[U-Boot] [PATCH] ARM: Respect CONFIG_SPL_STACK define in lowlevel_init.S
The SPL and U-Boot proper may use different initial stack locations, which are configured via CONFIG_SPL_STACK and CONFIG_SYS_INIT_SP_ADDR defines. The lowlevel_init.S code needs to handle this in the same way as crt0.S
Without this fix, setting the U-Boot stack location to some place, which is not safely accessible by the SPL (such as the DRAM), causes a very early SPL deadlock.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com --- arch/arm/cpu/armv7/lowlevel_init.S | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv7/lowlevel_init.S b/arch/arm/cpu/armv7/lowlevel_init.S index 1872c57..658934d 100644 --- a/arch/arm/cpu/armv7/lowlevel_init.S +++ b/arch/arm/cpu/armv7/lowlevel_init.S @@ -19,7 +19,11 @@ ENTRY(lowlevel_init) /* * Setup a temporary stack. Global data is not available yet. */ +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) + ldr sp, =CONFIG_SPL_STACK +#else ldr sp, =CONFIG_SYS_INIT_SP_ADDR +#endif bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ #ifdef CONFIG_SPL_DM mov r9, #0
On 4 September 2016 at 21:36, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
Siarhei Siamashka
