[PATCH v3 0/4] arm: kirkwood: Add support for Pogoplug V4
Pogoplug V4 specifications:
Kirkwood 88F6192 SoC 800 MHz CPU 1Gbs Ethernet 128 MB RAM 128 MB NAND 1x USB 2.0 2x USB 3.0 (on PCIe bus) 1 SDHC slot 1x External SATA port (USM enclosure form factor slot)
Changes in v3: - Migrate config symbols from board include header to defconfig - Remove obsolete config symbols from header file - Don't use ifdefs for unselectable config symbols in header file - Migrate symbols from board include header to Kconfig - Squash board file small patches into one patch
Changes in v2: - Use mainline Linux DTS version - Use canonical format for defconfig file - Move constants to .c file and remove header file
Tony Dinh (4): arm: kirkwood: Pogoplug-V4 : Add DTS files arm: kirkwood: Pogoplug V4 : Add board include header and defconfig files arm: kirkwood: Pogoplug-V4 : Add Kconfig files arm: kirkwood: Pogoplug-V4 : Add board implementation files
arch/arm/dts/Makefile | 1 + arch/arm/dts/kirkwood-pogoplug-series-4.dts | 180 ++++++++++++++++ arch/arm/mach-kirkwood/Kconfig | 6 + board/cloudengines/pogo_v4/Kconfig | 16 ++ board/cloudengines/pogo_v4/MAINTAINERS | 6 + board/cloudengines/pogo_v4/Makefile | 10 + board/cloudengines/pogo_v4/kwbimage.cfg | 148 +++++++++++++ board/cloudengines/pogo_v4/pogo_v4.c | 220 ++++++++++++++++++++ configs/pogo_v4_defconfig | 79 +++++++ include/configs/pogo_v4.h | 56 +++++ 10 files changed, 722 insertions(+) create mode 100644 arch/arm/dts/kirkwood-pogoplug-series-4.dts create mode 100644 board/cloudengines/pogo_v4/Kconfig create mode 100644 board/cloudengines/pogo_v4/MAINTAINERS create mode 100644 board/cloudengines/pogo_v4/Makefile create mode 100644 board/cloudengines/pogo_v4/kwbimage.cfg create mode 100644 board/cloudengines/pogo_v4/pogo_v4.c create mode 100644 configs/pogo_v4_defconfig create mode 100644 include/configs/pogo_v4.h
Add DTS files for Pogoplug V4 board
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Tony Dinh mibodhi@gmail.com ---
(no changes since v2)
arch/arm/dts/Makefile | 1 + arch/arm/dts/kirkwood-pogoplug-series-4.dts | 180 ++++++++++++++++++++ 2 files changed, 181 insertions(+) create mode 100644 arch/arm/dts/kirkwood-pogoplug-series-4.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1b65e65eb8..ce33a4b52b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -71,6 +71,7 @@ dtb-$(CONFIG_ARCH_KIRKWOOD) += \ kirkwood-openrd-client.dtb \ kirkwood-openrd-ultimate.dtb \ kirkwood-pogo_e02.dtb \ + kirkwood-pogoplug-series-4.dtb \ kirkwood-sheevaplug.dtb
dtb-$(CONFIG_MACH_S900) += \ diff --git a/arch/arm/dts/kirkwood-pogoplug-series-4.dts b/arch/arm/dts/kirkwood-pogoplug-series-4.dts new file mode 100644 index 0000000000..5aa4669ae2 --- /dev/null +++ b/arch/arm/dts/kirkwood-pogoplug-series-4.dts @@ -0,0 +1,180 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * kirkwood-pogoplug-series-4.dts - Device tree file for PogoPlug Series 4 + * inspired by the board files made by Kevin Mihelich for ArchLinux, + * and their DTS file. + * + * Copyright (C) 2015 Linus Walleij linus.walleij@linaro.org + */ + +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6192.dtsi" +#include <dt-bindings/input/linux-event-codes.h> + +/ { + model = "Cloud Engines PogoPlug Series 4"; + compatible = "cloudengines,pogoplugv4", "marvell,kirkwood-88f6192", + "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x08000000>; + }; + + chosen { + stdout-path = "uart0:115200n8"; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_button_eject>; + pinctrl-names = "default"; + + eject { + debounce-interval = <50>; + wakeup-source; + linux,code = <KEY_EJECTCD>; + label = "Eject Button"; + gpios = <&gpio0 