[PATCH] Revert "mmc: fsl_esdhc_imx: use VENDORSPEC_FRC_SDCLK_ON to control card clock output"
This reverts commit 63756575b42b8b4fb3f59cbbf0cedf03331bc2d2.
Since this commit a imx6qdl-pico board boots extremely slowly in both SPL as well as U-Boot proper.
Fix this revert for now to avoid such regression.
Signed-off-by: Fabio Estevam festevam@gmail.com --- drivers/mmc/fsl_esdhc_imx.c | 29 ++++++++--------------------- include/fsl_esdhc_imx.h | 2 -- 2 files changed, 8 insertions(+), 23 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index a4675838e58a..b49d5ede2711 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -653,10 +653,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) clk = (pre_div << 8) | (div << 4);
#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); #else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif @@ -668,7 +665,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) pr_warn("fsl_esdhc_imx: Internal clock never stabilised.\n");
#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif @@ -723,14 +720,8 @@ static void esdhc_set_strobe_dll(struct mmc *mmc) struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); struct fsl_esdhc *regs = priv->esdhc_regs; u32 val; - u32 tmp; - int ret;
if (priv->clock > ESDHC_STROBE_DLL_CLK_FREQ) { - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); esdhc_write32(®s->strobe_dllctrl, ESDHC_STROBE_DLL_CTRL_RESET);
/* @@ -748,7 +739,6 @@ static void esdhc_set_strobe_dll(struct mmc *mmc) pr_warn("HS400 strobe DLL status REF not lock!\n"); if (!(val & ESDHC_STROBE_DLL_STS_SLV_LOCK)) pr_warn("HS400 strobe DLL status SLV not lock!\n"); - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); } }
@@ -980,18 +970,14 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) #ifdef MMC_SUPPORTS_TUNING if (mmc->clk_disable) { #ifdef CONFIG_FSL_USDHC - u32 tmp; - - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); - ret = readx_poll_timeout(esdhc_read32, ®s->prsstat, tmp, tmp & PRSSTAT_SDOFF, 100); - if (ret) - pr_warn("fsl_esdhc_imx: Internal clock never gate off.\n"); + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); #else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); #endif } else { #ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_CKEN); #else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif @@ -1067,7 +1053,7 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) #ifndef CONFIG_FSL_USDHC esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN); #else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_HCKEN | VENDORSPEC_IPGEN); #endif
/* Set the initial clock speed */ @@ -1205,7 +1191,8 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, esdhc_write32(®s->autoc12err, 0); esdhc_write32(®s->clktunectrlstatus, 0); #else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_FRC_SDCLK_ON); + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); #endif
if (priv->vs18_enable) diff --git a/include/fsl_esdhc_imx.h b/include/fsl_esdhc_imx.h index b0920344641c..45ed635a77bf 100644 --- a/include/fsl_esdhc_imx.h +++ b/include/fsl_esdhc_imx.h @@ -39,7 +39,6 @@ #define VENDORSPEC_HCKEN 0x00001000 #define VENDORSPEC_IPGEN 0x00000800 #define VENDORSPEC_INIT 0x20007809 -#define VENDORSPEC_FRC_SDCLK_ON 0x00000100
#define IRQSTAT 0x0002e030 #define IRQSTAT_DMAE (0x10000000) @@ -97,7 +96,6 @@ #define PRSSTAT_CINS (0x00010000) #define PRSSTAT_BREN (0x00000800) #define PRSSTAT_BWEN (0x00000400) -#define PRSSTAT_SDOFF (0x00000080) #define PRSSTAT_SDSTB (0X00000008) #define PRSSTAT_DLA (0x00000004) #define PRSSTAT_CICHB (0x00000002)
Fabio Estevam
