[U-Boot] [PATCH] imx-common: spl: Allow booting from eMMC when SPL is loaded from non-eMMC device
This patch tries to solve the problem described in following patch: https://patchwork.ozlabs.org/patch/796237/
The main argument against the above code was the potential lack of consistency if we boot SPL from the SD card (and then eMMC may load u-boot proper).
This patch preserves this consistency if spl_boot_device() detects boot from either SD card or eMMC.
It only will change boot device if boot from non-SD/eMMC device is detected - i.e SPI-NOR (as in this case).
Signed-off-by: Lukasz Majewski lukma@denx.de ---
arch/arm/mach-imx/spl.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 6c16872f59..735d9f6261 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -134,7 +134,12 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) /* called from spl_mmc to see type of boot mode for storage (RAW or FAT) */ u32 spl_boot_mode(const u32 boot_device) { - switch (spl_boot_device()) { + u32 spl_bd = spl_boot_device(); + + if (spl_bd != BOOT_DEVICE_MMC1) + spl_bd = boot_device; + + switch (spl_bd) { /* for MMC return either RAW or FAT mode */ case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2:
You should explain what the problem is in the commit message. Random link to a random website which may go away at some point is useless. Having it below --- is fine, but in the commit message it's not.
And from this, I don't really understand what this patch is trying to solve. IMO it'd be better to solve this on a board-level.
- u32 spl_bd = spl_boot_device();
- if (spl_bd != BOOT_DEVICE_MMC1)
- switch (spl_bd) { /* for MMC return either RAW or FAT mode */ case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2:
But have we not board_boot_order() for such as cases ? It is a wek function and you can define it in your board code. Put in mach-imx, it is valid for all boards.
Best regards, Stefano
After a bit of offline discussion with Lukasz, I think I understand what the problem is.
The SPL common code calls spl_boot_device() to determine which boot device to boot from next ; in his case, SPI or eMMC. In case eMMC is selected, the SPL MMC common code then calls spl_boot_mode() (different function than spl_boot_device()) to determine whether the content on SD/eMMC is RAW or on a FS.
The iMX implementation (and layerspace too) does extra stuff in the implementation of spl_boot_mode() by calling spl_boot_device() again, which is wrong.
spl_boot_mode() is only used by spl_mmc.c , so we are certain the system is booting from SD/MMC . By turning this around, if the board code did override the board_boot_order() to load the next payload from SD/MMC/eMMC AND started SPL from non-SD/MMC/eMMC device , calling spl_boot_device() in spl_boot_mode() implementation will return bogus result and the spl_boot_mode() will fail in the default: case.
Thus, the fix here is to do what ie. socfpga does, just discern whether the content on SD/MMC/eMMC is RAW or FS and do not do any extra checks.
By doing so, we can probably even clean this up and have default __weak spl_boot_mode() implementation rather than having a custom copy for each SoC.
Lukasz Majewski
Stefano Babic
