[U-Boot] [PATCH v3 0/7] spl: nand: sunxi: implement auto-detection
Hello,
This patch series aims at adding support for NAND auto-detection to the sunxi SPL NAND driver.
As explained in patch 7, this auto-detection is nothing more than a dumb "trial and error" logic, but it allows one to use the same SPL binary for all kind of sunxi boards booting from NAND. Of course, this approach might increase a bit the boot-time, but this is something we could address by adding a "default NAND config", that would be tested before launching the auto-detection procedure.
Now let's detail a bit what's inside this patch-set. Patch 1 is a cleanup removing support for BootROM configs, which in my opinion are not only inefficient but also not reliable (at least the current implementation does not guarantee that you'll be using the correct configuration when reading the NAND).
Piotr, Hans, any comment? Is this a real problem if we get rid of syndrome/BootROM configs? I mean, are you really using this mode? If that's not the case, I'd prefer dropping support for this feature. ITOH, if you really need this mode, then I'd recommend adding Kconfig options to specify the exact config to be used rather than randomly testing configs (see my explanation in patch 1).
Patch 2 is reworking the SYS_NAND_U_BOOT_OFFS Kconfig dependency model to make it usable on all platforms (not only sunxi).
Patch 3 is adding generic support for redundant u-boot images, which is particularly useful on modern NANDs where corruptions is likely to happen. Patch 4 is just getting rid of the open-coded version of redundant u-boot image support in the sunxi NAND driver.
Patch 5 is a simple improvement of the NAND controller status polling loop, which is really important to make the "trial and error" approach efficient (we try to limit the impact on boot-time here). Patch 6 and 7 are implementing the auto-detection logic.
Best Regards,
Boris
Changes since v2: - rework the Kconfig options for SYS_U_BOOT_OFFS and SYS_U_BOOT_REDUND_OFFS
Changes since v1: - added Hans ack - fixed 2 typos in patch 7
Boris Brezillon (7): spl: nand: sunxi: remove support for so-called 'syndrome' mode spl: nand: rework SYS_NAND_U_BOOT_OFFS Kconfig option dependency spl: nand: support redundant u-boot image spl: nand: sunxi: stop guessing the redundant u-boot offset spl: nand: sunxi: rework status polling loop spl: nand: sunxi: split 'load page' and 'read page' logic spl: nand: sunxi: add support for NAND config auto-detection
common/spl/spl_nand.c | 5 + drivers/mtd/nand/Kconfig | 21 +- drivers/mtd/nand/sunxi_nand_spl.c | 480 ++++++++++++++++++++++++-------------- 3 files changed, 332 insertions(+), 174 deletions(-)
The sunxi SPL NAND controller driver supports use 'BootROM'-like configs, that is, configs where the ECC bytes and real data are interleaved in the page instead of putting ECC bytes in the OOB area.
Doing that has several drawbacks: - since you're interleaving data and ECC bytes you can't use the whole page otherwise you might override the bad block marker with non-FF bytes. - to solve the bad block marker problem, the ROM code supports partially using the page, but this introduces a huge penalty both in term of read speed and NAND memory usage. While this is fine for rather small binaries(like the SPL one which is at maximum 24KB large), it becomes non-negligible for the bootloader image (several hundred of KB). - auto-detection of the page size is not reliable (this is in my opinion the biggest problem). If you get the page size wrong, you'll end up reading data at a different offset than what was specified by the caller and the reading may succeed (if valid data were written at this address).
For all those reasons I think it's wiser to completely remove support for 'syndrome' configs. If we ever need to support it again, then I'd recommend specifying all the config parameters through Kconfig options.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Hans de Goede hdegoede@redhat.com --- drivers/mtd/nand/sunxi_nand_spl.c | 56 ++++++++++----------------------------- 1 file changed, 14 insertions(+), 42 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index b0e07aa..1739da2 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -119,9 +119,6 @@ const uint16_t random_seed[128] = { 0x7c57, 0x0fbe, 0x46ce, 0x4939, 0x6b17, 0x37bb, 0x3e91, 0x76db, };
-/* random seed used for syndrome calls */ -const uint16_t random_seed_syndrome = 0x4a80; - #define MAX_RETRIES 10
static int check_value_inner(int offset, int expected_bits, @@ -183,7 +180,7 @@ void nand_init(void) }
static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, - int addr_cycles, uint32_t real_addr, dma_addr_t dst, int syndrome) + int addr_cycles, uint32_t real_addr, dma_addr_t dst) { uint32_t val; int i, ecc_off = 0; @@ -209,17 +206,11 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, page = real_addr / page_size; column = real_addr % page_size;
- if (syndrome) - column += (column / ecc_page_size) * ecc_off; - /* clear ecc status */ writel(0, SUNXI_NFC_BASE + NFC_ECC_ST);
/* Choose correct seed */ - if (syndrome) - rand_seed = random_seed_syndrome; - else - rand_seed = random_seed[page % 128]; + rand_seed = random_seed[page % 128];
