[U-Boot] [PATCH 0/4] ARM: uniphier: eMMC boot support
Masahiro Yamada (4): ARM: uniphier: add eMMC boot support ARM: uniphier: add a command to find the first MMC (non-SD) device ARM: uniphier: add emmcupdate command ARM: uniphier: default to environment in eMMC
arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 12 +++++ arch/arm/dts/uniphier-proxstream2-gentil.dts | 12 +++++ arch/arm/dts/uniphier-proxstream2-vodka.dts | 12 +++++ arch/arm/mach-uniphier/boot-mode/boot-mode.c | 66 ++++++++++++++++++++++++++++ doc/README.uniphier | 14 ++++++ include/configs/uniphier.h | 22 +++++++--- 6 files changed, 132 insertions(+), 6 deletions(-)
Export device nodes needed for eMMC boot (eMMC node, pinctrl, and clock) to the SPL DTB. CONFIG_SUPPORT_EMMC_BOOT is also necessary to use "mmc partconf" command.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 12 ++++++++++++ arch/arm/dts/uniphier-proxstream2-gentil.dts | 12 ++++++++++++ arch/arm/dts/uniphier-proxstream2-vodka.dts | 12 ++++++++++++ arch/arm/mach-uniphier/boot-mode/boot-mode.c | 25 +++++++++++++++++++++++++ include/configs/uniphier.h | 3 +++ 5 files changed, 64 insertions(+)
diff --git a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts index 1ca1042..82e2bd0 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts @@ -95,6 +95,14 @@ u-boot,dm-pre-reloc; };
+&mio { + u-boot,dm-pre-reloc; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + &pinctrl { u-boot,dm-pre-reloc; }; @@ -102,3 +110,7 @@ &pinctrl_uart0 { u-boot,dm-pre-reloc; }; + +&pinctrl_emmc { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/uniphier-proxstream2-gentil.dts b/arch/arm/dts/uniphier-proxstream2-gentil.dts index c3551fe..eb1d2bc 100644 --- a/arch/arm/dts/uniphier-proxstream2-gentil.dts +++ b/arch/arm/dts/uniphier-proxstream2-gentil.dts @@ -75,6 +75,14 @@ u-boot,dm-pre-reloc; };
+&mio { + u-boot,dm-pre-reloc; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + &pinctrl { u-boot,dm-pre-reloc; }; @@ -82,3 +90,7 @@ &pinctrl_uart2 { u-boot,dm-pre-reloc; }; + +&pinctrl_emmc { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/uniphier-proxstream2-vodka.dts b/arch/arm/dts/uniphier-proxstream2-vodka.dts index d61e0b6..e7d5db8 100644 --- a/arch/arm/dts/uniphier-proxstream2-vodka.dts +++ b/arch/arm/dts/uniphier-proxstream2-vodka.dts @@ -60,6 +60,14 @@ u-boot,dm-pre-reloc; };
+&mio { + u-boot,dm-pre-reloc; +}; + +&emmc { + u-boot,dm-pre-reloc; +}; + &pinctrl { u-boot,dm-pre-reloc; }; @@ -67,3 +75,7 @@ &pinctrl_uart2 { u-boot,dm-pre-reloc; }; + +&pinctrl_emmc { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index 935e551..2f2e45d 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <mmc.h> #include <spl.h>
#include "../sbc/sbc-regs.h" @@ -52,3 +53,27 @@ u32 spl_boot_device(void)
return ret == BOOT_DEVICE_USB ? BOOT_DEVICE_NOR : ret; } + +u32 spl_boot_mode(void) +{ + struct mmc *mmc; + + /* + * work around a bug in the Boot ROM of PH1-sLD3, LD4, Pro4, and sLD8: + * + * The boot ROM in these SoCs breaks the PARTITION_CONFIG [179] of + * Extended CSD register; when switching to the Boot Partition 1, the + * Boot ROM should issue the SWITCH command (CMD6) with Set Bits for + * the Access Bits, but in fact it uses Write Byte for the Access Bits. + * As a result, the BOOT_PARTITION_ENABLE field of the PARTITION_CONFIG + * is lost. This bug was fixed for PH1-Pro5 and later SoCs. + * + * Fixup mmc->part_config here because it is used to determine the + * partition which the U-Boot image is read from. + */ + mmc = find_mmc_device(0); + mmc->part_config &= ~EXT_CSD_BOOT_PART_NUM(PART_ACCESS_MASK); + mmc->part_config |= EXT_CSD_BOOT_PARTITION_ENABLE; + + return MMCSD_MODE_EMMCBOOT; +} diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 9d14155..19dbfbb 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -148,6 +148,7 @@
/* SD/MMC */ #define CONFIG_CMD_MMC +#define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_GENERIC_MMC
/* memtest works on */ @@ -263,6 +264,7 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT
#define CONFIG_SPL_LIBCOMMON_SUPPORT /* for mem_malloc_init */ #define CONFIG_SPL_LIBGENERIC_SUPPORT @@ -270,6 +272,7 @@ #define CONFIG_SPL_BOARD_INIT
#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x10000 +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x80
#define CONFIG_SPL_MAX_FOOTPRINT 0x10000
UniPhier SoC family supports both (e)MMC boot and SD card boot; however, both of them are handled in the same uclass.
