AT91 - SAMA5D27 adding a new board - common initialisation code and file names
I'm in the process of adding support to U-Boot for an AT91 SAMA5D27 based board. There may be a USB port configuration change pending, but otherwise it's functionally complete.
The design is quite similar to the Microchip SAMA5D2 Xplained Board, to the extent that I have only 6 lines of code changes out of the ~180 lines of (non-comment) code in board/atmel/sama5d2_xplained/sama5d2_xplained.c
In particular the clocks and memory setup code is non-trivial, but identical. With this in mind I was wondering whether (and to what extent) an acceptable patch to support this board would require factoring out this common code?
The (non-comment) diff between my interim init code for the new board, and eval/reference board is currently: --- board/atmel/sama5d2_xplained/sama5d2_xplained.c 2020-12-15 10:52:32.175616057 +0000 +++ board/scs/cubemb1/cubemb1.c 2020-12-17 14:42:42.399610818 +0000 @@ -30,10 +30,6 @@ #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { -#ifdef CONFIG_DM_VIDEO - at91_video_show_board_info(); -#endif - at91_pda_detect(); return 0; } #endif @@ -83,13 +79,13 @@ return 0; }
-#define AT24MAC_MAC_OFFSET 0x9a +#define MAC24AA_MAC_OFFSET 0xfa
#ifdef CONFIG_MISC_INIT_R int misc_init_r(void) { #ifdef CONFIG_I2C_EEPROM - at91_set_ethaddr(AT24MAC_MAC_OFFSET); + at91_set_ethaddr(MAC24AA_MAC_OFFSET); #endif
I'm also uncertain about file naming - there seem to be a number of different conventions in use for file and directory names (different combinations of SoC, board, architecture, and manufacturer).
The new board is:
mfr: South Coast Science model: Cube MB v1
Do the following file and directory names look reasonable?
arch/arm/dts/Makefile | 3 +++ arch/arm/dts/at91-sama5d27_cubemb1.dts | 263 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-at91/Kconfig | 8 +++++++ board/scs/cubemb1/Kconfig | 15 +++++++++++++ board/scs/cubemb1/MAINTAINERS | 6 ++++++ board/scs/cubemb1/Makefile | 8 +++++++ board/scs/cubemb1/cubemb1.c | 198 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/cubemb1_emmc_defconfig | 104 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/cubemb1_sdcard_defconfig | 104 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/cubemb1.h | 9 ++++++++ 10 files changed, 718 insertions(+)
Cheers,
Tim.
On 17.12.2020 17:09, Tim Small wrote:
Hello,
-#endif
Does your board select DM_VIDEO ? If you do not require DM_VIDEO you can just disable it from your configuration
at91_pda_detect();
Does this impact your board? It should not do anything, provided that you do not have the W1 subsystem enabled in your board configuration
#endifat91_set_ethaddr(MAC24AA_MAC_OFFSET);
Here you have a different EEPROM on your board, this is correct ? For this, it may be an idea to take out that offset into some type of header configuration... Other than this, you can completely reuse the sama5d2_xplained.c ? (considering also my comments above )
The new board is:
Cheers,
Tim.
-- South East Open Source Solutions Limited Registered in England and Wales with company number 06134732. Registered Office: 2 Powell Gardens, Redhill, Surrey, RH1 1TQ VAT number: GB 900 6633 53 http://seoss.co.uk/ +44-(0)1273-808309
Eugen.Hristev@microchip.com
Tim Small
