[PATCH v2 00/16] arm: dts: imx: sync device trees with upstream linux kernel part 2
This series synchronises them imx device trees with the upstream Linux kernel (v6.0-rc1). I split it into two parts. This is part 2.
It also fixes a few issues as discussed during/after the pre-mature application of my first series [1].
I am not touching kontron-sl-mx6ul as Frieder already took care of those [2].
Feedback welcome. Thanks!
[1] https://patchwork.ozlabs.org/project/uboot/cover/20220721132748.1052244-1-ma... [2] https://patchwork.ozlabs.org/project/uboot/cover/20220823142917.306176-1-fri...
Changes in v2: - Add missing imx28-lwe.dtsi as pointed out by Fabio. Thanks!
Marcel Ziswiler (16): imx7ulp: synchronise device tree with linux imx7d: synchronise device tree with linux imx6ul: synchronise device tree with linux imx6ull: synchronise device tree with linux imx6ulz: synchronise device tree with linux imx6sx: synchronise device tree with linux imx6sll: synchronise device tree with linux imx6sl: synchronise device tree with linux imx6qp: synchronise device tree with linux imx6qdl: synchronise device tree with linux imx53: synchronise device tree with linux imx51: synchronise device tree with linux imx28: synchronise device tree with linux imx23: synchronise device tree with linux tbs2910: revert prepare to synchronise device trees with linux imx28: avoid num_cs and spi_max_frequency build errors
arch/arm/dts/imx23-evk.dts | 1 - arch/arm/dts/imx23-pinfunc.h | 8 +- arch/arm/dts/imx23-u-boot.dtsi | 7 +- arch/arm/dts/imx23.dtsi | 2 +- arch/arm/dts/imx28-evk.dts | 2 +- arch/arm/dts/imx28-lwe.dtsi | 170 ++++ arch/arm/dts/imx28-pinfunc.h | 8 +- arch/arm/dts/imx28-xea-u-boot.dtsi | 2 + arch/arm/dts/imx28-xea.dts | 188 ++-- arch/arm/dts/imx28.dtsi | 20 +- arch/arm/dts/imx51.dtsi | 24 +- arch/arm/dts/imx53-cx9020.dts | 414 ++++---- arch/arm/dts/imx53-kp.dts | 2 + arch/arm/dts/imx53-m53menlo.dts | 306 ++++-- arch/arm/dts/imx53-pinfunc.h | 11 +- arch/arm/dts/imx53-ppd.dts | 87 +- arch/arm/dts/imx53-usbarmory.dts | 1 - arch/arm/dts/imx53.dtsi | 39 +- arch/arm/dts/imx6q-sabrelite.dts | 11 +- arch/arm/dts/imx6q-tbs2910-u-boot.dtsi | 4 +- arch/arm/dts/imx6qdl-sabrelite.dtsi | 11 +- arch/arm/dts/imx6qp-sabreauto.dts | 7 +- arch/arm/dts/imx6qp-sabresd.dts | 10 +- arch/arm/dts/imx6qp.dtsi | 3 +- arch/arm/dts/imx6sl-evk.dts | 183 ++-- arch/arm/dts/imx6sl-pinfunc.h | 6 +- arch/arm/dts/imx6sl.dtsi | 362 ++++--- arch/arm/dts/imx6sll-evk.dts | 879 +++++++---------- arch/arm/dts/imx6sll-pinfunc.h | 6 +- arch/arm/dts/imx6sll.dtsi | 445 +++++---- arch/arm/dts/imx6sx-sabreauto.dts | 623 +++++++++--- arch/arm/dts/imx6sx-sdb.dts | 8 +- arch/arm/dts/imx6sx-sdb.dtsi | 56 +- arch/arm/dts/imx6sx-softing-vining-2000.dts | 50 +- arch/arm/dts/imx6sx-udoo-neo.dtsi | 86 +- arch/arm/dts/imx6sx.dtsi | 129 ++- arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ul-phytec-segin.dtsi | 5 - arch/arm/dts/imx6ul.dtsi | 36 +- arch/arm/dts/imx6ull-colibri.dtsi | 10 +- arch/arm/dts/imx6ull.dtsi | 2 +- arch/arm/dts/imx6ulz.dtsi | 1 - arch/arm/dts/imx7ulp-com-u-boot.dtsi | 2 +- arch/arm/dts/imx7ulp-com.dts | 32 +- arch/arm/dts/imx7ulp-evk.dts | 430 ++------- arch/arm/dts/imx7ulp-pinfunc.h | 990 ++++++-------------- arch/arm/dts/imx7ulp.dtsi | 681 +++++--------- arch/arm/dts/mxs-pinfunc.h | 8 +- include/dt-bindings/clock/imx6sl-clock.h | 10 +- include/dt-bindings/clock/imx6sll-clock.h | 16 +- include/dt-bindings/clock/imx7ulp-clock.h | 170 ++-- include/dt-bindings/reset/imx7-reset.h | 1 + 52 files changed, 3197 insertions(+), 3370 deletions(-) create mode 100644 arch/arm/dts/imx28-lwe.dtsi
Synchronise device tree with linux v6.0-rc1.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
arch/arm/dts/imx7ulp-com-u-boot.dtsi | 2 +- arch/arm/dts/imx7ulp-com.dts | 32 +- arch/arm/dts/imx7ulp-evk.dts | 430 ++-------- arch/arm/dts/imx7ulp-pinfunc.h | 990 +++++++--------------- arch/arm/dts/imx7ulp.dtsi | 681 ++++++--------- include/dt-bindings/clock/imx7ulp-clock.h | 170 ++-- 6 files changed, 694 insertions(+), 1611 deletions(-)
diff --git a/arch/arm/dts/imx7ulp-com-u-boot.dtsi b/arch/arm/dts/imx7ulp-com-u-boot.dtsi index d73bfbf7a0..b766c5ef3f 100644 --- a/arch/arm/dts/imx7ulp-com-u-boot.dtsi +++ b/arch/arm/dts/imx7ulp-com-u-boot.dtsi @@ -32,6 +32,6 @@ u-boot,dm-spl; };
-&gpio0 { +&gpio_ptc { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx7ulp-com.dts b/arch/arm/dts/imx7ulp-com.dts index dcfa37441f..d76fea3b35 100644 --- a/arch/arm/dts/imx7ulp-com.dts +++ b/arch/arm/dts/imx7ulp-com.dts @@ -1,12 +1,11 @@ // SPDX-License-Identifier: GPL-2.0 // // Copyright 2019 NXP -// Author: Fabio Estevam fabio.estevam@nxp.com
/dts-v1/;
#include "imx7ulp.dtsi" -#include "imx7ulp-com-u-boot.dtsi" +#include <dt-bindings/input/input.h>
/ { model = "Embedded Artists i.MX7ULP COM"; @@ -16,9 +15,9 @@ stdout-path = &lpuart4; };
- memory { + memory@60000000 { device_type = "memory"; - reg = <0x60000000 0x8000000>; + reg = <0x60000000 0x4000000>; }; };
@@ -37,11 +36,9 @@ status = "okay"; };
-&usbphy1 { - fsl,tx-d-cal = <88>; -}; - &usdhc0 { + assigned-clocks = <&pcc2 IMX7ULP_CLK_USDHC0>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_APLL_PFD1>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usdhc0>; non-removable; @@ -51,19 +48,16 @@ };
&iomuxc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_1>; - - pinctrl_hog_1: hoggrp-1 { + pinctrl_lpuart4: lpuart4grp { fsl,pins = < - IMX7ULP_PAD_PTC1__PTC1 0x20000 + IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 + IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 >; };
- pinctrl_lpuart4: lpuart4grp { + pinctrl_usbotg1_id: otg1idgrp { fsl,pins = < - IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 - IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 + IMX7ULP_PAD_PTC13__USB0_ID 0x10003 >; };
@@ -82,10 +76,4 @@ IMX7ULP_PAD_PTD11__SDHC0_DQS 0x42 >; }; - - pinctrl_usbotg1_id: otg1idgrp { - fsl,pins = < - IMX7ULP_PAD_PTC13__USB0_ID 0x10003 - >; - }; }; diff --git a/arch/arm/dts/imx7ulp-evk.dts b/arch/arm/dts/imx7ulp-evk.dts index 8f6a935e24..eff51e113d 100644 --- a/arch/arm/dts/imx7ulp-evk.dts +++ b/arch/arm/dts/imx7ulp-evk.dts @@ -1,9 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright 2017-2018 NXP + * Dong Aisheng aisheng.dong@nxp.com */
/dts-v1/; @@ -12,365 +11,57 @@
/ { model = "NXP i.MX7ULP EVK"; - compatible = "fsl,imx7ulp-evk", "fsl,imx7ulp", "Generic DT based system"; + compatible = "fsl,imx7ulp-evk", "fsl,imx7ulp";
chosen { - bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x402D0000,115200"; stdout-path = &lpuart4; };
- bcmdhd_wlan_0: bcmdhd_wlan@0 { - compatible = "android,bcmdhd_wlan"; - wlreg_on-supply = <&wlreg_on>; - bcmdhd_fw = "/lib/firmware/bcm/1DX_BCM4343W/fw_bcmdhd.bin"; - bcmdhd_nv = "/lib/firmware/bcm/1DX_BCM4343W/bcmdhd.1DX.SDIO.cal"; - }; - - memory { + memory@60000000 { device_type = "memory"; reg = <0x60000000 0x40000000>; };
backlight { - compatible = "gpio-backlight"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_backlight>; - gpios = <&gpio3 2 GPIO_ACTIVE_HIGH>; - default-on; + compatible = "pwm-backlight"; + pwms = <&tpm4 1 50000 0>; + brightness-levels = <0 20 25 30 35 40 100>; + default-brightness-level = <6>; status = "okay"; };
- mipi_dsi_reset: mipi-dsi-reset { - compatible = "gpio-reset"; - reset-gpios = <&gpio0 19 GPIO_ACTIVE_LOW>; - reset-delay-us = <1000>; - #reset-cells = <0>; - }; - - regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - wlreg_on: fixedregulator@100 { - compatible = "regulator-fixed"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "wlreg_on"; - gpio = <&gpio2 6 GPIO_ACTIVE_HIGH>; - startup-delay-us = <100>; - enable-active-high; - }; - - reg_usb_otg1_vbus: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usbotg1_vbus>; - regulator-name = "usb_otg1_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_vsd_3v3: regulator@1 { - compatible = "regulator-fixed"; - reg = <1>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio1 0 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - }; - - pf1550-rpmsg { - compatible = "fsl,pf1550-rpmsg"; - sw1_reg: SW1 { - regulator-name = "SW1"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <1387500>; - regulator-boot-on; - regulator-always-on; - }; - - sw2_reg: SW2 { - regulator-name = "SW2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <1387500>; - regulator-boot-on; - regulator-always-on; - }; - - sw3_reg: SW3 { - regulator-name = "SW3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - vref_reg: VREFDDR { - regulator-name = "VREFDDR"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - vldo1_reg: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vldo2_reg: LDO2 { - regulator-name = "LDO2"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vldo3_reg: LDO3 { - regulator-name = "LDO3"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - }; -}; - -&iomuxc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_1>; - - imx7ulp-evk { - pinctrl_hog_1: hoggrp-1 { - fsl,pins = < - IMX7ULP_PAD_PTC1__PTC1 0x20000 - >; - }; - - pinctrl_backlight: backlight_grp { - fsl,pins = < - IMX7ULP_PAD_PTF2__PTF2 0x20000 - >; - }; - - pinctrl_lpi2c5: lpi2c5grp { - fsl,pins = < - IMX7ULP_PAD_PTC4__LPI2C5_SCL 0x27 - IMX7ULP_PAD_PTC5__LPI2C5_SDA 0x27 - >; - }; - - pinctrl_mipi_dsi_reset: mipi_dsi_reset_grp { - fsl,pins = < - IMX7ULP_PAD_PTC19__PTC19 0x20003 - >; - }; - - pinctrl_lpuart4: lpuart4grp { - fsl,pins = < - IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 - IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 - >; - }; - - pinctrl_lpuart6: lpuart6grp { - fsl,pins = < - IMX7ULP_PAD_PTE10__LPUART6_TX 0x3 - IMX7ULP_PAD_PTE11__LPUART6_RX 0x3 - IMX7ULP_PAD_PTE9__LPUART6_RTS_B 0x3 - IMX7ULP_PAD_PTE8__LPUART6_CTS_B 0x3 - IMX7ULP_PAD_PTE7__PTE7 0x20000 /* BT_REG_ON */ - >; - }; - - pinctrl_lpuart7: lpuart7grp { - fsl,pins = < - IMX7ULP_PAD_PTF14__LPUART7_TX 0x3 - IMX7ULP_PAD_PTF15__LPUART7_RX 0x3 - IMX7ULP_PAD_PTF13__LPUART7_RTS_B 0x3 - IMX7ULP_PAD_PTF12__LPUART7_CTS_B 0x3 - >; - }; - - pinctrl_usdhc0: usdhc0grp { - fsl,pins = < - IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 - IMX7ULP_PAD_PTD2__SDHC0_CLK 0x10042 - IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 - IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 - IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 - IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 - IMX7ULP_PAD_PTC10__PTC10 0x10000 /* USDHC0 CD */ - IMX7ULP_PAD_PTD0__PTD0 0x20000 /* USDHC0 RST */ - >; - }; - - pinctrl_usdhc0_8bit: usdhc0grp_8bit { - fsl,pins = < - IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 - IMX7ULP_PAD_PTD2__SDHC0_CLK 0x10042 - IMX7ULP_PAD_PTD3__SDHC0_D7 0x43 - IMX7ULP_PAD_PTD4__SDHC0_D6 0x43 - IMX7ULP_PAD_PTD5__SDHC0_D5 0x43 - IMX7ULP_PAD_PTD6__SDHC0_D4 0x43 - IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 - IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 - IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 - IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 - IMX7ULP_PAD_PTD11__SDHC0_DQS 0x42 - >; - }; - - pinctrl_lpi2c7: lpi2c7grp { - fsl,pins = < - IMX7ULP_PAD_PTF12__LPI2C7_SCL 0x27 - IMX7ULP_PAD_PTF13__LPI2C7_SDA 0x27 - >; - }; - - pinctrl_lpspi3: lpspi3grp { - fsl,pins = < - IMX7ULP_PAD_PTF16__LPSPI3_SIN 0x0 - IMX7ULP_PAD_PTF17__LPSPI3_SOUT 0x0 - IMX7ULP_PAD_PTF18__LPSPI3_SCK 0x0 - IMX7ULP_PAD_PTF19__LPSPI3_PCS0 0x0 - >; - }; - - pinctrl_usbotg1_vbus: otg1vbusgrp { - fsl,pins = < - IMX7ULP_PAD_PTC0__PTC0 0x20000 - >; - }; - - pinctrl_usbotg1_id: otg1idgrp { - fsl,pins = < - IMX7ULP_PAD_PTC13__USB0_ID 0x10003 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - IMX7ULP_PAD_PTE3__SDHC1_CMD 0x43 - IMX7ULP_PAD_PTE2__SDHC1_CLK 0x10042 - IMX7ULP_PAD_PTE1__SDHC1_D0 0x43 - IMX7ULP_PAD_PTE0__SDHC1_D1 0x43 - IMX7ULP_PAD_PTE5__SDHC1_D2 0x43 - IMX7ULP_PAD_PTE4__SDHC1_D3 0x43 - >; - }; - - pinctrl_usdhc1_rst: usdhc1grp_rst { - fsl,pins = < - IMX7ULP_PAD_PTE11__PTE11 0x20000 /* USDHC1 RST */ - IMX7ULP_PAD_PTE13__PTE13 0x10003 /* USDHC1 CD */ - IMX7ULP_PAD_PTE12__PTE12 0x10003 /* USDHC1 WP */ - IMX7ULP_PAD_PTE14__SDHC1_VS 0x43 /* USDHC1 VSEL */ - >; - }; - - pinctrl_dsi_hdmi: dsi_hdmi_grp { - fsl,pins = < - IMX7ULP_PAD_PTC18__PTC18 0x10003 /* DSI_HDMI_INT */ - >; - }; - }; -}; - -&lcdif { - status = "okay"; - disp-dev = "mipi_dsi_northwest"; - display = <&display0>; - - display0: display@0 { - bits-per-pixel = <16>; - bus-width = <24>; - - display-timings { - native-mode = <&timing0>; - timing0: timing0 { - clock-frequency = <9200000>; - hactive = <480>; - vactive = <272>; - hfront-porch = <8>; - hback-porch = <4>; - hsync-len = <41>; - vback-porch = <2>; - vfront-porch = <4>; - vsync-len = <10>; - - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; + reg_usb_otg1_vbus: regulator-usb-otg1-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1_vbus>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio_ptc 0 GPIO_ACTIVE_HIGH>; + enable-active-high; }; -}; - -&lpi2c7 { - #address-cells = <1>; - #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpi2c7>; -}; - -&lpi2c5 { - #address-cells = <1>; - #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpi2c5>; - status = "okay"; -};
-&lpspi3 { - #address-cells = <1>; - #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpspi3>; - status = "okay"; - - spidev0: spi@0 { - reg = <0>; - compatible = "rohm,dh2228fv"; - spi-max-frequency = <1000000>; + reg_vsd_3v3: regulator-vsd-3v3 { + compatible = "regulator-fixed"; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc0_rst>; + gpio = <&gpio_ptd 0 GPIO_ACTIVE_HIGH>; + enable-active-high; }; };
-&mipi_dsi { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_mipi_dsi_reset>; - lcd_panel = "TRULY-WVGA-TFT3P5581E"; - resets = <&mipi_dsi_reset>; - status = "okay"; -}; - -&lpuart4 { /* console */ +&lpuart4 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lpuart4>; status = "okay"; };
-&lpuart6 { /* BT */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpuart6>; - status = "okay"; -}; - -&lpuart7 { /* Uart test */ +&tpm4 { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpuart7>; - status = "disabled"; -}; - -&rpmsg{ + pinctrl-0 = <&pinctrl_pwm0>; status = "okay"; };
@@ -381,21 +72,62 @@ srp-disable; hnp-disable; adp-disable; + disable-over-current; status = "okay"; };
-&usbphy1 { - fsl,tx-d-cal = <88>; -}; - &usdhc0 { - pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; + assigned-clocks = <&pcc2 IMX7ULP_CLK_USDHC0>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_APLL_PFD1>; + pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usdhc0>; - pinctrl-1 = <&pinctrl_usdhc0>; - pinctrl-2 = <&pinctrl_usdhc0>; - pinctrl-3 = <&pinctrl_usdhc0>; - cd-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>; + cd-gpios = <&gpio_ptc 10 GPIO_ACTIVE_LOW>; vmmc-supply = <®_vsd_3v3>; - vqmmc-supply = <&vldo2_reg>; status = "okay"; }; + +&iomuxc1 { + pinctrl_lpuart4: lpuart4grp { + fsl,pins = < + IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 + IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 + >; + bias-pull-up; + }; + + pinctrl_pwm0: pwm0grp { + fsl,pins = < + IMX7ULP_PAD_PTF2__TPM4_CH1 0x2 + >; + }; + + pinctrl_usbotg1_vbus: otg1vbusgrp { + fsl,pins = < + IMX7ULP_PAD_PTC0__PTC0 0x20000 + >; + }; + + pinctrl_usbotg1_id: otg1idgrp { + fsl,pins = < + IMX7ULP_PAD_PTC13__USB0_ID 0x10003 + >; + }; + + pinctrl_usdhc0: usdhc0grp { + fsl,pins = < + IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 + IMX7ULP_PAD_PTD2__SDHC0_CLK 0x40 + IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 + IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 + IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 + IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 + IMX7ULP_PAD_PTC10__PTC10 0x3 /* CD */ + >; + }; + + pinctrl_usdhc0_rst: usdhc0-gpio-rst-grp { + fsl,pins = < + IMX7ULP_PAD_PTD0__PTD0 0x3 + >; + }; +}; diff --git a/arch/arm/dts/imx7ulp-pinfunc.h b/arch/arm/dts/imx7ulp-pinfunc.h index 777d7f0947..c0148d79b6 100644 --- a/arch/arm/dts/imx7ulp-pinfunc.h +++ b/arch/arm/dts/imx7ulp-pinfunc.h @@ -1,11 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Copyright 2016 Freescale Semiconductor, Inc. - * Copyright 2017 - 2018 NXP - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * + * Copyright 2017 NXP */
#ifndef __DTS_IMX7ULP_PINFUNC_H @@ -15,654 +11,244 @@ * The pin function ID is a tuple of * <mux_conf_reg input_reg mux_mode input_val> */ -#define IMX7ULP_PAD_PTA0__CMP0_IN1_3V 0x0000 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA0__PTA0 0x0000 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA0__LPSPI0_PCS1 0x0000 0x0104 0x3 0x2 -#define IMX7ULP_PAD_PTA0__LPUART0_CTS_B 0x0000 0x01F8 0x4 0x2 -#define IMX7ULP_PAD_PTA0__LPI2C0_SCL 0x0000 0x017C 0x5 0x2 -#define IMX7ULP_PAD_PTA0__TPM0_CLKIN 0x0000 0x01A8 0x6 0x2 -#define IMX7ULP_PAD_PTA0__I2S0_RX_BCLK 0x0000 0x01B8 0x7 0x2 -#define IMX7ULP_PAD_PTA0__LLWU0_P0 0x0000 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA1__CMP0_IN2_3V 0x0004 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA1__PTA1 0x0004 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA1__LPSPI0_PCS2 0x0004 0x0108 0x3 0x1 -#define IMX7ULP_PAD_PTA1__LPUART0_RTS_B 0x0004 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA1__LPI2C0_SDA 0x0004 0x0180 0x5 0x1 -#define IMX7ULP_PAD_PTA1__TPM0_CH0 0x0004 0x0138 0x6 0x1 -#define IMX7ULP_PAD_PTA1__I2S0_RX_FS 0x0004 0x01BC 0x7 0x1 -#define IMX7ULP_PAD_PTA2__CMP1_IN2_3V 0x0008 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA2__PTA2 0x0008 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA2__LPSPI0_PCS3 0x0008 0x010C 0x3 0x1 -#define IMX7ULP_PAD_PTA2__LPUART0_TX 0x0008 0x0200 0x4 0x1 -#define IMX7ULP_PAD_PTA2__LPI2C0_HREQ 0x0008 0x0178 0x5 0x1 -#define IMX7ULP_PAD_PTA2__TPM0_CH1 0x0008 0x013C 0x6 0x1 -#define IMX7ULP_PAD_PTA2__I2S0_RXD0 0x0008 0x01DC 0x7 0x1 -#define IMX7ULP_PAD_PTA3__CMP1_IN4_3V 0x000C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA3__PTA3 0x000C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA3__LPSPI0_PCS0 0x000C 0x0100 0x3 0x1 -#define IMX7ULP_PAD_PTA3__LPUART0_RX 0x000C 0x01FC 0x4 0x1 -#define IMX7ULP_PAD_PTA3__TPM0_CH2 0x000C 0x0140 0x6 0x1 -#define IMX7ULP_PAD_PTA3__I2S0_RXD1 0x000C 0x01E0 0x7 0x1 -#define IMX7ULP_PAD_PTA3__CMP0_OUT 0x000C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA3__LLWU0_P1 0x000C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA4__ADC1_CH3A 0x0010 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA4__PTA4 0x0010 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA4__LPSPI0_SIN 0x0010 0x0114 0x3 0x1 -#define IMX7ULP_PAD_PTA4__LPUART1_CTS_B 0x0010 0x0204 0x4 0x1 -#define IMX7ULP_PAD_PTA4__LPI2C1_SCL 0x0010 0x0188 0x5 0x1 -#define IMX7ULP_PAD_PTA4__TPM0_CH3 0x0010 0x0144 0x6 0x1 -#define IMX7ULP_PAD_PTA4__I2S0_MCLK 0x0010 0x01B4 0x7 0x1 -#define IMX7ULP_PAD_PTA5__ADC1_CH3B 0x0014 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA5__PTA5 0x0014 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA5__LPSPI0_SOUT 0x0014 0x0118 0x3 0x1 -#define IMX7ULP_PAD_PTA5__LPUART1_RTS_B 0x0014 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA5__LPI2C1_SDA 0x0014 0x018C 0x5 0x1 -#define IMX7ULP_PAD_PTA5__TPM0_CH4 0x0014 0x0148 0x6 0x1 -#define IMX7ULP_PAD_PTA5__I2S0_TX_BCLK 0x0014 0x01C0 0x7 0x1 -#define IMX7ULP_PAD_PTA6__ADC1_CH4A 0x0018 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA6__PTA6 0x0018 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA6__LPSPI0_SCK 0x0018 0x0110 0x3 0x1 -#define IMX7ULP_PAD_PTA6__LPUART1_TX 0x0018 0x020C 0x4 0x1 -#define IMX7ULP_PAD_PTA6__LPI2C1_HREQ 0x0018 0x0184 0x5 0x1 -#define IMX7ULP_PAD_PTA6__TPM0_CH5 0x0018 0x014C 0x6 0x1 -#define IMX7ULP_PAD_PTA6__I2S0_TX_FS 0x0018 0x01C4 0x7 0x1 -#define IMX7ULP_PAD_PTA7__ADC1_CH4B 0x001C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA7__PTA7 0x001C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA7__LPUART1_RX 0x001C 0x0208 0x4 0x1 -#define IMX7ULP_PAD_PTA7__TPM1_CH1 0x001C 0x0154 0x6 0x1 -#define IMX7ULP_PAD_PTA7__I2S0_TXD0 0x001C 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA8__ADC1_CH5A 0x0020 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA8__PTA8 0x0020 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA8__LPSPI1_PCS1 0x0020 0x0120 0x3 0x1 -#define IMX7ULP_PAD_PTA8__LPUART2_CTS_B 0x0020 0x0210 0x4 0x1 -#define IMX7ULP_PAD_PTA8__LPI2C2_SCL 0x0020 0x0194 0x5 0x1 -#define IMX7ULP_PAD_PTA8__TPM1_CLKIN 0x0020 0x01AC 0x6 0x1 -#define IMX7ULP_PAD_PTA8__I2S0_TXD1 0x0020 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA9__ADC1_CH5B 0x0024 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA9__PTA9 0x0024 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA9__LPSPI1_PCS2 0x0024 0x0124 0x3 0x1 -#define IMX7ULP_PAD_PTA9__LPUART2_RTS_B 0x0024 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA9__LPI2C2_SDA 0x0024 0x0198 0x5 0x1 -#define IMX7ULP_PAD_PTA9__TPM1_CH0 0x0024 0x0150 0x6 0x1 -#define IMX7ULP_PAD_PTA9__NMI0_B 0x0024 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA10__ADC1_CH6A 0x0028 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA10__PTA10 0x0028 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA10__LPSPI1_PCS3 0x0028 0x0128 0x3 0x1 -#define IMX7ULP_PAD_PTA10__LPUART2_TX 0x0028 0x0218 0x4 0x1 -#define IMX7ULP_PAD_PTA10__LPI2C2_HREQ 0x0028 0x0190 0x5 0x1 -#define IMX7ULP_PAD_PTA10__TPM2_CLKIN 0x0028 0x01F4 0x6 0x1 -#define IMX7ULP_PAD_PTA10__I2S0_RX_BCLK 0x0028 0x01B8 0x7 0x1 -#define IMX7ULP_PAD_PTA11__ADC1_CH6B 0x002C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA11__PTA11 0x002C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA11__LPUART2_RX 0x002C 0x0214 0x4 0x1 -#define IMX7ULP_PAD_PTA11__TPM2_CH0 0x002C 0x0158 0x6 0x1 -#define IMX7ULP_PAD_PTA11__I2S0_RX_FS 0x002C 0x01BC 0x7 0x2 -#define IMX7ULP_PAD_PTA12__ADC1_CH7A 0x0030 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA12__PTA12 0x0030 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA12__LPSPI1_SIN 0x0030 0x0130 0x3 0x1 -#define IMX7ULP_PAD_PTA12__LPUART3_CTS_B 0x0030 0x021C 0x4 0x1 -#define IMX7ULP_PAD_PTA12__LPI2C3_SCL 0x0030 0x01A0 0x5 0x1 -#define IMX7ULP_PAD_PTA12__TPM2_CH1 0x0030 0x015C 0x6 0x1 -#define IMX7ULP_PAD_PTA12__I2S0_RXD0 0x0030 0x01DC 0x7 0x2 -#define IMX7ULP_PAD_PTA13__ADC1_CH7B 0x0034 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA13__PTA13 0x0034 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA13__LPSPI1_SOUT 0x0034 0x0134 0x3 0x2 -#define IMX7ULP_PAD_PTA13__LPUART3_RTS_B 0x0034 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA13__LPI2C3_SDA 0x0034 0x01A4 0x5 0x2 -#define IMX7ULP_PAD_PTA13__TPM3_CLKIN 0x0034 0x01B0 0x6 0x1 -#define IMX7ULP_PAD_PTA13__I2S0_RXD1 0x0034 0x01E0 0x7 0x2 -#define IMX7ULP_PAD_PTA13__CMP0_OUT 0x0034 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA13__LLWU0_P2 0x0034 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA14__ADC1_CH8A 0x0038 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA14__PTA14 0x0038 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA14__LPSPI1_SCK 0x0038 0x012C 0x3 0x2 -#define IMX7ULP_PAD_PTA14__LPUART3_TX 0x0038 0x0224 0x4 0x2 -#define IMX7ULP_PAD_PTA14__LPI2C3_HREQ 0x0038 0x019C 0x5 0x2 -#define IMX7ULP_PAD_PTA14__TPM3_CH0 0x0038 0x0160 0x6 0x1 -#define IMX7ULP_PAD_PTA14__I2S0_MCLK 0x0038 0x01B4 0x7 0x2 -#define IMX7ULP_PAD_PTA14__LLWU0_P3 0x0038 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA15__ADC1_CH8B 0x003C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA15__PTA15 0x003C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA15__LPSPI1_PCS0 0x003C 0x011C 0x3 0x1 -#define IMX7ULP_PAD_PTA15__LPUART3_RX 0x003C 0x0220 0x4 0x1 -#define IMX7ULP_PAD_PTA15__TPM3_CH1 0x003C 0x0164 0x6 0x1 -#define IMX7ULP_PAD_PTA15__I2S0_TX_BCLK 0x003C 0x01C0 0x7 0x2 -#define IMX7ULP_PAD_PTA16__CMP1_IN5_3V 0x0040 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA16__PTA16 0x0040 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA16__FXIO0_D0 0x0040 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA16__LPSPI0_SOUT 0x0040 0x0118 0x3 0x2 -#define IMX7ULP_PAD_PTA16__LPUART0_CTS_B 0x0040 0x01F8 0x4 0x1 -#define IMX7ULP_PAD_PTA16__LPI2C0_SCL 0x0040 0x017C 0x5 0x1 -#define IMX7ULP_PAD_PTA16__TPM3_CH2 0x0040 0x0168 0x6 0x1 -#define IMX7ULP_PAD_PTA16__I2S0_TX_FS 0x0040 0x01C4 0x7 0x2 -#define IMX7ULP_PAD_PTA17__CMP1_IN6_3V 0x0044 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA17__PTA17 0x0044 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA17__FXIO0_D1 0x0044 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA17__LPSPI0_SCK 0x0044 0x0110 0x3 0x2 -#define IMX7ULP_PAD_PTA17__LPUART0_RTS_B 0x0044 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA17__LPI2C0_SDA 0x0044 0x0180 0x5 0x2 -#define IMX7ULP_PAD_PTA17__TPM3_CH3 0x0044 0x016C 0x6 0x1 -#define IMX7ULP_PAD_PTA17__I2S0_TXD0 0x0044 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA18__CMP1_IN1_3V 0x0048 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA18__PTA18 0x0048 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA18__FXIO0_D2 0x0048 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA18__LPSPI0_PCS0 0x0048 0x0100 0x3 0x2 -#define IMX7ULP_PAD_PTA18__LPUART0_TX 0x0048 0x0200 0x4 0x2 -#define IMX7ULP_PAD_PTA18__LPI2C0_HREQ 0x0048 0x0178 0x5 0x2 -#define IMX7ULP_PAD_PTA18__TPM3_CH4 0x0048 0x0170 0x6 0x1 -#define IMX7ULP_PAD_PTA18__I2S0_TXD1 0x0048 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA18__LLWU0_P4 0x0048 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA19__CMP1_IN3_3V 0x004C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA19__PTA19 0x004C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA19__FXIO0_D3 0x004C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA19__LPUART0_RX 0x004C 0x01FC 0x4 0x2 -#define IMX7ULP_PAD_PTA19__TPM3_CH5 0x004C 0x0174 0x6 0x1 -#define IMX7ULP_PAD_PTA19__I2S1_RX_BCLK 0x004C 0x01CC 0x7 0x1 -#define IMX7ULP_PAD_PTA19__LPTMR0_ALT3 0x004C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA19__LLWU0_P5 0x004C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA20__ADC0_CH10A 0x0050 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA20__PTA20 0x0050 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA20__FXIO0_D4 0x0050 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA20__LPSPI0_SIN 0x0050 0x0114 0x3 0x2 -#define IMX7ULP_PAD_PTA20__LPUART1_CTS_B 0x0050 0x0204 0x4 0x2 -#define IMX7ULP_PAD_PTA20__LPI2C1_SCL 0x0050 0x0188 0x5 0x2 -#define IMX7ULP_PAD_PTA20__TPM0_CLKIN 0x0050 0x01A8 0x6 0x1 -#define IMX7ULP_PAD_PTA20__I2S1_RX_FS 0x0050 0x01D0 0x7 0x1 -#define IMX7ULP_PAD_PTA21__ADC0_CH10B 0x0054 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA21__PTA21 0x0054 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA21__FXIO0_D5 0x0054 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA21__LPSPI0_PCS1 0x0054 0x0104 0x3 0x1 -#define IMX7ULP_PAD_PTA21__LPUART1_RTS_B 0x0054 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA21__LPI2C1_SDA 0x0054 0x018C 0x5 0x2 -#define IMX7ULP_PAD_PTA21__TPM0_CH0 0x0054 0x0138 0x6 0x2 -#define IMX7ULP_PAD_PTA21__I2S1_RXD0 0x0054 0x01E4 0x7 0x1 -#define IMX7ULP_PAD_PTA22__ADC0_CH9A 0x0058 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA22__PTA22 0x0058 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA22__FXIO0_D6 0x0058 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA22__LPSPI0_PCS2 0x0058 0x0108 0x3 0x2 -#define IMX7ULP_PAD_PTA22__LPUART1_TX 0x0058 0x020C 0x4 0x2 -#define IMX7ULP_PAD_PTA22__LPI2C1_HREQ 0x0058 0x0184 0x5 0x2 -#define IMX7ULP_PAD_PTA22__TPM0_CH1 0x0058 0x013C 0x6 0x2 -#define IMX7ULP_PAD_PTA22__I2S1_RXD1 0x0058 0x01E8 0x7 0x1 -#define IMX7ULP_PAD_PTA22__LPTMR0_ALT2 0x0058 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA22__EWM_OUT_B 0x0058 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTA23__ADC0_CH9B 0x005C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA23__PTA23 0x005C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA23__FXIO0_D7 0x005C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA23__LPSPI0_PCS3 0x005C 0x010C 0x3 0x2 -#define IMX7ULP_PAD_PTA23__LPUART1_RX 0x005C 0x0208 0x4 0x2 -#define IMX7ULP_PAD_PTA23__TPM0_CH2 0x005C 0x0140 0x6 0x2 -#define IMX7ULP_PAD_PTA23__I2S1_MCLK 0x005C 0x01C8 0x7 0x1 -#define IMX7ULP_PAD_PTA23__LLWU0_P6 0x005C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTA24__ADC0_CH8A 0x0060 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA24__PTA24 0x0060 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA24__FXIO0_D8 0x0060 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA24__LPSPI1_PCS1 0x0060 0x0120 0x3 0x2 -#define IMX7ULP_PAD_PTA24__LPUART2_CTS_B 0x0060 0x0210 0x4 0x2 -#define IMX7ULP_PAD_PTA24__LPI2C2_SCL 0x0060 0x0194 0x5 0x2 -#define IMX7ULP_PAD_PTA24__TPM0_CH3 0x0060 0x0144 0x6 0x2 -#define IMX7ULP_PAD_PTA24__I2S1_TX_BCLK 0x0060 0x01D4 0x7 0x1 -#define IMX7ULP_PAD_PTA25__ADC0_CH8B 0x0064 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA25__PTA25 0x0064 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA25__FXIO0_D9 0x0064 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA25__LPSPI1_PCS2 0x0064 0x0124 0x3 0x2 -#define IMX7ULP_PAD_PTA25__LPUART2_RTS_B 0x0064 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA25__LPI2C2_SDA 0x0064 0x0198 0x5 0x2 -#define IMX7ULP_PAD_PTA25__TPM0_CH4 0x0064 0x0148 0x6 0x2 -#define IMX7ULP_PAD_PTA25__I2S1_TX_FS 0x0064 0x01D8 0x7 0x1 -#define IMX7ULP_PAD_PTA26__PTA26 0x0068 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA26__JTAG_TMS_SWD_DIO 0x0068 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTA26__FXIO0_D10 0x0068 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA26__LPSPI1_PCS3 0x0068 0x0128 0x3 0x2 -#define IMX7ULP_PAD_PTA26__LPUART2_TX 0x0068 0x0218 0x4 0x2 -#define IMX7ULP_PAD_PTA26__LPI2C2_HREQ 0x0068 0x0190 0x5 0x2 -#define IMX7ULP_PAD_PTA26__TPM0_CH5 0x0068 0x014C 0x6 0x2 -#define IMX7ULP_PAD_PTA26__I2S1_RXD2 0x0068 0x01EC 0x7 0x1 -#define IMX7ULP_PAD_PTA27__PTA27 0x006C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA27__JTAG_TDO 0x006C 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTA27__FXIO0_D11 0x006C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA27__LPUART2_RX 0x006C 0x0214 0x4 0x2 -#define IMX7ULP_PAD_PTA27__TPM1_CH1 0x006C 0x0154 0x6 0x2 -#define IMX7ULP_PAD_PTA27__I2S1_RXD3 0x006C 0x01F0 0x7 0x1 -#define IMX7ULP_PAD_PTA28__PTA28 0x0070 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA28__JTAG_TDI 0x0070 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTA28__FXIO0_D12 0x0070 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA28__LPSPI1_SIN 0x0070 0x0130 0x3 0x2 -#define IMX7ULP_PAD_PTA28__LPUART3_CTS_B 0x0070 0x021C 0x4 0x2 -#define IMX7ULP_PAD_PTA28__LPI2C3_SCL 0x0070 0x01A0 0x5 0x2 -#define IMX7ULP_PAD_PTA28__TPM1_CLKIN 0x0070 0x01AC 0x6 0x2 -#define IMX7ULP_PAD_PTA28__I2S1_TXD2 0x0070 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA29__PTA29 0x0074 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA29__JTAG_TCLK_SWD_CLK 0x0074 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTA29__FXIO0_D13 0x0074 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA29__LPSPI1_SOUT 0x0074 0x0134 0x3 0x1 -#define IMX7ULP_PAD_PTA29__LPUART3_RTS_B 0x0074 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTA29__LPI2C3_SDA 0x0074 0x01A4 0x5 0x1 -#define IMX7ULP_PAD_PTA29__TPM1_CH0 0x0074 0x0150 0x6 0x2 -#define IMX7ULP_PAD_PTA29__I2S1_TXD3 0x0074 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA30__ADC0_CH1A 0x0078 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA30__PTA30 0x0078 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA30__FXIO0_D14 0x0078 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA30__LPSPI1_SCK 0x0078 0x012C 0x3 0x1 -#define IMX7ULP_PAD_PTA30__LPUART3_TX 0x0078 0x0224 0x4 0x1 -#define IMX7ULP_PAD_PTA30__LPI2C3_HREQ 0x0078 0x019C 0x5 0x1 -#define IMX7ULP_PAD_PTA30__TPM2_CLKIN 0x0078 0x01F4 0x6 0x2 -#define IMX7ULP_PAD_PTA30__I2S1_TXD0 0x0078 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA30__JTAG_TRST_B 0x0078 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTA31__ADC0_CH1B 0x007C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTA31__PTA31 0x007C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTA31__FXIO0_D15 0x007C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTA31__LPSPI1_PCS0 0x007C 0x011C 0x3 0x2 -#define IMX7ULP_PAD_PTA31__LPUART3_RX 0x007C 0x0220 0x4 0x2 -#define IMX7ULP_PAD_PTA31__TPM2_CH0 0x007C 0x0158 0x6 0x2 -#define IMX7ULP_PAD_PTA31__I2S1_TXD1 0x007C 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTA31__LPTMR0_ALT1 0x007C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTA31__EWM_IN 0x007C 0x0228 0xc 0x1 -#define IMX7ULP_PAD_PTA31__LLWU0_P7 0x007C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB0__ADC0_CH0A 0x0080 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB0__PTB0 0x0080 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB0__FXIO0_D16 0x0080 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB0__LPSPI0_SIN 0x0080 0x0114 0x3 0x3 -#define IMX7ULP_PAD_PTB0__LPUART0_TX 0x0080 0x0200 0x4 0x3 -#define IMX7ULP_PAD_PTB0__TPM2_CH1 0x0080 0x015C 0x6 0x2 -#define IMX7ULP_PAD_PTB0__CLKOUT0 0x0080 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTB0__CMP1_OUT 0x0080 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB0__EWM_OUT_B 0x0080 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTB1__ADC0_CH0B 0x0084 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB1__PTB1 0x0084 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB1__FXIO0_D17 0x0084 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB1__LPSPI0_SOUT 0x0084 0x0118 0x3 0x3 -#define IMX7ULP_PAD_PTB1__LPUART0_RX 0x0084 0x01FC 0x4 0x3 -#define IMX7ULP_PAD_PTB1__TPM3_CLKIN 0x0084 0x01B0 0x6 0x3 -#define IMX7ULP_PAD_PTB1__I2S1_TX_BCLK 0x0084 0x01D4 0x7 0x2 -#define IMX7ULP_PAD_PTB1__RTC_CLKOUT 0x0084 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB1__EWM_IN 0x0084 0x0228 0xc 0x2 -#define IMX7ULP_PAD_PTB1__LLWU0_P8 0x0084 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB2__ADC0_CH6A 0x0088 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB2__PTB2 0x0088 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB2__FXIO0_D18 0x0088 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB2__LPSPI0_SCK 0x0088 0x0110 0x3 0x3 -#define IMX7ULP_PAD_PTB2__LPUART1_TX 0x0088 0x020C 0x4 0x3 -#define IMX7ULP_PAD_PTB2__TPM3_CH0 0x0088 0x0160 0x6 0x2 -#define IMX7ULP_PAD_PTB2__I2S1_TX_FS 0x0088 0x01D8 0x7 0x2 -#define IMX7ULP_PAD_PTB2__TRACE_CLKOUT 0x0088 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB3__ADC0_CH6B 0x008C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB3__PTB3 0x008C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB3__FXIO0_D19 0x008C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB3__LPSPI0_PCS0 0x008C 0x0100 0x3 0x3 -#define IMX7ULP_PAD_PTB3__LPUART1_RX 0x008C 0x0208 0x4 0x3 -#define IMX7ULP_PAD_PTB3__TPM3_CH1 0x008C 0x0164 0x6 0x2 -#define IMX7ULP_PAD_PTB3__I2S1_TXD0 0x008C 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTB3__TRACE_D0 0x008C 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB3__LPTMR1_ALT2 0x008C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB3__LLWU0_P9 0x008C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB4__PTB4 0x0090 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB4__FXIO0_D20 0x0090 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB4__LPSPI0_PCS1 0x0090 0x0104 0x3 0x3 -#define IMX7ULP_PAD_PTB4__LPUART2_TX 0x0090 0x0218 0x4 0x3 -#define IMX7ULP_PAD_PTB4__LPI2C0_HREQ 0x0090 0x0178 0x5 0x3 -#define IMX7ULP_PAD_PTB4__TPM3_CH2 0x0090 0x0168 0x6 0x2 -#define IMX7ULP_PAD_PTB4__I2S1_TXD1 0x0090 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTB4__QSPIA_DATA7 0x0090 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB4__TRACE_D1 0x0090 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB4__SEC_VIO_B 0x0090 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB5__PTB5 0x0094 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB5__FXIO0_D21 0x0094 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB5__LPSPI0_PCS2 0x0094 0x0108 0x3 0x3 -#define