[PATCH] nvmem: u-boot-env: fix crc32 casting type
This fixes: drivers/nvmem/u-boot-env.c:141:17: sparse: sparse: cast to restricted __le32
Reported-by: kernel test robot lkp@intel.com Fixes: f955dc1445069 ("nvmem: add driver handling U-Boot environment variables") Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/nvmem/u-boot-env.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c index 9b9abfb8f187..fb993ef4249f 100644 --- a/drivers/nvmem/u-boot-env.c +++ b/drivers/nvmem/u-boot-env.c @@ -138,7 +138,7 @@ static int u_boot_env_parse(struct u_boot_env *priv) data_offset = offsetof(struct u_boot_env_image_redundant, data); break; } - crc32 = le32_to_cpu(*(uint32_t *)(buf + crc32_offset)); + crc32 = le32_to_cpu(*(__le32 *)(buf + crc32_offset)); crc32_data_len = priv->mtd->size - crc32_data_offset; data_len = priv->mtd->size - data_offset;
Hello Rafał,
- crc32 = le32_to_cpu(*(__le32 *)(buf + crc32_offset));
I had to do a double take to make sure alignment is not violated. It's not, because crc32_offset is always zero.
How about rewriting this as
/* CRC32 is always at offset 0 */ crc32 = le32_to_cpup(buf);
To make the alignment clear to the reader?
Cheers, Ahmad
Ahmad Fatoum
Rafał Miłecki