29 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_led_green &pmx_led_red>; + pinctrl-names = "default"; + + health { + label = "pogoplugv4:green:health"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW>; + default-state = "on"; + }; + fault { + label = "pogoplugv4:red:fault"; + gpios = <&gpio0 24 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&pinctrl { + pmx_sata0: pmx-sata0 { + marvell,pins = "mpp21"; + marvell,function = "sata0"; + }; + + pmx_sata1: pmx-sata1 { + marvell,pins = "mpp20"; + marvell,function = "sata1"; + }; + + pmx_sdio_cd: pmx-sdio-cd { + marvell,pins = "mpp27"; + marvell,function = "gpio"; + }; + + pmx_sdio_wp: pmx-sdio-wp { + marvell,pins = "mpp28"; + marvell,function = "gpio"; + }; + + pmx_button_eject: pmx-button-eject { + marvell,pins = "mpp29"; + marvell,function = "gpio"; + }; + + pmx_led_green: pmx-led-green { + marvell,pins = "mpp22"; + marvell,function = "gpio"; + }; + + pmx_led_red: pmx-led-red { + marvell,pins = "mpp24"; + marvell,function = "gpio"; + }; +}; + +&uart0 { + status = "okay"; +}; + +/* + * This PCIE controller has a USB 3.0 XHCI controller at 1,0 + */ +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; + +&sata { + status = "okay"; + pinctrl-0 = <&pmx_sata0 &pmx_sata1>; + pinctrl-names = "default"; + nr-ports = <1>; +}; + +&sdio { + status = "okay"; + pinctrl-0 = <&pmx_sdio &pmx_sdio_cd &pmx_sdio_wp>; + pinctrl-names = "default"; + cd-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio0 28 GPIO_ACTIVE_HIGH>; +}; + +&nand { + /* 128 MiB of NAND flash */ + chip-delay = <40>; + status = "okay"; + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot"; + reg = <0x00000000 0x200000>; + read-only; + }; + + partition@200000 { + label = "uImage"; + reg = <0x00200000 0x300000>; + }; + + partition@500000 { + label = "uImage2"; + reg = <0x00500000 0x300000>; + }; + + partition@800000 { + label = "failsafe"; + reg = <0x00800000 0x800000>; + }; + + partition@1000000 { + label = "root"; + reg = <0x01000000 0x7000000>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +};
Add board include header and defconfig files for Pogoplug V4
Changes in v2: - Use canonical format for defconfig file
configs/pogo_v4_defconfig | 79 +++++++++++++++++++++++++++++++++++++++ include/configs/pogo_v4.h | 56 +++++++++++++++++++++++++++ 2 files changed, 135 insertions(+) create mode 100644 configs/pogo_v4_defconfig create mode 100644 include/configs/pogo_v4.h
diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig new file mode 100644 index 0000000000..5490067b9e --- /dev/null +++ b/configs/pogo_v4_defconfig @@ -0,0 +1,79 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_DCACHE_OFF=y +CONFIG_ARCH_CPU_INIT=y +CONFIG_SYS_THUMB_BUILD=y +CONFIG_ARCH_KIRKWOOD=y +CONFIG_SYS_KWD_CONFIG="board/cloudengines/pogo_v4/kwbimage.cfg" +CONFIG_SYS_TEXT_BASE=0x600000 +CONFIG_TARGET_POGO_V4=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_ENV_OFFSET=0xC0000 +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-pogoplug-series-4" +CONFIG_IDENT_STRING="\nPogoplug V4" +CONFIG_SYS_LOAD_ADDR=0x800000 +CONFIG_BOOTSTAGE=y +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="setenv bootargs ${bootargs_console}; run bootcmd_usb; bootm 0x00800000 0x01100000 0x2c00000" +CONFIG_USE_PREBOOT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="Pogo_V4> " +CONFIG_CMD_BOOTZ=y +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SATA=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_JFFS2=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" +CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:2M(u-boot),3M(uImage),3M(uImage2),8M(failsafe),112M(root)" +CONFIG_CMD_UBI=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_VERSION_VARIABLE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_DM=y +CONFIG_SATA_MV=y +CONFIG_KIRKWOOD_GPIO=y +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MVEBU_MMC=y +CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_DM_ETH=y +CONFIG_MVGBE=y +CONFIG_MII=y +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_DM_RTC=y +CONFIG_RTC_EMULATION=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_PCI=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_JFFS2_LZO=y +CONFIG_JFFS2_NAND=y diff --git a/include/configs/pogo_v4.h b/include/configs/pogo_v4.h new file mode 100644 index 0000000000..d94d49505a --- /dev/null +++ b/include/configs/pogo_v4.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2014-2022 Tony Dinh mibodhi@gmail.com + * + * Based on + * Copyright (C) 2012 + * David Purdy david.c.purdy@gmail.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + */ + +#ifndef _CONFIG_POGO_V4_H +#define _CONFIG_POGO_V4_H + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Default environment variables + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "dtb_file=/boot/dts/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0"\ + "mtdids=nand0=orion_nand\0"\ + "bootargs_console=console=ttyS0,115200\0" \ + "bootcmd_usb=usb start; load usb 0:1 0x00800000 /boot/uImage; " \ + "load usb 0:1 0x01100000 /boot/uInitrd; " \ + "load usb 0:1 0x2c00000 $dtb_file\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_FEATURE_COMMAND_EDITING /* for netconsole */ +#define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ +#define CONFIG_PHY_BASE_ADR 0 +#endif /* CONFIG_CMD_NET */ + +/* + * SATA Driver configuration + */ +#define CONFIG_SYS_SATA_MAX_DEVICE 1 + +/* + * Support large disk for SATA and USB + */ +#define CONFIG_SYS_64BIT_LBA +#define CONFIG_LBA48 + +#endif /* _CONFIG_POGO_V4_H */
Add Kconfig files for Pogoplug V4 board
Changes in v3: - Migrate symbols from board include header to Kconfig
arch/arm/mach-kirkwood/Kconfig | 6 ++++++ board/cloudengines/pogo_v4/Kconfig | 16 ++++++++++++++++ 2 files changed, 22 insertions(+) create mode 100644 board/cloudengines/pogo_v4/Kconfig
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index c060cc8546..382b836267 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -51,6 +51,11 @@ config TARGET_POGO_E02 select FEROCEON_88FR131 select KW88F6281
+config TARGET_POGO_V4 + bool "Pogoplug V4 Board" + select FEROCEON_88FR131 + select KW88F6192 + config TARGET_DNS325 bool "dns325 Board" select FEROCEON_88FR131 @@ -123,6 +128,7 @@ source "board/Marvell/guruplug/Kconfig" source "board/Marvell/sheevaplug/Kconfig" source "board/buffalo/lsxl/Kconfig" source "board/cloudengines/pogo_e02/Kconfig" +source "board/cloudengines/pogo_v4/Kconfig" source "board/d-link/dns325/Kconfig" source "board/iomega/iconnect/Kconfig" source "board/keymile/Kconfig" diff --git a/board/cloudengines/pogo_v4/Kconfig b/board/cloudengines/pogo_v4/Kconfig new file mode 100644 index 0000000000..db3b76b4d4 --- /dev/null +++ b/board/cloudengines/pogo_v4/Kconfig @@ -0,0 +1,16 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2014-2021 Tony Dinh mibodhi@gmail.com +# +if TARGET_POGO_V4 + +config SYS_BOARD + default "pogo_v4" + +config SYS_VENDOR + default "cloudengines" + +config SYS_CONFIG_NAME + default "pogo_v4" + +endif
Note: currently the fdt_get_phy_addr function in this file is duplicate in this board and many other Kirkwood boards (eg. Sheevaplug, GoFlex Home, etc.). This function is being factored out into common area by another patch. And because it was written for flattree only, the patch is being rewritten to use livetree calls.