writel((rand_seed << 16) | NFC_ECC_RANDOM_EN | NFC_ECC_EN | NFC_ECC_PIPELINE | (ecc_mode << 12), @@ -228,9 +219,8 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, val = readl(SUNXI_NFC_BASE + NFC_CTL); writel(val | NFC_CTL_RAM_METHOD, SUNXI_NFC_BASE + NFC_CTL);
- if (!syndrome) - writel(page_size + (column / ecc_page_size) * ecc_off, - SUNXI_NFC_BASE + NFC_SPARE_AREA); + writel(page_size + (column / ecc_page_size) * ecc_off, + SUNXI_NFC_BASE + NFC_SPARE_AREA);
flush_dcache_range(dst, ALIGN(dst + ecc_page_size, ARCH_DMA_MINALIGN));
@@ -266,7 +256,7 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, writel(NFC_SEND_CMD1 | NFC_SEND_CMD2 | NFC_DATA_TRANS | NFC_PAGE_CMD | NFC_WAIT_FLAG | ((addr_cycles - 1) << NFC_ADDR_NUM_OFFSET) | - NFC_SEND_ADR | NFC_DATA_SWAP_METHOD | (syndrome ? NFC_SEQ : 0), + NFC_SEND_ADR | NFC_DATA_SWAP_METHOD, SUNXI_NFC_BASE + NFC_CMD);
if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_DMA_INT_FLAG, @@ -292,7 +282,7 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, }
static int nand_read_ecc(int page_size, int ecc_strength, int ecc_page_size, - int addr_cycles, uint32_t offs, uint32_t size, void *dest, int syndrome) + int addr_cycles, uint32_t offs, uint32_t size, void *dest) { void *end = dest + size;
@@ -301,16 +291,14 @@ static int nand_read_ecc(int page_size, int ecc_strength, int ecc_page_size,
for ( ;dest < end; dest += ecc_page_size, offs += ecc_page_size) { if (nand_read_page(page_size, ecc_strength, ecc_page_size, - addr_cycles, offs, (dma_addr_t)dest, - syndrome)) + addr_cycles, offs, (dma_addr_t)dest)) return -1; }
return 0; }
-static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest, - int syndrome) +static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest) { const struct { int page_size; @@ -337,7 +325,7 @@ static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest, nand_configs[i].ecc_strength, nand_configs[i].ecc_page_size, nand_configs[i].addr_cycles, - offs, size, dest, syndrome) == 0) { + offs, size, dest) == 0) { debug("success\n"); nand_config = i; return 0; @@ -351,48 +339,32 @@ static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest, nand_configs[nand_config].ecc_strength, nand_configs[nand_config].ecc_page_size, nand_configs[nand_config].addr_cycles, - offs, size, dest, syndrome); + offs, size, dest); }
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dest) { -#if CONFIG_SYS_NAND_U_BOOT_OFFS == CONFIG_SPL_PAD_TO - /* - * u-boot-dtb.bin appended to SPL, use syndrome (like the BROM does) - * and try different erase block sizes to find the backup. - */ - const uint32_t boot_offsets[] = { - 0 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, - 1 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, - 2 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, - 4 * 1024 * 1024 + CONFIG_SYS_NAND_U_BOOT_OFFS, - }; - const int syndrome = 1; -#else /* - * u-boot-dtb.bin on its own partition, do not use syndrome, u-boot - * partition sits after 2 eraseblocks (spl, spl-backup), look for - * backup u-boot 1 erase block further. + * u-boot partition sits after 2 eraseblocks (spl, spl-backup), look + * for backup u-boot 1 erase block further. */ const uint32_t eraseblock_size = CONFIG_SYS_NAND_U_BOOT_OFFS / 2; const uint32_t boot_offsets[] = { CONFIG_SYS_NAND_U_BOOT_OFFS, CONFIG_SYS_NAND_U_BOOT_OFFS + eraseblock_size, }; - const int syndrome = 0; -#endif int i;
if (offs == CONFIG_SYS_NAND_U_BOOT_OFFS) { for (i = 0; i < ARRAY_SIZE(boot_offsets); i++) { if (nand_read_buffer(boot_offsets[i], size, - dest, syndrome) == 0) + dest) == 0) return 0; } return -1; }
- return nand_read_buffer(offs, size, dest, syndrome); + return nand_read_buffer(offs, size, dest); }
void nand_deselect(void)
The SYS_NAND_U_BOOT_OFFS is quite generic, but the Kconfig entry is forced to explicitly depend on platforms that are not already defining it in their include/configs/<board>.h header.
Add the SYS_NAND_U_BOOT_LOCATIONS option, make the SYS_NAND_U_BOOT_OFFS depends on it, remove the dependency on NAND_SUNXI and make it dependent on SPL selection.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Hans de Goede hdegoede@redhat.com --- drivers/mtd/nand/Kconfig | 15 +++++++++++---- 1 file changed, 11 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 2fc73ef..5fe169f 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -99,17 +99,24 @@ config SYS_NAND_BUSWIDTH_16BIT not available while configuring controller. So a static CONFIG_NAND_xx is needed to know the device's bus-width in advance.
-# Enhance depends when converting drivers to Kconfig which use this config +if SPL + +config SYS_NAND_U_BOOT_LOCATIONS + bool "Define U-boot binaries locations in NAND" + help + Enable CONFIG_SYS_NAND_U_BOOT_OFFS though Kconfig. + This option should not be enabled when compiling U-boot for boards + defining CONFIG_SYS_NAND_U_BOOT_OFFS in their include/configs/<board>.h + file. + config SYS_NAND_U_BOOT_OFFS hex "Location in NAND to read U-Boot from" default 0x8000 if NAND_SUNXI - depends on NAND_SUNXI + depends on SYS_NAND_U_BOOT_LOCATIONS help Set the offset from the start of the nand where u-boot should be loaded from.