IMX7ULP_PAD_PTB5__LPUART2_RX 0x0094 0x0214 0x4 0x3 -#define IMX7ULP_PAD_PTB5__LPI2C1_HREQ 0x0094 0x0184 0x5 0x3 -#define IMX7ULP_PAD_PTB5__TPM3_CH3 0x0094 0x016C 0x6 0x2 -#define IMX7ULP_PAD_PTB5__I2S1_TXD2 0x0094 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTB5__QSPIA_DATA6 0x0094 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB5__TRACE_D2 0x0094 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB5__RTC_CLKOUT 0x0094 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB6__ADC1_CH1A 0x0098 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB6__PTB6 0x0098 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB6__FXIO0_D22 0x0098 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB6__LPSPI0_PCS3 0x0098 0x010C 0x3 0x3 -#define IMX7ULP_PAD_PTB6__LPUART3_TX 0x0098 0x0224 0x4 0x3 -#define IMX7ULP_PAD_PTB6__LPI2C0_SCL 0x0098 0x017C 0x5 0x3 -#define IMX7ULP_PAD_PTB6__TPM3_CH4 0x0098 0x0170 0x6 0x2 -#define IMX7ULP_PAD_PTB6__I2S1_TXD3 0x0098 0x0000 0x7 0x0 -#define IMX7ULP_PAD_PTB6__QSPIA_DATA5 0x0098 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB6__TRACE_D3 0x0098 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB6__LPTMR1_ALT3 0x0098 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB6__LLWU0_P10 0x0098 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB7__ADC1_CH1B 0x009C 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB7__PTB7 0x009C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB7__FXIO0_D23 0x009C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB7__LPSPI1_SIN 0x009C 0x0130 0x3 0x3 -#define IMX7ULP_PAD_PTB7__LPUART3_RX 0x009C 0x0220 0x4 0x3 -#define IMX7ULP_PAD_PTB7__LPI2C0_SDA 0x009C 0x0180 0x5 0x3 -#define IMX7ULP_PAD_PTB7__TPM3_CH5 0x009C 0x0174 0x6 0x2 -#define IMX7ULP_PAD_PTB7__I2S1_MCLK 0x009C 0x01C8 0x7 0x2 -#define IMX7ULP_PAD_PTB7__QSPIA_SS1_B 0x009C 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB7__CMP1_OUT 0x009C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB7__LLWU0_P11 0x009C 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB8__ADC0_CH14A_CMP0_IN0 0x00A0 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB8__PTB8 0x00A0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB8__FXIO0_D24 0x00A0 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB8__LPSPI1_SOUT 0x00A0 0x0134 0x3 0x3 -#define IMX7ULP_PAD_PTB8__LPI2C1_SCL 0x00A0 0x0188 0x5 0x3 -#define IMX7ULP_PAD_PTB8__TPM0_CLKIN 0x00A0 0x01A8 0x6 0x3 -#define IMX7ULP_PAD_PTB8__I2S1_RX_BCLK 0x00A0 0x01CC 0x7 0x2 -#define IMX7ULP_PAD_PTB8__QSPIA_SS0_B 0x00A0 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB8__RTC_CLKOUT 0x00A0 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB9__ADC0_CH14B_CMP0_IN2 0x00A4 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB9__PTB9 0x00A4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB9__FXIO0_D25 0x00A4 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB9__LPSPI1_SCK 0x00A4 0x012C 0x3 0x3 -#define IMX7ULP_PAD_PTB9__LPI2C1_SDA 0x00A4 0x018C 0x5 0x3 -#define IMX7ULP_PAD_PTB9__TPM0_CH0 0x00A4 0x0138 0x6 0x3 -#define IMX7ULP_PAD_PTB9__I2S1_RX_FS 0x00A4 0x01D0 0x7 0x2 -#define IMX7ULP_PAD_PTB9__QSPIA_DQS 0x00A4 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB9__LLWU0_P12 0x00A4 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB10__CMP0_IN1 0x00A8 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB10__PTB10 0x00A8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB10__FXIO0_D26 0x00A8 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB10__LPSPI1_PCS0 0x00A8 0x011C 0x3 0x3 -#define IMX7ULP_PAD_PTB10__LPI2C2_SCL 0x00A8 0x0194 0x5 0x3 -#define IMX7ULP_PAD_PTB10__TPM0_CH1 0x00A8 0x013C 0x6 0x3 -#define IMX7ULP_PAD_PTB10__I2S1_RXD0 0x00A8 0x01E4 0x7 0x2 -#define IMX7ULP_PAD_PTB10__TRACE_D4 0x00A8 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB11__CMP0_IN3 0x00AC 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB11__PTB11 0x00AC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB11__FXIO0_D27 0x00AC 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB11__LPSPI1_PCS1 0x00AC 0x0120 0x3 0x3 -#define IMX7ULP_PAD_PTB11__LPI2C2_SDA 0x00AC 0x0198 0x5 0x3 -#define IMX7ULP_PAD_PTB11__TPM1_CLKIN 0x00AC 0x01AC 0x6 0x3 -#define IMX7ULP_PAD_PTB11__I2S1_RXD1 0x00AC 0x01E8 0x7 0x2 -#define IMX7ULP_PAD_PTB11__TRACE_D5 0x00AC 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB12__ADC1_CH13A_CMP1_IN0 0x00B0 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB12__PTB12 0x00B0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB12__FXIO0_D28 0x00B0 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB12__LPSPI1_PCS2 0x00B0 0x0124 0x3 0x3 -#define IMX7ULP_PAD_PTB12__LPUART2_TX 0x00B0 0x0218 0x4 0x4 -#define IMX7ULP_PAD_PTB12__LPI2C3_SCL 0x00B0 0x01A0 0x5 0x3 -#define IMX7ULP_PAD_PTB12__TPM1_CH0 0x00B0 0x0150 0x6 0x3 -#define IMX7ULP_PAD_PTB12__I2S1_RXD2 0x00B0 0x01EC 0x7 0x2 -#define IMX7ULP_PAD_PTB12__TRACE_D6 0x00B0 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB13__ADC1_CH13B_CMP1_IN1 0x00B4 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB13__PTB13 0x00B4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB13__FXIO0_D29 0x00B4 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB13__LPSPI1_PCS3 0x00B4 0x0128 0x3 0x3 -#define IMX7ULP_PAD_PTB13__LPUART2_RX 0x00B4 0x0214 0x4 0x4 -#define IMX7ULP_PAD_PTB13__LPI2C3_SDA 0x00B4 0x01A4 0x5 0x3 -#define IMX7ULP_PAD_PTB13__TPM1_CH1 0x00B4 0x0154 0x6 0x3 -#define IMX7ULP_PAD_PTB13__I2S1_RXD3 0x00B4 0x01F0 0x7 0x2 -#define IMX7ULP_PAD_PTB13__QSPIA_DATA4 0x00B4 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB13__TRACE_D7 0x00B4 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTB14__ADC1_CH2A 0x00B8 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB14__PTB14 0x00B8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB14__FXIO0_D30 0x00B8 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB14__LPI2C2_HREQ 0x00B8 0x0190 0x5 0x3 -#define IMX7ULP_PAD_PTB14__TPM2_CLKIN 0x00B8 0x01F4 0x6 0x3 -#define IMX7ULP_PAD_PTB14__QSPIA_SS1_B 0x00B8 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB14__QSPIA_SCLK_B 0x00B8 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTB14__RTC_CLKOUT 0x00B8 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTB14__LLWU0_P13 0x00B8 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB15__ADC1_CH2B 0x00BC 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB15__PTB15 0x00BC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB15__FXIO0_D31 0x00BC 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTB15__LPI2C3_HREQ 0x00BC 0x019C 0x5 0x3 -#define IMX7ULP_PAD_PTB15__TPM2_CH0 0x00BC 0x0158 0x6 0x3 -#define IMX7ULP_PAD_PTB15__QSPIA_SCLK 0x00BC 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB16__ADC0_CH4A 0x00C0 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB16__PTB16 0x00C0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB16__TPM2_CH1 0x00C0 0x015C 0x6 0x3 -#define IMX7ULP_PAD_PTB16__QSPIA_DATA3 0x00C0 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB16__LLWU0_P14 0x00C0 0x0000 0xd 0x0 -#define IMX7ULP_PAD_PTB17__ADC0_CH4B 0x00C4 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB17__PTB17 0x00C4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB17__TPM3_CLKIN 0x00C4 0x01B0 0x6 0x2 -#define IMX7ULP_PAD_PTB17__QSPIA_DATA2 0x00C4 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB18__ADC0_CH5A 0x00C8 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB18__PTB18 0x00C8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB18__TPM3_CH0 0x00C8 0x0160 0x6 0x3 -#define IMX7ULP_PAD_PTB18__QSPIA_DATA1 0x00C8 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB19__ADC0_CH5B 0x00CC 0x0000 0x0 0x0 -#define IMX7ULP_PAD_PTB19__PTB19 0x00CC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTB19__TPM3_CH1 0x00CC 0x0164 0x6 0x3 -#define IMX7ULP_PAD_PTB19__QSPIA_DATA0 0x00CC 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTB19__USB0_ID 0x00CC 0x0338 0xa 0x0 -#define IMX7ULP_PAD_PTB19__LLWU0_P15 0x00CC 0x0000 0xd 0x0 + #define IMX7ULP_PAD_PTC0__PTC0 0x0000 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC0__TRACE_D15 0x0000 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC0__LPUART4_CTS_B 0x0000 0x0244 0x4 0x1 #define IMX7ULP_PAD_PTC0__LPI2C4_SCL 0x0000 0x0278 0x5 0x1 #define IMX7ULP_PAD_PTC0__TPM4_CLKIN 0x0000 0x0298 0x6 0x1 #define IMX7ULP_PAD_PTC0__FB_AD0 0x0000 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC0__TRACE_D15 0x0000 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC1__PTC1 0x0004 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC1__TRACE_D14 0x0004 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC1__LPUART4_RTS_B 0x0004 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTC1__LPI2C4_SDA 0x0004 0x027C 0x5 0x1 +#define IMX7ULP_PAD_PTC1__LPI2C4_SDA 0x0004 0x027c 0x5 0x1 #define IMX7ULP_PAD_PTC1__TPM4_CH0 0x0004 0x0280 0x6 0x1 #define IMX7ULP_PAD_PTC1__FB_AD1 0x0004 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC1__TRACE_D14 0x0004 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC2__PTC2 0x0008 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC2__LPUART4_TX 0x0008 0x024C 0x4 0x1 +#define IMX7ULP_PAD_PTC2__TRACE_D13 0x0008 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC2__LPUART4_TX 0x0008 0x024c 0x4 0x1 #define IMX7ULP_PAD_PTC2__LPI2C4_HREQ 0x0008 0x0274 0x5 0x1 #define IMX7ULP_PAD_PTC2__TPM4_CH1 0x0008 0x0284 0x6 0x1 #define IMX7ULP_PAD_PTC2__FB_AD2 0x0008 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC2__TRACE_D13 0x0008 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTC3__PTC3 0x000C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC3__LPUART4_RX 0x000C 0x0248 0x4 0x1 -#define IMX7ULP_PAD_PTC3__TPM4_CH2 0x000C 0x0288 0x6 0x1 -#define IMX7ULP_PAD_PTC3__FB_AD3 0x000C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC3__TRACE_D12 0x000C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC3__PTC3 0x000c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC3__TRACE_D12 0x000c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC3__LPUART4_RX 0x000c 0x0248 0x4 0x1 +#define IMX7ULP_PAD_PTC3__TPM4_CH2 0x000c 0x0288 0x6 0x1 +#define IMX7ULP_PAD_PTC3__FB_AD3 0x000c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC4__PTC4 0x0010 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC4__TRACE_D11 0x0010 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC4__FXIO1_D0 0x0010 0x0204 0x2 0x1 -#define IMX7ULP_PAD_PTC4__LPSPI2_PCS1 0x0010 0x02A0 0x3 0x1 +#define IMX7ULP_PAD_PTC4__LPSPI2_PCS1 0x0010 0x02a0 0x3 0x1 #define IMX7ULP_PAD_PTC4__LPUART5_CTS_B 0x0010 0x0250 0x4 0x1 -#define IMX7ULP_PAD_PTC4__LPI2C5_SCL 0x0010 0x02BC 0x5 0x1 -#define IMX7ULP_PAD_PTC4__TPM4_CH3 0x0010 0x028C 0x6 0x1 +#define IMX7ULP_PAD_PTC4__LPI2C5_SCL 0x0010 0x02bc 0x5 0x1 +#define IMX7ULP_PAD_PTC4__TPM4_CH3 0x0010 0x028c 0x6 0x1 #define IMX7ULP_PAD_PTC4__FB_AD4 0x0010 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC4__TRACE_D11 0x0010 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC5__PTC5 0x0014 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC5__TRACE_D10 0x0014 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC5__FXIO1_D1 0x0014 0x0208 0x2 0x1 -#define IMX7ULP_PAD_PTC5__LPSPI2_PCS2 0x0014 0x02A4 0x3 0x1 +#define IMX7ULP_PAD_PTC5__LPSPI2_PCS2 0x0014 0x02a4 0x3 0x1 #define IMX7ULP_PAD_PTC5__LPUART5_RTS_B 0x0014 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTC5__LPI2C5_SDA 0x0014 0x02C0 0x5 0x1 +#define IMX7ULP_PAD_PTC5__LPI2C5_SDA 0x0014 0x02c0 0x5 0x1 #define IMX7ULP_PAD_PTC5__TPM4_CH4 0x0014 0x0290 0x6 0x1 #define IMX7ULP_PAD_PTC5__FB_AD5 0x0014 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC5__TRACE_D10 0x0014 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC6__PTC6 0x0018 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC6__FXIO1_D2 0x0018 0x020C 0x2 0x1 -#define IMX7ULP_PAD_PTC6__LPSPI2_PCS3 0x0018 0x02A8 0x3 0x1 +#define IMX7ULP_PAD_PTC6__TRACE_D9 0x0018 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC6__FXIO1_D2 0x0018 0x020c 0x2 0x1 +#define IMX7ULP_PAD_PTC6__LPSPI2_PCS3 0x0018 0x02a8 0x3 0x1 #define IMX7ULP_PAD_PTC6__LPUART5_TX 0x0018 0x0258 0x4 0x1 -#define IMX7ULP_PAD_PTC6__LPI2C5_HREQ 0x0018 0x02B8 0x5 0x1 +#define IMX7ULP_PAD_PTC6__LPI2C5_HREQ 0x0018 0x02b8 0x5 0x1 #define IMX7ULP_PAD_PTC6__TPM4_CH5 0x0018 0x0294 0x6 0x1 #define IMX7ULP_PAD_PTC6__FB_AD6 0x0018 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC6__TRACE_D9 0x0018 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTC7__PTC7 0x001C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC7__FXIO1_D3 0x001C 0x0210 0x2 0x1 -#define IMX7ULP_PAD_PTC7__LPUART5_RX 0x001C 0x0254 0x4 0x1 -#define IMX7ULP_PAD_PTC7__TPM5_CH1 0x001C 0x02C8 0x6 0x1 -#define IMX7ULP_PAD_PTC7__FB_AD7 0x001C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC7__TRACE_D8 0x001C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC7__PTC7 0x001c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC7__TRACE_D8 0x001c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC7__FXIO1_D3 0x001c 0x0210 0x2 0x1 +#define IMX7ULP_PAD_PTC7__LPUART5_RX 0x001c 0x0254 0x4 0x1 +#define IMX7ULP_PAD_PTC7__TPM5_CH1 0x001c 0x02c8 0x6 0x1 +#define IMX7ULP_PAD_PTC7__FB_AD7 0x001c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC8__PTC8 0x0020 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC8__TRACE_D7 0x0020 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC8__FXIO1_D4 0x0020 0x0214 0x2 0x1 -#define IMX7ULP_PAD_PTC8__LPSPI2_SIN 0x0020 0x02B0 0x3 0x1 -#define IMX7ULP_PAD_PTC8__LPUART6_CTS_B 0x0020 0x025C 0x4 0x1 -#define IMX7ULP_PAD_PTC8__LPI2C6_SCL 0x0020 0x02FC 0x5 0x1 -#define IMX7ULP_PAD_PTC8__TPM5_CLKIN 0x0020 0x02CC 0x6 0x1 +#define IMX7ULP_PAD_PTC8__LPSPI2_SIN 0x0020 0x02b0 0x3 0x1 +#define IMX7ULP_PAD_PTC8__LPUART6_CTS_B 0x0020 0x025c 0x4 0x1 +#define IMX7ULP_PAD_PTC8__LPI2C6_SCL 0x0020 0x02fc 0x5 0x1 +#define IMX7ULP_PAD_PTC8__TPM5_CLKIN 0x0020 0x02cc 0x6 0x1 #define IMX7ULP_PAD_PTC8__FB_AD8 0x0020 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC8__TRACE_D7 0x0020 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC9__PTC9 0x0024 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC9__TRACE_D6 0x0024 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC9__FXIO1_D5 0x0024 0x0218 0x2 0x1 -#define IMX7ULP_PAD_PTC9__LPSPI2_SOUT 0x0024 0x02B4 0x3 0x1 +#define IMX7ULP_PAD_PTC9__LPSPI2_SOUT 0x0024 0x02b4 0x3 0x1 #define IMX7ULP_PAD_PTC9__LPUART6_RTS_B 0x0024 0x0000 0x4 0x0 #define IMX7ULP_PAD_PTC9__LPI2C6_SDA 0x0024 0x0300 0x5 0x1 -#define IMX7ULP_PAD_PTC9__TPM5_CH0 0x0024 0x02C4 0x6 0x1 +#define IMX7ULP_PAD_PTC9__TPM5_CH0 0x0024 0x02c4 0x6 0x1 #define IMX7ULP_PAD_PTC9__FB_AD9 0x0024 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC9__TRACE_D6 0x0024 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC10__PTC10 0x0028 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC10__FXIO1_D6 0x0028 0x021C 0x2 0x1 -#define IMX7ULP_PAD_PTC10__LPSPI2_SCK 0x0028 0x02AC 0x3 0x1 +#define IMX7ULP_PAD_PTC10__TRACE_D5 0x0028 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC10__FXIO1_D6 0x0028 0x021c 0x2 0x1 +#define IMX7ULP_PAD_PTC10__LPSPI2_SCK 0x0028 0x02ac 0x3 0x1 #define IMX7ULP_PAD_PTC10__LPUART6_TX 0x0028 0x0264 0x4 0x1 -#define IMX7ULP_PAD_PTC10__LPI2C6_HREQ 0x0028 0x02F8 0x5 0x1 -#define IMX7ULP_PAD_PTC10__TPM7_CH3 0x0028 0x02E8 0x6 0x1 +#define IMX7ULP_PAD_PTC10__LPI2C6_HREQ 0x0028 0x02f8 0x5 0x1 +#define IMX7ULP_PAD_PTC10__TPM7_CH3 0x0028 0x02e8 0x6 0x1 #define IMX7ULP_PAD_PTC10__FB_AD10 0x0028 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC10__TRACE_D5 0x0028 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTC11__PTC11 0x002C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC11__FXIO1_D7 0x002C 0x0220 0x2 0x1 -#define IMX7ULP_PAD_PTC11__LPSPI2_PCS0 0x002C 0x029C 0x3 0x1 -#define IMX7ULP_PAD_PTC11__LPUART6_RX 0x002C 0x0260 0x4 0x1 -#define IMX7ULP_PAD_PTC11__TPM7_CH4 0x002C 0x02EC 0x6 0x1 -#define IMX7ULP_PAD_PTC11__FB_AD11 0x002C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC11__TRACE_D4 0x002C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC11__PTC11 0x002c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC11__TRACE_D4 0x002c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC11__FXIO1_D7 0x002c 0x0220 0x2 0x1 +#define IMX7ULP_PAD_PTC11__LPSPI2_PCS0 0x002c 0x029c 0x3 0x1 +#define IMX7ULP_PAD_PTC11__LPUART6_RX 0x002c 0x0260 0x4 0x1 +#define IMX7ULP_PAD_PTC11__TPM7_CH4 0x002c 0x02ec 0x6 0x1 +#define IMX7ULP_PAD_PTC11__FB_AD11 0x002c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC12__PTC12 0x0030 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC12__TRACE_D3 0x0030 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC12__FXIO1_D8 0x0030 0x0224 0x2 0x1 #define IMX7ULP_PAD_PTC12__LPSPI3_PCS1 0x0030 0x0314 0x3 0x1 #define IMX7ULP_PAD_PTC12__LPUART7_CTS_B 0x0030 0x0268 0x4 0x1 #define IMX7ULP_PAD_PTC12__LPI2C7_SCL 0x0030 0x0308 0x5 0x1 -#define IMX7ULP_PAD_PTC12__TPM7_CH5 0x0030 0x02F0 0x6 0x1 +#define IMX7ULP_PAD_PTC12__TPM7_CH5 0x0030 0x02f0 0x6 0x1 #define IMX7ULP_PAD_PTC12__FB_AD12 0x0030 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC12__TRACE_D3 0x0030 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC13__PTC13 0x0034 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC13__TRACE_D2 0x0034 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC13__FXIO1_D9 0x0034 0x0228 0x2 0x1 #define IMX7ULP_PAD_PTC13__LPSPI3_PCS2 0x0034 0x0318 0x3 0x1 #define IMX7ULP_PAD_PTC13__LPUART7_RTS_B 0x0034 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTC13__LPI2C7_SDA 0x0034 0x030C 0x5 0x1 -#define IMX7ULP_PAD_PTC13__TPM7_CLKIN 0x0034 0x02F4 0x6 0x1 +#define IMX7ULP_PAD_PTC13__LPI2C7_SDA 0x0034 0x030c 0x5 0x1 +#define IMX7ULP_PAD_PTC13__TPM7_CLKIN 0x0034 0x02f4 0x6 0x1 #define IMX7ULP_PAD_PTC13__FB_AD13 0x0034 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC13__TRACE_D2 0x0034 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC13__USB0_ID 0x0034 0x0338 0xb 0x1 #define IMX7ULP_PAD_PTC14__PTC14 0x0038 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC14__FXIO1_D10 0x0038 0x022C 0x2 0x1 -#define IMX7ULP_PAD_PTC14__LPSPI3_PCS3 0x0038 0x031C 0x3 0x1 +#define IMX7ULP_PAD_PTC14__TRACE_D1 0x0038 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC14__FXIO1_D10 0x0038 0x022c 0x2 0x1 +#define IMX7ULP_PAD_PTC14__LPSPI3_PCS3 0x0038 0x031c 0x3 0x1 #define IMX7ULP_PAD_PTC14__LPUART7_TX 0x0038 0x0270 0x4 0x1 #define IMX7ULP_PAD_PTC14__LPI2C7_HREQ 0x0038 0x0304 0x5 0x1 -#define IMX7ULP_PAD_PTC14__TPM7_CH0 0x0038 0x02DC 0x6 0x1 +#define IMX7ULP_PAD_PTC14__TPM7_CH0 0x0038 0x02dc 0x6 0x1 #define IMX7ULP_PAD_PTC14__FB_AD14 0x0038 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC14__TRACE_D1 0x0038 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTC15__PTC15 0x003C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC15__FXIO1_D11 0x003C 0x0230 0x2 0x1 -#define IMX7ULP_PAD_PTC15__LPUART7_RX 0x003C 0x026C 0x4 0x1 -#define IMX7ULP_PAD_PTC15__TPM7_CH1 0x003C 0x02E0 0x6 0x1 -#define IMX7ULP_PAD_PTC15__FB_AD15 0x003C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC15__TRACE_D0 0x003C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC15__PTC15 0x003c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC15__TRACE_D0 0x003c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC15__FXIO1_D11 0x003c 0x0230 0x2 0x1 +#define IMX7ULP_PAD_PTC15__LPUART7_RX 0x003c 0x026c 0x4 0x1 +#define IMX7ULP_PAD_PTC15__TPM7_CH1 0x003c 0x02e0 0x6 0x1 +#define IMX7ULP_PAD_PTC15__FB_AD15 0x003c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC16__PTC16 0x0040 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC16__TRACE_CLKOUT 0x0040 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC16__FXIO1_D12 0x0040 0x0234 0x2 0x1 #define IMX7ULP_PAD_PTC16__LPSPI3_SIN 0x0040 0x0324 0x3 0x1 -#define IMX7ULP_PAD_PTC16__TPM7_CH2 0x0040 0x02E4 0x6 0x1 +#define IMX7ULP_PAD_PTC16__TPM7_CH2 0x0040 0x02e4 0x6 0x1 #define IMX7ULP_PAD_PTC16__FB_ALE_FB_CS1_B_FB_TS_B 0x0040 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC16__TRACE_CLKOUT 0x0040 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTC16__USB1_OC2 0x0040 0x0334 0xb 0x1 #define IMX7ULP_PAD_PTC17__PTC17 0x0044 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTC17__FXIO1_D13 0x0044 0x0238 0x2 0x1 #define IMX7ULP_PAD_PTC17__LPSPI3_SOUT 0x0044 0x0328 0x3 0x1 -#define IMX7ULP_PAD_PTC17__TPM6_CLKIN 0x0044 0x02D8 0x6 0x1 +#define IMX7ULP_PAD_PTC17__TPM6_CLKIN 0x0044 0x02d8 0x6 0x1 #define IMX7ULP_PAD_PTC17__FB_CS0_B 0x0044 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC18__PTC18 0x0048 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC18__FXIO1_D14 0x0048 0x023C 0x2 0x1 +#define IMX7ULP_PAD_PTC18__FXIO1_D14 0x0048 0x023c 0x2 0x1 #define IMX7ULP_PAD_PTC18__LPSPI3_SCK 0x0048 0x0320 0x3 0x1 -#define IMX7ULP_PAD_PTC18__TPM6_CH0 0x0048 0x02D0 0x6 0x1 +#define IMX7ULP_PAD_PTC18__TPM6_CH0 0x0048 0x02d0 0x6 0x1 #define IMX7ULP_PAD_PTC18__FB_OE_B 0x0048 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTC18__USB0_ID 0x0048 0x0338 0xb 0x2 -#define IMX7ULP_PAD_PTC18__VIU_DE 0x0048 0x033C 0xc 0x1 -#define IMX7ULP_PAD_PTC19__PTC19 0x004C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTC19__FXIO1_D15 0x004C 0x0240 0x2 0x1 -#define IMX7ULP_PAD_PTC19__LPSPI3_PCS0 0x004C 0x0310 0x3 0x1 -#define IMX7ULP_PAD_PTC19__TPM6_CH1 0x004C 0x02D4 0x6 0x1 -#define IMX7ULP_PAD_PTC19__FB_A16 0x004C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTC19__USB0_ID 0x004C 0x0338 0xa 0x3 -#define IMX7ULP_PAD_PTC19__USB1_PWR2 0x004C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTC19__VIU_DE 0x004C 0x033C 0xc 0x3 +#define IMX7ULP_PAD_PTC18__VIU_DE 0x0048 0x033c 0xc 0x1 +#define IMX7ULP_PAD_PTC19__PTC19 0x004c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC19__FXIO1_D15 0x004c 0x0240 0x2 0x1 +#define IMX7ULP_PAD_PTC19__LPSPI3_PCS0 0x004c 0x0310 0x3 0x1 +#define IMX7ULP_PAD_PTC19__TPM6_CH1 0x004c 0x02d4 0x6 0x1 +#define IMX7ULP_PAD_PTC19__FB_A16 0x004c 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC19__USB0_ID 0x004c 0x0338 0xa 0x3 +#define IMX7ULP_PAD_PTC19__USB1_PWR2 0x004c 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTC19__VIU_DE 0x004c 0x033c 0xc 0x3 #define IMX7ULP_PAD_PTD0__PTD0 0x0080 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD0__SDHC0_RESET_B 0x0080 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTD1__PTD1 0x0084 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD1__SDHC0_CMD 0x0084 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTD2__PTD2 0x0088 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD2__SDHC0_CLK 0x0088 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD3__PTD3 0x008C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD3__SDHC0_D7 0x008C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD3__PTD3 0x008c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD3__SDHC0_D7 0x008c 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTD4__PTD4 0x0090 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD4__SDHC0_D6 0x0090 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTD5__PTD5 0x0094 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD5__SDHC0_D5 0x0094 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTD6__PTD6 0x0098 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTD6__SDHC0_D4 0x0098 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD7__PTD7 0x009C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD7__SDHC0_D3 0x009C 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD8__PTD8 0x00A0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD8__TPM4_CLKIN 0x00A0 0x0298 0x6 0x2 -#define IMX7ULP_PAD_PTD8__SDHC0_D2 0x00A0 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD9__PTD9 0x00A4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD9__TPM4_CH0 0x00A4 0x0280 0x6 0x2 -#define IMX7ULP_PAD_PTD9__SDHC0_D1 0x00A4 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD10__PTD10 0x00A8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD10__TPM4_CH1 0x00A8 0x0284 0x6 0x2 -#define IMX7ULP_PAD_PTD10__SDHC0_D0 0x00A8 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTD11__PTD11 0x00AC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTD11__TPM4_CH2 0x00AC 0x0288 0x6 0x2 -#define IMX7ULP_PAD_PTD11__SDHC0_DQS 0x00AC 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD7__PTD7 0x009c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD7__SDHC0_D3 0x009c 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD8__PTD8 0x00a0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD8__TPM4_CLKIN 0x00a0 0x0298 0x6 0x2 +#define IMX7ULP_PAD_PTD8__SDHC0_D2 0x00a0 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD9__PTD9 0x00a4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD9__TPM4_CH0 0x00a4 0x0280 0x6 0x2 +#define IMX7ULP_PAD_PTD9__SDHC0_D1 0x00a4 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD10__PTD10 0x00a8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD10__TPM4_CH1 0x00a8 0x0284 0x6 0x2 +#define IMX7ULP_PAD_PTD10__SDHC0_D0 0x00a8 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD11__PTD11 0x00ac 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD11__TPM4_CH2 0x00ac 0x0288 0x6 0x2 +#define IMX7ULP_PAD_PTD11__SDHC0_DQS 0x00ac 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE0__PTE0 0x0100 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE0__FXIO1_D31 0x0100 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE0__LPSPI2_PCS1 0x0100 0x02A0 0x3 0x2 +#define IMX7ULP_PAD_PTE0__LPSPI2_PCS1 0x0100 0x02a0 0x3 0x2 #define IMX7ULP_PAD_PTE0__LPUART4_CTS_B 0x0100 0x0244 0x4 0x2 #define IMX7ULP_PAD_PTE0__LPI2C4_SCL 0x0100 0x0278 0x5 0x2 #define IMX7ULP_PAD_PTE0__SDHC1_D1 0x0100 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE0__FB_A25 0x0100 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE1__PTE1 0x0104 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE1__FXIO1_D30 0x0104 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE1__LPSPI2_PCS2 0x0104 0x02A4 0x3 0x2 +#define IMX7ULP_PAD_PTE1__LPSPI2_PCS2 0x0104 0x02a4 0x3 0x2 #define IMX7ULP_PAD_PTE1__LPUART4_RTS_B 0x0104 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTE1__LPI2C4_SDA 0x0104 0x027C 0x5 0x2 +#define IMX7ULP_PAD_PTE1__LPI2C4_SDA 0x0104 0x027c 0x5 0x2 #define IMX7ULP_PAD_PTE1__SDHC1_D0 0x0104 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE1__FB_A26 0x0104 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE2__PTE2 0x0108 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE2__FXIO1_D29 0x0108 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE2__LPSPI2_PCS3 0x0108 0x02A8 0x3 0x2 -#define IMX7ULP_PAD_PTE2__LPUART4_TX 0x0108 0x024C 0x4 0x2 +#define IMX7ULP_PAD_PTE2__LPSPI2_PCS3 0x0108 0x02a8 0x3 0x2 +#define IMX7ULP_PAD_PTE2__LPUART4_TX 0x0108 0x024c 0x4 0x2 #define IMX7ULP_PAD_PTE2__LPI2C4_HREQ 0x0108 0x0274 0x5 0x2 #define IMX7ULP_PAD_PTE2__SDHC1_CLK 0x0108 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTE3__PTE3 0x010C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTE3__FXIO1_D28 0x010C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE3__LPUART4_RX 0x010C 0x0248 0x4 0x2 -#define IMX7ULP_PAD_PTE3__TPM5_CH1 0x010C 0x02C8 0x6 0x2 -#define IMX7ULP_PAD_PTE3__SDHC1_CMD 0x010C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE3__PTE3 0x010c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE3__FXIO1_D28 0x010c 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE3__LPUART4_RX 0x010c 0x0248 0x4 0x2 +#define IMX7ULP_PAD_PTE3__TPM5_CH1 0x010c 0x02c8 0x6 0x2 +#define IMX7ULP_PAD_PTE3__SDHC1_CMD 0x010c 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE4__PTE4 0x0110 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE4__FXIO1_D27 0x0110 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE4__LPSPI2_SIN 0x0110 0x02B0 0x3 0x2 +#define IMX7ULP_PAD_PTE4__LPSPI2_SIN 0x0110 0x02b0 0x3 0x2 #define IMX7ULP_PAD_PTE4__LPUART5_CTS_B 0x0110 0x0250 0x4 0x2 -#define IMX7ULP_PAD_PTE4__LPI2C5_SCL 0x0110 0x02BC 0x5 0x2 -#define IMX7ULP_PAD_PTE4__TPM5_CLKIN 0x0110 0x02CC 0x6 0x2 +#define IMX7ULP_PAD_PTE4__LPI2C5_SCL 0x0110 0x02bc 0x5 0x2 +#define IMX7ULP_PAD_PTE4__TPM5_CLKIN 0x0110 0x02cc 0x6 0x2 #define IMX7ULP_PAD_PTE4__SDHC1_D3 0x0110 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE5__PTE5 0x0114 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE5__FXIO1_D26 0x0114 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE5__LPSPI2_SOUT 0x0114 0x02B4 0x3 0x2 +#define IMX7ULP_PAD_PTE5__LPSPI2_SOUT 0x0114 0x02b4 0x3 0x2 #define IMX7ULP_PAD_PTE5__LPUART5_RTS_B 0x0114 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTE5__LPI2C5_SDA 0x0114 0x02C0 0x5 0x2 -#define IMX7ULP_PAD_PTE5__TPM5_CH0 0x0114 0x02C4 0x6 0x2 +#define IMX7ULP_PAD_PTE5__LPI2C5_SDA 0x0114 0x02c0 0x5 0x2 +#define IMX7ULP_PAD_PTE5__TPM5_CH0 0x0114 0x02c4 0x6 0x2 #define IMX7ULP_PAD_PTE5__SDHC1_D2 0x0114 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTE5__VIU_DE 0x0114 0x033C 0xc 0x2 +#define IMX7ULP_PAD_PTE5__VIU_DE 0x0114 0x033c 0xc 0x2 #define IMX7ULP_PAD_PTE6__PTE6 0x0118 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE6__FXIO1_D25 0x0118 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE6__LPSPI2_SCK 0x0118 0x02AC 0x3 0x2 +#define IMX7ULP_PAD_PTE6__LPSPI2_SCK 0x0118 0x02ac 0x3 0x2 #define IMX7ULP_PAD_PTE6__LPUART5_TX 0x0118 0x0258 0x4 0x2 -#define IMX7ULP_PAD_PTE6__LPI2C5_HREQ 0x0118 0x02B8 0x5 0x2 -#define IMX7ULP_PAD_PTE6__TPM7_CH3 0x0118 0x02E8 0x6 0x2 +#define IMX7ULP_PAD_PTE6__LPI2C5_HREQ 0x0118 0x02b8 0x5 0x2 +#define IMX7ULP_PAD_PTE6__TPM7_CH3 0x0118 0x02e8 0x6 0x2 #define IMX7ULP_PAD_PTE6__SDHC1_D4 0x0118 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE6__FB_A17 0x0118 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE6__USB0_OC 0x0118 0x0330 0xb 0x1 -#define IMX7ULP_PAD_PTE7__PTE7 0x011C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTE7__FXIO1_D24 0x011C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE7__LPSPI2_PCS0 0x011C 0x029C 0x3 0x2 -#define IMX7ULP_PAD_PTE7__LPUART5_RX 0x011C 0x0254 0x4 0x2 -#define IMX7ULP_PAD_PTE7__TPM7_CH4 0x011C 0x02EC 0x6 0x2 -#define IMX7ULP_PAD_PTE7__SDHC1_D5 0x011C 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTE7__FB_A18 0x011C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE7__TRACE_D7 0x011C 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE7__USB0_PWR 0x011C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTE7__VIU_FID 0x011C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE7__PTE7 0x011c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE7__TRACE_D7 0x011c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE7__USB0_PWR 0x011c 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE7__VIU_FID 0x011c 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE7__FXIO1_D24 0x011c 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE7__LPSPI2_PCS0 0x011c 0x029c 0x3 0x2 +#define IMX7ULP_PAD_PTE7__LPUART5_RX 0x011c 0x0254 0x4 0x2 +#define IMX7ULP_PAD_PTE7__TPM7_CH4 0x011c 0x02ec 0x6 0x2 +#define IMX7ULP_PAD_PTE7__SDHC1_D5 0x011c 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE7__FB_A18 0x011c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE8__PTE8 0x0120 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE8__TRACE_D6 0x0120 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTE8__VIU_D16 0x0120 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE8__FXIO1_D23 0x0120 0x0000 0x2 0x0 #define IMX7ULP_PAD_PTE8__LPSPI3_PCS1 0x0120 0x0314 0x3 0x2 -#define IMX7ULP_PAD_PTE8__LPUART6_CTS_B 0x0120 0x025C 0x4 0x2 -#define IMX7ULP_PAD_PTE8__LPI2C6_SCL 0x0120 0x02FC 0x5 0x2 -#define IMX7ULP_PAD_PTE8__TPM7_CH5 0x0120 0x02F0 0x6 0x2 +#define IMX7ULP_PAD_PTE8__LPUART6_CTS_B 0x0120 0x025c 0x4 0x2 +#define IMX7ULP_PAD_PTE8__LPI2C6_SCL 0x0120 0x02fc 0x5 0x2 +#define IMX7ULP_PAD_PTE8__TPM7_CH5 0x0120 0x02f0 0x6 0x2 #define IMX7ULP_PAD_PTE8__SDHC1_WP 0x0120 0x0200 0x7 0x1 #define IMX7ULP_PAD_PTE8__SDHC1_D6 0x0120 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE8__FB_CS3_B_FB_BE7_0_BLS31_24_B 0x0120 0x0000 0x9 0x0 @@ -673,220 +259,220 @@ #define IMX7ULP_PAD_PTE9__LPSPI3_PCS2 0x0124 0x0318 0x3 0x2 #define IMX7ULP_PAD_PTE9__LPUART6_RTS_B 0x0124 0x0000 0x4 0x0 #define IMX7ULP_PAD_PTE9__LPI2C6_SDA 0x0124 0x0300 0x5 0x2 -#define IMX7ULP_PAD_PTE9__TPM7_CLKIN 0x0124 0x02F4 0x6 0x2 -#define IMX7ULP_PAD_PTE9__SDHC1_CD 0x0124 0x032C 0x7 0x1 +#define IMX7ULP_PAD_PTE9__TPM7_CLKIN 0x0124 0x02f4 0x6 0x2 +#define IMX7ULP_PAD_PTE9__SDHC1_CD 0x0124 0x032c 0x7 0x1 #define IMX7ULP_PAD_PTE9__SDHC1_D7 0x0124 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE9__FB_TBST_B_FB_CS2_B_FB_BE15_8_BLS23_16_B 0x0124 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE10__PTE10 0x0128 0x0000 0x1 0x0 #define IMX7ULP_PAD_PTE10__TRACE_D4 0x0128 0x0000 0xa 0x0 #define IMX7ULP_PAD_PTE10__VIU_D18 0x0128 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE10__FXIO1_D21 0x0128 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE10__LPSPI3_PCS3 0x0128 0x031C 0x3 0x2 +#define IMX7ULP_PAD_PTE10__LPSPI3_PCS3 0x0128 0x031c 0x3 0x2 #define IMX7ULP_PAD_PTE10__LPUART6_TX 0x0128 0x0264 0x4 0x2 -#define IMX7ULP_PAD_PTE10__LPI2C6_HREQ 0x0128 0x02F8 0x5 0x2 -#define IMX7ULP_PAD_PTE10__TPM7_CH0 0x0128 0x02DC 0x6 0x2 +#define IMX7ULP_PAD_PTE10__LPI2C6_HREQ 0x0128 0x02f8 0x5 0x2 +#define IMX7ULP_PAD_PTE10__TPM7_CH0 0x0128 0x02dc 0x6 0x2 #define IMX7ULP_PAD_PTE10__SDHC1_VS 0x0128 0x0000 0x7 0x0 #define IMX7ULP_PAD_PTE10__SDHC1_DQS 0x0128 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE10__FB_A19 0x0128 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE11__PTE11 0x012C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTE11__TRACE_D3 0x012C 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE11__VIU_D19 0x012C 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTE11__FXIO1_D20 0x012C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE11__LPUART6_RX 0x012C 0x0260 0x4 0x2 -#define IMX7ULP_PAD_PTE11__TPM7_CH1 0x012C 0x02E0 0x6 0x2 -#define IMX7ULP_PAD_PTE11__SDHC1_RESET_B 0x012C 0x0000 0x8 0x0 -#define IMX7ULP_PAD_PTE11__FB_A20 0x012C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE11__PTE11 0x012c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE11__TRACE_D3 0x012c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE11__VIU_D19 0x012c 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE11__FXIO1_D20 0x012c 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE11__LPUART6_RX 0x012c 0x0260 0x4 0x2 +#define IMX7ULP_PAD_PTE11__TPM7_CH1 0x012c 0x02e0 0x6 0x2 +#define IMX7ULP_PAD_PTE11__SDHC1_RESET_B 0x012c 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE11__FB_A20 0x012c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTE12__PTE12 0x0130 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE12__TRACE_D2 0x0130 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE12__USB1_OC2 0x0130 0x0334 0xb 0x2 +#define IMX7ULP_PAD_PTE12__VIU_D20 0x0130 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE12__FXIO1_D19 0x0130 0x0000 0x2 0x0 #define IMX7ULP_PAD_PTE12__LPSPI3_SIN 0x0130 0x0324 0x3 0x2 #define IMX7ULP_PAD_PTE12__LPUART7_CTS_B 0x0130 0x0268 0x4 0x2 #define IMX7ULP_PAD_PTE12__LPI2C7_SCL 0x0130 0x0308 0x5 0x2 -#define IMX7ULP_PAD_PTE12__TPM7_CH2 0x0130 0x02E4 0x6 0x2 +#define IMX7ULP_PAD_PTE12__TPM7_CH2 0x0130 0x02e4 0x6 0x2 #define IMX7ULP_PAD_PTE12__SDHC1_WP 0x0130 0x0200 0x8 0x2 #define IMX7ULP_PAD_PTE12__FB_A21 0x0130 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE12__TRACE_D2 0x0130 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE12__USB1_OC2 0x0130 0x0334 0xb 0x2 -#define IMX7ULP_PAD_PTE12__VIU_D20 0x0130 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE13__PTE13 0x0134 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE13__TRACE_D1 0x0134 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE13__USB1_PWR2 0x0134 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE13__VIU_D21 0x0134 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE13__FXIO1_D18 0x0134 0x0000 0x2 0x0 #define IMX7ULP_PAD_PTE13__LPSPI3_SOUT 0x0134 0x0328 0x3 0x2 #define IMX7ULP_PAD_PTE13__LPUART7_RTS_B 0x0134 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTE13__LPI2C7_SDA 0x0134 0x030C 0x5 