Hi, I had downloaded U-Boot source code from AMCC website to build a u-boot image for NAND Flash.
Inside the u-boot directory I executed the following commands: make distclean make canyonlands_nand_config But I get the following error : : invalid option make: *** [canyonlands_nand_config] Error 1
These same commands executed inside the u-boot downloaded from the DENX site, does not give any errors. Has anybody else such a problem?
Regards, Afzal Nadirshah
________________________________ http://www.mindtree.com/email/disclaimer.html
Hi Afzal: Would you please send me the link to the files you got. I can help you check it out.
Feng Kan AMCC Software Engineering
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Afzal Nadirshah Sent: Thursday, February 05, 2009 9:13 PM To: u-boot@lists.denx.de Subject: [U-Boot] U-Boot compile error
Hi Feng, This is the link from which the Resource CD for the 460EX canyonlands evaluation kit, was downloaded : http://www.amcc.com/Embedded/Downloads/download.html?cat=1&family=19&... The u-boot source code was obtained from this CD. Regards, Afzal Nadirshah ________________________________________ From: Feng Kan [fkan@amcc.com] Sent: Friday, February 06, 2009 10:46 PM To: Afzal Nadirshah; u-boot@lists.denx.de Subject: RE: [U-Boot] U-Boot compile error
Dear Afzal Nadirshah,
In message 174230991E95D743B0C91DF471EF44E8434329C602@MTW02MSG02.mindtree.com you wrote:
This is the link from which the Resource CD for the 460EX canyonlands evaluation kit, was downloaded : http://www.amcc.com/Embedded/Downloads/download.html?cat=1&family=19&ins=33 The u-boot source code was obtained from this CD.
I recommend to use the U-Boot sources from the offical (mianline) U-Boot repository instead.
Afzal Nadirshah
Feng Kan