-if SPL - config SPL_NAND_DENALI bool "Support Denali NAND controller for SPL" help
On modern NAND it's more than recommended to have a backup copy of the u-boot binary to recover from corruption: bitflips are quite common on MLC NANDs, and the read-disturbance will corrupt your u-boot partitition more quickly than what you would see on an SLC NAND.
Add an extra Kconfig option to specify the offset of the redundant u-boot image.
# Conflicts: # common/spl/spl_nand.c # drivers/mtd/nand/Kconfig --- common/spl/spl_nand.c | 5 +++++ drivers/mtd/nand/Kconfig | 8 ++++++++ 2 files changed, 13 insertions(+)
diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index bbd9546..d8c5b9e 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -107,6 +107,11 @@ int spl_nand_load_image(void) #endif /* Load u-boot */ err = spl_nand_load_element(CONFIG_SYS_NAND_U_BOOT_OFFS, header); +#if CONFIG_SYS_NAND_U_BOOT_OFFS != CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND + if (err) + err = spl_nand_load_element(CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND, + header); +#endif nand_deselect(); return err; } diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 5fe169f..8c46a2f 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -117,6 +117,14 @@ config SYS_NAND_U_BOOT_OFFS Set the offset from the start of the nand where u-boot should be loaded from.
+config SYS_NAND_U_BOOT_OFFS_REDUND + hex "Location in NAND to read U-Boot from" + default SYS_NAND_U_BOOT_OFFS + depends on SYS_NAND_U_BOOT_LOCATIONS + help + Set the offset from the start of the nand where the redundant u-boot + should be loaded from. + config SPL_NAND_DENALI bool "Support Denali NAND controller for SPL" help
- if (err)
header);
- hex "Location in NAND to read U-Boot from"
- default SYS_NAND_U_BOOT_OFFS
- depends on SYS_NAND_U_BOOT_LOCATIONS
- help
- Set the offset from the start of the nand where the redundant u-boot
- should be loaded from.
I'm adding the below ifdef while applying, so that the build doesn't break on targets that don't define CONFIG_SYS_NAND_U_BOOT_LOCATIONS.
diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 952f644..0e35e0f 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -134,11 +134,13 @@ int spl_nand_load_image(void) #endif /* Load u-boot */ err = spl_nand_load_element(CONFIG_SYS_NAND_U_BOOT_OFFS, header); +#ifdef CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND #if CONFIG_SYS_NAND_U_BOOT_OFFS != CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND if (err) err = spl_nand_load_element(CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND, header); #endif +#endif nand_deselect(); return err; }
-Scott
- if (err)
header);
- help
Oops. I previously had
#ifndef CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND #define CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND CONFIG_SYS_NAND_U_BOOT_OFFS #endif
at the beginning of the file, but I removed it when switching to the approach you suggested.
Thanks for fixing that.
Regards,
Boris
-Scott
Use CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND value instead of trying to guess where the redundant u-boot image is based on simple (and most of the time erroneous) heuristics.
# Conflicts: # drivers/mtd/nand/sunxi_nand_spl.c --- drivers/mtd/nand/sunxi_nand_spl.c | 20 -------------------- 1 file changed, 20 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index 1739da2..13e6eab 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -344,26 +344,6 @@ static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest)
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dest) { - /* - * u-boot partition sits after 2 eraseblocks (spl, spl-backup), look - * for backup u-boot 1 erase block further. - */ - const uint32_t eraseblock_size = CONFIG_SYS_NAND_U_BOOT_OFFS / 2; - const uint32_t boot_offsets[] = { - CONFIG_SYS_NAND_U_BOOT_OFFS, - CONFIG_SYS_NAND_U_BOOT_OFFS + eraseblock_size, - }; - int i; - - if (offs == CONFIG_SYS_NAND_U_BOOT_OFFS) { - for (i = 0; i < ARRAY_SIZE(boot_offsets); i++) { - if (nand_read_buffer(boot_offsets[i], size, - dest) == 0) - return 0; - } - return -1; - } - return nand_read_buffer(offs, size, dest); }
check_value_xxx() helpers are using a 1ms delay between each test, which can be quite long for some operations (like a page read on an SLC NAND). Since we don't have anything to do but to poll this register, reduce the delay between each test to 1us.