Changes in v3: - Squash board file small patches into one patch
Changes in v2: - Move constants to .c file and remove header file
board/cloudengines/pogo_v4/MAINTAINERS | 6 + board/cloudengines/pogo_v4/Makefile | 10 ++ board/cloudengines/pogo_v4/kwbimage.cfg | 148 ++++++++++++++++ board/cloudengines/pogo_v4/pogo_v4.c | 220 ++++++++++++++++++++++++ 4 files changed, 384 insertions(+) create mode 100644 board/cloudengines/pogo_v4/MAINTAINERS create mode 100644 board/cloudengines/pogo_v4/Makefile create mode 100644 board/cloudengines/pogo_v4/kwbimage.cfg create mode 100644 board/cloudengines/pogo_v4/pogo_v4.c
diff --git a/board/cloudengines/pogo_v4/MAINTAINERS b/board/cloudengines/pogo_v4/MAINTAINERS new file mode 100644 index 0000000000..35fd7858b7 --- /dev/null +++ b/board/cloudengines/pogo_v4/MAINTAINERS @@ -0,0 +1,6 @@ +POGO_V4 BOARD +M: Tony Dinh mibodhi@gmail.com +S: Maintained +F: board/cloudengines/pogo_v4/ +F: include/configs/pogo_v4.h +F: configs/pogo_v4_defconfig diff --git a/board/cloudengines/pogo_v4/Makefile b/board/cloudengines/pogo_v4/Makefile new file mode 100644 index 0000000000..511bf5ff7e --- /dev/null +++ b/board/cloudengines/pogo_v4/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2014-2021 Tony Dinh mibodhi@gmail.com +# +# Based on +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# + +obj-y := pogo_v4.o diff --git a/board/cloudengines/pogo_v4/kwbimage.cfg b/board/cloudengines/pogo_v4/kwbimage.cfg new file mode 100644 index 0000000000..f6294fe313 --- /dev/null +++ b/board/cloudengines/pogo_v4/kwbimage.cfg @@ -0,0 +1,148 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2012 +# David Purdy david.c.purdy@gmail.com +# +# Based on Kirkwood support: +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar <prafulla <at> marvell.com> + +# Boot Media configurations (DONE) +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V (SHOULD BE SAME) +DATA 0xffd100e0 0x1b1b1b9b + +#Dram initalization for SINGLE x16 CL=3 @ 200MHz (need CL=3 @ 200MHz?) +DATA 0xffd01400 0x43000618 # DDR Configuration register +# bit13-0: 0x200 (200 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xffd01404 0x34143000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 3=recommended value for CL=3 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 6= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xffd01408 0x11012227 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xffd0140c 0x00000819 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xffd01410 0x00000001 # DDR Address Control (changed to Dockstar vals) +# bit1-0: 00, Cs0width=x16 +# bit3-2: 10, Cs0size=512Mb +# bit5-4: 00, Cs2width=nonexistent +# bit7-6: 00, Cs1size =nonexistent +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xffd01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xffd01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xffd0141c 0x00000632 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 (<===== change to CL=3 ?) +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xffd01420 0x00000040 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xffd01424 0x0000F07F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 0 , no sample stage +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xffd01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xffd0147c 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x07FFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x07, Size (i.e. 128MB) + +DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xffd01494 