0x2 -#define IMX7ULP_PAD_PTE13__TPM6_CLKIN 0x0134 0x02D8 0x6 0x2 -#define IMX7ULP_PAD_PTE13__SDHC1_CD 0x0134 0x032C 0x8 0x2 +#define IMX7ULP_PAD_PTE13__LPI2C7_SDA 0x0134 0x030c 0x5 0x2 +#define IMX7ULP_PAD_PTE13__TPM6_CLKIN 0x0134 0x02d8 0x6 0x2 +#define IMX7ULP_PAD_PTE13__SDHC1_CD 0x0134 0x032c 0x8 0x2 #define IMX7ULP_PAD_PTE13__FB_A22 0x0134 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE13__TRACE_D1 0x0134 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE13__USB1_PWR2 0x0134 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTE13__VIU_D21 0x0134 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE14__PTE14 0x0138 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE14__TRACE_D0 0x0138 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE14__USB0_OC 0x0138 0x0330 0xb 0x2 +#define IMX7ULP_PAD_PTE14__VIU_D22 0x0138 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTE14__FXIO1_D17 0x0138 0x0000 0x2 0x0 #define IMX7ULP_PAD_PTE14__LPSPI3_SCK 0x0138 0x0320 0x3 0x2 #define IMX7ULP_PAD_PTE14__LPUART7_TX 0x0138 0x0270 0x4 0x2 #define IMX7ULP_PAD_PTE14__LPI2C7_HREQ 0x0138 0x0304 0x5 0x2 -#define IMX7ULP_PAD_PTE14__TPM6_CH0 0x0138 0x02D0 0x6 0x2 +#define IMX7ULP_PAD_PTE14__TPM6_CH0 0x0138 0x02d0 0x6 0x2 #define IMX7ULP_PAD_PTE14__SDHC1_VS 0x0138 0x0000 0x8 0x0 #define IMX7ULP_PAD_PTE14__FB_A23 0x0138 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE14__TRACE_D0 0x0138 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE14__USB0_OC 0x0138 0x0330 0xb 0x2 -#define IMX7ULP_PAD_PTE14__VIU_D22 0x0138 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTE15__PTE15 0x013C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTE15__FXIO1_D16 0x013C 0x0000 0x2 0x0 -#define IMX7ULP_PAD_PTE15__LPSPI3_PCS0 0x013C 0x0310 0x3 0x2 -#define IMX7ULP_PAD_PTE15__LPUART7_RX 0x013C 0x026C 0x4 0x2 -#define IMX7ULP_PAD_PTE15__TPM6_CH1 0x013C 0x02D4 0x6 0x2 -#define IMX7ULP_PAD_PTE15__FB_A24 0x013C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTE15__TRACE_CLKOUT 0x013C 0x0000 0xa 0x0 -#define IMX7ULP_PAD_PTE15__USB0_PWR 0x013C 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTE15__VIU_D23 0x013C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE15__PTE15 0x013c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE15__TRACE_CLKOUT 0x013c 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE15__USB0_PWR 0x013c 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE15__VIU_D23 0x013c 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE15__FXIO1_D16 0x013c 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE15__LPSPI3_PCS0 0x013c 0x0310 0x3 0x2 +#define IMX7ULP_PAD_PTE15__LPUART7_RX 0x013c 0x026c 0x4 0x2 +#define IMX7ULP_PAD_PTE15__TPM6_CH1 0x013c 0x02d4 0x6 0x2 +#define IMX7ULP_PAD_PTE15__FB_A24 0x013c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTF0__PTF0 0x0180 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF0__VIU_DE 0x0180 0x033c 0xc 0x0 #define IMX7ULP_PAD_PTF0__LPUART4_CTS_B 0x0180 0x0244 0x4 0x3 #define IMX7ULP_PAD_PTF0__LPI2C4_SCL 0x0180 0x0278 0x5 0x3 #define IMX7ULP_PAD_PTF0__TPM4_CLKIN 0x0180 0x0298 0x6 0x3 #define IMX7ULP_PAD_PTF0__FB_RW_B 0x0180 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF0__VIU_DE 0x0180 0x033C 0xc 0x0 #define IMX7ULP_PAD_PTF1__PTF1 0x0184 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF1__VIU_HSYNC 0x0184 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF1__LPUART4_RTS_B 0x0184 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTF1__LPI2C4_SDA 0x0184 0x027C 0x5 0x3 +#define IMX7ULP_PAD_PTF1__LPI2C4_SDA 0x0184 0x027c 0x5 0x3 #define IMX7ULP_PAD_PTF1__TPM4_CH0 0x0184 0x0280 0x6 0x3 #define IMX7ULP_PAD_PTF1__CLKOUT 0x0184 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF1__VIU_HSYNC 0x0184 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF2__PTF2 0x0188 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF2__LPUART4_TX 0x0188 0x024C 0x4 0x3 +#define IMX7ULP_PAD_PTF2__VIU_VSYNC 0x0188 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF2__LPUART4_TX 0x0188 0x024c 0x4 0x3 #define IMX7ULP_PAD_PTF2__LPI2C4_HREQ 0x0188 0x0274 0x5 0x3 #define IMX7ULP_PAD_PTF2__TPM4_CH1 0x0188 0x0284 0x6 0x3 #define IMX7ULP_PAD_PTF2__FB_TSIZ1_FB_CS5_B_FB_BE23_16_BLS15_8_B 0x0188 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF2__VIU_VSYNC 0x0188 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF3__PTF3 0x018C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF3__LPUART4_RX 0x018C 0x0248 0x4 0x3 -#define IMX7ULP_PAD_PTF3__TPM4_CH2 0x018C 0x0288 0x6 0x3 -#define IMX7ULP_PAD_PTF3__FB_AD16 0x018C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF3__VIU_PCLK 0x018C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF3__PTF3 0x018c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF3__VIU_PCLK 0x018c 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF3__LPUART4_RX 0x018c 0x0248 0x4 0x3 +#define IMX7ULP_PAD_PTF3__TPM4_CH2 0x018c 0x0288 0x6 0x3 +#define IMX7ULP_PAD_PTF3__FB_AD16 0x018c 0x0000 0x9 0x0 #define IMX7ULP_PAD_PTF4__PTF4 0x0190 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF4__VIU_D0 0x0190 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF4__FXIO1_D0 0x0190 0x0204 0x2 0x2 -#define IMX7ULP_PAD_PTF4__LPSPI2_PCS1 0x0190 0x02A0 0x3 0x3 +#define IMX7ULP_PAD_PTF4__LPSPI2_PCS1 0x0190 0x02a0 0x3 0x3 #define IMX7ULP_PAD_PTF4__LPUART5_CTS_B 0x0190 0x0250 0x4 0x3 -#define IMX7ULP_PAD_PTF4__LPI2C5_SCL 0x0190 0x02BC 0x5 0x3 -#define IMX7ULP_PAD_PTF4__TPM4_CH3 0x0190 0x028C 0x6 0x2 +#define IMX7ULP_PAD_PTF4__LPI2C5_SCL 0x0190 0x02bc 0x5 0x3 +#define IMX7ULP_PAD_PTF4__TPM4_CH3 0x0190 0x028c 0x6 0x2 #define IMX7ULP_PAD_PTF4__FB_AD17 0x0190 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF4__VIU_D0 0x0190 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF5__PTF5 0x0194 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF5__VIU_D1 0x0194 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF5__FXIO1_D1 0x0194 0x0208 0x2 0x2 -#define IMX7ULP_PAD_PTF5__LPSPI2_PCS2 0x0194 0x02A4 0x3 0x3 +#define IMX7ULP_PAD_PTF5__LPSPI2_PCS2 0x0194 0x02a4 0x3 0x3 #define IMX7ULP_PAD_PTF5__LPUART5_RTS_B 0x0194 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTF5__LPI2C5_SDA 0x0194 0x02C0 0x5 0x3 +#define IMX7ULP_PAD_PTF5__LPI2C5_SDA 0x0194 0x02c0 0x5 0x3 #define IMX7ULP_PAD_PTF5__TPM4_CH4 0x0194 0x0290 0x6 0x2 #define IMX7ULP_PAD_PTF5__FB_AD18 0x0194 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF5__VIU_D1 0x0194 0x0000 0xc 0x0 #define IMX7ULP_PAD_PTF6__PTF6 0x0198 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF6__FXIO1_D2 0x0198 0x020C 0x2 0x2 -#define IMX7ULP_PAD_PTF6__LPSPI2_PCS3 0x0198 0x02A8 0x3 0x3 +#define IMX7ULP_PAD_PTF6__VIU_D2 0x0198 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF6__FXIO1_D2 0x0198 0x020c 0x2 0x2 +#define IMX7ULP_PAD_PTF6__LPSPI2_PCS3 0x0198 0x02a8 0x3 0x3 #define IMX7ULP_PAD_PTF6__LPUART5_TX 0x0198 0x0258 0x4 0x3 -#define IMX7ULP_PAD_PTF6__LPI2C5_HREQ 0x0198 0x02B8 0x5 0x3 +#define IMX7ULP_PAD_PTF6__LPI2C5_HREQ 0x0198 0x02b8 0x5 0x3 #define IMX7ULP_PAD_PTF6__TPM4_CH5 0x0198 0x0294 0x6 0x2 #define IMX7ULP_PAD_PTF6__FB_AD19 0x0198 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF6__VIU_D2 0x0198 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF7__PTF7 0x019C 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF7__FXIO1_D3 0x019C 0x0210 0x2 0x2 -#define IMX7ULP_PAD_PTF7__LPUART5_RX 0x019C 0x0254 0x4 0x3 -#define IMX7ULP_PAD_PTF7__TPM5_CH1 0x019C 0x02C8 0x6 0x3 -#define IMX7ULP_PAD_PTF7__FB_AD20 0x019C 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF7__VIU_D3 0x019C 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF8__PTF8 0x01A0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF8__FXIO1_D4 0x01A0 0x0214 0x2 0x2 -#define IMX7ULP_PAD_PTF8__LPSPI2_SIN 0x01A0 0x02B0 0x3 0x3 -#define IMX7ULP_PAD_PTF8__LPUART6_CTS_B 0x01A0 0x025C 0x4 0x3 -#define IMX7ULP_PAD_PTF8__LPI2C6_SCL 0x01A0 0x02FC 0x5 0x3 -#define IMX7ULP_PAD_PTF8__TPM5_CLKIN 0x01A0 0x02CC 0x6 0x3 -#define IMX7ULP_PAD_PTF8__FB_AD21 0x01A0 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF8__USB1_CLK 0x01A0 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF8__VIU_D4 0x01A0 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF9__PTF9 0x01A4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF9__FXIO1_D5 0x01A4 0x0218 0x2 0x2 -#define IMX7ULP_PAD_PTF9__LPSPI2_SOUT 0x01A4 0x02B4 0x3 0x3 -#define IMX7ULP_PAD_PTF9__LPUART6_RTS_B 0x01A4 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTF9__LPI2C6_SDA 0x01A4 0x0300 0x5 0x3 -#define IMX7ULP_PAD_PTF9__TPM5_CH0 0x01A4 0x02C4 0x6 0x3 -#define IMX7ULP_PAD_PTF9__FB_AD22 0x01A4 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF9__USB1_NXT 0x01A4 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF9__VIU_D5 0x01A4 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF10__PTF10 0x01A8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF10__FXIO1_D6 0x01A8 0x021C 0x2 0x2 -#define IMX7ULP_PAD_PTF10__LPSPI2_SCK 0x01A8 0x02AC 0x3 0x3 -#define IMX7ULP_PAD_PTF10__LPUART6_TX 0x01A8 0x0264 0x4 0x3 -#define IMX7ULP_PAD_PTF10__LPI2C6_HREQ 0x01A8 0x02F8 0x5 0x3 -#define IMX7ULP_PAD_PTF10__TPM7_CH3 0x01A8 0x02E8 0x6 0x3 -#define IMX7ULP_PAD_PTF10__FB_AD23 0x01A8 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF10__USB1_STP 0x01A8 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF10__VIU_D6 0x01A8 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF11__PTF11 0x01AC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF11__FXIO1_D7 0x01AC 0x0220 0x2 0x2 -#define IMX7ULP_PAD_PTF11__LPSPI2_PCS0 0x01AC 0x029C 0x3 0x3 -#define IMX7ULP_PAD_PTF11__LPUART6_RX 0x01AC 0x0260 0x4 0x3 -#define IMX7ULP_PAD_PTF11__TPM7_CH4 0x01AC 0x02EC 0x6 0x3 -#define IMX7ULP_PAD_PTF11__FB_CS4_B_FB_TSIZ0_FB_BE31_24_BLS7_0_B 0x01AC 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF11__USB1_DIR 0x01AC 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF11__VIU_D7 0x01AC 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF12__PTF12 0x01B0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF12__FXIO1_D8 0x01B0 0x0224 0x2 0x2 -#define IMX7ULP_PAD_PTF12__LPSPI3_PCS1 0x01B0 0x0314 0x3 0x3 -#define IMX7ULP_PAD_PTF12__LPUART7_CTS_B 0x01B0 0x0268 0x4 0x3 -#define IMX7ULP_PAD_PTF12__LPI2C7_SCL 0x01B0 0x0308 0x5 0x3 -#define IMX7ULP_PAD_PTF12__TPM7_CH5 0x01B0 0x02F0 0x6 0x3 -#define IMX7ULP_PAD_PTF12__FB_AD24 0x01B0 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF12__USB1_DATA0 0x01B0 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF12__VIU_D8 0x01B0 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF13__PTF13 0x01B4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF13__FXIO1_D9 0x01B4 0x0228 0x2 0x2 -#define IMX7ULP_PAD_PTF13__LPSPI3_PCS2 0x01B4 0x0318 0x3 0x3 -#define IMX7ULP_PAD_PTF13__LPUART7_RTS_B 0x01B4 0x0000 0x4 0x0 -#define IMX7ULP_PAD_PTF13__LPI2C7_SDA 0x01B4 0x030C 0x5 0x3 -#define IMX7ULP_PAD_PTF13__TPM7_CLKIN 0x01B4 0x02F4 0x6 0x3 -#define IMX7ULP_PAD_PTF13__FB_AD25 0x01B4 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF13__USB1_DATA1 0x01B4 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF13__VIU_D9 0x01B4 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF14__PTF14 0x01B8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF14__FXIO1_D10 0x01B8 0x022C 0x2 0x2 -#define IMX7ULP_PAD_PTF14__LPSPI3_PCS3 0x01B8 0x031C 0x3 0x3 -#define IMX7ULP_PAD_PTF14__LPUART7_TX 0x01B8 0x0270 0x4 0x3 -#define IMX7ULP_PAD_PTF14__LPI2C7_HREQ 0x01B8 0x0304 0x5 0x3 -#define IMX7ULP_PAD_PTF14__TPM7_CH0 0x01B8 0x02DC 0x6 0x3 -#define IMX7ULP_PAD_PTF14__FB_AD26 0x01B8 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF14__USB1_DATA2 0x01B8 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF14__VIU_D10 0x01B8 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF15__PTF15 0x01BC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF15__FXIO1_D11 0x01BC 0x0230 0x2 0x2 -#define IMX7ULP_PAD_PTF15__LPUART7_RX 0x01BC 0x026C 0x4 0x3 -#define IMX7ULP_PAD_PTF15__TPM7_CH1 0x01BC 0x02E0 0x6 0x3 -#define IMX7ULP_PAD_PTF15__FB_AD27 0x01BC 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF15__USB1_DATA3 0x01BC 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF15__VIU_D11 0x01BC 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF16__PTF16 0x01C0 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF16__USB1_DATA4 0x01C0 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF16__VIU_D12 0x01C0 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF16__FXIO1_D12 0x01C0 0x0234 0x2 0x2 -#define IMX7ULP_PAD_PTF16__LPSPI3_SIN 0x01C0 0x0324 0x3 0x3 -#define IMX7ULP_PAD_PTF16__TPM7_CH2 0x01C0 0x02E4 0x6 0x3 -#define IMX7ULP_PAD_PTF16__FB_AD28 0x01C0 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF17__PTF17 0x01C4 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF17__USB1_DATA5 0x01C4 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF17__VIU_D13 0x01C4 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF17__FXIO1_D13 0x01C4 0x0238 0x2 0x2 -#define IMX7ULP_PAD_PTF17__LPSPI3_SOUT 0x01C4 0x0328 0x3 0x3 -#define IMX7ULP_PAD_PTF17__TPM6_CLKIN 0x01C4 0x02D8 0x6 0x3 -#define IMX7ULP_PAD_PTF17__FB_AD29 0x01C4 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF18__PTF18 0x01C8 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF18__USB1_DATA6 0x01C8 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF18__VIU_D14 0x01C8 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF18__FXIO1_D14 0x01C8 0x023C 0x2 0x2 -#define IMX7ULP_PAD_PTF18__LPSPI3_SCK 0x01C8 0x0320 0x3 0x3 -#define IMX7ULP_PAD_PTF18__TPM6_CH0 0x01C8 0x02D0 0x6 0x3 -#define IMX7ULP_PAD_PTF18__FB_AD30 0x01C8 0x0000 0x9 0x0 -#define IMX7ULP_PAD_PTF19__PTF19 0x01CC 0x0000 0x1 0x0 -#define IMX7ULP_PAD_PTF19__USB1_DATA7 0x01CC 0x0000 0xb 0x0 -#define IMX7ULP_PAD_PTF19__VIU_D15 0x01CC 0x0000 0xc 0x0 -#define IMX7ULP_PAD_PTF19__FXIO1_D15 0x01CC 0x0240 0x2 0x2 -#define IMX7ULP_PAD_PTF19__LPSPI3_PCS0 0x01CC 0x0310 0x3 0x3 -#define IMX7ULP_PAD_PTF19__TPM6_CH1 0x01CC 0x02D4 0x6 0x3 -#define IMX7ULP_PAD_PTF19__FB_AD31 0x01CC 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF7__PTF7 0x019c 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF7__VIU_D3 0x019c 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF7__FXIO1_D3 0x019c 0x0210 0x2 0x2 +#define IMX7ULP_PAD_PTF7__LPUART5_RX 0x019c 0x0254 0x4 0x3 +#define IMX7ULP_PAD_PTF7__TPM5_CH1 0x019c 0x02c8 0x6 0x3 +#define IMX7ULP_PAD_PTF7__FB_AD20 0x019c 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF8__PTF8 0x01a0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF8__USB1_ULPI_CLK 0x01a0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF8__VIU_D4 0x01a0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF8__FXIO1_D4 0x01a0 0x0214 0x2 0x2 +#define IMX7ULP_PAD_PTF8__LPSPI2_SIN 0x01a0 0x02b0 0x3 0x3 +#define IMX7ULP_PAD_PTF8__LPUART6_CTS_B 0x01a0 0x025c 0x4 0x3 +#define IMX7ULP_PAD_PTF8__LPI2C6_SCL 0x01a0 0x02fc 0x5 0x3 +#define IMX7ULP_PAD_PTF8__TPM5_CLKIN 0x01a0 0x02cc 0x6 0x3 +#define IMX7ULP_PAD_PTF8__FB_AD21 0x01a0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF9__PTF9 0x01a4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF9__USB1_ULPI_NXT 0x01a4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF9__VIU_D5 0x01a4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF9__FXIO1_D5 0x01a4 0x0218 0x2 0x2 +#define IMX7ULP_PAD_PTF9__LPSPI2_SOUT 0x01a4 0x02b4 0x3 0x3 +#define IMX7ULP_PAD_PTF9__LPUART6_RTS_B 0x01a4 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF9__LPI2C6_SDA 0x01a4 0x0300 0x5 0x3 +#define IMX7ULP_PAD_PTF9__TPM5_CH0 0x01a4 0x02c4 0x6 0x3 +#define IMX7ULP_PAD_PTF9__FB_AD22 0x01a4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF10__PTF10 0x01a8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF10__USB1_ULPI_STP 0x01a8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF10__VIU_D6 0x01a8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF10__FXIO1_D6 0x01a8 0x021c 0x2 0x2 +#define IMX7ULP_PAD_PTF10__LPSPI2_SCK 0x01a8 0x02ac 0x3 0x3 +#define IMX7ULP_PAD_PTF10__LPUART6_TX 0x01a8 0x0264 0x4 0x3 +#define IMX7ULP_PAD_PTF10__LPI2C6_HREQ 0x01a8 0x02f8 0x5 0x3 +#define IMX7ULP_PAD_PTF10__TPM7_CH3 0x01a8 0x02e8 0x6 0x3 +#define IMX7ULP_PAD_PTF10__FB_AD23 0x01a8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF11__PTF11 0x01ac 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF11__USB1_ULPI_DIR 0x01ac 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF11__VIU_D7 0x01ac 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF11__FXIO1_D7 0x01ac 0x0220 0x2 0x2 +#define IMX7ULP_PAD_PTF11__LPSPI2_PCS0 0x01ac 0x029c 0x3 0x3 +#define IMX7ULP_PAD_PTF11__LPUART6_RX 0x01ac 0x0260 0x4 0x3 +#define IMX7ULP_PAD_PTF11__TPM7_CH4 0x01ac 0x02ec 0x6 0x3 +#define IMX7ULP_PAD_PTF11__FB_CS4_B_FB_TSIZ0_FB_BE31_24_BLS7_0_B 0x01ac 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF12__PTF12 0x01b0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF12__USB1_ULPI_DATA0 0x01b0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF12__VIU_D8 0x01b0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF12__FXIO1_D8 0x01b0 0x0224 0x2 0x2 +#define IMX7ULP_PAD_PTF12__LPSPI3_PCS1 0x01b0 0x0314 0x3 0x3 +#define IMX7ULP_PAD_PTF12__LPUART7_CTS_B 0x01b0 0x0268 0x4 0x3 +#define IMX7ULP_PAD_PTF12__LPI2C7_SCL 0x01b0 0x0308 0x5 0x3 +#define IMX7ULP_PAD_PTF12__TPM7_CH5 0x01b0 0x02f0 0x6 0x3 +#define IMX7ULP_PAD_PTF12__FB_AD24 0x01b0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF13__PTF13 0x01b4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF13__USB1_ULPI_DATA1 0x01b4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF13__VIU_D9 0x01b4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF13__FXIO1_D9 0x01b4 0x0228 0x2 0x2 +#define IMX7ULP_PAD_PTF13__LPSPI3_PCS2 0x01b4 0x0318 0x3 0x3 +#define IMX7ULP_PAD_PTF13__LPUART7_RTS_B 0x01b4 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF13__LPI2C7_SDA 0x01b4 0x030c 0x5 0x3 +#define IMX7ULP_PAD_PTF13__TPM7_CLKIN 0x01b4 0x02f4 0x6 0x3 +#define IMX7ULP_PAD_PTF13__FB_AD25 0x01b4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF14__PTF14 0x01b8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF14__USB1_ULPI_DATA2 0x01b8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF14__VIU_D10 0x01b8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF14__FXIO1_D10 0x01b8 0x022c 0x2 0x2 +#define IMX7ULP_PAD_PTF14__LPSPI3_PCS3 0x01b8 0x031c 0x3 0x3 +#define IMX7ULP_PAD_PTF14__LPUART7_TX 0x01b8 0x0270 0x4 0x3 +#define IMX7ULP_PAD_PTF14__LPI2C7_HREQ 0x01b8 0x0304 0x5 0x3 +#define IMX7ULP_PAD_PTF14__TPM7_CH0 0x01b8 0x02dc 0x6 0x3 +#define IMX7ULP_PAD_PTF14__FB_AD26 0x01b8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF15__PTF15 0x01bc 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF15__USB1_ULPI_DATA3 0x01bc 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF15__VIU_D11 0x01bc 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF15__FXIO1_D11 0x01bc 0x0230 0x2 0x2 +#define IMX7ULP_PAD_PTF15__LPUART7_RX 0x01bc 0x026c 0x4 0x3 +#define IMX7ULP_PAD_PTF15__TPM7_CH1 0x01bc 0x02e0 0x6 0x3 +#define IMX7ULP_PAD_PTF15__FB_AD27 0x01bc 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF16__PTF16 0x01c0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF16__USB1_ULPI_DATA4 0x01c0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF16__VIU_D12 0x01c0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF16__FXIO1_D12 0x01c0 0x0234 0x2 0x2 +#define IMX7ULP_PAD_PTF16__LPSPI3_SIN 0x01c0 0x0324 0x3 0x3 +#define IMX7ULP_PAD_PTF16__TPM7_CH2 0x01c0 0x02e4 0x6 0x3 +#define IMX7ULP_PAD_PTF16__FB_AD28 0x01c0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF17__PTF17 0x01c4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF17__USB1_ULPI_DATA5 0x01c4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF17__VIU_D13 0x01c4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF17__FXIO1_D13 0x01c4 0x0238 0x2 0x2 +#define IMX7ULP_PAD_PTF17__LPSPI3_SOUT 0x01c4 0x0328 0x3 0x3 +#define IMX7ULP_PAD_PTF17__TPM6_CLKIN 0x01c4 0x02d8 0x6 0x3 +#define IMX7ULP_PAD_PTF17__FB_AD29 0x01c4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF18__PTF18 0x01c8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF18__USB1_ULPI_DATA6 0x01c8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF18__VIU_D14 0x01c8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF18__FXIO1_D14 0x01c8 0x023c 0x2 0x2 +#define IMX7ULP_PAD_PTF18__LPSPI3_SCK 0x01c8 0x0320 0x3 0x3 +#define IMX7ULP_PAD_PTF18__TPM6_CH0 0x01c8 0x02d0 0x6 0x3 +#define IMX7ULP_PAD_PTF18__FB_AD30 0x01c8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF19__PTF19 0x01cc 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF19__USB1_ULPI_DATA7 0x01cc 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF19__VIU_D15 0x01cc 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF19__FXIO1_D15 0x01cc 0x0240 0x2 0x2 +#define IMX7ULP_PAD_PTF19__LPSPI3_PCS0 0x01cc 0x0310 0x3 0x3 +#define IMX7ULP_PAD_PTF19__TPM6_CH1 0x01cc 0x02d4 0x6 0x3 +#define IMX7ULP_PAD_PTF19__FB_AD31 0x01cc 0x0000 0x9 0x0
#endif /* __DTS_IMX7ULP_PINFUNC_H */ diff --git a/arch/arm/dts/imx7ulp.dtsi b/arch/arm/dts/imx7ulp.dtsi index 494b9d98b2..bcec98b964 100644 --- a/arch/arm/dts/imx7ulp.dtsi +++ b/arch/arm/dts/imx7ulp.dtsi @@ -1,28 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2015-2016 Freescale Semiconductor, Inc. - * Copyright 2021 NXP - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2017-2018 NXP + * Dong Aisheng aisheng.dong@nxp.com */
#include <dt-bindings/clock/imx7ulp-clock.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/gpio/gpio.h> -#include "skeleton.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> + #include "imx7ulp-pinfunc.h"
/ { interrupt-parent = <&intc>;
+ #address-cells = <1>; + #size-cells = <1>; + aliases { - gpio0 = &gpio4; - gpio1 = &gpio5; - gpio2 = &gpio0; - gpio3 = &gpio1; - gpio4 = &gpio2; - gpio5 = &gpio3; + gpio0 = &gpio_ptc; + gpio1 = &gpio_ptd; + gpio2 = &gpio_pte; + gpio3 = &gpio_ptf; + i2c0 = &lpi2c6; + i2c1 = &lpi2c7; mmc0 = &usdhc0; mmc1 = &usdhc1; serial0 = &lpuart4; @@ -30,44 +31,17 @@ serial2 = &lpuart6; serial3 = &lpuart7; usbphy0 = &usbphy1; - usb0 = &usbotg1; - i2c4 = &lpi2c4; - i2c5 = &lpi2c5; - i2c6 = &lpi2c6; - i2c7 = &lpi2c7; - spi0 = &qspi1; };
cpus { #address-cells = <1>; #size-cells = <0>;
- cpu0: cpu@0 { + cpu0: cpu@f00 { compatible = "arm,cortex-a7"; device_type = "cpu"; - reg = <0>; - }; - }; - - reserved-memory { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - /* global autoconfigured region for contiguous allocations */ - linux,cma { - compatible = "shared-dma-pool"; - reusable; - size = <0xC000000>; - alignment = <0x2000>; - linux,cma-default; - }; - - rpmsg_reserved: rpmsg@9FFF0000 { - no-map; - reg = <0x9FF00000 0x100000>; + reg = <0xf00>; }; - };
intc: interrupt-controller@40021000 { @@ -75,128 +49,77 @@ #interrupt-cells = <3>; interrupt-controller; reg = <0x40021000 0x1000>, - <0x40022000 0x100>; + <0x40022000 0x1000>; };
- clocks { - #address-cells = <1>; - #size-cells = <0>; - - ckil: clock@0 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "ckil"; - }; - - osc: clock@1 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "osc"; - }; - - sirc: clock@2 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <16000000>; - clock-output-names = "sirc"; - }; + rosc: clock-rosc { + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "rosc"; + #clock-cells = <0>; + };
- firc: clock@3 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <48000000>; - clock-output-names = "firc"; - }; + sosc: clock-sosc { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "sosc"; + #clock-cells = <0>; + };
- upll: clock@4 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <480000000>; - clock-output-names = "upll"; - }; + sirc: clock-sirc { + compatible = "fixed-clock"; + clock-frequency = <16000000>; + clock-output-names = "sirc"; + #clock-cells = <0>; + };
- mpll: clock@5 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <480000000>; - clock-output-names = "mpll"; - }; + firc: clock-firc { + compatible = "fixed-clock"; + clock-frequency = <48000000>; + clock-output-names = "firc"; + #clock-cells = <0>; };
- sram: sram@20000000 { - compatible = "fsl,lpm-sram"; - reg = <0x1fffc000 0x4000>; + upll: clock-upll { + compatible = "fixed-clock"; + clock-frequency = <480000000>; + clock-output-names = "upll"; + #clock-cells = <0>; };
- ahbbridge0: ahb-bridge0@40000000 { - compatible = "fsl,aips-bus", "simple-bus"; + ahbbridge0: bus@40000000 { + compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x40000000 0x800000>; ranges;
- edma0: dma-controller@40080000 { + edma1: dma-controller@40080000 { #dma-cells = <2>; - compatible = "nxp,imx7ulp-edma"; + compatible = "fsl,imx7ulp-edma"; reg = <0x40080000 0x2000>, <0x40210000 0x1000>; dma-channels = <32>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clock-names = "dma", "dmamux0"; - clocks = <&clks IMX7ULP_CLK_DMA1>, <&clks IMX7ULP_CLK_DMA_MUX1>; - }; - - mu: mu@40220000 { - compatible = "fsl,imx7ulp-mu", "fsl,imx6sx-mu"; - reg = <0x40220000 0x1000>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - status = "okay"; - }; - - nmi: nmi@40220000 { - compatible = "fsl,imx7ulp-nmi"; - reg = <0x40220000 0x1000>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - status = "okay"; - }; - - rpmsg: rpmsg{ - compatible = "fsl,imx7ulp-rpmsg"; - memory-region = <&rpmsg_reserved>; - status = "disabled"; - }; - - snvs: snvs@40230000 { - compatible = "fsl,sec-v4.0-mon","syscon", "simple-mfd"; - reg = <0x40230000 0x10000>; - - snvs_rtc: snvs-rtc-lp{ - compatible = "fsl,sec-v4.0-mon-rtc-lp"; - regmap =<&snvs>; - offset = <0x34>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "snvs-rtc"; - clocks = <&clks IMX7ULP_CLK_SNVS>; - }; + clocks = <&pcc2 IMX7ULP_CLK_DMA1>, + <&pcc2 IMX7ULP_CLK_DMA_MUX1>; };
crypto: crypto@40240000 { @@ -205,8 +128,8 @@ #size-cells = <1>; reg = <0x40240000 0x10000>; ranges = <0 0x40240000 0x10000>; - clocks = <&clks IMX7ULP_CLK_CAAM>, - <&clks IMX7ULP_CLK_NIC1_BUS_DIV>; + clocks = <&pcc2 IMX7ULP_CLK_CAAM>, + <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>; clock-names = "aclk", "ipg";
sec_jr0: jr@1000 { @@ -222,105 +145,55 @@ }; };
- tpm5: tpm@40260000 { - compatible = "fsl,imx7ulp-tpm"; - reg = <0x40260000 0x1000>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPTPM5>; - }; - - lpit: 1@40270000 { - compatible = "fsl,imx-lpit"; - reg = <0x40270000 0x1000>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - /* clocks = <&lpclk>;*/ - clocks = <&clks IMX7ULP_CLK_LPIT1>; - assigned-clock-rates = <48000000>; - assigned-clocks = <&clks IMX7ULP_CLK_LPIT1>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - }; - - lpi2c4: lpi2c4@402B0000 { - compatible = "fsl,imx7ulp-lpi2c"; - reg = <0x402B0000 0x10000>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPI2C4>; - clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPI2C4>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - assigned-clock-rates = <48000000>; - status = "disabled"; - }; - - lpi2c5: lpi2c4@402C0000 { - compatible = "fsl,imx7ulp-lpi2c"; - reg = <0x402C0000 0x10000>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPI2C5>; - clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPI2C5>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - assigned-clock-rates = <48000000>; - status = "disabled"; - }; - - lpspi2: lpspi@40290000 { - compatible = "fsl,imx7ulp-spi"; - reg = <0x40290000 0x10000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPSPI2>; - clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPSPI2>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - assigned-clock-rates = <48000000>; - status = "disabled"; - }; - - lpspi3: lpspi@402A0000 { - compatible = "fsl,imx7ulp-spi"; - reg = <0x402A0000 0x10000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPSPI3>; - clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPSPI3>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - assigned-clock-rates = <48000000>; - status = "disabled"; - }; - - lpuart4: serial@402D0000 { + lpuart4: serial@402d0000 { compatible = "fsl,imx7ulp-lpuart"; - reg = <0x402D0000 0x1000>; + reg = <0x402d0000 0x1000>; interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPUART4>; + clocks = <&pcc2 IMX7ULP_CLK_LPUART4>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPUART4>; - assigned-clock-parents = <&clks IMX7ULP_CLK_OSC>; + assigned-clocks = <&pcc2 IMX7ULP_CLK_LPUART4>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_SOSC_BUS_CLK>; assigned-clock-rates = <24000000>; status = "disabled"; };
- lpuart5: serial@402E0000 { + lpuart5: serial@402e0000 { compatible = "fsl,imx7ulp-lpuart"; - reg = <0x402E0000 0x1000>; + reg = <0x402e0000 0x1000>; interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPUART5>; + clocks = <&pcc2 IMX7ULP_CLK_LPUART5>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPUART5>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; + assigned-clocks = <&pcc2 IMX7ULP_CLK_LPUART5>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC>; assigned-clock-rates = <48000000>; - dmas = <&edma0 0 20>, <&edma0 0 19>; - dma-names = "tx","rx"; status = "disabled"; };
+ tpm4: pwm@40250000 { + compatible = "fsl,imx7ulp-pwm"; + reg = <0x40250000 0x1000>; + assigned-clocks = <&pcc2 IMX7ULP_CLK_LPTPM4>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_SOSC_BUS_CLK>; + clocks = <&pcc2 IMX7ULP_CLK_LPTPM4>; + #pwm-cells = <3>; + status = "disabled"; + }; + + tpm5: tpm@40260000 { + compatible = "fsl,imx7ulp-tpm"; + reg = <0x40260000 0x1000>; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>, + <&pcc2 IMX7ULP_CLK_LPTPM5>; + clock-names = "ipg", "per"; + }; + usbotg1: usb@40330000 { - compatible = "fsl,imx7ulp-usb", "fsl,imx6ul-usb", - "fsl,imx27-usb"; + compatible = "fsl,imx7ulp-usb", "fsl,imx6ul-usb"; reg = <0x40330000 0x200>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_USB0>; - fsl,usbphy = <&usbphy1>; + clocks = <&pcc2 IMX7ULP_CLK_USB0>; + phys = <&usbphy1>; fsl,usbmisc = <&usbmisc1 0>; ahb-burst-config = <0x0>; tx-burst-size-dword = <0x8>; @@ -329,314 +202,260 @@ };
usbmisc1: usbmisc@40330200 { + compatible = "fsl,imx7ulp-usbmisc", "fsl,imx7d-usbmisc"; #index-cells = <1>; - compatible = "fsl,imx7ulp-usbmisc", "fsl,imx7d-usbmisc", - "fsl,imx6q-usbmisc"; reg = <0x40330200 0x200>; };
- usbphy1: usbphy@0x40350000 { - compatible = "fsl,imx7ulp-usbphy", - "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; + usbphy1: usb-phy@40350000 { + compatible = "fsl,imx7ulp-usbphy", "fsl,imx6ul-usbphy"; reg = <0x40350000 0x1000>; interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_USB_PHY>; - nxp,sim = <&sim>; + clocks = <&pcc2 IMX7ULP_CLK_USB_PHY>; + #phy-cells = <0>; };
- usdhc0: usdhc@40370000 { - compatible = "fsl,imx7ulp-usdhc"; + usdhc0: mmc@40370000 { + compatible = "fsl,imx7ulp-usdhc", "fsl,imx6sx-usdhc"; reg = <0x40370000 0x10000>; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_NIC1_BUS_DIV>, - <&clks IMX7ULP_CLK_NIC1_DIV>, - <&clks IMX7ULP_CLK_USDHC0>; - clock-names ="ipg", "ahb", "per"; + clocks = <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>, + <&scg1 IMX7ULP_CLK_NIC1_DIV>, + <&pcc2 IMX7ULP_CLK_USDHC0>; + clock-names = "ipg", "ahb", "per"; bus-width = <4>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; status = "disabled"; };
- usdhc1: usdhc@40380000 { - compatible = "fsl,imx7ulp-usdhc"; + usdhc1: mmc@40380000 { + compatible = "fsl,imx7ulp-usdhc", "fsl,imx6sx-usdhc"; reg = <0x40380000 0x10000>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_NIC1_BUS_DIV>, - <&clks IMX7ULP_CLK_NIC1_DIV>, - <&clks IMX7ULP_CLK_USDHC1>; - clock-names ="ipg", "ahb", "per"; + clocks = <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>, + <&scg1 IMX7ULP_CLK_NIC1_DIV>, + <&pcc2 IMX7ULP_CLK_USDHC1>; + clock-names = "ipg", "ahb", "per"; bus-width = <4>; fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; + fsl,tuning-step = <2>; status = "disabled"; };
- wdog1: wdog@403D0000 { - compatible = "fsl,imx7ulp-wdt"; - reg = <0x403D0000 0x10000>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_WDG1>; - assigned-clocks = <&clks IMX7ULP_CLK_WDG1>; - assigned-clocks-parents = <&clks IMX7ULP_CLK_FIRC>; - /* - * As the 1KHz LPO clock rate is not trimed,the actually clock - * is about 667Hz, so the init timeout 60s should set 40*1000 - * in the TOVAL register. - */ - timeout-sec = <40>; + scg1: clock-controller@403e0000 { + compatible = "fsl,imx7ulp-scg1"; + reg = <0x403e0000 0x10000>; + clocks = <&rosc>, <&sosc>, <&sirc>, + <&firc>, <&upll>; + clock-names = "rosc", "sosc", "sirc", + "firc", "upll"; + #clock-cells = <1>; };
- wdog2: wdog@40430000 { + wdog1: watchdog@403d0000 { compatible = "fsl,imx7ulp-wdt"; - reg = <0x40430000 0x10000>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_WDG2>; - assigned-clocks = <&clks IMX7ULP_CLK_WDG2>; - assigned-clocks-parents = <&clks IMX7ULP_CLK_FIRC>; + reg = <0x403d0000 0x10000>; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pcc2 IMX7ULP_CLK_WDG1>; + assigned-clocks = <&pcc2 IMX7ULP_CLK_WDG1>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC_BUS_CLK>; timeout-sec = <40>; };
- clks: scg1@403E0000 { - compatible = "fsl,imx7ulp-scg1"; - reg = <0x403E0000 0x10000>; - clocks = <&ckil>, <&osc>, <&sirc>, - <&firc>, <&upll>, <&mpll>; - clock-names = "ckil", "osc", "sirc", - "firc", "upll", "mpll"; + pcc2: clock-controller@403f0000 { + compatible = "fsl,imx7ulp-pcc2"; + reg = <0x403f0000 0x10000>; #clock-cells = <1>; - assigned-clocks = <&clks IMX7ULP_CLK_LPTPM5>, - <&clks IMX7ULP_CLK_USDHC1>; - assigned-clock-parents = <&clks IMX7ULP_CLK_OSC>, - <&clks IMX7ULP_CLK_NIC1_DIV>; - }; - - pcc2: pcc2@403F0000 { - compatible = "fsl,imx7ulp-pcc2"; - reg = <0x403F0000 0x10000>; - }; - - pmc1: pmc1@40400000 { - compatible = "fsl,imx7ulp-pmc1"; - reg = <0x40400000 0x1000>; - }; - - smc1: smc1@40410000 { + clocks = <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>, + <&scg1 IMX7ULP_CLK_NIC1_DIV>, + <&scg1 IMX7ULP_CLK_DDR_DIV>, + <&scg1 IMX7ULP_CLK_APLL_PFD2>, + <&scg1 IMX7ULP_CLK_APLL_PFD1>, + <&scg1 IMX7ULP_CLK_APLL_PFD0>, + <&scg1 IMX7ULP_CLK_UPLL>, + <&scg1 IMX7ULP_CLK_SOSC_BUS_CLK>, + <&scg1 IMX7ULP_CLK_FIRC_BUS_CLK>, + <&scg1 IMX7ULP_CLK_ROSC>, + <&scg1 IMX7ULP_CLK_SPLL_BUS_CLK>; + clock-names = "nic1_bus_clk", "nic1_clk", "ddr_clk", + "apll_pfd2", "apll_pfd1", "apll_pfd0", + "upll", "sosc_bus_clk", + "firc_bus_clk", "rosc", "spll_bus_clk"; + assigned-clocks = <&pcc2 IMX7ULP_CLK_LPTPM5>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_SOSC_BUS_CLK>; + }; + + smc1: clock-controller@40410000 { compatible = "fsl,imx7ulp-smc1"; reg = <0x40410000 0x1000>; + #clock-cells = <1>; + clocks = <&scg1 IMX7ULP_CLK_CORE_DIV>, + <&scg1 IMX7ULP_CLK_HSRUN_CORE_DIV>; + clock-names = "divcore", "hsrun_divcore"; };
+ pcc3: clock-controller@40b30000 { + compatible = "fsl,imx7ulp-pcc3"; + reg = <0x40b30000 0x10000>; + #clock-cells = <1>; + clocks = <&scg1 IMX7ULP_CLK_NIC1_BUS_DIV>, + <&scg1 IMX7ULP_CLK_NIC1_DIV>, + <&scg1 IMX7ULP_CLK_DDR_DIV>, + <&scg1 IMX7ULP_CLK_APLL_PFD2>, + <&scg1 IMX7ULP_CLK_APLL_PFD1>, + <&scg1 IMX7ULP_CLK_APLL_PFD0>, + <&scg1 IMX7ULP_CLK_UPLL>, + <&scg1 IMX7ULP_CLK_SOSC_BUS_CLK>, + <&scg1 IMX7ULP_CLK_FIRC_BUS_CLK>, + <&scg1 IMX7ULP_CLK_ROSC>, + <&scg1 IMX7ULP_CLK_SPLL_BUS_CLK>; + clock-names = "nic1_bus_clk", "nic1_clk", "ddr_clk", + "apll_pfd2", "apll_pfd1", "apll_pfd0", + "upll", "sosc_bus_clk", + "firc_bus_clk", "rosc", "spll_bus_clk"; + }; };
- ahbbridge1: ahb-bridge1@40800000 { - compatible = "fsl,aips-bus", "simple-bus"; + ahbbridge1: bus@40800000 { + compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x40800000 0x800000>; ranges;
- lpi2c6: lpi2c6@40A40000 { + lpi2c6: i2c@40a40000 { compatible = "fsl,imx7ulp-lpi2c"; - reg = <0x40A40000 0x10000>; + reg = <0x40a40000 0x10000>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPI2C6>; + clocks = <&pcc3 IMX7ULP_CLK_LPI2C6>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPI2C6>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; + assigned-clocks = <&pcc3 IMX7ULP_CLK_LPI2C6>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC>; assigned-clock-rates = <48000000>; status = "disabled"; };