While we're at it, rename the max_number_of_retries parameters and the MAX_RETRIES macro into timeout_us and DEFAULT_TIMEOUT_US to reflect that we're actually waiting a given amount of time and not only a number of retries.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Hans de Goede hdegoede@redhat.com --- drivers/mtd/nand/sunxi_nand_spl.c | 29 +++++++++++++---------------- 1 file changed, 13 insertions(+), 16 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index 13e6eab..55b3c8a 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -119,35 +119,31 @@ const uint16_t random_seed[128] = { 0x7c57, 0x0fbe, 0x46ce, 0x4939, 0x6b17, 0x37bb, 0x3e91, 0x76db, };
-#define MAX_RETRIES 10 +#define DEFAULT_TIMEOUT_US 100000
static int check_value_inner(int offset, int expected_bits, - int max_number_of_retries, int negation) + int timeout_us, int negation) { - int retries = 0; do { int val = readl(offset) & expected_bits; if (negation ? !val : val) return 1; - mdelay(1); - retries++; - } while (retries < max_number_of_retries); + udelay(1); + } while (--timeout_us);
return 0; }
static inline int check_value(int offset, int expected_bits, - int max_number_of_retries) + int timeout_us) { - return check_value_inner(offset, expected_bits, - max_number_of_retries, 0); + return check_value_inner(offset, expected_bits, timeout_us, 0); }
static inline int check_value_negated(int offset, int unexpected_bits, - int max_number_of_retries) + int timeout_us) { - return check_value_inner(offset, unexpected_bits, - max_number_of_retries, 1); + return check_value_inner(offset, unexpected_bits, timeout_us, 1); }
void nand_init(void) @@ -162,7 +158,7 @@ void nand_init(void) SUNXI_NFC_BASE + NFC_CTL);
if (!check_value_negated(SUNXI_NFC_BASE + NFC_CTL, - NFC_CTL_RESET, MAX_RETRIES)) { + NFC_CTL_RESET, DEFAULT_TIMEOUT_US)) { printf("Couldn't initialize nand\n"); }
@@ -172,7 +168,7 @@ void nand_init(void) SUNXI_NFC_BASE + NFC_CMD);
if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_CMD_INT_FLAG, - MAX_RETRIES)) { + DEFAULT_TIMEOUT_US)) { printf("Error timeout waiting for nand reset\n"); return; } @@ -260,14 +256,15 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, SUNXI_NFC_BASE + NFC_CMD);
if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_DMA_INT_FLAG, - MAX_RETRIES)) { + DEFAULT_TIMEOUT_US)) { printf("Error while initializing dma interrupt\n"); return -1; } writel(NFC_ST_DMA_INT_FLAG, SUNXI_NFC_BASE + NFC_ST);
if (!check_value_negated(SUNXI_DMA_BASE + SUNXI_DMA_CFG_REG0, - SUNXI_DMA_DDMA_CFG_REG_LOADING, MAX_RETRIES)) { + SUNXI_DMA_DDMA_CFG_REG_LOADING, + DEFAULT_TIMEOUT_US)) { printf("Error while waiting for dma transfer to finish\n"); return -1; }
Split the 'load page' and 'read page' logic in 2 different functions so we can later load the page and test different ECC configs without the penalty of reloading the same page in the NAND cache.
We also move common setup to a dedicated function (nand_apply_config()) to avoid rewriting the same values in NFC registers each time we read a page.
These new functions are passed a pointer to an nfc_config struct to limit the number of parameters.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Hans de Goede hdegoede@redhat.com --- drivers/mtd/nand/sunxi_nand_spl.c | 185 +++++++++++++++++++++++--------------- 1 file changed, 114 insertions(+), 71 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index 55b3c8a..b43f2af 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -66,6 +66,8 @@ #define NFC_ROW_AUTO_INC (1 << 27) #define NFC_SEND_CMD3 (1 << 28) #define NFC_SEND_CMD4 (1 << 29) +#define NFC_RAW_CMD (0 << 30) +#define NFC_PAGE_CMD (2 << 30)
#define NFC_ST_CMD_INT_FLAG (1 << 1) #define NFC_ST_DMA_INT_FLAG (1 << 2) @@ -78,9 +80,6 @@ #define NFC_CMD_RNDOUT 0x05 #define NFC_CMD_READSTART 0x30
- -#define NFC_PAGE_CMD (2 << 30) - #define SUNXI_DMA_CFG_REG0 0x300 #define SUNXI_DMA_SRC_START_ADDR_REG0 0x304 #define SUNXI_DMA_DEST_START_ADDRR_REG0 0x308 @@ -97,6 +96,15 @@ #define SUNXI_DMA_DDMA_PARA_REG_SRC_WAIT_CYC (0x0F << 0) #define SUNXI_DMA_DDMA_PARA_REG_SRC_BLK_SIZE (0x7F << 8)
