFOUND) - return; - - /* Turn on the GPIO which connects to the codec's "enable" line. */ - gpio_set_pull(gpio_get_number(&en_gpio), S5P_GPIO_PULL_NONE); - -#ifdef CONFIG_SOUND_MAX98095 - /* Enable MAX98095 Codec */ - gpio_request(EXYNOS5_GPIO_X17, "max98095_enable"); - gpio_direction_output(EXYNOS5_GPIO_X17, 1); - gpio_set_pull(EXYNOS5_GPIO_X17, S5P_GPIO_PULL_NONE); -#endif -} - int exynos_init(void) { - board_enable_audio_codec(); - return 0; }
Changes in v2: None
- int node, ret;
- if (node <= 0)
return;
&en_gpio,
GPIOD_IS_OUT |
return;
line. */
-#endif -}
Lukasz Majewski
Now that these boards use driver model we can drop the old code. At present s5p_mmc_init() is still used by goni and smdkv310 so cannot be removed unless we remove those boards.
Changes in v2: None
arch/arm/mach-exynos/include/mach/mmc.h | 2 - board/samsung/common/board.c | 38 ------------------- drivers/mmc/s5p_sdhci.c | 50 ------------------------- 3 files changed, 90 deletions(-)
diff --git a/arch/arm/mach-exynos/include/mach/mmc.h b/arch/arm/mach-exynos/include/mach/mmc.h index ca4e7eda342..eece44ea1aa 100644 --- a/arch/arm/mach-exynos/include/mach/mmc.h +++ b/arch/arm/mach-exynos/include/mach/mmc.h @@ -64,6 +64,4 @@ static inline int s5p_mmc_init(int index, int bus_width) return s5p_sdhci_init(base, index, bus_width); }
-int exynos_mmc_init(const void *blob); - #endif diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 3391228522c..96228a86a11 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -249,44 +249,6 @@ int board_eth_init(bd_t *bis) return 0; }
-#ifdef CONFIG_MMC -static int init_mmc(void) -{ -#ifdef CONFIG_MMC_SDHCI - return exynos_mmc_init(gd->fdt_blob); -#else - return 0; -#endif -} - -static int init_dwmmc(void) -{ -#ifdef CONFIG_MMC_DW - return exynos_dwmmc_init(gd->fdt_blob); -#else - return 0; -#endif -} - -int board_mmc_init(bd_t *bis) -{ - int ret; - - if (get_boot_mode() == BOOT_MODE_SD) { - ret = init_mmc(); - ret |= init_dwmmc(); - } else { - ret = init_dwmmc(); - ret |= init_mmc(); - } - - if (ret) - debug("mmc init failed\n"); - - return ret; -} -#endif - #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 591a3bce084..9dd0b865eb8 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -118,9 +118,6 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width) return s5p_sdhci_core_init(host); }
-#if CONFIG_IS_ENABLED(OF_CONTROL) -struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS]; - static int do_sdhci_init(struct sdhci_host *host) { int dev_id, flag, ret; @@ -191,53 +188,6 @@ static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) return 0; }
-static int process_nodes(const void *blob, int node_list[], int count) -{ - struct sdhci_host *host; - int i, node, ret; - int failed = 0; - - debug("%s: count = %d\n", __func__, count); - - /* build sdhci_host[] for each controller */ - for (i = 0; i < count; i++) { - node = node_list[i]; - if (node <= 0) - continue; - - host = &sdhci_host[i]; - - ret = sdhci_get_config(blob, node, host); - if (ret) { - printf("%s: failed to decode dev %d (%d)\n", __func__, i, ret); - failed++; - continue; - } - - ret = do_sdhci_init(host); - if (ret && ret != -ENODEV) { - printf("%s: failed to initialize dev %d (%d)\n", __func__, i, ret); - failed++; - } - } - - /* we only consider it an error when all nodes fail */ - return (failed == count ? -1 : 0); -} - -int exynos_mmc_init(const void *blob) -{ - int count; - int node_list[SDHCI_MAX_HOSTS]; - - count = fdtdec_find_aliases_for_id(blob, "mmc", - COMPAT_SAMSUNG_EXYNOS_MMC, node_list, - SDHCI_MAX_HOSTS); - - return process_nodes(blob, node_list, count); -} -#endif - #ifdef CONFIG_DM_MMC static int s5p_sdhci_probe(struct udevice *dev) {
Changes in v2: None
-#else
-#endif -}
-#else
-#endif -}
- int ret;
ret = init_mmc();
- } else {
ret = init_dwmmc();
ret |= init_mmc();
- if (ret)
- return ret;
-} -#endif
- int i, node, ret;
- int failed = 0;
if (node <= 0)
continue;
if (ret) {
failed++;
continue;
failed++;
- int count;
SDHCI_MAX_HOSTS);
-} -#endif
Lukasz Majewski
This enum still exists but we can shrink it a little based on recent driver-model conversions with samsung. Update it to remove unused items.
