[PATCH next] power: rk8xx: fix display name for RK808
Commit 2ce40542e0eb ("power: rk8xx: properly print all supported PMICs name") fixed all PMICs name that were broken but broke the only one that was not broken already: RK808. This one is a special case because the ID registers are marked as reserved and always return 0, so the variant cannot be derived the same way it is done for other PMICs from Rockchip.
Fixes: 2ce40542e0eb ("power: rk8xx: properly print all supported PMICs name") Signed-off-by: Quentin Schulz quentin.schulz@cherry.de --- Tested on RK3399 Puma. --- drivers/power/pmic/rk8xx.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 617bb511e4e..4d5a5ceafad 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -281,6 +281,8 @@ static int rk8xx_probe(struct udevice *dev) show_variant = bitfield_extract_by_mask(priv->variant, RK8XX_ID_MSK); switch (priv->variant) { case RK808_ID: + /* RK808 ID is 0x0000, so fix show_variant for that PMIC */ + show_variant = 0x808; break; case RK805_ID: case RK816_ID:
--- base-commit: e242cd95130b64cf91692da41363ac59b25fc08d change-id: 20240617-rk808-show-variant-2121df41caf7
Looking good to me, but I'd still suggest [1] that reading the MSB/LSB ID registers (i.e. 0x17 and 0x18) is skipped on the RK808 altogether, because the RK808 datasheet lists those two registers as reserved and provides no methods for determining the chip name.
Reviewed-by: Dragan Simic dsimic@manjaro.org
[1] https://lore.kernel.org/u-boot/7ef07d9b9b8a1b9064eb506c96ca8213@manjaro.org/
break; case RK805_ID: case RK816_ID:show_variant = 0x808;
Hi Dragan,
Rockchip themselves do this, c.f.:
https://github.com/rockchip-linux/u-boot/blob/next-dev/drivers/power/pmic/rk...
I won't send a patch for this, but feel free to send one if you feel like this is really important.
Thanks!
Quentin
Hello Quentin,
I see, thanks for the reference.
I'll make a note to implement and send a patch later, after the dust settles on this. I think that the additional correctness warrants such a patch.
Dragan Simic
Quentin Schulz
Quentin Schulz