+struct nfc_config { + int page_size; + int ecc_strength; + int ecc_size; + int addr_cycles; + int nseeds; + bool randomize; +}; + /* minimal "boot0" style NAND support for Allwinner A20 */
/* random seed used by linux */ @@ -175,50 +183,70 @@ void nand_init(void) writel(NFC_ST_CMD_INT_FLAG, SUNXI_NFC_BASE + NFC_ST); }
-static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, - int addr_cycles, uint32_t real_addr, dma_addr_t dst) +static void nand_apply_config(const struct nfc_config *conf) { - uint32_t val; - int i, ecc_off = 0; - uint16_t ecc_mode = 0; - uint16_t rand_seed; - uint32_t page; - uint16_t column; - static const u8 strengths[] = { 16, 24, 28, 32, 40, 48, 56, 60, 64 }; + u32 val;
- for (i = 0; i < ARRAY_SIZE(strengths); i++) { - if (ecc_strength == strengths[i]) { - ecc_mode = i; - break; - } + val = readl(SUNXI_NFC_BASE + NFC_CTL); + val &= ~NFC_CTL_PAGE_SIZE_MASK; + writel(val | NFC_CTL_RAM_METHOD | NFC_CTL_PAGE_SIZE(conf->page_size), + SUNXI_NFC_BASE + NFC_CTL); + writel(conf->ecc_size, SUNXI_NFC_BASE + NFC_CNT); + writel(conf->page_size, SUNXI_NFC_BASE + NFC_SPARE_AREA); +} + +static int nand_load_page(const struct nfc_config *conf, u32 offs) +{ + int page = offs / conf->page_size; + + writel((NFC_CMD_RNDOUTSTART << NFC_RANDOM_READ_CMD1_OFFSET) | + (NFC_CMD_RNDOUT << NFC_RANDOM_READ_CMD0_OFFSET) | + (NFC_CMD_READSTART << NFC_READ_CMD_OFFSET), + SUNXI_NFC_BASE + NFC_RCMD_SET); + writel(((page & 0xFFFF) << 16), SUNXI_NFC_BASE + NFC_ADDR_LOW); + writel((page >> 16) & 0xFF, SUNXI_NFC_BASE + NFC_ADDR_HIGH); + writel(NFC_ST_CMD_INT_FLAG, SUNXI_NFC_BASE + NFC_ST); + writel(NFC_SEND_CMD1 | NFC_SEND_CMD2 | NFC_RAW_CMD | NFC_WAIT_FLAG | + ((conf->addr_cycles - 1) << NFC_ADDR_NUM_OFFSET) | NFC_SEND_ADR, + SUNXI_NFC_BASE + NFC_CMD); + + if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_CMD_INT_FLAG, + DEFAULT_TIMEOUT_US)) { + printf("Error while initializing dma interrupt\n"); + return -EIO; }
- /* HW ECC always request ECC bytes for 1024 bytes blocks */ - ecc_off = DIV_ROUND_UP(ecc_strength * fls(8 * 1024), 8); - /* HW ECC always work with even numbers of ECC bytes */ - ecc_off += (ecc_off & 1); - ecc_off += 4; /* prepad */ + return 0; +} + +static int nand_read_page(const struct nfc_config *conf, u32 offs, + void *dest, int len) +{ + dma_addr_t dst = (dma_addr_t)dest; + int nsectors = len / conf->ecc_size; + u16 rand_seed; + u32 val; + int page; + + page = offs / conf->page_size;
- page = real_addr / page_size; - column = real_addr % page_size; + if (offs % conf->page_size || len % conf->ecc_size || + len > conf->page_size || len < 0) + return -EINVAL;
/* Choose correct seed */ - rand_seed = random_seed[page % 128]; + rand_seed = random_seed[page % conf->nseeds];
- writel((rand_seed << 16) | NFC_ECC_RANDOM_EN | NFC_ECC_EN - | NFC_ECC_PIPELINE | (ecc_mode << 12), + writel((rand_seed << 16) | (conf->ecc_strength << 12) | + (conf->randomize ? NFC_ECC_RANDOM_EN : 0) | + (conf->ecc_size == 512 ? NFC_ECC_BLOCK_SIZE : 0) | + NFC_ECC_EN | NFC_ECC_PIPELINE | NFC_ECC_EXCEPTION, SUNXI_NFC_BASE + NFC_ECC_CTL);
- val = readl(SUNXI_NFC_BASE + NFC_CTL); - writel(val | NFC_CTL_RAM_METHOD, SUNXI_NFC_BASE + NFC_CTL); - - writel(page_size + (column / ecc_page_size) * ecc_off, - SUNXI_NFC_BASE + NFC_SPARE_AREA); - - flush_dcache_range(dst, ALIGN(dst + ecc_page_size, ARCH_DMA_MINALIGN)); + flush_dcache_range(dst, ALIGN(dst + conf->ecc_size, ARCH_DMA_MINALIGN));