Changes in v2: None
include/fdtdec.h | 6 ------ lib/fdtdec.c | 6 ------ 2 files changed, 12 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index f1bcbf837ff..de7dd63b5a4 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -133,18 +133,12 @@ enum fdt_compat_id { /* Tegra210 XUSB pad controller */ COMPAT_SMSC_LAN9215, /* SMSC 10/100 Ethernet LAN9215 */ COMPAT_SAMSUNG_EXYNOS5_SROMC, /* Exynos5 SROMC */ - COMPAT_SAMSUNG_S3C2440_I2C, /* Exynos I2C Controller */ - COMPAT_SAMSUNG_EXYNOS5_SOUND, /* Exynos Sound */ - COMPAT_WOLFSON_WM8994_CODEC, /* Wolfson WM8994 Sound Codec */ COMPAT_SAMSUNG_EXYNOS_USB_PHY, /* Exynos phy controller for usb2.0 */ COMPAT_SAMSUNG_EXYNOS5_USB3_PHY,/* Exynos phy controller for usb3.0 */ COMPAT_SAMSUNG_EXYNOS_TMU, /* Exynos TMU */ COMPAT_SAMSUNG_EXYNOS_MIPI_DSI, /* Exynos mipi dsi */ COMPAT_SAMSUNG_EXYNOS_DWMMC, /* Exynos DWMMC controller */ - COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ - COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */ - COMPAT_SAMSUNG_EXYNOS5_I2C, /* Exynos5 High Speed I2C Controller */ COMPAT_SAMSUNG_EXYNOS_SYSMMU, /* Exynos sysmmu */ COMPAT_INTEL_MICROCODE, /* Intel microcode update */ COMPAT_AMS_AS3722, /* AMS AS3722 PMIC */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 6f8ec0dbed7..18b8bf81955 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -40,18 +40,12 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(NVIDIA_TEGRA210_XUSB_PADCTL, "nvidia,tegra210-xusb-padctl"), COMPAT(SMSC_LAN9215, "smsc,lan9215"), COMPAT(SAMSUNG_EXYNOS5_SROMC, "samsung,exynos-sromc"), - COMPAT(SAMSUNG_S3C2440_I2C, "samsung,s3c2440-i2c"), - COMPAT(SAMSUNG_EXYNOS5_SOUND, "samsung,exynos-sound"), - COMPAT(WOLFSON_WM8994_CODEC, "wolfson,wm8994-codec"), COMPAT(SAMSUNG_EXYNOS_USB_PHY, "samsung,exynos-usb-phy"), COMPAT(SAMSUNG_EXYNOS5_USB3_PHY, "samsung,exynos5250-usb3-phy"), COMPAT(SAMSUNG_EXYNOS_TMU, "samsung,exynos-tmu"), COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS_DWMMC, "samsung,exynos-dwmmc"), - COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), - COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"), - COMPAT(SAMSUNG_EXYNOS5_I2C, "samsung,exynos5-hsi2c"), COMPAT(SAMSUNG_EXYNOS_SYSMMU, "samsung,sysmmu-v3.3"), COMPAT(INTEL_MICROCODE, "intel,microcode"), COMPAT(AMS_AS3722, "ams,as3722"),
Changes in v2: None
Lukasz Majewski
This is no-longer used. Drop it.
Changes in v2: - Add new patches as per the cover letter
include/fdtdec.h | 1 - lib/fdtdec.c | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index de7dd63b5a4..2a8ad960260 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -141,7 +141,6 @@ enum fdt_compat_id { COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_SAMSUNG_EXYNOS_SYSMMU, /* Exynos sysmmu */ COMPAT_INTEL_MICROCODE, /* Intel microcode update */ - COMPAT_AMS_AS3722, /* AMS AS3722 PMIC */ COMPAT_INTEL_QRK_MRC, /* Intel Quark MRC */ COMPAT_ALTERA_SOCFPGA_DWMAC, /* SoCFPGA Ethernet controller */ COMPAT_ALTERA_SOCFPGA_DWMMC, /* SoCFPGA DWMMC controller */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 18b8bf81955..e06f2282028 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -48,7 +48,6 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(SAMSUNG_EXYNOS_SYSMMU, "samsung,sysmmu-v3.3"), COMPAT(INTEL_MICROCODE, "intel,microcode"), - COMPAT(AMS_AS3722, "ams,as3722"), COMPAT(INTEL_QRK_MRC, "intel,quark-mrc"), COMPAT(ALTERA_SOCFPGA_DWMAC, "altr,socfpga-stmmac"), COMPAT(ALTERA_SOCFPGA_DWMMC, "altr,socfpga-dw-mshc"),
Changes in v2:
Lukasz Majewski
Dear Simon Glass,
Changes in v2:
Do you want a pick patches up to your tree?
Thanks, Minkyu Kang.
Hi Minkyu,
On Thu, 20 Dec 2018 at 17:40, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Simon Glass,
Changes in v2:
I am happy to do that if you prefer, but please let me know.
Hi Minkyu,
On Fri, 21 Dec 2018 at 10:35, Simon Glass sjg@chromium.org wrote:
Hi Minkyu,
Dear Simon Glass,
Changes in v2:
Shall I go ahead and do this? The merge window is open now.
On 17/01/19 06:42, Simon Glass wrote:
Hi Minkyu,
Hi Minkyu,
Dear Simon Glass,
Changes in v2:
Yes, please. I delegate this patchset to you.
Lukasz Majewski
Minkyu Kang
