Please pull u-boot-marvell/master
Hi Tom,
please pull the 2nd batch of MVEBU related patches in this merge window. The major changes are:
---------------------------------------------------------------- - mvebu bubt cmd: Add A38x support (Joel) - Clearfog: Fix SCSI boot duplication (Joel) - Armada-37xx: Fix DDR PHY clock divider values (Marek) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=5&view=result...
Thanks, Stefan
The following changes since commit bdcb29960e3a9558803632783b922f26993d219e:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq (2020-04-21 15:20:42 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to f60a66ef5d7da1980f180cd1cbfd2ce01157e522:
cmd: mvebu: bubt: show image boot device (2020-04-22 14:28:15 +0200)
---------------------------------------------------------------- Joel Johnson (7): arm: mvebu: clearfog: adjust SCSI boot duplication arm: mvebu: correct SPL boot configs for SPI/MMC cmd: mvebu: bubt: add A38x support cmd: mvebu: bubt: correct U-Boot spelling cmd: mvebu: bubt: verify A38x target device type arm: mvebu: clearfog: enable bubt command cmd: mvebu: bubt: show image boot device
Marek Behún (1): clk: armada-37xx-periph: fix DDR PHY clock divider values
arch/arm/mach-mvebu/Kconfig | 12 +++ cmd/mvebu/bubt.c | 133 +++++++++++++++++++++++++++++++-- configs/clearfog_defconfig | 4 +- configs/controlcenterdc_defconfig | 4 - configs/db-88f6720_defconfig | 4 - configs/db-88f6820-amc_defconfig | 4 - configs/db-88f6820-gp_defconfig | 4 - configs/db-mv784mp-gp_defconfig | 3 - configs/ds414_defconfig | 3 - configs/helios4_defconfig | 1 - configs/maxbcm_defconfig | 3 - configs/theadorable_debug_defconfig | 3 - configs/turris_omnia_defconfig | 4 - configs/x530_defconfig | 4 - drivers/clk/mvebu/armada-37xx-periph.c | 4 +- include/configs/clearfog.h | 7 -- include/configs/helios4.h | 5 -- 17 files changed, 142 insertions(+), 60 deletions(-)
On Wed, Apr 22, 2020 at 04:48:33PM +0200, Stefan Roese wrote:
Hi Tom,
But the following checkpatch should be fixed in a follow up sometime: WARNING: quoted string split across lines #28: FILE: cmd/mvebu/bubt.c:734: + printf("Error: A38x image meant to be " + "booted from "%s", not "%s"!\n",
(There's another but I think the split is fine for how humans would grep for it).
Hi Tom,
"booted from \"%s\", not
"%s"!\n",
Joel, will you please take care of this.
Thanks, Stefan
Hi Tom,
"%s"!\n",
Thanks, Stefan
Yep, I'll get it updated today.
Joel
Joel Johnson
Stefan Roese
