[U-Boot] [Patch ARM/AT91] remove __attribute__ ((packed)) in at91 headers
* remove __attribute__ ((packed)) to prevent byte access to soc registers in some gcc version
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de ---
see http://lists.denx.de/pipermail/u-boot/2010-December/084076.html arch/arm/include/asm/arch-at91/at91_mc.h | 10 +++++----- arch/arm/include/asm/arch-at91/at91_st.h | 2 +- arch/arm/include/asm/arch-at91/at91_tc.h | 4 ++-- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91_mc.h b/arch/arm/include/asm/arch-at91/at91_mc.h index acfbd10..09453a9 100644 --- a/arch/arm/include/asm/arch-at91/at91_mc.h +++ b/arch/arm/include/asm/arch-at91/at91_mc.h @@ -36,7 +36,7 @@ typedef struct at91_ebi { u32 csa; /* 0x00 Chip Select Assignment Register */ u32 cfgr; /* 0x04 Configuration Register */ u32 reserved[2]; -} __attribute__ ((packed)) at91_ebi_t; +} at91_ebi_t;
#define AT91_EBI_CSA_CS0A 0x0001 #define AT91_EBI_CSA_CS1A 0x0002 @@ -55,11 +55,11 @@ typedef struct at91_sdramc { u32 imr; /* 0x1C SDRAMC Interrupt Mask Register */ u32 icr; /* 0x20 SDRAMC Interrupt Status Register */ u32 reserved[3]; -} __attribute__ ((packed)) at91_sdramc_t; +} at91_sdramc_t;
typedef struct at91_smc { u32 csr[8]; /* 0x00 SDRAMC Mode Register */ -} __attribute__ ((packed)) at91_smc_t; +} at91_smc_t;
#define AT91_SMC_CSR_RWHOLD(x) ((x & 0x7) << 28) #define AT91_SMC_CSR_RWSETUP(x) ((x & 0x7) << 24) @@ -78,7 +78,7 @@ typedef struct at91_smc {
typedef struct at91_bfc { u32 mr; /* 0x00 SDRAMC Mode Register */ -} __attribute__ ((packed)) at91_bfc_t; +} at91_bfc_t;
typedef struct at91_mc { u32 rcr; /* 0x00 MC Remap Control Register */ @@ -91,7 +91,7 @@ typedef struct at91_mc { at91_sdramc_t sdramc; /* 0x90 - 0xBC SDRAMC User Interface */ at91_bfc_t bfc; /* 0xC0 BFC User Interface */ u32 reserved2[15]; -} __attribute__ ((packed)) at91_mc_t; +} at91_mc_t;
#endif #endif diff --git a/arch/arm/include/asm/arch-at91/at91_st.h b/arch/arm/include/asm/arch-at91/at91_st.h index 53f9320..98b0a76 100644 --- a/arch/arm/include/asm/arch-at91/at91_st.h +++ b/arch/arm/include/asm/arch-at91/at91_st.h @@ -35,7 +35,7 @@ typedef struct at91_st { u32 imr; u32 rtar; u32 crtr; -} __attribute__ ((packed)) at91_st_t ; +} at91_st_t ;
#define AT91_ST_CR_WDRST 1
diff --git a/arch/arm/include/asm/arch-at91/at91_tc.h b/arch/arm/include/asm/arch-at91/at91_tc.h index 1e180ad..1eae4e9 100644 --- a/arch/arm/include/asm/arch-at91/at91_tc.h +++ b/arch/arm/include/asm/arch-at91/at91_tc.h @@ -36,7 +36,7 @@ typedef struct at91_tcc { u32 idr; /* 0x28 Interrupt Disable Register */ u32 imr; /* 0x2C Interrupt Mask Register */ u32 reserved3[4]; -} __attribute__ ((packed)) at91_tcc_t; +} at91_tcc_t;
#define AT91_TC_CCR_CLKEN 0x00000001 #define AT91_TC_CCR_CLKDIS 0x00000002 @@ -57,7 +57,7 @@ typedef struct at91_tc { at91_tcc_t tc[3]; /* 0x00 TC Channel 0-2 */ u32 bcr; /* 0xC0 TC Block Control Register */ u32 bmr; /* 0xC4 TC Block Mode Register */ -} __attribute__ ((packed)) at91_tc_t; +} at91_tc_t;
#define AT91_TC_BMR_TC0XC0S_TCLK0 0x00000000 #define AT91_TC_BMR_TC0XC0S_NONE 0x00000001 -- 1.7.1
Dear Jens Scharsig,
- remove __attribute__ ((packed)) to prevent byte access to soc registers in some gcc version
Applied to u-boot-atmel/next.
Thanks,
Reinhard
Jens Scharsig
Reinhard Meyer