/* SUNXI_DMA */ writel(0x0, SUNXI_DMA_BASE + SUNXI_DMA_CFG_REG0); /* clr dma cmd */ @@ -227,38 +255,27 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, SUNXI_DMA_BASE + SUNXI_DMA_SRC_START_ADDR_REG0); /* read to RAM */ writel(dst, SUNXI_DMA_BASE + SUNXI_DMA_DEST_START_ADDRR_REG0); - writel(SUNXI_DMA_DDMA_PARA_REG_SRC_WAIT_CYC - | SUNXI_DMA_DDMA_PARA_REG_SRC_BLK_SIZE, - SUNXI_DMA_BASE + SUNXI_DMA_DDMA_PARA_REG0); - writel(ecc_page_size, - SUNXI_DMA_BASE + SUNXI_DMA_DDMA_BC_REG0); /* 1kB */ - writel(SUNXI_DMA_DDMA_CFG_REG_LOADING - | SUNXI_DMA_DDMA_CFG_REG_DMA_DEST_DATA_WIDTH_32 - | SUNXI_DMA_DDMA_CFG_REG_DDMA_DST_DRQ_TYPE_DRAM - | SUNXI_DMA_DDMA_CFG_REG_DMA_SRC_DATA_WIDTH_32 - | SUNXI_DMA_DDMA_CFG_REG_DMA_SRC_ADDR_MODE_IO - | SUNXI_DMA_DDMA_CFG_REG_DDMA_SRC_DRQ_TYPE_NFC, - SUNXI_DMA_BASE + SUNXI_DMA_CFG_REG0); - - writel((NFC_CMD_RNDOUTSTART << NFC_RANDOM_READ_CMD1_OFFSET) - | (NFC_CMD_RNDOUT << NFC_RANDOM_READ_CMD0_OFFSET) - | (NFC_CMD_READSTART | NFC_READ_CMD_OFFSET), SUNXI_NFC_BASE - + NFC_RCMD_SET); - writel(1, SUNXI_NFC_BASE + NFC_SECTOR_NUM); - writel(((page & 0xFFFF) << 16) | column, - SUNXI_NFC_BASE + NFC_ADDR_LOW); - writel((page >> 16) & 0xFF, SUNXI_NFC_BASE + NFC_ADDR_HIGH); + writel(SUNXI_DMA_DDMA_PARA_REG_SRC_WAIT_CYC | + SUNXI_DMA_DDMA_PARA_REG_SRC_BLK_SIZE, + SUNXI_DMA_BASE + SUNXI_DMA_DDMA_PARA_REG0); + writel(len, SUNXI_DMA_BASE + SUNXI_DMA_DDMA_BC_REG0); + writel(SUNXI_DMA_DDMA_CFG_REG_LOADING | + SUNXI_DMA_DDMA_CFG_REG_DMA_DEST_DATA_WIDTH_32 | + SUNXI_DMA_DDMA_CFG_REG_DDMA_DST_DRQ_TYPE_DRAM | + SUNXI_DMA_DDMA_CFG_REG_DMA_SRC_DATA_WIDTH_32 | + SUNXI_DMA_DDMA_CFG_REG_DMA_SRC_ADDR_MODE_IO | + SUNXI_DMA_DDMA_CFG_REG_DDMA_SRC_DRQ_TYPE_NFC, + SUNXI_DMA_BASE + SUNXI_DMA_CFG_REG0); + + writel(nsectors, SUNXI_NFC_BASE + NFC_SECTOR_NUM); writel(NFC_ST_DMA_INT_FLAG, SUNXI_NFC_BASE + NFC_ST); - writel(NFC_SEND_CMD1 | NFC_SEND_CMD2 | NFC_DATA_TRANS | - NFC_PAGE_CMD | NFC_WAIT_FLAG | - ((addr_cycles - 1) << NFC_ADDR_NUM_OFFSET) | - NFC_SEND_ADR | NFC_DATA_SWAP_METHOD, - SUNXI_NFC_BASE + NFC_CMD); + writel(NFC_DATA_TRANS | NFC_PAGE_CMD | NFC_DATA_SWAP_METHOD, + SUNXI_NFC_BASE + NFC_CMD);
if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_DMA_INT_FLAG, DEFAULT_TIMEOUT_US)) { printf("Error while initializing dma interrupt\n"); - return -1; + return -EIO; } writel(NFC_ST_DMA_INT_FLAG, SUNXI_NFC_BASE + NFC_ST);
@@ -266,29 +283,55 @@ static int nand_read_page(int page_size, int ecc_strength, int ecc_page_size, SUNXI_DMA_DDMA_CFG_REG_LOADING, DEFAULT_TIMEOUT_US)) { printf("Error while waiting for dma transfer to finish\n"); - return -1; + return -EIO; }
invalidate_dcache_range(dst, - ALIGN(dst + ecc_page_size, ARCH_DMA_MINALIGN)); + ALIGN(dst + conf->ecc_size, ARCH_DMA_MINALIGN));
- if (readl(SUNXI_NFC_BASE + NFC_ECC_ST)) - return -1; + val = readl(SUNXI_NFC_BASE + NFC_ECC_ST);
- return 0; + /* ECC error detected. */ + if (val & 0xffff) + return -EIO; + + /* + * Return 1 if the page is empty. + * We consider the page as empty if the first ECC block is marked + * empty. + */ + return (val & 0x10000) ? 1 : 0; }
static int nand_read_ecc(int page_size, int ecc_strength, int ecc_page_size, int addr_cycles, uint32_t offs, uint32_t size, void *dest) { void *end = dest + size; + static const u8 strengths[] = { 16, 24, 28, 32, 40, 48, 56, 60, 64 }; + struct nfc_config conf = { + .page_size = page_size, + .ecc_size = ecc_page_size, + .addr_cycles = addr_cycles, + .nseeds = ARRAY_SIZE(random_seed), + .randomize = true, + }; + int i;
- clrsetbits_le32(SUNXI_NFC_BASE + NFC_CTL, NFC_CTL_PAGE_SIZE_MASK, - NFC_CTL_PAGE_SIZE(page_size)); + for (i = 0; i < ARRAY_SIZE(strengths); i++) { + if (ecc_strength == strengths[i]) { + conf.ecc_strength = i; + break; + } + } + + + nand_apply_config(&conf); + + for ( ;dest < end; dest += ecc_page_size, offs += page_size) { + if (nand_load_page(&conf, offs)) + return -1;
- for ( ;dest < end; dest += ecc_page_size, offs += ecc_page_size) { - if (nand_read_page(page_size, ecc_strength, ecc_page_size, - addr_cycles, offs, (dma_addr_t)dest)) + if (nand_read_page(&conf, offs, dest, page_size)) return -1; }
NAND chips are supposed to expose their capabilities through advanced mechanisms like READID, ONFI or JEDEC parameter tables. While those methods are appropriate for the bootloader itself, it's way to complicated and takes too much space to fit in the SPL.