When booting from the eMMC, we want to know the device number of the (e)MMC, not SD. This command is useful to find the first MMC (non-SD) device.
arch/arm/mach-uniphier/boot-mode/boot-mode.c | 36 ++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index 2f2e45d..481e209 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -7,6 +7,7 @@ #include <common.h> #include <mmc.h> #include <spl.h> +#include <linux/err.h>
#include "../sbc/sbc-regs.h" #include "../soc-info.h" @@ -77,3 +78,38 @@ u32 spl_boot_mode(void)
return MMCSD_MODE_EMMCBOOT; } + +#ifdef CONFIG_DM_MMC +static int find_first_mmc_device(void) +{ + struct mmc *mmc; + int i; + + for (i = 0; (mmc = find_mmc_device(i)); i++) { + if (!mmc_init(mmc) && IS_MMC(mmc)) + return i; + } + + return -ENODEV; +} + +#ifndef CONFIG_SPL_BUILD +static int do_mmcsetn(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int dev; + + dev = find_first_mmc_device(); + if (dev < 0) + return CMD_RET_FAILURE; + + setenv_ulong("mmc_first_dev", dev); + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + mmcsetn, 1, 1, do_mmcsetn, + "Set the first MMC (not SD) dev number to "mmc_first_dev" enviroment", + "" +); +#endif +#endif
The Boot ROM expects the boot image (SPL) in the Boot Partition 1. So, updating images involves the hardware partition switch. It might be a bit advanced for some users.
To be user-friendly, this commit adds a useful command to update the images; just put SPL and U-Boot proper into the public directory of the TFTP server and execute "run emmcupdate" from the command line.
doc/README.uniphier | 14 ++++++++++++++ include/configs/uniphier.h | 7 +++++++ 2 files changed, 21 insertions(+)
diff --git a/doc/README.uniphier b/doc/README.uniphier index 7cfff97..47b4d78 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -78,6 +78,20 @@ directory, and then run the following command at the U-Boot command line: => run nandupdate
+Burn U-Boot images to eMMC +-------------------------- + +Write two files to the Boot partition 1 of the eMMC device as follows: + - spl/u-boot-spl.bin at the offset address 0x00000000 + - u-boot.img at the offset address 0x00010000 + +If a TFTP server is available, the images can be easily updated. +Just copy the u-boot-spl-dtb.bin and u-boot-dtb.img to the TFTP public +directory, and then run the following command at the U-Boot command line: + + => run emmcupdate + + UniPhier specific commands --------------------------
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 19dbfbb..1b28cdc 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -233,6 +233,13 @@ "netdev=eth0\0" \ "verify=n\0" \ "nor_base=0x42000000\0" \ + "emmcupdate=mmcsetn &&" \ + "mmc partconf $mmc_first_dev 0 1 1 &&" \ + "mmc erase 0 800 &&" \ + "tftpboot u-boot-spl.bin &&" \ + "mmc write $loadaddr 0 80 &&" \ + "tftpboot u-boot.img &&" \ + "mmc write $loadaddr 80 780\0" \ "nandupdate=nand erase 0 0x00100000 &&" \ "tftpboot u-boot-spl.bin &&" \ "nand write $loadaddr 0 0x00010000 &&" \
Of the several boot devices supported, it looks like the eMMC is the most commonly used. Enable CONFIG_ENV_IS_IN_MMC by default.
arch/arm/mach-uniphier/boot-mode/boot-mode.c | 5 +++++ include/configs/uniphier.h | 12 ++++++------ 2 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-uniphier/boot-mode/boot-mode.c b/arch/arm/mach-uniphier/boot-mode/boot-mode.c index 481e209..d5ef10a 100644 --- a/arch/arm/mach-uniphier/boot-mode/boot-mode.c +++ b/arch/arm/mach-uniphier/boot-mode/boot-mode.c @@ -93,6 +93,11 @@ static int find_first_mmc_device(void) return -ENODEV; }
+int mmc_get_env_dev(void) +{ + return find_first_mmc_device(); +} + #ifndef CONFIG_SPL_BUILD static int do_mmcsetn(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 1b28cdc..b1c8ccb 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -99,16 +99,16 @@
#define CONFIG_CONS_INDEX 1
-/* - * For NAND booting the environment is embedded in the U-Boot image. Please take - * look at the file board/amcc/canyonlands/u-boot-nand.lds for details. - */ +/* #define CONFIG_ENV_IS_NOWHERE */ /* #define CONFIG_ENV_IS_IN_NAND */ -#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET 0x80000 #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET 0x0 /* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */
+#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 1 + /* Time clock 1MHz */ #define CONFIG_SYS_TIMER_RATE 1000000
2016-02-16 17:08 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series, applied to u-boot-uniphier.
Masahiro Yamada