- lpi2c7: lpi2c7@40A50000 { + lpi2c7: i2c@40a50000 { compatible = "fsl,imx7ulp-lpi2c"; - reg = <0x40A50000 0x10000>; + reg = <0x40a50000 0x10000>; interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPI2C7>; + clocks = <&pcc3 IMX7ULP_CLK_LPI2C7>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPI2C7>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; + assigned-clocks = <&pcc3 IMX7ULP_CLK_LPI2C7>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC>; assigned-clock-rates = <48000000>; status = "disabled"; };
- lpuart6: serial@40A60000 { + lpuart6: serial@40a60000 { compatible = "fsl,imx7ulp-lpuart"; - reg = <0x40A60000 0x1000>; + reg = <0x40a60000 0x1000>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPUART6>; + clocks = <&pcc3 IMX7ULP_CLK_LPUART6>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPUART6>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; + assigned-clocks = <&pcc3 IMX7ULP_CLK_LPUART6>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC>; assigned-clock-rates = <48000000>; - dmas = <&edma0 0 22>, <&edma0 0 21>; - dma-names = "tx","rx"; status = "disabled"; };
- lpuart7: serial@40A70000 { + lpuart7: serial@40a70000 { compatible = "fsl,imx7ulp-lpuart"; - reg = <0x40A70000 0x1000>; + reg = <0x40a70000 0x1000>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_LPUART7>; + clocks = <&pcc3 IMX7ULP_CLK_LPUART7>; clock-names = "ipg"; - assigned-clocks = <&clks IMX7ULP_CLK_LPUART7>; - assigned-clock-parents = <&clks IMX7ULP_CLK_FIRC>; - assigned-clock-rates = <50000000>; - dmas = <&edma0 0 24>, <&edma0 0 23>; - dma-names = "tx","rx"; - status = "disabled"; - }; - - lcdif: lcdif@40AA0000 { - compatible = "fsl,imx7ulp-lcdif"; - reg = <0x40aa0000 0x10000>; - interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_DUMMY>, - <&clks IMX7ULP_CLK_LCDIF>, - <&clks IMX7ULP_CLK_DUMMY>; - clock-names = "axi", "pix", "disp_axi"; - status = "disabled"; - }; - - mipi_dsi: mipi_dsi@40A90000 { - compatible = "fsl,imx7ulp-mipi-dsi"; - reg = <0x40A90000 0x10000>; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_DSI>; - clock-names = "mipi_dsi_clk"; - sim = <&sim>; + assigned-clocks = <&pcc3 IMX7ULP_CLK_LPUART7>; + assigned-clock-parents = <&scg1 IMX7ULP_CLK_FIRC>; + assigned-clock-rates = <48000000>; status = "disabled"; };
- mmdc: mmdc@40ab0000 { - compatible = "fsl,imx7ulp-mmdc"; - reg = <0x40ab0000 0x4000>; + memory-controller@40ab0000 { + compatible = "fsl,imx7ulp-mmdc", "fsl,imx6q-mmdc"; + reg = <0x40ab0000 0x1000>; + clocks = <&pcc3 IMX7ULP_CLK_MMDC>; };
- pcc3: pcc3@40B30000 { - compatible = "fsl,imx7ulp-pcc3"; - reg = <0x40B30000 0x10000>; - }; - - iomuxc: iomuxc@4103D000 { - compatible = "fsl,imx7ulp-iomuxc-0"; - reg = <0x4103D000 0x1000>; - fsl,mux_mask = <0xf00>; - status = "disabled"; - }; - - iomuxc1: iomuxc1@40ac0000 { - compatible = "fsl,imx7ulp-iomuxc-1"; + iomuxc1: pinctrl@40ac0000 { + compatible = "fsl,imx7ulp-iomuxc1"; reg = <0x40ac0000 0x1000>; - fsl,mux_mask = <0xf00>; };
- gpio4: gpio@4103f000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x4103f000 0x1000 0x4100F000 0x40>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&iomuxc 0 0 32>; - }; - - gpio5: gpio@41040000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x41040000 0x1000 0x4100F040 0x40>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&iomuxc 0 32 32>; - }; - - gpio0: gpio@40ae0000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x40ae0000 0x1000 0x400F0000 0x40>; + gpio_ptc: gpio@40ae0000 { + compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; + reg = <0x40ae0000 0x1000 0x400f0000 0x40>; gpio-controller; #gpio-cells = <2>; interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; - gpio-ranges = <&iomuxc1 0 0 32>; + clocks = <&pcc2 IMX7ULP_CLK_RGPIO2P1>, + <&pcc3 IMX7ULP_CLK_PCTLC>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 0 20>; };
- gpio1: gpio@40af0000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x40af0000 0x1000 0x400F0040 0x40>; + gpio_ptd: gpio@40af0000 { + compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; + reg = <0x40af0000 0x1000 0x400f0040 0x40>; gpio-controller; #gpio-cells = <2>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; - gpio-ranges = <&iomuxc1 0 32 32>; + clocks = <&pcc2 IMX7ULP_CLK_RGPIO2P1>, + <&pcc3 IMX7ULP_CLK_PCTLD>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 32 12>; };
- gpio2: gpio@40b00000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x40b00000 0x1000 0x400F0080 0x40>; + gpio_pte: gpio@40b00000 { + compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; + reg = <0x40b00000 0x1000 0x400f0080 0x40>; gpio-controller; #gpio-cells = <2>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; - gpio-ranges = <&iomuxc1 0 64 32>; + clocks = <&pcc2 IMX7ULP_CLK_RGPIO2P1>, + <&pcc3 IMX7ULP_CLK_PCTLE>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 64 16>; };
- gpio3: gpio@40b10000 { - compatible = "fsl,imx7ulp-gpio"; - reg = <0x40b10000 0x1000 0x400F00c0 0x40>; + gpio_ptf: gpio@40b10000 { + compatible = "fsl,imx7ulp-gpio", "fsl,vf610-gpio"; + reg = <0x40b10000 0x1000 0x400f00c0 0x40>; gpio-controller; #gpio-cells = <2>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; interrupt-controller; #interrupt-cells = <2>; - gpio-ranges = <&iomuxc1 0 96 32>; + clocks = <&pcc2 IMX7ULP_CLK_RGPIO2P1>, + <&pcc3 IMX7ULP_CLK_PCTLF>; + clock-names = "gpio", "port"; + gpio-ranges = <&iomuxc1 0 96 20>; }; + };
- pmc0: pmc0@410a1000 { - compatible = "fsl,imx7ulp-pmc0"; - reg = <0x410a1000 0x1000>; - }; + m4aips1: bus@41080000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x41080000 0x80000>; + ranges;
sim: sim@410a3000 { compatible = "fsl,imx7ulp-sim", "syscon"; reg = <0x410a3000 0x1000>; };
- qspi1: qspi@410A5000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7ulp-qspi"; - reg = <0x410A5000 0x10000>, <0xC0000000 0x10000000>; - reg-names = "QuadSPI", "QuadSPI-memory"; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7ULP_CLK_DUMMY>, - <&clks IMX7ULP_CLK_DUMMY>; - clock-names = "qspi_en", "qspi"; - status = "disabled"; - }; - - gpu: gpu@41800000 { - compatible = "fsl,imx6q-gpu"; - reg = <0x41800000 0x80000>, <0x41880000 0x80000>, - <0x60000000 0x40000000>, <0x0 0x4000000>; - reg-names = "iobase_3d", "iobase_2d", - "phys_baseaddr", "contiguous_mem"; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "irq_3d", "irq_2d"; - clocks = <&clks IMX7ULP_CLK_GPU3D>, - <&clks IMX7ULP_CLK_NIC1_DIV>, - <&clks IMX7ULP_CLK_GPU_DIV>, - <&clks IMX7ULP_CLK_GPU2D>, - <&clks IMX7ULP_CLK_NIC1_DIV>, - <&clks IMX7ULP_CLK_NIC1_DIV>; - clock-names = "gpu3d_clk", "gpu3d_shader_clk", - "gpu3d_axi_clk", "gpu2d_clk", - "gpu2d_shader_clk", "gpu2d_axi_clk"; + ocotp: efuse@410a6000 { + compatible = "fsl,imx7ulp-ocotp", "syscon"; + reg = <0x410a6000 0x4000>; + clocks = <&scg1 IMX7ULP_CLK_DUMMY>; }; }; - - imx_ion { - compatible = "fsl,mxc-ion"; - fsl,heap-id = <0>; - }; }; diff --git a/include/dt-bindings/clock/imx7ulp-clock.h b/include/dt-bindings/clock/imx7ulp-clock.h index 0a955df4ad..b58370d146 100644 --- a/include/dt-bindings/clock/imx7ulp-clock.h +++ b/include/dt-bindings/clock/imx7ulp-clock.h @@ -1,21 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright (C) 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright 2017~2018 NXP * */
#ifndef __DT_BINDINGS_CLOCK_IMX7ULP_H #define __DT_BINDINGS_CLOCK_IMX7ULP_H
+/* SCG1 */ + #define IMX7ULP_CLK_DUMMY 0 -#define IMX7ULP_CLK_CKIL 1 -#define IMX7ULP_CLK_OSC 2 +#define IMX7ULP_CLK_ROSC 1 +#define IMX7ULP_CLK_SOSC 2 #define IMX7ULP_CLK_FIRC 3 - -/* SCG1 */ #define IMX7ULP_CLK_SPLL_PRE_SEL 4 #define IMX7ULP_CLK_SPLL_PRE_DIV 5 #define IMX7ULP_CLK_SPLL 6 @@ -51,111 +49,71 @@ #define IMX7ULP_CLK_NIC1_DIV 36 #define IMX7ULP_CLK_NIC1_BUS_DIV 37 #define IMX7ULP_CLK_NIC1_EXT_DIV 38 +/* IMX7ULP_CLK_MIPI_PLL is unsupported and shouldn't be used in DT */ +#define IMX7ULP_CLK_MIPI_PLL 39 +#define IMX7ULP_CLK_SIRC 40 +#define IMX7ULP_CLK_SOSC_BUS_CLK 41 +#define IMX7ULP_CLK_FIRC_BUS_CLK 42 +#define IMX7ULP_CLK_SPLL_BUS_CLK 43 +#define IMX7ULP_CLK_HSRUN_SYS_SEL 44 +#define IMX7ULP_CLK_HSRUN_CORE_DIV 45
-/* PCG2 */ -#define IMX7ULP_CLK_DMA1 39 -#define IMX7ULP_CLK_RGPIO2P1 40 -#define IMX7ULP_CLK_FLEXBUS 41 -#define IMX7ULP_CLK_SEMA42_1 42 -#define IMX7ULP_CLK_DMA_MUX1 43 -#define IMX7ULP_CLK_SNVS 44 -#define IMX7ULP_CLK_CAAM 45 -#define IMX7ULP_CLK_LPTPM4 46 -#define IMX7ULP_CLK_LPTPM5 47 -#define IMX7ULP_CLK_LPIT1 48 -#define IMX7ULP_CLK_LPSPI2 49 -#define IMX7ULP_CLK_LPSPI3 50 -#define IMX7ULP_CLK_LPI2C4 51 -#define IMX7ULP_CLK_LPI2C5 52 -#define IMX7ULP_CLK_LPUART4 53 -#define IMX7ULP_CLK_LPUART5 54 -#define IMX7ULP_CLK_FLEXIO1 55 -#define IMX7ULP_CLK_USB0 56 -#define IMX7ULP_CLK_USB1 57 -#define IMX7ULP_CLK_USB_PHY 58 -#define IMX7ULP_CLK_USB_PL301 59 -#define IMX7ULP_CLK_USDHC0 60 -#define IMX7ULP_CLK_USDHC1 61 -#define IMX7ULP_CLK_WDG1 62 -#define IMX7ULP_CLK_WDG2 63 - -/* PCG3 */ -#define IMX7ULP_CLK_LPTPM6 64 -#define IMX7ULP_CLK_LPTPM7 65 -#define IMX7ULP_CLK_LPI2C6 66 -#define IMX7ULP_CLK_LPI2C7 67 -#define IMX7ULP_CLK_LPUART6 68 -#define IMX7ULP_CLK_LPUART7 69 -#define IMX7ULP_CLK_VIU 70 -#define IMX7ULP_CLK_DSI 71 -#define IMX7ULP_CLK_LCDIF 72 -#define IMX7ULP_CLK_MMDC 73 -#define IMX7ULP_CLK_PCTLC 74 -#define IMX7ULP_CLK_PCTLD 75 -#define IMX7ULP_CLK_PCTLE 76 -#define IMX7ULP_CLK_PCTLF 77 -#define IMX7ULP_CLK_GPU3D 78 -#define IMX7ULP_CLK_GPU2D 79 - -#define IMX7ULP_CLK_MIPI_PLL 80 -#define IMX7ULP_CLK_SIRC 81 +#define IMX7ULP_CLK_CORE 46 +#define IMX7ULP_CLK_HSRUN_CORE 47
-#define IMX7ULP_CLK_SCG1_CLKOUT 82 +#define IMX7ULP_CLK_SCG1_END 48
-#define IMX7ULP_CLK_END 83 +/* PCC2 */ +#define IMX7ULP_CLK_DMA1 0 +#define IMX7ULP_CLK_RGPIO2P1 1 +#define IMX7ULP_CLK_FLEXBUS 2 +#define IMX7ULP_CLK_SEMA42_1 3 +#define IMX7ULP_CLK_DMA_MUX1 4 +#define IMX7ULP_CLK_CAAM 6 +#define IMX7ULP_CLK_LPTPM4 7 +#define IMX7ULP_CLK_LPTPM5 8 +#define IMX7ULP_CLK_LPIT1 9 +#define IMX7ULP_CLK_LPSPI2 10 +#define IMX7ULP_CLK_LPSPI3 11 +#define IMX7ULP_CLK_LPI2C4 12 +#define IMX7ULP_CLK_LPI2C5 13 +#define IMX7ULP_CLK_LPUART4 14 +#define IMX7ULP_CLK_LPUART5 15 +#define IMX7ULP_CLK_FLEXIO1 16 +#define IMX7ULP_CLK_USB0 17 +#define IMX7ULP_CLK_USB1 18 +#define IMX7ULP_CLK_USB_PHY 19 +#define IMX7ULP_CLK_USB_PL301 20 +#define IMX7ULP_CLK_USDHC0 21 +#define IMX7ULP_CLK_USDHC1 22 +#define IMX7ULP_CLK_WDG1 23 +#define IMX7ULP_CLK_WDG2 24
-/*cm4 clocks*/ -#define IMX7ULP_CM4_CLK_DUMMY 0 -#define IMX7ULP_CM4_CLK_CKIL 1 -#define IMX7ULP_CM4_CLK_OSC 2 -#define IMX7ULP_CM4_CLK_FIRC 3 -#define IMX7ULP_CM4_CLK_SIRC 4 +#define IMX7ULP_CLK_PCC2_END 25
-/* SCG0 */ -#define IMX7ULP_CM4_CLK_SPLL_VCO_PRE_SEL 5 -#define IMX7ULP_CM4_CLK_SPLL_VCO_PRE_DIV 6 -#define IMX7ULP_CM4_CLK_SPLL 7 -#define IMX7ULP_CM4_CLK_SPLL_VCO 8 -#define IMX7ULP_CM4_CLK_SPLL_VCO_POST_DIV1 9 -#define IMX7ULP_CM4_CLK_SPLL_VCO_POST_DIV2 10 -#define IMX7ULP_CM4_CLK_SPLL_PFD0 11 -#define IMX7ULP_CM4_CLK_SPLL_PFD1 12 -#define IMX7ULP_CM4_CLK_SPLL_PFD2 13 -#define IMX7ULP_CM4_CLK_SPLL_PFD3 14 -#define IMX7ULP_CM4_CLK_SPLL_PFD_SEL 15 -#define IMX7ULP_CM4_CLK_SPLL_PFD 16 -#define IMX7ULP_CM4_CLK_SPLL_SEL 17 -#define IMX7ULP_CM4_CLK_APLL_VCO_PRE_SEL 18 -#define IMX7ULP_CM4_CLK_APLL_VCO_PRE_DIV 19 -#define IMX7ULP_CM4_CLK_APLL 20 -#define IMX7ULP_CM4_CLK_APLL_VCO 21 -#define IMX7ULP_CM4_CLK_APLL_VCO_POST_DIV1 22 -#define IMX7ULP_CM4_CLK_APLL_VCO_POST_DIV2 23 -#define IMX7ULP_CM4_CLK_APLL_PFD0 24 -#define IMX7ULP_CM4_CLK_APLL_PFD1 25 -#define IMX7ULP_CM4_CLK_APLL_PFD2 26 -#define IMX7ULP_CM4_CLK_APLL_PFD3 27 -#define IMX7ULP_CM4_CLK_APLL_PFD_SEL 28 -#define IMX7ULP_CM4_CLK_APLL_PFD 29 -#define IMX7ULP_CM4_CLK_APLL_SEL 30 -#define IMX7ULP_CM4_CLK_APLL_PFD0_PRE_DIV 31 -#define IMX7ULP_CM4_CLK_SYS_SEL 32 -#define IMX7ULP_CM4_CLK_CORE_DIV 33 -#define IMX7ULP_CM4_CLK_BUS_DIV 34 -#define IMX7ULP_CM4_CLK_PLAT_DIV 35 -#define IMX7ULP_CM4_CLK_SLOW_DIV 36 +/* PCC3 */ +#define IMX7ULP_CLK_LPTPM6 0 +#define IMX7ULP_CLK_LPTPM7 1 +#define IMX7ULP_CLK_LPI2C6 2 +#define IMX7ULP_CLK_LPI2C7 3 +#define IMX7ULP_CLK_LPUART6 4 +#define IMX7ULP_CLK_LPUART7 5 +#define IMX7ULP_CLK_VIU 6 +#define IMX7ULP_CLK_DSI 7 +#define IMX7ULP_CLK_LCDIF 8 +#define IMX7ULP_CLK_MMDC 9 +#define IMX7ULP_CLK_PCTLC 10 +#define IMX7ULP_CLK_PCTLD 11 +#define IMX7ULP_CLK_PCTLE 12 +#define IMX7ULP_CLK_PCTLF 13 +#define IMX7ULP_CLK_GPU3D 14 +#define IMX7ULP_CLK_GPU2D 15
-#define IMX7ULP_CM4_CLK_SAI0_SEL 37 -#define IMX7ULP_CM4_CLK_SAI0_DIV 38 -#define IMX7ULP_CM4_CLK_SAI0_ROOT 39 -#define IMX7ULP_CM4_CLK_SAI0_IPG 40 -#define IMX7ULP_CM4_CLK_SAI1_SEL 41 -#define IMX7ULP_CM4_CLK_SAI1_DIV 42 -#define IMX7ULP_CM4_CLK_SAI1_ROOT 43 -#define IMX7ULP_CM4_CLK_SAI1_IPG 44 +#define IMX7ULP_CLK_PCC3_END 16
-#define IMX7ULP_CLK_SCG0_CLKOUT 45 +/* SMC1 */ +#define IMX7ULP_CLK_ARM 0
-#define IMX7ULP_CM4_CLK_END 46 +#define IMX7ULP_CLK_SMC1_END 1
#endif /* __DT_BINDINGS_CLOCK_IMX7ULP_H */
From: Marcel Ziswiler marcel.ziswiler@toradex.com Synchronise device tree with linux v6.0-rc1. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
include/dt-bindings/reset/imx7-reset.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/dt-bindings/reset/imx7-reset.h b/include/dt-bindings/reset/imx7-reset.h index bb92452ffb..a5b35b4754 100644 --- a/include/dt-bindings/reset/imx7-reset.h +++ b/include/dt-bindings/reset/imx7-reset.h @@ -50,3 +50,4 @@ #define IMX7_RESET_NUM 26
#endif +
arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi | 2 +- arch/arm/dts/imx6ul-phytec-segin.dtsi | 5 ---- arch/arm/dts/imx6ul.dtsi | 36 +++++++++++------------ 3 files changed, 19 insertions(+), 24 deletions(-)
diff --git a/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi b/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi index 3bd6edb42e..301838d2d0 100644 --- a/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi +++ b/arch/arm/dts/imx6ul-14x14-evk-u-boot.dtsi @@ -8,7 +8,7 @@ display0 = &lcdif; };
-&{/soc} { +&soc { u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/imx6ul-phytec-segin.dtsi b/arch/arm/dts/imx6ul-phytec-segin.dtsi index 0d4ba9494c..38ea4dcfa2 100644 --- a/arch/arm/dts/imx6ul-phytec-segin.dtsi +++ b/arch/arm/dts/imx6ul-phytec-segin.dtsi @@ -83,11 +83,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_adc1>; vref-supply = <®_adc1_vref_3v3>; - /* - * driver can not separate a specific channel so we request 4 channels - * here - we need only the fourth channel - */ - num-channels = <4>; status = "disabled"; };
diff --git a/arch/arm/dts/imx6ul.dtsi b/arch/arm/dts/imx6ul.dtsi index afeec01f65..c95efd1d8c 100644 --- a/arch/arm/dts/imx6ul.dtsi +++ b/arch/arm/dts/imx6ul.dtsi @@ -64,20 +64,18 @@ clock-frequency = <696000000>; clock-latency = <61036>; /* two CLK32 periods */ #cooling-cells = <2>; - operating-points = < + operating-points = /* kHz uV */ - 696000 1275000 - 528000 1175000 - 396000 1025000 - 198000 950000 - >; - fsl,soc-operating-points = < + <696000 1275000>, + <528000 1175000>, + <396000 1025000>, + <198000 950000>; + fsl,soc-operating-points = /* KHz uV */ - 696000 1275000 - 528000 1175000 - 396000 1175000 - 198000 1175000 - >; + <696000 1275000>, + <528000 1175000>, + <396000 1175000>, + <198000 1175000>; clocks = <&clks IMX6UL_CLK_ARM>, <&clks IMX6UL_CLK_PLL2_BUS>, <&clks IMX6UL_CLK_PLL2_PFD2>, @@ -139,7 +137,7 @@ interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; };
- soc { + soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; @@ -149,6 +147,9 @@ ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x20000>; + ranges = <0 0x00900000 0x20000>; + #address-cells = <1>; + #size-cells = <1>; };
intc: interrupt-controller@a01000 { @@ -543,7 +544,7 @@ };
kpp: keypad@20b8000 { - compatible = "fsl,imx6ul-kpp", "fsl,imx6q-kpp", "fsl,imx21-kpp"; + compatible = "fsl,imx6ul-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_KPP>; @@ -923,7 +924,6 @@ reg = <0x02198000 0x4000>; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_ADC1>; - num-channels = <2>; clock-names = "adc"; fsl,adck-max-frequency = <30000000>, <40000000>, <20000000>; @@ -998,7 +998,7 @@ };
csi: csi@21c4000 { - compatible = "fsl,imx6ul-csi", "fsl,imx7-csi"; + compatible = "fsl,imx6ul-csi"; reg = <0x021c4000 0x4000>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_CSI>; @@ -1007,7 +1007,7 @@ };
lcdif: lcdif@21c8000 { - compatible = "fsl,imx6ul-lcdif", "fsl,imx28-lcdif"; + compatible = "fsl,imx6ul-lcdif", "fsl,imx6sx-lcdif"; reg = <0x021c8000 0x4000>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_LCDIF_PIX>, @@ -1028,7 +1028,7 @@ qspi: spi@21e0000 { #address-cells = <1>; #size-cells = <0>; - compatible = "fsl,imx6ul-qspi", "fsl,imx6sx-qspi"; + compatible = "fsl,imx6ul-qspi"; reg = <0x021e0000 0x4000>, <0x60000000 0x10000000>; reg-names = "QuadSPI", "QuadSPI-memory"; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
arch/arm/dts/imx6ull-colibri.dtsi | 10 +++++++--- arch/arm/dts/imx6ull.dtsi | 2 +- 2 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx6ull-colibri.dtsi b/arch/arm/dts/imx6ull-colibri.dtsi index 15621e03fa..577a424b0e 100644 --- a/arch/arm/dts/imx6ull-colibri.dtsi +++ b/arch/arm/dts/imx6ull-colibri.dtsi @@ -94,7 +94,6 @@ };
&adc1 { - num-channels = <10>; vref-supply = <®_module_3v3_avdd>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_adc1>; @@ -166,7 +165,7 @@ atmel_mxt_ts: touchscreen@4a { compatible = "atmel,maxtouch"; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_atmel_conn>; + pinctrl-0 = <&pinctrl_atmel_conn &pinctrl_atmel_snvs_conn>; reg = <0x4a>; interrupt-parent = <&gpio5>; interrupts = <4 IRQ_TYPE_EDGE_FALLING>; /* SODIMM 107 / INT */ @@ -331,7 +330,6 @@ pinctrl_atmel_conn: atmelconngrp { fsl,pins = < MX6UL_PAD_JTAG_MOD__GPIO1_IO10 0xb0a0 /* SODIMM 106 */ - MX6ULL_PAD_SNVS_TAMPER4__GPIO5_IO04 0xb0a0 /* SODIMM 107 */ >; };
@@ -684,6 +682,12 @@ };
&iomuxc_snvs { + pinctrl_atmel_snvs_conn: atmelsnvsconngrp { + fsl,pins = < + MX6ULL_PAD_SNVS_TAMPER4__GPIO5_IO04 0xb0a0 /* SODIMM 107 */ + >; + }; + pinctrl_snvs_gpio1: snvsgpio1grp { fsl,pins = < MX6ULL_PAD_SNVS_TAMPER6__GPIO5_IO06 0x110a0 /* SODIMM 93 */ diff --git a/arch/arm/dts/imx6ull.dtsi b/arch/arm/dts/imx6ull.dtsi index 9bf67490ac..2bccd45e9f 100644 --- a/arch/arm/dts/imx6ull.dtsi +++ b/arch/arm/dts/imx6ull.dtsi @@ -50,7 +50,7 @@ };
/ { - soc { + soc: soc { aips3: bus@2200000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>;
arch/arm/dts/imx6ulz.dtsi | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/imx6ulz.dtsi b/arch/arm/dts/imx6ulz.dtsi index aeb2ddc540..0b5f1a7635 100644 --- a/arch/arm/dts/imx6ulz.dtsi +++ b/arch/arm/dts/imx6ulz.dtsi @@ -16,7 +16,6 @@ /delete-property/ serial7; /delete-property/ spi2; /delete-property/ spi3; - /delete-property/ spi4; }; };
arch/arm/dts/imx6sx-sabreauto.dts | 623 +++++++++++++++----- arch/arm/dts/imx6sx-sdb.dts | 8 +- arch/arm/dts/imx6sx-sdb.dtsi | 56 +- arch/arm/dts/imx6sx-softing-vining-2000.dts | 50 +- arch/arm/dts/imx6sx-udoo-neo.dtsi | 86 ++- arch/arm/dts/imx6sx.dtsi | 129 ++-- 6 files changed, 709 insertions(+), 243 deletions(-)
diff --git a/arch/arm/dts/imx6sx-sabreauto.dts b/arch/arm/dts/imx6sx-sabreauto.dts index 9643d1fe06..83ee97252f 100644 --- a/arch/arm/dts/imx6sx-sabreauto.dts +++ b/arch/arm/dts/imx6sx-sabreauto.dts @@ -1,10 +1,6 @@ -/* - * Copyright (C) 2014 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2014 Freescale Semiconductor, Inc.
/dts-v1/;
@@ -14,29 +10,171 @@ model = "Freescale i.MX6 SoloX Sabre Auto Board"; compatible = "fsl,imx6sx-sabreauto", "fsl,imx6sx";
- memory { + memory@80000000 { + device_type = "memory"; reg = <0x80000000 0x80000000>; };
- regulators { - compatible = "simple-bus"; + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_led>; + + user { + label = "debug"; + gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + vcc_sd3: regulator-vcc-sd3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_vcc_sd3>; + regulator-name = "VCC_SD3"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + gpio = <&gpio2 11 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_can_wake: regulator-can-wake { + compatible = "regulator-fixed"; + regulator-name = "can-wake"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&max7310_b 7 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_can_en: regulator-can-en { + compatible = "regulator-fixed"; + regulator-name = "can-en"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&max7310_b 5 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_can_wake>; + }; + + reg_can_stby: regulator-can-stby { + compatible = "regulator-fixed"; + regulator-name = "can-stby"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&max7310_b 4 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_can_en>; + }; + + reg_cs42888: cs42888_supply { + compatible = "regulator-fixed"; + regulator-name = "cs42888_supply"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + sound-cs42888 { + compatible = "fsl,imx6-sabreauto-cs42888", + "fsl,imx-audio-cs42888"; + model = "imx-cs42888"; + audio-cpu = <&esai>; + audio-asrc = <&asrc>; + audio-codec = <&cs42888>; + audio-routing = + "Line Out Jack", "AOUT1L", + "Line Out Jack", "AOUT1R", + "Line Out Jack", "AOUT2L", + "Line Out Jack", "AOUT2R", + "Line Out Jack", "AOUT3L", + "Line Out Jack", "AOUT3R", + "Line Out Jack", "AOUT4L", + "Line Out Jack", "AOUT4R", + "AIN1L", "Line In Jack", + "AIN1R", "Line In Jack", + "AIN2L", "Line In Jack", + "AIN2R", "Line In Jack"; + }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif"; + model = "imx-spdif"; + spdif-controller = <&spdif>; + spdif-in; + }; +}; + +&anaclk2 { + clock-frequency = <24576000>; +}; + +&clks { + assigned-clocks = <&clks IMX6SX_PLL4_BYPASS_SRC>, + <&clks IMX6SX_PLL4_BYPASS>, + <&clks IMX6SX_CLK_PLL4_POST_DIV>; + assigned-clock-parents = <&clks IMX6SX_CLK_LVDS2_IN>, + <&clks IMX6SX_PLL4_BYPASS_SRC>; + assigned-clock-rates = <0>, <0>, <24576000>; +}; + +&esai { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_esai>; + assigned-clocks = <&clks IMX6SX_CLK_ESAI_SEL>, + <&clks IMX6SX_CLK_ESAI_EXTAL>; + assigned-clock-parents = <&clks IMX6SX_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <0>, <24576000>; + status = "okay"; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy1>; + fsl,magic-packet; + status = "okay"; + + mdio { #address-cells = <1>; #size-cells = <0>;
- vcc_sd3: regulator@0 { - compatible = "regulator-fixed"; + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; reg = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_vcc_sd3>; - regulator-name = "VCC_SD3"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - gpio = <&gpio2 11 GPIO_ACTIVE_HIGH>; - enable-active-high; + }; + + ethphy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; }; }; };
+&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet2>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; +}; + +&flexcan1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_can_stby>; + status = "okay"; +}; + +&flexcan2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_can_stby>; + status = "okay"; +}; + &uart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; @@ -68,17 +206,325 @@ status = "okay"; };
+&iomuxc { + pinctrl_egalax_int: egalax-intgrp { + fsl,pins = < + MX6SX_PAD_SD4_RESET_B__GPIO6_IO_22 0x10b0 + >; + }; + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6SX_PAD_ENET1_MDIO__ENET1_MDIO 0xa0b1 + MX6SX_PAD_ENET1_MDC__ENET1_MDC 0xa0b1 + MX6SX_PAD_RGMII1_TXC__ENET1_RGMII_TXC 0xa0b9 + MX6SX_PAD_RGMII1_TD0__ENET1_TX_DATA_0 0xa0b1 + MX6SX_PAD_RGMII1_TD1__ENET1_TX_DATA_1 0xa0b1 + MX6SX_PAD_RGMII1_TD2__ENET1_TX_DATA_2 0xa0b1 + MX6SX_PAD_RGMII1_TD3__ENET1_TX_DATA_3 0xa0b1 + MX6SX_PAD_RGMII1_TX_CTL__ENET1_TX_EN 0xa0b1 + MX6SX_PAD_RGMII1_RXC__ENET1_RX_CLK 0x3081 + MX6SX_PAD_RGMII1_RD0__ENET1_RX_DATA_0 0x3081 + MX6SX_PAD_RGMII1_RD1__ENET1_RX_DATA_1 0x3081 + MX6SX_PAD_RGMII1_RD2__ENET1_RX_DATA_2 0x3081 + MX6SX_PAD_RGMII1_RD3__ENET1_RX_DATA_3 0x3081 + MX6SX_PAD_RGMII1_RX_CTL__ENET1_RX_EN 0x3081 + >; + }; + + pinctrl_enet2: enet2grp { + fsl,pins = < + MX6SX_PAD_RGMII2_TXC__ENET2_RGMII_TXC 0xa0b9 + MX6SX_PAD_RGMII2_TD0__ENET2_TX_DATA_0 0xa0b1 + MX6SX_PAD_RGMII2_TD1__ENET2_TX_DATA_1 0xa0b1 + MX6SX_PAD_RGMII2_TD2__ENET2_TX_DATA_2 0xa0b1 + MX6SX_PAD_RGMII2_TD3__ENET2_TX_DATA_3 0xa0b1 + MX6SX_PAD_RGMII2_TX_CTL__ENET2_TX_EN 0xa0b1 + MX6SX_PAD_RGMII2_RXC__ENET2_RX_CLK 0x3081 + MX6SX_PAD_RGMII2_RD0__ENET2_RX_DATA_0 0x3081 + MX6SX_PAD_RGMII2_RD1__ENET2_RX_DATA_1 0x3081 + MX6SX_PAD_RGMII2_RD2__ENET2_RX_DATA_2 0x3081 + MX6SX_PAD_RGMII2_RD3__ENET2_RX_DATA_3 0x3081 + MX6SX_PAD_RGMII2_RX_CTL__ENET2_RX_EN 0x3081 + >; + }; + + pinctrl_esai: esaigrp { + fsl,pins = < + MX6SX_PAD_CSI_DATA00__ESAI_TX_CLK 0x1b030 + MX6SX_PAD_CSI_DATA01__ESAI_TX_FS 0x1b030 + MX6SX_PAD_CSI_HSYNC__ESAI_TX0 0x1b030 + MX6SX_PAD_CSI_DATA04__ESAI_TX1 0x1b030 + MX6SX_PAD_CSI_DATA06__ESAI_TX2_RX3 0x1b030 + MX6SX_PAD_CSI_DATA07__ESAI_TX3_RX2 0x1b030 + MX6SX_PAD_CSI_DATA02__ESAI_RX_CLK 0x1b030 + MX6SX_PAD_CSI_DATA03__ESAI_RX_FS 0x1b030 + MX6SX_PAD_CSI_VSYNC__ESAI_TX5_RX0 0x1b030 + MX6SX_PAD_CSI_DATA05__ESAI_TX4_RX1 0x1b030 + >; + }; + + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX6SX_PAD_QSPI1B_DQS__CAN1_TX 0x1b020 + MX6SX_PAD_QSPI1A_SS1_B__CAN1_RX 0x1b020 + >; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = < + MX6SX_PAD_QSPI1B_SS1_B__CAN2_RX 0x1b020 + MX6SX_PAD_QSPI1A_DQS__CAN2_TX 0x1b020 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6SX_PAD_GPIO1_IO03__I2C2_SDA 0x4001b8b1 + MX6SX_PAD_GPIO1_IO02__I2C2_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6SX_PAD_KEY_ROW4__I2C3_SDA 0x4001b8b1 + MX6SX_PAD_KEY_COL4__I2C3_SCL 0x4001b8b1 + >; + }; + + pinctrl_led: ledgrp { + fsl,pins = < + MX6SX_PAD_CSI_PIXCLK__GPIO1_IO_24 0x17059 + >; + }; + + pinctrl_spdif: spdifgrp { + fsl,pins = < + MX6SX_PAD_ENET2_COL__SPDIF_IN 0x1b0b0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6SX_PAD_GPIO1_IO04__UART1_DCE_TX 0x1b0b1 + MX6SX_PAD_GPIO1_IO05__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x17059 + MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x10059 + MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x17059 + MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x17059 + MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x17059 + MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x17059 + MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x17059 + MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x17059 + MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x17059 + MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x17059 + MX6SX_PAD_KEY_COL0__GPIO2_IO_10 0x17059 /* CD */ + MX6SX_PAD_KEY_ROW0__GPIO2_IO_15 0x17059 /* WP */ + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp-100mhz { + fsl,pins = < + MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x170b9 + MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x100b9 + MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x170b9 + MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x170b9 + MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x170b9 + MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x170b9 + MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x170b9 + MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x170b9 + MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x170b9 + MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x170b9 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp-200mhz { + fsl,pins = < + MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x170f9 + MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x100f9 + MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x170f9 + MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x170f9 + MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x170f9 + MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x170f9 + MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x170f9 + MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x170f9 + MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x170f9 + MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x170f9 + >; + }; + + pinctrl_usdhc4: usdhc4grp { + fsl,pins = < + MX6SX_PAD_SD4_CMD__USDHC4_CMD 0x17059 + MX6SX_PAD_SD4_CLK__USDHC4_CLK 0x10059 + MX6SX_PAD_SD4_DATA0__USDHC4_DATA0 0x17059 + MX6SX_PAD_SD4_DATA1__USDHC4_DATA1 0x17059 + MX6SX_PAD_SD4_DATA2__USDHC4_DATA2 0x17059 + MX6SX_PAD_SD4_DATA3__USDHC4_DATA3 0x17059 + MX6SX_PAD_SD4_DATA7__GPIO6_IO_21 0x17059 /* CD */ + MX6SX_PAD_SD4_DATA6__GPIO6_IO_20 0x17059 /* WP */ + >; + }; + + pinctrl_vcc_sd3: vccsd3grp { + fsl,pins = < + MX6SX_PAD_KEY_COL1__GPIO2_IO_11 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6SX_PAD_GPIO1_IO13__WDOG1_WDOG_ANY 0x30b0 + >; + }; +}; + &i2c2 { clock-frequency = <100000>; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2_1>; + pinctrl-0 = <&pinctrl_i2c2>; status = "okay"; + + cs42888: cs42888@48 { + compatible = "cirrus,cs42888"; + reg = <0x48>; + clocks = <&anaclk2 0>; + clock-names = "mclk"; + VA-supply = <®_cs42888>; + VD-supply = <®_cs42888>; + VLS-supply = <®_cs42888>; + VLC-supply = <®_cs42888>; + }; + + touchscreen@4 { + compatible = "eeti,egalax_ts"; + reg = <0x04>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_egalax_int>; + interrupt-parent = <&gpio6>; + interrupts = <22 IRQ_TYPE_EDGE_FALLING>; + wakeup-gpios = <&gpio6 22 GPIO_ACTIVE_HIGH>; + }; + + pfuze100: pmic@8 { + compatible = "fsl,pfuze100"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3b_reg: sw3b { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-always-on; + }; + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vgen3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + max7322: gpio@68 { + compatible = "maxim,max7322"; + reg = <0x68>; + gpio-controller; + #gpio-cells = <2>; + }; };
&i2c3 { - clock-frequency = <100000>; + clock-frequency = <100000>; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c3_2>; + pinctrl-0 = <&pinctrl_i2c3>; status = "okay";
max7310_a: gpio@30 { @@ -96,133 +542,16 @@ }; };
-&qspi1 { +&spdif { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi1_1>; + pinctrl-0 = <&pinctrl_spdif>; + assigned-clocks = <&clks IMX6SX_CLK_SPDIF_PODF>; + assigned-clock-rates = <24576000>; status = "okay"; - ddrsmp=<2>; - - flash0: n25q256a@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q256a"; - spi-max-frequency = <29000000>; - reg = <0>; - }; - - flash1: n25q256a@1 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q256a"; - spi-max-frequency = <29000000>; - reg = <1>; - }; };
-&iomuxc { - imx6x-sabreauto { - pinctrl_i2c2_1: i2c2grp-1 { - fsl,pins = < - MX6SX_PAD_GPIO1_IO03__I2C2_SDA 0x4001b8b1 - MX6SX_PAD_GPIO1_IO02__I2C2_SCL 0x4001b8b1 - >; - }; - - pinctrl_i2c3_2: i2c3grp-2 { - fsl,pins = < - MX6SX_PAD_KEY_ROW4__I2C3_SDA 0x4001b8b1 - MX6SX_PAD_KEY_COL4__I2C3_SCL 0x4001b8b1 - >; - }; - - pinctrl_qspi1_1: qspi1grp_1 { - fsl,pins = < - MX6SX_PAD_QSPI1A_DATA0__QSPI1_A_DATA_0 0x70a1 - MX6SX_PAD_QSPI1A_DATA1__QSPI1_A_DATA_1 0x70a1 - MX6SX_PAD_QSPI1A_DATA2__QSPI1_A_DATA_2 0x70a1 - MX6SX_PAD_QSPI1A_DATA3__QSPI1_A_DATA_3 0x70a1 - MX6SX_PAD_QSPI1A_SCLK__QSPI1_A_SCLK 0x70a1 - MX6SX_PAD_QSPI1A_SS0_B__QSPI1_A_SS0_B 0x70a1 - MX6SX_PAD_QSPI1B_DATA0__QSPI1_B_DATA_0 0x70a1 - MX6SX_PAD_QSPI1B_DATA1__QSPI1_B_DATA_1 0x70a1 - MX6SX_PAD_QSPI1B_DATA2__QSPI1_B_DATA_2 0x70a1 - MX6SX_PAD_QSPI1B_DATA3__QSPI1_B_DATA_3 0x70a1 - MX6SX_PAD_QSPI1B_SCLK__QSPI1_B_SCLK 0x70a1 - MX6SX_PAD_QSPI1B_SS0_B__QSPI1_B_SS0_B 0x70a1 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX6SX_PAD_GPIO1_IO04__UART1_TX 0x1b0b1 - MX6SX_PAD_GPIO1_IO05__UART1_RX 0x1b0b1 - >; - }; - - pinctrl_usdhc3: usdhc3grp { - fsl,pins = < - MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x17059 - MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x10059 - MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x17059 - MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x17059 - MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x17059 - MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x17059 - MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x17059 - MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x17059 - MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x17059 - MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x17059 - MX6SX_PAD_KEY_COL0__GPIO2_IO_10 0x17059 /* CD */ - MX6SX_PAD_KEY_ROW0__GPIO2_IO_15 0x17059 /* WP */ - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3grp-100mhz { - fsl,pins = < - MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x170b9 - MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x100b9 - MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x170b9 - MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x170b9 - MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x170b9 - MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x170b9 - MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x170b9 - MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x170b9 - MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x170b9 - MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x170b9 - >; - }; - - pinctrl_usdhc3_200mhz: usdhc3grp-200mhz { - fsl,pins = < - MX6SX_PAD_SD3_CMD__USDHC3_CMD 0x170f9 - MX6SX_PAD_SD3_CLK__USDHC3_CLK 0x100f9 - MX6SX_PAD_SD3_DATA0__USDHC3_DATA0 0x170f9 - MX6SX_PAD_SD3_DATA1__USDHC3_DATA1 0x170f9 - MX6SX_PAD_SD3_DATA2__USDHC3_DATA2 0x170f9 - MX6SX_PAD_SD3_DATA3__USDHC3_DATA3 0x170f9 - MX6SX_PAD_SD3_DATA4__USDHC3_DATA4 0x170f9 - MX6SX_PAD_SD3_DATA5__USDHC3_DATA5 0x170f9 - MX6SX_PAD_SD3_DATA6__USDHC3_DATA6 0x170f9 - MX6SX_PAD_SD3_DATA7__USDHC3_DATA7 0x170f9 - >; - }; - - pinctrl_usdhc4: usdhc4grp { - fsl,pins = < - MX6SX_PAD_SD4_CMD__USDHC4_CMD 0x17059 - MX6SX_PAD_SD4_CLK__USDHC4_CLK 0x10059 - MX6SX_PAD_SD4_DATA0__USDHC4_DATA0 0x17059 - MX6SX_PAD_SD4_DATA1__USDHC4_DATA1 0x17059 - MX6SX_PAD_SD4_DATA2__USDHC4_DATA2 0x17059 - MX6SX_PAD_SD4_DATA3__USDHC4_DATA3 0x17059 - MX6SX_PAD_SD4_DATA7__GPIO6_IO_21 0x17059 /* CD */ - MX6SX_PAD_SD4_DATA6__GPIO6_IO_20 0x17059 /* WP */ - >; - }; - - pinctrl_vcc_sd3: vccsd3grp { - fsl,pins = < - MX6SX_PAD_KEY_COL1__GPIO2_IO_11 0x17059 - >; - }; - }; +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; }; diff --git a/arch/arm/dts/imx6sx-sdb.dts b/arch/arm/dts/imx6sx-sdb.dts index 5a63ca6157..969cfe920d 100644 --- a/arch/arm/dts/imx6sx-sdb.dts +++ b/arch/arm/dts/imx6sx-sdb.dts @@ -108,23 +108,23 @@ pinctrl-0 = <&pinctrl_qspi2>; status = "okay";
- flash0: n25q256a@0 { + flash0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "micron,n25q256a", "jedec,spi-nor"; spi-max-frequency = <29000000>; spi-rx-bus-width = <4>; - spi-tx-bus-width = <4>; + spi-tx-bus-width = <1>; reg = <0>; };
- flash1: n25q256a@2 { + flash1: flash@2 { #address-cells = <1>; #size-cells = <1>; compatible = "micron,n25q256a", "jedec,spi-nor"; spi-max-frequency = <29000000>; spi-rx-bus-width = <4>; - spi-tx-bus-width = <4>; + spi-tx-bus-width = <1>; reg = <2>; }; }; diff --git a/arch/arm/dts/imx6sx-sdb.dtsi b/arch/arm/dts/imx6sx-sdb.dtsi index f6972deb5e..c6e85e4a08 100644 --- a/arch/arm/dts/imx6sx-sdb.dtsi +++ b/arch/arm/dts/imx6sx-sdb.dtsi @@ -153,6 +153,8 @@
sound { compatible = "fsl,imx6sx-sdb-wm8962", "fsl,imx-audio-wm8962"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hp>; model = "wm8962-audio"; ssi-controller = <&ssi2>; audio-codec = <&codec>; @@ -165,6 +167,7 @@ "IN3R", "AMIC"; mux-int-port = <2>; mux-ext-port = <6>; + hp-det-gpio = <&gpio1 17 GPIO_ACTIVE_LOW>; };
panel { @@ -179,6 +182,15 @@ }; }; }; + + sound-spdif { + compatible = "fsl,imx-audio-spdif", + "fsl,imx6sx-sdb-spdif"; + model = "imx-spdif"; + spdif-controller = <&spdif>; + spdif-out; + }; + };
&audmux { @@ -194,6 +206,7 @@ phy-mode = "rgmii-id"; phy-handle = <ðphy1>; phy-reset-gpios = <&gpio2 7 GPIO_ACTIVE_LOW>; + fsl,magic-packet; status = "okay";
mdio { @@ -213,8 +226,9 @@ &fec2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_enet2>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; phy-handle = <ðphy2>; + fsl,magic-packet; status = "okay"; };
@@ -281,6 +295,7 @@ };
&pwm3 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm3>; status = "okay"; @@ -296,6 +311,14 @@ status = "disabled"; };
+&spdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spdif>; + assigned-clocks = <&clks IMX6SX_CLK_SPDIF_PODF>; + assigned-clock-rates = <24576000>; + status = "okay"; +}; + &ssi2 { status = "okay"; }; @@ -450,6 +473,12 @@ >; };
