Hello, I am trying to undertsnad the multiple serial configuration/usage in u-boot. in dochttp://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=tree;f=doc;hb=42d44f631c4e8e5359775bdc098f2fffde4e5c05/ README.serial_multihttp://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=blob_plain;f=doc/README.serial_multi;hb=42d44f631c4e8e5359775bdc098f2fffde4e5c05 it is said: " * 1* The support for multiple serial interfaces as implemented is mainly 2http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=blob;f=doc/README.serial_multi;h=ad61d4261b66a00564c741db0176ca51ecece408;hb=42d44f631c4e8e5359775bdc098f2fffde4e5c05#l2intended to allow for modem dial-in / dial-out while still being able 3http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=blob;f=doc/README.serial_multi;h=ad61d4261b66a00564c741db0176ca51ecece408;hb=42d44f631c4e8e5359775bdc098f2fffde4e5c05#l3to use a serial console on a (different) serial port. " I am not sure I undertand what is ment in the words "modem dial-in / dial-out". What is actually the benefit of using multiple serial (#define CONFIG_MULTI_SERIAL) instead of using direcet call to ns15669 driver (for the UART'S which are not the console). If we have a case where there is only one same UART which is the console, is there any benefit of multiple serial ?
Best Regards,
Ran
The benefit is that you can easy switch the console setting the stdout/stdin variables in u-boot.
Best regards, Stefano Babic
Ran Shalit
Stefano Babic
