[PATCH 1/1] efi_loader: select GPT partition support
The UEFI specification requires support for GPT partition tables. The device path node of GPT partition uses the partition UUID.
Let CONFIG_EFI_LOADER select the necessary GPT related configuration settings.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 156b391521..c4741ffec1 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -12,6 +12,9 @@ config EFI_LOADER depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 select LIB_UUID + select PARTITIONS + select EFI_PARTITION + select PARTITION_UUIDS select HAVE_BLOCK_DEVICE select REGEX imply CFB_CONSOLE_ANSI -- 2.32.0