+ pinctrl_hp: hpgrp { + fsl,pins = < + MX6SX_PAD_CSI_DATA03__GPIO1_IO_17 0x17059 + >; + }; + pinctrl_i2c1: i2c1grp { fsl,pins = < MX6SX_PAD_GPIO1_IO01__I2C1_SDA 0x4001b8b1 @@ -505,6 +534,13 @@ >; };
+ pinctrl_mqs: mqsgrp { + fsl,pins = < + MX6SX_PAD_SD2_CLK__MQS_RIGHT 0x120b0 + MX6SX_PAD_SD2_CMD__MQS_LEFT 0x120b0 + >; + }; + pinctrl_pcie: pciegrp { fsl,pins = < MX6SX_PAD_ENET1_COL__GPIO2_IO_0 0x10b0 @@ -562,19 +598,25 @@ >; };
+ pinctrl_spdif: spdifgrp { + fsl,pins = < + MX6SX_PAD_SD4_DATA4__SPDIF_OUT 0x1b0b0 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < - MX6SX_PAD_GPIO1_IO04__UART1_TX 0x1b0b1 - MX6SX_PAD_GPIO1_IO05__UART1_RX 0x1b0b1 + MX6SX_PAD_GPIO1_IO04__UART1_DCE_TX 0x1b0b1 + MX6SX_PAD_GPIO1_IO05__UART1_DCE_RX 0x1b0b1 >; };
pinctrl_uart5: uart5grp { fsl,pins = < - MX6SX_PAD_KEY_ROW3__UART5_RX 0x1b0b1 - MX6SX_PAD_KEY_COL3__UART5_TX 0x1b0b1 - MX6SX_PAD_KEY_ROW2__UART5_CTS_B 0x1b0b1 - MX6SX_PAD_KEY_COL2__UART5_RTS_B 0x1b0b1 + MX6SX_PAD_KEY_ROW3__UART5_DCE_RX 0x1b0b1 + MX6SX_PAD_KEY_COL3__UART5_DCE_TX 0x1b0b1 + MX6SX_PAD_KEY_ROW2__UART5_DCE_CTS 0x1b0b1 + MX6SX_PAD_KEY_COL2__UART5_DCE_RTS 0x1b0b1 >; };
diff --git a/arch/arm/dts/imx6sx-softing-vining-2000.dts b/arch/arm/dts/imx6sx-softing-vining-2000.dts index 78dd5755a3..b9a1401e6c 100644 --- a/arch/arm/dts/imx6sx-softing-vining-2000.dts +++ b/arch/arm/dts/imx6sx-softing-vining-2000.dts @@ -1,9 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0-only /* * Copyright (C) 2016 Christoph Fritz chf.fritz@googlemail.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
/dts-v1/; @@ -16,11 +13,6 @@ model = "Softing VIN|ING 2000"; compatible = "samtec,imx6sx-vining-2000", "fsl,imx6sx";
- aliases { - mmc0 = &usdhc4; - mmc1 = &usdhc2; - }; - chosen { stdout-path = &uart1; }; @@ -48,22 +40,22 @@ regulator-max-microvolt = <3300000>; };
- pwmleds { + led-controller { compatible = "pwm-leds";
- red { + led-1 { label = "red"; max-brightness = <255>; pwms = <&pwm6 0 50000>; };
- green { + led-2 { label = "green"; max-brightness = <255>; pwms = <&pwm2 0 50000>; };
- blue { + led-3 { label = "blue"; max-brightness = <255>; pwms = <&pwm1 0 50000>; @@ -101,7 +93,7 @@ &ecspi4 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi4>; - cs-gpios = <&gpio7 4 GPIO_ACTIVE_HIGH>; + cs-gpios = <&gpio7 4 GPIO_ACTIVE_LOW>; status = "okay"; };
@@ -270,17 +262,6 @@ status = "okay"; };
-®_pcie { - regulator-always-on; -}; - -&pcie { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie>; - reset-gpio = <&gpio4 6 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - &iomuxc { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpios>; @@ -409,15 +390,15 @@
pinctrl_uart2: uart2grp { fsl,pins = < - MX6SX_PAD_GPIO1_IO06__UART2_TX 0x1b0b1 - MX6SX_PAD_GPIO1_IO07__UART2_RX 0x1b0b1 + MX6SX_PAD_GPIO1_IO06__UART2_DCE_TX 0x1b0b1 + MX6SX_PAD_GPIO1_IO07__UART2_DCE_RX 0x1b0b1 >; };
@@ -515,19 +496,30 @@ }; };
+&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + reset-gpio = <&gpio4 6 GPIO_ACTIVE_HIGH>; + reset-gpio-active-high; + status = "okay"; +}; + &pwm1 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm1>; status = "okay"; };
&pwm2 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm2>; status = "okay"; };
&pwm6 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm6>; status = "okay"; diff --git a/arch/arm/dts/imx6sx-udoo-neo.dtsi b/arch/arm/dts/imx6sx-udoo-neo.dtsi index ee64565509..c84ea1fac5 100644 --- a/arch/arm/dts/imx6sx-udoo-neo.dtsi +++ b/arch/arm/dts/imx6sx-udoo-neo.dtsi @@ -183,6 +183,27 @@ status = "okay"; };
+&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <100000>; + status = "okay"; + + hdmi-transmitter@70 { + compatible = "nxp,tda998x"; + reg = <0x70>; + interrupts-extended = <&gpio3 27 IRQ_TYPE_LEVEL_LOW>; + + ports { + port { + hdmi: endpoint { + remote-endpoint = <&lcdc>; + }; + }; + }; + }; +}; + &i2c4 { /* Onboard Motion sensors */ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_i2c4>; @@ -190,10 +211,22 @@ status = "disabled"; };
+&lcdif1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcd>; + status = "okay"; + + port { + lcdc: endpoint { + remote-endpoint = <&hdmi>; + }; + }; +}; + &iomuxc { pinctrl_bt_reg: btreggrp { fsl,pins = - <MX6SX_PAD_KEY_ROW2__GPIO2_IO_17 0x15059>; + <MX6SX_PAD_KEY_ROW2__GPIO2_IO_17 0x15059>; };
pinctrl_enet1: enet1grp { @@ -227,12 +260,52 @@ <MX6SX_PAD_GPIO1_IO02__I2C2_SCL 0x4001b8b1>; };
+ pinctrl_i2c3: i2c3grp { + fsl,pins = + <MX6SX_PAD_KEY_ROW4__I2C3_SDA 0x4001b8b1>, + <MX6SX_PAD_KEY_COL4__I2C3_SCL 0x4001b8b1>; + }; + pinctrl_i2c4: i2c4grp { fsl,pins = <MX6SX_PAD_USB_H_DATA__I2C4_SDA 0x4001b8b1>, <MX6SX_PAD_USB_H_STROBE__I2C4_SCL 0x4001b8b1>; };
+ pinctrl_lcd: lcdgrp { + fsl,pins = < + MX6SX_PAD_LCD1_DATA00__LCDIF1_DATA_0 0x4001b0b0 + MX6SX_PAD_LCD1_DATA01__LCDIF1_DATA_1 0x4001b0b0 + MX6SX_PAD_LCD1_DATA02__LCDIF1_DATA_2 0x4001b0b0 + MX6SX_PAD_LCD1_DATA03__LCDIF1_DATA_3 0x4001b0b0 + MX6SX_PAD_LCD1_DATA04__LCDIF1_DATA_4 0x4001b0b0 + MX6SX_PAD_LCD1_DATA05__LCDIF1_DATA_5 0x4001b0b0 + MX6SX_PAD_LCD1_DATA06__LCDIF1_DATA_6 0x4001b0b0 + MX6SX_PAD_LCD1_DATA07__LCDIF1_DATA_7 0x4001b0b0 + MX6SX_PAD_LCD1_DATA08__LCDIF1_DATA_8 0x4001b0b0 + MX6SX_PAD_LCD1_DATA09__LCDIF1_DATA_9 0x4001b0b0 + MX6SX_PAD_LCD1_DATA10__LCDIF1_DATA_10 0x4001b0b0 + MX6SX_PAD_LCD1_DATA11__LCDIF1_DATA_11 0x4001b0b0 + MX6SX_PAD_LCD1_DATA12__LCDIF1_DATA_12 0x4001b0b0 + MX6SX_PAD_LCD1_DATA13__LCDIF1_DATA_13 0x4001b0b0 + MX6SX_PAD_LCD1_DATA14__LCDIF1_DATA_14 0x4001b0b0 + MX6SX_PAD_LCD1_DATA15__LCDIF1_DATA_15 0x4001b0b0 + MX6SX_PAD_LCD1_DATA16__LCDIF1_DATA_16 0x4001b0b0 + MX6SX_PAD_LCD1_DATA17__LCDIF1_DATA_17 0x4001b0b0 + MX6SX_PAD_LCD1_DATA18__LCDIF1_DATA_18 0x4001b0b0 + MX6SX_PAD_LCD1_DATA19__LCDIF1_DATA_19 0x4001b0b0 + MX6SX_PAD_LCD1_DATA20__LCDIF1_DATA_20 0x4001b0b0 + MX6SX_PAD_LCD1_DATA21__LCDIF1_DATA_21 0x4001b0b0 + MX6SX_PAD_LCD1_DATA22__LCDIF1_DATA_22 0x4001b0b0 + MX6SX_PAD_LCD1_DATA23__LCDIF1_DATA_23 0x4001b0b0 + MX6SX_PAD_LCD1_CLK__LCDIF1_CLK 0x4001b0b0 + MX6SX_PAD_LCD1_ENABLE__LCDIF1_ENABLE 0x4001b0b0 + MX6SX_PAD_LCD1_VSYNC__LCDIF1_VSYNC 0x4001b0b0 + MX6SX_PAD_LCD1_HSYNC__LCDIF1_HSYNC 0x4001b0b0 + MX6SX_PAD_LCD1_RESET__GPIO3_IO_27 0x4001b0b0 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = <MX6SX_PAD_GPIO1_IO04__UART1_DCE_TX 0x1b0b1>, @@ -273,24 +346,23 @@
pinctrl_otg1_reg: otg1grp { fsl,pins = - <MX6SX_PAD_GPIO1_IO09__GPIO1_IO_9 0x10b0>; + <MX6SX_PAD_GPIO1_IO09__GPIO1_IO_9 0x10b0>; };
- pinctrl_otg2_reg: otg2grp { fsl,pins = - <MX6SX_PAD_NAND_RE_B__GPIO4_IO_12 0x10b0>; + <MX6SX_PAD_NAND_RE_B__GPIO4_IO_12 0x10b0>; };
pinctrl_usb_otg1: usbotg1grp { fsl,pins = - <MX6SX_PAD_GPIO1_IO10__ANATOP_OTG1_ID 0x17059>, - <MX6SX_PAD_GPIO1_IO08__USB_OTG1_OC 0x10b0>; + <MX6SX_PAD_GPIO1_IO10__ANATOP_OTG1_ID 0x17059>, + <MX6SX_PAD_GPIO1_IO08__USB_OTG1_OC 0x10b0>; };
pinctrl_usb_otg2: usbot2ggrp { fsl,pins = - <MX6SX_PAD_QSPI1A_DATA0__USB_OTG2_OC 0x10b0>; + <MX6SX_PAD_QSPI1A_DATA0__USB_OTG2_OC 0x10b0>; };
pinctrl_usdhc2: usdhc2grp { diff --git a/arch/arm/dts/imx6sx.dtsi b/arch/arm/dts/imx6sx.dtsi index 8d2d396ad1..4d075e2bf7 100644 --- a/arch/arm/dts/imx6sx.dtsi +++ b/arch/arm/dts/imx6sx.dtsi @@ -49,6 +49,9 @@ spi2 = &ecspi3; spi3 = &ecspi4; spi4 = &ecspi5; + usb0 = &usbotg1; + usb1 = &usbotg2; + usb2 = &usbh; usbphy0 = &usbphy1; usbphy1 = &usbphy2; }; @@ -87,6 +90,8 @@ "pll1_sw", "pll1_sys"; arm-supply = <®_arm>; soc-supply = <®_soc>; + nvmem-cells = <&cpu_speed_grade>; + nvmem-cell-names = "speed_grade"; }; };
@@ -132,14 +137,10 @@ clock-output-names = "anaclk2"; };
- tempmon: tempmon { - compatible = "fsl,imx6sx-tempmon", "fsl,imx6q-tempmon"; - interrupt-parent = <&gpc>; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; - fsl,tempmon = <&anatop>; - nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>; - nvmem-cell-names = "calib", "temp_grade"; - clocks = <&clks IMX6SX_CLK_PLL3_USB_OTG>; + mqs: mqs { + compatible = "fsl,imx6sx-mqs"; + gpr = <&gpr>; + status = "disabled"; };
pmu { @@ -153,7 +154,7 @@ #phy-cells = <0>; };
- soc { + soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; @@ -181,7 +182,7 @@ interrupt-parent = <&intc>; };
- L2: l2-cache@a02000 { + L2: cache-controller@a02000 { compatible = "arm,pl310-cache"; reg = <0x00a02000 0x1000>; interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; @@ -215,7 +216,7 @@ clocks = <&clks IMX6SX_CLK_APBH_DMA>; };
- gpmi: gpmi-nand@1806000{ + gpmi: nand-controller@1806000{ compatible = "fsl,imx6sx-gpmi-nand"; #address-cells = <1>; #size-cells = <1>; @@ -333,6 +334,7 @@ };
esai: esai@2024000 { + compatible = "fsl,imx6sx-esai", "fsl,imx35-esai"; reg = <0x02024000 0x4000>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SX_CLK_ESAI_IPG>, @@ -342,6 +344,9 @@ <&clks IMX6SX_CLK_SPBA>; clock-names = "core", "mem", "extal", "fsys", "spba"; + dmas = <&sdma 23 21 0>, + <&sdma 24 21 0>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -388,18 +393,28 @@ };
asrc: asrc@2034000 { + compatible = "fsl,imx6sx-asrc", "fsl,imx53-asrc"; reg = <0x02034000 0x4000>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SX_CLK_ASRC_MEM>, - <&clks IMX6SX_CLK_ASRC_IPG>, - <&clks IMX6SX_CLK_SPDIF>, - <&clks IMX6SX_CLK_SPBA>; - clock-names = "mem", "ipg", "asrck", "spba"; - dmas = <&sdma 17 20 1>, <&sdma 18 20 1>, - <&sdma 19 20 1>, <&sdma 20 20 1>, - <&sdma 21 20 1>, <&sdma 22 20 1>; + clocks = <&clks IMX6SX_CLK_ASRC_IPG>, + <&clks IMX6SX_CLK_ASRC_MEM>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, + <&clks IMX6SX_CLK_SPDIF>, <&clks 0>, <&clks 0>, + <&clks IMX6SX_CLK_SPBA>; + clock-names = "mem", "ipg", "asrck_0", + "asrck_1", "asrck_2", "asrck_3", "asrck_4", + "asrck_5", "asrck_6", "asrck_7", "asrck_8", + "asrck_9", "asrck_a", "asrck_b", "asrck_c", + "asrck_d", "asrck_e", "asrck_f", "spba"; + dmas = <&sdma 17 23 1>, <&sdma 18 23 1>, + <&sdma 19 23 1>, <&sdma 20 23 1>, + <&sdma 21 23 1>, <&sdma 22 23 1>; dma-names = "rxa", "rxb", "rxc", "txa", "txb", "txc"; + fsl,asrc-rate = <48000>; + fsl,asrc-width = <16>; status = "okay"; }; }; @@ -411,7 +426,7 @@ clocks = <&clks IMX6SX_CLK_PWM1>, <&clks IMX6SX_CLK_PWM1>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm2: pwm@2084000 { @@ -421,7 +436,7 @@ clocks = <&clks IMX6SX_CLK_PWM2>, <&clks IMX6SX_CLK_PWM2>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm3: pwm@2088000 { @@ -431,7 +446,7 @@ clocks = <&clks IMX6SX_CLK_PWM3>, <&clks IMX6SX_CLK_PWM3>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm4: pwm@208c000 { @@ -441,7 +456,7 @@ clocks = <&clks IMX6SX_CLK_PWM4>, <&clks IMX6SX_CLK_PWM4>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
flexcan1: can@2090000 { @@ -451,7 +466,7 @@ clocks = <&clks IMX6SX_CLK_CAN1_IPG>, <&clks IMX6SX_CLK_CAN1_SERIAL>; clock-names = "ipg", "per"; - fsl,stop-mode = <&gpr 0x10 1 0x10 17>; + fsl,stop-mode = <&gpr 0x10 1>; status = "disabled"; };
@@ -462,11 +477,11 @@ clocks = <&clks IMX6SX_CLK_CAN2_IPG>, <&clks IMX6SX_CLK_CAN2_SERIAL>; clock-names = "ipg", "per"; - fsl,stop-mode = <&gpr 0x10 2 0x10 18>; + fsl,stop-mode = <&gpr 0x10 2>; status = "disabled"; };
- gpt: gpt@2098000 { + gpt: timer@2098000 { compatible = "fsl,imx6sx-gpt", "fsl,imx6dl-gpt"; reg = <0x02098000 0x4000>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; @@ -559,7 +574,7 @@ gpio-ranges = <&iomuxc 0 148 10>, <&iomuxc 10 169 2>; };
- kpp: kpp@20b8000 { + kpp: keypad@20b8000 { compatible = "fsl,imx6sx-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -567,14 +582,14 @@ status = "disabled"; };
- wdog1: wdog@20bc000 { + wdog1: watchdog@20bc000 { compatible = "fsl,imx6sx-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SX_CLK_IPG>; };
- wdog2: wdog@20c0000 { + wdog2: watchdog@20c0000 { compatible = "fsl,imx6sx-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; @@ -582,7 +597,7 @@ status = "disabled"; };
- clks: ccm@20c4000 { + clks: clock-controller@20c4000 { compatible = "fsl,imx6sx-ccm"; reg = <0x020c4000 0x4000>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, @@ -594,7 +609,7 @@
anatop: anatop@20c8000 { compatible = "fsl,imx6sx-anatop", "fsl,imx6q-anatop", - "syscon", "simple-bus"; + "syscon", "simple-mfd"; reg = <0x020c8000 0x1000>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, @@ -694,6 +709,16 @@ anatop-min-voltage = <725000>; anatop-max-voltage = <1450000>; }; + + tempmon: tempmon { + compatible = "fsl,imx6sx-tempmon", "fsl,imx6q-tempmon"; + interrupt-parent = <&gpc>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon = <&anatop>; + nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>; + nvmem-cell-names = "calib", "temp_grade"; + clocks = <&clks IMX6SX_CLK_PLL3_USB_OTG>; + }; };
usbphy1: usbphy@20c9000 { @@ -752,7 +777,7 @@ interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; };
- src: src@20d8000 { + src: reset-controller@20d8000 { compatible = "fsl,imx6sx-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, @@ -806,7 +831,7 @@ }; };
- iomuxc: iomuxc@20e0000 { + iomuxc: pinctrl@20e0000 { compatible = "fsl,imx6sx-iomuxc"; reg = <0x020e0000 0x4000>; }; @@ -837,7 +862,7 @@ reg = <0x02100000 0x100000>; ranges;
- crypto: caam@2100000 { + crypto: crypto@2100000 { compatible = "fsl,sec-v4.0"; #address-cells = <1>; #size-cells = <1>; @@ -850,13 +875,13 @@ <&clks IMX6SX_CLK_EIM_SLOW>; clock-names = "mem", "aclk", "ipg", "emi_slow";
- sec_jr0: jr0@1000 { + sec_jr0: jr@1000 { compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; };
- sec_jr1: jr1@2000 { + sec_jr1: jr@2000 { compatible = "fsl,sec-v4.0-job-ring"; reg = <0x2000 0x1000>; interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; @@ -928,6 +953,7 @@ "enet_clk_ref", "enet_out"; fsl,num-tx-queues = <3>; fsl,num-rx-queues = <3>; + fsl,stop-mode = <&gpr 0x10 3>; status = "disabled"; };
@@ -940,7 +966,7 @@ status = "disabled"; };
- usdhc1: usdhc@2190000 { + usdhc1: mmc@2190000 { compatible = "fsl,imx6sx-usdhc", "fsl,imx6sl-usdhc"; reg = <0x02190000 0x4000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; @@ -952,7 +978,7 @@ status = "disabled"; };
- usdhc2: usdhc@2194000 { + usdhc2: mmc@2194000 { compatible = "fsl,imx6sx-usdhc", "fsl,imx6sl-usdhc"; reg = <0x02194000 0x4000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; @@ -964,7 +990,7 @@ status = "disabled"; };
- usdhc3: usdhc@2198000 { + usdhc3: mmc@2198000 { compatible = "fsl,imx6sx-usdhc", "fsl,imx6sl-usdhc"; reg = <0x02198000 0x4000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; @@ -976,7 +1002,7 @@ status = "disabled"; };
- usdhc4: usdhc@219c000 { + usdhc4: mmc@219c000 { compatible = "fsl,imx6sx-usdhc", "fsl,imx6sl-usdhc"; reg = <0x0219c000 0x4000>; interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; @@ -1037,6 +1063,7 @@ <&clks IMX6SX_CLK_ENET_PTP>; clock-names = "ipg", "ahb", "ptp", "enet_clk_ref", "enet_out"; + fsl,stop-mode = <&gpr 0x10 4>; status = "disabled"; };
@@ -1051,13 +1078,17 @@ status = "disabled"; };
- ocotp: ocotp@21bc000 { + ocotp: efuse@21bc000 { #address-cells = <1>; #size-cells = <1>; compatible = "fsl,imx6sx-ocotp", "syscon"; reg = <0x021bc000 0x4000>; clocks = <&clks IMX6SX_CLK_OCOTP>;
+ cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + }; + tempmon_calib: calib@38 { reg = <0x38 4>; }; @@ -1289,7 +1320,7 @@ status = "disabled"; };
- wdog3: wdog@2288000 { + wdog3: watchdog@2288000 { compatible = "fsl,imx6sx-wdt", "fsl,imx21-wdt"; reg = <0x02288000 0x4000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; @@ -1329,7 +1360,7 @@ clocks = <&clks IMX6SX_CLK_PWM5>, <&clks IMX6SX_CLK_PWM5>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm6: pwm@22a8000 { @@ -1339,7 +1370,7 @@ clocks = <&clks IMX6SX_CLK_PWM6>, <&clks IMX6SX_CLK_PWM6>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm7: pwm@22ac000 { @@ -1349,7 +1380,7 @@ clocks = <&clks IMX6SX_CLK_PWM7>, <&clks IMX6SX_CLK_PWM7>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
pwm8: pwm@22b0000 { @@ -1359,20 +1390,20 @@ clocks = <&clks IMX6SX_CLK_PWM8>, <&clks IMX6SX_CLK_PWM8>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; }; };
pcie: pcie@8ffc000 { - compatible = "fsl,imx6sx-pcie", "snps,dw-pcie"; + compatible = "fsl,imx6sx-pcie"; reg = <0x08ffc000 0x04000>, <0x08f00000 0x80000>; reg-names = "dbi", "config"; #address-cells = <3>; #size-cells = <2>; device_type = "pci"; bus-range = <0x00 0xff>; - ranges = <0x81000000 0 0 0x08f80000 0 0x00010000 /* downstream I/O */ - 0x82000000 0 0x08000000 0x08000000 0 0x00f00000>; /* non-prefetchable memory */ + ranges = <0x81000000 0 0 0x08f80000 0 0x00010000>, /* downstream I/O */ + <0x82000000 0 0x08000000 0x08000000 0 0x00f00000>; /* non-prefetchable memory */ num-lanes = <1>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "msi";
arch/arm/dts/imx6sll-evk.dts | 879 ++++++++-------------- arch/arm/dts/imx6sll-pinfunc.h | 6 +- arch/arm/dts/imx6sll.dtsi | 445 ++++++----- include/dt-bindings/clock/imx6sll-clock.h | 16 +- 4 files changed, 551 insertions(+), 795 deletions(-)
diff --git a/arch/arm/dts/imx6sll-evk.dts b/arch/arm/dts/imx6sll-evk.dts index b4af007c98..32b3d82fec 100644 --- a/arch/arm/dts/imx6sll-evk.dts +++ b/arch/arm/dts/imx6sll-evk.dts @@ -1,9 +1,8 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) /* - * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2017-2018 NXP. * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
/dts-v1/; @@ -16,11 +15,16 @@ model = "Freescale i.MX6SLL EVK Board"; compatible = "fsl,imx6sll-evk", "fsl,imx6sll";
- memory { + chosen { + stdout-path = &uart1; + }; + + memory@80000000 { + device_type = "memory"; reg = <0x80000000 0x80000000>; };
- backlight { + backlight_display: backlight-display { compatible = "pwm-backlight"; pwms = <&pwm1 0 5000000>; brightness-levels = <0 4 8 16 32 64 128 255>; @@ -28,108 +32,114 @@ status = "okay"; };
- battery: max8903@0 { - compatible = "fsl,max8903-charger"; + leds { + compatible = "gpio-leds"; pinctrl-names = "default"; - dok_input = <&gpio4 13 1>; - uok_input = <&gpio4 13 1>; - chg_input = <&gpio4 15 1>; - flt_input = <&gpio4 14 1>; - fsl,dcm_always_high; - fsl,dc_valid; - fsl,adc_disable; - status = "okay"; + pinctrl-0 = <&pinctrl_led>; + + user { + label = "debug"; + gpios = <&gpio2 4 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; };
- pxp_v4l2_out { - compatible = "fsl,imx6sl-pxp-v4l2"; - status = "okay"; + reg_usb_otg1_vbus: regulator-otg1-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg1_vbus>; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 0 GPIO_ACTIVE_HIGH>; + enable-active-high; };
- regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; + reg_usb_otg2_vbus: regulator-otg2-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb_otg2_vbus>; + regulator-name = "usb_otg2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + };
- reg_usb_otg1_vbus: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - regulator-name = "usb_otg1_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio4 0 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; + reg_aud3v: regulator-aud3v { + compatible = "regulator-fixed"; + regulator-name = "wm8962-supply-3v15"; + regulator-min-microvolt = <3150000>; + regulator-max-microvolt = <3150000>; + regulator-boot-on; + };
- reg_usb_otg2_vbus: regulator@1 { - compatible = "regulator-fixed"; - reg = <1>; - regulator-name = "usb_otg2_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio4 2 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; + reg_aud4v: regulator-aud4v { + compatible = "regulator-fixed"; + regulator-name = "wm8962-supply-4v2"; + regulator-min-microvolt = <4325000>; + regulator-max-microvolt = <4325000>; + regulator-boot-on; + };
- reg_aud3v: regulator@2 { - compatible = "regulator-fixed"; - reg = <2>; - regulator-name = "wm8962-supply-3v15"; - regulator-min-microvolt = <3150000>; - regulator-max-microvolt = <3150000>; - regulator-boot-on; - }; + reg_lcd_3v3: regulator-lcd-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_lcd_3v3>; + regulator-name = "lcd-3v3"; + gpio = <&gpio4 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + };
- reg_aud4v: regulator@3 { - compatible = "regulator-fixed"; - reg = <3>; - regulator-name = "wm8962-supply-4v2"; - regulator-min-microvolt = <4325000>; - regulator-max-microvolt = <4325000>; - regulator-boot-on; - }; + reg_lcd_5v: regulator-lcd-5v { + compatible = "regulator-fixed"; + regulator-name = "lcd-5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + };
- reg_lcd: regulator@4 { - compatible = "regulator-fixed"; - reg = <4>; - regulator-name = "lcd-pwr"; - gpio = <&gpio4 8 0>; - enable-active-high; - }; + reg_sd1_vmmc: regulator-sd1-vmmc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_sd1_vmmc>; + regulator-name = "SD1_SPWR"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + gpio = <&gpio3 30 GPIO_ACTIVE_HIGH>; + enable-active-high; + };
- reg_sd1_vmmc: sd1_vmmc { - compatible = "regulator-fixed"; - regulator-name = "SD1_SPWR"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - gpio = <&gpio3 30 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; + reg_sd3_vmmc: regulator-sd3-vmmc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_sd3_vmmc>; + regulator-name = "SD3_WIFI"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + gpio = <&gpio4 4 GPIO_ACTIVE_HIGH>; + enable-active-high; + };
- reg_sd2_vmmc: sd2_vmmc { - compatible = "regulator-fixed"; - regulator-name = "eMMC-VCCQ"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - }; + panel { + compatible = "sii,43wvf1g"; + backlight = <&backlight_display>; + dvdd-supply = <®_lcd_3v3>; + avdd-supply = <®_lcd_5v>;
- reg_sd3_vmmc: sd3_vmmc { - compatible = "regulator-fixed"; - regulator-name = "SD3_WIFI"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - gpio = <&gpio4 4 GPIO_ACTIVE_HIGH>; - enable-active-high; + port { + panel_in: endpoint { + remote-endpoint = <&display_out>; + }; }; - };
sound { compatible = "fsl,imx6sl-evk-wm8962", "fsl,imx-audio-wm8962"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hp>; model = "wm8962-audio"; - cpu-dai = <&ssi2>; - audio-codec = <&codec>; + audio-cpu = <&ssi2>; + audio-codec = <&wm8962>; audio-routing = "Headphone Jack", "HPOUTL", "Headphone Jack", "HPOUTR", @@ -139,8 +149,7 @@ "IN3R", "AMIC"; mux-int-port = <2>; mux-ext-port = <3>; - codec-master; - hp-det-gpios = <&gpio4 24 1>; + hp-det-gpio = <&gpio4 24 GPIO_ACTIVE_LOW>; }; };
@@ -150,11 +159,6 @@ status = "okay"; };
-&clks { - assigned-clocks = <&clks IMX6SLL_CLK_PLL4_AUDIO_DIV>; - assigned-clock-rates = <393216000>; -}; - &cpu0 { arm-supply = <&sw1a_reg>; soc-supply = <&sw1c_reg>; @@ -166,7 +170,7 @@ pinctrl-0 = <&pinctrl_i2c1>; status = "okay";
- pmic: pfuze100@08 { + pfuze100: pmic@8 { compatible = "fsl,pfuze100"; reg = <0x08>;
@@ -211,6 +215,7 @@ sw4_reg: sw4 { regulator-min-microvolt = <800000>; regulator-max-microvolt = <3300000>; + regulator-always-on; };
swbst_reg: swbst { @@ -265,76 +270,6 @@ }; }; }; - - max17135: max17135@48 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_max17135>; - compatible = "maxim,max17135"; - reg = <0x48>; - status = "okay"; - - vneg_pwrup = <1>; - gvee_pwrup = <2>; - vpos_pwrup = <10>; - gvdd_pwrup = <12>; - gvdd_pwrdn = <1>; - vpos_pwrdn = <2>; - gvee_pwrdn = <8>; - vneg_pwrdn = <10>; - gpio_pmic_pwrgood = <&gpio2 13 0>; - gpio_pmic_vcom_ctrl = <&gpio2 3 0>; - gpio_pmic_wakeup = <&gpio2 14 0>; - gpio_pmic_v3p3 = <&gpio2 7 0>; - gpio_pmic_intr = <&gpio2 12 0>; - - regulators { - DISPLAY_reg: DISPLAY { - regulator-name = "DISPLAY"; - }; - - GVDD_reg: GVDD { - /* 20v */ - regulator-name = "GVDD"; - }; - - GVEE_reg: GVEE { - /* -22v */ - regulator-name = "GVEE"; - }; - - HVINN_reg: HVINN { - /* -22v */ - regulator-name = "HVINN"; - }; - - HVINP_reg: HVINP { - /* 20v */ - regulator-name = "HVINP"; - }; - - VCOM_reg: VCOM { - regulator-name = "VCOM"; - /* 2's-compliment, -4325000 */ - regulator-min-microvolt = <0xffbe0178>; - /* 2's-compliment, -500000 */ - regulator-max-microvolt = <0xfff85ee0>; - }; - - VNEG_reg: VNEG { - /* -15v */ - regulator-name = "VNEG"; - }; - - VPOS_reg: VPOS { - /* 15v */ - regulator-name = "VPOS"; - }; - - V3P3_reg: V3P3 { - regulator-name = "V3P3"; - }; - }; - }; };
&i2c3 { @@ -343,7 +278,7 @@ pinctrl-0 = <&pinctrl_i2c3>; status = "okay";
- codec: wm8962@1a { + wm8962: audio-codec@1a { compatible = "wlf,wm8962"; reg = <0x1a>; clocks = <&clks IMX6SLL_CLK_EXTERN_AUDIO>; @@ -355,365 +290,37 @@ PLLVDD-supply = <&vgen3_reg>; SPKVDD1-supply = <®_aud4v>; SPKVDD2-supply = <®_aud4v>; - amic-mono; }; };
-&gpc { - fsl,ldo-bypass = <1>; -}; - -&iomuxc { +&lcdif { pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog>; - - imx6sll-evk { - pinctrl_hog: hoggrp { - fsl,pins = < - MX6SLL_PAD_KEY_ROW7__GPIO4_IO07 0x17059 - MX6SLL_PAD_GPIO4_IO22__GPIO4_IO22 0x17059 - MX6SLL_PAD_KEY_COL3__GPIO3_IO30 0x17059 - /* - * Must set the LVE of pad SD2_RESET, otherwise current - * leakage through eMMC chip will pull high the VCCQ to - * 2.6v, which will impact SD1 and SD3 SD3.0 voltage switch. - */ - MX6SLL_PAD_SD2_RESET__GPIO4_IO27 0x417059 - MX6SLL_PAD_KEY_COL4__GPIO4_IO00 0x17059 - MX6SLL_PAD_REF_CLK_32K__GPIO3_IO22 0x17059 /* SD3 CD */ - MX6SLL_PAD_KEY_COL6__GPIO4_IO04 0x17059 /*SD3 RESET */ - MX6SLL_PAD_KEY_COL5__GPIO4_IO02 0x17059 - MX6SLL_PAD_GPIO4_IO24__GPIO4_IO24 0x17059 /* HP DETECT */ - /* CHG_FLT, CHG_UOK/DOK, CHG_STATUS */ - MX6SLL_PAD_ECSPI2_MISO__GPIO4_IO14 0x17000 - MX6SLL_PAD_ECSPI2_MOSI__GPIO4_IO13 0x17000 - MX6SLL_PAD_ECSPI2_SS0__GPIO4_IO15 0x17000 - >; - }; - - pinctrl_audmux3: audmux3grp { - fsl,pins = < - MX6SLL_PAD_AUD_TXC__AUD3_TXC 0x4130b0 - MX6SLL_PAD_AUD_TXFS__AUD3_TXFS 0x4130b0 - MX6SLL_PAD_AUD_TXD__AUD3_TXD 0x4110b0 - MX6SLL_PAD_AUD_RXD__AUD3_RXD 0x4130b0 - MX6SLL_PAD_AUD_MCLK__AUDIO_CLK_OUT 0x4130b0 - >; - }; - - pinctrl_csi1: csi1grp { - fsl,pins = < - MX6SLL_PAD_EPDC_GDRL__CSI_MCLK 0x1b088 - MX6SLL_PAD_EPDC_GDCLK__CSI_PIXCLK 0x1b088 - MX6SLL_PAD_EPDC_GDSP__CSI_VSYNC 0x1b088 - MX6SLL_PAD_EPDC_GDOE__CSI_HSYNC 0x1b088 - MX6SLL_PAD_EPDC_DATA02__CSI_DATA02 0x1b088 - MX6SLL_PAD_EPDC_DATA03__CSI_DATA03 0x1b088 - MX6SLL_PAD_EPDC_DATA04__CSI_DATA04 0x1b088 - MX6SLL_PAD_EPDC_DATA05__CSI_DATA05 0x1b088 - MX6SLL_PAD_EPDC_DATA06__CSI_DATA06 0x1b088 - MX6SLL_PAD_EPDC_DATA07__CSI_DATA07 0x1b088 - MX6SLL_PAD_EPDC_SDCLK__CSI_DATA08 0x1b088 - MX6SLL_PAD_EPDC_SDLE__CSI_DATA09 0x1b088 - MX6SLL_PAD_EPDC_SDSHR__GPIO1_IO26 0x80000000 - MX6SLL_PAD_EPDC_SDOE__GPIO1_IO25 0x80000000 - >; - }; - - pinctrl_epdc0: epdcgrp0 { - fsl,pins = < - MX6SLL_PAD_EPDC_DATA00__EPDC_DATA00 0x100b1 - MX6SLL_PAD_EPDC_DATA01__EPDC_DATA01 0x100b1 - MX6SLL_PAD_EPDC_DATA02__EPDC_DATA02 0x100b1 - MX6SLL_PAD_EPDC_DATA03__EPDC_DATA03 0x100b1 - MX6SLL_PAD_EPDC_DATA04__EPDC_DATA04 0x100b1 - MX6SLL_PAD_EPDC_DATA05__EPDC_DATA05 0x100b1 - MX6SLL_PAD_EPDC_DATA06__EPDC_DATA06 0x100b1 - MX6SLL_PAD_EPDC_DATA07__EPDC_DATA07 0x100b1 - MX6SLL_PAD_EPDC_DATA08__EPDC_DATA08 0x100b1 - MX6SLL_PAD_EPDC_DATA09__EPDC_DATA09 0x100b1 - MX6SLL_PAD_EPDC_DATA10__EPDC_DATA10 0x100b1 - MX6SLL_PAD_EPDC_DATA11__EPDC_DATA11 0x100b1 - MX6SLL_PAD_EPDC_DATA12__EPDC_DATA12 0x100b1 - MX6SLL_PAD_EPDC_DATA13__EPDC_DATA13 0x100b1 - MX6SLL_PAD_EPDC_DATA14__EPDC_DATA14 0x100b1 - MX6SLL_PAD_EPDC_DATA15__EPDC_DATA15 0x100b1 - MX6SLL_PAD_EPDC_SDCLK__EPDC_SDCLK_P 0x100b1 - MX6SLL_PAD_EPDC_SDLE__EPDC_SDLE 0x100b1 - MX6SLL_PAD_EPDC_SDOE__EPDC_SDOE 0x100b1 - MX6SLL_PAD_EPDC_SDSHR__EPDC_SDSHR 0x100b1 - MX6SLL_PAD_EPDC_SDCE0__EPDC_SDCE0 0x100b1 - MX6SLL_PAD_EPDC_GDCLK__EPDC_GDCLK 0x100b1 - MX6SLL_PAD_EPDC_GDOE__EPDC_GDOE 0x100b1 - MX6SLL_PAD_EPDC_GDRL__EPDC_GDRL 0x100b1 - MX6SLL_PAD_EPDC_GDSP__EPDC_GDSP 0x100b1 - >; - }; - - pinctrl_lcdif_dat: lcdifdatgrp { - fsl,pins = < - MX6SLL_PAD_LCD_DATA00__LCD_DATA00 0x79 - MX6SLL_PAD_LCD_DATA01__LCD_DATA01 0x79 - MX6SLL_PAD_LCD_DATA02__LCD_DATA02 0x79 - MX6SLL_PAD_LCD_DATA03__LCD_DATA03 0x79 - MX6SLL_PAD_LCD_DATA04__LCD_DATA04 0x79 - MX6SLL_PAD_LCD_DATA05__LCD_DATA05 0x79 - MX6SLL_PAD_LCD_DATA06__LCD_DATA06 0x79 - MX6SLL_PAD_LCD_DATA07__LCD_DATA07 0x79 - MX6SLL_PAD_LCD_DATA08__LCD_DATA08 0x79 - MX6SLL_PAD_LCD_DATA09__LCD_DATA09 0x79 - MX6SLL_PAD_LCD_DATA10__LCD_DATA10 0x79 - MX6SLL_PAD_LCD_DATA11__LCD_DATA11 0x79 - MX6SLL_PAD_LCD_DATA12__LCD_DATA12 0x79 - MX6SLL_PAD_LCD_DATA13__LCD_DATA13 0x79 - MX6SLL_PAD_LCD_DATA14__LCD_DATA14 0x79 - MX6SLL_PAD_LCD_DATA15__LCD_DATA15 0x79 - MX6SLL_PAD_LCD_DATA16__LCD_DATA16 0x79 - MX6SLL_PAD_LCD_DATA17__LCD_DATA17 0x79 - MX6SLL_PAD_LCD_DATA18__LCD_DATA18 0x79 - MX6SLL_PAD_LCD_DATA19__LCD_DATA19 0x79 - MX6SLL_PAD_LCD_DATA20__LCD_DATA20 0x79 - MX6SLL_PAD_LCD_DATA21__LCD_DATA21 0x79 - MX6SLL_PAD_LCD_DATA22__LCD_DATA22 0x79 - MX6SLL_PAD_LCD_DATA23__LCD_DATA23 0x79 - >; - }; - - pinctrl_lcdif_ctrl: lcdifctrlgrp { - fsl,pins = < - MX6SLL_PAD_LCD_CLK__LCD_CLK 0x79 - MX6SLL_PAD_LCD_ENABLE__LCD_ENABLE 0x79 - MX6SLL_PAD_LCD_HSYNC__LCD_HSYNC 0x79 - MX6SLL_PAD_LCD_VSYNC__LCD_VSYNC 0x79 - MX6SLL_PAD_LCD_RESET__LCD_RESET 0x79 - MX6SLL_PAD_ECSPI1_SCLK__GPIO4_IO08 0x79 - >; - }; - - pinctrl_max17135: max17135grp-1 { - fsl,pins = < - MX6SLL_PAD_EPDC_PWR_STAT__GPIO2_IO13 0x80000000 /* pwrgood */ - MX6SLL_PAD_EPDC_VCOM0__GPIO2_IO03 0x80000000 /* vcom_ctrl */ - MX6SLL_PAD_EPDC_PWR_WAKE__GPIO2_IO14 0x80000000 /* wakeup */ - MX6SLL_PAD_EPDC_PWR_CTRL0__GPIO2_IO07 0x80000000 /* v3p3 */ - MX6SLL_PAD_EPDC_PWR_IRQ__GPIO2_IO12 0x80000000 /* pwr int */ - >; - }; - - pinctrl_spdif: spdifgrp { - fsl,pins = < - MX6SLL_PAD_SD2_DATA4__SPDIF_OUT 0x4130b0 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX6SLL_PAD_UART1_TXD__UART1_DCE_TX 0x1b0b1 - MX6SLL_PAD_UART1_RXD__UART1_DCE_RX 0x1b0b1 - >; - }; - - pinctrl_uart5: uart5grp { - fsl,pins = < - MX6SLL_PAD_KEY_ROW1__GPIO3_IO27 0x1b0b1 /* bt reg on */ - MX6SLL_PAD_ECSPI1_MOSI__UART5_DCE_TX 0x1b0b1 - MX6SLL_PAD_ECSPI1_SCLK__UART5_DCE_RX 0x1b0b1 - MX6SLL_PAD_ECSPI1_SS0__UART5_DCE_CTS 0x1b0b1 - MX6SLL_PAD_ECSPI1_MISO__UART5_DCE_RTS 0x1b0b1 - >; - }; - - pinctrl_uart5dte: uart5dtegrp { - fsl,pins = < - MX6SLL_PAD_ECSPI1_MOSI__UART5_DTE_RX 0x1b0b1 - MX6SLL_PAD_ECSPI1_SCLK__UART5_DTE_TX 0x1b0b1 - MX6SLL_PAD_ECSPI1_SS0__UART5_DTE_RTS 0x1b0b1 - MX6SLL_PAD_ECSPI1_MISO__UART5_DTE_CTS 0x1b0b1 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX6SLL_PAD_SD1_CMD__SD1_CMD 0x17059 - MX6SLL_PAD_SD1_CLK__SD1_CLK 0x13059 - MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x17059 - MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x17059 - MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x17059 - MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x17059 - >; - }; - - pinctrl_usdhc1_100mhz: usdhc1grp_100mhz { - fsl,pins = < - MX6SLL_PAD_SD1_CMD__SD1_CMD 0x170b9 - MX6SLL_PAD_SD1_CLK__SD1_CLK 0x130b9 - MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x170b9 - MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x170b9 - MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x170b9 - MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x170b9 - >; - }; - - pinctrl_usdhc1_200mhz: usdhc1grp_200mhz { - fsl,pins = < - MX6SLL_PAD_SD1_CMD__SD1_CMD 0x170f9 - MX6SLL_PAD_SD1_CLK__SD1_CLK 0x130f9 - MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x170f9 - MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x170f9 - MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x170f9 - MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x170f9 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX6SLL_PAD_SD2_CMD__SD2_CMD 0x17059 - MX6SLL_PAD_SD2_CLK__SD2_CLK 0x13059 - MX6SLL_PAD_SD2_DATA0__SD2_DATA0 0x17059 - MX6SLL_PAD_SD2_DATA1__SD2_DATA1 0x17059 - MX6SLL_PAD_SD2_DATA2__SD2_DATA2 0x17059 - MX6SLL_PAD_SD2_DATA3__SD2_DATA3 0x17059 - MX6SLL_PAD_SD2_DATA4__SD2_DATA4 0x17059 - MX6SLL_PAD_SD2_DATA5__SD2_DATA5 0x17059 - MX6SLL_PAD_SD2_DATA6__SD2_DATA6 0x17059 - MX6SLL_PAD_SD2_DATA7__SD2_DATA7 0x17059 - MX6SLL_PAD_GPIO4_IO21__SD2_STROBE 0x413059 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2grp_100mhz { - fsl,pins = < - MX6SLL_PAD_SD2_CMD__SD2_CMD 0x170b9 - MX6SLL_PAD_SD2_CLK__SD2_CLK 0x130b9 - MX6SLL_PAD_SD2_DATA0__SD2_DATA0 0x170b9 - MX6SLL_PAD_SD2_DATA1__SD2_DATA1 0x170b9 - MX6SLL_PAD_SD2_DATA2__SD2_DATA2 0x170b9 - MX6SLL_PAD_SD2_DATA3__SD2_DATA3 0x170b9 - MX6SLL_PAD_SD2_DATA4__SD2_DATA4 0x170b9 - MX6SLL_PAD_SD2_DATA5__SD2_DATA5 0x170b9 - MX6SLL_PAD_SD2_DATA6__SD2_DATA6 0x170b9 - MX6SLL_PAD_SD2_DATA7__SD2_DATA7 0x170b9 - MX6SLL_PAD_GPIO4_IO21__SD2_STROBE 0x4130b9 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2grp_200mhz { - fsl,pins = < - MX6SLL_PAD_SD2_CMD__SD2_CMD 0x170f9 - MX6SLL_PAD_SD2_CLK__SD2_CLK 0x130f9 - MX6SLL_PAD_SD2_DATA0__SD2_DATA0 0x170f9 - MX6SLL_PAD_SD2_DATA1__SD2_DATA1 0x170f9 - MX6SLL_PAD_SD2_DATA2__SD2_DATA2 0x170f9 - MX6SLL_PAD_SD2_DATA3__SD2_DATA3 0x170f9 - MX6SLL_PAD_SD2_DATA4__SD2_DATA4 0x170f9 - MX6SLL_PAD_SD2_DATA5__SD2_DATA5 0x170f9 - MX6SLL_PAD_SD2_DATA6__SD2_DATA6 0x170f9 - MX6SLL_PAD_SD2_DATA7__SD2_DATA7 0x170f9 - MX6SLL_PAD_GPIO4_IO21__SD2_STROBE 0x4130f9 - >; - }; - - pinctrl_usdhc3: usdhc3grp { - fsl,pins = < - MX6SLL_PAD_SD3_CMD__SD3_CMD 0x17059 - MX6SLL_PAD_SD3_CLK__SD3_CLK 0x13059 - MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x17059 - MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x17059 - MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x17059 - MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x17059 - >; - }; - - pinctrl_usdhc3_100mhz: usdhc3grp_100mhz { - fsl,pins = < - MX6SLL_PAD_SD3_CMD__SD3_CMD 0x170b9 - MX6SLL_PAD_SD3_CLK__SD3_CLK 0x130b9 - MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x170b9 - MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x170b9 - MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x170b9 - MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x170b9 - >; - }; - - pinctrl_usdhc3_200mhz: usdhc3grp_200mhz { - fsl,pins = < - MX6SLL_PAD_SD3_CMD__SD3_CMD 0x170f9 - MX6SLL_PAD_SD3_CLK__SD3_CLK 0x130f9 - MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x170f9 - MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x170f9 - MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x170f9 - MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x170f9 - >; - }; - - pinctrl_usbotg1: usbotg1grp { - fsl,pins = < - MX6SLL_PAD_EPDC_PWR_COM__USB_OTG1_ID 0x17059 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX6SLL_PAD_I2C1_SCL__I2C1_SCL 0x4001b8b1 - MX6SLL_PAD_I2C1_SDA__I2C1_SDA 0x4001b8b1 - >; - }; - - pinctrl_i2c3: i2c3grp { - fsl,pins = < - MX6SLL_PAD_AUD_RXFS__I2C3_SCL 0x4041b8b1 - MX6SLL_PAD_AUD_RXC__I2C3_SDA 0x4041b8b1 - >; - }; + pinctrl-0 = <&pinctrl_lcd>; + status = "okay";
- pinctrl_pwm1: pmw1grp { - fsl,pins = < - MX6SLL_PAD_PWM1__PWM1_OUT 0x110b0 - >; + port { + display_out: endpoint { + remote-endpoint = <&panel_in>; }; }; };
-&lcdif { +&pwm1 { + #pwm-cells = <2>; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lcdif_dat - &pinctrl_lcdif_ctrl>; - lcd-supply = <®_lcd>; - display = <&display>; + pinctrl-0 = <&pinctrl_pwm1>; status = "okay"; +};
- display: display { - bits-per-pixel = <16>; - bus-width = <24>; - - display-timings { - native-mode = <&timing0>; - timing0: timing0 { - clock-frequency = <33500000>; - hactive = <800>; - vactive = <480>; - hback-porch = <89>; - hfront-porch = <164>; - vback-porch = <23>; - vfront-porch = <10>; - hsync-len = <10>; - vsync-len = <10>; - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; - }; +&snvs_poweroff { + status = "okay"; };
-&pxp { +&snvs_pwrkey { status = "okay"; };
-&pwm1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pwm1>; +&ssi2 { status = "okay"; };
@@ -723,16 +330,6 @@ status = "okay"; };
-&uart5 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart5>; - fsl,uart-has-rtscts; - /* for DTE mode, add below change */ - /* fsl,dte-mode; */ - /* pinctrl-0 = <&pinctrl_uart5dte>; */ - status = "disabled"; -}; - &usdhc1 { pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc1>; @@ -741,34 +338,11 @@ cd-gpios = <&gpio4 7 GPIO_ACTIVE_LOW>; wp-gpios = <&gpio4 22 GPIO_ACTIVE_HIGH>; keep-power-in-suspend; - enable-sdio-wakeup; + wakeup-source; vmmc-supply = <®_sd1_vmmc>; status = "okay"; };
