[U-Boot] Pull request: u-boot-arm/master
Hello Tom (and sorry for the duplicate),
The following changes since commit 10dc77716f41979e03baf3b847b97dc7279ef30d:
esdhc/usdhc: Fix warning when CONFIG_SYS_FSL_ESDHC_USE_PIO is not set (2014-05-23 09:19:05 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 33144ea443c298ac9d6f04926a02881a5bae91a3:
Merge branch 'u-boot-ti/master' into 'u-boot-arm/master' (2014-05-24 09:50:00 +0200)
Albert ARIBAUD (3): Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master' Merge branch 'u-boot-sh/rmobile' into 'u-boot-arm/master' Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'
Ash Charles (9): omap: overo: allow the use of a plain text env file instead boot scripts OMAP3: overo: add command support for mtd and ubi OMAP3: overo: eliminate hard-coded partition offsets arm: omap3: Fix omap3_overo SPL boot hangup Add Board Revision for Wireless chip OMAP3: overo: add some Gumstix expansion boards Allow overo to boot with device tree omap3: overo: Use common configurations for Overo omap4: duovero: Add Gumstix DuoVero machine.
Dmitry Lifshitz (3): cm-t54: add cm-t54 board support cm-t54: add EEPROM support and MAC address handling cm-t54: add environment partition runtime detection
Heiko Schocher (1): arm, am33xx: Enable CONFIG_SYS_GENERIC_BOARD for siemens boards
Igor Grinberg (1): compulab: eeprom: add default eeprom address
Ilya Ledvich (1): compulab: eeprom: enable any i2c driver
Keerthy (1): ARM: DRA72x: volt: Update the pmic offsets
Lokesh Vutla (5): ARM: DRA72x: Add Silicon ID support ARM: DRA72x: clocks: Update the hwdata ARM: DRA72x: Update EMIF data ARM: DRA7xx: ctrl: Fix efuse register addresses ARM: OMAP: Fix omap_sdram_size calculation
Masahiro Yamada (7): zynq: add empty xil_io.h to avoid compile error zynq: treat ps7_init.c/h as external files to ignore them build: support a new image u-boot-dtb.img zynq: load u-boot-dtb.img if CONFIG_OF_SEPARATE is defined zynq: import zynq-7000.dtsi from Linux Kernel zynq: add memory nodes to device tree to initialize DRAM with OF zynq: add UART nodes to device tree to initialize UART with OF
Michal Simek (12): ARM: zynq: Fix sparse warnings in slcr.c ARM: zynq: Fix sparse warning in ddrc.c ARM: zynq: Remove sparse warnings ARM: zynq: Do not use half memory size for ECC case ARM: zynq: Call zynq board_init() in SPL ARM: zynq: slcr: Fix incorrect commentary ARM: zynq: Setup correct slcr_lock value ARM: zynq: Fix building SPL without FPGA support ARM: zynq: Extend kernel image size to 60MB ARM: zynq: Add MIO detection code ARM: zynq: ehci: Added USB host driver support ARM: zynq: Extend maximum number of command arguments
Mike Looijmans (1): ARM: zynq: Fix bootmode mask
Nobuhiro Iwamatsu (20): arm: rmobile: Add define of SCIF register for R8A7790 and R8A7791 arm: rmobile: koelsch: Remove define of SCIF register arm: rmobile: koelsch: Remove CONFIG_USE_ARCH_MEMSET and MEMCPY arm: rmobile: koelsch: Enable optimization of thumb arm: rmobile: lager: Remove define of SCIF register arm: rmobile: lager: Remove CONFIG_USE_ARCH_MEMSET and MEMCPY arm: rmobile: lager: Enable optimization of thumb gpio: r8a7791-gpio: Fix typo in macro gpio: r8a7790-gpio: Fix typo in macro arm: rmobile: koelsch: Add support USB controller arm: rmobile: koelsch: Add support command and filesystems of VFAT arm: rmobile: lager: Add support USB controller arm: rmobile: lager: Add support command and filesystems of VFAT arm: rmobile: lager: Add support ext4/fat write command arm: rmobile: koelsch: Add support ext4/fat write command arm: rmobile: r8a7791: Fix MOD_SEL3 function table about FN_SEL_IEB arm: rmobile: koelsch: Fix QoS revision 0.240 and 0.320 arm: rmobile: armadillo800eva: Enable CONFIG_SYS_GENERIC_BOARD arm: rmobile: koelsch: Enable CONFIG_SYS_GENERIC_BOARD arm: rmobile: lager: Enable CONFIG_SYS_GENERIC_BOARD
Peter A. Bigot (1): OMAP3: overo: increase linux partition to 8 MiB
Sergey Alyoshin (1): am33xx: report silicon revision instead of code
Siva Durga Prasad Paladugu (5): ARM: zynq: Added efuse status register base address ARM: zynq: Added USB host support for zynq boards ARM: zynq: Enable the FAT write capability ARM: zynq: Move USB/SD/MMC common FAT configs ARM: zynq: Enable EXT4 configs
Tom Rini (1): armv7:TI: Add <asm/ti-common/sys_proto.h> and migrate omap_hw_init_context
pekon gupta (3): ARM: omap4: add platform specific info for GPMC and ELM controllers ARM: omap5: add platform specific info for GPMC and ELM controllers ARM: omap: merge GPMC initialization code for all platform
Makefile | 8 ++++ arch/arm/cpu/armv7/am33xx/Makefile | 1 - arch/arm/cpu/armv7/am33xx/mem.c | 98 --------------------------------------- arch/arm/cpu/armv7/am33xx/sys_info.c | 41 +++++++++------- arch/arm/cpu/armv7/omap-common/Makefile | 4 -- arch/arm/cpu/armv7/omap-common/emif-common.c | 6 ++- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 15 +++--- arch/arm/cpu/armv7/omap-common/mem-common.c | 117 +++++++++++++++++++++++++++++++++++++++++++--- arch/arm/cpu/armv7/omap3/Makefile | 1 - arch/arm/cpu/armv7/omap5/hw_data.c | 40 ++++++++++++++++ arch/arm/cpu/armv7/omap5/hwinit.c | 3 ++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 8 ++-- arch/arm/cpu/armv7/omap5/sdram.c | 19 +++++++- arch/arm/cpu/armv7/rmobile/pfc-r8a7791.c | 2 +- arch/arm/cpu/armv7/zynq/cpu.c | 13 ++++++ arch/arm/cpu/armv7/zynq/ddrc.c | 5 +- arch/arm/cpu/armv7/zynq/slcr.c | 87 ++++++++++++++++++++++++++++++++-- arch/arm/cpu/armv7/zynq/spl.c | 15 ++++++ arch/arm/dts/zynq-7000.dtsi | 194 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/zynq-microzed.dts | 9 ++++ arch/arm/dts/zynq-zc702.dts | 9 ++++ arch/arm/dts/zynq-zc706.dts | 9 ++++ arch/arm/dts/zynq-zc770-xm010.dts | 9 ++++ arch/arm/dts/zynq-zc770-xm012.dts | 9 ++++ arch/arm/dts/zynq-zc770-xm013.dts | 9 ++++ arch/arm/dts/zynq-zed.dts | 9 ++++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + arch/arm/include/asm/arch-omap3/mem.h | 1 + arch/arm/include/asm/arch-omap4/cpu.h | 5 +- arch/arm/include/asm/arch-omap4/hardware.h | 26 +++++++++++ arch/arm/include/asm/arch-omap4/mem.h | 62 +++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap.h | 3 -- arch/arm/include/asm/arch-omap4/sys_proto.h | 51 +------------------- arch/arm/include/asm/arch-omap5/cpu.h | 5 +- arch/arm/include/asm/arch-omap5/hardware.h | 26 +++++++++++ arch/arm/include/asm/arch-omap5/mem.h | 62 +++++++++++++++++++++++++ arch/arm/include/asm/arch-omap5/omap.h | 9 +--- arch/arm/include/asm/arch-omap5/sys_proto.h | 50 +------------------- arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h | 6 +-- arch/arm/include/asm/arch-rmobile/r8a7791-gpio.h | 6 +-- arch/arm/include/asm/arch-rmobile/r8a7791.h | 1 + arch/arm/include/asm/arch-rmobile/rcar-base.h | 8 ++++ arch/arm/include/asm/arch-zynq/hardware.h | 13 +++++- arch/arm/include/asm/arch-zynq/sys_proto.h | 2 + arch/arm/include/asm/omap_common.h | 7 +-- arch/arm/include/asm/ti-common/sys_proto.h | 72 ++++++++++++++++++++++++++++ board/compulab/cm_t54/Makefile | 10 ++++ board/compulab/cm_t54/cm_t54.c | 262 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/compulab/cm_t54/mux.c | 94 +++++++++++++++++++++++++++++++++++++ board/compulab/cm_t54/spl.c | 66 ++++++++++++++++++++++++++ board/compulab/common/Makefile | 2 +- board/compulab/common/eeprom.c | 5 ++ board/compulab/common/eeprom.h | 2 +- board/gumstix/duovero/Makefile | 8 ++++ board/gumstix/duovero/duovero.c | 264 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/gumstix/duovero/duovero_mux_data.h | 199 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/overo/overo.c | 43 ++++++++++++++++- board/overo/overo.h | 17 +++++++ board/renesas/koelsch/qos.c | 1 + board/xilinx/zynq/.gitignore | 1 + board/xilinx/zynq/Makefile | 5 +- board/xilinx/zynq/board.c | 25 ++++++---- board/xilinx/zynq/ps7_init.c | 12 ----- board/xilinx/zynq/xil_io.h | 13 ++++++ boards.cfg | 2 + drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-zynq.c | 104 +++++++++++++++++++++++++++++++++++++++++ include/configs/armadillo-800eva.h | 1 + include/configs/cm_t54.h | 149 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/duovero.h | 62 +++++++++++++++++++++++++ include/configs/koelsch.h | 23 +++++++-- include/configs/lager.h | 22 +++++++-- include/configs/omap3_overo.h | 296 +++++++++++++++++++++++++++++++++++++------------------------------------------------------------------------------- include/configs/siemens-am33x-common.h | 2 + include/configs/ti_omap4_common.h | 9 ++++ include/configs/zynq-common.h | 52 ++++++++++++++++----- include/configs/zynq_zc70x.h | 1 + include/configs/zynq_zed.h | 1 + 78 files changed, 2383 insertions(+), 527 deletions(-) delete mode 100644 arch/arm/cpu/armv7/am33xx/mem.c create mode 100644 arch/arm/include/asm/arch-omap4/hardware.h create mode 100644 arch/arm/include/asm/arch-omap4/mem.h create mode 100644 arch/arm/include/asm/arch-omap5/hardware.h create mode 100644 arch/arm/include/asm/arch-omap5/mem.h create mode 100644 arch/arm/include/asm/ti-common/sys_proto.h create mode 100644 board/compulab/cm_t54/Makefile create mode 100644 board/compulab/cm_t54/cm_t54.c create mode 100644 board/compulab/cm_t54/mux.c create mode 100644 board/compulab/cm_t54/spl.c create mode 100644 board/gumstix/duovero/Makefile create mode 100644 board/gumstix/duovero/duovero.c create mode 100644 board/gumstix/duovero/duovero_mux_data.h create mode 100644 board/xilinx/zynq/.gitignore delete mode 100644 board/xilinx/zynq/ps7_init.c create mode 100644 board/xilinx/zynq/xil_io.h create mode 100644 drivers/usb/host/ehci-zynq.c create mode 100644 include/configs/cm_t54.h create mode 100644 include/configs/duovero.h
Amicalement,
Albert ARIBAUD
