[U-Boot] [PATCH 1/2] ARM: tegra: reserve unmapped RAM so EFI doesn't use it
Tegra U-Boot ensures that board_get_usable_ram_top() never returns a value over 4GB, since some peripherals can't access such addresses. However, on systems with more than 2GB of RAM, RAM bank 1 does describe this extra RAM, so that Linux (or whatever OS) can use it, subject to DMA limitations. Since board_get_usable_ram_top() points at the top of RAM bank 0, the memory locations describes by RAM bank 1 are not mapped by U-Boot's MMU configuration, and so cannot be used for anything.
For some completely inexplicable reason, U-Boot's EFI support ignores the value returned by board_get_usable_ram_top(), and EFI memory allocation routines will return values above U-Boot's RAM top. This causes U-Boot to crash when it accesses that RAM, since it isn't mapped by the MMU. One use-case where this happens is TFTP download of a file on Jetson TX1 (p2371-2180).
This change explicitly tells the EFI code that this extra RAM should not be used, thus avoiding the crash.
A previous attempt to make EFI honor board_get_usable_ram_top() was rejected. So, this patch will need to be replicated for any board that implements board_get_usable_ram_top().
Fixes: aa909462d018 ("efi_loader: efi_allocate_pages is too restrictive") Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/mach-tegra/board2.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 421a71b3014d..869d5d99d2fd 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <efi_loader.h> #include <errno.h> #include <ns16550.h> #include <usb.h> @@ -210,6 +211,19 @@ int board_early_init_f(void)
int board_late_init(void) { +#ifdef CONFIG_EFI_LOADER + if (gd->bd->bi_dram[1].start) { + /* + * Only bank 0 is below board_get_usable_ram_top(), so all of + * bank 1 is not mapped by the U-Boot MMU configuration, and so + * we must prevent EFI from using it. + */ + efi_add_memory_map(gd->bd->bi_dram[1].start, + gd->bd->bi_dram[1].size / 4096, + EFI_RESERVED_MEMORY_TYPE, false); + } +#endif + #if defined(CONFIG_TEGRA_SUPPORT_NON_SECURE) if (tegra_cpu_is_non_secure()) { printf("CPU is in NS mode\n");
This reverts commit ccfc78b820e5e431c5bd73b072e7536a972e1710.
Now that the underlying issue is fixed, we can revert the revert and hence restore the original EFI code.
Signed-off-by: Stephen Warren swarren@nvidia.com --- lib/efi_loader/efi_memory.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index e2b40aa85b5a..e902d5a280bb 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -304,7 +304,7 @@ efi_status_t efi_allocate_pages(int type, int memory_type, switch (type) { case EFI_ALLOCATE_ANY_PAGES: /* Any page */ - addr = efi_find_free_memory(len, gd->start_addr_sp); + addr = efi_find_free_memory(len, -1ULL); if (!addr) { r = EFI_NOT_FOUND; break;
- if (gd->bd->bi_dram[1].start) {
Please, do not hard code the page size here. You can use
EFI_PAGE_SHIFT. The constant is defined in efi.h.
The EFI spec says:
"Regions that are backed by physical hardware, but are not supposed to be accessed by the OS, must be returned as EfiReservedMemoryType."
I assume this is not what you want. To only avoid that the U-Boot EFI implementation uses the memory make it EFI_BOOT_SERVICES_DATA.
Best regards
Heinrich
The EFI spec says:
Basically it boils down to what the memory is reserved for. For DRAM that the OS should use, use EFI_BOOT_SERVICES_DATA. That way no U-Boot allocations will use the memory, but Linux for example will.
If the memory however should not be used by an OS either (like a reserved ATF region), then mark it as reserved.
Alex
Alexander Graf
Stephen Warren