0x00030000 # DDR ODT Control (Low) (DONE) +# bit3-0: 2, ODT0Rd, MODT[0] asserted during read from DRAM CS1 +# bit7-4: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 +# bit19-16:2, ODT0Wr, MODT[0] asserted during write to DRAM CS1 +# bit23-20:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 + +DATA 0xffd01498 0x00000000 # DDR ODT Control (High) (DONE) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xffd0149c 0x0000e803 # CPU ODT Control (DONE) +DATA 0xffd01480 0x00000001 # DDR Initialization Control (DONE) +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/cloudengines/pogo_v4/pogo_v4.c b/board/cloudengines/pogo_v4/pogo_v4.c new file mode 100644 index 0000000000..c85de0b22e --- /dev/null +++ b/board/cloudengines/pogo_v4/pogo_v4.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2014-2021 Tony Dinh mibodhi@gmail.com + * + * Based on + * Copyright (C) 2012 David Purdy david.c.purdy@gmail.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include <asm/arch/mpp.h> +#include <asm/io.h> +#include <asm/arch/gpio.h> +#include <asm/mach-types.h> +#include <bootstage.h> +#include <command.h> +#include <init.h> +#include <linux/bitops.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* GPIO configuration */ +#define POGO_V4_OE_LOW (~(0)) +#define POGO_V4_OE_HIGH (~(0)) +#define POGO_V4_OE_VAL_LOW BIT(29) +#define POGO_V4_OE_VAL_HIGH 0 + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL BIT(4) +#define MV88E1116_RGMII_RXTM_CTRL BIT(5) + +/* button */ +#define BTN_EJECT 29 + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + mvebu_config_gpio(POGO_V4_OE_VAL_LOW, + POGO_V4_OE_VAL_HIGH, + POGO_V4_OE_LOW, POGO_V4_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, + MPP14_SD_D0, + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_SATA1_ACTn, + MPP21_SATA0_ACTn, + MPP22_GPIO, /* Green LED */ + MPP23_GPIO, + MPP24_GPIO, /* Red LED */ + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, /* Eject button */ + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, + MPP35_GPIO, /* FR6192 has only 36 GPIOs */ + 0 + }; + kirkwood_mpp_conf(kwmpp_config, NULL); + + return 0; +} + +int board_late_init(void) +{ + /* Do late init to ensure successful enumeration of XHCI devices */ + pci_init(); + return 0; +} + +int board_init(void) +{ + /* Boot parameters address */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +int fdt_get_phy_addr(const char *path) +{ + const void *fdt = gd->fdt_blob; + const u32 *reg; + const u32 *val; + int node, phandle, addr; + + /* Find the node by its full path */ + node = fdt_path_offset(fdt, path); + if (node >= 0) { + /* Look up phy-handle */ + val = fdt_getprop(fdt, node, "phy-handle", NULL); + if (!val) { + /* Look up phy (deprecated property for phy handle) */ + val = fdt_getprop(fdt, node, "phy", NULL); + } + if (val) { + phandle = fdt32_to_cpu(*val); + if (!phandle) + return -FDT_ERR_NOTFOUND; + + /* Follow it to its node */ + node = fdt_node_offset_by_phandle(fdt, phandle); + if (node) { + /* Look up reg */ + reg = fdt_getprop(fdt, node, "reg", NULL); + if (reg) { + addr = fdt32_to_cpu(*reg); + return addr; + } + } + } + } + return -FDT_ERR_NOTFOUND; +} + +#if defined(CONFIG_RESET_PHY_R) +/* Configure and initialize PHY */ +void reset_phy(void) +{ + u16 reg; + int phyaddr; + char *name = "ethernet-controller@72000"; + char *eth0_path = "/ocp@f1000000/ethernet-controller@72000"; + + if (miiphy_set_current_dev(name)) + return; + + phyaddr = fdt_get_phy_addr(eth0_path); + if (phyaddr < 0) + return; + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, phyaddr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, phyaddr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, phyaddr); + + printf("88E1116 Initialized on %s\n", name); +} +#endif /* CONFIG_RESET_PHY_R */ + +#if CONFIG_IS_ENABLED(BOOTSTAGE) +#define GREEN_LED BIT(22) +#define RED_LED BIT(24) +#define BOTH_LEDS (GREEN_LED | RED_LED) +#define NEITHER_LED 0 + +static void set_leds(u32 leds, u32 blinking) +{ + struct kwgpio_registers *r; + u32 oe; + u32 bl; + + r = (struct kwgpio_registers *)MVEBU_GPIO0_BASE; + oe = readl(&r->oe) | BOTH_LEDS; + writel(oe & ~leds, &r->oe); /* active low */ + bl = readl(&r->blink_en) & ~BOTH_LEDS; + writel(bl | blinking, &r->blink_en); +} + +void show_boot_progress(int val) +{ + switch (val) { + case BOOTSTAGE_ID_RUN_OS: /* booting Linux */ + set_leds(BOTH_LEDS, NEITHER_LED); + break; + case BOOTSTAGE_ID_NET_ETH_START: /* Ethernet initialization */ + set_leds(GREEN_LED, GREEN_LED); + break; + default: + if (val < 0) /* error */ + set_leds(RED_LED, RED_LED); + break; + } +} +#endif
Changes in v3:
Changes in v2:
- Copyright (C) 2014-2021 Tony Dinh mibodhi@gmail.com
- Based on
- Copyright (C) 2012 David Purdy david.c.purdy@gmail.com
- Based on Kirkwood support:
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- mvebu_config_gpio(POGO_V4_OE_VAL_LOW,
- /* Multi-Purpose Pins Functionality configuration */
- u32 kwmpp_config[] = {
MPP0_NF_IO2,
MPP1_NF_IO3,
MPP2_NF_IO4,
MPP3_NF_IO5,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP7_GPO,
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP12_SD_CLK,
MPP13_SD_CMD,
MPP14_SD_D0,
MPP15_SD_D1,
MPP16_SD_D2,
MPP17_SD_D3,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_SATA1_ACTn,
MPP21_SATA0_ACTn,
MPP23_GPIO,
MPP25_GPIO,
MPP26_GPIO,
MPP27_GPIO,
MPP28_GPIO,
MPP30_GPIO,
MPP31_GPIO,
MPP32_GPIO,
MPP33_GPIO,
MPP34_GPIO,
0
- kirkwood_mpp_conf(kwmpp_config, NULL);
- /* Do late init to ensure successful enumeration of XHCI devices */
- pci_init();
- /* Boot parameters address */
- gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
- const void *fdt = gd->fdt_blob;
- const u32 *reg;
- const u32 *val;
- int node, phandle, addr;
- /* Find the node by its full path */
- node = fdt_path_offset(fdt, path);
- if (node >= 0) {
if (!val) {
if (val) {
if (!phandle)
if (node) {
/* Look up reg */
if (reg) {
return addr;
- return -FDT_ERR_NOTFOUND;
- u16 reg;
- int phyaddr;
- char *name = "ethernet-controller@72000";
- char *eth0_path = "/ocp@f1000000/ethernet-controller@72000";
- if (miiphy_set_current_dev(name))
return;
- phyaddr = fdt_get_phy_addr(eth0_path);
- if (phyaddr < 0)
return;
- miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 2);
- miiphy_read(name, phyaddr, MV88E1116_MAC_CTRL_REG, ®);
- reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL);
- miiphy_write(name, phyaddr, MV88E1116_MAC_CTRL_REG, reg);
- miiphy_write(name, phyaddr, MV88E1116_PGADR_REG, 0);
Please take a look at drivers/net/phy/marvell.c / m88e1310_config(). Here you will find (amongst others):
/* Set RGMII delay */ phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_PAGE, 0x0002); reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL); reg |= 0x0030; phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1310_PHY_RGMII_CTRL, reg);
Can't you use the Marvell PHY driver instead of this ad-hoc implementation? I didn't check the compatibilty of your PHY and this driver though.
