[PATCH v2] fdt: Make fdt addr -q quieter
64597346 "fdt: Add -q option to fdt addr for distro_bootcmd" introduced the -q option for fdt addr, which sets the current working fdt address without printing any output.
baf41410 "fdt: Show a message when the working FDT changes" made the utility function set_working_fdt_addr (in cmd/fdt.c) output a message on each invocation, even if called via fdt addr -q, in which case its output is now slightly noisier.
To fix this, split out set_working_fdt_addr into set_working_fdt_addr plus the static function set_working_fdt_addr_quiet. set_working_fdt_addr_quiet can be called by "quiet" fdt cmd logic and set_working_fdt_addr is exported (as before) to other boot logic. The latter calls the former.
Remove the assertion from the fdt addr test case when calling with the -q argument.
Signed-off-by: Peter Hoyes Peter.Hoyes@arm.com --- cmd/fdt.c | 19 ++++++++++++++----- test/cmd/fdt.c | 1 - 2 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/cmd/fdt.c b/cmd/fdt.c index f38fe909c3..f1f2ef6a12 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -36,16 +36,21 @@ static int is_printable_string(const void *data, int len); */ struct fdt_header *working_fdt;
-void set_working_fdt_addr(ulong addr) +static void set_working_fdt_addr_quiet(ulong addr) { void *buf;
- printf("Working FDT set to %lx\n", addr); buf = map_sysmem(addr, 0); working_fdt = buf; env_set_hex("fdtaddr", addr); }
+void set_working_fdt_addr(ulong addr) +{ + printf("Working FDT set to %lx\n", addr); + set_working_fdt_addr_quiet(addr); +} + /* * Get a value from the fdt and format it to be set in the environment */ @@ -192,10 +197,14 @@ static int do_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if ((quiet && fdt_check_header(blob)) || (!quiet && !fdt_valid(&blob))) return 1; - if (control) + if (control) { gd->fdt_blob = blob; - else - set_working_fdt_addr(addr); + } else { + if (quiet) + set_working_fdt_addr_quiet(addr); + else + set_working_fdt_addr(addr); + }
if (argc >= 2) { int len; diff --git a/test/cmd/fdt.c b/test/cmd/fdt.c index cdbaf8c425..85b96c614b 100644 --- a/test/cmd/fdt.c +++ b/test/cmd/fdt.c @@ -229,7 +229,6 @@ static int fdt_test_addr_resize(struct unit_test_state *uts)
/* ...quietly */ ut_assertok(run_commandf("fdt addr -q %08x %x", addr, sizeof(fdt) / 4)); - ut_assert_nextline("Working FDT set to %lx", addr); ut_assertok(ut_check_console_end(uts));
/* We cannot easily provoke errors in fdt_open_into(), so ignore that */
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org
Thanks !
Applied to u-boot-dm/next, thanks!
Peter Hoyes