-&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>; - vqmmc-supply = <®_sd2_vmmc>; - bus-width = <8>; - no-removable; - status = "okay"; -}; - -&usdhc3 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc3>; - pinctrl-1 = <&pinctrl_usdhc3_100mhz>; - pinctrl-2 = <&pinctrl_usdhc3_200mhz>; - cd-gpios = <&gpio3 22 GPIO_ACTIVE_LOW>; - keep-power-in-suspend; - enable-sdio-wakeup; - vmmc-supply = <®_sd3_vmmc>; - status = "okay"; -}; - &usbotg1 { vbus-supply = <®_usb_otg1_vbus>; pinctrl-names = "default"; @@ -787,15 +361,216 @@ status = "okay"; };
-&epdc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_epdc0>; - V3P3-supply = <&V3P3_reg>; - VCOM-supply = <&VCOM_reg>; - DISPLAY-supply = <&DISPLAY_reg>; +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + cd-gpios = <&gpio3 22 GPIO_ACTIVE_LOW>; + keep-power-in-suspend; + wakeup-source; + vmmc-supply = <®_sd3_vmmc>; status = "okay"; };
-&ssi2 { - status = "okay"; +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog1>; + fsl,ext-reset-output; +}; + +&iomuxc { + pinctrl_audmux3: audmux3grp { + fsl,pins = < + MX6SLL_PAD_AUD_TXC__AUD3_TXC 0x4130b0 + MX6SLL_PAD_AUD_TXFS__AUD3_TXFS 0x4130b0 + MX6SLL_PAD_AUD_TXD__AUD3_TXD 0x4110b0 + MX6SLL_PAD_AUD_RXD__AUD3_RXD 0x4130b0 + MX6SLL_PAD_AUD_MCLK__AUDIO_CLK_OUT 0x4130b0 + >; + }; + + pinctrl_hp: hpgrp { + fsl,pins = < + MX6SLL_PAD_GPIO4_IO24__GPIO4_IO24 0x17059 /* HP DETECT */ + >; + }; + + pinctrl_reg_sd3_vmmc: sd3vmmcgrp { + fsl,pins = < + MX6SLL_PAD_KEY_COL6__GPIO4_IO04 0x17059 + >; + }; + + pinctrl_usb_otg1_vbus: vbus1grp { + fsl,pins = < + MX6SLL_PAD_KEY_COL4__GPIO4_IO00 0x17059 + >; + }; + + pinctrl_usb_otg2_vbus: vbus2grp { + fsl,pins = < + MX6SLL_PAD_KEY_COL5__GPIO4_IO02 0x17059 + >; + }; + + pinctrl_reg_lcd_3v3: reglcd3v3grp { + fsl,pins = < + MX6SLL_PAD_KEY_ROW5__GPIO4_IO03 0x17059 + >; + }; + + pinctrl_reg_sd1_vmmc: sd1vmmcgrp { + fsl,pins = < + MX6SLL_PAD_KEY_COL3__GPIO3_IO30 0x17059 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6SLL_PAD_UART1_TXD__UART1_DCE_TX 0x1b0b1 + MX6SLL_PAD_UART1_RXD__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6SLL_PAD_SD1_CMD__SD1_CMD 0x17059 + MX6SLL_PAD_SD1_CLK__SD1_CLK 0x13059 + MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x17059 + MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x17059 + MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x17059 + MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x17059 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp_100mhz { + fsl,pins = < + MX6SLL_PAD_SD1_CMD__SD1_CMD 0x170b9 + MX6SLL_PAD_SD1_CLK__SD1_CLK 0x130b9 + MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x170b9 + MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x170b9 + MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x170b9 + MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x170b9 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp_200mhz { + fsl,pins = < + MX6SLL_PAD_SD1_CMD__SD1_CMD 0x170f9 + MX6SLL_PAD_SD1_CLK__SD1_CLK 0x130f9 + MX6SLL_PAD_SD1_DATA0__SD1_DATA0 0x170f9 + MX6SLL_PAD_SD1_DATA1__SD1_DATA1 0x170f9 + MX6SLL_PAD_SD1_DATA2__SD1_DATA2 0x170f9 + MX6SLL_PAD_SD1_DATA3__SD1_DATA3 0x170f9 + >; + }; + + pinctrl_usbotg1: usbotg1grp { + fsl,pins = < + MX6SLL_PAD_EPDC_PWR_COM__USB_OTG1_ID 0x17059 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6SLL_PAD_SD3_CMD__SD3_CMD 0x17061 + MX6SLL_PAD_SD3_CLK__SD3_CLK 0x13061 + MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x17061 + MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x17061 + MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x17061 + MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x17061 + MX6SLL_PAD_REF_CLK_32K__GPIO3_IO22 0x17059 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp_100mhz { + fsl,pins = < + MX6SLL_PAD_SD3_CMD__SD3_CMD 0x170a1 + MX6SLL_PAD_SD3_CLK__SD3_CLK 0x130a1 + MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x170a1 + MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x170a1 + MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x170a1 + MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x170a1 + MX6SLL_PAD_REF_CLK_32K__GPIO3_IO22 0x17059 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp_200mhz { + fsl,pins = < + MX6SLL_PAD_SD3_CMD__SD3_CMD 0x170e9 + MX6SLL_PAD_SD3_CLK__SD3_CLK 0x130f9 + MX6SLL_PAD_SD3_DATA0__SD3_DATA0 0x170e9 + MX6SLL_PAD_SD3_DATA1__SD3_DATA1 0x170e9 + MX6SLL_PAD_SD3_DATA2__SD3_DATA2 0x170e9 + MX6SLL_PAD_SD3_DATA3__SD3_DATA3 0x170e9 + MX6SLL_PAD_REF_CLK_32K__GPIO3_IO22 0x17059 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6SLL_PAD_I2C1_SCL__I2C1_SCL 0x4001b8b1 + MX6SLL_PAD_I2C1_SDA__I2C1_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6SLL_PAD_AUD_RXFS__I2C3_SCL 0x4041b8b1 + MX6SLL_PAD_AUD_RXC__I2C3_SDA 0x4041b8b1 + >; + }; + + pinctrl_lcd: lcdgrp { + fsl,pins = < + MX6SLL_PAD_LCD_DATA00__LCD_DATA00 0x79 + MX6SLL_PAD_LCD_DATA01__LCD_DATA01 0x79 + MX6SLL_PAD_LCD_DATA02__LCD_DATA02 0x79 + MX6SLL_PAD_LCD_DATA03__LCD_DATA03 0x79 + MX6SLL_PAD_LCD_DATA04__LCD_DATA04 0x79 + MX6SLL_PAD_LCD_DATA05__LCD_DATA05 0x79 + MX6SLL_PAD_LCD_DATA06__LCD_DATA06 0x79 + MX6SLL_PAD_LCD_DATA07__LCD_DATA07 0x79 + MX6SLL_PAD_LCD_DATA08__LCD_DATA08 0x79 + MX6SLL_PAD_LCD_DATA09__LCD_DATA09 0x79 + MX6SLL_PAD_LCD_DATA10__LCD_DATA10 0x79 + MX6SLL_PAD_LCD_DATA11__LCD_DATA11 0x79 + MX6SLL_PAD_LCD_DATA12__LCD_DATA12 0x79 + MX6SLL_PAD_LCD_DATA13__LCD_DATA13 0x79 + MX6SLL_PAD_LCD_DATA14__LCD_DATA14 0x79 + MX6SLL_PAD_LCD_DATA15__LCD_DATA15 0x79 + MX6SLL_PAD_LCD_DATA16__LCD_DATA16 0x79 + MX6SLL_PAD_LCD_DATA17__LCD_DATA17 0x79 + MX6SLL_PAD_LCD_DATA18__LCD_DATA18 0x79 + MX6SLL_PAD_LCD_DATA19__LCD_DATA19 0x79 + MX6SLL_PAD_LCD_DATA20__LCD_DATA20 0x79 + MX6SLL_PAD_LCD_DATA21__LCD_DATA21 0x79 + MX6SLL_PAD_LCD_DATA22__LCD_DATA22 0x79 + MX6SLL_PAD_LCD_DATA23__LCD_DATA23 0x79 + MX6SLL_PAD_LCD_CLK__LCD_CLK 0x79 + MX6SLL_PAD_LCD_ENABLE__LCD_ENABLE 0x79 + MX6SLL_PAD_LCD_HSYNC__LCD_HSYNC 0x79 + MX6SLL_PAD_LCD_VSYNC__LCD_VSYNC 0x79 + MX6SLL_PAD_LCD_RESET__LCD_RESET 0x79 + >; + }; + + pinctrl_led: ledgrp { + fsl,pins = < + MX6SLL_PAD_EPDC_VCOM1__GPIO2_IO04 0x17059 + >; + }; + + pinctrl_pwm1: pmw1grp { + fsl,pins = < + MX6SLL_PAD_PWM1__PWM1_OUT 0x110b0 + >; + }; + + pinctrl_wdog1: wdog1grp { + fsl,pins = < + MX6SLL_PAD_WDOG_B__WDOG1_B 0x170b0 + >; + }; }; diff --git a/arch/arm/dts/imx6sll-pinfunc.h b/arch/arm/dts/imx6sll-pinfunc.h index 5a3700b0a0..713a346f4c 100644 --- a/arch/arm/dts/imx6sll-pinfunc.h +++ b/arch/arm/dts/imx6sll-pinfunc.h @@ -1,9 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright 2017-2018 NXP. * */
diff --git a/arch/arm/dts/imx6sll.dtsi b/arch/arm/dts/imx6sll.dtsi index ebc6d9d2c9..d4a000c3dd 100644 --- a/arch/arm/dts/imx6sll.dtsi +++ b/arch/arm/dts/imx6sll.dtsi @@ -1,18 +1,19 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2017-2018 NXP. * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
#include <dt-bindings/clock/imx6sll-clock.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include "imx6sll-pinfunc.h" -#include "skeleton.dtsi"
/ { + #address-cells = <1>; + #size-cells = <1>; + aliases { gpio0 = &gpio1; gpio1 = &gpio2; @@ -35,6 +36,8 @@ spi1 = &ecspi2; spi3 = &ecspi3; spi4 = &ecspi4; + usb0 = &usbotg1; + usb1 = &usbotg2; usbphy0 = &usbphy1; usbphy1 = &usbphy2; }; @@ -48,80 +51,58 @@ device_type = "cpu"; reg = <0>; next-level-cache = <&L2>; - operating-points = < + operating-points = /* kHz uV */ - 996000 1225000 - 792000 1175000 - 396000 1075000 - 198000 975000 - >; - fsl,soc-operating-points = < + <996000 1275000>, + <792000 1175000>, + <396000 1075000>, + <198000 975000>; + fsl,soc-operating-points = /* ARM kHz SOC-PU uV */ - 996000 1225000 - 792000 1175000 - 396000 1175000 - 198000 1175000 - >; + <996000 1175000>, + <792000 1175000>, + <396000 1175000>, + <198000 1175000>; clock-latency = <61036>; /* two CLK32 periods */ - fsl,low-power-run; + #cooling-cells = <2>; clocks = <&clks IMX6SLL_CLK_ARM>, <&clks IMX6SLL_CLK_PLL2_PFD2>, <&clks IMX6SLL_CLK_STEP>, <&clks IMX6SLL_CLK_PLL1_SW>, - <&clks IMX6SLL_CLK_PLL1_SYS>, - <&clks IMX6SLL_CLK_PLL1>, - <&clks IMX6SLL_PLL1_BYPASS>, - <&clks IMX6SLL_PLL1_BYPASS_SRC>; + <&clks IMX6SLL_CLK_PLL1_SYS>; clock-names = "arm", "pll2_pfd2_396m", "step", - "pll1_sw", "pll1_sys", "pll1", "pll1_bypass", - "pll1_bypass_src"; + "pll1_sw", "pll1_sys"; + nvmem-cells = <&cpu_speed_grade>; + nvmem-cell-names = "speed_grade"; }; };
- intc: interrupt-controller@00a01000 { - compatible = "arm,cortex-a9-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x00a01000 0x1000>, - <0x00a00100 0x100>; - interrupt-parent = <&intc>; + ckil: clock-ckil { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "ckil"; };
- clocks { - #address-cells = <1>; - #size-cells = <0>; - - ckil: clock@0 { - compatible = "fixed-clock"; - reg = <0>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "ckil"; - }; - - osc: clock@1 { - compatible = "fixed-clock"; - reg = <1>; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "osc"; - }; + osc: clock-osc-24m { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + clock-output-names = "osc"; + };
- ipp_di0: clock@2 { - compatible = "fixed-clock"; - reg = <2>; - #clock-cells = <0>; - clock-frequency = <0>; - clock-output-names = "ipp_di0"; - }; + ipp_di0: clock-ipp-di0 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + clock-output-names = "ipp_di0"; + };
- ipp_di1: clock@3 { - compatible = "fixed-clock"; - reg = <3>; - #clock-cells = <0>; - clock-frequency = <0>; - clock-output-names = "ipp_di1"; - }; + ipp_di1: clock-ipp-di1 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0>; + clock-output-names = "ipp_di1"; };
soc { @@ -131,42 +112,21 @@ interrupt-parent = <&gpc>; ranges;
- busfreq { - compatible = "fsl,imx_busfreq"; - clocks = <&clks IMX6SLL_CLK_PLL2_PFD2>, <&clks IMX6SLL_CLK_PLL2_198M>, - <&clks IMX6SLL_CLK_PLL2_BUS>, <&clks IMX6SLL_CLK_ARM>, - <&clks IMX6SLL_CLK_PLL3_USB_OTG>, <&clks IMX6SLL_CLK_PERIPH>, - <&clks IMX6SLL_CLK_PERIPH_PRE>, <&clks IMX6SLL_CLK_PERIPH_CLK2>, - <&clks IMX6SLL_CLK_PERIPH_CLK2_SEL>, <&clks IMX6SLL_CLK_OSC>, - <&clks IMX6SLL_CLK_AHB>, <&clks IMX6SLL_CLK_AXI_PODF>, - <&clks IMX6SLL_CLK_PERIPH2>, <&clks IMX6SLL_CLK_PERIPH2_PRE>, - <&clks IMX6SLL_CLK_PERIPH2_CLK2>, <&clks IMX6SLL_CLK_PERIPH2_CLK2_SEL>, - <&clks IMX6SLL_CLK_STEP>, <&clks IMX6SLL_CLK_MMDC_P0_FAST>, <&clks IMX6SLL_PLL1_BYPASS_SRC>, - <&clks IMX6SLL_PLL1_BYPASS>, <&clks IMX6SLL_CLK_PLL1_SYS>, <&clks IMX6SLL_CLK_PLL1_SW>, - <&clks IMX6SLL_CLK_PLL1>; - clock-names = "pll2_pfd2_396m", "pll2_198m", "pll2_bus", "arm", "pll3_usb_otg", - "periph", "periph_pre", "periph_clk2", "periph_clk2_sel", "osc", - "ahb", "ocram", "periph2", "periph2_pre", "periph2_clk2", "periph2_clk2_sel", - "step", "mmdc", "pll1_bypass_src", "pll1_bypass", "pll1_sys", "pll1_sw", "pll1"; - fsl,max_ddr_freq = <400000000>; - }; - - ocrams: sram@00900000 { - compatible = "fsl,lpm-sram"; - reg = <0x00900000 0x4000>; + ocram: sram@900000 { + compatible = "mmio-sram"; + reg = <0x00900000 0x20000>; };
- ocrams_ddr: sram@00904000 { - compatible = "fsl,ddr-lpm-sram"; - reg = <0x00904000 0x1000>; + intc: interrupt-controller@a01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00a01000 0x1000>, + <0x00a00100 0x100>; + interrupt-parent = <&intc>; };
- ocram: sram@00905000 { - compatible = "mmio-sram"; - reg = <0x00905000 0x1B000>; - }; - - L2: l2-cache@00a02000 { + L2: cache-controller@a02000 { compatible = "arm,pl310-cache"; reg = <0x00a02000 0x1000>; interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; @@ -176,21 +136,21 @@ arm,data-latency = <4 2 3>; };
- aips1: bus@02000000 { + aips1: bus@2000000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x100000>; ranges;
- spba: spba-bus@02000000 { + spba: spba-bus@2000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x40000>; ranges;
- spdif: spdif@02004000 { + spdif: spdif@2004000 { compatible = "fsl,imx6sl-spdif", "fsl,imx35-spdif"; reg = <0x02004000 0x4000>; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; @@ -214,7 +174,7 @@ status = "disabled"; };
- ecspi1: ecspi@02008000 { + ecspi1: spi@2008000 { compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; reg = <0x02008000 0x4000>; interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; @@ -226,7 +186,7 @@ status = "disabled"; };
- ecspi2: ecspi@0200c000 { + ecspi2: spi@200c000 { compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; reg = <0x0200c000 0x4000>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; @@ -238,7 +198,7 @@ status = "disabled"; };
- ecspi3: ecspi@02010000 { + ecspi3: spi@2010000 { compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; reg = <0x02010000 0x4000>; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; @@ -250,7 +210,7 @@ status = "disabled"; };
- ecspi4: ecspi@02014000 { + ecspi4: spi@2014000 { compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; reg = <0x02014000 0x4000>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; @@ -262,10 +222,11 @@ status = "disabled"; };
- uart4: serial@02018000 { - compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", "fsl,imx21-uart"; + uart4: serial@2018000 { + compatible = "fsl,imx6sl-uart", "fsl,imx6q-uart", + "fsl,imx21-uart"; reg = <0x02018000 0x4000>; - interrupts =<GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 31 4 0>, <&sdma 32 4 0>; dma-names = "rx", "tx"; clocks = <&clks IMX6SLL_CLK_UART4_IPG>, @@ -274,8 +235,9 @@ status = "disabled"; };
- uart1: serial@02020000 { - compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", "fsl,imx21-uart"; + uart1: serial@2020000 { + compatible = "fsl,imx6sl-uart", "fsl,imx6q-uart", + "fsl,imx21-uart"; reg = <0x02020000 0x4000>; interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 25 4 0>, <&sdma 26 4 0>; @@ -286,8 +248,9 @@ status = "disabled"; };
- uart2: serial@02024000 { - compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", "fsl,imx21-uart"; + uart2: serial@2024000 { + compatible = "fsl,imx6sl-uart", "fsl,imx6q-uart", + "fsl,imx21-uart"; reg = <0x02024000 0x4000>; interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 27 4 0>, <&sdma 28 4 0>; @@ -298,8 +261,8 @@ status = "disabled"; };
- ssi1: ssi@02028000 { - compatible = "fsl,imx6sll-ssi", "fsl,imx51-ssi"; + ssi1: ssi@2028000 { + compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; reg = <0x02028000 0x4000>; interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 37 22 0>, <&sdma 38 22 0>; @@ -311,8 +274,8 @@ status = "disabled"; };
- ssi2: ssi2@0202c000 { - compatible = "fsl,imx6sll-ssi", "fsl,imx51-ssi"; + ssi2: ssi@202c000 { + compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; reg = <0x0202c000 0x4000>; interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 41 22 0>, <&sdma 42 22 0>; @@ -324,8 +287,8 @@ status = "disabled"; };
- ssi3: ssi@02030000 { - compatible = "fsl,imx6sll-ssi", "fsl,imx51-ssi"; + ssi3: ssi@2030000 { + compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; reg = <0x02030000 0x4000>; interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 45 22 0>, <&sdma 46 22 0>; @@ -337,8 +300,9 @@ status = "disabled"; };
- uart3: serial@02034000 { - compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", "fsl,imx21-uart"; + uart3: serial@2034000 { + compatible = "fsl,imx6sl-uart", "fsl,imx6q-uart", + "fsl,imx21-uart"; reg = <0x02034000 0x4000>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 29 4 0>, <&sdma 30 4 0>; @@ -350,48 +314,48 @@ }; };
- pwm1: pwm@02080000 { + pwm1: pwm@2080000 { compatible = "fsl,imx6sll-pwm", "fsl,imx27-pwm"; reg = <0x02080000 0x4000>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_PWM1>, <&clks IMX6SLL_CLK_PWM1>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
- pwm2: pwm@02084000 { + pwm2: pwm@2084000 { compatible = "fsl,imx6sll-pwm", "fsl,imx27-pwm"; reg = <0x02084000 0x4000>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_PWM2>, <&clks IMX6SLL_CLK_PWM2>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
- pwm3: pwm@02088000 { + pwm3: pwm@2088000 { compatible = "fsl,imx6sll-pwm", "fsl,imx27-pwm"; reg = <0x02088000 0x4000>; interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_PWM3>, <&clks IMX6SLL_CLK_PWM3>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
- pwm4: pwm@0208c000 { + pwm4: pwm@208c000 { compatible = "fsl,imx6sll-pwm", "fsl,imx27-pwm"; reg = <0x0208c000 0x4000>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_PWM4>, <&clks IMX6SLL_CLK_PWM4>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; };
- gpt1: gpt@02098000 { - compatible = "fsl,imx6sll-gpt"; + gpt1: timer@2098000 { + compatible = "fsl,imx6sl-gpt"; reg = <0x02098000 0x4000>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_GPT_BUS>, @@ -399,73 +363,104 @@ clock-names = "ipg", "per"; };
- gpio1: gpio@0209c000 { + gpio1: gpio@209c000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x0209c000 0x4000>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO1>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 94 7>, <&iomuxc 7 25 25>; };
- gpio2: gpio@020a0000 { + gpio2: gpio@20a0000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x020a0000 0x4000>; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO2>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 50 32>; };
- gpio3: gpio@020a4000 { + gpio3: gpio@20a4000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x020a4000 0x4000>; interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO3>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; + gpio-ranges = <&iomuxc 0 82 12>, <&iomuxc 12 103 4>, + <&iomuxc 16 101 2>, <&iomuxc 18 5 1>, + <&iomuxc 21 6 11>; };
- gpio4: gpio@020a8000 { + gpio4: gpio@20a8000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x020a8000 0x4000>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO4>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; - }; - - gpio5: gpio@020ac000 { + gpio-ranges = <&iomuxc 0 17 8>, <&iomuxc 8 107 8>, + <&iomuxc 16 151 1>, <&iomuxc 17 149 1>, + <&iomuxc 18 146 1>, <&iomuxc 19 144 1>, + <&iomuxc 20 142 1>, <&iomuxc 21 143 1>, + <&iomuxc 22 150 1>, <&iomuxc 23 148 1>, + <&iomuxc 24 147 1>, <&iomuxc 25 145 1>, + <&iomuxc 26 152 1>, <&iomuxc 27 125 1>, + <&iomuxc 28 131 1>, <&iomuxc 29 134 1>, + <&iomuxc 30 129 1>, <&iomuxc 31 133 1>; + }; + + gpio5: gpio@20ac000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x020ac000 0x4000>; interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO5>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; - }; - - gpio6: gpio@020b0000 { + gpio-ranges = <&iomuxc 0 135 1>, <&iomuxc 1 128 1>, + <&iomuxc 2 132 1>, <&iomuxc 3 130 1>, + <&iomuxc 4 127 1>, <&iomuxc 5 126 1>, + <&iomuxc 6 120 1>, <&iomuxc 7 123 1>, + <&iomuxc 8 118 1>, <&iomuxc 9 122 1>, + <&iomuxc 10 124 1>, <&iomuxc 11 117 1>, + <&iomuxc 12 121 1>, <&iomuxc 13 119 1>, + <&iomuxc 14 116 1>, <&iomuxc 15 115 1>, + <&iomuxc 16 140 2>, <&iomuxc 18 136 1>, + <&iomuxc 19 138 1>, <&iomuxc 20 139 1>, + <&iomuxc 21 137 1>; + }; + + gpio6: gpio@20b0000 { compatible = "fsl,imx6sll-gpio", "fsl,imx35-gpio"; reg = <0x020b0000 0x4000>; interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SLL_CLK_GPIO6>; gpio-controller; #gpio-cells = <2>; interrupt-controller; #interrupt-cells = <2>; };
- kpp: kpp@020b8000 { + kpp: keypad@20b8000 { compatible = "fsl,imx6sll-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -473,14 +468,14 @@ status = "disabled"; };
- wdog1: wdog@020bc000 { + wdog1: watchdog@20bc000 { compatible = "fsl,imx6sll-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_WDOG1>; };
- wdog2: wdog@020c0000 { + wdog2: watchdog@20c0000 { compatible = "fsl,imx6sll-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; @@ -488,7 +483,7 @@ status = "disabled"; };
- clks: ccm@020c4000 { + clks: clock-controller@20c4000 { compatible = "fsl,imx6sll-ccm"; reg = <0x020c4000 0x4000>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, @@ -496,19 +491,25 @@ #clock-cells = <1>; clocks = <&ckil>, <&osc>, <&ipp_di0>, <&ipp_di1>; clock-names = "ckil", "osc", "ipp_di0", "ipp_di1"; + + assigned-clocks = <&clks IMX6SLL_CLK_PERCLK_SEL>; + assigned-clock-parents = <&clks IMX6SLL_CLK_OSC>; };
- anatop: anatop@020c8000 { + anatop: anatop@20c8000 { compatible = "fsl,imx6sll-anatop", "fsl,imx6q-anatop", - "syscon", "simple-bus"; + "syscon", "simple-mfd"; reg = <0x020c8000 0x4000>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>;
- reg_3p0: regulator-3p0@120 { + reg_3p0: regulator-3p0@20c8120 { compatible = "fsl,anatop-regulator"; + reg = <0x20c8120>; regulator-name = "vdd3p0"; regulator-min-microvolt = <2625000>; regulator-max-microvolt = <3400000>; @@ -520,18 +521,19 @@ anatop-max-voltage = <3400000>; anatop-enable-bit = <0>; }; - };
- tempmon: tempmon { - compatible = "fsl,imx6sll-tempmon", "fsl,imx6sx-tempmon"; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; - fsl,tempmon = <&anatop>; - fsl,tempmon-data = <&ocotp>; - clocks = <&clks IMX6SLL_CLK_PLL3_USB_OTG>; - status = "disabled"; + tempmon: temperature-sensor { + compatible = "fsl,imx6sll-tempmon", "fsl,imx6sx-tempmon"; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + interrupt-parent = <&gpc>; + fsl,tempmon = <&anatop>; + nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>; + nvmem-cell-names = "calib", "temp_grade"; + clocks = <&clks IMX6SLL_CLK_PLL3_USB_OTG>; + }; };
- usbphy1: usbphy@020c9000 { + usbphy1: usb-phy@20c9000 { compatible = "fsl,imx6sll-usbphy", "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020c9000 0x1000>; @@ -541,7 +543,7 @@ fsl,anatop = <&anatop>; };
- usbphy2: usbphy@020ca000 { + usbphy2: usb-phy@20ca000 { compatible = "fsl,imx6sll-usbphy", "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020ca000 0x1000>; @@ -551,7 +553,7 @@ fsl,anatop = <&anatop>; };
- snvs: snvs@020cc000 { + snvs: snvs@20cc000 { compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; reg = <0x020cc000 0x4000>;
@@ -559,7 +561,8 @@ compatible = "fsl,sec-v4.0-mon-rtc-lp"; regmap = <&snvs>; offset = <0x34>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; };
snvs_poweroff: snvs-poweroff { @@ -567,6 +570,7 @@ regmap = <&snvs>; offset = <0x38>; mask = <0x61>; + status = "disabled"; };
snvs_pwrkey: snvs-powerkey { @@ -574,21 +578,12 @@ regmap = <&snvs>; interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; linux,keycode = <KEY_POWER>; - wakeup; + wakeup-source; + status = "disabled"; }; };
- epit1: epit@020d0000 { - reg = <0x020d0000 0x4000>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - }; - - epit2: epit@020d4000 { - reg = <0x020d4000 0x4000>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - }; - - src: src@020d8000 { + src: reset-controller@20d8000 { compatible = "fsl,imx6sll-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, @@ -596,28 +591,27 @@ #reset-cells = <1>; };
- gpc: gpc@020dc000 { + gpc: interrupt-controller@20dc000 { compatible = "fsl,imx6sll-gpc", "fsl,imx6q-gpc"; reg = <0x020dc000 0x4000>; interrupt-controller; #interrupt-cells = <3>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; - fsl,mf-mix-wakeup-irq = <0x7c00000 0x7d00 0x0 0x1400640>; };
- iomuxc: iomuxc@020e0000 { + iomuxc: pinctrl@20e0000 { compatible = "fsl,imx6sll-iomuxc"; reg = <0x020e0000 0x4000>; };
- gpr: iomuxc-gpr@020e4000 { + gpr: iomuxc-gpr@20e4000 { compatible = "fsl,imx6sll-iomuxc-gpr", "fsl,imx6q-iomuxc-gpr", "syscon"; reg = <0x020e4000 0x4000>; };
- csi: csi@020e8000 { + csi: csi@20e8000 { compatible = "fsl,imx6sll-csi", "fsl,imx6s-csi"; reg = <0x020e8000 0x4000>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; @@ -628,11 +622,11 @@ status = "disabled"; };
- sdma: sdma@020ec000 { - compatible = "fsl,imx6sll-sdma", "fsl,imx35-sdma"; + sdma: dma-controller@20ec000 { + compatible = "fsl,imx6sll-sdma", "fsl,imx6ul-sdma"; reg = <0x020ec000 0x4000>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SLL_CLK_SDMA>, + clocks = <&clks IMX6SLL_CLK_IPG>, <&clks IMX6SLL_CLK_SDMA>; clock-names = "ipg", "ahb"; #dma-cells = <3>; @@ -640,27 +634,16 @@ fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; };
- pxp: pxp@020f0000 { - compatible = "fsl,imx6ull-pxp-dma", "fsl,imx7d-pxp-dma"; - reg = <0x020f0000 0x4000>; + pxp: pxp@20f0000 { + compatible = "fsl,imx6sll-pxp", "fsl,imx6ull-pxp"; + reg = <0x20f0000 0x4000>; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SLL_CLK_DUMMY>, - <&clks IMX6SLL_CLK_PXP>; - clock-names = "pxp_ipg", "pxp_axi"; - status = "disabled"; - }; - - epdc: epdc@020f4000 { - compatible = "fsl,imx6sll-epdc", "fsl,imx7d-epdc"; - reg = <0x020f4000 0x4000>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SLL_CLK_EPDC_AXI>, <&clks IMX6SLL_CLK_EPDC_PIX>; - clock-names = "epdc_axi", "epdc_pix"; - status = "disabled"; + clocks = <&clks IMX6SLL_CLK_PXP>; + clock-names = "axi"; };
- lcdif: lcdif@020f8000 { + lcdif: lcd-controller@20f8000 { compatible = "fsl,imx6sll-lcdif", "fsl,imx28-lcdif"; reg = <0x020f8000 0x4000>; interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; @@ -671,8 +654,8 @@ status = "disabled"; };
- dcp: dcp@020fc000 { - compatible = "fsl,imx6sl-dcp"; + dcp: crypto@20fc000 { + compatible = "fsl,imx28-dcp"; reg = <0x020fc000 0x4000>; interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, @@ -682,14 +665,14 @@ }; };
- aips2: bus@02100000 { + aips2: bus@2100000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02100000 0x100000>; ranges;
- usbotg1: usb@02184000 { + usbotg1: usb@2184000 { compatible = "fsl,imx6sll-usb", "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184000 0x200>; @@ -704,7 +687,7 @@ status = "disabled"; };
- usbotg2: usb@02184200 { + usbotg2: usb@2184200 { compatible = "fsl,imx6sll-usb", "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184200 0x200>; @@ -718,14 +701,14 @@ status = "disabled"; };
- usbmisc: usbmisc@02184800 { + usbmisc: usbmisc@2184800 { #index-cells = <1>; compatible = "fsl,imx6sll-usbmisc", "fsl,imx6ul-usbmisc", "fsl,imx6q-usbmisc"; reg = <0x02184800 0x200>; };
- usdhc1: usdhc@02190000 { + usdhc1: mmc@2190000 { compatible = "fsl,imx6sll-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02190000 0x4000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; @@ -739,7 +722,7 @@ status = "disabled"; };
- usdhc2: usdhc@02194000 { + usdhc2: mmc@2194000 { compatible = "fsl,imx6sll-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02194000 0x4000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; @@ -753,7 +736,7 @@ status = "disabled"; };
- usdhc3: usdhc@02198000 { + usdhc3: mmc@2198000 { compatible = "fsl,imx6sll-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02198000 0x4000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; @@ -767,17 +750,17 @@ status = "disabled"; };
- i2c1: i2c@021a0000 { + i2c1: i2c@21a0000 { #address-cells = <1>; #size-cells = <0>; - compatible = "fs,imx6sll-i2c", "fsl,imx21-i2c"; + compatible = "fsl,imx6sll-i2c", "fsl,imx21-i2c"; reg = <0x021a0000 0x4000>; interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SLL_CLK_I2C1>; status = "disabled"; };
- i2c2: i2c@021a4000 { + i2c2: i2c@21a4000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sll-i2c", "fsl,imx21-i2c"; @@ -787,7 +770,7 @@ status = "disabled"; };
- i2c3: i2c@021a8000 { + i2c3: i2c@21a8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sll-i2c", "fsl,imx21-i2c"; @@ -797,56 +780,50 @@ status = "disabled"; };
- romcp@021ac000 { - compatible = "fsl,imx6sll-romcp", "syscon"; - reg = <0x021ac000 0x4000>; - }; - - mmdc: mmdc@021b0000 { + mmdc: memory-controller@21b0000 { compatible = "fsl,imx6sll-mmdc", "fsl,imx6q-mmdc"; reg = <0x021b0000 0x4000>; + clocks = <&clks IMX6SLL_CLK_MMDC_P0_IPG>; };
- rngb: rngb@021b4000 { - compatible = "fsl,imx6sl-rng", "fsl,imx-rng", "imx-rng"; + rngb: rng@21b4000 { + compatible = "fsl,imx6sll-rngb", "fsl,imx25-rngb"; reg = <0x021b4000 0x4000>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SLL_CLK_DUMMY>; + clocks = <&clks IMX6SLL_CLK_DUMMY>; };
- ocotp: ocotp-ctrl@021bc000 { + ocotp: efuse@21bc000 { + #address-cells = <1>; + #size-cells = <1>; compatible = "fsl,imx6sll-ocotp", "syscon"; reg = <0x021bc000 0x4000>; clocks = <&clks IMX6SLL_CLK_OCOTP>; - };
- csu: csu@021c0000 { - compatible = "fsl,imx6sll-csu"; - reg = <0x021c0000 0x4000>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; + cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + };
- snvs_gpr: snvs-gpr@0x021c4000 { - compatible = "fsl, imx6sll-snvs-gpr"; - reg = <0x021c4000 0x10000>; - }; + tempmon_calib: calib@38 { + reg = <0x38 4>; + };
- iomuxc_snvs: iomuxc-snvs@021c8000 { - compatible = "fsl,imx6sll-iomuxc-snvs"; - reg = <0x021c80000 0x10000>; + tempmon_temp_grade: temp-grade@20 { + reg = <0x20 4>; + }; };
- audmux: audmux@021d8000 { + audmux: audmux@21d8000 { compatible = "fsl,imx6sll-audmux", "fsl,imx31-audmux"; reg = <0x021d8000 0x4000>; status = "disabled"; };
- uart5: serial@021f4000 { - compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", "fsl,imx21-uart"; + uart5: serial@21f4000 { + compatible = "fsl,imx6sll-uart", "fsl,imx6q-uart", + "fsl,imx21-uart"; reg = <0x021f4000 0x4000>; - interrupts =<GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sdma 33 4 0>, <&sdma 34 4 0>; dma-names = "rx", "tx"; clocks = <&clks IMX6SLL_CLK_UART5_IPG>, diff --git a/include/dt-bindings/clock/imx6sll-clock.h b/include/dt-bindings/clock/imx6sll-clock.h index 39c25671d6..494fd0c37f 100644 --- a/include/dt-bindings/clock/imx6sll-clock.h +++ b/include/dt-bindings/clock/imx6sll-clock.h @@ -1,9 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (C) 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright 2017-2018 NXP. * */
@@ -199,6 +197,14 @@ #define IMX6SLL_CLK_EXTERN_AUDIO_PODF 171 #define IMX6SLL_CLK_EXTERN_AUDIO 172
-#define IMX6SLL_CLK_END 173 +#define IMX6SLL_CLK_GPIO1 173 +#define IMX6SLL_CLK_GPIO2 174 +#define IMX6SLL_CLK_GPIO3 175 +#define IMX6SLL_CLK_GPIO4 176 +#define IMX6SLL_CLK_GPIO5 177 +#define IMX6SLL_CLK_GPIO6 178 +#define IMX6SLL_CLK_MMDC_P1_IPG 179 + +#define IMX6SLL_CLK_END 180
#endif /* __DT_BINDINGS_CLOCK_IMX6SLL_H */
From: Marcel Ziswiler marcel.ziswiler@toradex.com Synchronise device tree with linux v6.0-rc1. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
arch/arm/dts/imx6sl-evk.dts | 183 ++++++------ arch/arm/dts/imx6sl-pinfunc.h | 6 +- arch/arm/dts/imx6sl.dtsi | 362 ++++++++++++++--------- include/dt-bindings/clock/imx6sl-clock.h | 10 +- 4 files changed, 325 insertions(+), 236 deletions(-)
diff --git a/arch/arm/dts/imx6sl-evk.dts b/arch/arm/dts/imx6sl-evk.dts index 0a90eea170..f16c830f1e 100644 --- a/arch/arm/dts/imx6sl-evk.dts +++ b/arch/arm/dts/imx6sl-evk.dts @@ -1,10 +1,6 @@ -/* - * Copyright (C) 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ +// SPDX-License-Identifier: GPL-2.0 +// +//Copyright (C) 2013 Freescale Semiconductor, Inc.
/dts-v1/;
@@ -16,11 +12,16 @@ model = "Freescale i.MX6 SoloLite EVK Board"; compatible = "fsl,imx6sl-evk", "fsl,imx6sl";
- memory { + chosen { + stdout-path = &uart1; + }; + + memory@80000000 { + device_type = "memory"; reg = <0x80000000 0x40000000>; };
- backlight { + backlight_display: backlight_display { compatible = "pwm-backlight"; pwms = <&pwm1 0 5000000>; brightness-levels = <0 4 8 16 32 64 128 255>; @@ -39,62 +40,62 @@ }; };
- regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - reg_usb_otg1_vbus: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - regulator-name = "usb_otg1_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio4 0 0>; - enable-active-high; - vin-supply = <&swbst_reg>; - }; + reg_usb_otg1_vbus: regulator-usb-otg1-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_otg1_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 0 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&swbst_reg>; + };
- reg_usb_otg2_vbus: regulator@1 { - compatible = "regulator-fixed"; - reg = <1>; - regulator-name = "usb_otg2_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio4 2 0>; - enable-active-high; - vin-supply = <&swbst_reg>; - }; + reg_usb_otg2_vbus: regulator-usb-otg2-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_otg2_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio4 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&swbst_reg>; + };
- reg_aud3v: regulator@2 { - compatible = "regulator-fixed"; - reg = <2>; - regulator-name = "wm8962-supply-3v15"; - regulator-min-microvolt = <3150000>; - regulator-max-microvolt = <3150000>; - regulator-boot-on; - }; + reg_aud3v: regulator-aud3v { + compatible = "regulator-fixed"; + regulator-name = "wm8962-supply-3v15"; + regulator-min-microvolt = <3150000>; + regulator-max-microvolt = <3150000>; + regulator-boot-on; + };
- reg_aud4v: regulator@3 { - compatible = "regulator-fixed"; - reg = <3>; - regulator-name = "wm8962-supply-4v2"; - regulator-min-microvolt = <4325000>; - regulator-max-microvolt = <4325000>; - regulator-boot-on; - }; + reg_aud4v: regulator-aud4v { + compatible = "regulator-fixed"; + regulator-name = "wm8962-supply-4v2"; + regulator-min-microvolt = <4325000>; + regulator-max-microvolt = <4325000>; + regulator-boot-on; + };
- reg_lcd_3v3: regulator@4 { - compatible = "regulator-fixed"; - reg = <4>; - regulator-name = "lcd-3v3"; - gpio = <&gpio4 3 0>; - enable-active-high; - }; + reg_lcd_3v3: regulator-lcd-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_lcd_3v3>; + regulator-name = "lcd-3v3"; + gpio = <&gpio4 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_lcd_5v: regulator-lcd-5v { + compatible = "regulator-fixed"; + regulator-name = "lcd-5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; };
sound { compatible = "fsl,imx6sl-evk-wm8962", "fsl,imx-audio-wm8962"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hp>; model = "wm8962-audio"; ssi-controller = <&ssi2>; audio-codec = <&codec>; @@ -107,6 +108,20 @@ "IN3R", "AMIC"; mux-int-port = <2>; mux-ext-port = <3>; + hp-det-gpio = <&gpio4 19 GPIO_ACTIVE_LOW>; + }; + + panel { + compatible = "sii,43wvf1g"; + backlight = <&backlight_display>; + dvdd-supply = <®_lcd_3v3>; + avdd-supply = <®_lcd_5v>; + + port { + panel_in: endpoint { + remote-endpoint = <&display_out>; + }; + }; }; };
@@ -117,12 +132,12 @@ };
&ecspi1 { - cs-gpios = <&gpio4 11 0>; + cs-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi1>; status = "okay";
- flash: m25p80@0 { + flash: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "st,m25p32", "jedec,spi-nor"; @@ -145,7 +160,7 @@ pinctrl-0 = <&pinctrl_i2c1>; status = "okay";
- pmic: pfuze100@08 { + pmic: pfuze100@8 { compatible = "fsl,pfuze100"; reg = <0x08>;
@@ -190,6 +205,7 @@ sw4_reg: sw4 { regulator-min-microvolt = <800000>; regulator-max-microvolt = <3300000>; + regulator-always-on; };
swbst_reg: swbst { @@ -330,6 +346,12 @@ >; };
+ pinctrl_hp: hpgrp { + fsl,pins = < + MX6SL_PAD_FEC_RX_ER__GPIO4_IO19 0x1b0b0 + >; + }; + pinctrl_i2c1: i2c1grp { fsl,pins = < MX6SL_PAD_I2C1_SCL__I2C1_SCL 0x4001b8b1 @@ -401,6 +423,12 @@ >; };
+ pinctrl_reg_lcd_3v3: reglcd3v3grp { + fsl,pins = < + MX6SL_PAD_KEY_ROW5__GPIO4_IO03 0x17059 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < MX6SL_PAD_UART1_RXD__UART1_RX_DATA 0x1b0b1 @@ -546,41 +574,30 @@ &lcdif { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lcd>; - lcd-supply = <®_lcd_3v3>; - display = <&display0>; status = "okay";
- display0: display0 { - bits-per-pixel = <32>; - bus-width = <24>; - - display-timings { - native-mode = <&timing0>; - timing0: timing0 { - clock-frequency = <33500000>; - hactive = <800>; - vactive = <480>; - hback-porch = <89>; - hfront-porch = <164>; - vback-porch = <23>; - vfront-porch = <10>; - hsync-len = <10>; - vsync-len = <10>; - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; + port { + display_out: endpoint { + remote-endpoint = <&panel_in>; }; }; };
&pwm1 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm1>; status = "okay"; };
+®_vdd1p1 { + vin-supply = <&sw2_reg>; +}; + +®_vdd2p5 { + vin-supply = <&sw2_reg>; +}; + &snvs_poweroff { status = "okay"; }; diff --git a/arch/arm/dts/imx6sl-pinfunc.h b/arch/arm/dts/imx6sl-pinfunc.h index 77b17bcc7b..bcf16060ec 100644 --- a/arch/arm/dts/imx6sl-pinfunc.h +++ b/arch/arm/dts/imx6sl-pinfunc.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * */
#ifndef __DTS_IMX6SL_PINFUNC_H diff --git a/arch/arm/dts/imx6sl.dtsi b/arch/arm/dts/imx6sl.dtsi index 37e341c6c3..271f4b971a 100644 --- a/arch/arm/dts/imx6sl.dtsi +++ b/arch/arm/dts/imx6sl.dtsi @@ -1,11 +1,6 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2013 Freescale Semiconductor, Inc.
