[U-Boot] [PATCH] pcmcia: Drop a bunch of unused CONFIG_SYS_PCMCIA_ macros
Last users of the following macros (for n = 0..7) were removed in commit 5b8e76c35ec312a ("powerpc, 8xx: remove support for 8xx"):
CONFIG_SYS_PCMCIA_PBRn CONFIG_SYS_PCMCIA_PORn
Signed-off-by: Tuomas Tynkkynen tuomas@tuxera.com --- include/pcmcia.h | 109 ------------------------------------------- scripts/config_whitelist.txt | 16 ------- 2 files changed, 125 deletions(-)
diff --git a/include/pcmcia.h b/include/pcmcia.h index 94b54c210d..8df90ee2b7 100644 --- a/include/pcmcia.h +++ b/include/pcmcia.h @@ -60,115 +60,6 @@ typedef struct { ulong or; } pcmcia_win_t;
-/* - * Definitions for PCMCIA control registers to operate in IDE mode - * - * All timing related setup (PCMCIA_SHT, PCMCIA_SST, PCMCIA_SL) - * to be done later (depending on CPU clock) - */ - -/* Window 0: - * Base: 0xFE100000 CS1 - * Port Size: 2 Bytes - * Port Size: 16 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR0 0xFE100000 -#define CONFIG_SYS_PCMCIA_POR0 ( PCMCIA_BSIZE_2 \ - | PCMCIA_PPS_16 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 1: - * Base: 0xFE100080 CS1 - * Port Size: 8 Bytes - * Port Size: 8 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR1 0xFE100080 -#define CONFIG_SYS_PCMCIA_POR1 ( PCMCIA_BSIZE_8 \ - | PCMCIA_PPS_8 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 2: - * Base: 0xFE100100 CS2 - * Port Size: 8 Bytes - * Port Size: 8 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR2 0xFE100100 -#define CONFIG_SYS_PCMCIA_POR2 ( PCMCIA_BSIZE_8 \ - | PCMCIA_PPS_8 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 3: - * not used - */ -#define CONFIG_SYS_PCMCIA_PBR3 0 -#define CONFIG_SYS_PCMCIA_POR3 0 - -/* Window 4: - * Base: 0xFE100C00 CS1 - * Port Size: 2 Bytes - * Port Size: 16 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR4 0xFE100C00 -#define CONFIG_SYS_PCMCIA_POR4 ( PCMCIA_BSIZE_2 \ - | PCMCIA_PPS_16 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 5: - * Base: 0xFE100C80 CS1 - * Port Size: 8 Bytes - * Port Size: 8 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR5 0xFE100C80 -#define CONFIG_SYS_PCMCIA_POR5 ( PCMCIA_BSIZE_8 \ - | PCMCIA_PPS_8 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 6: - * Base: 0xFE100D00 CS2 - * Port Size: 8 Bytes - * Port Size: 8 Bit - * Common Memory Space - */ - -#define CONFIG_SYS_PCMCIA_PBR6 0xFE100D00 -#define CONFIG_SYS_PCMCIA_POR6 ( PCMCIA_BSIZE_8 \ - | PCMCIA_PPS_8 \ - | PCMCIA_PRS_MEM \ - | PCMCIA_SLOT_x \ - | PCMCIA_PV \ - ) - -/* Window 7: - * not used - */ -#define CONFIG_SYS_PCMCIA_PBR7 0 -#define CONFIG_SYS_PCMCIA_POR7 0 - /**********************************************************************/
/* diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 22dc663cda..a3cc86c16f 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4157,22 +4157,6 @@ CONFIG_SYS_PCMCIA_ATTR_BASE CONFIG_SYS_PCMCIA_IO_BASE CONFIG_SYS_PCMCIA_MEM_ADDR CONFIG_SYS_PCMCIA_MEM_SIZE -CONFIG_SYS_PCMCIA_PBR0 -CONFIG_SYS_PCMCIA_PBR1 -CONFIG_SYS_PCMCIA_PBR2 -CONFIG_SYS_PCMCIA_PBR3 -CONFIG_SYS_PCMCIA_PBR4 -CONFIG_SYS_PCMCIA_PBR5 -CONFIG_SYS_PCMCIA_PBR6 -CONFIG_SYS_PCMCIA_PBR7 -CONFIG_SYS_PCMCIA_POR0 -CONFIG_SYS_PCMCIA_POR1 -CONFIG_SYS_PCMCIA_POR2 -CONFIG_SYS_PCMCIA_POR3 -CONFIG_SYS_PCMCIA_POR4 -CONFIG_SYS_PCMCIA_POR5 -CONFIG_SYS_PCMCIA_POR6 -CONFIG_SYS_PCMCIA_POR7 CONFIG_SYS_PDCNT CONFIG_SYS_PEHLPAR CONFIG_SYS_PEPAR
Tuomas Tynkkynen
