[U-Boot] [PATCH] ARM: uniphier: fix DSPLL init code for LD20 SoC
Signed-off-by: Dai Okamura okamura.dai@socionext.com Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/clk/pll-base-ld20.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/clk/pll-base-ld20.c b/arch/arm/mach-uniphier/clk/pll-base-ld20.c index 697eb7aabf01..3aa42f8bfdcd 100644 --- a/arch/arm/mach-uniphier/clk/pll-base-ld20.c +++ b/arch/arm/mach-uniphier/clk/pll-base-ld20.c @@ -88,7 +88,7 @@ int uniphier_ld20_sscpll_set_regi(unsigned long reg_base, unsigned regi) if (!base) return -ENOMEM;
- tmp = readl(base + 8); /* SSCPLLCTRL */ + tmp = readl(base + 8); /* SSCPLLCTRL3 */ tmp &= ~SC_PLLCTRL3_REGI_MASK; tmp |= regi << SC_PLLCTRL3_REGI_SHIFT; writel(tmp, base + 8); @@ -133,9 +133,9 @@ int uniphier_ld20_dspll_init(unsigned long reg_base) if (!base) return -ENOMEM;
- tmp = readl(base + 8); /* DSPLLCTRL2 */ + tmp = readl(base + 4); /* DSPLLCTRL2 */ tmp |= SC_DSPLLCTRL2_K_LD; - writel(tmp, base + 8); + writel(tmp, base + 4);
iounmap(base);
2017-08-28 21:57 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier. Thanks.
Masahiro Yamada