#include <dt-bindings/interrupt-controller/irq.h> #include "imx6sl-pinfunc.h" @@ -18,10 +13,8 @@ * The decompressor and also some bootloaders rely on a * pre-existing /chosen node to be available to insert the * command line and merge other ATAGS info. - * Also for U-Boot there must be a pre-existing /memory node. */ chosen {}; - memory { device_type = "memory"; reg = <0 0>; };
aliases { ethernet0 = &fec; @@ -30,6 +23,13 @@ gpio2 = &gpio3; gpio3 = &gpio4; gpio4 = &gpio5; + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + mmc2 = &usdhc3; + mmc3 = &usdhc4; serial0 = &uart1; serial1 = &uart2; serial2 = &uart3; @@ -39,6 +39,9 @@ spi1 = &ecspi2; spi2 = &ecspi3; spi3 = &ecspi4; + usb0 = &usbotg1; + usb1 = &usbotg2; + usb2 = &usbh; usbphy0 = &usbphy1; usbphy1 = &usbphy2; }; @@ -47,24 +50,23 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a9"; device_type = "cpu"; reg = <0x0>; next-level-cache = <&L2>; - operating-points = < + operating-points = /* kHz uV */ - 996000 1275000 - 792000 1175000 - 396000 975000 - >; - fsl,soc-operating-points = < - /* ARM kHz SOC-PU uV */ - 996000 1225000 - 792000 1175000 - 396000 1175000 - >; + <996000 1275000>, + <792000 1175000>, + <396000 975000>; + fsl,soc-operating-points = + /* ARM kHz SOC-PU uV */ + <996000 1225000>, + <792000 1175000>, + <396000 1175000>; clock-latency = <61036>; /* two CLK32 periods */ + #cooling-cells = <2>; clocks = <&clks IMX6SL_CLK_ARM>, <&clks IMX6SL_CLK_PLL2_PFD2>, <&clks IMX6SL_CLK_STEP>, <&clks IMX6SL_CLK_PLL1_SW>, <&clks IMX6SL_CLK_PLL1_SYS>; @@ -73,22 +75,12 @@ arm-supply = <®_arm>; pu-supply = <®_pu>; soc-supply = <®_soc>; + nvmem-cells = <&cpu_speed_grade>; + nvmem-cell-names = "speed_grade"; }; };
- intc: interrupt-controller@00a01000 { - compatible = "arm,cortex-a9-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x00a01000 0x1000>, - <0x00a00100 0x100>; - interrupt-parent = <&intc>; - }; - clocks { - #address-cells = <1>; - #size-cells = <0>; - ckil { compatible = "fixed-clock"; #clock-cells = <0>; @@ -102,6 +94,17 @@ }; };
+ pmu { + compatible = "arm,cortex-a9-pmu"; + interrupt-parent = <&gpc>; + interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; + }; + + usbphynop1: usbphynop1 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + }; + soc { #address-cells = <1>; #size-cells = <1>; @@ -109,13 +112,22 @@ interrupt-parent = <&gpc>; ranges;
- ocram: sram@00900000 { + ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x20000>; clocks = <&clks IMX6SL_CLK_OCRAM>; };
- L2: l2-cache@00a02000 { + intc: interrupt-controller@a01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x00a01000 0x1000>, + <0x00a00100 0x100>; + interrupt-parent = <&intc>; + }; + + L2: cache-controller@a02000 { compatible = "arm,pl310-cache"; reg = <0x00a02000 0x1000>; interrupts = <0 92 IRQ_TYPE_LEVEL_HIGH>; @@ -125,26 +137,21 @@ arm,data-latency = <4 2 3>; };
- pmu { - compatible = "arm,cortex-a9-pmu"; - interrupts = <0 94 IRQ_TYPE_LEVEL_HIGH>; - }; - - aips1: bus@02000000 { + aips1: bus@2000000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x100000>; ranges;
- spdif: spdif@02004000 { + spdif: spdif@2004000 { compatible = "fsl,imx6sl-spdif", "fsl,imx35-spdif"; reg = <0x02004000 0x4000>; @@ -165,7 +172,7 @@ status = "disabled"; };
- ecspi1: ecspi@02008000 { + ecspi1: spi@2008000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-ecspi", "fsl,imx51-ecspi"; @@ -177,7 +184,7 @@ status = "disabled"; };
- ecspi2: ecspi@0200c000 { + ecspi2: spi@200c000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-ecspi", "fsl,imx51-ecspi"; @@ -189,7 +196,7 @@ status = "disabled"; };
- ecspi3: ecspi@02010000 { + ecspi3: spi@2010000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-ecspi", "fsl,imx51-ecspi"; @@ -201,7 +208,7 @@ status = "disabled"; };
- ecspi4: ecspi@02014000 { + ecspi4: spi@2014000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-ecspi", "fsl,imx51-ecspi"; @@ -213,9 +220,9 @@ status = "disabled"; };
- uart5: serial@02018000 { + uart5: serial@2018000 { compatible = "fsl,imx6sl-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02018000 0x4000>; interrupts = <0 30 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_UART>, @@ -226,9 +233,9 @@ status = "disabled"; };
- uart1: serial@02020000 { + uart1: serial@2020000 { compatible = "fsl,imx6sl-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02020000 0x4000>; interrupts = <0 26 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_UART>, @@ -239,9 +246,9 @@ status = "disabled"; };
- uart2: serial@02024000 { + uart2: serial@2024000 { compatible = "fsl,imx6sl-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02024000 0x4000>; interrupts = <0 27 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_UART>, @@ -252,7 +259,7 @@ status = "disabled"; };
- ssi1: ssi@02028000 { + ssi1: ssi@2028000 { #sound-dai-cells = <0>; compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; @@ -268,7 +275,7 @@ status = "disabled"; };
- ssi2: ssi@0202c000 { + ssi2: ssi@202c000 { #sound-dai-cells = <0>; compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; @@ -284,7 +291,7 @@ status = "disabled"; };
- ssi3: ssi@02030000 { + ssi3: ssi@2030000 { #sound-dai-cells = <0>; compatible = "fsl,imx6sl-ssi", "fsl,imx51-ssi"; @@ -300,9 +307,9 @@ status = "disabled"; };
- uart3: serial@02034000 { + uart3: serial@2034000 { compatible = "fsl,imx6sl-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02034000 0x4000>; interrupts = <0 28 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_UART>, @@ -313,9 +320,9 @@ status = "disabled"; };
- uart4: serial@02038000 { + uart4: serial@2038000 { compatible = "fsl,imx6sl-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart", "fsl,imx21-uart"; reg = <0x02038000 0x4000>; interrupts = <0 29 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_UART>, @@ -327,47 +334,47 @@ }; };
- pwm1: pwm@02080000 { - #pwm-cells = <2>; + pwm1: pwm@2080000 { + #pwm-cells = <3>; compatible = "fsl,imx6sl-pwm", "fsl,imx27-pwm"; reg = <0x02080000 0x4000>; interrupts = <0 83 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_PWM1>, + clocks = <&clks IMX6SL_CLK_PERCLK>, <&clks IMX6SL_CLK_PWM1>; clock-names = "ipg", "per"; };
- pwm2: pwm@02084000 { - #pwm-cells = <2>; + pwm2: pwm@2084000 { + #pwm-cells = <3>; compatible = "fsl,imx6sl-pwm", "fsl,imx27-pwm"; reg = <0x02084000 0x4000>; interrupts = <0 84 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_PWM2>, + clocks = <&clks IMX6SL_CLK_PERCLK>, <&clks IMX6SL_CLK_PWM2>; clock-names = "ipg", "per"; };
- pwm3: pwm@02088000 { - #pwm-cells = <2>; + pwm3: pwm@2088000 { + #pwm-cells = <3>; compatible = "fsl,imx6sl-pwm", "fsl,imx27-pwm"; reg = <0x02088000 0x4000>; interrupts = <0 85 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_PWM3>, + clocks = <&clks IMX6SL_CLK_PERCLK>, <&clks IMX6SL_CLK_PWM3>; clock-names = "ipg", "per"; };
- pwm4: pwm@0208c000 { - #pwm-cells = <2>; + pwm4: pwm@208c000 { + #pwm-cells = <3>; compatible = "fsl,imx6sl-pwm", "fsl,imx27-pwm"; reg = <0x0208c000 0x4000>; interrupts = <0 86 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_PWM4>, + clocks = <&clks IMX6SL_CLK_PERCLK>, <&clks IMX6SL_CLK_PWM4>; clock-names = "ipg", "per"; };
- gpt: gpt@02098000 { + gpt: timer@2098000 { compatible = "fsl,imx6sl-gpt"; reg = <0x02098000 0x4000>; interrupts = <0 55 IRQ_TYPE_LEVEL_HIGH>; @@ -376,7 +383,7 @@ clock-names = "ipg", "per"; };
- gpio1: gpio@0209c000 { + gpio1: gpio@209c000 { compatible = "fsl,imx6sl-gpio", "fsl,imx35-gpio"; reg = <0x0209c000 0x4000>; interrupts = <0 66 IRQ_TYPE_LEVEL_HIGH>, @@ -393,7 +400,7 @@ <&iomuxc 27 64 4>, <&iomuxc 31 52 1>; };
- gpio2: gpio@020a0000 { + gpio2: gpio@20a0000 { compatible = "fsl,imx6sl-gpio", "fsl,imx35-gpio"; reg = <0x020a0000 0x4000>; interrupts = <0 68 IRQ_TYPE_LEVEL_HIGH>, @@ -411,7 +418,7 @@ <&iomuxc 23 125 7>, <&iomuxc 30 110 2>; };
- gpio3: gpio@020a4000 { + gpio3: gpio@20a4000 { compatible = "fsl,imx6sl-gpio", "fsl,imx35-gpio"; reg = <0x020a4000 0x4000>; interrupts = <0 70 IRQ_TYPE_LEVEL_HIGH>, @@ -430,7 +437,7 @@ <&iomuxc 31 102 1>; };
- gpio4: gpio@020a8000 { + gpio4: gpio@20a8000 { compatible = "fsl,imx6sl-gpio", "fsl,imx35-gpio"; reg = <0x020a8000 0x4000>; interrupts = <0 72 IRQ_TYPE_LEVEL_HIGH>, @@ -456,7 +463,7 @@ <&iomuxc 30 152 1>, <&iomuxc 31 156 1>; };
- gpio5: gpio@020ac000 { + gpio5: gpio@20ac000 { compatible = "fsl,imx6sl-gpio", "fsl,imx35-gpio"; reg = <0x020ac000 0x4000>; interrupts = <0 74 IRQ_TYPE_LEVEL_HIGH>, @@ -478,30 +485,30 @@ <&iomuxc 21 161 1>; };
- kpp: kpp@020b8000 { + kpp: keypad@20b8000 { compatible = "fsl,imx6sl-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <0 82 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_DUMMY>; + clocks = <&clks IMX6SL_CLK_IPG>; status = "disabled"; };
- wdog1: wdog@020bc000 { + wdog1: watchdog@20bc000 { compatible = "fsl,imx6sl-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <0 80 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_DUMMY>; + clocks = <&clks IMX6SL_CLK_IPG>; };
- wdog2: wdog@020c0000 { + wdog2: watchdog@20c0000 { compatible = "fsl,imx6sl-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <0 81 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6SL_CLK_DUMMY>; + clocks = <&clks IMX6SL_CLK_IPG>; status = "disabled"; };
- clks: ccm@020c4000 { + clks: clock-controller@20c4000 { compatible = "fsl,imx6sl-ccm"; reg = <0x020c4000 0x4000>; interrupts = <0 87 IRQ_TYPE_LEVEL_HIGH>, @@ -509,20 +516,20 @@ #clock-cells = <1>; };
- anatop: anatop@020c8000 { + anatop: anatop@20c8000 { compatible = "fsl,imx6sl-anatop", "fsl,imx6q-anatop", - "syscon", "simple-bus"; + "syscon", "simple-mfd"; reg = <0x020c8000 0x1000>; interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>, <0 54 IRQ_TYPE_LEVEL_HIGH>, <0 127 IRQ_TYPE_LEVEL_HIGH>;
- regulator-1p1 { + reg_vdd1p1: regulator-1p1 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd1p1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1375000>; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1200000>; regulator-always-on; anatop-reg-offset = <0x110>; anatop-vol-bit-shift = <8>; @@ -530,9 +537,10 @@ anatop-min-bit-val = <4>; anatop-min-voltage = <800000>; anatop-max-voltage = <1375000>; + anatop-enable-bit = <0>; };
- regulator-3p0 { + reg_vdd3p0: regulator-3p0 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd3p0"; regulator-min-microvolt = <2800000>; @@ -544,13 +552,14 @@ anatop-min-bit-val = <0>; anatop-min-voltage = <2625000>; anatop-max-voltage = <3400000>; + anatop-enable-bit = <0>; };
- regulator-2p5 { + reg_vdd2p5: regulator-2p5 { compatible = "fsl,anatop-regulator"; regulator-name = "vdd2p5"; - regulator-min-microvolt = <2100000>; - regulator-max-microvolt = <2850000>; + regulator-min-microvolt = <2250000>; + regulator-max-microvolt = <2750000>; regulator-always-on; anatop-reg-offset = <0x130>; anatop-vol-bit-shift = <8>; @@ -558,6 +567,7 @@ anatop-min-bit-val = <0>; anatop-min-voltage = <2100000>; anatop-max-voltage = <2850000>; + anatop-enable-bit = <0>; };
reg_arm: regulator-vddcore { @@ -582,7 +592,6 @@ regulator-name = "vddpu"; regulator-min-microvolt = <725000>; regulator-max-microvolt = <1450000>; - regulator-always-on; anatop-reg-offset = <0x140>; anatop-vol-bit-shift = <9>; anatop-vol-bit-width = <5>; @@ -610,17 +619,19 @@ anatop-min-voltage = <725000>; anatop-max-voltage = <1450000>; }; - };
- tempmon: tempmon { - compatible = "fsl,imx6q-tempmon"; - interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; - fsl,tempmon = <&anatop>; - fsl,tempmon-data = <&ocotp>; - clocks = <&clks IMX6SL_CLK_PLL3_USB_OTG>; + tempmon: tempmon { + compatible = "fsl,imx6q-tempmon"; + interrupts = <0 49 IRQ_TYPE_LEVEL_HIGH>; + interrupt-parent = <&gpc>; + fsl,tempmon = <&anatop>; + nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>; + nvmem-cell-names = "calib", "temp_grade"; + clocks = <&clks IMX6SL_CLK_PLL3_USB_OTG>; + }; };
- usbphy1: usbphy@020c9000 { + usbphy1: usbphy@20c9000 { compatible = "fsl,imx6sl-usbphy", "fsl,imx23-usbphy"; reg = <0x020c9000 0x1000>; interrupts = <0 44 IRQ_TYPE_LEVEL_HIGH>; @@ -628,7 +639,7 @@ fsl,anatop = <&anatop>; };
- usbphy2: usbphy@020ca000 { + usbphy2: usbphy@20ca000 { compatible = "fsl,imx6sl-usbphy", "fsl,imx23-usbphy"; reg = <0x020ca000 0x1000>; interrupts = <0 45 IRQ_TYPE_LEVEL_HIGH>; @@ -636,7 +647,7 @@ fsl,anatop = <&anatop>; };
@@ -652,22 +663,23 @@ compatible = "syscon-poweroff"; regmap = <&snvs>; offset = <0x38>; + value = <0x60>; mask = <0x60>; status = "disabled"; }; };
- epit1: epit@020d0000 { + epit1: epit@20d0000 { reg = <0x020d0000 0x4000>; interrupts = <0 56 IRQ_TYPE_LEVEL_HIGH>; };
- epit2: epit@020d4000 { + epit2: epit@20d4000 { reg = <0x020d4000 0x4000>; interrupts = <0 57 IRQ_TYPE_LEVEL_HIGH>; };
- src: src@020d8000 { + src: reset-controller@20d8000 { compatible = "fsl,imx6sl-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <0 91 IRQ_TYPE_LEVEL_HIGH>, @@ -675,63 +687,89 @@ #reset-cells = <1>; };
- gpc: gpc@020dc000 { + gpc: gpc@20dc000 { compatible = "fsl,imx6sl-gpc", "fsl,imx6q-gpc"; reg = <0x020dc000 0x4000>; interrupt-controller; #interrupt-cells = <3>; interrupts = <0 89 IRQ_TYPE_LEVEL_HIGH>; interrupt-parent = <&intc>; - pu-supply = <®_pu>; - clocks = <&clks IMX6SL_CLK_GPU2D_OVG>, - <&clks IMX6SL_CLK_GPU2D_PODF>; - #power-domain-cells = <1>; + clocks = <&clks IMX6SL_CLK_IPG>; + clock-names = "ipg"; + + pgc { + #address-cells = <1>; + #size-cells = <0>; + + power-domain@0 { + reg = <0>; + #power-domain-cells = <0>; + }; + + pd_pu: power-domain@1 { + reg = <1>; + #power-domain-cells = <0>; + power-supply = <®_pu>; + clocks = <&clks IMX6SL_CLK_GPU2D_OVG>, + <&clks IMX6SL_CLK_GPU2D_PODF>; + }; + + pd_disp: power-domain@2 { + reg = <2>; + #power-domain-cells = <0>; + clocks = <&clks IMX6SL_CLK_LCDIF_AXI>, + <&clks IMX6SL_CLK_LCDIF_PIX>, + <&clks IMX6SL_CLK_EPDC_AXI>, + <&clks IMX6SL_CLK_EPDC_PIX>, + <&clks IMX6SL_CLK_PXP_AXI>; + }; + }; };
- gpr: iomuxc-gpr@020e0000 { + gpr: iomuxc-gpr@20e0000 { compatible = "fsl,imx6sl-iomuxc-gpr", "fsl,imx6q-iomuxc-gpr", "syscon"; reg = <0x020e0000 0x38>; };
- iomuxc: iomuxc@020e0000 { + iomuxc: pinctrl@20e0000 { compatible = "fsl,imx6sl-iomuxc"; reg = <0x020e0000 0x4000>; };
- csi: csi@020e4000 { + csi: csi@20e4000 { reg = <0x020e4000 0x4000>; interrupts = <0 7 IRQ_TYPE_LEVEL_HIGH>; };
- spdc: spdc@020e8000 { + spdc: spdc@20e8000 { reg = <0x020e8000 0x4000>; interrupts = <0 6 IRQ_TYPE_LEVEL_HIGH>; };
- sdma: sdma@020ec000 { + sdma: sdma@20ec000 { compatible = "fsl,imx6sl-sdma", "fsl,imx6q-sdma"; reg = <0x020ec000 0x4000>; interrupts = <0 2 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_SDMA>, - <&clks IMX6SL_CLK_SDMA>; + <&clks IMX6SL_CLK_AHB>; clock-names = "ipg", "ahb"; #dma-cells = <3>; /* imx6sl reuses imx6q sdma firmware */ fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; };
- pxp: pxp@020f0000 { + pxp: pxp@20f0000 { reg = <0x020f0000 0x4000>; interrupts = <0 98 IRQ_TYPE_LEVEL_HIGH>; };
- epdc: epdc@020f4000 { + epdc: epdc@20f4000 { reg = <0x020f4000 0x4000>; interrupts = <0 97 IRQ_TYPE_LEVEL_HIGH>; };
- lcdif: lcdif@020f8000 { + lcdif: lcdif@20f8000 { compatible = "fsl,imx6sl-lcdif", "fsl,imx28-lcdif"; reg = <0x020f8000 0x4000>; interrupts = <0 39 IRQ_TYPE_LEVEL_HIGH>; @@ -740,9 +778,10 @@ <&clks IMX6SL_CLK_DUMMY>; clock-names = "pix", "axi", "disp_axi"; status = "disabled"; + power-domains = <&pd_disp>; };
- dcp: dcp@020fc000 { + dcp: crypto@20fc000 { compatible = "fsl,imx6sl-dcp", "fsl,imx28-dcp"; reg = <0x020fc000 0x4000>; interrupts = <0 99 IRQ_TYPE_LEVEL_HIGH>, @@ -751,14 +790,14 @@ }; };
- usbotg1: usb@02184000 { + usbotg1: usb@2184000 { compatible = "fsl,imx6sl-usb", "fsl,imx27-usb"; reg = <0x02184000 0x200>; interrupts = <0 43 IRQ_TYPE_LEVEL_HIGH>; @@ -771,7 +810,7 @@ status = "disabled"; };
- usbotg2: usb@02184200 { + usbotg2: usb@2184200 { compatible = "fsl,imx6sl-usb", "fsl,imx27-usb"; reg = <0x02184200 0x200>; interrupts = <0 42 IRQ_TYPE_LEVEL_HIGH>; @@ -784,11 +823,13 @@ status = "disabled"; };
- usbh: usb@02184400 { + usbh: usb@2184400 { compatible = "fsl,imx6sl-usb", "fsl,imx27-usb"; reg = <0x02184400 0x200>; interrupts = <0 40 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6SL_CLK_USBOH3>; + fsl,usbphy = <&usbphynop1>; + phy_type = "hsic"; fsl,usbmisc = <&usbmisc 2>; dr_mode = "host"; ahb-burst-config = <0x0>; @@ -797,14 +838,14 @@ status = "disabled"; };
- usbmisc: usbmisc@02184800 { + usbmisc: usbmisc@2184800 { #index-cells = <1>; compatible = "fsl,imx6sl-usbmisc", "fsl,imx6q-usbmisc"; reg = <0x02184800 0x200>; clocks = <&clks IMX6SL_CLK_USBOH3>; };
- fec: ethernet@02188000 { + fec: ethernet@2188000 { compatible = "fsl,imx6sl-fec", "fsl,imx25-fec"; reg = <0x02188000 0x4000>; interrupts = <0 114 IRQ_TYPE_LEVEL_HIGH>; @@ -814,7 +855,7 @@ status = "disabled"; };
- usdhc1: usdhc@02190000 { + usdhc1: mmc@2190000 { compatible = "fsl,imx6sl-usdhc", "fsl,imx6q-usdhc"; reg = <0x02190000 0x4000>; interrupts = <0 22 IRQ_TYPE_LEVEL_HIGH>; @@ -826,7 +867,7 @@ status = "disabled"; };
- usdhc2: usdhc@02194000 { + usdhc2: mmc@2194000 { compatible = "fsl,imx6sl-usdhc", "fsl,imx6q-usdhc"; reg = <0x02194000 0x4000>; interrupts = <0 23 IRQ_TYPE_LEVEL_HIGH>; @@ -838,7 +879,7 @@ status = "disabled"; };
- usdhc3: usdhc@02198000 { + usdhc3: mmc@2198000 { compatible = "fsl,imx6sl-usdhc", "fsl,imx6q-usdhc"; reg = <0x02198000 0x4000>; interrupts = <0 24 IRQ_TYPE_LEVEL_HIGH>; @@ -850,7 +891,7 @@ status = "disabled"; };
- usdhc4: usdhc@0219c000 { + usdhc4: mmc@219c000 { compatible = "fsl,imx6sl-usdhc", "fsl,imx6q-usdhc"; reg = <0x0219c000 0x4000>; interrupts = <0 25 IRQ_TYPE_LEVEL_HIGH>; @@ -862,7 +903,7 @@ status = "disabled"; };
- i2c1: i2c@021a0000 { + i2c1: i2c@21a0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-i2c", "fsl,imx21-i2c"; @@ -872,7 +913,7 @@ status = "disabled"; };
- i2c2: i2c@021a4000 { + i2c2: i2c@21a4000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-i2c", "fsl,imx21-i2c"; @@ -882,7 +923,7 @@ status = "disabled"; };
- i2c3: i2c@021a8000 { + i2c3: i2c@21a8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6sl-i2c", "fsl,imx21-i2c"; @@ -892,17 +933,20 @@ status = "disabled"; };
- mmdc: mmdc@021b0000 { + memory-controller@21b0000 { compatible = "fsl,imx6sl-mmdc", "fsl,imx6q-mmdc"; reg = <0x021b0000 0x4000>; + clocks = <&clks IMX6SL_CLK_MMDC_P0_IPG>; };
- rngb: rngb@021b4000 { + rngb: rngb@21b4000 { + compatible = "fsl,imx6sl-rngb", "fsl,imx25-rngb"; reg = <0x021b4000 0x4000>; interrupts = <0 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SL_CLK_DUMMY>; };
- weim: weim@021b8000 { + weim: weim@21b8000 { #address-cells = <2>; #size-cells = <1>; reg = <0x021b8000 0x4000>; @@ -911,17 +955,51 @@ status = "disabled"; };
- ocotp: ocotp@021bc000 { + ocotp: efuse@21bc000 { compatible = "fsl,imx6sl-ocotp", "syscon"; reg = <0x021bc000 0x4000>; clocks = <&clks IMX6SL_CLK_OCOTP>; + #address-cells = <1>; + #size-cells = <1>; + + cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + }; + + tempmon_calib: calib@38 { + reg = <0x38 4>; + }; + + tempmon_temp_grade: temp-grade@20 { + reg = <0x20 4>; + }; };
- audmux: audmux@021d8000 { + audmux: audmux@21d8000 { compatible = "fsl,imx6sl-audmux", "fsl,imx31-audmux"; reg = <0x021d8000 0x4000>; status = "disabled"; }; }; + + gpu_2d: gpu@2200000 { + compatible = "vivante,gc"; + reg = <0x02200000 0x4000>; + interrupts = <0 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SL_CLK_MMDC_ROOT>, + <&clks IMX6SL_CLK_GPU2D_OVG>; + clock-names = "bus", "core"; + power-domains = <&pd_pu>; + }; + + gpu_vg: gpu@2204000 { + compatible = "vivante,gc"; + reg = <0x02204000 0x4000>; + interrupts = <0 11 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6SL_CLK_MMDC_ROOT>, + <&clks IMX6SL_CLK_GPU2D_OVG>; + clock-names = "bus", "core"; + power-domains = <&pd_pu>; + }; }; }; diff --git a/include/dt-bindings/clock/imx6sl-clock.h b/include/dt-bindings/clock/imx6sl-clock.h index e14573e293..31364d2caa 100644 --- a/include/dt-bindings/clock/imx6sl-clock.h +++ b/include/dt-bindings/clock/imx6sl-clock.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * */
#ifndef __DT_BINDINGS_CLOCK_IMX6SL_H @@ -175,6 +171,8 @@ #define IMX6SL_CLK_SSI2_IPG 162 #define IMX6SL_CLK_SSI3_IPG 163 #define IMX6SL_CLK_SPDIF_GCLK 164 -#define IMX6SL_CLK_END 165 +#define IMX6SL_CLK_MMDC_P0_IPG 165 +#define IMX6SL_CLK_MMDC_P1_IPG 166 +#define IMX6SL_CLK_END 167
#endif /* __DT_BINDINGS_CLOCK_IMX6SL_H */
arch/arm/dts/imx6qp-sabreauto.dts | 7 ++++++- arch/arm/dts/imx6qp-sabresd.dts | 10 +++++++++- arch/arm/dts/imx6qp.dtsi | 3 +-- 3 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx6qp-sabreauto.dts b/arch/arm/dts/imx6qp-sabreauto.dts index d4caeeb0af..2bb3bfb18e 100644 --- a/arch/arm/dts/imx6qp-sabreauto.dts +++ b/arch/arm/dts/imx6qp-sabreauto.dts @@ -47,7 +47,12 @@ };
&pcie { - status = "disabled"; + reset-gpio = <&max7310_c 5 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&sata { + status = "okay"; };
&vgen3_reg { diff --git a/arch/arm/dts/imx6qp-sabresd.dts b/arch/arm/dts/imx6qp-sabresd.dts index f1b9cb104f..f69eec18d8 100644 --- a/arch/arm/dts/imx6qp-sabresd.dts +++ b/arch/arm/dts/imx6qp-sabresd.dts @@ -50,6 +50,14 @@ }; };
+&vgen3_reg { + regulator-always-on; +}; + &pcie { - status = "disabled"; + status = "okay"; +}; + +&sata { + status = "okay"; }; diff --git a/arch/arm/dts/imx6qp.dtsi b/arch/arm/dts/imx6qp.dtsi index 93b89dc1f5..0503655138 100644 --- a/arch/arm/dts/imx6qp.dtsi +++ b/arch/arm/dts/imx6qp.dtsi @@ -77,7 +77,6 @@ };
&fec { - /delete-property/interrupts-extended; interrupts = <0 118 IRQ_TYPE_LEVEL_HIGH>, <0 119 IRQ_TYPE_LEVEL_HIGH>; }; @@ -111,5 +110,5 @@ };
&pcie { - compatible = "fsl,imx6qp-pcie", "snps,dw-pcie"; + compatible = "fsl,imx6qp-pcie"; };
arch/arm/dts/imx6q-sabrelite.dts | 11 ++++++----- arch/arm/dts/imx6qdl-sabrelite.dtsi | 11 ++++++----- 2 files changed, 12 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/imx6q-sabrelite.dts b/arch/arm/dts/imx6q-sabrelite.dts index 434b1433e7..7c6a2f234c 100644 --- a/arch/arm/dts/imx6q-sabrelite.dts +++ b/arch/arm/dts/imx6q-sabrelite.dts @@ -1,8 +1,9 @@ -// SPDX-License-Identifier: GPL-2.0+ -// -// Copyright 2013-2019 Boundary Devices, Inc. -// Copyright 2012 Freescale Semiconductor, Inc. -// Copyright 2011 Linaro Ltd. +// SPDX-License-Identifier: GPL-2.0 OR X11 +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + */
/dts-v1/; #include "imx6q.dtsi" diff --git a/arch/arm/dts/imx6qdl-sabrelite.dtsi b/arch/arm/dts/imx6qdl-sabrelite.dtsi index a757817a3c..22f8e2783c 100644 --- a/arch/arm/dts/imx6qdl-sabrelite.dtsi +++ b/arch/arm/dts/imx6qdl-sabrelite.dtsi @@ -1,8 +1,9 @@ -// SPDX-License-Identifier: GPL-2.0+ -// -// Copyright 2013-2019 Boundary Devices, Inc. -// Copyright 2012 Freescale Semiconductor, Inc. -// Copyright 2011 Linaro Ltd. +// SPDX-License-Identifier: GPL-2.0 OR X11 +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Copyright 2011 Linaro Ltd. + * + */
#include <dt-bindings/clock/imx6qdl-clock.h> #include <dt-bindings/gpio/gpio.h>
arch/arm/dts/imx53-cx9020.dts | 414 ++++++++++++++++++------------- arch/arm/dts/imx53-kp.dts | 2 + arch/arm/dts/imx53-m53menlo.dts | 306 ++++++++++++++++++----- arch/arm/dts/imx53-pinfunc.h | 11 +- arch/arm/dts/imx53-ppd.dts | 87 +++++-- arch/arm/dts/imx53-usbarmory.dts | 1 - arch/arm/dts/imx53.dtsi | 39 +-- 7 files changed, 577 insertions(+), 283 deletions(-)
diff --git a/arch/arm/dts/imx53-cx9020.dts b/arch/arm/dts/imx53-cx9020.dts index e08850999b..cfb18849a9 100644 --- a/arch/arm/dts/imx53-cx9020.dts +++ b/arch/arm/dts/imx53-cx9020.dts @@ -1,195 +1,133 @@ -// SPDX-License-Identifier: GPL-2.0+ OR X11 +// SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright 2016 Beckhoff Automation - * Copyright 2011 Freescale Semiconductor, Inc. - * Copyright 2011 Linaro Ltd. + * Copyright 2017 Beckhoff Automation GmbH & Co. KG + * based on imx53-qsb.dts */
/dts-v1/; #include "imx53.dtsi"
-#define MX53_PAD_EIM_D26__UART2_RXD_MUX 0x144 0x48c 0x880 0x2 0x0 -#define MX53_PAD_EIM_D27__UART2_TXD_MUX 0x148 0x490 0x000 0x2 0x0 -#define MX53_PAD_EIM_D28__UART2_RTS 0x14c 0x494 0x87c 0x2 0x0 -#define MX53_PAD_EIM_D29__UART2_CTS 0x150 0x498 0x000 0x2 0x0 - / { - model = "Beckhoff CX9020-0100 i.MX53"; - compatible = "fsl,imx53-qsb", "fsl,imx53"; + model = "Beckhoff CX9020 Embedded PC"; + compatible = "bhf,cx9020", "fsl,imx53";
chosen { stdout-path = &uart2; }; -};
-&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog>; + memory@70000000 { + device_type = "memory"; + reg = <0x70000000 0x20000000>, + <0xb0000000 0x20000000>; + }; + + display-0 { + #address-cells =<1>; + #size-cells = <0>; + compatible = "fsl,imx-parallel-display"; + interface-pix-fmt = "rgb24"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ipu_disp0>; + + port@0 { + reg = <0>; + + display0_in: endpoint { + remote-endpoint = <&ipu_di0_disp0>; + }; + }; + + port@1 { + reg = <1>; + + display0_out: endpoint { + remote-endpoint = <&tfp410_in>; + }; + }; + }; + + dvi-connector { + compatible = "dvi-connector"; + ddc-i2c-bus = <&i2c2>; + digital; + + port { + dvi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + };
- imx53-qsb { - pinctrl_hog: hoggrp { - fsl,pins = < - MX53_PAD_GPIO_0__CCM_SSI_EXT1_CLK 0x80000000 - MX53_PAD_GPIO_8__GPIO1_8 0x80000000 - MX53_PAD_PATA_DATA14__GPIO2_14 0x80000000 - MX53_PAD_PATA_DATA15__GPIO2_15 0x80000000 - MX53_PAD_GPIO_1__GPIO1_1 0x80000000 - MX53_PAD_GPIO_4__GPIO1_4 0x80000000 - MX53_PAD_PATA_DA_0__GPIO7_6 0x80000000 - MX53_PAD_GPIO_16__GPIO7_11 0x80000000 - - MX53_PAD_EIM_OE__EMI_WEIM_OE 0x80000000 - MX53_PAD_EIM_WAIT__EMI_WEIM_WAIT 0x80000000 - MX53_PAD_EIM_LBA__EMI_WEIM_LBA 0x80000000 - MX53_PAD_EIM_RW__EMI_WEIM_RW 0x80000000 - MX53_PAD_EIM_EB0__EMI_WEIM_EB_0 0x80000000 - MX53_PAD_EIM_EB1__EMI_WEIM_EB_1 0x80000000 - MX53_PAD_EIM_EB2__EMI_WEIM_EB_2 0x80000000 - MX53_PAD_EIM_EB3__EMI_WEIM_EB_3 0x80000000 - MX53_PAD_EIM_CS0__EMI_WEIM_CS_0 0x80000000 - MX53_PAD_EIM_CS1__EMI_WEIM_CS_1 0x80000000 - MX53_PAD_EIM_A16__EMI_WEIM_A_16 0x80000000 - MX53_PAD_EIM_A17__EMI_WEIM_A_17 0x80000000 - MX53_PAD_EIM_A18__EMI_WEIM_A_18 0x80000000 - MX53_PAD_EIM_A19__EMI_WEIM_A_19 0x80000000 - MX53_PAD_EIM_A20__EMI_WEIM_A_20 0x80000000 - MX53_PAD_EIM_A21__EMI_WEIM_A_21 0x80000000 - MX53_PAD_EIM_A22__EMI_WEIM_A_22 0x80000000 - MX53_PAD_EIM_DA0__EMI_NAND_WEIM_DA_0 0xa4 - MX53_PAD_EIM_DA1__EMI_NAND_WEIM_DA_1 0xa4 - MX53_PAD_EIM_DA2__EMI_NAND_WEIM_DA_2 0xa4 - MX53_PAD_EIM_DA3__EMI_NAND_WEIM_DA_3 0xa4 - MX53_PAD_EIM_DA4__EMI_NAND_WEIM_DA_4 0xa4 - MX53_PAD_EIM_DA5__EMI_NAND_WEIM_DA_5 0xa4 - MX53_PAD_EIM_DA6__EMI_NAND_WEIM_DA_6 0xa4 - MX53_PAD_EIM_DA7__EMI_NAND_WEIM_DA_7 0xa4 - MX53_PAD_EIM_DA8__EMI_NAND_WEIM_DA_8 0xa4 - MX53_PAD_EIM_DA9__EMI_NAND_WEIM_DA_9 0xa4 - MX53_PAD_EIM_DA10__EMI_NAND_WEIM_DA_10 0xa4 - MX53_PAD_EIM_DA11__EMI_NAND_WEIM_DA_11 0xa4 - MX53_PAD_EIM_DA12__EMI_NAND_WEIM_DA_12 0xa4 - MX53_PAD_EIM_DA13__EMI_NAND_WEIM_DA_13 0xa4 - MX53_PAD_EIM_DA14__EMI_NAND_WEIM_DA_14 0xa4 - MX53_PAD_EIM_DA15__EMI_NAND_WEIM_DA_15 0xa4 - MX53_PAD_PATA_DATA0__EMI_NANDF_D_0 0xa4 - MX53_PAD_PATA_DATA1__EMI_NANDF_D_1 0xa4 - MX53_PAD_PATA_DATA2__EMI_NANDF_D_2 0xa4 - MX53_PAD_PATA_DATA3__EMI_NANDF_D_3 0xa4 - MX53_PAD_PATA_DATA4__EMI_NANDF_D_4 0xa4 - MX53_PAD_PATA_DATA5__EMI_NANDF_D_5 0xa4 - MX53_PAD_PATA_DATA6__EMI_NANDF_D_6 0xa4 - MX53_PAD_PATA_DATA7__EMI_NANDF_D_7 0xa4 - MX53_PAD_PATA_DATA8__EMI_NANDF_D_8 0xa4 - MX53_PAD_PATA_DATA9__EMI_NANDF_D_9 0xa4 - MX53_PAD_PATA_DATA10__EMI_NANDF_D_10 0xa4 - MX53_PAD_PATA_DATA11__EMI_NANDF_D_11 0xa4 - MX53_PAD_PATA_DATA12__EMI_NANDF_D_12 0xa4 - MX53_PAD_PATA_DATA13__EMI_NANDF_D_13 0xa4 - MX53_PAD_PATA_DATA14__EMI_NANDF_D_14 0xa4 - MX53_PAD_PATA_DATA15__EMI_NANDF_D_15 0xa4 - MX53_PAD_NANDF_CLE__GPIO6_7 0x00000001 - MX53_PAD_NANDF_WP_B__GPIO6_9 0x00000001 - MX53_PAD_NANDF_ALE__GPIO6_8 0x00000001 - - MX53_PAD_EIM_D23__GPIO3_23 0x80000000 - - MX53_PAD_KEY_COL0__AUDMUX_AUD5_TXC 0x80000000 - MX53_PAD_KEY_ROW0__AUDMUX_AUD5_TXD 0x80000000 - MX53_PAD_KEY_COL1__AUDMUX_AUD5_TXFS 0x80000000 - MX53_PAD_KEY_ROW1__AUDMUX_AUD5_RXD 0x80000000 - - MX53_PAD_CSI0_DAT8__I2C1_SDA 0x400001ec - MX53_PAD_CSI0_DAT9__I2C1_SCL 0x400001ec - - MX53_PAD_KEY_ROW3__I2C2_SDA 0xc0000000 - MX53_PAD_KEY_COL3__I2C2_SCL 0xc0000000 - - MX53_PAD_DI0_DISP_CLK__IPU_DI0_DISP_CLK 0x5 - MX53_PAD_DI0_PIN15__IPU_DI0_PIN15 0x5 - MX53_PAD_DI0_PIN2__IPU_DI0_PIN2 0x5 - MX53_PAD_DI0_PIN3__IPU_DI0_PIN3 0x5 - MX53_PAD_DI0_PIN4__IPU_DI0_PIN4 0x5 - MX53_PAD_DISP0_DAT0__IPU_DISP0_DAT_0 0x5 - MX53_PAD_DISP0_DAT1__IPU_DISP0_DAT_1 0x5 - MX53_PAD_DISP0_DAT2__IPU_DISP0_DAT_2 0x5 - MX53_PAD_DISP0_DAT3__IPU_DISP0_DAT_3 0x5 - MX53_PAD_DISP0_DAT4__IPU_DISP0_DAT_4 0x5 - MX53_PAD_DISP0_DAT5__IPU_DISP0_DAT_5 0x5 - MX53_PAD_DISP0_DAT6__IPU_DISP0_DAT_6 0x5 - MX53_PAD_DISP0_DAT7__IPU_DISP0_DAT_7 0x5 - MX53_PAD_DISP0_DAT8__IPU_DISP0_DAT_8 0x5 - MX53_PAD_DISP0_DAT9__IPU_DISP0_DAT_9 0x5 - MX53_PAD_DISP0_DAT10__IPU_DISP0_DAT_10 0x5 - MX53_PAD_DISP0_DAT11__IPU_DISP0_DAT_11 0x5 - MX53_PAD_DISP0_DAT12__IPU_DISP0_DAT_12 0x5 - MX53_PAD_DISP0_DAT13__IPU_DISP0_DAT_13 0x5 - MX53_PAD_DISP0_DAT14__IPU_DISP0_DAT_14 0x5 - MX53_PAD_DISP0_DAT15__IPU_DISP0_DAT_15 0x5 - MX53_PAD_DISP0_DAT16__IPU_DISP0_DAT_16 0x5 - MX53_PAD_DISP0_DAT17__IPU_DISP0_DAT_17 0x5 - MX53_PAD_DISP0_DAT18__IPU_DISP0_DAT_18 0x5 - MX53_PAD_DISP0_DAT19__IPU_DISP0_DAT_19 0x5 - MX53_PAD_DISP0_DAT20__IPU_DISP0_DAT_20 0x5 - MX53_PAD_DISP0_DAT21__IPU_DISP0_DAT_21 0x5 - MX53_PAD_DISP0_DAT22__IPU_DISP0_DAT_22 0x5 - MX53_PAD_DISP0_DAT23__IPU_DISP0_DAT_23 0x5 - >; + dvi-converter { + compatible = "ti,tfp410"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <&display0_out>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&dvi_connector_in>; + }; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + pwr-r { + gpios = <&gpio3 22 GPIO_ACTIVE_HIGH>; + default-state = "off"; };
- pinctrl_fec0: fec0grp { - fsl,pins = < - MX53_PAD_FEC_MDC__FEC_MDC 0x4 - MX53_PAD_FEC_MDIO__FEC_MDIO 0x1fc - MX53_PAD_FEC_REF_CLK__FEC_TX_CLK 0x180 - MX53_PAD_FEC_RX_ER__FEC_RX_ER 0x180 - MX53_PAD_FEC_CRS_DV__FEC_RX_DV 0x180 - MX53_PAD_FEC_RXD1__FEC_RDATA_1 0x180 - MX53_PAD_FEC_RXD0__FEC_RDATA_0 0x180 - MX53_PAD_FEC_TX_EN__FEC_TX_EN 0x4 - MX53_PAD_FEC_TXD1__FEC_TDATA_1 0x4 - MX53_PAD_FEC_TXD0__FEC_TDATA_0 0x4 - >; + pwr-g { + gpios = <&gpio3 24 GPIO_ACTIVE_HIGH>; + default-state = "on"; };
- pinctrl_esdhc1: esdhc1grp { - fsl,pins = < - MX53_PAD_SD1_DATA0__ESDHC1_DAT0 0x1d5 - MX53_PAD_SD1_DATA1__ESDHC1_DAT1 0x1d5 - MX53_PAD_SD1_DATA2__ESDHC1_DAT2 0x1d5 - MX53_PAD_SD1_DATA3__ESDHC1_DAT3 0x1d5 - MX53_PAD_SD1_CMD__ESDHC1_CMD 0x1d5 - MX53_PAD_SD1_CLK__ESDHC1_CLK 0x1d5 - >; + pwr-b { + gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; + default-state = "off"; };
- pinctrl_esdhc2: esdhc2grp { - fsl,pins = < - MX53_PAD_SD2_DATA0__ESDHC2_DAT0 0x1d5 - MX53_PAD_SD2_DATA1__ESDHC2_DAT1 0x1d5 - MX53_PAD_SD2_DATA2__ESDHC2_DAT2 0x1d5 - MX53_PAD_SD2_DATA3__ESDHC2_DAT3 0x1d5 - MX53_PAD_SD2_CMD__ESDHC2_CMD 0x1d5 - MX53_PAD_SD2_CLK__ESDHC2_CLK 0x1d5 - >; + sd1-b { + linux,default-trigger = "mmc0"; + gpios = <&gpio3 20 GPIO_ACTIVE_HIGH>; };
- pinctrl_uart2: uart2grp { - fsl,pins = < - MX53_PAD_EIM_D26__UART2_RXD_MUX 0x1e4 - MX53_PAD_EIM_D27__UART2_TXD_MUX 0x1e4 - MX53_PAD_EIM_D28__UART2_RTS 0x1e4 - MX53_PAD_EIM_D29__UART2_CTS 0x1e4 - >; + sd2-b { + linux,default-trigger = "mmc1"; + gpios = <&gpio3 17 GPIO_ACTIVE_HIGH>; }; }; -};
-&uart2 { - pinctrl-names = "default"; - uart-has-rtscts; - fsl,dte-mode; - pinctrl-0 = <&pinctrl_uart2>; - status = "okay"; + regulator-3p2v { + compatible = "regulator-fixed"; + regulator-name = "3P2V"; + regulator-min-microvolt = <3200000>; + regulator-max-microvolt = <3200000>; + regulator-always-on; + }; + + reg_usb_vbus: regulator-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio7 8 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; };
&esdhc1 { @@ -210,22 +148,148 @@
&fec { pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec>; phy-mode = "rmii"; - phy-reset-gpios = <&gpio7 6 0>; - pinctrl-0 = <&pinctrl_fec0>; + phy-reset-gpios = <&gpio7 6 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&ipu_di0_disp0 { + remote-endpoint = <&display0_in>; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + fsl,dte-mode; status = "okay"; - fixed-link { /* RMII fixed link to KZ8863 */ - speed = <100>; - full-duplex; - }; };
&usbh1 { + vbus-supply = <®_usb_vbus>; phy_type = "utmi"; status = "okay"; };
&usbotg { - dr_mode = "host"; + dr_mode = "peripheral"; status = "okay"; }; + +&vpu { + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX53_PAD_GPIO_0__CCM_CLKO 0x1c4 + MX53_PAD_GPIO_16__I2C3_SDA 0x1c4 + MX53_PAD_EIM_D22__GPIO3_22 0x1c4 + MX53_PAD_EIM_D23__GPIO3_23 0x1e4 + MX53_PAD_EIM_D24__GPIO3_24 0x1e4 + >; + }; + + pinctrl_esdhc1: esdhc1grp { + fsl,pins = < + MX53_PAD_SD1_DATA0__ESDHC1_DAT0 0x1d5 + MX53_PAD_SD1_DATA1__ESDHC1_DAT1 0x1d5 + MX53_PAD_SD1_DATA2__ESDHC1_DAT2 0x1d5 + MX53_PAD_SD1_DATA3__ESDHC1_DAT3 0x1d5 + MX53_PAD_SD1_CMD__ESDHC1_CMD 0x1d5 + MX53_PAD_SD1_CLK__ESDHC1_CLK 0x1d5 + MX53_PAD_GPIO_1__ESDHC1_CD 0x1c4 + MX53_PAD_EIM_D17__GPIO3_17 0x1e4 + MX53_PAD_GPIO_3__GPIO1_3 0x1c4 + >; + }; + + pinctrl_esdhc2: esdhc2grp { + fsl,pins = < + MX53_PAD_SD2_DATA0__ESDHC2_DAT0 0x1d5 + MX53_PAD_SD2_DATA1__ESDHC2_DAT1 0x1d5 + MX53_PAD_SD2_DATA2__ESDHC2_DAT2 0x1d5 + MX53_PAD_SD2_DATA3__ESDHC2_DAT3 0x1d5 + MX53_PAD_SD2_CMD__ESDHC2_CMD 0x1d5 + MX53_PAD_SD2_CLK__ESDHC2_CLK 0x1d5 + MX53_PAD_GPIO_4__ESDHC2_CD 0x1e4 + MX53_PAD_EIM_D20__GPIO3_20 0x1e4 + MX53_PAD_GPIO_8__GPIO1_8 0x1c4 + >; + }; + + pinctrl_fec: fecgrp { + fsl,pins = < + MX53_PAD_FEC_MDC__FEC_MDC 0x4 + MX53_PAD_FEC_MDIO__FEC_MDIO 0x1fc + MX53_PAD_FEC_REF_CLK__FEC_TX_CLK 0x180 + MX53_PAD_FEC_RX_ER__FEC_RX_ER 0x180 + MX53_PAD_FEC_CRS_DV__FEC_RX_DV 0x180 + MX53_PAD_FEC_RXD1__FEC_RDATA_1 0x180 + MX53_PAD_FEC_RXD0__FEC_RDATA_0 0x180 + MX53_PAD_FEC_TX_EN__FEC_TX_EN 0x4 + MX53_PAD_FEC_TXD1__FEC_TDATA_1 0x4 + MX53_PAD_FEC_TXD0__FEC_TDATA_0 0x4 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX53_PAD_KEY_ROW3__I2C2_SDA 0xc0000000 + MX53_PAD_KEY_COL3__I2C2_SCL 0xc0000000 + >; + }; + + pinctrl_ipu_disp0: ipudisp0grp { + fsl,pins = < + MX53_PAD_DI0_DISP_CLK__IPU_DI0_DISP_CLK 0x5 + MX53_PAD_DI0_PIN15__IPU_DI0_PIN15 0x5 + MX53_PAD_DI0_PIN2__IPU_DI0_PIN2 0x5 + MX53_PAD_DI0_PIN3__IPU_DI0_PIN3 0x5 + MX53_PAD_DI0_PIN4__IPU_DI0_PIN4 0x5 + MX53_PAD_DISP0_DAT0__IPU_DISP0_DAT_0 0x5 + MX53_PAD_DISP0_DAT1__IPU_DISP0_DAT_1 0x5 + MX53_PAD_DISP0_DAT2__IPU_DISP0_DAT_2 0x5 + MX53_PAD_DISP0_DAT3__IPU_DISP0_DAT_3 0x5 + MX53_PAD_DISP0_DAT4__IPU_DISP0_DAT_4 0x5 + MX53_PAD_DISP0_DAT5__IPU_DISP0_DAT_5 0x5 + MX53_PAD_DISP0_DAT6__IPU_DISP0_DAT_6 0x5 + MX53_PAD_DISP0_DAT7__IPU_DISP0_DAT_7 0x5 + MX53_PAD_DISP0_DAT8__IPU_DISP0_DAT_8 0x5 + MX53_PAD_DISP0_DAT9__IPU_DISP0_DAT_9 0x5 + MX53_PAD_DISP0_DAT10__IPU_DISP0_DAT_10 0x5 + MX53_PAD_DISP0_DAT11__IPU_DISP0_DAT_11 0x5 + MX53_PAD_DISP0_DAT12__IPU_DISP0_DAT_12 0x5 + MX53_PAD_DISP0_DAT13__IPU_DISP0_DAT_13 0x5 + MX53_PAD_DISP0_DAT14__IPU_DISP0_DAT_14 0x5 + MX53_PAD_DISP0_DAT15__IPU_DISP0_DAT_15 0x5 + MX53_PAD_DISP0_DAT16__IPU_DISP0_DAT_16 0x5 + MX53_PAD_DISP0_DAT17__IPU_DISP0_DAT_17 0x5 + MX53_PAD_DISP0_DAT18__IPU_DISP0_DAT_18 0x5 + MX53_PAD_DISP0_DAT19__IPU_DISP0_DAT_19 0x5 + MX53_PAD_DISP0_DAT20__IPU_DISP0_DAT_20 0x5 + MX53_PAD_DISP0_DAT21__IPU_DISP0_DAT_21 0x5 + MX53_PAD_DISP0_DAT22__IPU_DISP0_DAT_22 0x5 + MX53_PAD_DISP0_DAT23__IPU_DISP0_DAT_23 0x5 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX53_PAD_EIM_D26__UART2_RXD_MUX 0x1e4 + MX53_PAD_EIM_D27__UART2_TXD_MUX 0x1e4 + MX53_PAD_EIM_D28__UART2_RTS 0x1e4 + MX53_PAD_EIM_D29__UART2_CTS 0x1e4 + >; + }; +}; diff --git a/arch/arm/dts/imx53-kp.dts b/arch/arm/dts/imx53-kp.dts index 03e571d274..c951def82a 100644 --- a/arch/arm/dts/imx53-kp.dts +++ b/arch/arm/dts/imx53-kp.dts @@ -10,6 +10,8 @@ #include "imx53.dtsi" #include "imx53-pinfunc.h"