Thanks, Stefan
- /* reset the phy */
- miiphy_reset(name, phyaddr);
- printf("88E1116 Initialized on %s\n", name);
- struct kwgpio_registers *r;
- u32 oe;
- u32 bl;
- r = (struct kwgpio_registers *)MVEBU_GPIO0_BASE;
- oe = readl(&r->oe) | BOTH_LEDS;
- writel(oe & ~leds, &r->oe); /* active low */
- bl = readl(&r->blink_en) & ~BOTH_LEDS;
- writel(bl | blinking, &r->blink_en);
- switch (val) {
- case BOOTSTAGE_ID_RUN_OS: /* booting Linux */
break;
- case BOOTSTAGE_ID_NET_ETH_START: /* Ethernet initialization */
break;
- default:
break;
+} +#endif
Viele Grüße, Stefan Roese
Hi Stefan,
Changes in v3:
Changes in v2:
- Based on
MPP0_NF_IO2,
MPP1_NF_IO3,
MPP2_NF_IO4,
MPP3_NF_IO5,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP7_GPO,
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP12_SD_CLK,
MPP13_SD_CMD,
MPP14_SD_D0,
MPP15_SD_D1,
MPP16_SD_D2,
MPP17_SD_D3,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_SATA1_ACTn,
MPP21_SATA0_ACTn,
MPP23_GPIO,
MPP25_GPIO,
MPP26_GPIO,
MPP27_GPIO,
MPP28_GPIO,
MPP30_GPIO,
MPP31_GPIO,
MPP32_GPIO,
MPP33_GPIO,
MPP34_GPIO,
0
pci_init();
const u32 *reg;
const u32 *val;
if (node >= 0) {
if (!val) {
if (val) {
if (!phandle)
if (node) {
/* Look up reg */
if (reg) {
return addr;
u16 reg;
int phyaddr;
return;
if (phyaddr < 0)
return;
Thanks for the advice. Marek had a similar comment regarding this code.
https://lists.denx.de/pipermail/u-boot/2021-December/470019.html
Marek said, "There the m88e1118_config() method already does one thing of what you are doing here: enabling rgmii delays. It also sets LED config, but does not reset the PHY. You can add call to phy_reset() there..."
Currently, all other Kirkwood boards also use this old ad-hoc implementation. And the PHY addr is different in some of these boards. If we add phy_reset() in m88e1118_config(), we would need to make sure all existing boards that use the driver will work... OTOH, perhaps we can keep the phy_reset() call in each Kirkwood board...
Sounds like an approach that will potentially touch a common area, so I think it is best that I will do the modernization and more testing in a separate patch series, after we're done with this Pogo V4 board.
Does that sound reasonable?
Thanks, Tony
Thanks, Stefan
/* reset the phy */
u32 oe;
u32 bl;
switch (val) {
break;
break;
default:
break;
+} +#endif
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
Hi Tony,
On 1/19/22 02:31, Tony Dinh wrote:
<snip>
u16 reg;
int phyaddr;
return;
if (phyaddr < 0)
return;
I should be checked, if this phy_reset() is really necessary. Perhaps by checking in the Linux Kernel code as well and the documentation of the PHY.
Yes, I'm fine with this approach. Let's handle this in some follow-up patches ( from you ;) ).
Thanks, Stefan
fHi Stefan,
On Wed, Jan 19, 2022 at 6:37 AM Stefan Roese sr@denx.de wrote:
Hi Tony,
<snip>
u16 reg;
int phyaddr;
return;
if (phyaddr < 0)
return;
I believe it is necessary. During testing Kirwood boards with Marvel Alaska chip, if the PHY reset call is timed out, we don't have a network. But I will try without phy_reset() using the new driver to see how it behaves.
I will :)
Also, I will resend this series to rearrange the patch order.
Thanks, Tony
Thanks, Stefan
Hi Stefan,
On Wed, Jan 19, 2022 at 3:23 PM Tony Dinh mibodhi@gmail.com wrote:
fHi Stefan,
Hi Tony,
<snip>
u16 reg;
int phyaddr;
return;
if (phyaddr < 0)
return;
Following up on this topic about phy_reset().
I've dug a bit deeper and now see that Kirkwood SoCs also have uclass mvgbe supports in arch/arm/mach-kirkwood/cpu.c. So all we need to do is to let the Kirkwood cpu_eth_init() function start the whole sequence of execution, and the uclass mvgbe would do all the work to bring up the network PHY! So that comes down to defining a function in the board file, similar to the Armada SoC boards.
int board_eth_init(struct bd_info *bis) { return cpu_eth_init(bis); }
Thanks, Tony
Stefan Roese
Tony Dinh