Replace those mechanisms by a dumb 'trial and error' mechanism.
With this new approach we can get rid of the fixed config list that was used in the sunxi NAND SPL driver.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Hans de Goede hdegoede@redhat.com --- Changes since v1: - fix the nand_max_ecc_strength() --- drivers/mtd/nand/sunxi_nand_spl.c | 262 +++++++++++++++++++++++++++++--------- 1 file changed, 204 insertions(+), 58 deletions(-)
diff --git a/drivers/mtd/nand/sunxi_nand_spl.c b/drivers/mtd/nand/sunxi_nand_spl.c index b43f2af..1ef7366 100644 --- a/drivers/mtd/nand/sunxi_nand_spl.c +++ b/drivers/mtd/nand/sunxi_nand_spl.c @@ -103,6 +103,7 @@ struct nfc_config { int addr_cycles; int nseeds; bool randomize; + bool valid; };
/* minimal "boot0" style NAND support for Allwinner A20 */ @@ -219,6 +220,26 @@ static int nand_load_page(const struct nfc_config *conf, u32 offs) return 0; }
+static int nand_reset_column(void) +{ + writel((NFC_CMD_RNDOUTSTART << NFC_RANDOM_READ_CMD1_OFFSET) | + (NFC_CMD_RNDOUT << NFC_RANDOM_READ_CMD0_OFFSET) | + (NFC_CMD_RNDOUTSTART << NFC_READ_CMD_OFFSET), + SUNXI_NFC_BASE + NFC_RCMD_SET); + writel(0, SUNXI_NFC_BASE + NFC_ADDR_LOW); + writel(NFC_SEND_CMD1 | NFC_SEND_CMD2 | NFC_RAW_CMD | + (1 << NFC_ADDR_NUM_OFFSET) | NFC_SEND_ADR | NFC_CMD_RNDOUT, + SUNXI_NFC_BASE + NFC_CMD); + + if (!check_value(SUNXI_NFC_BASE + NFC_ST, NFC_ST_CMD_INT_FLAG, + DEFAULT_TIMEOUT_US)) { + printf("Error while initializing dma interrupt\n"); + return -1; + } + + return 0; +} + static int nand_read_page(const struct nfc_config *conf, u32 offs, void *dest, int len) { @@ -303,88 +324,213 @@ static int nand_read_page(const struct nfc_config *conf, u32 offs, return (val & 0x10000) ? 1 : 0; }
-static int nand_read_ecc(int page_size, int ecc_strength, int ecc_page_size, - int addr_cycles, uint32_t offs, uint32_t size, void *dest) +static int nand_max_ecc_strength(struct nfc_config *conf) { - void *end = dest + size; - static const u8 strengths[] = { 16, 24, 28, 32, 40, 48, 56, 60, 64 }; - struct nfc_config conf = { - .page_size = page_size, - .ecc_size = ecc_page_size, - .addr_cycles = addr_cycles, - .nseeds = ARRAY_SIZE(random_seed), - .randomize = true, - }; + static const int ecc_bytes[] = { 32, 46, 54, 60, 74, 88, 102, 110, 116 }; + int max_oobsize, max_ecc_bytes; + int nsectors = conf->page_size / conf->ecc_size; int i;
- for (i = 0; i < ARRAY_SIZE(strengths); i++) { - if (ecc_strength == strengths[i]) { - conf.ecc_strength = i; + /* + * ECC strength is limited by the size of the OOB area which is + * correlated with the page size. + */ + switch (conf->page_size) { + case 2048: + max_oobsize = 64; + break; + case 4096: + max_oobsize = 256; + break; + case 8192: + max_oobsize = 640; + break; + case 16384: + max_oobsize = 1664; + break; + default: + return -EINVAL; + } + + max_ecc_bytes = max_oobsize / nsectors; + + for (i = 0; i < ARRAY_SIZE(ecc_bytes); i++) { + if (ecc_bytes[i] > max_ecc_bytes) break; - } }
+ if (!i) + return -EINVAL;
- nand_apply_config(&conf); + return i - 1; +}
- for ( ;dest < end; dest += ecc_page_size, offs += page_size) { - if (nand_load_page(&conf, offs)) - return -1; +static int nand_detect_ecc_config(struct nfc_config *conf, u32 offs, + void *dest) +{ + /* NAND with pages > 4k will likely require 1k sector size. */ + int min_ecc_size = conf->page_size > 4096 ? 1024 : 512; + int page = offs / conf->page_size; + int ret;
- if (nand_read_page(&conf, offs, dest, page_size)) - return -1; + /* + * In most cases, 1k sectors are preferred over 512b ones, start + * testing this config first. + */ + for (conf->ecc_size = 1024; conf->ecc_size >= min_ecc_size; + conf->ecc_size >>= 1) { + int max_ecc_strength = nand_max_ecc_strength(conf); + + nand_apply_config(conf); + + /* + * We are starting from the maximum ECC strength because + * most of the time NAND vendors provide an OOB area that + * barely meets the ECC requirements. + */ + for (conf->ecc_strength = max_ecc_strength; + conf->ecc_strength >= 0; + conf->ecc_strength--) { + conf->randomize = false; + if (nand_reset_column()) + return -EIO; + + /* + * Only read the first sector to speedup detection. + */ + ret = nand_read_page(conf, offs, dest, conf->ecc_size); + if (!ret) { + return 0; + } else