+#define IMX_PAD_SION 0x40000000 + / { model = "K+P iMX53"; compatible = "kp,imx53-kp", "fsl,imx53"; diff --git a/arch/arm/dts/imx53-m53menlo.dts b/arch/arm/dts/imx53-m53menlo.dts index 3767dcaef4..d5c68d1ea7 100644 --- a/arch/arm/dts/imx53-m53menlo.dts +++ b/arch/arm/dts/imx53-m53menlo.dts @@ -5,12 +5,30 @@
/dts-v1/; #include "imx53-m53.dtsi" -#include "imx53-m53menlo-u-boot.dtsi"
/ { model = "MENLO M53 EMBEDDED DEVICE"; compatible = "menlo,m53menlo", "fsl,imx53";
+ gpio-keys { + compatible = "gpio-keys"; + pinctrl-0 = <&pinctrl_power_button>; + pinctrl-names = "default"; + + power-button { + label = "Power button"; + gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + }; + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + pinctrl-0 = <&pinctrl_power_out>; + pinctrl-names = "default"; + gpios = <&gpio1 13 GPIO_ACTIVE_LOW>; + }; + leds { compatible = "gpio-leds"; pinctrl-names = "default"; @@ -31,27 +49,60 @@ eth { label = "EthLedYe"; gpios = <&gpio2 11 GPIO_ACTIVE_LOW>; - linux,default-trigger = "none"; + linux,default-trigger = "netdev"; + }; + }; + + lvds-decoder { + compatible = "ti,ds90cf364a", "lvds-decoder"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + lvds_decoder_in: endpoint { + remote-endpoint = <&lvds0_out>; + }; + }; + + port@1 { + reg = <1>; + + lvds_decoder_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; }; };
panel { - compatible = "edt,etm070080dh6"; + compatible = "edt,etm0700g0dh6"; + pinctrl-0 = <&pinctrl_display_gpio>; + pinctrl-names = "default"; enable-gpios = <&gpio6 0 GPIO_ACTIVE_HIGH>;
port { panel_in: endpoint { - remote-endpoint = <&lvds0_out>; + remote-endpoint = <&lvds_decoder_out>; }; }; };
+ beeper { + compatible = "gpio-beeper"; + pinctrl-0 = <&pinctrl_beeper>; + gpios = <&gpio6 3 GPIO_ACTIVE_HIGH>; + }; + reg_usbh1_vbus: regulator-usbh1-vbus { compatible = "regulator-fixed"; regulator-name = "vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; - gpio = <&gpio1 2 GPIO_ACTIVE_LOW>; + gpio = <&gpio1 2 0>; }; };
@@ -75,6 +126,25 @@ assigned-clock-rates = <133333334>, <33333334>, <33333334>; };
+&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2>; + cs-gpios = <&gpio2 26 GPIO_ACTIVE_LOW>, <&gpio2 27 GPIO_ACTIVE_LOW>; + status = "okay"; + + spidev@0 { + compatible = "menlo,m53cpld"; + spi-max-frequency = <25000000>; + reg = <0>; + }; + + spidev@1 { + compatible = "menlo,m53cpld"; + spi-max-frequency = <25000000>; + reg = <1>; + }; +}; + &esdhc1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_esdhc1>; @@ -86,19 +156,81 @@ &fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_fec>; - phy-handle = <ðphy0>; phy-mode = "rmii"; + phy-reset-gpios = <&gpio7 7 GPIO_ACTIVE_LOW>; status = "okay"; +};
- mdio { - #address-cells = <1>; - #size-cells = <0>; +&gpio1 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +};
- ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; - }; +&gpio2 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "TestPin_SV2_3", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpio3 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "CPLD_JTAG_TDI", "CPLD_JTAG_TMS", "", "", + "", "CPLD_JTAG_TDO", "", ""; +}; + +&gpio5 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "CPLD_JTAG_TCK", "KBD_intK", + "CPLD_int", "CPLD_JTAG_internal", "CPLD_D[0]", "CPLD_D[1]", + "CPLD_D[2]", "CPLD_D[3]", "CPLD_D[4]", "CPLD_D[5]", + "CPLD_D[6]", "CPLD_D[7]", "DISP_reset", "KBD_intI"; +}; + +&gpio6 { + gpio-line-names = + "", "", "", "", + "CPLD_reset", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; +}; + +&gpio7 { + gpio-line-names = + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "USB-OTG_OverCurrent", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", "", + "", "", "", ""; };
&i2c1 { @@ -148,27 +280,37 @@ imx53-m53evk { hoggrp { fsl,pins = < - MX53_PAD_GPIO_0__CCM_SSI_EXT1_CLK 0x1c4 - MX53_PAD_EIM_EB3__GPIO2_31 0x1d5 - MX53_PAD_PATA_DA_0__GPIO7_6 0x1d5 - MX53_PAD_GPIO_19__CCM_CLKO 0x1d5 - MX53_PAD_CSI0_MCLK__CCM_CSI0_MCLK 0x1d5 - MX53_PAD_CSI0_DAT4__GPIO5_22 0x1d5 - MX53_PAD_CSI0_DAT5__GPIO5_23 0x1d5 - MX53_PAD_CSI0_DAT6__GPIO5_24 0x1d5 - MX53_PAD_CSI0_DAT7__GPIO5_25 0x1d5 - MX53_PAD_CSI0_DAT8__GPIO5_26 0x1d5 - MX53_PAD_CSI0_DAT9__GPIO5_27 0x1d5 - MX53_PAD_CSI0_DAT10__GPIO5_28 0x1d5 - MX53_PAD_CSI0_DAT11__GPIO5_29 0x1d5 - MX53_PAD_CSI0_DAT14__GPIO6_0 0x1d5 + MX53_PAD_GPIO_19__CCM_CLKO 0x1e4 + MX53_PAD_CSI0_DATA_EN__GPIO5_20 0x1e4 + MX53_PAD_CSI0_DAT4__GPIO5_22 0x1e4 + MX53_PAD_CSI0_DAT5__GPIO5_23 0x1c4 + MX53_PAD_CSI0_DAT6__GPIO5_24 0x1e4 + MX53_PAD_CSI0_DAT7__GPIO5_25 0x1e4 + MX53_PAD_CSI0_DAT8__GPIO5_26 0x1e4 + MX53_PAD_CSI0_DAT9__GPIO5_27 0x1c4 + MX53_PAD_CSI0_DAT10__GPIO5_28 0x1e4 + MX53_PAD_CSI0_DAT11__GPIO5_29 0x1e4 + MX53_PAD_PATA_DATA11__GPIO2_11 0x1e4 + MX53_PAD_EIM_D24__GPIO3_24 0x1e4 + MX53_PAD_EIM_D25__GPIO3_25 0x1e4 + MX53_PAD_EIM_D29__GPIO3_29 0x1e4 + MX53_PAD_CSI0_PIXCLK__GPIO5_18 0x1e4 + MX53_PAD_CSI0_VSYNC__GPIO5_21 0x1e4 + MX53_PAD_CSI0_DAT18__GPIO6_4 0x1c4 + MX53_PAD_PATA_DATA8__GPIO2_8 0x1e4 >; };
pinctrl_led: ledgrp { fsl,pins = < - MX53_PAD_CSI0_DAT15__GPIO6_1 0x1d5 - MX53_PAD_CSI0_DAT16__GPIO6_2 0x1d5 + MX53_PAD_CSI0_DAT15__GPIO6_1 0x1c4 + MX53_PAD_CSI0_DAT16__GPIO6_2 0x1c4 + >; + }; + + pinctrl_beeper: beepergrp { + fsl,pins = < + MX53_PAD_CSI0_DAT17__GPIO6_3 0x1c4 >; };
@@ -181,49 +323,66 @@
pinctrl_can2: can2grp { fsl,pins = < - MX53_PAD_KEY_COL4__CAN2_TXCAN 0x1c4 + MX53_PAD_KEY_COL4__CAN2_TXCAN 0x1e4 MX53_PAD_KEY_ROW4__CAN2_RXCAN 0x1c4 >; };
pinctrl_display_gpio: display-gpiogrp { fsl,pins = < - MX53_PAD_CSI0_DAT12__GPIO5_30 0x1d5 /* Reset */ - MX53_PAD_CSI0_DAT13__GPIO5_31 0x1d5 /* Interrupt */ + MX53_PAD_CSI0_DAT12__GPIO5_30 0x1c4 /* Reset */ + MX53_PAD_CSI0_MCLK__GPIO5_19 0x1e4 /* Int-K */ + MX53_PAD_CSI0_DAT13__GPIO5_31 0x1c4 /* Int-I */ + + MX53_PAD_CSI0_DAT14__GPIO6_0 0x1c4 /* Power down */ >; };
pinctrl_edt_ft5x06: edt-ft5x06grp { fsl,pins = < - MX53_PAD_PATA_DATA9__GPIO2_9 0x1d5 /* Reset */ - MX53_PAD_CSI0_DAT19__GPIO6_5 0x1d5 /* Interrupt */ - MX53_PAD_PATA_DATA10__GPIO2_10 0x1d5 /* Wake */ + MX53_PAD_PATA_DATA9__GPIO2_9 0x1e4 /* Reset */ + MX53_PAD_CSI0_DAT19__GPIO6_5 0x1c4 /* Interrupt */ + MX53_PAD_PATA_DATA10__GPIO2_10 0x1e4 /* Wake */ + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX53_PAD_EIM_CS0__ECSPI2_SCLK 0xe4 + MX53_PAD_EIM_OE__ECSPI2_MISO 0xe4 + MX53_PAD_EIM_CS1__ECSPI2_MOSI 0xe4 + MX53_PAD_EIM_RW__GPIO2_26 0xe4 + MX53_PAD_EIM_LBA__GPIO2_27 0xe4 >; };
pinctrl_esdhc1: esdhc1grp { fsl,pins = < - MX53_PAD_SD1_DATA0__ESDHC1_DAT0 0x1d5 - MX53_PAD_SD1_DATA1__ESDHC1_DAT1 0x1d5 - MX53_PAD_SD1_DATA2__ESDHC1_DAT2 0x1d5 - MX53_PAD_SD1_DATA3__ESDHC1_DAT3 0x1d5 - MX53_PAD_SD1_CMD__ESDHC1_CMD 0x1d5 - MX53_PAD_SD1_CLK__ESDHC1_CLK 0x1d5 + MX53_PAD_SD1_DATA0__ESDHC1_DAT0 0x1e4 + MX53_PAD_SD1_DATA1__ESDHC1_DAT1 0x1e4 + MX53_PAD_SD1_DATA2__ESDHC1_DAT2 0x1e4 + MX53_PAD_SD1_DATA3__ESDHC1_DAT3 0x1e4 + MX53_PAD_SD1_CMD__ESDHC1_CMD 0x1e4 + MX53_PAD_SD1_CLK__ESDHC1_CLK 0x1e4 + MX53_PAD_GPIO_1__GPIO1_1 0x1c4 + MX53_PAD_GPIO_9__GPIO1_9 0x1e4 >; };
pinctrl_fec: fecgrp { fsl,pins = < - MX53_PAD_FEC_MDC__FEC_MDC 0x4 - MX53_PAD_FEC_MDIO__FEC_MDIO 0x1fc - MX53_PAD_FEC_REF_CLK__FEC_TX_CLK 0x180 - MX53_PAD_FEC_RX_ER__FEC_RX_ER 0x180 - MX53_PAD_FEC_CRS_DV__FEC_RX_DV 0x180 - MX53_PAD_FEC_RXD1__FEC_RDATA_1 0x180 - MX53_PAD_FEC_RXD0__FEC_RDATA_0 0x180 - MX53_PAD_FEC_TX_EN__FEC_TX_EN 0x4 - MX53_PAD_FEC_TXD1__FEC_TDATA_1 0x4 - MX53_PAD_FEC_TXD0__FEC_TDATA_0 0x4 + MX53_PAD_FEC_MDC__FEC_MDC 0x1e4 + MX53_PAD_FEC_MDIO__FEC_MDIO 0x1e4 + MX53_PAD_FEC_REF_CLK__FEC_TX_CLK 0x1e4 + MX53_PAD_FEC_RX_ER__FEC_RX_ER 0x1e4 + MX53_PAD_FEC_CRS_DV__FEC_RX_DV 0x1e4 + MX53_PAD_FEC_RXD1__FEC_RDATA_1 0x1e4 + MX53_PAD_FEC_RXD0__FEC_RDATA_0 0x1e4 + MX53_PAD_FEC_TX_EN__FEC_TX_EN 0x1c4 + MX53_PAD_FEC_TXD1__FEC_TDATA_1 0x1e4 + MX53_PAD_FEC_TXD0__FEC_TDATA_0 0x1e4 + MX53_PAD_PATA_DA_1__GPIO7_7 0x1e4 + MX53_PAD_EIM_EB3__GPIO2_31 0x1e4 >; };
@@ -252,10 +411,24 @@ >; };
+ pinctrl_power_button: powerbutgrp { + fsl,pins = < + MX53_PAD_SD2_DATA0__GPIO1_15 0x1e4 + >; + }; + + pinctrl_power_out: poweroutgrp { + fsl,pins = < + MX53_PAD_SD2_DATA2__GPIO1_13 0x1e4 + >; + }; + pinctrl_uart1: uart1grp { fsl,pins = < MX53_PAD_PATA_DIOW__UART1_TXD_MUX 0x1e4 MX53_PAD_PATA_DMACK__UART1_RXD_MUX 0x1e4 + MX53_PAD_PATA_IORDY__UART1_RTS 0x1e4 + MX53_PAD_PATA_RESET_B__UART1_CTS 0x1e4 >; };
@@ -263,13 +436,25 @@ fsl,pins = < MX53_PAD_PATA_BUFFER_EN__UART2_RXD_MUX 0x1e4 MX53_PAD_PATA_DMARQ__UART2_TXD_MUX 0x1e4 + MX53_PAD_PATA_DIOR__UART2_RTS 0x1e4 + MX53_PAD_PATA_INTRQ__UART2_CTS 0x1e4 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX53_PAD_PATA_CS_1__UART3_RXD_MUX 0x1e4 + MX53_PAD_PATA_CS_0__UART3_TXD_MUX 0x1e4 + MX53_PAD_PATA_DA_2__UART3_RTS 0x1e4 >; };
pinctrl_usb: usbgrp { fsl,pins = < - MX53_PAD_GPIO_2__GPIO1_2 0x1d5 - MX53_PAD_GPIO_3__USBOH3_USBH1_OC 0x1d5 + MX53_PAD_GPIO_2__GPIO1_2 0x1c4 + MX53_PAD_GPIO_3__USBOH3_USBH1_OC 0x1c4 + MX53_PAD_GPIO_4__GPIO1_4 0x1c4 + MX53_PAD_GPIO_18__GPIO7_13 0x1c4 >; }; }; @@ -290,7 +475,7 @@ reg = <2>;
lvds0_out: endpoint { - remote-endpoint = <&panel_in>; + remote-endpoint = <&lvds_decoder_in>; }; }; }; @@ -299,12 +484,21 @@ &uart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; + uart-has-rtscts; status = "okay"; };
&uart2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; + uart-has-rtscts; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + linux,rs485-enabled-at-boot-time; status = "okay"; };
@@ -313,7 +507,7 @@ pinctrl-0 = <&pinctrl_usb>; vbus-supply = <®_usbh1_vbus>; phy_type = "utmi"; - dr_mode = "peripheral"; + dr_mode = "host"; status = "okay"; };
diff --git a/arch/arm/dts/imx53-pinfunc.h b/arch/arm/dts/imx53-pinfunc.h index baf710d0df..67bd06610f 100644 --- a/arch/arm/dts/imx53-pinfunc.h +++ b/arch/arm/dts/imx53-pinfunc.h @@ -1,16 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Copyright 2013 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * */
#ifndef __DTS_IMX53_PINFUNC_H #define __DTS_IMX53_PINFUNC_H
-#define IMX_PAD_SION 0x40000000 /* * The pin function ID is a tuple of * <mux_reg conf_reg input_reg mux_mode input_val> @@ -525,6 +520,7 @@ #define MX53_PAD_EIM_D25__UART1_DSR 0x140 0x488 0x000 0x7 0x0 #define MX53_PAD_EIM_D26__EMI_WEIM_D_26 0x144 0x48c 0x000 0x0 0x0 #define MX53_PAD_EIM_D26__GPIO3_26 0x144 0x48c 0x000 0x1 0x0 +#define MX53_PAD_EIM_D26__UART2_RXD_MUX 0x144 0x48c 0x880 0x2 0x0 #define MX53_PAD_EIM_D26__UART2_TXD_MUX 0x144 0x48c 0x000 0x2 0x0 #define MX53_PAD_EIM_D26__FIRI_RXD 0x144 0x48c 0x80c 0x3 0x0 #define MX53_PAD_EIM_D26__IPU_CSI0_D_1 0x144 0x48c 0x000 0x4 0x0 @@ -534,6 +530,7 @@ #define MX53_PAD_EIM_D27__EMI_WEIM_D_27 0x148 0x490 0x000 0x0 0x0 #define MX53_PAD_EIM_D27__GPIO3_27 0x148 0x490 0x000 0x1 0x0 #define MX53_PAD_EIM_D27__UART2_RXD_MUX 0x148 0x490 0x880 0x2 0x1 +#define MX53_PAD_EIM_D27__UART2_TXD_MUX 0x148 0x490 0x000 0x2 0x0 #define MX53_PAD_EIM_D27__FIRI_TXD 0x148 0x490 0x000 0x3 0x0 #define MX53_PAD_EIM_D27__IPU_CSI0_D_0 0x148 0x490 0x000 0x4 0x0 #define MX53_PAD_EIM_D27__IPU_DI1_PIN13 0x148 0x490 0x000 0x5 0x0 @@ -542,6 +539,7 @@ #define MX53_PAD_EIM_D28__EMI_WEIM_D_28 0x14c 0x494 0x000 0x0 0x0 #define MX53_PAD_EIM_D28__GPIO3_28 0x14c 0x494 0x000 0x1 0x0 #define MX53_PAD_EIM_D28__UART2_CTS 0x14c 0x494 0x000 0x2 0x0 +#define MX53_PAD_EIM_D28__UART2_RTS 0x14c 0x494 0x87c 0x2 0x0 #define MX53_PAD_EIM_D28__IPU_DISPB0_SER_DIO 0x14c 0x494 0x82c 0x3 0x1 #define MX53_PAD_EIM_D28__CSPI_MOSI 0x14c 0x494 0x788 0x4 0x1 #define MX53_PAD_EIM_D28__I2C1_SDA 0x14c 0x494 0x818 0x5 0x1 @@ -549,6 +547,7 @@ #define MX53_PAD_EIM_D28__IPU_DI0_PIN13 0x14c 0x494 0x000 0x7 0x0 #define MX53_PAD_EIM_D29__EMI_WEIM_D_29 0x150 0x498 0x000 0x0 0x0 #define MX53_PAD_EIM_D29__GPIO3_29 0x150 0x498 0x000 0x1 0x0 +#define MX53_PAD_EIM_D29__UART2_CTS 0x150 0x498 0x000 0x2 0x0 #define MX53_PAD_EIM_D29__UART2_RTS 0x150 0x498 0x87c 0x2 0x1 #define MX53_PAD_EIM_D29__IPU_DISPB0_SER_RS 0x150 0x498 0x000 0x3 0x0 #define MX53_PAD_EIM_D29__CSPI_SS0 0x150 0x498 0x78c 0x4 0x2 diff --git a/arch/arm/dts/imx53-ppd.dts b/arch/arm/dts/imx53-ppd.dts index a6278476d3..37d0cffea9 100644 --- a/arch/arm/dts/imx53-ppd.dts +++ b/arch/arm/dts/imx53-ppd.dts @@ -1,4 +1,3 @@ -// SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 General Electric Company * @@ -71,6 +70,12 @@ clock-frequency = <11289600>; };
+ achc_24M: achc-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + sgtlsound: sound { compatible = "fsl,imx53-cpuvo-sgtl5000", "fsl,imx-audio-sgtl5000"; @@ -177,15 +182,42 @@ power-supply = <®_3v3_lcd>; };
- leds { + led-controller-1 { compatible = "pwm-leds";
- alarm-brightness { + led-1 { + label = "alarm-brightness"; pwms = <&pwm1 0 100000>; max-brightness = <255>; }; };
+ led-controller-2 { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_alarmled_pins>; + + led-2 { + label = "alarm:red"; + gpios = <&gpio7 3 GPIO_ACTIVE_HIGH>; + }; + + led-3 { + label = "alarm:yellow"; + gpios = <&gpio7 7 GPIO_ACTIVE_HIGH>; + }; + + led-4 { + label = "alarm:blue"; + gpios = <&gpio7 8 GPIO_ACTIVE_HIGH>; + }; + + led-5 { + label = "alarm:silenced"; + gpios = <&gpio7 13 GPIO_ACTIVE_HIGH>; + }; + }; + gpio-poweroff { compatible = "gpio-poweroff"; gpios = <&gpio3 9 GPIO_ACTIVE_HIGH>; @@ -288,16 +320,13 @@ &gpio4 12 GPIO_ACTIVE_LOW>; status = "okay";
- spidev0: spi@0 { - compatible = "ge,achc"; - reg = <0>; - spi-max-frequency = <1000000>; - }; - - spidev1: spi@1 { - compatible = "ge,achc"; - reg = <1>; - spi-max-frequency = <1000000>; + spidev0: spi@1 { + compatible = "ge,achc", "nxp,kinetis-k20"; + reg = <1>, <0>; + vdd-supply = <®_3v3>; + vdda-supply = <®_3v3>; + clocks = <&achc_24M>; + reset-gpios = <&gpio3 6 GPIO_ACTIVE_LOW>; };
gpioxra0: gpio@2 { @@ -439,7 +468,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_esdhc3>; bus-width = <8>; - non-removable; status = "okay"; };
@@ -489,7 +517,7 @@ reg = <1>;
rtc@30 { - compatible = "sii,s35392a-rtc"; + compatible = "sii,s35390a"; reg = <0x30>; };
@@ -565,7 +593,7 @@
touchscreen@4b { compatible = "atmel,maxtouch"; - reset-gpio = <&gpio5 19 GPIO_ACTIVE_HIGH>; + reset-gpio = <&gpio5 19 GPIO_ACTIVE_LOW>; reg = <0x4b>; interrupt-parent = <&gpio5>; interrupts = <4 IRQ_TYPE_LEVEL_LOW>; @@ -600,12 +628,14 @@ };
&pwm2 { + #pwm-cells = <2>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pwm2>; status = "okay"; @@ -624,6 +654,7 @@ &uart2 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; + fsl,dma-info = <24 20>; status = "okay"; };
@@ -643,6 +674,7 @@ &uart5 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart5>; + fsl,dma-info = <4096 4>; status = "okay"; };
@@ -911,18 +943,10 @@ MX53_PAD_NANDF_CS3__GPIO6_16 0x0 /* POWER_AND_BOOT_STATUS_INDICATOR */ MX53_PAD_PATA_INTRQ__GPIO7_2 0x1e4 - /* ACTIVATE_ALARM_LIGHT_RED */ - MX53_PAD_PATA_DIOR__GPIO7_3 0x0 - /* ACTIVATE_ALARM_LIGHT_YELLOW */ - MX53_PAD_PATA_DA_1__GPIO7_7 0x0 - /* ACTIVATE_ALARM_LIGHT_CYAN */ - MX53_PAD_PATA_DA_2__GPIO7_8 0x0 /* RUNNING_ON_BATTERY_INDICATOR_GREEN */ MX53_PAD_GPIO_16__GPIO7_11 0x0 /* BATTERY_STATUS_INDICATOR_AMBER */ MX53_PAD_GPIO_17__GPIO7_12 0x0 - /* AUDIO_ALARMS_SILENCED_INDICATOR */ - MX53_PAD_GPIO_18__GPIO7_13 0x0 >; };
@@ -1082,6 +1106,17 @@ MX53_PAD_KEY_COL4__USBOH3_USBOTG_OC 0x180 >; }; -};
-#include "imx53-ppd-uboot.dtsi" + pinctrl_alarmled_pins: qmx6alarmledgrp { + fsl,pins = < + /* ACTIVATE_ALARM_LIGHT_RED */ + MX53_PAD_PATA_DIOR__GPIO7_3 0x0 + /* ACTIVATE_ALARM_LIGHT_YELLOW */ + MX53_PAD_PATA_DA_1__GPIO7_7 0x0 + /* ACTIVATE_ALARM_LIGHT_CYAN */ + MX53_PAD_PATA_DA_2__GPIO7_8 0x0 + /* AUDIO_ALARMS_SILENCED_INDICATOR */ + MX53_PAD_GPIO_18__GPIO7_13 0x0 + >; + }; +}; diff --git a/arch/arm/dts/imx53-usbarmory.dts b/arch/arm/dts/imx53-usbarmory.dts index 433b62e736..f34993a490 100644 --- a/arch/arm/dts/imx53-usbarmory.dts +++ b/arch/arm/dts/imx53-usbarmory.dts @@ -91,7 +91,6 @@ &esdhc1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_esdhc1>; - broken-cd; status = "okay"; };
diff --git a/arch/arm/dts/imx53.dtsi b/arch/arm/dts/imx53.dtsi index 8536f59f59..b7a6469d34 100644 --- a/arch/arm/dts/imx53.dtsi +++ b/arch/arm/dts/imx53.dtsi @@ -86,25 +86,25 @@
clocks { ckil { - compatible = "fsl,imx-ckil", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <32768>; };
ckih1 { - compatible = "fsl,imx-ckih1", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <22579200>; };
ckih2 { - compatible = "fsl,imx-ckih2", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <0>; };
osc { - compatible = "fsl,imx-osc", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; }; @@ -132,7 +132,7 @@ status = "okay"; };
- soc { + soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; @@ -222,21 +222,21 @@ clock-names = "core_clk", "mem_iface_clk"; };
- bus@50000000 { /* AIPS1 */ + aips1: bus@50000000 { /* AIPS1 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x50000000 0x10000000>; ranges;
- spba@50000000 { + spba-bus@50000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x50000000 0x40000>; ranges;
- esdhc1: esdhc@50004000 { + esdhc1: mmc@50004000 { compatible = "fsl,imx53-esdhc"; reg = <0x50004000 0x4000>; interrupts = <1>; @@ -248,7 +248,7 @@ status = "disabled"; };
- esdhc2: esdhc@50008000 { + esdhc2: mmc@50008000 { compatible = "fsl,imx53-esdhc"; reg = <0x50008000 0x4000>; interrupts = <2>; @@ -301,7 +301,7 @@ status = "disabled"; };
- esdhc3: esdhc@50020000 { + esdhc3: mmc@50020000 { compatible = "fsl,imx53-esdhc"; reg = <0x50020000 0x4000>; interrupts = <3>; @@ -313,7 +313,7 @@ status = "disabled"; };
- esdhc4: esdhc@50024000 { + esdhc4: mmc@50024000 { compatible = "fsl,imx53-esdhc"; reg = <0x50024000 0x4000>; interrupts = <4>; @@ -427,14 +427,14 @@ status = "disabled"; };
- wdog1: wdog@53f98000 { + wdog1: watchdog@53f98000 { compatible = "fsl,imx53-wdt", "fsl,imx21-wdt"; reg = <0x53f98000 0x4000>; interrupts = <58>; clocks = <&clks IMX5_CLK_DUMMY>; };
- wdog2: wdog@53f9c000 { + wdog2: watchdog@53f9c000 { compatible = "fsl,imx53-wdt", "fsl,imx21-wdt"; reg = <0x53f9c000 0x4000>; interrupts = <59>; @@ -525,7 +525,7 @@ };
pwm1: pwm@53fb4000 { - #pwm-cells = <2>; + #pwm-cells = <3>; compatible = "fsl,imx53-pwm", "fsl,imx27-pwm"; reg = <0x53fb4000 0x4000>; clocks = <&clks IMX5_CLK_PWM1_IPG_GATE>, @@ -535,7 +535,7 @@ };
pwm2: pwm@53fb8000 { - #pwm-cells = <2>; + #pwm-cells = <3>; compatible = "fsl,imx53-pwm", "fsl,imx27-pwm"; reg = <0x53fb8000 0x4000>; clocks = <&clks IMX5_CLK_PWM2_IPG_GATE>, @@ -588,9 +588,10 @@ status = "disabled"; };
- src: src@53fd0000 { + src: reset-controller@53fd0000 { compatible = "fsl,imx53-src", "fsl,imx51-src"; reg = <0x53fd0000 0x4000>; + interrupts = <75>; #reset-cells = <1>; };
@@ -654,7 +655,7 @@ }; };
- bus@60000000 { /* AIPS2 */ + aips2: bus@60000000 { /* AIPS2 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -666,8 +667,8 @@ reg = <0x63f00000 0x60>; };
- iim: iim@63f98000 { - compatible = "fsl,imx53-iim", "fsl,imx27-iim"; + iim: efuse@63f98000 { + compatible = "fsl,imx53-iim", "fsl,imx27-iim", "syscon"; reg = <0x63f98000 0x4000>; interrupts = <69>; clocks = <&clks IMX5_CLK_IIM_GATE>;
From: Marcel Ziswiler marcel.ziswiler@toradex.com Synchronise device tree with linux v6.0-rc1. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
arch/arm/dts/imx51.dtsi | 24 +++++++++++++++--------- 1 file changed, 15 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/imx51.dtsi b/arch/arm/dts/imx51.dtsi index 7ebb46ce9e..592d9c23a4 100644 --- a/arch/arm/dts/imx51.dtsi +++ b/arch/arm/dts/imx51.dtsi @@ -48,25 +48,25 @@
ckih1 { - compatible = "fsl,imx-ckih1", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <0>; };
osc { - compatible = "fsl,imx-osc", "fixed-clock"; + compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <24000000>; }; @@ -114,7 +114,7 @@ ports = <&ipu_di0>, <&ipu_di1>; };
- soc { + soc: soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; @@ -171,14 +171,14 @@ }; };
- bus@70000000 { /* AIPS1 */ + aips1: bus@70000000 { /* AIPS1 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x70000000 0x10000000>; ranges;
- spba@70000000 { + spba-bus@70000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -215,6 +215,8 @@ clocks = <&clks IMX5_CLK_UART3_IPG_GATE>, <&clks IMX5_CLK_UART3_PER_GATE>; clock-names = "ipg", "per"; + dmas = <&sdma 43 5 1>, <&sdma 44 5 2>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -426,6 +428,8 @@ clocks = <&clks IMX5_CLK_UART1_IPG_GATE>, <&clks IMX5_CLK_UART1_PER_GATE>; clock-names = "ipg", "per"; + dmas = <&sdma 18 4 1>, <&sdma 19 4 2>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -436,6 +440,8 @@ clocks = <&clks IMX5_CLK_UART2_IPG_GATE>, <&clks IMX5_CLK_UART2_PER_GATE>; clock-names = "ipg", "per"; + dmas = <&sdma 16 4 1>, <&sdma 17 4 2>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -454,7 +460,7 @@ }; };
- bus@80000000 { /* AIPS2 */ + aips2: bus@80000000 { /* AIPS2 */ compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; @@ -467,7 +473,7 @@ };
iim: efuse@83f98000 { - compatible = "fsl,imx51-iim", "fsl,imx27-iim"; + compatible = "fsl,imx51-iim", "fsl,imx27-iim", "syscon"; reg = <0x83f98000 0x4000>; interrupts = <69>; clocks = <&clks IMX5_CLK_IIM_GATE>;
Changes in v2: - Add missing imx28-lwe.dtsi as pointed out by Fabio. Thanks!
arch/arm/dts/imx28-evk.dts | 2 +- arch/arm/dts/imx28-lwe.dtsi | 170 +++++++++++++++++++++++++++++++ arch/arm/dts/imx28-pinfunc.h | 8 +- arch/arm/dts/imx28-xea.dts | 188 ++++++++++++++--------------------- arch/arm/dts/imx28.dtsi | 20 +++- arch/arm/dts/mxs-pinfunc.h | 8 +- 6 files changed, 261 insertions(+), 135 deletions(-) create mode 100644 arch/arm/dts/imx28-lwe.dtsi
diff --git a/arch/arm/dts/imx28-evk.dts b/arch/arm/dts/imx28-evk.dts index 7e2b0f198d..1053b7c584 100644 --- a/arch/arm/dts/imx28-evk.dts +++ b/arch/arm/dts/imx28-evk.dts @@ -129,7 +129,7 @@ pinctrl-0 = <&spi2_pins_a>; status = "okay";
- flash: m25p80@0 { + flash: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "sst,sst25vf016b", "jedec,spi-nor"; diff --git a/arch/arm/dts/imx28-lwe.dtsi b/arch/arm/dts/imx28-lwe.dtsi new file mode 100644 index 0000000000..bb971e660d --- /dev/null +++ b/arch/arm/dts/imx28-lwe.dtsi @@ -0,0 +1,170 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2021 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + */ + +/dts-v1/; +#include "imx28.dtsi" + +/ { + aliases { + spi2 = &ssp3; + }; + + chosen { + bootargs = "root=/dev/mmcblk0p2 rootfstype=ext4 ro rootwait console=ttyAMA0,115200 panic=1"; + }; + + memory@40000000 { + reg = <0x40000000 0x08000000>; + }; + + reg_3v3: regulator-reg-3v3 { + compatible = "regulator-fixed"; + regulator-name = "3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_usb_5v: regulator-reg-usb-5v { + compatible = "regulator-fixed"; + regulator-name = "usb_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_fec_3v3: regulator-reg-fec-3v3 { + compatible = "regulator-fixed"; + regulator-name = "fec-phy"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&duart { + pinctrl-names = "default"; + pinctrl-0 = <&duart_pins_a>; + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; +}; + +&saif0 { + pinctrl-names = "default"; + pinctrl-0 = <&saif0_pins_a>; + #sound-dai-cells = <0>; + assigned-clocks = <&clks 53>; + assigned-clock-rates = <12000000>; + status = "okay"; +}; + +&saif1 { + pinctrl-names = "default"; + pinctrl-0 = <&saif1_pins_a>; + fsl,saif-master = <&saif0>; + #sound-dai-cells = <0>; + status = "okay"; +}; + +&spi3_pins_a { + fsl,pinmux-ids = < + MX28_PAD_AUART2_RX__SSP3_D4 + MX28_PAD_AUART2_TX__SSP3_D5 + MX28_PAD_SSP3_SCK__SSP3_SCK + MX28_PAD_SSP3_MOSI__SSP3_CMD + MX28_PAD_SSP3_MISO__SSP3_D0 + MX28_PAD_SSP3_SS0__SSP3_D3 + MX28_PAD_AUART2_TX__GPIO_3_9 + >; +}; + +&ssp0 { + compatible = "fsl,imx28-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_8bit_pins_a>; + bus-width = <8>; + vmmc-supply = <®_3v3>; + non-removable; + status = "okay"; +}; + +&ssp2 { + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi2_pins_a>; + status = "okay"; +}; + +&ssp3 { + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_pins_a>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <40000000>; + reg = <0>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot"; + reg = <0 0x80000>; + read-only; + }; + + partition@80000 { + label = "env0"; + reg = <0x80000 0x10000>; + }; + + partition@90000 { + label = "env1"; + reg = <0x90000 0x10000>; + }; + + partition@100000 { + label = "kernel"; + reg = <0x100000 0x400000>; + }; + + partition@500000 { + label = "swupdate"; + reg = <0x500000 0x800000>; + }; + }; + }; +}; + +&usb0 { + vbus-supply = <®_usb_5v>; + pinctrl-names = "default"; + pinctrl-0 = <&usb0_pins_b>, <&usb0_id_pins_a>; + dr_mode = "host"; + status = "okay"; +}; + +&usbphy0 { + status = "okay"; +}; + +&usb1 { + vbus-supply = <®_usb_5v>; + pinctrl-names = "default"; + pinctrl-0 = <&usb1_pins_b>; + dr_mode = "host"; + status = "okay"; +}; + +&usbphy1 { + status = "okay"; +}; diff --git a/arch/arm/dts/imx28-pinfunc.h b/arch/arm/dts/imx28-pinfunc.h index e11f69ba0f..d427e6c2fa 100644 --- a/arch/arm/dts/imx28-pinfunc.h +++ b/arch/arm/dts/imx28-pinfunc.h @@ -1,14 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Header providing constants for i.MX28 pinctrl bindings. * * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html */
#ifndef __DT_BINDINGS_MX28_PINCTRL_H__ diff --git a/arch/arm/dts/imx28-xea.dts b/arch/arm/dts/imx28-xea.dts index f4b503cf65..a400c108f6 100644 --- a/arch/arm/dts/imx28-xea.dts +++ b/arch/arm/dts/imx28-xea.dts @@ -1,143 +1,99 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT /* - * Copyright 2019 + * Copyright 2021 * Lukasz Majewski, DENX Software Engineering, lukma@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ or X11 - * */
/dts-v1/; - -#include "imx28.dtsi" +#include "imx28-lwe.dtsi"
/ { - model = "Liebherr (LWE) XEA i.MX28 Board"; - compatible = "lwe,xea", "fsl,imx28"; - - aliases { - spi3 = &ssp3; - }; - - memory@40000000 { - device_type = "memory"; - reg = <0x40000000 0x10000000>; - }; - - reg_3p3v: regulator-3p3v { - compatible = "regulator-fixed"; - regulator-name = "3P3V"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - reg_fec_3v3: regulator-fec-3v3 { - compatible = "regulator-fixed"; - regulator-name = "fec-3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio0 0 GPIO_ACTIVE_HIGH>; - enable-active-high; - regulator-boot-on; - }; - - reg_usb_5v: regulator-usb-5v { - compatible = "regulator-fixed"; - regulator-name = "usb_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio1 28 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; + compatible = "lwn,imx28-xea", "fsl,imx28"; };
-&mac0 { - phy-mode = "rmii"; +&can0 { pinctrl-names = "default"; - pinctrl-0 = <&mac0_pins_a>; - phy-supply = <®_fec_3v3>; - phy-reset-gpios = <&gpio2 13 GPIO_ACTIVE_LOW>; - phy-reset-duration = <1>; - phy-reset-post-delay = <1>; + pinctrl-0 = <&can1_pins_a>; status = "okay"; - - fixed-link { - speed = <100>; - full-duplex; - }; };
-&ssp0 { - compatible = "fsl,imx28-mmc"; +&i2c1 { pinctrl-names = "default"; - pinctrl-0 = <&mmc0_8bit_pins_a>; - bus-width = <8>; - vmmc-supply = <®_3p3v>; - non-removable; + pinctrl-0 = <&i2c1_pins_b>; status = "okay"; };
-&ssp3 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx28-spi"; +&pinctrl { pinctrl-names = "default"; - pinctrl-0 = <&spi3_pins_b>; - status = "okay"; - spi-max-frequency = <40000000>; - num-cs = <2>; + pinctrl-0 = <&hog_pins_a &hog_pins_tiva>;
- flash0: s25fl256s@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "jedec,spi-nor"; - spi-max-frequency = <40000000>; + hog_pins_a: hog@0 { reg = <0>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_D00__GPIO_0_0 + MX28_PAD_GPMI_D02__GPIO_0_2 + MX28_PAD_GPMI_D05__GPIO_0_5 + MX28_PAD_GPMI_CE1N__GPIO_0_17 + MX28_PAD_GPMI_RDY0__GPIO_0_20 + MX28_PAD_GPMI_RDY1__GPIO_0_21 + MX28_PAD_GPMI_RDY2__GPIO_0_22 + MX28_PAD_GPMI_RDN__GPIO_0_24 + MX28_PAD_GPMI_CLE__GPIO_0_27 + MX28_PAD_LCD_VSYNC__GPIO_1_28 + MX28_PAD_SSP1_SCK__GPIO_2_12 + MX28_PAD_SSP1_CMD__GPIO_2_13 + MX28_PAD_SSP2_SS1__GPIO_2_20 + MX28_PAD_SSP2_SS2__GPIO_2_21 + MX28_PAD_LCD_D00__GPIO_1_0 + MX28_PAD_LCD_D01__GPIO_1_1 + MX28_PAD_LCD_D02__GPIO_1_2 + MX28_PAD_LCD_D03__GPIO_1_3 + MX28_PAD_LCD_D04__GPIO_1_4 + MX28_PAD_LCD_D05__GPIO_1_5 + MX28_PAD_LCD_D06__GPIO_1_6 + >; + fsl,drive-strength = <MXS_DRIVE_4mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + + hog_pins_tiva: hog@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_RDY3__GPIO_0_23 + MX28_PAD_GPMI_WRN__GPIO_0_25 + >; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + };
- partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - partition@0 { - label = "SPL"; - reg = <0x0 0x10000>; - read-only; - }; - partition@10000 { - label = "u-boot"; - reg = <0x10000 0x70000>; - read-only; - }; - partition@80000 { - label = "uboot-env1"; - reg = <0x80000 0x10000>; - }; - partition@90000 { - label = "uboot-env2"; - reg = <0x90000 0x10000>; - }; - partition@A0000 { - label = "rescue"; - reg = <0xA0000 0xF40000>; - }; - partition@FE0000 { - label = "spl-boot-data1"; - reg = <0xFE0000 0x10000>; - }; - partition@FF0000 { - label = "spl-boot-data2"; - reg = <0xFF0000 0x10000>; - }; - }; + hog_pins_coding: hog@2 { + reg = <2>; + fsl,pinmux-ids = < + MX28_PAD_GPMI_D01__GPIO_0_1 + MX28_PAD_GPMI_D03__GPIO_0_3 + MX28_PAD_GPMI_D04__GPIO_0_4 + MX28_PAD_GPMI_D06__GPIO_0_6 + MX28_PAD_GPMI_D07__GPIO_0_7 + >; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; }; };
-&usb0 { - vbus-supply = <®_usb_5v>; - status = "okay"; +®_fec_3v3 { + gpio = <&gpio0 0 0>; };
-&usbphy0 { - status = "okay"; +®_usb_5v { + gpio = <&gpio0 2 0>; +}; + +&spi2_pins_a { + fsl,pinmux-ids = < + MX28_PAD_SSP2_SCK__SSP2_SCK + MX28_PAD_SSP2_MOSI__SSP2_CMD + MX28_PAD_SSP2_MISO__SSP2_D0 + MX28_PAD_SSP2_SS0__GPIO_2_19 + >; }; diff --git a/arch/arm/dts/imx28.dtsi b/arch/arm/dts/imx28.dtsi index e14d8ef015..130b4145af 100644 --- a/arch/arm/dts/imx28.dtsi +++ b/arch/arm/dts/imx28.dtsi @@ -100,7 +100,7 @@ status = "disabled"; };
- gpmi: gpmi-nand@8000c000 { + gpmi: nand-controller@8000c000 { compatible = "fsl,imx28-gpmi-nand"; #address-cells = <1>; #size-cells = <1>; @@ -110,6 +110,8 @@ interrupt-names = "bch"; clocks = <&clks 50>; clock-names = "gpmi_io"; + assigned-clocks = <&clks 13>; + assigned-clock-parents = <&clks 10>; dmas = <&dma_apbh 4>; dma-names = "rx-tx"; status = "disabled"; @@ -948,6 +950,16 @@ fsl,pull-up = <MXS_PULL_DISABLE>; };
+ usb1_pins_b: usb1@1 { + reg = <1>; + fsl,pinmux-ids = < + MX28_PAD_PWM2__USB1_OVERCURRENT + >; + fsl,drive-strength = <MXS_DRIVE_12mA>; + fsl,voltage = <MXS_VOLTAGE_HIGH>; + fsl,pull-up = <MXS_PULL_DISABLE>; + }; + usb0_id_pins_a: usb0id@0 { reg = <0>; fsl,pinmux-ids = < @@ -998,7 +1010,7 @@ clocks = <&clks 26>; };
- dcp: dcp@80028000 { + dcp: crypto@80028000 { compatible = "fsl,imx28-dcp", "fsl,imx23-dcp"; reg = <0x80028000 0x2000>; interrupts = <52 53 54>; @@ -1011,7 +1023,7 @@ status = "disabled"; };
- ocotp: ocotp@8002c000 { + ocotp: efuse@8002c000 { compatible = "fsl,imx28-ocotp", "fsl,ocotp"; #address-cells = <1>; #size-cells = <1>; @@ -1317,7 +1329,7 @@ status = "disabled"; };
- etn_switch: switch@800f8000 { + eth_switch: switch@800f8000 { reg = <0x800f8000 0x8000>; status = "disabled"; }; diff --git a/arch/arm/dts/mxs-pinfunc.h b/arch/arm/dts/mxs-pinfunc.h index c6da987b20..31297abcbc 100644 --- a/arch/arm/dts/mxs-pinfunc.h +++ b/arch/arm/dts/mxs-pinfunc.h @@ -1,14 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Header providing constants for i.MX28 pinctrl bindings. * * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html */
#ifndef __DT_BINDINGS_MXS_PINCTRL_H__
arch/arm/dts/imx23-evk.dts | 1 - arch/arm/dts/imx23-pinfunc.h | 8 +------- arch/arm/dts/imx23-u-boot.dtsi | 7 +++---- arch/arm/dts/imx23.dtsi | 2 +- 4 files changed, 5 insertions(+), 13 deletions(-)
diff --git a/arch/arm/dts/imx23-evk.dts b/arch/arm/dts/imx23-evk.dts index 8cbaf1c811..3b609d987d 100644 --- a/arch/arm/dts/imx23-evk.dts +++ b/arch/arm/dts/imx23-evk.dts @@ -79,7 +79,6 @@ MX23_PAD_LCD_RESET__GPIO_1_18 MX23_PAD_PWM3__GPIO_1_29 MX23_PAD_PWM4__GPIO_1_30 - MX23_PAD_SSP1_DETECT__SSP1_DETECT >; fsl,drive-strength = <MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; diff --git a/arch/arm/dts/imx23-pinfunc.h b/arch/arm/dts/imx23-pinfunc.h index 5c0f32ca3a..468c079f3c 100644 --- a/arch/arm/dts/imx23-pinfunc.h +++ b/arch/arm/dts/imx23-pinfunc.h @@ -1,14 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Header providing constants for i.MX23 pinctrl bindings. * * Copyright (C) 2013 Lothar Waßmann LW@KARO-electronics.de - * - * The code contained herein is licensed under the GNU General Public - * License. You may obtain a copy of the GNU General Public License - * Version 2 at the following locations: - * - * http://www.opensource.org/licenses/gpl-license.html - * http://www.gnu.org/copyleft/gpl.html */
#ifndef __DT_BINDINGS_MX23_PINCTRL_H__ diff --git a/arch/arm/dts/imx23-u-boot.dtsi b/arch/arm/dts/imx23-u-boot.dtsi index 5e87aca61b..5de62bbb90 100644 --- a/arch/arm/dts/imx23-u-boot.dtsi +++ b/arch/arm/dts/imx23-u-boot.dtsi @@ -1,14 +1,13 @@ // SPDX-License-Identifier: GPL-2.0+
&gpio0 { - gpio-ranges = <&pinctrl 0 0 32>; + gpio-ranges = <&{/apb@80000000/apbh@80000000/pinctrl@80018000} 0 0 32>; };
&gpio1 { - gpio-ranges = <&pinctrl 0 32 31>; + gpio-ranges = <&{/apb@80000000/apbh@80000000/pinctrl@80018000} 0 32 31>; };
&gpio2 { - gpio-ranges = <&pinctrl 0 63 32>; + gpio-ranges = <&{/apb@80000000/apbh@80000000/pinctrl@80018000} 0 63 32>; }; - diff --git a/arch/arm/dts/imx23.dtsi b/arch/arm/dts/imx23.dtsi index 4cfec77849..7f4c602454 100644 --- a/arch/arm/dts/imx23.dtsi +++ b/arch/arm/dts/imx23.dtsi @@ -105,7 +105,7 @@ status = "disabled"; };
- pinctrl: pinctrl@80018000 { + pinctrl@80018000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx23-pinctrl", "simple-bus";
Avoid the following build errors after the device tree sync:
drivers/spi/mxs_spi.c: In function ‘mxs_spi_probe’: drivers/spi/mxs_spi.c:327:25: error: ‘struct dtd_fsl_imx23_spi’ has no member named ‘spi_max_frequency’ 327 | priv->max_freq = dtplat->spi_max_frequency; | ^~ drivers/spi/mxs_spi.c:328:23: error: ‘struct dtd_fsl_imx23_spi’ has no member named ‘num_cs’ 328 | plat->num_cs = dtplat->num_cs; | ^~
arch/arm/dts/imx28-xea-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx28-xea-u-boot.dtsi b/arch/arm/dts/imx28-xea-u-boot.dtsi index cc2ced5d2d..8b5d7e10b3 100644 --- a/arch/arm/dts/imx28-xea-u-boot.dtsi +++ b/arch/arm/dts/imx28-xea-u-boot.dtsi @@ -42,5 +42,7 @@ };
&ssp3 { + num-cs = <2>; + spi-max-frequency = <40000000>; u-boot,dm-spl; };
From: Marcel Ziswiler marcel.ziswiler@toradex.com Avoid the following build errors after the device tree sync: drivers/spi/mxs_spi.c: In function ‘mxs_spi_probe’: drivers/spi/mxs_spi.c:327:25: error: ‘struct dtd_fsl_imx23_spi’ has no member named ‘spi_max_frequency’ 327 | priv->max_freq = dtplat->spi_max_frequency; | ^~ drivers/spi/mxs_spi.c:328:23: error: ‘struct dtd_fsl_imx23_spi’ has no member named ‘num_cs’ 328 | plat->num_cs = dtplat->num_cs; | ^~ Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Marcel Ziswiler
sbabic@denx.de
