[U-Boot] [PATCH] fw_env.h: include autoconf.h
From: Max Krummenacher max.krummenacher@toradex.com
Without this, when CONFIG_ENV_VARS_UBOOT_CONFIG is active we get a compile time error when doing 'make env'. In file included from tools/env/fw_env.c:117:0: include/env_default.h:110:11: error: expected ‘}’ before ‘CONFIG_SYS_ARCH’
When building U-Boot this is included indirectly by the compiler switch -include /home/trdx/git.toradex.com/u-boot-2014.10-toradex/include/linux/kconfig.h
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- This is an issue on all tegra boards due CONFIG_ENV_VARS_UBOOT_CONFIG being defined in the tegra-common.h header file.
I already did reported this once last November but did not get any useful insights back then:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/200702
tools/env/fw_env.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/env/fw_env.h b/tools/env/fw_env.h index aff471b..d6faf34 100644 --- a/tools/env/fw_env.h +++ b/tools/env/fw_env.h @@ -13,6 +13,7 @@ #else #include <config.h> #endif +#include <generated/autoconf.h>
/* * To build the utility with the static configuration
Ug. I'm cc'ing a few distro people since this makes it further clear that by whatever name a distro packages fw_setenv/fw_getenv these are really machine (to the extent U-Boot is built) specific applications due to the need to include a copy of the default environment so that we can support making sure that variables that aren't supposed to be overwritten are not overwritten (see the fw_getdefenv call in tools/env/fw_env.c::fw_env_write).
I'll let Masahiro comment on if this is the best way to fix the compile problem.
Hi Tom, Marcel,
Sorry for my late reply. I missed this message.
2015-04-17 2:20 GMT+09:00 Tom Rini trini@konsulko.com:
I've just recalled this issue. In fact, it was reported by another person and I posted a patch last November (but it's been dismissed long and I also finally forgot about it...)
http://patchwork.ozlabs.org/patch/417192/
I do not like host applications to include such machine-specific stuff. Maybe, we should rewrite this tool as a generic host-program + a separate machine environment file.
Anyway, we should have not left a build error long, so thanks for fixing it!
Marcel Ziswiler
Masahiro Yamada