if (ret > 0) { + /* + * If page is empty we can't deduce anything + * about the ECC config => stop the detection. + */ + return -EINVAL; + } + + conf->randomize = true; + conf->nseeds = ARRAY_SIZE(random_seed); + do { + if (nand_reset_column()) + return -EIO; + + if (!nand_read_page(conf, offs, dest, + conf->ecc_size)) + return 0; + + /* + * Find the next ->nseeds value that would + * change the randomizer seed for the page + * we're trying to read. + */ + while (conf->nseeds >= 16) { + int seed = page % conf->nseeds; + + conf->nseeds >>= 1; + if (seed != page % conf->nseeds) + break; + } + } while (conf->nseeds >= 16); + } }
- return 0; + return -EINVAL; }
-static int nand_read_buffer(uint32_t offs, unsigned int size, void *dest) +static int nand_detect_config(struct nfc_config *conf, u32 offs, void *dest) { - const struct { - int page_size; - int ecc_strength; - int ecc_page_size; - int addr_cycles; - } nand_configs[] = { - { 8192, 40, 1024, 5 }, - { 16384, 56, 1024, 5 }, - { 8192, 24, 1024, 5 }, - { 4096, 24, 1024, 5 }, - }; - static int nand_config = -1; - int i; + if (conf->valid) + return 0;
- if (nand_config == -1) { - for (i = 0; i < ARRAY_SIZE(nand_configs); i++) { - debug("nand: trying page %d ecc %d / %d addr %d: ", - nand_configs[i].page_size, - nand_configs[i].ecc_strength, - nand_configs[i].ecc_page_size, - nand_configs[i].addr_cycles); - if (nand_read_ecc(nand_configs[i].page_size, - nand_configs[i].ecc_strength, - nand_configs[i].ecc_page_size, - nand_configs[i].addr_cycles, - offs, size, dest) == 0) { - debug("success\n"); - nand_config = i; + /* + * Modern NANDs are more likely than legacy ones, so we start testing + * with 5 address cycles. + */ + for (conf->addr_cycles = 5; + conf->addr_cycles >= 4; + conf->addr_cycles--) { + int max_page_size = conf->addr_cycles == 4 ? 2048 : 16384; + + /* + * Ignoring 1k pages cause I'm not even sure this case exist + * in the real world. + */ + for (conf->page_size = 2048; conf->page_size <= max_page_size; + conf->page_size <<= 1) { + if (nand_load_page(conf, offs)) + return -1; + + if (!nand_detect_ecc_config(conf, offs, dest)) { + conf->valid = true; return 0; } - debug("failed\n"); } - return -1; }
- return nand_read_ecc(nand_configs[nand_config].page_size, - nand_configs[nand_config].ecc_strength, - nand_configs[nand_config].ecc_page_size, - nand_configs[nand_config].addr_cycles, - offs, size, dest); + return -EINVAL; +} + +static int nand_read_buffer(struct nfc_config *conf, uint32_t offs, + unsigned int size, void *dest) +{ + int first_seed, page, ret; + + size = ALIGN(size, conf->page_size); + page = offs / conf->page_size; + first_seed = page % conf->nseeds; + + for (; size; size -= conf->page_size) { + if (nand_load_page(conf, offs)) + return -1; + + ret = nand_read_page(conf, offs, dest, conf->page_size); + /* + * The ->nseeds value should be equal to the number of pages + * in an eraseblock. Since we don't know this information in + * advance we might have picked a wrong value. + */ + if (ret < 0 && conf->randomize) { + int cur_seed = page % conf->nseeds; + + /* + * We already tried all the seed values => we are + * facing a real corruption. + */ + if (cur_seed < first_seed) + return -EIO; + + /* Try to adjust ->nseeds and read the page again... */ + conf->nseeds = cur_seed; + + if (nand_reset_column()) + return -EIO; + + /* ... it still fails => it's a real corruption. */ + if (nand_read_page(conf, offs, dest, conf->page_size)) + return -EIO; + } else if (ret && conf->randomize) { + memset(dest, 0xff, conf->page_size); + } + + page++; + offs += conf->page_size; + dest += conf->page_size; + } + + return 0; }
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dest) { - return nand_read_buffer(offs, size, dest); + static struct nfc_config conf = { }; + int ret; + + ret = nand_detect_config(&conf, offs, dest); + if (ret) + return ret; + + return nand_read_buffer(&conf, offs, size, dest); }
On Mon, 6 Jun 2016 10:16:55 +0200 Boris Brezillon boris.brezillon@free-electrons.com wrote:
Hello,
Scott, can you have a look at this version and let me know if this is what you had in mind for the Kconfig options?
Best Regards,
Boris
Changes since v2:
Changes since v1:
- added Hans ack
Boris Brezillon
Scott Wood
