[U-Boot] [PATCH] fdt: remove fdtdec_get_alias_node() function
The fdt_path_offset() checks an alias too.
fdtdec_get_alias_node(blob, "foo") is equivalent to fdt_path_offset(blob, "foo").
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
drivers/serial/serial-uclass.c | 2 +- include/fdtdec.h | 11 ----------- lib/fdtdec.c | 15 --------------- 3 files changed, 1 insertion(+), 27 deletions(-)
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 71f1a5c..28dccfa 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -34,7 +34,7 @@ static void serial_find_console_or_panic(void) /* Check for a chosen console */ node = fdtdec_get_chosen_node(gd->fdt_blob, "stdout-path"); if (node < 0) - node = fdtdec_get_alias_node(gd->fdt_blob, "console"); + node = fdt_path_offset(gd->fdt_blob, "console"); if (!uclass_get_device_by_of_offset(UCLASS_SERIAL, node, &cur_dev)) return;
diff --git a/include/fdtdec.h b/include/fdtdec.h index 4ae77be..6e01cce 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -388,17 +388,6 @@ int fdtdec_get_alias_seq(const void *blob, const char *base, int node, int *seqp);
/** - * Get the offset of the given alias node - * - * This looks up an alias in /aliases then finds the offset of that node. - * - * @param blob Device tree blob (if NULL, then error is returned) - * @param name Alias name, e.g. "console" - * @return Node offset referred to by that alias, or -ve FDT_ERR_... - */ -int fdtdec_get_alias_node(const void *blob, const char *name); - -/** * Get the offset of the given chosen node * * This looks up a property in /chosen containing the path to another node, diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 9714620..2c9d694 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -368,21 +368,6 @@ int fdtdec_get_alias_seq(const void *blob, const char *base, int offset, return -ENOENT; }
-int fdtdec_get_alias_node(const void *blob, const char *name) -{ - const char *prop; - int alias_node; - int len; - - if (!blob) - return -FDT_ERR_NOTFOUND; - alias_node = fdt_path_offset(blob, "/aliases"); - prop = fdt_getprop(blob, alias_node, name, &len); - if (!prop) - return -FDT_ERR_NOTFOUND; - return fdt_path_offset(blob, prop); -} - int fdtdec_get_chosen_node(const void *blob, const char *name) { const char *prop;
On 21 November 2014 at 03:47, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Thanks!
Hi Masahiro,
Thanks!
Applied to u-boot-fdt, thanks!
In case you are interested, these was added and removed before:
added: b5220bc fdt: add decode helper library removed: 0087847 fdt: Remove fdtdec_find_alias_node() function added: 3234aa4 fdt: Add a function to get the node offset of an alias
All three commits were written by me. Given that track record I will be due to add it again in 2016.
Hi Simon,
On Thu, 27 Nov 2014 09:22:10 -0700 Simon Glass sjg@chromium.org wrote:
Hi Masahiro,
Thanks!
Oh dear, and then I will be due to remove it again in 2018.
Best Regards Masahiro Yamada
Masahiro Yamada
